[petsc-users] Using C routines in PETSc code
Smith, Barry F. bsmith at mcs.anl.gov
Fri Aug 31 12:43:00 CDT 2018
> On Aug 31, 2018, at 12:12 PM, Fazlul Huq <huq2090 at gmail.com> wrote:
> Hello PETSc Developers,
> Can I use c programming routine in PETSc code and make and run it (since PETSc is written in c)?
   Of course.
> Last day I tried to do that but I got error message while making the file.
   Must be due to syntax errors in the code. You should read the error messages to determine how to fix the code.
   Barry
> Thanks.
> Huq
