[petsc-users] Integration of hyper & trilinos
Jed Brown jed at jedbrown.org
Thu Aug 30 09:40:45 CDT 2018
You would configure PETSc with --download-hypre and --download-ml (this
part of Trilinos can be installed on its own).  Then run your
application with run-time options like -pc_type hypre or -pc_type ml.
See the user's manual and/or tutorials.
Fazlul Huq <huq2090 at gmail.com> writes:
> Hello Petsc developers,
> 1. I want to integrate petsc with hyper and trilinos cause I want to solve
> some   problems using multigrid. I know, I need to download and install
> both of them and then configure petsc with hyper and trilinos to use them
> with petsc. But, I don't know how to configure petsc with hyper and
> trilinos or any other package. Is it like, running some command from
> terminal or editing .bashrc file? Currently, this is the .bashrc file
> regarding petsc in my desktop:
> export PETSC_DIR=/home/jimmy/projects/petsc
> 2. Can I use c programming routine in petsc code and make and run it? If
> yes then what is the procedure? Last day I tried to do that but I got error
> message while making the file.
> Thanks.
> Fazlul Huq
> Graduate Research Assistant
> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> University of Illinois at Urbana-Champaign (UIUC)
> E-mail: huq2090 at gmail.com
