[petsc-users] Integration of hyper & trilinos
Fazlul Huq
huq2090 at gmail.com
Thu Aug 30 10:50:33 CDT 2018
I have run:
jimmy at dave:~/projects/petsc$ ./configure --download-hyper
jimmy at dave:~/projects/petsc$ ./configure --download-ml
At the end I got following message:
xxx=========================================================================xxx
Configure stage complete. Now build PETSc libraries with (gnumake build):
make PETSC_DIR=/home/jimmy/projects/petsc PETSC_ARCH=arch-linux2-c-debug
all
Am I ready to use it now or do I need no make it first?
Or do I need to edit .bashrc file with,
export PETSC_DIR=/home/jimmy/projects/petsc
export PETSC_ARCH=arch-linux2-c-debug all
And then run make from command window?
Thanks.
Huq
On Thu, Aug 30, 2018 at 9:40 AM Jed Brown <jed at jedbrown.org> wrote:
> You would configure PETSc with --download-hypre and --download-ml (this
> part of Trilinos can be installed on its own). Then run your
> application with run-time options like -pc_type hypre or -pc_type ml.
> See the user's manual and/or tutorials.
> Fazlul Huq <huq2090 at gmail.com> writes:
> > Hello Petsc developers,
> > 1. I want to integrate petsc with hyper and trilinos cause I want to
> solve
> > some problems using multigrid. I know, I need to download and install
> > both of them and then configure petsc with hyper and trilinos to use them
> > with petsc. But, I don't know how to configure petsc with hyper and
> > trilinos or any other package. Is it like, running some command from
> > terminal or editing .bashrc file? Currently, this is the .bashrc file
> > regarding petsc in my desktop:
> > 2. Can I use c programming routine in petsc code and make and run it? If
> > yes then what is the procedure? Last day I tried to do that but I got
> error
> > message while making the file.
> > Thanks.
> > Fazlul Huq
> > Graduate Research Assistant
> > Department of Nuclear, Plasma & Radiological Engineering (NPRE)
> > University of Illinois at Urbana-Champaign (UIUC)
> > E-mail: huq2090 at gmail.com
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180830/08e1e464/attachment-0001.html>
