[petsc-users] v3.9.3 config problem
Smith, Barry F. bsmith at mcs.anl.gov
Sun Aug 19 21:13:10 CDT 2018
    The ftp site with the version 4 netcfd files does have an that look like version 5. Have to keep looking for netcdf 5 (assuming it must exist).
   Barry
> On Aug 19, 2018, at 9:05 PM, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   I can reproduce the problem so don't bother wiping anything just yet. My compiler gives more useful messages:
> s/src/ex_create_par.c:388:16: error: use of undeclared identifier 'netcdf4_mode'; did you mean 'netcdf5_mode'?
>    nc_mode |= netcdf4_mode;
>               netcdf5_mode
> So it appears that the exodusii version used requires a more recent version of netcdf but why didn't our testing detect this????
>> On Aug 19, 2018, at 9:01 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
>> Should I try wiping out the externalpackages directory as well as $PETSC_ARCH?
>> - Adrian
>> On 20/08/18 14:00, Smith, Barry F. wrote:
>>>   Trying to reproduce it now but I'm pretty sure we've tested it.
>>>   Do you have some old files lying around that might be causing the problem?
>>> /home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/git.exodusii/packages/seacas/libraries/exodus/src/ex_create_par.c:375:9: error: 'netcdf4_mode' undeclared (first use in this function)
>>>     if (netcdf4_mode == -1) {
>>> Maybe externalpackages has downloads from a previous build still located that don't work with the latest exodusii?
>>>   Barry
>>>> On Aug 19, 2018, at 8:51 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
>>>> hi
>>>> I just pulled the latest PETSc master branch (v3.9.3) but am having trouble building it. It's been running fine on v3.8.4.
>>>> I deleted my $PETSC_ARCH directory and tried to configure. But it seems to be falling over when trying to build Exodus. I've attached the configure.log.
>>>> Any ideas?
>>>> - Adrian
>>>> Dr Adrian Croucher
>>>> Senior Research Fellow
>>>> Department of Engineering Science
>>>> University of Auckland, New Zealand
>>>> email: a.croucher at auckland.ac.nz
>>>> tel: +64 (0)9 923 4611
>>>> <configure.log>
>> Dr Adrian Croucher
