[petsc-users] v3.9.3 config problem
Adrian Croucher
a.croucher at auckland.ac.nz
Sun Aug 19 21:06:37 CDT 2018
On 20/08/18 14:01, Adrian Croucher wrote:
> Should I try wiping out the externalpackages directory as well as
> $PETSC_ARCH?
I did try this anyway. First it gave the following errors:
Error! missing file:
/home/acro018/software/PETSc/code/externalpackages-bak/sowing-1.1.16d/src/sys/makefile
/home/acro018/software/PETSc/code/externalpackages-bak/sowing-1.1.16d/src/doctext/test/makefile
/home/acro018/software/PETSc/code/externalpackages-bak/sowing-1.1.16d/src/bfort/testing/makefile
Not sure if these matter. It continued but then got the same errors
trying to build Exodus.
- Adrian
> - Adrian
> On 20/08/18 14:00, Smith, Barry F. wrote:
>> Trying to reproduce it now but I'm pretty sure we've tested it.
>> Do you have some old files lying around that might be causing the
>> problem?
>> /home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/git.exodusii/packages/seacas/libraries/exodus/src/ex_create_par.c:375:9:
>> error: 'netcdf4_mode' undeclared (first use in this function)
>> if (netcdf4_mode == -1) {
>> Maybe externalpackages has downloads from a previous build still
>> located that don't work with the latest exodusii?
>> Barry
>>> On Aug 19, 2018, at 8:51 PM, Adrian Croucher
>>> <a.croucher at auckland.ac.nz> wrote:
>>> hi
>>> I just pulled the latest PETSc master branch (v3.9.3) but am having
>>> trouble building it. It's been running fine on v3.8.4.
>>> I deleted my $PETSC_ARCH directory and tried to configure. But it
>>> seems to be falling over when trying to build Exodus. I've attached
>>> the configure.log.
>>> Any ideas?
>>> - Adrian
>>> Dr Adrian Croucher
>>> Senior Research Fellow
>>> Department of Engineering Science
>>> University of Auckland, New Zealand
>>> email: a.croucher at auckland.ac.nz
>>> tel: +64 (0)9 923 4611
>>> <configure.log>
Dr Adrian Croucher
