[petsc-users] v3.9.3 config problem
Adrian Croucher
a.croucher at auckland.ac.nz
Sun Aug 19 21:01:31 CDT 2018
Should I try wiping out the externalpackages directory as well as
$PETSC_ARCH?
- Adrian
On 20/08/18 14:00, Smith, Barry F. wrote:
> Trying to reproduce it now but I'm pretty sure we've tested it.
> Do you have some old files lying around that might be causing the problem?
> /home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/git.exodusii/packages/seacas/libraries/exodus/src/ex_create_par.c:375:9: error: 'netcdf4_mode' undeclared (first use in this function)
> if (netcdf4_mode == -1) {
> Maybe externalpackages has downloads from a previous build still located that don't work with the latest exodusii?
> Barry
>> On Aug 19, 2018, at 8:51 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
>> hi
>> I just pulled the latest PETSc master branch (v3.9.3) but am having trouble building it. It's been running fine on v3.8.4.
>> I deleted my $PETSC_ARCH directory and tried to configure. But it seems to be falling over when trying to build Exodus. I've attached the configure.log.
>> Any ideas?
>> - Adrian
>> Dr Adrian Croucher
>> Senior Research Fellow
>> Department of Engineering Science
>> University of Auckland, New Zealand
>> email: a.croucher at auckland.ac.nz
>> tel: +64 (0)9 923 4611
>> <configure.log>
Dr Adrian Croucher
