[petsc-users] v3.9.3 config problem
Smith, Barry F. bsmith at mcs.anl.gov
Sun Aug 19 21:00:10 CDT 2018
   Trying to reproduce it now but I'm pretty sure we've tested it.
   Do you have some old files lying around that might be causing the problem?
/home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/git.exodusii/packages/seacas/libraries/exodus/src/ex_create_par.c:375:9: error: 'netcdf4_mode' undeclared (first use in this function)
     if (netcdf4_mode == -1) {
Maybe externalpackages has downloads from a previous build still located that don't work with the latest exodusii?
   Barry
> On Aug 19, 2018, at 8:51 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
> hi
> I just pulled the latest PETSc master branch (v3.9.3) but am having trouble building it. It's been running fine on v3.8.4.
> I deleted my $PETSC_ARCH directory and tried to configure. But it seems to be falling over when trying to build Exodus. I've attached the configure.log.
> Any ideas?
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
> <configure.log>
