[petsc-users] Problem in compiling PETSc+ML
Ali Reza Khaz'ali arkhazali at cc.iut.ac.ir
Thu Aug 16 14:29:20 CDT 2018
Thanks a lot. In fact I had built ML from Trilinos before, and I
wondered if I could use it in PETSc.
Best wishes,
Ali
On 8/16/2018 10:12 PM, Satish Balay wrote:
> Sorry - most external packages won't work with --download-pacakge
> option on windows [with MS/Intel compilers].
> If you need ML on windows - you might have to install it separately
> [by checking its windows installation instructions - if they exist]
> And then specify it to petsc configure with --with-ml-include
> --with-ml-lib options.
> Satish
> On Thu, 16 Aug 2018, Ali Reza Khaz'ali wrote:
>> Hi,
>> I have been using PETSc on a MS windows 7 x64 system with Intel MKL, MPI and
>> compilers without problem. For an specific problem, I had to use ML. However,
>> I could not compile ML with the before-mentioned toolsets.  The the log files
>> (PETSc and ML) are attached. Any help is much appreciated.
>> Thanks,
>> Ali
Ali Reza Khaz’ali
Assistant Professor of Petroleum Engineering,
Department of Chemical Engineering
Isfahan University of Technology
Isfahan, Iran
