[petsc-users] Problem in compiling PETSc+ML
Satish Balay
balay at mcs.anl.gov
Thu Aug 16 12:42:23 CDT 2018
Sorry - most external packages won't work with --download-pacakge
option on windows [with MS/Intel compilers].
If you need ML on windows - you might have to install it separately
[by checking its windows installation instructions - if they exist]
And then specify it to petsc configure with --with-ml-include
--with-ml-lib options.
Satish
On Thu, 16 Aug 2018, Ali Reza Khaz'ali wrote:
> Hi,
> I have been using PETSc on a MS windows 7 x64 system with Intel MKL, MPI and
> compilers without problem. For an specific problem, I had to use ML. However,
> I could not compile ML with the before-mentioned toolsets. The the log files
> (PETSc and ML) are attached. Any help is much appreciated.
> Thanks,
> Ali
