[petsc-users] Problem in compiling PETSc+ML
Thu Aug 16 15:15:22 CDT 2018
If you can built it from Trilinos - you should be able to use it from PETSc.
[by specifing ml to petsc with --with-ml-include,--with-ml-lib options]
This is unverified though..
Satish
On Thu, 16 Aug 2018, Ali Reza Khaz'ali wrote:
> Thanks a lot. In fact I had built ML from Trilinos before, and I wondered if I
> could use it in PETSc.
> Best wishes,
> Ali
> On 8/16/2018 10:12 PM, Satish Balay wrote:
> > Sorry - most external packages won't work with --download-pacakge
> > option on windows [with MS/Intel compilers].
> > If you need ML on windows - you might have to install it separately
> > [by checking its windows installation instructions - if they exist]
> > And then specify it to petsc configure with --with-ml-include
> > --with-ml-lib options.
> > Satish
> >> Hi,
> >> I have been using PETSc on a MS windows 7 x64 system with Intel MKL, MPI
> >> and
> >> compilers without problem. For an specific problem, I had to use ML.
> >> However,
> >> I could not compile ML with the before-mentioned toolsets.  The the log
> >> files
> >> (PETSc and ML) are attached. Any help is much appreciated.
> >> Thanks,
> >> Ali
