[petsc-users] Problem in compiling PETSc+ML
Ali Reza Khaz'ali arkhazali at cc.iut.ac.ir
Thu Aug 16 01:59:56 CDT 2018
I have been using PETSc on a MS windows 7 x64 system with Intel MKL, MPI
and compilers without problem. For an specific problem, I had to use ML.
However, I could not compile ML with the before-mentioned toolsets.  The
the log files (PETSc and ML) are attached. Any help is much appreciated.
Ali
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by ml configure 6.2, which was
generated by GNU Autoconf 2.69.  Invocation command line was
  $ ./configure --prefix=/home/alireza/Petsc393Install MAKE=/usr/bin/make --libdir=/home/alireza/Petsc393Install/lib CC=/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl CFLAGS=-O2 -MT -wd4996 -Qopenmp AR=/usr/bin/ar ARFLAGS=cr CXX=/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl CXXFLAGS=-O2 -MT -wd4996 -Qopenmp -TP F90=/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort F90FLAGS=-MT -O2 -Qopenmp -fpp F77=/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort FFLAGS=-MT -O2 -Qopenmp -fpp FC=/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort FCFLAGS=-MT -O2 -Qopenmp -fpp --disable-shared --disable-ml-epetra --disable-ml-aztecoo --disable-ml-examples --disable-tests --enable-libcheck --with-cflags=-O2 -MT -wd4996 -Qopenmp -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include CPPFLAGS=-I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include --with-fflags=-MT -O2 -Qopenmp -fpp  -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include --with-cxxflags=-O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include --enable-mpi --with-mpi-libs=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib --with-blas=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mkl/lib/intel64_win/mkl_intel_lp64_dll.lib mkl_intel_thread_dll.lib mkl_core_dll.lib libiomp5md.lib
## Platform. ##
hostname = AliReza-PC
uname -m = x86_64
uname -r = 2.10.0(0.325/5/3)
uname -s = CYGWIN_NT-6.1
uname -v = 2018-02-02 15:16
/usr/bin/uname -p = unknown
/bin/uname -X     = unknown
/bin/arch              = x86_64
/usr/bin/arch -k       = unknown
/usr/convex/getsysinfo = unknown
/usr/bin/hostinfo      = unknown
/bin/machine           = unknown
/usr/bin/oslevel       = unknown
/bin/universe          = unknown
PATH: /usr/bin
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/bin/intel64
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/compiler
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.15.26726/bin/HostX64/x64
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/VC/VCPackages
PATH: /cygdrive/c/Program Files (x86)/Microsoft SDKs/TypeScript/3.0
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TestWindow
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/Roslyn
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/x64
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64
PATH: /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64
PATH: /cygdrive/c/Program Files (x86)/HTML Help Workshop
PATH: /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17134.0/x64
PATH: /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64
PATH: /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/Tools
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/ipp
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/daal
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/tbb/vc_mt
PATH: /cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.3.210/windows/mpi/intel64/bin
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/mpirt
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/compiler
PATH: /cygdrive/e/Python37/Scripts
PATH: /cygdrive/e/Program Files (x86)/IntelSWTools/mpi/2018.1.156/intel64/bin
PATH: /cygdrive/c/Program Files/Microsoft MPI/Bin
PATH: /cygdrive/c/Program Files (x86)/Intel/MPI-RT/4.1.3.045/em64t/bin
PATH: /cygdrive/c/Program Files (x86)/CMG/CMGJobService
PATH: /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.3.050/intel64/bin
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/mpirt
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler
PATH: /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler
PATH: /cygdrive/c/ProgramData/Oracle/Java/javapath
PATH: /cygdrive/c/Python27
PATH: /cygdrive/c/Python27/Scripts
PATH: /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/bin
PATH: /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.2.044/intel64/bin
PATH: /cygdrive/c/Program Files (x86)/Intel/Composer XE 2015/bin/ia32
PATH: /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86_64
PATH: /cygdrive/c/Windows/System32
PATH: /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE
PATH: /cygdrive/e/Program Files/PuTTY
PATH: /cygdrive/c/ecl/HOME
PATH: /cygdrive/c/ecl/MACROS
PATH: /cygdrive/e/Program Files/CMake/bin
PATH: /cygdrive/e/ecl/HOME
PATH: /cygdrive/e/ecl/MACROS
PATH: /cygdrive/c/Program Files/dotnet
PATH: /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.14.26428/bin/Hostx64/x64
PATH: /cygdrive/e/Program Files (x86)/IncrediBuild
PATH: /cygdrive/e/Python36/Scripts
PATH: /cygdrive/c/Users/AliReza/.dnx/bin
PATH: /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll
PATH: /cygdrive/c/Program Files (x86)/SSH Communications Security/SSH Secure Shell
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin
PATH: /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja
## Core tests. ##
configure:2775: checking whether to enable maintainer-specific portions of Makefiles
configure:2784: result: no
configure:2804: checking build system type
configure:2818: result: x86_64-unknown-cygwin
configure:2838: checking host system type
configure:2851: result: x86_64-unknown-cygwin
configure:2871: checking target system type
configure:2884: result: x86_64-unknown-cygwin
configure:2929: checking for a BSD-compatible install
configure:2997: result: /usr/bin/install -c
configure:3008: checking whether build environment is sane
configure:3063: result: yes
configure:3214: checking for a thread-safe mkdir -p
configure:3253: result: /usr/bin/mkdir -p
configure:3260: checking for gawk
configure:3276: found /usr/bin/gawk
configure:3287: result: gawk
configure:3298: checking whether /usr/bin/make sets $(MAKE)
configure:3320: result: yes
configure:3349: checking whether /usr/bin/make supports nested variables
configure:3366: result: yes
configure:3446: checking whether UID '197608' is supported by ustar format
configure:3449: result: yes
configure:3456: checking whether GID '197121' is supported by ustar format
configure:3459: result: yes
configure:3467: checking how to create a ustar tar archive
configure:3478: tar --version
tar (GNU tar) 1.29
Packaged by Cygwin (1.29-1)
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
configure:3481: $? = 0
configure:3521: tardir=conftest.dir && eval tar --format=ustar -chf - "$tardir" >conftest.tar
configure:3524: $? = 0
configure:3528: tar -xf - <conftest.tar
configure:3531: $? = 0
configure:3533: cat conftest.dir/file
GrepMe
configure:3536: $? = 0
configure:3549: result: gnutar
configure:3754: checking user-defined MPI libraries
configure:3756: result: /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib
configure:3791: checking whether we are using MPI
configure:3793: result: yes
configure:4098: checking for C++ compiler version
configure:4107: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl --version >&5
Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
configure:4118: $? = 0
configure:4107: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -v >&5
icl: command line warning #10006: ignoring unknown option '/v'
icl: command line error: no files specified; for help type "icl /help"
configure:4118: $? = 1
configure:4107: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -V >&5
configure:4107: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -qversion >&5
icl: command line warning #10006: ignoring unknown option '/qversion'
configure:4138: checking whether the C++ compiler works
configure:4160: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include  conftest.cpp  >&5
conftest.cpp
configure:4164: $? = 0
configure:4212: result: yes
configure:4215: checking for C++ compiler default output file name
configure:4217: result: conftest.exe
configure:4223: checking for suffix of executables
configure:4230: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -o conftest.exe -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include  conftest.cpp  >&5
conftest.cpp
configure:4234: $? = 0
configure:4256: result: .exe
configure:4278: checking whether we are cross compiling
configure:4286: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -o conftest.exe -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include  conftest.cpp  >&5
conftest.cpp
configure:4290: $? = 0
configure:4297: ./conftest.exe
configure:4301: $? = 0
configure:4316: result: no
configure:4321: checking for suffix of object files
configure:4343: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:4347: $? = 0
configure:4368: result: o
configure:4372: checking whether we are using the GNU C++ compiler
configure:4391: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.cpp(15): error: identifier "choke" is undefined
         choke me
compilation aborted for E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.cpp (code 2)
configure:4391: $? = 2
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME "ml"
| #define PACKAGE_TARNAME "ml"
| #define PACKAGE_VERSION "6.2"
| #define PACKAGE_STRING "ml 6.2"
| #define PACKAGE_BUGREPORT "jhu at sandia.gov"
| #define PACKAGE_URL ""
| #define HAVE_MPI /**/
| /* end confdefs.h.  */
| int
| main ()
| #ifndef __GNUC__
|        choke me
| #endif
|   return 0;
configure:4400: result: no
configure:4409: checking whether /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl accepts -g
configure:4429: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -g -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:4429: $? = 0
configure:4470: result: yes
configure:4504: checking for style of include used by /usr/bin/make
configure:4532: result: GNU
configure:4558: checking dependency style of /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl
configure:4669: result: msvc7
configure:4821: checking for C compiler version
configure:4830: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl --version >&5
configure:4841: $? = 0
configure:4830: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -v >&5
configure:4841: $? = 1
configure:4830: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -V >&5
configure:4830: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -qversion >&5
configure:4845: checking whether we are using the GNU C compiler
configure:4864: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.c >&5
conftest.c
E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.c(15): error: identifier "choke" is undefined
         choke me
compilation aborted for E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.c (code 2)
configure:4864: $? = 2
| /* confdefs.h */
| int
| main ()
| #ifndef __GNUC__
|        choke me
| #endif
|   return 0;
configure:4873: result: no
configure:4882: checking whether /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl accepts -g
configure:4902: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -g -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.c >&5
conftest.c
configure:4902: $? = 0
configure:4943: result: yes
configure:4960: checking for /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl option to accept ISO C89
configure:5023: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -c -O2 -MT -wd4996 -Qopenmp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.c >&5
conftest.c
configure:5023: $? = 0
configure:5036: result: none needed
configure:5061: checking whether /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl understands -c and -o together
configure:5083: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c conftest.c -o conftest2.o
conftest.c
configure:5086: $? = 0
conftest.c
configure:5098: result: yes
configure:5117: checking dependency style of /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl
configure:5228: result: msvc7
configure:5349: checking for Fortran 77 compiler version
configure:5358: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort --version >&5
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
configure:5369: $? = 0
configure:5358: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -v >&5
ifort: command line warning #10006: ignoring unknown option '/v'
ifort: command line error: no files specified; for help type "ifort /help"
configure:5369: $? = 1
configure:5358: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -V >&5
configure:5358: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -qversion >&5
ifort: command line warning #10006: ignoring unknown option '/qversion'
configure:5378: checking whether we are using the GNU Fortran 77 compiler
configure:5391: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -MT -O2 -Qopenmp -fpp conftest.F >&5
E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.F(3): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
       choke me
compilation aborted for E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.F (code 1)
configure:5391: $? = 1
|       program main
| #ifndef __GNUC__
|        choke me
| #endif
|       end
configure:5400: result: no
configure:5406: checking whether /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort accepts -g
configure:5417: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -g conftest.f >&5
configure:5417: $? = 0
configure:5425: result: yes
configure:5497: checking for ranlib
configure:5513: found /usr/bin/ranlib
configure:5524: result: ranlib
configure:5554: checking finding build directory
configure:5557: result: /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml
configure:5580: checking whether additional CCFLAGS flags should be added
configure:5591: result: no
configure:5598: checking whether additional CXXFLAGS flags should be added
configure:5605: result: CXXFLAGS = -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP
configure:5636: checking whether additional CFLAGS flags should be added
configure:5643: result: CFLAGS = -O2 -MT -wd4996 -Qopenmp -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp
configure:5654: checking whether additional FFLAGS flags should be added
configure:5661: result: FFLAGS = -MT -O2 -Qopenmp -fpp  -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp
configure:5672: checking whether additional libraries are needed
configure:5683: result: no
configure:5691: checking whether additional LDFLAGS flags should be added
configure:5702: result: no
configure:5735: checking for special archiver command
configure:5749: result: none
configure:5772: checking how to run the C++ preprocessor
configure:5799: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:5799: $? = 0
configure:5813: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:5813: $? = 2
| /* confdefs.h */
| #include <ac_nonexistent.h>
configure:5838: result: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E
configure:5858: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:5858: $? = 0
configure:5872: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:5872: $? = 2
| /* confdefs.h */
configure:5919: checking for mpi.h
configure:5925: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:5925: $? = 0
configure:5926: result: yes
configure:5989: checking whether to build export makefiles
configure:5994: result: yes
configure:6066: checking for perl
configure:6082: found /usr/bin/perl
configure:6094: result: yes
configure:6136: checking whether gnumake specific code should be enabled
configure:6146: result: no
configure:6175: checking for grep that handles long lines and -e
configure:6233: result: /usr/bin/grep
configure:6238: checking for egrep
configure:6300: result: /usr/bin/grep -E
configure:6305: checking for ANSI C header files
configure:6325: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6325: $? = 0
configure:6398: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -o conftest.exe -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include  conftest.cpp /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib  >&5
conftest.cpp
configure:6398: $? = 0
configure:6398: ./conftest.exe
configure:6409: result: yes
configure:6422: checking for sys/types.h
configure:6422: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6422: $? = 0
configure:6422: result: yes
configure:6422: checking for sys/stat.h
conftest.cpp
configure:6422: checking for stdlib.h
conftest.cpp
configure:6422: checking for string.h
conftest.cpp
configure:6422: checking for memory.h
conftest.cpp
configure:6422: checking for strings.h
conftest.cpp
E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.cpp(51): catastrophic error: cannot open source file "strings.h"
  #include <strings.h>
compilation aborted for E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.cpp (code 4)
configure:6422: $? = 4
| /* confdefs.h */
| #define HAVE_EXPORT_MAKEFILES /**/
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #include <stdio.h>
| #ifdef HAVE_SYS_TYPES_H
| # include <sys/types.h>
| #endif
| #ifdef HAVE_SYS_STAT_H
| # include <sys/stat.h>
| #endif
| #ifdef STDC_HEADERS
| # include <stdlib.h>
| # include <stddef.h>
| #else
| # ifdef HAVE_STDLIB_H
| # endif
| #endif
| #ifdef HAVE_STRING_H
| # if !defined STDC_HEADERS && defined HAVE_MEMORY_H
| #  include <memory.h>
| # endif
| # include <string.h>
| #endif
| #ifdef HAVE_STRINGS_H
| # include <strings.h>
| #endif
| #ifdef HAVE_INTTYPES_H
| # include <inttypes.h>
| #endif
| #ifdef HAVE_STDINT_H
| # include <stdint.h>
| #endif
| #ifdef HAVE_UNISTD_H
| # include <unistd.h>
| #endif
configure:6422: result: no
configure:6422: checking for inttypes.h
conftest.cpp
configure:6422: checking for stdint.h
conftest.cpp
configure:6422: checking for unistd.h
conftest.cpp
E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.cpp(53): catastrophic error: cannot open source file "unistd.h"
  #include <unistd.h>
| /* confdefs.h */
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #include <stdio.h>
| #endif
| #endif
| #ifdef STDC_HEADERS
| #else
| # endif
| #endif
| # endif
| #endif
| #endif
| #endif
| #endif
| #endif
| #include <unistd.h>
configure:6437: checking cstdlib usability
configure:6437: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6437: $? = 0
configure:6437: result: yes
configure:6437: checking cstdlib presence
configure:6437: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6437: checking for cstdlib
configure:6450: checking cstdio usability
configure:6450: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6450: $? = 0
configure:6450: result: yes
configure:6450: checking cstdio presence
configure:6450: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6450: checking for cstdio
configure:6463: checking cassert usability
configure:6463: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6463: $? = 0
configure:6463: result: yes
configure:6463: checking cassert presence
configure:6463: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6463: checking for cassert
configure:6476: checking cmath usability
configure:6476: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6476: $? = 0
configure:6476: result: yes
configure:6476: checking cmath presence
configure:6476: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6476: checking for cmath
configure:6489: checking iomanip usability
configure:6489: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6489: $? = 0
configure:6489: result: yes
configure:6489: checking iomanip presence
configure:6489: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6489: checking for iomanip
configure:6502: checking iostream usability
configure:6502: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6502: $? = 0
configure:6502: result: yes
configure:6502: checking iostream presence
configure:6502: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6502: checking for iostream
configure:6515: checking string usability
configure:6515: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6515: $? = 0
configure:6515: result: yes
configure:6515: checking string presence
configure:6515: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6515: checking for string
configure:6527: checking malloc.h usability
configure:6527: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6527: $? = 0
configure:6527: result: yes
configure:6527: checking malloc.h presence
configure:6527: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp
configure:6527: checking for malloc.h
configure:6643: checking for inline
configure:6659: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6659: $? = 0
configure:6667: result: inline
configure:6690: checking whether the compiler implements namespaces
configure:6713: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6713: $? = 0
configure:6727: result: yes
configure:6735: checking whether the compiler supports Standard Template Library
configure:6764: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6764: $? = 0
configure:6778: result: yes
configure:6786: checking whether the compiler recognizes bool as a built-in type
configure:6813: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6813: $? = 0
configure:6827: result: yes
configure:6835: checking whether the compiler supports the mutable keyword
configure:6863: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6863: $? = 0
configure:6877: result: yes
configure:6888: checking whether the compiler accepts the new for scoping rules
configure:6917: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6917: $? = 0
configure:6931: result: yes
configure:6940: checking whether the compiler recognizes std::sprintf as supported IO function
configure:6970: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6970: $? = 0
configure:6995: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:6995: $? = 0
configure:7015: result: yes
configure:7024: checking whether /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl recognizes __PRETTY_FUNCTION__
configure:7037: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include conftest.cpp >&5
conftest.cpp
configure:7037: $? = 0
configure:7055: result: yes
configure:7133: checking whether to use ml_newtpe
configure:7137: result: yes
configure:7160: checking whether to use ml_enrich
configure:7170: result: no
configure:7185: checking whether to use ml_aztec2_1
configure:7195: result: no
configure:7209: checking whether to use ml_complex_maxwell
configure:7219: result: no
configure:7234: checking whether to use ml_timing
configure:7244: result: no
configure:7258: checking whether to use ml_memory_checking
configure:7268: result: no
configure:7282: checking whether to use ml_flops
configure:7292: result: no
configure:7306: checking whether to use ml_benchmarking
configure:7316: result: no
configure:7366: checking whether to use ml_superlu
configure:7376: result: no
configure:7391: checking whether to use ml_superlu2
configure:7401: result: no
configure:7416: checking whether to use ml_superlu_dist
configure:7426: result: no
configure:7441: checking whether to use ml_metis
configure:7451: result: no
configure:7466: checking whether to use ml_parmetis2x
configure:7476: result: no
configure:7491: checking whether to use ml_parmetis3x
configure:7501: result: no
configure:7516: checking whether to use ml_arpack
configure:7526: result: no
configure:7541: checking whether to use ml_parpack
configure:7551: result: no
configure:7566: checking whether to use ml_parasails
configure:7576: result: no
configure:7591: checking whether to use ml_nox
configure:7601: result: no
configure:7624: checking whether to use ml_zoltan
configure:7634: result: no
configure:7657: checking whether to use ml_zoltan3
configure:7667: result: no
configure:7690: checking whether to use petsc
configure:7700: result: no
configure:7734: checking whether to build optional epetra dependent code in ml
configure:7744: result: no
configure:7783: checking whether to build optional amesos dependent code in ml
configure:7793: result: no
configure:7844: checking whether to build optional ifpack dependent code in ml
configure:7854: result: no
configure:7893: checking whether to build optional teuchos dependent code in ml
configure:7903: result: no
configure:7944: checking whether to build optional aztecoo dependent code in ml
configure:7954: result: no
configure:7993: checking whether to build optional epetraext dependent code in ml
configure:8003: result: no
configure:8049: checking whether to build optional isorropia dependent code in ml
configure:8059: result: no
configure:8098: checking whether to build optional galeri dependent code in ml
configure:8108: result: no
configure:8165: checking whether to use ml-examples
configure:8175: result: no
configure:8199: checking whether to use tests
configure:8209: result: no
configure:8230: checking whether to use ml-tests
configure:8240: result: no
configure:8284: checking whether to use libcheck
configure:8288: result: yes
configure:8305: checking whether additional library search paths defined
configure:8316: result: no
configure:8324: checking whether additional include search paths defined
configure:8335: result: no
configure:8352: checking how to get verbose linking output from /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort
configure:8362: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -MT -O2 -Qopenmp -fpp  -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp conftest.f >&5
configure:8362: $? = 0
configure:8380: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -o conftest.exe -MT -O2 -Qopenmp -fpp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp -v conftest.f /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib
configure:8380: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -o conftest.exe -MT -O2 -Qopenmp -fpp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp -verbose conftest.f /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib
ifort: command line warning #10006: ignoring unknown option '/verbose'
configure:8380: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -o conftest.exe -MT -O2 -Qopenmp -fpp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp --verbose conftest.f /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib
Attempting to create file: C:\Users\AliReza\AppData\Local\Temp\wfeC4B9.tmp
ifort
del C:\Users\AliReza\AppData\Local\Temp\wfeC4B9.tmp
Attempting to create file: C:\Users\AliReza\AppData\Local\Temp\wfeC4E9.tmp
ifort -MT -O2 -Qopenmp -fpp -IE:\PROGRA~4\INTELS~1\COMPIL~2\windows\mpi\intel64\include -MT -O2 -Qopenmp -fpp conftest.f E:\PROGRA~4\INTELS~1\COMPIL~2\windows\mpi\intel64\lib\impi.lib -FeE:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.exe -link
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 14.15.26726.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:E:\cygwin64\home\alireza\petsc-3.9.3\arch-mswin-c-opt\externalpackages\git.ml\conftest.exe
-subsystem:console
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
conftest.obj
del C:\Users\AliReza\AppData\Local\Temp\wfeC4E9.tmp
configure:8463: result: --verbose
configure:8465: checking for Fortran 77 libraries of /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort
configure:8488: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -o conftest.exe -MT -O2 -Qopenmp -fpp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp --verbose conftest.f /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib
Attempting to create file: C:\Users\AliReza\AppData\Local\Temp\wfeC758.tmp
ifort
del C:\Users\AliReza\AppData\Local\Temp\wfeC758.tmp
Attempting to create file: C:\Users\AliReza\AppData\Local\Temp\wfeC778.tmp
-subsystem:console
conftest.obj
del C:\Users\AliReza\AppData\Local\Temp\wfeC778.tmp
configure:8684: result:  -link
configure:8701: checking for dummy main to link with Fortran 77 libraries
configure:8735: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -o conftest.exe -O2 -MT -wd4996 -Qopenmp -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include  conftest.c /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib   -link
 >&5
conftest.c
LINK : fatal error LNK1181: cannot open input file 'libink.obj'
configure:8735: $? = 157
| /* confdefs.h */
| #define HAVE_CSTDLIB 1
| #define HAVE_CSTDIO 1
| #define HAVE_CASSERT 1
| #define HAVE_CMATH 1
| #define HAVE_IOMANIP 1
| #define HAVE_IOSTREAM 1
| #define HAVE_STRING 1
| #define HAVE_MALLOC_H 1
| #define HAVE_NAMESPACES /**/
| #define HAVE_STL /**/
| #define HAVE_BOOL /**/
| #define HAVE_MUTABLE /**/
| #define HAVE_NEW_FOR_SCOPING /**/
| #define HAVE_STD_SPRINTF /**/
| #define HAVE_CFUNC /**/
| #define HAVE_ML_NEW_T_PE 1
| #define ML_BIG_INT int
| #define HAVE_LIBCHECK /**/
| #ifdef F77_DUMMY_MAIN
| #  ifdef __cplusplus
|      extern "C"
| #  endif
|    int F77_DUMMY_MAIN() { return 1; }
| #endif
| int
| main ()
|   return 0;
configure:8764: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -o conftest.exe -O2 -MT -wd4996 -Qopenmp -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include  conftest.c /cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib   -link
 >&5
conftest.c
configure:8764: $? = 157
| /* confdefs.h */
| #define F77_DUMMY_MAIN MAIN__
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #define F77_DUMMY_MAIN __main
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #define F77_DUMMY_MAIN _MAIN
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #define F77_DUMMY_MAIN __MAIN
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #define F77_DUMMY_MAIN main_
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #define F77_DUMMY_MAIN main__
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
 >&5
conftest.c
| /* confdefs.h */
| #define F77_DUMMY_MAIN _main
| #  ifdef __cplusplus
|      extern "C"
| #  endif
| #endif
| int
| main ()
|   return 0;
configure:8780: result: unknown
configure:8797: error: in `/home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml':
configure:8799: error: linking to Fortran libraries from C fails
See `config.log' for more details
## Cache variables. ##
ac_cv_build=x86_64-unknown-cygwin
ac_cv_c_compiler_gnu=no
ac_cv_c_inline=inline
ac_cv_c_var_func=yes
ac_cv_cxx_bool=yes
ac_cv_cxx_compiler_gnu=no
ac_cv_cxx_have_stl=yes
ac_cv_cxx_mutable=yes
ac_cv_cxx_namespaces=yes
ac_cv_cxx_new_for_scoping=yes
ac_cv_cxx_std_sprintf1=yes
ac_cv_cxx_std_sprintf2=yes
ac_cv_cxx_std_sprintf=yes
ac_cv_env_CCC_set=
ac_cv_env_CCC_value=
ac_cv_env_CC_set=set
ac_cv_env_CC_value='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl'
ac_cv_env_CFLAGS_set=set
ac_cv_env_CFLAGS_value='-O2 -MT -wd4996 -Qopenmp'
ac_cv_env_CPPFLAGS_set=set
ac_cv_env_CPPFLAGS_value=-I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=set
ac_cv_env_CXXFLAGS_value='-O2 -MT -wd4996 -Qopenmp -TP'
ac_cv_env_CXX_set=set
ac_cv_env_CXX_value='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl'
ac_cv_env_F77_set=set
ac_cv_env_F77_value='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort'
ac_cv_env_FFLAGS_set=set
ac_cv_env_FFLAGS_value='-MT -O2 -Qopenmp -fpp'
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_LIBS_set=
ac_cv_env_LIBS_value=
ac_cv_env_MATLAB_EXE_set=
ac_cv_env_MATLAB_EXE_value=
ac_cv_env_MATLAB_set=
ac_cv_env_MATLAB_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_exeext=.exe
ac_cv_f77_compiler_gnu=no
ac_cv_f77_dummy_main=unknown
ac_cv_f77_libs=' -link
ac_cv_fortran_dummy_main=unknown
ac_cv_header_cassert=yes
ac_cv_header_cmath=yes
ac_cv_header_cstdio=yes
ac_cv_header_cstdlib=yes
ac_cv_header_inttypes_h=yes
ac_cv_header_iomanip=yes
ac_cv_header_iostream=yes
ac_cv_header_malloc_h=yes
ac_cv_header_memory_h=yes
ac_cv_header_stdc=yes
ac_cv_header_stdint_h=yes
ac_cv_header_stdlib_h=yes
ac_cv_header_string=yes
ac_cv_header_string_h=yes
ac_cv_header_strings_h=no
ac_cv_header_sys_stat_h=yes
ac_cv_header_sys_types_h=yes
ac_cv_header_unistd_h=no
ac_cv_host=x86_64-unknown-cygwin
ac_cv_implicit_use_amesos=no
ac_cv_implicit_use_aztecoo=no
ac_cv_implicit_use_epetra=no
ac_cv_implicit_use_epetraext=no
ac_cv_implicit_use_galeri=no
ac_cv_implicit_use_ifpack=no
ac_cv_implicit_use_isorropia=no
ac_cv_implicit_use_teuchos=no
ac_cv_ml_using_amesos_default=no
ac_cv_ml_using_aztecoo_default=no
ac_cv_ml_using_epetra_default=no
ac_cv_ml_using_epetraext_default=no
ac_cv_ml_using_galeri_default=no
ac_cv_ml_using_ifpack_default=no
ac_cv_ml_using_isorropia_default=no
ac_cv_ml_using_teuchos_default=no
ac_cv_objext=o
ac_cv_path_EGREP='/usr/bin/grep -E'
ac_cv_path_GREP=/usr/bin/grep
ac_cv_path_install='/usr/bin/install -c'
ac_cv_path_mkdir=/usr/bin/mkdir
ac_cv_prog_AWK=gawk
ac_cv_prog_CXXCPP='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E'
ac_cv_prog_HAVE_PERL=yes
ac_cv_prog_ac_ct_RANLIB=ranlib
ac_cv_prog_cc_c89=
ac_cv_prog_cc_g=yes
ac_cv_prog_cxx_g=yes
ac_cv_prog_f77_g=yes
ac_cv_prog_f77_v=--verbose
ac_cv_prog_make__usr_bin_make_set=yes
ac_cv_target=x86_64-unknown-cygwin
ac_cv_use_amesos=no
ac_cv_use_aztecoo=no
ac_cv_use_epetra=no
ac_cv_use_epetraext=no
ac_cv_use_examples=yes
ac_cv_use_export_makefiles=yes
ac_cv_use_galeri=no
ac_cv_use_gnumake=no
ac_cv_use_ifpack=no
ac_cv_use_isorropia=no
ac_cv_use_libcheck=yes
ac_cv_use_ml_arpack=no
ac_cv_use_ml_aztec2_1=no
ac_cv_use_ml_benchmarking=no
ac_cv_use_ml_complex_maxwell=no
ac_cv_use_ml_enrich=no
ac_cv_use_ml_examples=no
ac_cv_use_ml_flops=no
ac_cv_use_ml_memory_checking=no
ac_cv_use_ml_metis=no
ac_cv_use_ml_multiple_rhs=no
ac_cv_use_ml_newtpe=yes
ac_cv_use_ml_nox=no
ac_cv_use_ml_parasails=no
ac_cv_use_ml_parmetis2x=no
ac_cv_use_ml_parmetis3x=no
ac_cv_use_ml_parpack=no
ac_cv_use_ml_superlu2=no
ac_cv_use_ml_superlu=no
ac_cv_use_ml_superlu_dist=no
ac_cv_use_ml_tests=no
ac_cv_use_ml_timing=no
ac_cv_use_ml_zoltan3=no
ac_cv_use_ml_zoltan=no
ac_cv_use_petsc=no
ac_cv_use_tests=no
ac_cv_use_teuchos=no
am_cv_CC_dependencies_compiler_type=msvc7
am_cv_CXX_dependencies_compiler_type=msvc7
am_cv_make_support_nested_variables=yes
am_cv_prog_cc_c_o=yes
am_cv_prog_tar_ustar=gnutar
## Output variables. ##
ACLOCAL='${SHELL} /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml/config/missing aclocal-1.15'
ALTERNATE_AR=''
AMDEPBACKSLASH='\'
AMDEP_FALSE='#'
AMDEP_TRUE=''
AMTAR='$${TAR-tar}'
AM_BACKSLASH='\'
AM_DEFAULT_V='$(AM_DEFAULT_VERBOSITY)'
AM_DEFAULT_VERBOSITY='1'
AM_V='$(V)'
AUTOCONF='${SHELL} /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml/config/missing autoconf'
AUTOHEADER='${SHELL} /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml/config/missing autoheader'
AUTOMAKE='${SHELL} /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml/config/missing automake-1.15'
AWK='gawk'
BLAS_LIBS=''
BUILD_MATLAB_FALSE=''
BUILD_MATLAB_TRUE=''
BUILD_ML_MATLAB_FALSE=''
BUILD_ML_MATLAB_TRUE=''
BUILD_TESTS_FALSE=''
BUILD_TESTS_TRUE='#'
CC='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl'
CCDEPMODE='depmode=msvc7'
CFLAGS='-O2 -MT -wd4996 -Qopenmp -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp'
CPPFLAGS='-I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include'
CXX='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl'
CXXDEPMODE='depmode=msvc7'
CXXFLAGS='-O2 -MT -wd4996 -Qopenmp -TP -DMPICH_SKIP_MPICXX -DOMPI_SKIP_MPICXX -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -O2 -MT -wd4996 -Qopenmp -TP'
CYGPATH_W='cygpath -w'
DEFS=''
DEPDIR='.deps'
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EXEEXT='.exe'
F77='/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort'
FFLAGS='-MT -O2 -Qopenmp -fpp  -I/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include -MT -O2 -Qopenmp -fpp'
FLIBS=' -link
GREP='/usr/bin/grep'
HAVE_MPI_FALSE='#'
HAVE_MPI_TRUE=''
HAVE_PERL='yes'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='$(install_sh) -c -s'
LAPACK_LIBS=''
LDFLAGS=''
LIBOBJS=''
LIBS='/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib '
LTLIBOBJS=''
MAINT='#'
MAINTAINER_MODE_FALSE=''
MAINTAINER_MODE_TRUE='#'
MAKEINFO='${SHELL} /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml/config/missing makeinfo'
MATLAB=''
MATLAB_EXE=''
MATLAB_ROOT=''
MATLAB_ROOT_USE_FALSE=''
MATLAB_ROOT_USE_TRUE=''
MATLAB_USE_FALSE=''
MATLAB_USE_TRUE=''
MEX=''
MEXEXT=''
MEXEXT_VALUE=''
MKDIR_P='/usr/bin/mkdir -p'
ML_BENCHMARKING_FALSE=''
ML_BENCHMARKING_TRUE='#'
ML_BUILD_DIRECTORY='/home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml'
ML_BUILD_EXAMPLES_FALSE=''
ML_BUILD_EXAMPLES_TRUE='#'
ML_CFUNC_FALSE='#'
ML_CFUNC_TRUE=''
ML_MATLAB_INCLUDES=''
ML_STANDALONE_MODE_FALSE='#'
ML_STANDALONE_MODE_TRUE=''
ML_USING_AMESOS_FALSE=''
ML_USING_AMESOS_TRUE='#'
ML_USING_AZTECOO_FALSE=''
ML_USING_AZTECOO_TRUE='#'
ML_USING_EPETRAEXT_FALSE=''
ML_USING_EPETRAEXT_TRUE='#'
ML_USING_EPETRA_FALSE=''
ML_USING_EPETRA_TRUE='#'
ML_USING_GALERI_FALSE=''
ML_USING_GALERI_TRUE='#'
ML_USING_IFPACK_FALSE=''
ML_USING_IFPACK_TRUE='#'
ML_USING_ISORROPIA_FALSE=''
ML_USING_ISORROPIA_TRUE='#'
ML_USING_NOX_FALSE=''
ML_USING_NOX_TRUE='#'
ML_USING_TEUCHOS_FALSE=''
ML_USING_TEUCHOS_TRUE='#'
ML_USING_ZOLTAN_FALSE=''
ML_USING_ZOLTAN_TRUE='#'
MPI_CC_EXISTS=''
MPI_CXX=''
MPI_CXX_EXISTS=''
MPI_F77_EXISTS=''
MPI_TEMP_CXX=''
OBJEXT='o'
PACKAGE='ml'
PACKAGE_BUGREPORT='jhu at sandia.gov'
PACKAGE_NAME='ml'
PACKAGE_STRING='ml 6.2'
PACKAGE_TARNAME='ml'
PACKAGE_URL=''
PACKAGE_VERSION='6.2'
PATH_SEPARATOR=':'
PERL_EXE='perl'
RANLIB='ranlib'
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
SUB_EXAMPLE_FALSE=''
SUB_EXAMPLE_TRUE='#'
SUB_TEST_FALSE=''
SUB_TEST_TRUE='#'
TRILINOS_TEMPLATE_OBJS=''
USE_ALTERNATE_AR_FALSE=''
USE_ALTERNATE_AR_TRUE='#'
USING_EXPORT_MAKEFILES_FALSE='#'
USING_EXPORT_MAKEFILES_TRUE=''
USING_GNUMAKE_FALSE=''
USING_GNUMAKE_TRUE='#'
USING_PERL_FALSE='#'
USING_PERL_TRUE=''
VERSION='6.2'
ac_aux_dir='config'
ac_ct_CC=''
ac_ct_CXX=''
ac_ct_F77=''
am__EXEEXT_FALSE=''
am__EXEEXT_TRUE=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE='#'
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE='#'
am__include='include'
am__isrc=''
am__leading_dot='.'
am__nodep='_no'
am__quote=''
am__tar='tar --format=ustar -chf - "$$tardir"'
am__untar='tar -xf -'
bindir='${exec_prefix}/bin'
build='x86_64-unknown-cygwin'
build_alias=''
build_cpu='x86_64'
build_os='cygwin'
build_vendor='unknown'
datadir='${datarootdir}'
datarootdir='${prefix}/share'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
dvidir='${docdir}'
exec_prefix='NONE'
host='x86_64-unknown-cygwin'
host_alias=''
host_cpu='x86_64'
host_os='cygwin'
host_vendor='unknown'
htmldir='${docdir}'
includedir='${prefix}/include'
infodir='${datarootdir}/info'
install_sh='${SHELL} /home/alireza/petsc-3.9.3/arch-mswin-c-opt/externalpackages/git.ml/config/install-sh'
libdir='/home/alireza/Petsc393Install/lib'
libexecdir='${exec_prefix}/libexec'
localedir='${datarootdir}/locale'
localstatedir='${prefix}/var'
mandir='${datarootdir}/man'
mkdir_p='$(MKDIR_P)'
oldincludedir='/usr/include'
pdfdir='${docdir}'
prefix='/home/alireza/Petsc393Install'
program_transform_name='s,x,x,'
psdir='${docdir}'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target='x86_64-unknown-cygwin'
target_alias=''
target_cpu='x86_64'
target_os='cygwin'
target_vendor='unknown'
## confdefs.h. ##
/* confdefs.h */
configure: exit 1
                              Pushing language C
                              Popping language C
                              Pushing language CUDA
                              Popping language CUDA
                              Pushing language Cxx
                              Popping language Cxx
                              Pushing language FC
                              Popping language FC
Starting configure run at Thu, 16 Aug 2018 11:12:16 +0430
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/home/alireza/Petsc393Install --download-ml=1 --download-hypre –with-openmp --with-cc="win32fe icl" --with-fc="win32fe ifort" --with-mpi-include=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/include --with-mpi-lib=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/lib/impi.lib --with-mpi-mpiexec=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin/mpiexec.exe --with-debugging=0 --with-blaslapack-dir=/cygdrive/E/Program_Files_x86/IntelSWTools/compilers_and_libraries/windows/mkl/lib/intel64_win -CFLAGS="-O2 -MT -wd4996 -Qopenmp" -CXXFLAGS="-O2 -MT -wd4996 -Qopenmp" -FFLAGS="-MT -O2 -Qopenmp"
Working directory: /home/alireza/petsc-3.9.3
Machine platform:
('CYGWIN_NT-6.1', 'AliReza-PC', '2.10.0(0.325/5/3)', '2018-02-02 15:16', 'x86_64', '')
Python version:
2.7.14 (default, Oct 31 2017, 21:12:13)
[GCC 6.4.0]
          Pushing language C
          Popping language C
          Pushing language FC
          Popping language FC
TEST configureExternalPackagesDir from config.framework(/home/alireza/petsc-3.9.3/config/BuildSystem/config/framework.py:836)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:836)
TEST configureDebuggers from config.utilities.debuggers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program /usr/bin/gdb...found
                Defined make macro "GDB" to "/usr/bin/gdb"
Checking for program /usr/bin/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/bin/intel64/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/compiler/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.15.26726/bin/HostX64/x64/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/VC/VCPackages/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/TypeScript/3.0/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TestWindow/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/Roslyn/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/x64/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17134.0/x64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/dbx...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/Tools/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/ipp/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/daal/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/tbb/vc_mt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.3.210/windows/mpi/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/mpirt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/compiler/dbx...not found
Checking for program /cygdrive/e/Python37/Scripts/dbx...not found
Checking for program /cygdrive/e/Python37/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/mpi/2018.1.156/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI-RT/4.1.3.045/em64t/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/CMG/CMGJobService/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.3.050/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/mpirt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/dbx...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/dbx...not found
Checking for program /cygdrive/c/Python27/dbx...not found
Checking for program /cygdrive/c/Python27/Scripts/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.2.044/intel64/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Composer XE 2015/bin/ia32/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86_64/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86/dbx...not found
Checking for program /cygdrive/c/Progra/dbx...not found
Checking for program /cygdrive/c/Windows/System32/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/dbx...not found
Checking for program /cygdrive/e/Program Files/PuTTY/dbx...not found
Checking for program /cygdrive/c/ecl/HOME/dbx...not found
Checking for program /cygdrive/c/ecl/MACROS/dbx...not found
Checking for program /cygdrive/e/Program Files/CMake/bin/dbx...not found
Checking for program /cygdrive/e/ecl/HOME/dbx...not found
Checking for program /cygdrive/e/ecl/MACROS/dbx...not found
Checking for program /cygdrive/c/Program Files/dotnet/dbx...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.14.26428/bin/Hostx64/x64/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/IncrediBuild/dbx...not found
Checking for program /cygdrive/e/Python36/Scripts/dbx...not found
Checking for program /cygdrive/e/Python36/dbx...not found
Checking for program /cygdrive/c/Users/AliReza/.dnx/bin/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/dbx...not found
Checking for program /cygdrive/c/Program Files (x86)/SSH Communications Security/SSH Secure Shell/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/dbx...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/dbx...not found
Checking for program /usr/bin/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/bin/intel64/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/compiler/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.15.26726/bin/HostX64/x64/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/VC/VCPackages/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/TypeScript/3.0/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TestWindow/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/Roslyn/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/x64/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17134.0/x64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/xdb...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/Tools/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/ipp/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/daal/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/tbb/vc_mt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.3.210/windows/mpi/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/mpirt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/compiler/xdb...not found
Checking for program /cygdrive/e/Python37/Scripts/xdb...not found
Checking for program /cygdrive/e/Python37/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/mpi/2018.1.156/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI-RT/4.1.3.045/em64t/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/CMG/CMGJobService/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.3.050/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/mpirt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/xdb...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/xdb...not found
Checking for program /cygdrive/c/Python27/xdb...not found
Checking for program /cygdrive/c/Python27/Scripts/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.2.044/intel64/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Composer XE 2015/bin/ia32/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86_64/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86/xdb...not found
Checking for program /cygdrive/c/Progra/xdb...not found
Checking for program /cygdrive/c/Windows/System32/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/xdb...not found
Checking for program /cygdrive/e/Program Files/PuTTY/xdb...not found
Checking for program /cygdrive/c/ecl/HOME/xdb...not found
Checking for program /cygdrive/c/ecl/MACROS/xdb...not found
Checking for program /cygdrive/e/Program Files/CMake/bin/xdb...not found
Checking for program /cygdrive/e/ecl/HOME/xdb...not found
Checking for program /cygdrive/e/ecl/MACROS/xdb...not found
Checking for program /cygdrive/c/Program Files/dotnet/xdb...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.14.26428/bin/Hostx64/x64/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/IncrediBuild/xdb...not found
Checking for program /cygdrive/e/Python36/Scripts/xdb...not found
Checking for program /cygdrive/e/Python36/xdb...not found
Checking for program /cygdrive/c/Users/AliReza/.dnx/bin/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/xdb...not found
Checking for program /cygdrive/c/Program Files (x86)/SSH Communications Security/SSH Secure Shell/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/xdb...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/xdb...not found
Executing: uname -s
stdout: CYGWIN_NT-6.1
              Defined make macro "DSYMUTIL" to "true"
              Defined "USE_GDB_DEBUGGER" to "1"
TEST configureGit from config.sourceControl(/home/alireza/petsc-3.9.3/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /usr/bin/git...found
                Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.17.0
TEST configureMercurial from config.sourceControl(/home/alireza/petsc-3.9.3/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program /usr/bin/hg...found
                Defined make macro "HG" to "hg"
Executing: hg version -q
stdout: Mercurial Distributed SCM (version 4.3.2)
TEST configureCLanguage from PETSc.options.languages(/home/alireza/petsc-3.9.3/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
            C language is C
              Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/home/alireza/petsc-3.9.3/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
            Version Information:
            #define PETSC_VERSION_RELEASE    1
            #define PETSC_VERSION_MAJOR      3
            #define PETSC_VERSION_MINOR      9
            #define PETSC_VERSION_SUBMINOR   3
            #define PETSC_VERSION_PATCH      0
            #define PETSC_VERSION_DATE       "Jul, 02, 2018"
            #define PETSC_VERSION_GIT        "v3.9.3"
            #define PETSC_VERSION_DATE_GIT   "2018-07-02 10:58:05 -0500"
            #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
            #define PETSC_VERSION_ PETSC_VERSION_EQ
            #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
            #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
            #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
            #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
TEST getDatafilespath from PETSc.options.dataFilesPath(/home/alireza/petsc-3.9.3/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/home/alireza/petsc-3.9.3/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
            This is a tarball installation
TEST configureArchitecture from PETSc.options.arch(/home/alireza/petsc-3.9.3/config/PETSc/options/arch.py:36)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:36)
  Checks PETSC_ARCH and sets if not set
TEST setInstallDir from PETSc.options.installDir(/home/alireza/petsc-3.9.3/config/PETSc/options/installDir.py:36)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:36)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
              Defined make macro "PREFIXDIR" to "/home/alireza/Petsc393Install"
TEST saveReconfigure from PETSc.options.installDir(/home/alireza/petsc-3.9.3/config/PETSc/options/installDir.py:80)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:80)
TEST cleanInstallDir from PETSc.options.installDir(/home/alireza/petsc-3.9.3/config/PETSc/options/installDir.py:73)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:73)
TEST configureInstallDir from PETSc.options.installDir(/home/alireza/petsc-3.9.3/config/PETSc/options/installDir.py:57)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:57)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
            Changed persistence directory to /home/alireza/petsc-3.9.3/arch-mswin-c-opt/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/home/alireza/petsc-3.9.3/config/PETSc/options/installDir.py:93)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:93)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/home/alireza/petsc-3.9.3/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/home/alireza/petsc-3.9.3/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1633)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1633)
            **** printenv ****
VCToolsRedistDir=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Redist\MSVC\14.15.26706\
LIB=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\lib\intel64_win;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib\intel64_win;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib\intel64;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib\intel64_win;e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\ATLMFC\lib\x64;e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\lib\x64;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\lib\um\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.17134.0\ucrt\x64;C:\Program Files (x86)\Windows Kits\10\lib\10.0.17134.0\um\x64;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mpi\intel64\bin\..\..\intel64\lib;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp\lib\intel64;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\lib\intel64_win;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib\intel64_win;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\lib\intel64\vc_mt;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\lib\intel64\vc_mt;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\daal\lib\intel64_win;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\lib\intel64_win\vc_mt;
TBBROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..
COMPUTERNAME=ALIREZA-PC
SCRIPT_NAME=compilervars_arch.bat
SYSTEMROOT=C:\Windows
WIN_TITLE_ARCH=Intel(R) 64
PRODUCT_NAME=Intel Compiler 18.0 Update 3
VSCMD_VER=15.8.0
PSTL_TARGET_VS=all
WindowsSDK_ExecutablePath_x86=C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools\
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
INTELGTDEBUGGERROOT=E:\Program Files (x86)\IntelSWTools\debugger_2018\gdb\intel64_igfx\
FrameworkVersion64=v4.0.30319
VCToolsInstallDir=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\
include=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\include\intel64\lp64;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\include\intel64;e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\ATLMFC\include;e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\include;C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\include\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.17134.0\ucrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.17134.0\shared;C:\Program Files (x86)\Windows Kits\10\include\10.0.17134.0\um;C:\Program Files (x86)\Windows Kits\10\include\10.0.17134.0\winrt;C:\Program Files (x86)\Windows Kits\10\include\10.0.17134.0\cppwinrt;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mpi\intel64\bin\..\..\intel64\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\pstl\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\daal\include;C:\Program Files (x86)\Intel\Trace Analyzer and Collector\9.0.2.045\include
EXECIGNORE=*.dll
NDK_DIR=""
DNX_HOME=%USERPROFILE%\.dnx
COMSPEC=C:\Windows\system32\cmd.exe
windows_tracing_logfile=C:\BVTBin\Tests\installpackage\csilogfile.log
MSMPI_LIB64=C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x64\
ARCH_PATH=intel64
VCToolsVersion=14.15.26726
HOMEPATH=\Users\AliReza
SLBSLS_LICENSE_FILE=@localhost;
TARGET_ARCH=intel64
ICPP_COMPILER18=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.3.210\windows\
WindowsSDKVersion=10.0.17134.0\
__DOTNET_ADD_64BIT=1
HOMEDRIVE=C:
MKLROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl
FrameworkVersion=v4.0.30319
SYSTEMDRIVE=C:
INTEL_LICENSE_FILE=C:\Program Files (x86)\Common Files\\Intel\Licenses;C:\Program Files (x86)\Common Files\Intel\Licenses
PROCESSOR_LEVEL=6
OS=Windows_NT
__MS_VC_INSTALL_PATH=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\
MSVS_VAR_SCRIPT="e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Auxiliary\Build\vcvarsall.bat"
TARGET_VS=vs2017
LSDEFAULTDIR=C:\Program Files (x86)\CMG\SECURE
WindowsSdkBinPath=C:\Program Files (x86)\Windows Kits\10\bin\
Platform=x64
CPATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\pstl\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\daal\include;
CommandPromptType=Native
VS2017INSTALLDIR=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise
HOME=/cygdrive/c/Users/AliReza/
IFORT_COMPILER18=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.3.210\windows\
TBB_CXX=icl.exe
Framework40Version=v4.0
TBB_TARGET_ARCH=intel64
TEMP=/cygdrive/c/Users/AliReza/AppData/Local/Temp
SHLVL=2
VTUNE_AMPLIFIER_2018_DIR=E:\Program Files (x86)\IntelSWTools\VTune Amplifier 2018\
MIC_LD_LIBRARY_PATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib\mic;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\compiler\lib\intel64_win_mic
DevEnvDir=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\
VSCMD_ARG_app_plat=Desktop
WindowsSdkDir=C:\Program Files (x86)\Windows Kits\10\
LOGONSERVER=\\ALIREZA-PC
C_TARGET_ARCH=intel64
CLASSPATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\daal\lib\daal.jar;
ALLUSERSPROFILE=C:\ProgramData
MSVS_VAR_SCRIPT_DIR=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Auxiliary\Build
ROOT_ROOT_NAME=windows
KMP_DUPLICATE_LIB_OK=TRUE
SESSIONNAME=Console
PKG_CONFIG_PATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\bin\pkgconfig;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\bin\pkgconfig;
_=./configure
LIBRARY_PATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp\lib\intel64;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\..\..\linux\tbb\lib\intel64\gcc4.7;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\..\..\linux\tbb\lib\intel64\gcc4.7;
APPDATA=C:\Users\AliReza\AppData\Roaming
INSPECTOR_2018_DIR=E:\Program Files (x86)\IntelSWTools\Inspector 2018\
PUBLIC=C:\Users\Public
HTMLHelpDir=C:\Program Files (x86)\HTML Help Workshop
__VSCMD_PREINIT_INCLUDE=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mpi\intel64\bin\..\..\intel64\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mkl\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\pstl\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\include;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\daal\include;C:\Program Files (x86)\Intel\Trace Analyzer and Collector\9.0.2.045\include
TBB_BIN_DIR=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\
I_MPI_ROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mpi\intel64\bin\..\..
TMP=/cygdrive/c/Users/AliReza/AppData/Local/Temp
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\
VSCMD_ARG_TGT_ARCH=x64
USERDOMAIN=AliReza-PC
PRODUCT_NAME_FULL=Intel(R) Compiler 18.0 Update 3 (package 210)
COMMONPROGRAMFILES=C:\Program Files\Common Files
IPPROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp
VBOX_MSI_INSTALL_PATH=C:\Program Files\Oracle\VirtualBox\
VSTO_SUPPRESSDISPLAYALERTS=0
LD_LIBRARY_PATH=/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/linux/compiler/lib/intel64_lin:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/linux/tbb/lib/intel64/gcc4.7:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/linux/tbb/lib/intel64/gcc4.7:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/linux/daal/lib/intel64_lin:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/linux/tbb/lib/intel64_lin/gcc4.7:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/linux/tbb/lib/intel64_lin/gcc4.4
WindowsLibPath=C:\Program Files (x86)\Windows Kits\10\UnionMetadata\10.0.17134.0;C:\Program Files (x86)\Windows Kits\10\References\10.0.17134.0
MIC_LIBRARY_PATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\compiler\lib\mic;
ProgramData=C:\ProgramData
PROCESSOR_ARCHITECTURE=AMD64
VS150COMNTOOLS=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\Tools\
VisualStudioVersion=15.0
__VSCMD_PREINIT_PATH=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\mpi\intel64\bin\..\..\intel64\bin;E:\Program Files (x86)\IntelSWTools\debugger_2018\bin\\..\gdb\intel64\bin;E:\Program Files (x86)\IntelSWTools\debugger_2018\bin\..\libipt\intel64\lib;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\ipp\..\redist\intel64\ipp;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\redist\intel64_win\mkl;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\redist\intel64_win\compiler;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\..\redist\intel64\tbb\vc_mt;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\tbb\bin\..\..\redist\intel64\tbb\vc_mt;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\redist\intel64_win\daal;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\redist\intel64_win\tbb\vc_mt;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;E:\Program Files (x86)\IntelSWTools\compilers_and_libraries_2018.3.210\windows\mpi\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64_win\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32_win\compiler;E:\Python37\Scripts\;E:\Python37\;E:\Program Files (x86)\IntelSWTools\mpi\2018.1.156\intel64\bin;C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\Intel\MPI-RT\4.1.3.045\em64t\bin;C:\Program Files (x86)\CMG\CMGJobService;C:\Program Files (x86)\Intel\MPI\5.0.3.050\intel64\bin;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\mpirt;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\intel64\compiler;C:\Program Files (x86)\Common Files\Intel\Shared Libraries\redist\ia32\compiler;C:\ProgramData\Oracle\Java\javapath;C:\Python27;C:\Python27\Scripts;C:\Program Files (x86)\Intel\Trace Analyzer and Collector\9.0.2.045\bin;C:\Program Files (x86)\Intel\MPI\5.0.2.044\intel64\bin;C:\Program Files (x86)\Intel\Composer XE 2015\bin\ia32;C:\Program Files (x86)\AMD APP SDK\2.9\bin\x86_64;C:\Program Files (x86)\AMD APP SDK\2.9\bin\x86;C:\Progra;C:\Windows\System32;C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\IDE;E:\Program Files\PuTTY\;C:\ecl\HOME;C:\ecl\MACROS;E:\Program Files\CMake\bin;e:\ecl\HOME;e:\ecl\MACROS;C:\Program Files\dotnet\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;E:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.14.26428\bin\Hostx64\x64\;E:\Program Files (x86)\IncrediBuild;E:\Python36\Scripts\;E:\Python36\;C:\Users\AliReza\.dnx\bin;C:\Program Files (x86)\Intel\Trace Analyzer and Collector\9.0.2.045\dll;C:\Program Files (x86)\SSH Communications Security\SSH Secure Shell
ProgramW6432=C:\Program Files
USERNAME=AliReza
FrameworkDIR64=C:\Windows\Microsoft.NET\Framework64
PROMPT=$P$G
ADVISOR_2018_DIR=E:\Program Files (x86)\IntelSWTools\Advisor 2018\
INTEL_DEV_REDIST=C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
FrameworkDir=C:\Windows\Microsoft.NET\Framework64\
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC;.PY;.PYW
CommonProgramW6432=C:\Program Files\Common Files
WINDIR=C:\Windows
windows_tracing_flags=3
NUMBER_OF_PROCESSORS=4
VSCMD_START_DIR=E:\cygwin64\home\alireza
VCIDEInstallDir=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\VC\
WIN_TITLE=Intel Compiler 18.0 Update 3 Intel(R) 64
TARGET_VS_ARCH=amd64
MSMPI_INC=C:\Program Files (x86)\Microsoft SDKs\MPI\Include\
BIN_ROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\bin\
USERPROFILE=C:\Users\AliReza
VS140COMNTOOLS=C:\Program Files (x86)\Microsoft Visual Studio 14.0\Common7\Tools\
!E:=E:\cygwin64\home\alireza
LIBPATH=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\ATLMFC\lib\x64;e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\lib\x64;e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\lib\x86\store\references;C:\Program Files (x86)\Windows Kits\10\UnionMetadata\10.0.17134.0;C:\Program Files (x86)\Windows Kits\10\References\10.0.17134.0;C:\Windows\Microsoft.NET\Framework64\v4.0.30319;
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 69 Stepping 1, GenuineIntel
PROCESSOR_REVISION=4501
PATH=/usr/bin:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/bin/intel64:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/compiler:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.15.26726/bin/HostX64/x64:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/VC/VCPackages:/cygdrive/c/Program Files (x86)/Microsoft SDKs/TypeScript/3.0:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TestWindow:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/Roslyn:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/x64:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools:/cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64:/cygdrive/c/Program Files (x86)/HTML Help Workshop:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17134.0/x64:/cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin:/cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/Tools:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin:/cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin:/cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/ipp:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/daal:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/tbb/vc_mt:/cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath:/cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.3.210/windows/mpi/intel64/bin:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/compiler:/cygdrive/e/Python37/Scripts:/cygdrive/e/Python37:/cygdrive/e/Program Files (x86)/IntelSWTools/mpi/2018.1.156/intel64/bin:/cygdrive/c/Program Files/Microsoft MPI/Bin:/cygdrive/c/Program Files (x86)/Intel/MPI-RT/4.1.3.045/em64t/bin:/cygdrive/c/Program Files (x86)/CMG/CMGJobService:/cygdrive/c/Program Files (x86)/Intel/MPI/5.0.3.050/intel64/bin:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler:/cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler:/cygdrive/c/ProgramData/Oracle/Java/javapath:/cygdrive/c/Python27:/cygdrive/c/Python27/Scripts:/cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/bin:/cygdrive/c/Program Files (x86)/Intel/MPI/5.0.2.044/intel64/bin:/cygdrive/c/Program Files (x86)/Intel/Composer XE 2015/bin/ia32:/cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86_64:/cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86:/cygdrive/c/Progra:/cygdrive/c/Windows/System32:/cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE:/cygdrive/e/Program Files/PuTTY:/cygdrive/c/ecl/HOME:/cygdrive/c/ecl/MACROS:/cygdrive/e/Program Files/CMake/bin:/cygdrive/e/ecl/HOME:/cygdrive/e/ecl/MACROS:/cygdrive/c/Program Files/dotnet:/cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.14.26428/bin/Hostx64/x64:/cygdrive/e/Program Files (x86)/IncrediBuild:/cygdrive/e/Python36/Scripts:/cygdrive/e/Python36:/cygdrive/c/Users/AliReza/.dnx/bin:/cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll:/cygdrive/c/Program Files (x86)/SSH Communications Security/SSH Secure Shell:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin:/cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja
MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
PSTL_TARGET_ARCH=intel64
TERM=xterm
WindowsSDKLibVersion=10.0.17134.0\
PSTL_BIN_DIR=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\pstl\bin\
PSTLROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\pstl\bin\..
VSINSTALLDIR=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\
CMAKE_INCLUDE_PATH=C:\Users\AliReza\Desktop\boost_1_66_0\boost
IPP_TARGET_ARCH=intel64
LOCALAPPDATA=C:\Users\AliReza\AppData\Local
WindowsSDK_ExecutablePath_x64=C:\Program Files (x86)\Microsoft SDKs\Windows\v10.0A\bin\NETFX 4.6.1 Tools\x64\
ExtensionSdkDir=C:\Program Files (x86)\Microsoft SDKs\Windows Kits\10\ExtensionSDKs
UniversalCRTSdkDir=C:\Program Files (x86)\Windows Kits\10\
__DOTNET_PREFERRED_BITNESS=64
ESET_OPTIONS=
CMAKE_LIBRARY_PATH=C:\Users\AliReza\Desktop\boost_1_66_0\stage\lib
UCRTVersion=10.0.17134.0
IPG_Dir=C:\Program Files\Intel\Power Gadget 3.0
IFCPATH=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\Tools\MSVC\14.15.26726\ifc\x64
FP_NO_HOST_CHECK=NO
DAALROOT=E:\Program Files (x86)\IntelSWTools\compilers_and_libraries\windows\daal
VSCMD_ARG_HOST_ARCH=x64
TBB_TARGET_VS=vc_mt
OLDPWD=/home/alireza
NETFXSDKDir=C:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\
WindowsSdkVerBinPath=C:\Program Files (x86)\Windows Kits\10\bin\10.0.17134.0\
PWD=/home/alireza/petsc-3.9.3
IPG_Ver=3.0
MSMPI_LIB32=C:\Program Files (x86)\Microsoft SDKs\MPI\Lib\x86\
VCINSTALLDIR=e:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\VC\
TEST resetEnvCompilers from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1640)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1640)
TEST checkEnvCompilers from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1670)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1670)
TEST checkMPICompilerOverride from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1605)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1605)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1624)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1624)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:444)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:444)
  Determine the compiler vendor
            Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:454)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:454)
  Initialize the compiler and linker flags
              Pushing language C
            Initialized CFLAGS to -O2 -MT -wd4996 -Qopenmp
            Initialized LDFLAGS to
              Popping language C
            Initialized CUDAFLAGS to
            Initialized CXXFLAGS to -O2 -MT -wd4996 -Qopenmp
            Initialized CXX_CXXFLAGS to
              Pushing language FC
            Initialized FFLAGS to -MT -O2 -Qopenmp
              Popping language FC
            Initialized CPPFLAGS to
            Initialized CUDAPPFLAGS to -Wno-deprecated-gpu-targets
            Initialized CXXCPPFLAGS to
            Initialized CC_LINKER_FLAGS to []
            Initialized CXX_LINKER_FLAGS to []
            Initialized FC_LINKER_FLAGS to []
            Initialized CUDAC_LINKER_FLAGS to []
            Initialized sharedLibraryFlags to []
            Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:586)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:586)
  Locate a functional C compiler
Checking for program /usr/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/bin/intel64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.15.26726/bin/HostX64/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/VC/VCPackages/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/TypeScript/3.0/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TestWindow/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/Roslyn/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17134.0/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/win32fe...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/Tools/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/ipp/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/daal/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/tbb/vc_mt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.3.210/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/compiler/win32fe...not found
Checking for program /cygdrive/e/Python37/Scripts/win32fe...not found
Checking for program /cygdrive/e/Python37/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/mpi/2018.1.156/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI-RT/4.1.3.045/em64t/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/CMG/CMGJobService/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.3.050/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/c/Python27/win32fe...not found
Checking for program /cygdrive/c/Python27/Scripts/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.2.044/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Composer XE 2015/bin/ia32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86_64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86/win32fe...not found
Checking for program /cygdrive/c/Progra/win32fe...not found
Checking for program /cygdrive/c/Windows/System32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/win32fe...not found
Checking for program /cygdrive/e/Program Files/PuTTY/win32fe...not found
Checking for program /cygdrive/c/ecl/HOME/win32fe...not found
Checking for program /cygdrive/c/ecl/MACROS/win32fe...not found
Checking for program /cygdrive/e/Program Files/CMake/bin/win32fe...not found
Checking for program /cygdrive/e/ecl/HOME/win32fe...not found
Checking for program /cygdrive/e/ecl/MACROS/win32fe...not found
Checking for program /cygdrive/c/Program Files/dotnet/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.14.26428/bin/Hostx64/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IncrediBuild/win32fe...not found
Checking for program /cygdrive/e/Python36/Scripts/win32fe...not found
Checking for program /cygdrive/e/Python36/win32fe...not found
Checking for program /cygdrive/c/Users/AliReza/.dnx/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/SSH Communications Security/SSH Secure Shell/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/win32fe...not found
Checking for program /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe...found
                Defined make macro "CC" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl"
                Pushing language C
                            All intermediate test results are stored in /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE
                          All intermediate test results are stored in /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                                                Pushing language C
                                                Popping language C
                                                Pushing language FC
                                                Popping language FC
                        Pushing language C
                        Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe   -O2 -MT -wd4996 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe   -O2 -MT -wd4996 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
ipo: error #11018: Cannot open libpetsc-ufod4vtr9mqHvKIQiVAm.lib
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
Possible ERROR while running linker: exit code 40192
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                            Pushing language C
                            Popping language C
Testing executable /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe to see if it can be run
Executing: /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe
                Popping language C
TEST checkCPreprocessor from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:619)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:619)
  Locate a functional C preprocessor
                Defined make macro "CPP" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E"
              Pushing language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
conftest.c
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conffix.h"
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.c"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
 __declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
     size_t _Count,
     size_t _Size
void* __cdecl calloc(
      size_t _Count,
      size_t _Size
 int __cdecl _callnewh(
     size_t _Size
void* __cdecl _expand(
               void*  _Block,
      size_t _Size
void __cdecl _free_base(
      void* _Block
void __cdecl free(
      void* _Block
void* __cdecl _malloc_base(
     size_t _Size
void* __cdecl malloc(
      size_t _Size
size_t __cdecl _msize_base(
     void* _Block
size_t __cdecl _msize(
     void* _Block
void* __cdecl _realloc_base(
       void*  _Block,
                                size_t _Size
void* __cdecl realloc(
      void*  _Block,
             size_t _Size
void* __cdecl _recalloc_base(
      void*  _Block,
                               size_t _Count,
                               size_t _Size
void* __cdecl _recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size
void __cdecl _aligned_free(
      void* _Block
void* __cdecl _aligned_malloc(
      size_t _Size,
                        size_t _Alignment
void* __cdecl _aligned_offset_malloc(
      size_t _Size,
                        size_t _Alignment,
                        size_t _Offset
size_t __cdecl _aligned_msize(
     void*  _Block,
              size_t _Alignment,
              size_t _Offset
void* __cdecl _aligned_offset_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_offset_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment
void* __cdecl _aligned_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment
#line 225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
#pragma once
#line 26 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
     int* __cdecl _errno(void);
     errno_t __cdecl _set_errno( int _Value);
     errno_t __cdecl _get_errno( int* _Value);
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
 extern unsigned long  __cdecl __threadid(void);
 extern uintptr_t __cdecl __threadhandle(void);
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
    typedef int (__cdecl* _CoreCrtSecureSearchSortCompareFunction)(void*, void const*, void const*);
    typedef int (__cdecl* _CoreCrtNonSecureSearchSortCompareFunction)(void const*, void const*);
     void* __cdecl bsearch_s(
                                                       void const* _Key,
         void const* _Base,
                                                       rsize_t     _NumOfElements,
                                                       rsize_t     _SizeOfElements,
                           _CoreCrtSecureSearchSortCompareFunction _CompareFunction,
                                                   void*       _Context
     void __cdecl qsort_s(
         void*   _Base,
                                                        void*   _Context
 void* __cdecl bsearch(
                                                   void const* _Key,
     void const* _Base,
                    _CoreCrtNonSecureSearchSortCompareFunction _CompareFunction
 void __cdecl qsort(
     void*  _Base,
 void* __cdecl _lfind_s(
                                                      void const*   _Key,
     void const*   _Base,
                                                   unsigned int* _NumOfElements,
                                                      void*         _Context
 void* __cdecl _lfind(
                                                      void const*   _Key,
     void const*   _Base,
                                                      unsigned int  _SizeOfElements,
 void* __cdecl _lsearch_s(
                                                            void const*   _Key,
     void*         _Base,
                                                            void*         _Context
 void* __cdecl _lsearch(
                                                            void const*   _Key,
     void*         _Base,
#line 185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lfind" ". See online help for details."))
     void* __cdecl lfind(
                                                          void const*   _Key,
         void const*   _Base,
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lsearch" ". See online help for details."))
     void* __cdecl lsearch(
                                                               void const*   _Key,
         void*         _Base,
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
#pragma once
     errno_t __cdecl _itow_s(
                                 int      _Value,
         wchar_t* _Buffer,
                                 size_t   _BufferCount,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _itow(int _Value, wchar_t *_Buffer, int _Radix);
     errno_t __cdecl _ltow_s(
                                 long     _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ltow(long _Value, wchar_t *_Buffer, int _Radix);
     errno_t __cdecl _ultow_s(
                                 unsigned long _Value,
         wchar_t*      _Buffer,
                                 int           _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ultow(unsigned long _Value, wchar_t *_Buffer, int _Radix);
     double __cdecl wcstod(
                           wchar_t const* _String,
          wchar_t**      _EndPtr
     double __cdecl _wcstod_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     long __cdecl wcstol(
          wchar_t**      _EndPtr,
                             int            _Radix
     long __cdecl _wcstol_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     long long __cdecl wcstoll(
          wchar_t**      _EndPtr,
                             int            _Radix
     long long __cdecl _wcstoll_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned long __cdecl wcstoul(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned long __cdecl _wcstoul_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned long long __cdecl wcstoull(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned long long __cdecl _wcstoull_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     long double __cdecl wcstold(
          wchar_t**      _EndPtr
     long double __cdecl _wcstold_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     float __cdecl wcstof(
          wchar_t**      _EndPtr
     float __cdecl _wcstof_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     double __cdecl _wtof(
     double __cdecl _wtof_l(
         _locale_t      _Locale
     int __cdecl _wtoi(
     int __cdecl _wtoi_l(
         _locale_t      _Locale
     long __cdecl _wtol(
     long __cdecl _wtol_l(
         _locale_t      _Locale
     long long __cdecl _wtoll(
     long long __cdecl _wtoll_l(
         _locale_t      _Locale
     errno_t __cdecl _i64tow_s(
                                 __int64  _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     wchar_t* __cdecl _i64tow(
                           __int64  _Value,
          wchar_t* _Buffer,
                           int      _Radix
     errno_t __cdecl _ui64tow_s(
                                 unsigned __int64 _Value,
         wchar_t*         _Buffer,
                                 int              _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     wchar_t* __cdecl _ui64tow(
          wchar_t*         _Buffer,
                           int              _Radix
     __int64 __cdecl _wtoi64(
     __int64 __cdecl _wtoi64_l(
         _locale_t      _Locale
     __int64 __cdecl _wcstoi64(
          wchar_t**      _EndPtr,
                             int            _Radix
     __int64 __cdecl _wcstoi64_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned __int64 __cdecl _wcstoui64(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned __int64 __cdecl _wcstoui64_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     __declspec(allocator) wchar_t* __cdecl _wfullpath(
         wchar_t*       _Buffer,
                                   wchar_t const* _Path,
                                     size_t         _BufferCount
     errno_t __cdecl _wmakepath_s(
         wchar_t*       _Buffer,
                           wchar_t const* _Drive,
                           wchar_t const* _Dir,
                           wchar_t const* _Filename,
                           wchar_t const* _Ext
#line 361 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
#pragma warning(push)
#pragma warning(disable: 28719)
#pragma warning(disable: 28726)
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wmakepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wmakepath( wchar_t *_Buffer, wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext);
#pragma warning(pop)
     void __cdecl _wperror(
         wchar_t const* _ErrorMessage
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsplitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     void __cdecl _wsplitpath(
                           wchar_t const* _FullPath,
          wchar_t*       _Drive,
          wchar_t*       _Dir,
          wchar_t*       _Filename,
          wchar_t*       _Ext
     errno_t __cdecl _wsplitpath_s(
            wchar_t*       _Drive,
                                       size_t         _DriveCount,
              wchar_t*       _Dir,
                                       size_t         _DirCount,
         wchar_t*       _Filename,
                                       size_t         _FilenameCount,
              wchar_t*       _Ext,
                                       size_t         _ExtCount
         errno_t __cdecl _wdupenv_s(
              wchar_t**      _Buffer,
        size_t*        _BufferCount,
        wchar_t const* _VarName
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wdupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         wchar_t* __cdecl _wgetenv(
         errno_t __cdecl _wgetenv_s(
                                        size_t*        _RequiredCount,
             wchar_t*       _Buffer,
#line 438 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
         int __cdecl _wputenv(
             wchar_t const* _EnvString
         errno_t __cdecl _wputenv_s(
             wchar_t const* _Name,
             wchar_t const* _Value
         errno_t __cdecl _wsearchenv_s(
                                   wchar_t const* _VarName,
             wchar_t*       _Buffer,
                                     size_t         _BufferCount
        __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsearchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wsearchenv(wchar_t const* _Filename, wchar_t const* _VarName, wchar_t *_ResultPath);
         int __cdecl _wsystem(
             wchar_t const* _Command
__pragma(pack(pop))
#line 16 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#pragma once
#line 29 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 43 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 71 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 79 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
__pragma(pack(pop))
#line 17 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 void __cdecl _swab(
      char* _Buf1,
      char* _Buf2,
        int   _SizeInBytes
     __declspec(noreturn) void __cdecl exit( int _Code);
     __declspec(noreturn) void __cdecl _exit( int _Code);
     __declspec(noreturn) void __cdecl _Exit( int _Code);
     __declspec(noreturn) void __cdecl quick_exit( int _Code);
     __declspec(noreturn) void __cdecl abort(void);
 unsigned int __cdecl _set_abort_behavior(
     unsigned int _Flags,
     unsigned int _Mask
    typedef int (__cdecl* _onexit_t)(void);
#line 117 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
    int       __cdecl atexit(void (__cdecl*)(void));
    _onexit_t __cdecl _onexit( _onexit_t _Func);
int __cdecl at_quick_exit(void (__cdecl*)(void));
    typedef void (__cdecl* _purecall_handler)(void);
    typedef void (__cdecl* _invalid_parameter_handler)(
        wchar_t const*,
        wchar_t const*,
        wchar_t const*,
        unsigned int,
        uintptr_t
     _purecall_handler __cdecl _set_purecall_handler(
         _purecall_handler _Handler
     _purecall_handler __cdecl _get_purecall_handler(void);
     _invalid_parameter_handler __cdecl _set_invalid_parameter_handler(
         _invalid_parameter_handler _Handler
     _invalid_parameter_handler __cdecl _get_invalid_parameter_handler(void);
     _invalid_parameter_handler __cdecl _set_thread_local_invalid_parameter_handler(
     _invalid_parameter_handler __cdecl _get_thread_local_invalid_parameter_handler(void);
#line 199 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
  int __cdecl _set_error_mode( int _Mode);
     unsigned long* __cdecl __doserrno(void);
     errno_t __cdecl _set_doserrno( unsigned long _Value);
     errno_t __cdecl _get_doserrno( unsigned long * _Value);
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __sys_errlist(void);
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int * __cdecl __sys_nerr(void);
     void __cdecl perror( char const* _ErrMsg);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_pgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  char**    __cdecl __p__pgmptr (void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_wpgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  wchar_t** __cdecl __p__wpgmptr(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_fmode" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  int*      __cdecl __p__fmode  (void);
#line 253 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 errno_t __cdecl _get_pgmptr ( char**    _Value);
 errno_t __cdecl _get_wpgmptr( wchar_t** _Value);
 errno_t __cdecl _set_fmode  (              int       _Mode );
 errno_t __cdecl _get_fmode  (             int*      _PMode);
typedef struct _div_t
    int quot;
    int rem;
} div_t;
typedef struct _ldiv_t
    long quot;
    long rem;
} ldiv_t;
typedef struct _lldiv_t
    long long quot;
    long long rem;
} lldiv_t;
 int       __cdecl abs   ( int       _Number);
 long      __cdecl labs  ( long      _Number);
 long long __cdecl llabs ( long long _Number);
 __int64   __cdecl _abs64( __int64   _Number);
 unsigned short   __cdecl _byteswap_ushort( unsigned short   _Number);
 unsigned long    __cdecl _byteswap_ulong ( unsigned long    _Number);
 unsigned __int64 __cdecl _byteswap_uint64( unsigned __int64 _Number);
  div_t   __cdecl div  ( int       _Numerator,  int       _Denominator);
  ldiv_t  __cdecl ldiv ( long      _Numerator,  long      _Denominator);
  lldiv_t __cdecl lldiv( long long _Numerator,  long long _Denominator);
#pragma warning (push)
#pragma warning (disable:6540)
unsigned int __cdecl _rotl(
     unsigned int _Value,
     int          _Shift
unsigned long __cdecl _lrotl(
     int           _Shift
unsigned __int64 __cdecl _rotl64(
     int              _Shift
unsigned int __cdecl _rotr(
     int          _Shift
unsigned long __cdecl _lrotr(
     int           _Shift
unsigned __int64 __cdecl _rotr64(
     int              _Shift
#pragma warning (pop)
 void __cdecl srand( unsigned int _Seed);
  int __cdecl rand(void);
#line 380 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
    #pragma pack(push, 4)
    typedef struct
        unsigned char ld[10];
    } _LDOUBLE;
    #pragma pack(pop)
#line 410 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
typedef struct
    double x;
} _CRT_DOUBLE;
typedef struct
    float f;
} _CRT_FLOAT;
typedef struct
    long double x;
} _LONGDOUBLE;
typedef struct
    unsigned char ld12[12];
} _LDBL12;
#pragma pack(pop)
                     double    __cdecl atof   ( char const* _String);
   int       __cdecl atoi   ( char const* _String);
                     long      __cdecl atol   ( char const* _String);
                     long long __cdecl atoll  ( char const* _String);
                     __int64   __cdecl _atoi64( char const* _String);
  double    __cdecl _atof_l  ( char const* _String,  _locale_t _Locale);
  int       __cdecl _atoi_l  ( char const* _String,  _locale_t _Locale);
  long      __cdecl _atol_l  ( char const* _String,  _locale_t _Locale);
  long long __cdecl _atoll_l ( char const* _String,  _locale_t _Locale);
  __int64   __cdecl _atoi64_l( char const* _String,  _locale_t _Locale);
  int __cdecl _atoflt ( _CRT_FLOAT*  _Result,  char const* _String);
  int __cdecl _atodbl ( _CRT_DOUBLE* _Result,  char*       _String);
  int __cdecl _atoldbl( _LDOUBLE*    _Result,  char*       _String);
 int __cdecl _atoflt_l(
     _locale_t   _Locale
 int __cdecl _atodbl_l(
       char*        _String,
     _locale_t    _Locale
 int __cdecl _atoldbl_l(
        _LDOUBLE* _Result,
       char*     _String,
     _locale_t _Locale
 float __cdecl strtof(
      char**      _EndPtr
 float __cdecl _strtof_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 double __cdecl strtod(
      char**      _EndPtr
 double __cdecl _strtod_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 long double __cdecl strtold(
      char**      _EndPtr
 long double __cdecl _strtold_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 long __cdecl strtol(
      char**      _EndPtr,
                         int         _Radix
 long __cdecl _strtol_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 long long __cdecl strtoll(
      char**      _EndPtr,
                         int         _Radix
 long long __cdecl _strtoll_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned long __cdecl strtoul(
      char**      _EndPtr,
                         int         _Radix
 unsigned long __cdecl _strtoul_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned long long __cdecl strtoull(
      char**      _EndPtr,
                         int         _Radix
 unsigned long long __cdecl _strtoull_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 __int64 __cdecl _strtoi64(
      char**      _EndPtr,
                         int         _Radix
 __int64 __cdecl _strtoi64_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned __int64 __cdecl _strtoui64(
      char**      _EndPtr,
                         int         _Radix
 unsigned __int64 __cdecl _strtoui64_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 errno_t __cdecl _itoa_s(
                             int    _Value,
     char*  _Buffer,
                             int    _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _itoa(int _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _ltoa_s(
                             long   _Value,
     char*  _Buffer,
                             int    _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ltoa(long _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _ultoa_s(
     char*         _Buffer,
                             int           _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ultoa(unsigned long _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _i64toa_s(
                             __int64 _Value,
     char*   _Buffer,
                             int     _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _i64toa(
                       __int64 _Value,
      char*   _Buffer,
                       int     _Radix
 errno_t __cdecl _ui64toa_s(
     char*            _Buffer,
                             int              _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ui64toa(
      char*            _Buffer,
                       int              _Radix
 errno_t __cdecl _ecvt_s(
     char* _Buffer,
      double                       _Value,
      int                          _DigitCount,
     int*                         _PtDec,
     int*                         _PtSign
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ecvt(
      double _Value,
      int    _DigitCount,
     int*   _PtDec,
     int*   _PtSign
 errno_t __cdecl _fcvt_s(
     char*  _Buffer,
                             double _Value,
                             int    _FractionalDigitCount,
                            int*   _PtDec,
                            int*   _PtSign
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _fcvt(
      double _Value,
     int*   _PtDec,
     int*   _PtSign
 errno_t __cdecl _gcvt_s(
     char*  _Buffer,
                             double _Value,
                             int    _DigitCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_gcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _gcvt(
                       double _Value,
                       int    _DigitCount,
      char*  _Buffer
#line 838 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
     int __cdecl ___mb_cur_max_func(void);
     int __cdecl ___mb_cur_max_l_func(_locale_t _Locale);
 int __cdecl mblen(
      char const* _Ch,
                                            size_t      _MaxCount
 int __cdecl _mblen_l(
      char const* _Ch,
                                            size_t      _MaxCount,
                                        _locale_t   _Locale
 size_t __cdecl _mbstrlen(
     char const* _String
 size_t __cdecl _mbstrlen_l(
     _locale_t   _Locale
 size_t __cdecl _mbstrnlen(
       size_t      _MaxCount
 size_t __cdecl _mbstrnlen_l(
         size_t      _MaxCount,
     _locale_t   _Locale
 int __cdecl mbtowc(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                     size_t      _SrcSizeInBytes
 int __cdecl _mbtowc_l(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                     size_t      _SrcSizeInBytes,
                                 _locale_t   _Locale
 errno_t __cdecl mbstowcs_s(
                                                     size_t*     _PtNumOfCharConverted,
     wchar_t*    _DstBuf,
                                                          size_t      _SizeInWords,
                                    char const* _SrcBuf,
                                                          size_t      _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "mbstowcs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl mbstowcs( wchar_t *_Dest, char const* _Source, size_t _MaxCount);
 errno_t __cdecl _mbstowcs_s_l(
     wchar_t*    _DstBuf,
                                                          size_t      _MaxCount,
                                                      _locale_t   _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_mbstowcs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _mbstowcs_l( wchar_t *_Dest, char const* _Source, size_t _MaxCount, _locale_t _Locale);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wctomb_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl wctomb(
     char*   _MbCh,
                               wchar_t _WCh
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctomb_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl _wctomb_l(
      char*     _MbCh,
                         wchar_t   _WCh,
                     _locale_t _Locale
     errno_t __cdecl wctomb_s(
                                                        int*    _SizeConverted,
         char*   _MbCh,
                                                             rsize_t _SizeInBytes,
                                                             wchar_t _WCh
 errno_t __cdecl _wctomb_s_l(
     char*     _MbCh,
                                 wchar_t   _WCh,
                             _locale_t _Locale);
 errno_t __cdecl wcstombs_s(
     char*          _Dst,
        size_t         _DstSizeInBytes,
        wchar_t const* _Src,
        size_t         _MaxCountInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstombs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl wcstombs( char *_Dest, wchar_t const* _Source, size_t _MaxCount);
 errno_t __cdecl _wcstombs_s_l(
     char*          _Dst,
        size_t         _MaxCountInBytes,
                                                               _locale_t      _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcstombs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _wcstombs_l( char *_Dest, wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale);
 __declspec(allocator) char* __cdecl _fullpath(
     char*       _Buffer,
                               char const* _Path,
                                 size_t      _BufferCount
 errno_t __cdecl _makepath_s(
     char*       _Buffer,
                       char const* _Drive,
                       char const* _Dir,
                       char const* _Filename,
                       char const* _Ext
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_makepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _makepath( char *_Buffer, char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_splitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 void __cdecl _splitpath(
                       char const* _FullPath,
      char*       _Drive,
      char*       _Dir,
      char*       _Filename,
      char*       _Ext
 errno_t __cdecl _splitpath_s(
        char*       _Drive,
                                   size_t      _DriveCount,
          char*       _Dir,
                                   size_t      _DirCount,
     char*       _Filename,
          char*       _Ext,
                                   size_t      _ExtCount
 errno_t __cdecl getenv_s(
     char*       _Buffer,
                                 rsize_t     _BufferCount,
                               char const* _VarName
 int*       __cdecl __p___argc (void);
 char***    __cdecl __p___argv (void);
 wchar_t*** __cdecl __p___wargv(void);
#line 1164 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 char***    __cdecl __p__environ (void);
 wchar_t*** __cdecl __p__wenviron(void);
#line 1181 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "_dupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl getenv(
     errno_t __cdecl _dupenv_s(
          char**      _Buffer,
     int __cdecl system(
         char const* _Command
     int __cdecl _putenv(
         char const* _EnvString
     errno_t __cdecl _putenv_s(
         char const* _Name,
         char const* _Value
     errno_t __cdecl _searchenv_s(
                               char const* _VarName,
         char*       _Buffer,
                                 size_t      _BufferCount
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_searchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _searchenv(char const* _Filename, char const* _VarName, char *_Buffer);
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetErrorMode" " " "instead. See online help for details."))
     void __cdecl _seterrormode(
         int _Mode
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Beep" " " "instead. See online help for details."))
     void __cdecl _beep(
         unsigned _Frequency,
         unsigned _Duration
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Sleep" " " "instead. See online help for details."))
     void __cdecl _sleep(
         unsigned long _Duration
    #pragma warning(disable: 4141)
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ecvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ecvt(
          double _Value,
          int    _DigitCount,
         int*   _PtDec,
         int*   _PtSign
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_fcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl fcvt(
          double _Value,
         int*   _PtDec,
         int*   _PtSign
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_gcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl gcvt(
                           double _Value,
                           int    _DigitCount,
          char*  _DstBuf
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_itoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl itoa(
                           int   _Value,
          char* _Buffer,
                           int   _Radix
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ltoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ltoa(
                           long  _Value,
          char* _Buffer,
                           int   _Radix
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_swab" ". See online help for details."))
     void __cdecl swab(
         char* _Buf1,
         char* _Buf2,
                                    int   _SizeInBytes
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ultoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ultoa(
          char*         _Buffer,
                           int           _Radix
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_putenv" ". See online help for details."))
     int __cdecl putenv(
    _onexit_t __cdecl onexit( _onexit_t _Func);
__pragma(pack(pop))
#line 4 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Popping language C
TEST checkCUDACompiler from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:660)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:660)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:700)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:700)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:812)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:812)
  Locate a functional Cxx compiler
                Defined make macro "CXX" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl"
                Pushing language Cxx
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
                                                Pushing language C
                                                Popping language C
                                                Pushing language CUDA
                                                Popping language CUDA
                                                Popping language Cxx
                                                Pushing language FC
                                                Popping language FC
                        Pushing language CXX
                        Popping language CXX
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
TEST checkCxxPreprocessor from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:850)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:850)
  Locate a functional Cxx preprocessor
                Defined make macro "CXXCPP" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E"
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout:
conftest.cc
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.cc"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.cc"
extern "C" {
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.cc"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\cstdlib"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#pragma once
#line 219 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\xkeycheck.h"
#pragma once
#line 91 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\xkeycheck.h"
#line 263 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\xkeycheck.h"
#line 221 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#pragma once
#pragma once
extern "C" {
#pragma once
extern "C" {
#pragma once
extern "C" {
    extern "C++"
        template <typename _Ty>
        struct __vcrt_va_list_is_reference
            enum : bool { __the_value = false };
        struct __vcrt_va_list_is_reference<_Ty&>
            enum : bool { __the_value = true };
        struct __vcrt_va_list_is_reference<_Ty&&>
        struct __vcrt_assert_va_start_is_not_reference
            static_assert(!__vcrt_va_list_is_reference<_Ty>::__the_value,
                "va_start argument must not have reference type and must not be parenthesized");
#pragma pack(pop)
#line 82 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8)) extern "C" {
    typedef bool  __vcrt_bool;
#line 198 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    extern "C++"
        template <typename _CountofType, size_t _SizeOfArray>
        char (*__countof_helper(__unaligned _CountofType (&_Array)[_SizeOfArray]))[_SizeOfArray];
} __pragma(pack(pop))
#line 10 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#pragma once
extern "C++"
    template<bool _Enable, typename _Ty>
    struct _CrtEnableIf;
    template<typename _Ty>
    struct _CrtEnableIf<true, _Ty>
        typedef _Ty _Type;
    typedef bool  __crt_bool;
#line 147 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
} _Mbstatet;
#line 557 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 568 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 579 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 590 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 601 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 612 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 623 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 634 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 645 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 661 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 677 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 694 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 712 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 11 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#line 26 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#line 35 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#line 44 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#line 56 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\crtdefs.h"
#line 222 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 230 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 276 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 284 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 304 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 312 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 397 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 413 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 437 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 458 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 473 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 483 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 495 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 507 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 519 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 530 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 542 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 554 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 565 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 588 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 614 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 630 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 644 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 660 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 668 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 676 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 700 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 719 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 753 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 777 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 785 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 813 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\yvals_core.h"
#line 8 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\cstdlib"
#pragma once
#pragma once
     size_t _Count,
     size_t _Size
      size_t _Count,
      size_t _Size
     size_t _Size
               void*  _Block,
      size_t _Size
      void* _Block
void __cdecl free(
      void* _Block
     size_t _Size
      size_t _Size
     void* _Block
     void* _Block
       void*  _Block,
                                size_t _Size
      void*  _Block,
             size_t _Size
      void*  _Block,
                               size_t _Count,
                               size_t _Size
      void*  _Block,
             size_t _Count,
             size_t _Size
      void* _Block
      size_t _Size,
                        size_t _Alignment
      size_t _Size,
                        size_t _Alignment,
                        size_t _Offset
     void*  _Block,
              size_t _Alignment,
              size_t _Offset
      void*  _Block,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
      void*  _Block,
             size_t _Size,
                               size_t _Alignment
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment
#pragma once
#pragma once
    namespace std
        typedef decltype(__nullptr) nullptr_t;
    using ::std::nullptr_t;
                                                       void const* _Key,
         void const* _Base,
                                                   void*       _Context
         void*   _Base,
                                                        void*   _Context
                                                   void const* _Key,
     void const* _Base,
 void __cdecl qsort(
     void*  _Base,
                                                      void const*   _Key,
     void const*   _Base,
                                                      void*         _Context
                                                      void const*   _Key,
     void const*   _Base,
                                                            void const*   _Key,
     void*         _Base,
                                                            void*         _Context
                                                            void const*   _Key,
     void*         _Base,
                                                          void const*   _Key,
         void const*   _Base,
                                                               void const*   _Key,
         void*         _Base,
#pragma once
                                 int      _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    extern "C++" { template <size_t _Size> inline errno_t __cdecl _itow_s(int _Value, wchar_t (&_Buffer)[_Size], int _Radix) throw() { return _itow_s(_Value, _Buffer, _Size, _Radix); } }
                                 long     _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    extern "C++" { template <size_t _Size> inline errno_t __cdecl _ltow_s(long _Value, wchar_t (&_Buffer)[_Size], int _Radix) throw() { return _ltow_s(_Value, _Buffer, _Size, _Radix); } }
         wchar_t*      _Buffer,
                                 int           _Radix
    extern "C++" { template <size_t _Size> inline errno_t __cdecl _ultow_s(unsigned long _Value, wchar_t (&_Buffer)[_Size], int _Radix) throw() { return _ultow_s(_Value, _Buffer, _Size, _Radix); } }
          wchar_t**      _EndPtr
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
          wchar_t**      _EndPtr,
                             int            _Radix
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
          wchar_t**      _EndPtr,
                             int            _Radix
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
          wchar_t**      _EndPtr,
                             int            _Radix
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
          wchar_t**      _EndPtr,
                             int            _Radix
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
          wchar_t**      _EndPtr
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
          wchar_t**      _EndPtr
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
         _locale_t      _Locale
     int __cdecl _wtoi(
         _locale_t      _Locale
     long __cdecl _wtol(
         _locale_t      _Locale
         _locale_t      _Locale
                                 __int64  _Value,
         wchar_t* _Buffer,
                                 int      _Radix
                           __int64  _Value,
          wchar_t* _Buffer,
                           int      _Radix
         wchar_t*         _Buffer,
                                 int              _Radix
          wchar_t*         _Buffer,
                           int              _Radix
         _locale_t      _Locale
          wchar_t**      _EndPtr,
                             int            _Radix
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
          wchar_t**      _EndPtr,
                             int            _Radix
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
         wchar_t*       _Buffer,
                                     size_t         _BufferCount
         wchar_t*       _Buffer,
                           wchar_t const* _Ext
    extern "C++" { template <size_t _Size> inline errno_t __cdecl _wmakepath_s(wchar_t (&_Buffer)[_Size], wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext) throw() { return _wmakepath_s(_Buffer, _Size, _Drive, _Dir, _Filename, _Ext); } }
          wchar_t*       _Drive,
          wchar_t*       _Dir,
          wchar_t*       _Filename,
          wchar_t*       _Ext
            wchar_t*       _Drive,
                                       size_t         _DriveCount,
              wchar_t*       _Dir,
                                       size_t         _DirCount,
         wchar_t*       _Filename,
              wchar_t*       _Ext,
                                       size_t         _ExtCount
    extern "C++" { template <size_t _DriveSize, size_t _DirSize, size_t _NameSize, size_t _ExtSize> inline errno_t __cdecl _wsplitpath_s( wchar_t const* _Path, wchar_t (&_Drive)[_DriveSize], wchar_t (&_Dir)[_DirSize], wchar_t (&_Name)[_NameSize], wchar_t (&_Ext)[_ExtSize] ) throw() { return _wsplitpath_s(_Path, _Drive, _DriveSize, _Dir, _DirSize, _Name, _NameSize, _Ext, _ExtSize); } }
              wchar_t**      _Buffer,
             wchar_t*       _Buffer,
        extern "C++" { template <size_t _Size> inline errno_t __cdecl _wgetenv_s(size_t* _RequiredCount, wchar_t (&_Buffer)[_Size], wchar_t const* _VarName) throw() { return _wgetenv_s(_RequiredCount, _Buffer, _Size, _VarName); } }
             wchar_t*       _Buffer,
                                     size_t         _BufferCount
        extern "C++" { template <size_t _Size> inline errno_t __cdecl _wsearchenv_s(wchar_t const* _Filename, wchar_t const* _VarName, wchar_t (&_ResultPath)[_Size]) throw() { return _wsearchenv_s(_Filename, _VarName, _ResultPath, _Size); } }
#pragma once
 void __cdecl _swab(
      char* _Buf1,
      char* _Buf2,
        int   _SizeInBytes
     unsigned int _Mask
        wchar_t const*,
        wchar_t const*,
        wchar_t const*,
        unsigned int,
        uintptr_t
    int quot;
    int rem;
} div_t;
    long quot;
    long rem;
} ldiv_t;
    long long quot;
    long long rem;
} lldiv_t;
     int          _Shift
     int           _Shift
     int              _Shift
     int          _Shift
     int           _Shift
     int              _Shift
extern "C++"
    inline long abs(long const _X) throw()
        return labs(_X);
    inline long long abs(long long const _X) throw()
        return llabs(_X);
    inline ldiv_t div(long const _A1, long const _A2) throw()
        return ldiv(_A1, _A2);
    inline lldiv_t div(long long const _A1, long long const _A2) throw()
        return lldiv(_A1, _A2);
    typedef struct
    } _LDOUBLE;
    #pragma pack(pop)
typedef struct
    double x;
} _CRT_DOUBLE;
typedef struct
    float f;
} _CRT_FLOAT;
typedef struct
    long double x;
} _LONGDOUBLE;
typedef struct
} _LDBL12;
#pragma pack(pop)
     _locale_t   _Locale
       char*        _String,
     _locale_t    _Locale
        _LDOUBLE* _Result,
       char*     _String,
     _locale_t _Locale
      char**      _EndPtr
      char**      _EndPtr,
                     _locale_t   _Locale
      char**      _EndPtr
      char**      _EndPtr,
                     _locale_t   _Locale
      char**      _EndPtr
      char**      _EndPtr,
                     _locale_t   _Locale
      char**      _EndPtr,
                         int         _Radix
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
      char**      _EndPtr,
                         int         _Radix
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
      char**      _EndPtr,
                         int         _Radix
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
      char**      _EndPtr,
                         int         _Radix
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
      char**      _EndPtr,
                         int         _Radix
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
      char**      _EndPtr,
                         int         _Radix
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
                             int    _Value,
     char*  _Buffer,
                             int    _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _itoa_s(int _Value, char (&_Buffer)[_Size], int _Radix) throw() { return _itoa_s(_Value, _Buffer, _Size, _Radix); } }
                             long   _Value,
     char*  _Buffer,
                             int    _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ltoa_s(long _Value, char (&_Buffer)[_Size], int _Radix) throw() { return _ltoa_s(_Value, _Buffer, _Size, _Radix); } }
     char*         _Buffer,
                             int           _Radix
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ultoa_s(unsigned long _Value, char (&_Buffer)[_Size], int _Radix) throw() { return _ultoa_s(_Value, _Buffer, _Size, _Radix); } }
                             __int64 _Value,
     char*   _Buffer,
                             int     _Radix
                       __int64 _Value,
      char*   _Buffer,
                       int     _Radix
     char*            _Buffer,
                             int              _Radix
      char*            _Buffer,
                       int              _Radix
     char* _Buffer,
      double                       _Value,
      int                          _DigitCount,
     int*                         _PtDec,
     int*                         _PtSign
extern "C++" { template <size_t _Size> inline errno_t __cdecl _ecvt_s(char (&_Buffer)[_Size], double _Value, int _DigitCount, int* _PtDec, int* _PtSign) throw() { return _ecvt_s(_Buffer, _Size, _Value, _DigitCount, _PtDec, _PtSign); } }
      double _Value,
      int    _DigitCount,
     int*   _PtDec,
     int*   _PtSign
     char*  _Buffer,
                             double _Value,
                            int*   _PtDec,
                            int*   _PtSign
extern "C++" { template <size_t _Size> inline errno_t __cdecl _fcvt_s(char (&_Buffer)[_Size], double _Value, int _FractionalDigitCount, int* _PtDec, int* _PtSign) throw() { return _fcvt_s(_Buffer, _Size, _Value, _FractionalDigitCount, _PtDec, _PtSign); } }
      double _Value,
     int*   _PtDec,
     int*   _PtSign
     char*  _Buffer,
                             double _Value,
                             int    _DigitCount
extern "C++" { template <size_t _Size> inline errno_t __cdecl _gcvt_s(char (&_Buffer)[_Size], double _Value, int _DigitCount) throw() { return _gcvt_s(_Buffer, _Size, _Value, _DigitCount); } }
                       double _Value,
                       int    _DigitCount,
      char*  _Buffer
 int __cdecl mblen(
      char const* _Ch,
                                            size_t      _MaxCount
      char const* _Ch,
                                            size_t      _MaxCount,
                                        _locale_t   _Locale
     char const* _String
     _locale_t   _Locale
       size_t      _MaxCount
         size_t      _MaxCount,
     _locale_t   _Locale
 int __cdecl mbtowc(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                 _locale_t   _Locale
     wchar_t*    _DstBuf,
                                                          size_t      _MaxCount
extern "C++" { template <size_t _Size> inline errno_t __cdecl mbstowcs_s(size_t* _PtNumOfCharConverted, wchar_t (&_Dest)[_Size], char const* _Source, size_t _MaxCount) throw() { return mbstowcs_s(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount); } }
     wchar_t*    _DstBuf,
                                                          size_t      _MaxCount,
                                                      _locale_t   _Locale
extern "C++" { template <size_t _Size> inline errno_t __cdecl _mbstowcs_s_l(size_t* _PtNumOfCharConverted, wchar_t (&_Dest)[_Size], char const* _Source, size_t _MaxCount, _locale_t _Locale) throw() { return _mbstowcs_s_l(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount, _Locale); } }
 int __cdecl wctomb(
     char*   _MbCh,
                               wchar_t _WCh
      char*     _MbCh,
                         wchar_t   _WCh,
                     _locale_t _Locale
         char*   _MbCh,
                                                             wchar_t _WCh
     char*     _MbCh,
                                 wchar_t   _WCh,
                             _locale_t _Locale);
     char*          _Dst,
extern "C++" { template <size_t _Size> inline errno_t __cdecl wcstombs_s(size_t* _PtNumOfCharConverted, char (&_Dest)[_Size], wchar_t const* _Source, size_t _MaxCount) throw() { return wcstombs_s(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount); } }
     char*          _Dst,
                                                               _locale_t      _Locale
extern "C++" { template <size_t _Size> inline errno_t __cdecl _wcstombs_s_l(size_t* _PtNumOfCharConverted, char (&_Dest)[_Size], wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale) throw() { return _wcstombs_s_l(_PtNumOfCharConverted, _Dest, _Size, _Source, _MaxCount, _Locale); } }
     char*       _Buffer,
                               char const* _Path,
                                 size_t      _BufferCount
     char*       _Buffer,
                       char const* _Drive,
                       char const* _Dir,
                       char const* _Ext
extern "C++" { template <size_t _Size> inline errno_t __cdecl _makepath_s(char (&_Buffer)[_Size], char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext) throw() { return _makepath_s(_Buffer, _Size, _Drive, _Dir, _Filename, _Ext); } }
      char*       _Drive,
      char*       _Dir,
      char*       _Filename,
      char*       _Ext
        char*       _Drive,
                                   size_t      _DriveCount,
          char*       _Dir,
                                   size_t      _DirCount,
     char*       _Filename,
          char*       _Ext,
                                   size_t      _ExtCount
extern "C++" { template <size_t _DriveSize, size_t _DirSize, size_t _NameSize, size_t _ExtSize> inline errno_t __cdecl _splitpath_s( char const* _Dest, char (&_Drive)[_DriveSize], char (&_Dir)[_DirSize], char (&_Name)[_NameSize], char (&_Ext)[_ExtSize] ) throw() { return _splitpath_s(_Dest, _Drive, _DriveSize, _Dir, _DirSize, _Name, _NameSize, _Ext, _ExtSize); } }
     char*       _Buffer,
    extern "C++" { template <size_t _Size> inline errno_t __cdecl getenv_s(size_t* _RequiredCount, char (&_Buffer)[_Size], char const* _VarName) throw() { return getenv_s(_RequiredCount, _Buffer, _Size, _VarName); } }
          char**      _Buffer,
     int __cdecl system(
         char const* _Name,
         char const* _Value
         char*       _Buffer,
                                 size_t      _BufferCount
    extern "C++" { template <size_t _Size> inline errno_t __cdecl _searchenv_s(char const* _Filename, char const* _VarName, char (&_Buffer)[_Size]) throw() { return _searchenv_s(_Filename, _VarName, _Buffer, _Size); } }
         int _Mode
     void __cdecl _beep(
         unsigned _Duration
     char* __cdecl ecvt(
          double _Value,
          int    _DigitCount,
         int*   _PtDec,
         int*   _PtSign
     char* __cdecl fcvt(
          double _Value,
         int*   _PtDec,
         int*   _PtSign
     char* __cdecl gcvt(
                           double _Value,
                           int    _DigitCount,
          char*  _DstBuf
     char* __cdecl itoa(
                           int   _Value,
          char* _Buffer,
                           int   _Radix
     char* __cdecl ltoa(
                           long  _Value,
          char* _Buffer,
                           int   _Radix
     void __cdecl swab(
         char* _Buf1,
         char* _Buf2,
                                    int   _SizeInBytes
          char*         _Buffer,
                           int           _Radix
     int __cdecl putenv(
#line 9 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\cstdlib"
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 65 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 88 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 128 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
       struct _complex {
               double x,y;
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 65 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 88 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 128 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 137 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\math.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
#pragma once
#pragma warning(disable:4738)
#pragma warning(disable:4820)
    struct _exception
        int    type;
        char*  name;
        double arg1;
        double arg2;
        double retval;
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
    typedef float  float_t;
    typedef double double_t;
#line 74 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
        extern double const _HUGE;
void __cdecl _fperrraise( int _Except);
  short __cdecl _dclass( double _X);
  short __cdecl _ldclass( long double _X);
  short __cdecl _fdclass( float _X);
  int __cdecl _dsign( double _X);
  int __cdecl _ldsign( long double _X);
  int __cdecl _fdsign( float _X);
  int __cdecl _dpcomp( double _X,  double _Y);
  int __cdecl _ldpcomp( long double _X,  long double _Y);
  int __cdecl _fdpcomp( float _X,  float _Y);
  short __cdecl _dtest( double* _Px);
  short __cdecl _ldtest( long double* _Px);
  short __cdecl _fdtest( float* _Px);
 short __cdecl _d_int( double* _Px,  short _Xexp);
 short __cdecl _ld_int( long double* _Px,  short _Xexp);
 short __cdecl _fd_int( float* _Px,  short _Xexp);
 short __cdecl _dscale( double* _Px,  long _Lexp);
 short __cdecl _ldscale( long double* _Px,  long _Lexp);
 short __cdecl _fdscale( float* _Px,  long _Lexp);
 short __cdecl _dunscale( short* _Pex,  double* _Px);
 short __cdecl _ldunscale( short* _Pex,  long double* _Px);
 short __cdecl _fdunscale( short* _Pex,  float* _Px);
  short __cdecl _dexp( double* _Px,  double _Y,  long _Eoff);
  short __cdecl _ldexp( long double* _Px,  long double _Y,  long _Eoff);
  short __cdecl _fdexp( float* _Px,  float _Y,  long _Eoff);
  short __cdecl _dnorm( unsigned short* _Ps);
  short __cdecl _fdnorm( unsigned short* _Ps);
  double __cdecl _dpoly( double _X,  double const* _Tab,  int _N);
  long double __cdecl _ldpoly( long double _X,  long double const* _Tab,  int _N);
  float __cdecl _fdpoly( float _X,  float const* _Tab,  int _N);
  double __cdecl _dlog( double _X,  int _Baseflag);
  long double __cdecl _ldlog( long double _X,  int _Baseflag);
  float __cdecl _fdlog( float _X,  int _Baseflag);
  double __cdecl _dsin( double _X,  unsigned int _Qoff);
  long double __cdecl _ldsin( long double _X,  unsigned int _Qoff);
  float __cdecl _fdsin( float _X,  unsigned int _Qoff);
typedef union
    unsigned short _Sh[4];
    double _Val;
} _double_val;
typedef union
    unsigned short _Sh[2];
    float _Val;
} _float_val;
typedef union
    long double _Val;
} _ldouble_val;
typedef union
    unsigned short _Word[4];
    float _Float;
    double _Double;
    long double _Long_double;
} _float_const;
extern const _float_const _Denorm_C,  _Inf_C,  _Nan_C,  _Snan_C, _Hugeval_C;
extern const _float_const _FDenorm_C, _FInf_C, _FNan_C, _FSnan_C;
extern const _float_const _LDenorm_C, _LInf_C, _LNan_C, _LSnan_C;
extern const _float_const _Eps_C,  _Rteps_C;
extern const _float_const _FEps_C, _FRteps_C;
extern const _float_const _LEps_C, _LRteps_C;
extern const double      _Zero_C,  _Xbig_C;
extern const float       _FZero_C, _FXbig_C;
extern const long double _LZero_C, _LXbig_C;
#line 288 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
extern "C++"
     inline int fpclassify( float _X) throw()
        return _fdtest(&_X);
     inline int fpclassify( double _X) throw()
        return _dtest(&_X);
     inline int fpclassify( long double _X) throw()
        return _ldtest(&_X);
     inline bool signbit( float _X) throw()
        return _fdsign(_X) != 0;
     inline bool signbit( double _X) throw()
        return _dsign(_X) != 0;
     inline bool signbit( long double _X) throw()
        return _ldsign(_X) != 0;
     inline int _fpcomp( float _X,  float _Y) throw()
        return _fdpcomp(_X, _Y);
     inline int _fpcomp( double _X,  double _Y) throw()
        return _dpcomp(_X, _Y);
     inline int _fpcomp( long double _X,  long double _Y) throw()
        return _ldpcomp(_X, _Y);
    template <class _Trc, class _Tre> struct _Combined_type
        typedef float _Type;
    template <> struct _Combined_type<float, double>
        typedef double _Type;
    template <> struct _Combined_type<float, long double>
        typedef long double _Type;
    template <class _Ty, class _T2> struct _Real_widened
    template <> struct _Real_widened<float, float>
    template <> struct _Real_widened<float, double>
    template <> struct _Real_widened<double, float>
    template <> struct _Real_widened<double, double>
    template <class _Ty> struct _Real_type
    template <> struct _Real_type<float>
    template <> struct _Real_type<long double>
    template <class _T1, class _T2>
     inline int _fpcomp( _T1 _X,  _T2 _Y) throw()
        typedef typename _Combined_type<float,
            typename _Real_widened<
            typename _Real_type<_T1>::_Type,
            typename _Real_type<_T2>::_Type>::_Type>::_Type _Tw;
        return _fpcomp((_Tw)_X, (_Tw)_Y);
     inline bool isfinite( _Ty _X) throw()
        return fpclassify(_X) <= 0;
     inline bool isinf( _Ty _X) throw()
        return fpclassify(_X) == 1;
     inline bool isnan( _Ty _X) throw()
        return fpclassify(_X) == 2;
     inline bool isnormal( _Ty _X) throw()
        return fpclassify(_X) == (-1);
    template <class _Ty1, class _Ty2>
     inline bool isgreater( _Ty1 _X,  _Ty2 _Y) throw()
        return (_fpcomp(_X, _Y) & 4) != 0;
     inline bool isgreaterequal( _Ty1 _X,  _Ty2 _Y) throw()
        return (_fpcomp(_X, _Y) & (2 | 4)) != 0;
     inline bool isless( _Ty1 _X,  _Ty2 _Y) throw()
        return (_fpcomp(_X, _Y) & 1) != 0;
     inline bool islessequal( _Ty1 _X,  _Ty2 _Y) throw()
        return (_fpcomp(_X, _Y) & (1 | 2)) != 0;
     inline bool islessgreater( _Ty1 _X,  _Ty2 _Y) throw()
        return (_fpcomp(_X, _Y) & (1 | 4)) != 0;
     inline bool isunordered( _Ty1 _X,  _Ty2 _Y) throw()
        return _fpcomp(_X, _Y) == 0;
     int       __cdecl abs( int _X);
     long      __cdecl labs( long _X);
     long long __cdecl llabs( long long _X);
     double __cdecl acos( double _X);
     double __cdecl asin( double _X);
     double __cdecl atan( double _X);
     double __cdecl atan2( double _Y,  double _X);
     double __cdecl cos( double _X);
     double __cdecl cosh( double _X);
     double __cdecl exp( double _X);
      double __cdecl fabs( double _X);
     double __cdecl fmod( double _X,  double _Y);
     double __cdecl log( double _X);
     double __cdecl log10( double _X);
     double __cdecl pow( double _X,  double _Y);
     double __cdecl sin( double _X);
     double __cdecl sinh( double _X);
      double __cdecl sqrt( double _X);
     double __cdecl tan( double _X);
     double __cdecl tanh( double _X);
      double    __cdecl acosh( double _X);
      double    __cdecl asinh( double _X);
      double    __cdecl atanh( double _X);
       double    __cdecl atof( char const* _String);
       double    __cdecl _atof_l( char const* _String,  _locale_t _Locale);
      double    __cdecl _cabs( struct _complex _Complex_value);
      double    __cdecl cbrt( double _X);
      double    __cdecl ceil( double _X);
      double    __cdecl _chgsign( double _X);
      double    __cdecl copysign( double _Number,  double _Sign);
      double    __cdecl _copysign( double _Number,  double _Sign);
      double    __cdecl erf( double _X);
      double    __cdecl erfc( double _X);
      double    __cdecl exp2( double _X);
      double    __cdecl expm1( double _X);
      double    __cdecl fdim( double _X,  double _Y);
      double    __cdecl floor( double _X);
      double    __cdecl fma( double _X,  double _Y,  double _Z);
      double    __cdecl fmax( double _X,  double _Y);
      double    __cdecl fmin( double _X,  double _Y);
      double    __cdecl frexp( double _X,  int* _Y);
      double    __cdecl hypot( double _X,  double _Y);
      double    __cdecl _hypot( double _X,  double _Y);
      int       __cdecl ilogb( double _X);
      double    __cdecl ldexp( double _X,  int _Y);
      double    __cdecl lgamma( double _X);
      long long __cdecl llrint( double _X);
      long long __cdecl llround( double _X);
      double    __cdecl log1p( double _X);
      double    __cdecl log2( double _X);
      double    __cdecl logb( double _X);
      long      __cdecl lrint( double _X);
      long      __cdecl lround( double _X);
    int __cdecl _matherr( struct _exception* _Except);
      double __cdecl modf( double _X,  double* _Y);
      double __cdecl nan( char const* _X);
      double __cdecl nearbyint( double _X);
      double __cdecl nextafter( double _X,  double _Y);
      double __cdecl nexttoward( double _X,  long double _Y);
      double __cdecl remainder( double _X,  double _Y);
      double __cdecl remquo( double _X,  double _Y,  int* _Z);
      double __cdecl rint( double _X);
      double __cdecl round( double _X);
      double __cdecl scalbln( double _X,  long _Y);
      double __cdecl scalbn( double _X,  int _Y);
      double __cdecl tgamma( double _X);
      double __cdecl trunc( double _X);
      double __cdecl _j0( double _X );
      double __cdecl _j1( double _X );
      double __cdecl _jn(int _X,  double _Y);
      double __cdecl _y0( double _X);
      double __cdecl _y1( double _X);
      double __cdecl _yn( int _X,  double _Y);
      float     __cdecl acoshf( float _X);
      float     __cdecl asinhf( float _X);
      float     __cdecl atanhf( float _X);
      float     __cdecl cbrtf( float _X);
      float     __cdecl _chgsignf( float _X);
      float     __cdecl copysignf( float _Number,  float _Sign);
      float     __cdecl _copysignf( float _Number,  float _Sign);
      float     __cdecl erff( float _X);
      float     __cdecl erfcf( float _X);
      float     __cdecl expm1f( float _X);
      float     __cdecl exp2f( float _X);
      float     __cdecl fdimf( float _X,  float _Y);
      float     __cdecl fmaf( float _X,  float _Y,  float _Z);
      float     __cdecl fmaxf( float _X,  float _Y);
      float     __cdecl fminf( float _X,  float _Y);
      float     __cdecl _hypotf( float _X,  float _Y);
      int       __cdecl ilogbf( float _X);
      float     __cdecl lgammaf( float _X);
      long long __cdecl llrintf( float _X);
      long long __cdecl llroundf( float _X);
      float     __cdecl log1pf( float _X);
      float     __cdecl log2f( float _X);
      float     __cdecl logbf( float _X);
      long      __cdecl lrintf( float _X);
      long      __cdecl lroundf( float _X);
      float     __cdecl nanf( char const* _X);
      float     __cdecl nearbyintf( float _X);
      float     __cdecl nextafterf( float _X,  float _Y);
      float     __cdecl nexttowardf( float _X,  long double _Y);
      float     __cdecl remainderf( float _X,  float _Y);
      float     __cdecl remquof( float _X,  float _Y,  int* _Z);
      float     __cdecl rintf( float _X);
      float     __cdecl roundf( float _X);
      float     __cdecl scalblnf( float _X,  long _Y);
      float     __cdecl scalbnf( float _X,  int _Y);
      float     __cdecl tgammaf( float _X);
      float     __cdecl truncf( float _X);
          float __cdecl _logbf( float _X);
          float __cdecl _nextafterf( float _X,  float _Y);
          int   __cdecl _finitef( float _X);
          int   __cdecl _isnanf( float _X);
          int   __cdecl _fpclassf( float _X);
          int   __cdecl _set_FMA3_enable( int _Flag);
          int   __cdecl _get_FMA3_enable(void);
#line 606 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
          float __cdecl acosf( float _X);
          float __cdecl asinf( float _X);
          float __cdecl atan2f( float _Y,  float _X);
          float __cdecl atanf( float _X);
          float __cdecl ceilf( float _X);
          float __cdecl cosf( float _X);
          float __cdecl coshf( float _X);
          float __cdecl expf( float _X);
#line 663 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
         __inline float __cdecl __MS_fabsf( float _X)
            return (float)fabs(_X);
          float __cdecl floorf( float _X);
          float __cdecl fmodf( float _X,  float _Y);
#line 695 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
     __inline float __cdecl __MS_frexpf( float _X,  int *_Y)
        return (float)frexp(_X, _Y);
     __inline float __cdecl __MS_hypotf( float _X,  float _Y)
        return _hypotf(_X, _Y);
     __inline float __cdecl __MS_ldexpf( float _X,  int _Y)
        return (float)ldexp(_X, _Y);
          float  __cdecl log10f( float _X);
          float  __cdecl logf( float _X);
          float  __cdecl modff( float _X,  float *_Y);
          float  __cdecl powf( float _X,  float _Y);
          float  __cdecl sinf( float _X);
          float  __cdecl sinhf( float _X);
          float  __cdecl sqrtf( float _X);
          float  __cdecl tanf( float _X);
          float  __cdecl tanhf( float _X);
#line 774 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
      long double __cdecl acoshl( long double _X);
     __inline long double __cdecl __MS_acosl( long double _X)
        return acos((double)_X);
      long double __cdecl asinhl( long double _X);
     __inline long double __cdecl __MS_asinl( long double _X)
        return asin((double)_X);
     __inline long double __cdecl __MS_atan2l( long double _Y,  long double _X)
        return atan2((double)_Y, (double)_X);
      long double __cdecl atanhl( long double _X);
     __inline long double __cdecl __MS_atanl( long double _X)
        return atan((double)_X);
      long double __cdecl cbrtl( long double _X);
     __inline long double __cdecl __MS_ceill( long double _X)
        return ceil((double)_X);
     __inline long double __cdecl _chgsignl( long double _X)
        return _chgsign((double)_X);
      long double __cdecl copysignl( long double _Number,  long double _Sign);
     __inline long double __cdecl _copysignl( long double _Number,  long double _Sign)
        return _copysign((double)_Number, (double)_Sign);
     __inline long double __cdecl __MS_coshl( long double _X)
        return cosh((double)_X);
     __inline long double __cdecl __MS_cosl( long double _X)
        return cos((double)_X);
      long double __cdecl erfl( long double _X);
      long double __cdecl erfcl( long double _X);
     __inline long double __cdecl __MS_expl( long double _X)
        return exp((double)_X);
      long double __cdecl exp2l( long double _X);
      long double __cdecl expm1l( long double _X);
     __inline long double __cdecl __MS_fabsl( long double _X)
        return fabs((double)_X);
      long double __cdecl fdiml( long double _X,  long double _Y);
     __inline long double __cdecl __MS_floorl( long double _X)
        return floor((double)_X);
      long double __cdecl fmal( long double _X,  long double _Y,  long double _Z);
      long double __cdecl fmaxl( long double _X,  long double _Y);
      long double __cdecl fminl( long double _X,  long double _Y);
     __inline long double __cdecl __MS_fmodl( long double _X,  long double _Y)
        return fmod((double)_X, (double)_Y);
     __inline long double __cdecl __MS_frexpl( long double _X,  int *_Y)
        return frexp((double)_X, _Y);
      int __cdecl ilogbl( long double _X);
     __inline long double __cdecl _hypotl( long double _X,  long double _Y)
        return _hypot((double)_X, (double)_Y);
     __inline long double __cdecl __MS_hypotl( long double _X,  long double _Y)
     __inline long double __cdecl __MS_ldexpl( long double _X,  int _Y)
        return ldexp((double)_X, _Y);
      long double __cdecl lgammal( long double _X);
      long long __cdecl llrintl( long double _X);
      long long __cdecl llroundl( long double _X);
     __inline long double __cdecl __MS_logl( long double _X)
        return log((double)_X);
     __inline long double __cdecl __MS_log10l( long double _X)
        return log10((double)_X);
      long double __cdecl log1pl( long double _X);
      long double __cdecl log2l( long double _X);
      long double __cdecl logbl( long double _X);
      long __cdecl lrintl( long double _X);
      long __cdecl lroundl( long double _X);
     __inline long double __cdecl __MS_modfl( long double _X,  long double* _Y)
        double _F, _I;
        _F = modf((double)_X, &_I);
        *_Y = _I;
        return _F;
      long double __cdecl nanl( char const* _X);
      long double __cdecl nearbyintl( long double _X);
      long double __cdecl nextafterl( long double _X,  long double _Y);
      long double __cdecl nexttowardl( long double _X,  long double _Y);
     __inline long double __cdecl __MS_powl( long double _X,  long double _Y)
        return pow((double)_X, (double)_Y);
      long double __cdecl remainderl( long double _X,  long double _Y);
      long double __cdecl remquol( long double _X,  long double _Y,  int* _Z);
      long double __cdecl rintl( long double _X);
      long double __cdecl roundl( long double _X);
      long double __cdecl scalblnl( long double _X,  long _Y);
      long double __cdecl scalbnl( long double _X,  int _Y);
     __inline long double __cdecl __MS_sinhl( long double _X)
        return sinh((double)_X);
     __inline long double __cdecl __MS_sinl( long double _X)
        return sin((double)_X);
     __inline long double __cdecl __MS_sqrtl( long double _X)
        return sqrt((double)_X);
     __inline long double __cdecl __MS_tanhl( long double _X)
        return tanh((double)_X);
     __inline long double __cdecl __MS_tanl( long double _X)
        return tan((double)_X);
      long double __cdecl tgammal( long double _X);
      long double __cdecl truncl( long double _X);
#line 971 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
            extern double HUGE;
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_j0" ". See online help for details."))   double __cdecl j0( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_j1" ". See online help for details."))   double __cdecl j1( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_jn" ". See online help for details."))   double __cdecl jn( int _X,  double _Y);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_y0" ". See online help for details."))   double __cdecl y0( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_y1" ". See online help for details."))   double __cdecl y1( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_yn" ". See online help for details."))   double __cdecl yn( int _X,  double _Y);
#pragma warning(pop)
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\math.h"
#line 142 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 176 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 226 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 31 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 39 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 59 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 231 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 245 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 271 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 285 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 307 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 354 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 370 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" int fpclassifyf    ( float              __x ) throw();
 extern "C" int fpclassifyd    ( double             __x ) throw();
 extern "C" int fpclassifyl    ( long double            __x ) throw();
 extern "C" int isinff         ( float              __x ) throw();
 extern "C" int isinfd         ( double             __x ) throw();
 extern "C" int isinfl         ( long double            __x ) throw();
 extern "C" int isnanf         ( float              __x ) throw();
 extern "C" int isnand         ( double             __x ) throw();
 extern "C" int isnanl         ( long double            __x ) throw();
 extern "C" int isnormalf      ( float              __x ) throw();
 extern "C" int isnormald      ( double             __x ) throw();
 extern "C" int isnormall      ( long double            __x ) throw();
 extern "C" int isfinitef      ( float              __x ) throw();
 extern "C" int isfinited      ( double             __x ) throw();
 extern "C" int isfinitel      ( long double            __x ) throw();
 extern "C" int finitef        ( float              __x ) throw();
 extern "C" int finite         ( double             __x ) throw();
 extern "C" int finited        ( double             __x ) throw();
 extern "C" int finitel        ( long double            __x ) throw();
 extern "C" int signbitf       ( float              __x ) throw();
 extern "C" int signbitd       ( double             __x ) throw();
 extern "C" int signbitl       ( long double            __x ) throw();
 extern "C" int __fpclassifyf  ( float              __x ) throw();
 extern "C" int __fpclassify   ( double           __x ) throw();
 extern "C" int __fpclassifyd  ( double             __x ) throw();
 extern "C" int __fpclassifyl  ( long double            __x ) throw();
 extern "C" int __isinff       ( float              __x ) throw();
 extern "C" int __isinf        ( double           __x ) throw();
 extern "C" int __isinfd       ( double             __x ) throw();
 extern "C" int __isinfl       ( long double            __x ) throw();
 extern "C" int __isnanf       ( float              __x ) throw();
 extern "C" int __isnan        ( double           __x ) throw();
 extern "C" int __isnand       ( double             __x ) throw();
 extern "C" int __isnanl       ( long double            __x ) throw();
 extern "C" int __isnormalf    ( float              __x ) throw();
 extern "C" int __isnormal     ( double           __x ) throw();
 extern "C" int __isnormald    ( double             __x ) throw();
 extern "C" int __isnormall    ( long double            __x ) throw();
 extern "C" int __isfinitef    ( float              __x ) throw();
 extern "C" int __isfinite     ( double           __x ) throw();
 extern "C" int __isfinited    ( double             __x ) throw();
 extern "C" int __isfinitel    ( long double            __x ) throw();
 extern "C" int __finitef      ( float              __x ) throw();
 extern "C" int __finite       ( double             __x ) throw();
 extern "C" int __finited      ( double             __x ) throw();
 extern "C" int __finitel      ( long double            __x ) throw();
 extern "C" int __signbitf     ( float              __x ) throw();
 extern "C" int __signbit      ( double             __x ) throw();
 extern "C" int __signbitd     ( double             __x ) throw();
 extern "C" int __signbitl     ( long double            __x ) throw();
#line 470 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 487 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 520 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" int isgreaterf( float __xf, float __yf );
 extern "C" int isgreaterl( long double __xl, long double __yl );
 extern "C" int __isgreaterf( float __xf, float __yf );
 extern "C" int __isgreater( double __xd, double __yd );
 extern "C" int __isgreaterl( long double __xl, long double __yl );
 extern "C" int isgreaterequalf( float __xf, float __yf );
 extern "C" int isgreaterequall( long double __xl, long double __yl );
 extern "C" int __isgreaterequalf( float __xf, float __yf );
 extern "C" int __isgreaterequal( double __xd, double __yd );
 extern "C" int __isgreaterequall( long double __xl, long double __yl );
 extern "C" int islessf( float __xf, float __yf );
 extern "C" int islessl( long double __xl, long double __yl );
 extern "C" int __islessf( float __xf, float __yf );
 extern "C" int __isless( double __xd, double __yd );
 extern "C" int __islessl( long double __xl, long double __yl );
 int islessequalf( float __xf, float __yf );
 extern "C" int islessequall( long double __xl, long double __yl );
 extern "C" int __islessequalf( float __xf, float __yf );
 extern "C" int __islessequal( double __xd, double __yd );
 extern "C" int __islessequall( long double __xl, long double __yl );
 extern "C" int islessgreaterf( float __xf, float __yf );
 extern "C" int islessgreaterl( long double __xl, long double __yl );
 extern "C" int __islessgreaterf( float __xf, float __yf );
 extern "C" int __islessgreater( double __xd, double __yd );
 extern "C" int __islessgreaterl( long double __xl, long double __yl );
 extern "C" int isunorderedf( float __xf, float __yf );
 extern "C" int isunorderedl( long double __xl, long double __yl );
 extern "C" int __isunorderedf( float __xf, float __yf );
 extern "C" int __isunordered( double __xd, double __yd );
 extern "C" int __isunorderedl( long double __xl, long double __yl );
#line 584 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 597 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 612 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" float    __cdecl acosf( float __x );
 extern "C" float    __cdecl asinf( float __x );
 extern "C" float    __cdecl atanf( float __x );
 extern "C" float    __cdecl atan2f( float __y, float __x );
 extern "C" float    __cdecl cosf( float __x );
 extern "C" float    __cdecl sinf( float __x );
 extern "C" float    __cdecl tanf( float __x );
 extern "C" double   __cdecl acosh( double __x );
 extern "C" float    __cdecl acoshf( float __x );
 extern "C" double   __cdecl asinh( double __x );
 extern "C" float    __cdecl asinhf( float __x );
 extern "C" double   __cdecl atanh( double __x );
 extern "C" float    __cdecl atanhf( float __x );
#line 647 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" float    __cdecl coshf( float __x );
 extern "C" float    __cdecl sinhf( float __x );
 extern "C" float    __cdecl tanhf( float __x );
 extern "C" float    __cdecl expf( float __x );
 extern "C" double   __cdecl expm1( double __x );
 extern "C" float    __cdecl expm1f( float __x );
 extern "C" double   __cdecl exp2( double __x );
 extern "C" float    __cdecl exp2f( float __x );
#line 688 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" float    __cdecl frexpf( float __x, int *__exp );
 extern "C" float    __cdecl ldexpf( float __x, int __exp );
 extern "C" float    __cdecl nanf( const char* __tagp );
 extern "C" double   __cdecl nan ( const char* __tagp );
 extern "C" long double  __cdecl nanl( const char* __tagp );
 extern "C" double   __cdecl scalb( double __x, double __y );
 extern "C" float    __cdecl scalbf( float __x, float __y );
 extern "C" double   __cdecl scalbn( double __x, int __n );
 extern "C" float    __cdecl scalbnf( float __x, int __n );
 extern "C" double   __cdecl scalbln( double __x, long int __n );
 extern "C" float    __cdecl scalblnf( float __x, long int __n );
#line 728 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" float    __cdecl logf( float __x );
 extern "C" float    __cdecl log10f( float __x );
 extern "C" double   __cdecl log2( double __x );
 extern "C" float    __cdecl log2f( float __x );
 extern "C" double   __cdecl log1p( double __x );
 extern "C" float    __cdecl log1pf( float __x );
 extern "C" double   __cdecl logb( double __x );
 extern "C" float    __cdecl logbf( float __x );
 extern "C" int      __cdecl ilogb( double __x );
 extern "C" int      __cdecl ilogbf( float __x );
 extern "C" float    __cdecl modff( float __x, float *__iptr );
 extern "C" double   __cdecl cbrt( double __x );
 extern "C" float    __cdecl cbrtf( float __x );
#line 780 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" float    __cdecl fabsf( float __x );
 extern "C" double   __cdecl hypot( double __x, double __y );
 extern "C" float    __cdecl hypotf( float __x, float __y );
 extern "C" float    __cdecl powf( float __x, float __y );
 extern "C" float    __cdecl sqrtf( float __x );
 extern "C" double   __cdecl erf( double __x );
 extern "C" float    __cdecl erff( float __x );
 extern "C" double   __cdecl erfc( double __x );
 extern "C" float    __cdecl erfcf( float __x );
 extern "C" double   __cdecl lgamma( double __x );
 extern "C" float    __cdecl lgammaf( float __x );
extern "C" double   __cdecl gamma( double __x );
extern "C" float    __cdecl gammaf( float __x );
extern "C" double   __cdecl lgamma_r(double __x, int *__signgam);
extern "C" float    __cdecl lgammaf_r( float __x, int *__signgam );
extern "C" double   __cdecl gamma_r( double __x, int *__signgam );
extern "C" float    __cdecl gammaf_r( float __x, int *__signgam );
 extern "C" double   __cdecl tgamma( double __x );
 extern "C" float    __cdecl tgammaf( float __x );
#line 829 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern "C" float    __cdecl ceilf( float __x );
 extern "C" float    __cdecl floorf( float __x );
 extern "C" double   __cdecl nearbyint( double __x );
 extern "C" float    __cdecl nearbyintf( float __x );
 extern "C" double   __cdecl rint( double __x );
 extern "C" float    __cdecl rintf( float __x );
 extern "C" long int  __cdecl lrint( double __x );
 extern "C" long int  __cdecl lrintf( float __x );
 extern "C" long long int __cdecl llrint( double __x );
 extern "C" long long int __cdecl llrintf( float __x );
 extern "C" double   __cdecl round( double __x );
 extern "C" float    __cdecl roundf( float __x );
 extern "C" long int  __cdecl lround( double __x );
 extern "C" long int  __cdecl lroundf( float __x );
 extern "C" long long int __cdecl llround( double __x );
 extern "C" long long int __cdecl llroundf( float __x );
 extern "C" double   __cdecl trunc( double __x );
 extern "C" float    __cdecl truncf( float __x );
 extern "C" float    __cdecl fmodf( float __x, float __y );
 extern "C" double   __cdecl remainder( double __x, double __y );
 extern "C" float    __cdecl remainderf( float __x, float __y );
 extern "C" double   __cdecl remquo( double __x, double __y, int *__quo );
 extern "C" float    __cdecl remquof( float __x, float __y, int *__quo );
 extern "C" double   __cdecl copysign( double __x, double __y );
 extern "C" float    __cdecl copysignf( float __x, float __y );
 extern "C" double   __cdecl nextafter( double __x, double __y );
 extern "C" float    __cdecl nextafterf( float __x, float __y );
 extern "C" double   __cdecl __libm_nexttoward64 ( double __x, long double __y );
 extern "C" float    __cdecl __libm_nexttoward64f( float  __x, double __y );
 extern "C" double   __cdecl __libm_nexttoward64l( double __x, double __y );
 extern "C" double   __cdecl fdim( double __x, double __y );
 extern "C" float    __cdecl fdimf( float __x, float __y );
 extern "C" double   __cdecl fmax( double __x, double __y );
 extern "C" float    __cdecl fmaxf( float __x, float __y );
 extern "C" double   __cdecl fmin( double __x, double __y );
 extern "C" float    __cdecl fminf( float __x, float __y );
 extern "C" double   __cdecl fma( double __x, double __y, double __z );
 extern "C" float    __cdecl fmaf( float __x, float __y, float __z );
 extern "C" __forceinline long double  __cdecl acosl( long double __x )
  {return (long double) acos((double) __x);}
 extern "C" __forceinline long double  __cdecl asinl( long double __x )
  {return (long double) asin((double) __x);}
 extern "C" __forceinline long double  __cdecl atan2l( long double __y, long double __x )
  {return (long double) atan2((double)__y, (double) __x );}
 extern "C" __forceinline long double  __cdecl atanl( long double __x )
  {return (long double) atan((double) __x);}
 extern "C" __forceinline long double  __cdecl ceill( long double __x )
  {return (long double) ceil((double) __x);}
 extern "C" __forceinline long double  __cdecl cosl( long double __x )
  {return (long double) cos((double) __x);}
 extern "C" __forceinline long double  __cdecl coshl( long double __x )
  {return (long double) cosh((double) __x);}
 extern "C" __forceinline long double  __cdecl expl( long double __x )
  {return (long double) exp((double) __x);}
 extern "C" __forceinline long double  __cdecl fabsl( long double __x )
  {return (long double) fabs((double) __x);}
 extern "C" __forceinline long double  __cdecl floorl( long double __x )
  {return (long double) floor((double) __x);}
 extern "C" __forceinline long double  __cdecl fmodl( long double __x, long double __y )
  {return (long double) fmod((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl frexpl( long double __x, int *__exp )
  {return (long double) frexp((double)__x, __exp );}
 extern "C" __forceinline long double  __cdecl hypotl( long double __x, long double __y )
  {return (long double) hypot((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl ldexpl( long double __x, int __exp )
  {return (long double) ldexp((double)__x, __exp );}
 extern "C" __forceinline long double  __cdecl logl( long double __x )
  {return (long double) log((double) __x);}
 extern "C" __forceinline long double  __cdecl log10l( long double __x )
  {return (long double) log10((double) __x);}
 extern "C" __forceinline long double  __cdecl modfl( long double __x, long double *__iptr )
  {return (long double) modf((double)__x, (double *) __iptr );}
 extern "C" __forceinline long double  __cdecl powl( long double __x, long double __y )
  {return (long double) pow((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl sinhl( long double __x )
  {return (long double) sinh((double) __x);}
 extern "C" __forceinline long double  __cdecl sinl( long double __x )
  {return (long double) sin((double) __x);}
 extern "C" __forceinline long double  __cdecl sqrtl( long double __x )
  {return (long double) sqrt((double) __x);}
 extern "C" __forceinline long double  __cdecl tanl( long double __x )
  {return (long double) tan((double) __x);}
 extern "C" __forceinline long double  __cdecl tanhl( long double __x )
  {return (long double) tanh((double) __x);}
 extern "C" __forceinline long double  __cdecl acoshl( long double __x )
  {return (long double) acosh((double) __x);}
 extern "C" __forceinline long double  __cdecl asinhl( long double __x )
  {return (long double) asinh((double) __x);}
 extern "C" __forceinline long double  __cdecl atanhl( long double __x )
  {return (long double) atanh((double) __x);}
 extern "C" __forceinline long double  __cdecl cbrtl( long double __x )
  {return (long double) cbrt((double) __x);}
 extern "C" __forceinline long double  __cdecl copysignl( long double __x, long double __y )
  {return (long double) copysign((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl erfcl( long double __x )
  {return (long double) erfc((double) __x);}
 extern "C" __forceinline long double  __cdecl erfl( long double __x )
  {return (long double) erf((double) __x);}
 extern "C" __forceinline int      __cdecl ilogbl( long double __x )
  {return (long double) ilogb((double) __x);}
 extern "C" __forceinline long double  __cdecl gammal( long double __x )
  {return (long double) gamma((double) __x);}
 extern "C" __forceinline long double  __cdecl gammal_r( long double __x, int *__signgam )
  {return (long double) gamma_r((double) __x, __signgam);}
 extern "C" __forceinline long double  __cdecl lgammal( long double __x )
  {return (long double) lgamma((double) __x);}
 extern "C" __forceinline long double  __cdecl lgammal_r( long double __x, int *__signgam )
  {return (long double) lgamma_r((double) __x, __signgam);}
 extern "C" __forceinline long double  __cdecl log1pl( long double __x )
  {return (long double) log1p((double) __x);}
 extern "C" __forceinline long double  __cdecl logbl( long double __x )
  {return (long double) logb((double) __x);}
 extern "C" __forceinline long double  __cdecl nextafterl( long double __x, long double __y )
  {return (long double) nextafter((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl remainderl( long double __x, long double __y )
  {return (long double) remainder((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl rintl( long double __x )
  {return (long double) rint((double) __x);}
 extern "C" __forceinline long double  __cdecl scalbnl( long double __x, int __n )
  {return (long double) scalbn((double)__x, __n );}
 extern "C" __forceinline long double  __cdecl exp2l( long double __x )
  {return (long double) exp2((double) __x);}
 extern "C" __forceinline long double  __cdecl expm1l( long double __x )
  {return (long double) expm1((double) __x);}
 extern "C" __forceinline long double  __cdecl fdiml( long double __x, long double __y )
  {return (long double) fdim((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl fmal( long double __x, long double __y, long double __z )
  {return (long double) fma((double) __x, (double) __y, (double) __z);}
 extern "C" __forceinline long double  __cdecl fmaxl( long double __x, long double __y )
  {return (long double) fmax((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl fminl( long double __x, long double __y )
  {return (long double) fmin((double)__x, (double) __y );}
 extern "C" __forceinline long long int __cdecl llrintl( long double __x )
  {return (long double) llrint((double) __x);}
 extern "C" __forceinline long long int __cdecl llroundl( long double __x )
  {return (long double) llround((double) __x);}
 extern "C" __forceinline long double  __cdecl log2l( long double __x )
  {return (long double) log2((double) __x);}
 extern "C" __forceinline long int  __cdecl lrintl( long double __x )
  {return (long double) lrint((double) __x);}
 extern "C" __forceinline long int  __cdecl lroundl( long double __x )
  {return (long double) lround((double) __x);}
 extern "C" __forceinline long double  __cdecl nearbyintl( long double __x )
  {return (long double) nearbyint((double) __x);}
 extern "C" __forceinline long double  __cdecl nexttowardl( long double __x, long double __y )
 {return (long double)  __libm_nexttoward64l((double)__x, (double) __y );}
 extern "C" __forceinline double  __cdecl nexttoward( double __x, long double __y )
 {return __libm_nexttoward64l(__x, (double) __y );}
 extern "C" __forceinline float  __cdecl nexttowardf( float __x, long double __y )
 {return __libm_nexttoward64f(__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl remquol( long double __x, long double __y, int *__quo )
  {return (long double) remquo((double) __x, (double) __y, __quo);}
 extern "C" __forceinline long double  __cdecl roundl( long double __x )
  {return (long double) round((double) __x);}
 extern "C" __forceinline long double  __cdecl scalbl( long double __x, long double __y )
 {return (long double) scalb((double)__x, (double) __y );}
 extern "C" __forceinline long double  __cdecl scalblnl( long double __x, long int __n )
  {return (long double) scalbln((double)__x, __n );}
 extern "C" __forceinline long double  __cdecl tgammal( long double __x )
  {return (long double) tgamma((double) __x);}
 extern "C" __forceinline long double  __cdecl truncl( long double __x )
  {return (long double) trunc((double) __x);}
#line 1133 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 1147 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
typedef struct ____exception {
    int     type;
    const char  *name;
    double  arg1;
    double  arg2;
    double  retval;
} ___exception;
#line 1168 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
typedef struct ____exceptionf {
    int    type;
    const char *name;
    float  arg1;
    float  arg2;
    float  retval;
} ___exceptionf;
typedef struct ____exceptionl {
    int      type;
    const char   *name;
    long double  arg1;
    long double  arg2;
    long double  retval;
} ___exceptionl;
 extern "C" int __cdecl matherrf( struct ____exceptionf *__e );
 extern "C" int __cdecl matherrl( struct ____exceptionl *__e );
typedef int ( __cdecl *___pmatherr )( struct ____exception  *__e );
typedef int ( __cdecl *___pmatherrf )( struct ____exceptionf *__e );
typedef int ( __cdecl *___pmatherrl )( struct ____exceptionl *__e );
 extern "C" ___pmatherr  __cdecl __libm_setusermatherr( ___pmatherr  __user_matherr );
 extern "C" ___pmatherrf __cdecl __libm_setusermatherrf( ___pmatherrf __user_matherrf );
 extern "C" ___pmatherrl __cdecl __libm_setusermatherrl( ___pmatherrl __user_matherrl );
typedef enum ___LIB_VERSIONIMF_TYPE {
     _IEEE_ = -1
    ,_SVID_
    ,_XOPEN_
    ,_POSIX_
    ,_ISOC_
} _LIB_VERSIONIMF_TYPE;
extern "C" _LIB_VERSIONIMF_TYPE  _LIB_VERSIONIMF;
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_undefine.h"
#line 1234 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 142 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 176 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 226 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 10 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\cstdlib"
#pragma pack(push,8)
#pragma warning(push,3)
#pragma warning(disable: 4455 4494 4619 4643 4702 4984 4988)
 inline double abs( double _Xx) noexcept
	return (:: fabs(_Xx));
 inline float abs( float _Xx) noexcept
	return (:: fabsf(_Xx));
 inline long double abs( long double _Xx) noexcept
	return (:: fabsl(_Xx));
namespace std {
using :: size_t; using :: div_t; using :: ldiv_t;
using :: abort; using :: abs; using :: atexit;
using :: atof; using :: atoi; using :: atol;
using :: bsearch; using :: calloc; using :: div;
using :: exit; using :: free;
using :: labs; using :: ldiv; using :: malloc;
using :: mblen; using :: mbstowcs; using :: mbtowc;
using :: qsort; using :: rand; using :: realloc;
using :: srand; using :: strtod; using :: strtol;
using :: strtoul;
using :: wcstombs; using :: wctomb;
using :: lldiv_t;
using :: getenv;
using :: system;
using :: atoll; using :: llabs; using :: lldiv;
using :: strtof; using :: strtold;
using :: strtoll; using :: strtoull;
using :: _Exit; using :: at_quick_exit; using :: quick_exit;
#pragma pack(pop)
#line 4 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.setCompilers\\conftest.cc"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Popping language Cxx
TEST checkFortranCompiler from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:967)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:967)
  Locate a functional Fortran compiler
Checking for program /usr/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/mkl/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/bin/intel64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.15.26726/bin/HostX64/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/VC/VCPackages/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/TypeScript/3.0/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TestWindow/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/TeamFoundation/Team Explorer/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/Roslyn/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Team Tools/Performance Tools/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/Shared/Common/VSPerfCollectionTools/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft SDKs/Windows/v10.0A/bin/NETFX 4.6.1 Tools/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/HTML Help Workshop/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/10.0.17134.0/x64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Windows Kits/10/bin/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/MSBuild/15.0/bin/win32fe...not found
Checking for program /cygdrive/c/Windows/Microsoft.NET/Framework64/v4.0.30319/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/Tools/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/gdb/intel64/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/debugger_2018/libipt/intel64/lib/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/ipp/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64/tbb/vc_mt/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/daal/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries/windows/redist/intel64_win/tbb/vc_mt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/compilers_and_libraries_2018.3.210/windows/mpi/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64_win/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32_win/compiler/win32fe...not found
Checking for program /cygdrive/e/Python37/Scripts/win32fe...not found
Checking for program /cygdrive/e/Python37/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IntelSWTools/mpi/2018.1.156/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft MPI/Bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI-RT/4.1.3.045/em64t/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/CMG/CMGJobService/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.3.050/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/mpirt/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/intel64/compiler/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Common Files/Intel/Shared Libraries/redist/ia32/compiler/win32fe...not found
Checking for program /cygdrive/c/ProgramData/Oracle/Java/javapath/win32fe...not found
Checking for program /cygdrive/c/Python27/win32fe...not found
Checking for program /cygdrive/c/Python27/Scripts/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/MPI/5.0.2.044/intel64/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Composer XE 2015/bin/ia32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86_64/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/AMD APP SDK/2.9/bin/x86/win32fe...not found
Checking for program /cygdrive/c/Progra/win32fe...not found
Checking for program /cygdrive/c/Windows/System32/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Microsoft Visual Studio 14.0/Common7/IDE/win32fe...not found
Checking for program /cygdrive/e/Program Files/PuTTY/win32fe...not found
Checking for program /cygdrive/c/ecl/HOME/win32fe...not found
Checking for program /cygdrive/c/ecl/MACROS/win32fe...not found
Checking for program /cygdrive/e/Program Files/CMake/bin/win32fe...not found
Checking for program /cygdrive/e/ecl/HOME/win32fe...not found
Checking for program /cygdrive/e/ecl/MACROS/win32fe...not found
Checking for program /cygdrive/c/Program Files/dotnet/win32fe...not found
Checking for program /cygdrive/c/Program Files/Microsoft SQL Server/130/Tools/Binn/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/VC/Tools/MSVC/14.14.26428/bin/Hostx64/x64/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/IncrediBuild/win32fe...not found
Checking for program /cygdrive/e/Python36/Scripts/win32fe...not found
Checking for program /cygdrive/e/Python36/win32fe...not found
Checking for program /cygdrive/c/Users/AliReza/.dnx/bin/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/Intel/Trace Analyzer and Collector/9.0.2.045/dll/win32fe...not found
Checking for program /cygdrive/c/Program Files (x86)/SSH Communications Security/SSH Secure Shell/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/CMake/bin/win32fe...not found
Checking for program /cygdrive/e/Program Files (x86)/Microsoft Visual Studio/2017/Enterprise/Common7/IDE/CommonExtensions/Microsoft/CMake/Ninja/win32fe...not found
Checking for program /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe...found
                Defined make macro "FC" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort"
                Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                                Pushing language C
                                                Popping language C
                                                Pushing language CUDA
                                                Popping language CUDA
                                                Pushing language Cxx
                                                Pushing language FC
                                                Popping language FC
                        Pushing language FC
                        Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe   -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe   -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stdout:
ipo: error #11018: Cannot open libpetsc-ufod4vtr9mqHvKIQiVAm.lib
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'
Possible ERROR while running linker: exit code 40192
stdout:
LINK : fatal error LNK1181: cannot open input file 'libpetsc-ufod4vtr9mqHvKIQiVAm.lib'Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
                            Pushing language FC
                            Popping language FC
Testing executable /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe to see if it can be run
Executing: /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe
                Popping language FC
TEST checkFortranComments from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:988)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:988)
  Make sure fortran comment "!" works
              Pushing language FC
Successful compile:
Source:
      program main
! comment
      end
            Fortran comments can use ! in column 1
              Popping language FC
TEST checkLargeFileIO from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1106)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1106)
TEST checkArchiver from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1205)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1205)
  Check that the archiver exists and can make a library usable by the compiler
              Pushing language C
Executing: ar -V
stdout:
GNU ar (GNU Binutils) 2.29.1.20171006
Copyright (C) 2017 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Executing: ar -V
stdout:
                  Defined make macro "FAST_AR_FLAGS" to "Scq"
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int foo(int a) {
  return a+1;
Checking for program /usr/bin/ar...found
                Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/bin/ranlib...found
                Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconf1.a /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conf1.o
Executing: /usr/bin/ranlib -c /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconf1.a
Possible ERROR while running ranlib:
stderr:
/usr/bin/ranlib: invalid option -- c
            Ranlib is not functional with your archiver.  Try --with-ranlib=true if ranlib is unnecessary.
Executing: ar -V
stdout:
Executing: ar -V
stdout:
stdout: conftest.c
Successful compile:
Source:
int foo(int a) {
  return a+1;
                Defined make macro "RANLIB" to "/usr/bin/ranlib"
Executing: /usr/bin/ranlib /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconf1.a
stdout: conftest.c
Successful compile:
Source:
extern int foo(int);
int main() {
  int b = foo(1);  if (b);
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe   -O2 -MT -wd4996 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -L/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -lconf1
stdout:
ipo: error #11018: Cannot open libconf1.lib
LINK : fatal error LNK1181: cannot open input file 'libconf1.lib'
stdout:
LINK : fatal error LNK1181: cannot open input file 'libconf1.lib'Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
              Defined make macro "AR_FLAGS" to "cr"
              Defined make macro "AR_LIB_SUFFIX" to "lib"
              Popping language C
TEST checkSharedLinker from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1319)
TESTING: checkSharedLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1319)
  Check that the linker can produce shared libraries
Executing: uname -s
stdout: CYGWIN_NT-6.1
            Checking shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
                Defined make macro "LD_SHARED" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl"
            Trying C compiler flag
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -shared  -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: icl: command line warning #10006: ignoring unknown option '/shared'
              Rejecting C linker flag -shared due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
void  foo(void){
  fprintf_ptr(stdout,"hello");
  return;
void bar(void){foo();}
                                              Pushing language C
                                              Popping language C
                                              Pushing language FC
                                              Popping language FC
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconftest.so   -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: LINK : fatal error LNK1561: entry point must be defined
Possible ERROR while running linker: exit code 6400
stdout:
LINK : fatal error LNK1561: entry point must be defined            Rejected C compiler flag  because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl --help
stdout:
Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
Usage: win32fe <tool> --<win32fe options> -<tool options> <files>
  <tool> must be the first argument to win32fe
<tool>: {cl,icl,df,f90,ifl,bcc32,lib,tlib}
  cl:    Microsoft 32-bit C/C++ Optimizing Compiler
  icl:   Intel C/C++ Optimizing Compiler
  df:    Compaq Visual Fortran Optimizing Compiler
  f90:   Compaq Visual Fortran90 Optimizing Compiler
  ifl:   Intel Fortran Optimizing Compiler
  ifort: Intel Fortran Optimizing Compiler
  nvcc:  NVIDIA CUDA Compiler Driver
  bcc32: Borland C++ for Win32
  lib:   Microsoft Library Manager
  tlib:  Borland Library Manager
<win32fe options>:
  --help:       Output this help message and help for <tool>
  --path <arg>: <arg> specifies an addition to the PATH that is required
                (ex. the location of a required .dll)
  --use <arg>:  <arg> specifies the variant of <tool> to use
  --verbose:    Echo to stdout the translated commandline
                and other diagnostic information
  --version:    Output version info for win32fe and <tool>
  --wait_for_debugger:  Inserts an infinite wait after creation of <tool>
                and outputs PID so one can manually attach a debugger to the
                current process.  In the debugger, one must set:
                   tool::waitfordebugger = 0
                to continue the execution normally.
  --win-l:      For compilers, define -lfoo to link foo.lib instead of libfoo.lib
  --woff:       Suppress win32fe specific warning messages
For compilers:
  win32fe will map the following <tool options> to their native options:
    -c:          Compile Only, generates an object file with .o extension
                 This will invoke the compiler once for each file listed.
    -l<library>: Link the file lib<library>.lib or if using --win-l also, <library>.lib
    -o <file>:   Output=<file> context dependent
    -D<macro>:   Define <macro>
    -I<path>:    Add <path> to the include path
    -L<path>:    Add <path> to the link path
    -g:          Generate debug symbols in objects when specified for compilation,
                 and in executables when specified for linking (some compilers
                 specification at both times for full debugging support).
    -O:          Enable compiletime and/or linktime optimizations.
Ex: win32fe cl -g -c foo.c --verbose -Iinclude
Note: win32fe will automatically find the system library paths and
      system include paths, relieving the user of the need to invoke a
      particular shell.
icl specific help:
  win32fe uses -nologo by default for nonverbose output.  Use the flag:
     -logo  to disable this feature.
  -g is identical to -Z7.
  -O is identical to -O2.
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
                          Intel(R) C++ Compiler Help
  Intel(R) Compiler includes compiler options that optimize for instruction
  sets that are available in both Intel(R) and non-Intel microprocessors, but
  may perform additional optimizations for Intel microprocessors than for
  non-Intel microprocessors.  In addition, certain compiler options for
  Intel(R) Compiler are reserved for Intel microprocessors.  For a detailed
  description of these compiler options, including the instructions they
  implicate, please refer to "Intel(R) Compiler User and Reference Guides >
  Compiler Options."
  usage: icl [options] file1 [file2 ...] [/link linker_options]
     where options represents zero or more compiler options
     fileN is a C/C++ source (.c .cc .cpp .cxx .i), assembly (.asm),
     object (.obj), static library (.lib), or other linkable file
     linker_options represents zero or more linker options
Notes
1. Most Microsoft* Visual C++* compiler options are supported; a warning is
   printed for most unsupported options.  The precise behavior of performance
   options does not always match that of the Microsoft Visual C++ compiler.
2. Intel C++ compiler options may be placed in your icl.cfg file.
3. Most options beginning with /Q are specific to the Intel C++ compiler:
   (*I) indicates other options specific to the Intel C++ compiler
   (*M) indicates /Q options supported by the Microsoft Visual C++ compiler
   Some options listed are only available on a specific system
   i32    indicates the feature is available on systems based on IA-32
          architecture
   i64em  indicates the feature is available on systems using Intel(R) 64
          architecture
                             Compiler Option List
Optimization
/O1       optimize for maximum speed, but disable some optimizations which
          increase code size for a small speed benefit
/O2       optimize for maximum speed (DEFAULT)
/O3       optimize for maximum speed and enable more aggressive optimizations
          that may not improve performance on some programs
/Ox       enable maximum optimizations (same as /O2)
/Os       enable speed optimizations, but disable some optimizations which
          increase code size for small speed benefit (overrides /Ot)
/Ot       enable speed optimizations (overrides /Os)
/Od       disable optimizations
/Oi[-]    enable/disable inline expansion of intrinsic functions
/Oy[-]    enable/disable using EBP as a general purpose register (no frame
          pointer) (i32 only)
/fast     enable /QxHOST /O3 /Qipo /Qprec-div- /fp:fast=2
/Oa[-]    assume no aliasing in program
/Ow[-]    assume no aliasing within functions, but assume aliasing across calls
/Qno-builtin-<func>
          disable the <func> intrinsic
/Qprotect-parens[-]
          enable/disable(DEFAULT) a reassociation optimization for REAL
          and COMPLEX expression evaluations by not honoring parenthesis
Code Generation
/Qx<code>
          generate specialized code to run exclusively on processors
          indicated by <code> as described below
            SSE2    May generate Intel(R) SSE2 and SSE instructions for Intel
                    processors.  Optimizes for the Intel NetBurst(R)
                    microarchitecture.
            SSE3    May generate Intel(R) SSE3, SSE2, and SSE instructions for
                    Intel processors.  Optimizes for the enhanced Pentium(R) M
                    processor microarchitecture and Intel NetBurst(R)
                    microarchitecture.
            SSSE3   May generate Intel(R) SSSE3, SSE3, SSE2, and SSE
                    instructions for Intel processors.  Optimizes for the
                    Intel(R) Core(TM) microarchitecture.
            SSE4.1  May generate Intel(R) SSE4 Vectorizing Compiler and Media
                    Accelerator instructions for Intel processors.  May
                    generate Intel(R) SSSE3, SSE3, SSE2, and SSE instructions
                    and it may optimize for Intel(R) 45nm Hi-k next generation
                    Intel Core(TM) microarchitecture.
            SSE4.2  May generate Intel(R) SSE4 Efficient Accelerated String
                    and Text Processing instructions supported by Intel(R)
                    Core(TM) i7 processors.  May generate Intel(R) SSE4
                    Vectorizing Compiler and Media Accelerator, Intel(R) SSSE3,
                    SSE3, SSE2, and SSE instructions and it may optimize for
                    the Intel(R) Core(TM) processor family.
            AVX     May generate Intel(R) Advanced Vector Extensions (Intel(R)
                    AVX), Intel(R) SSE4.2, SSE4.1, SSSE3, SSE3,
                    SSE2, and SSE instructions for Intel(R) processors.
            CORE-AVX2
                    May generate Intel(R) Advanced Vector Extensions 2
                    (Intel(R) AVX2), Intel(R) AVX, SSE4.2, SSE4.1, SSSE3, SSE3,
            CORE-AVX-I
                    AVX), including instructions in Intel(R) Core 2(TM)
                    processors in process technology smaller than 32nm,
                    Intel(R) SSE4.2, SSE4.1, SSSE3, SSE3, SSE2, and SSE
            ATOM_SSE4.2
                    May generate MOVBE instructions for Intel(R) processors,
                    depending on the setting of option /Qinstruction.
                    May also generate Intel(R) SSE4.2, SSE3, SSE2, and SSE
                    instructions for Intel processors. Optimizes for Intel(R)
                    Atom(TM) processors that support Intel(R) SSE4.2 and MOVBE
                    instructions.
            ATOM_SSSE3
                    May also generate Intel(R) SSSE3, SSE3, SSE2, and SSE
                    Intel(R) Atom(TM) processor that support Intel(R) SSE
                    and MOVBE instructions.
            MIC-AVX512
                    May generate Intel(R) Advanced Vector Extensions 512
                    (Intel(R) AVX-512) Foundation instructions, Intel(R)
                    AVX-512 Conflict Detection instructions, Intel(R) AVX-512
                    Exponential and Reciprocal instructions, Intel(R) AVX-512
                    Prefetch instructions for Intel(R) processors, and the
                    instructions enabled with CORE-AVX2. Optimizes for Intel(R)
                    processors that support Intel(R) AVX-512 instructions.
            KNM
                    May generate Quad Fused Multiply Add (QFMA) and Quad
                    Virtual Neural Network Instruction (QVNNI) and the
                    instructions enabled with MIC-AVX512. Optimizes for
                    Intel(R) Xeon Phi(TM) product family processor code named
                    Knights Mill.
            CORE-AVX512
                    Doubleword and Quadword instructions, Intel(R) AVX-512
                    Byte and Word instructions and Intel(R) AVX-512 Vector
                    Length Extensions for Intel(R) processors, and the
            COMMON-AVX512
                    AVX-512 Conflict Detection instructions, as well as the
            BROADWELL
            CANNONLAKE
            HASWELL
            ICELAKE-CLIENT (or ICELAKE)
            ICELAKE-SERVER
            IVYBRIDGE
            KNL
            KNM
            SANDYBRIDGE
            SILVERMONT
            SKYLAKE
            SKYLAKE-AVX512
                    May generate instructions for processors that support the
                    specified Intel(R) microarchitecture code name. Optimizes
                    for Intel(R) processors that support the specified Intel(R)
                    Keywords KNL and SILVERMONT are only available on Windows*
                    and Linux* systems.
/QxHost   generate instructions for the highest instruction set and processor
          available on the compilation host machine
/Qax<code1>[,<code2>,...]
          generate code specialized for processors specified by <codes>
          while also generating generic IA-32 instructions.
          <codes> includes one or more of the following:
                    processors.
                    Intel processors.
            SSE4.1  May generate Intel(R) SSE4.1, SSSE3, SSE3, SSE2, and SSE
            SSE4.2  May generate Intel(R) SSE4.2, SSE4.1, SSSE3, SSE3, SSE2,
                    and SSE instructions for Intel processors.
            CORE-AVX2
            CORE-AVX-I
            CORE-AVX512
            BROADWELL
            CANNONLAKE
            HASWELL
            ICELAKE-SERVER
            IVYBRIDGE
            KNL
            KNM
            SANDYBRIDGE
            SILVERMONT
            SKYLAKE
            SKYLAKE-AVX512
                    and Linux* systems.
            MIC-AVX512
/arch:<code>
          generate specialized code to optimize for processors indicated by
            BROADWELL
            CANNONLAKE
            HASWELL
            ICELAKE-SERVER
            IVYBRIDGE
            KNL
            KNM
            SANDYBRIDGE
            SILVERMONT
            SKYLAKE-AVX512
            SKYLAKE    May generate instructions for processors that support
                       the specified Intel(R) microarchitecture code name
            CORE-AVX2  May generate Intel(R) Advanced Vector Extensions 2
                       (Intel(R) AVX2), Intel(R) AVX, SSE4.2, SSE4.1, SSE3,
                       SSE2, SSE, and SSSE3 instructions
            CORE-AVX-I May generate Float-16 conversion instructions and the
                       RDRND instruction, Intel(R) Advanced Vector Extensions
                       (Intel(R) AVX), Intel(R) SSE4.2, SSE4.1, SSE3, SSE2,
            AVX        May generate Intel(R) AVX, SSE4.2, SSE4.1, SSSE3, SSE3,
            SSE4.1     May generate Intel(R) SSE4.1, SSSE3, SSE3, SSE2 and SSE
                       instructions
            SSSE3      May generate Intel(R) SSSE3, SSE3, SSE2 and SSE
                       instructions
            SSE3       May generate Intel(R) SSE3, SSE2 and SSE instructions
/Qinstruction:<keyword>
          Refine instruction set output for the selected target processor
            [no]movbe  - Do/do not generate MOVBE instructions with ATOM_SSSE3
                          (requires /QxATOM_SSSE3)
/GR[-]    enable/disable C++ RTTI
/Qcxx-features
          enable standard C++ features (/GX /GR)
/EHa      enable asynchronous C++ exception handling model
/EHs      enable synchronous C++ exception handling model
/EHc      assume extern "C" functions do not throw exceptions
/Qsafeseh[-]
          Registers exceptions for safe exception handling (DEFAULT)
/Qregcall
          make __regcall the default calling convention
/Gv       make __vectorcall the default calling convention
/guard:cf
          enable control flow protection mechanism
/hotpatch[:n]
          generate padding bytes for function entries to enable image
          hotpatching. If specified, use 'n' as the padding.
/Qextend-arguments:[32|64]
          By default, unprototyped scalar integer arguments are passed
          in 32-bits (sign-extended if necessary).
          On Intel(R) 64, unprototyped scalar integer arguments may be
          extended to 64-bits.
/Qgpu-arch:<arch>[,<arch>]
          build offload code for graphics to run on a particular graphics
          processor
            haswell    - May generate instructions for the graphics processor
                         that is on Intel(R) microarchitecture code name
                         Haswell
            broadwell  - May generate instructions for the graphics processor
                         Broadwell
            cherryview - May generate instructions for the graphics processor
                         Cherryview
            skylake    - May generate instructions for the graphics processor
                         Skylake
            broxton    - May generate instructions for the graphics processor
                         Broxton
/Qgpu-asm-dump[:<file>]
          generate a native assembly listing for the processor graphics code
          to be offloaded (Intel(R) Graphics Technology only)
/Qm32     generate code for IA-32 architecture
/Qm64     generate code for Intel(R) 64 architecture
/Qstringop-strategy:<alg>
          Override the internal decision heuristic for the particular algorithm
          to use for inlining string operations. The allowed values for <alg>:
            rep             - Expand using 1 "rep" prefix (DEFAULT for /Os)
            const_size_loop - Expand into an inline loop when size is known at
                              compile time (DEFAULT)
            libcall         - Always use a library call.
/Qstringop-inline-threshold:<val>
          inline calls to memcall-like (memcpy, memset) functions when the
          number of bytes the functions handle are known at compile time and
          less than <val>
/Qcf-protection[:<arg>]
          Enables Control-flow Enforcement Technology (CET) protection, which
          defends your program from certain attacks that exploit
          vulnerabilities.
            shadow_stack    - Enables shadow stack protection
            branch_tracking - Enables endbranch (EB) generation
            full            - Enables both shadow stack protection and
                              endbranch (EB) generation (same as no <arg>)
            none            - Disables Control-flow Enforcement Technology
                              protection
Interprocedural Optimization (IPO)
/Qip[-]   enable(DEFAULT)/disable single-file IP optimization
          within files
/Qipo[n]  enable multi-file IP optimization between files
/Qipo-c   generate a multi-file object file (ipo_out.obj)
/Qipo-S   generate a multi-file assembly file (ipo_out.asm)
/Qip-no-inlining
          disable full and partial inlining
/Qip-no-pinlining
          disable partial inlining
/Qipo-separate
          create one object file for every source file (overrides /Qipo[n])
/Qipo-jobs<n>
          specify the number of jobs to be executed simultaneously during the
          IPO link phase
Advanced Optimizations
/Qunroll[n]
          set maximum number of times to unroll loops.  Omit n to use default
          heuristics.  Use n=0 to disable the loop unroller
/Qunroll-aggressive[-]
          enables more aggressive unrolling heuristics
/Qscalar-rep[-]
          enable(DEFAULT)/disable scalar replacement (requires /O3)
/Qansi-alias[-]
          enable(DEFAULT)/disable use of ANSI aliasing rules optimizations;
          user asserts that the program adheres to these rules
/Qansi-alias-check[-]
          enable(DEFAULT)/disable ANSI alias checking when using /Qansi-alias
/Qcomplex-limited-range[-]
          enable/disable(DEFAULT) the use of the basic algebraic expansions of
          some complex arithmetic operations.  This can allow for some
          performance improvement in programs which use a lot of complex
          arithmetic at the loss of some exponent range.
/Qalias-const[-]
          enable/disable(DEFAULT) a heuristic stating that if two arguments to
          a function have pointer type, a pointer to const does not alias a
          pointer to non-const. Also known as the input/output buffer rule, it
          assumes that input and output buffer arguments do not overlap.
/Qalias-args[-]
          enable(DEFAULT)/disable C/C++ rule that function arguments may be
          aliased; when disabling the rule, the user asserts that this is safe
/Qopt-multi-version-aggressive[-]
          enables more aggressive multi-versioning to check for pointer
          aliasing and scalar replacement
/Qopt-ra-region-strategy[:<keyword>]
          select the method that the register allocator uses to partition each
          routine into regions
            routine - one region per routine
            block   - one region per block
            trace   - one region per trace
            loop    - one region per loop
            default - compiler selects best option
/Qvec[-]  enables(DEFAULT)/disables vectorization
/Qvec-guard-write[-]
          enables cache/bandwidth optimization for stores under conditionals
          within vector loops
/Qvec-threshold[n]
          sets a threshold for the vectorization of loops based on the
          probability of profitable execution of the vectorized loop in
          parallel
/Qvecabi:<arg>
          select vector function ABI
            legacy - use the legacy vector function ABI
            compat - use the compatibility vector function ABI (DEFAULT)
            cmdtarget - generate an extended set of vector functions
/Qopt-malloc-options:{0|1|2|3|4}
          specify malloc configuration parameters.  Specifying a non-zero <n>
          value will cause alternate configuration parameters to be set for
          how malloc allocates and frees memory
/Qopt-jump-tables:<arg>
          control the generation of jump tables
            default - let the compiler decide when a jump table, a series of
                      if-then-else constructs or a combination is generated
            large   - generate jump tables up to a certain pre-defined size
                      (64K entries)
            <n>     - generate jump tables up to <n> in size
          use /Qopt-jump-tables- to lower switch statements as chains of
/Qopt-block-factor:<n>
          specify blocking factor for loop blocking
/Qfreestanding
          compile in a freestanding environment where the standard library
          may not be present
/Qopt-streaming-stores:<arg>
          specifies whether streaming stores are generated
            always - enables generation of streaming stores under the
                     assumption that the application is memory bound.  Also,
                     the user is responsible for inserting the right memory
                     fences for synchronization
            auto   - compiler decides when streaming stores are used (DEFAULT)
            never  - disables generation of streaming stores
/Qipp[:<arg>]
          link some or all of the Intel(R) Integrated Performance Primitives
          (Intel(R) IPP) libraries and bring in the associated headers
            common        - link using the main libraries set.  This is the
                            default value when /Qipp is specified
            crypto        - link using the main libraries set and the crypto
                            library
/Qipp-link:<arg>
          choose whether to link with static or dynamic libraries to support
          Intel(R) Integrated Performance Primitives (Intel(R) IPP)
            dynamic       - link using the dynamic libraries set.  This is the
                            default value when /Qipp is specified on Windows
            static        - link using the static libraries set.  This is the
                            default value when /Qipp is specified on Linux
/Qmkl[:<arg>]
          link to the Intel(R) Math Kernel Library (Intel(R) MKL) and bring
            parallel   - link using the threaded Intel(R) MKL libraries. This
                         is the default when /Qmkl is specified
            sequential - link using the non-threaded Intel(R) MKL libraries
            cluster    - link using the Intel(R) MKL Cluster libraries plus
                         the sequential Intel(R) MKL libraries
/Qtbb     link to the Intel(R) Threading Building Blocks (Intel(R) TBB)
/Qdaal[:<arg>]
          link to the Intel(R) Data Analytics Acceleration Library (Intel(R)
          DAAL) libraries and bring in the associated headers
            parallel   - link using the threaded Intel(R) DAAL (DEFAULT)
            sequential - link using the non-threaded Intel(R) DAAL
/Qopt-subscript-in-range[-]
          assumes no overflows in the intermediate computation of the
          subscripts
/Quse-intel-optimized-headers[-]
          take advantage of the optimized header files
/Qvla[-]  enable/disable(DEFAULT) Variable Length Arrays (C99 feature)
/Qintel-extensions[-]
          enable(DEFAULT)/disable C/C++ language extensions such as array
          notation, Intel(R) Cilk(TM) Plus language extensions, and
          support for decimal floating-point types.
/Qopt-matmul[-]
          replace matrix multiplication with calls to intrinsics and threading
          libraries for improved performance (DEFAULT at /O3 /Qparallel)
/Qsimd[-]
          enables(DEFAULT)/disables vectorization using simd pragma
/Qsimd-function-pointers[-]
          enables/disables(DEFAULT) pointers to simd-enabled functions
/Qguide-opts:<arg>
          tells the compiler to analyze certain code and generate
          recommendations that may improve optimizations
/Qguide-file[:<filename>]
          causes the results of guide to be output to a file
/Qguide-file-append[:<filename>]
          causes the results of guide to be appended to a file
/Qguide[:<level>]
          lets you set a level (1 - 4) of guidance for auto-vectorization,
          auto-parallelization, and data transformation (DEFAULT is 4 when the
          option is specified)
/Qguide-data-trans[:<level>]
          lets you set a level (1 - 4) of guidance for data transformation
          (DEFAULT is 4 when the option is specified)
/Qguide-par[:<level>]
          lets you set a level (1 - 4) of guidance for auto-parallelization
          lets you set a level (1 - 3) of guidance for auto-parallelization
          (DEFAULT is 2 when the option is specified)
/Qguide-vec[:<level>]
/Qguide-profile:<[file|dir]>[,[file|dir],...]
          specify a loop profiler data file (or set of files in a directory)
          when using the /Qguide option
/Qopt-mem-layout-trans[:<level>]
          controls the level of memory layout transformations performed by the
          compiler
           0 - disable memory layout transformations (same as
               /Qopt-mem-layout-trans-)
           1 - enable basic memory layout transformations
           2 - enable more memory layout transformations  (DEFAULT when the
           3 - enable aggressive memory layout transformations
/Qopt-prefetch[:n]
          enable levels of prefetch insertion, where 0 disables.
          n may be 0 through 5 inclusive.  Default is 2.
/Qopt-prefetch-
          disable(DEFAULT) prefetch insertion.  Equivalent to /Qopt-prefetch:0
/Qopt-prefetch-distance:n1[,n2]
          specify the prefetch distance (how many iterations ahead, use n1 and
          n2 values such that n1>=n2) to be used for compiler generated
          prefetches inside loops.  n1 indicates distance from memory to L2
          cache and n2 indicates distance from L2 to L1.
/Qopt-prefetch-issue-excl-hint
          generates PrefetchW instruction for Intel(R) microarchitecture
          code name Broadwell processors and beyond when /Qopt-prefetch
          is also used
/Qopt-gather-scatter-unroll:n
          specify an alternative loop unroll sequence for gather and scatter
          loops (Intel(R) MIC Architecture specific).  Disable with
          /Qopt-gather-scatter-unroll- (equivalent to n=0)
/Qopt-dynamic-align
          enable(DEFAULT) dynamic data alignment optimizations.  Specify
          /Qopt-dynamic-align- to disable
/Qalign-loops[:n]
          specify code alignment of loops to improve performance.
          n is the number of bytes for the minimum alignment boundary.  It must
          be a power of 2 between 1 and 4096.  If n is not present, an
          alignment of 16 bytes is used.
          Use of /Qalign-loops- (DEFAULT) sets alignment to 1.
/Qopt-zmm-usage:<keyword>
          Specifies the level of zmm registers usage.  You can specify one of
          the following:
            low  - Tells the compiler that the compiled program is unlikely to
                   benefit from zmm registers usage. It specifies that the
                   compiler should avoid using zmm registers unless it can
                   prove the gain from their usage.
            high - Tells the compiler to generate zmm code without restrictions
/Qoverride-limits
          provides a way to override certain internal compiler limits that are
          intended to prevent excessive memory usage or compile times for very
          large, complex compilation units.
Profile Guided Optimization (PGO)
/Qprof-dir <dir>
          specify directory for profiling output files (*.dyn and *.dpi)
/Qprof-src-root <dir>
          specify project root directory for application source files to
          enable relative path resolution during profile feedback on sources
          below that directory
/Qprof-src-root-cwd
          specify the current directory as the project root directory for
          application source files to enable relative path resolution during
          profile feedback on sources below that directory
/Qprof-src-dir[-]
          specify whether directory names of sources should be
          considered when looking up profile records within the .dpi file
/Qprof-file <file>
          specify file name for profiling summary file
/Qprof-data-order[-]
          enable/disable(DEFAULT) static data ordering with profiling
/Qprof-func-order[-]
          enable/disable(DEFAULT) function ordering with profiling
/Qprof-gen[:keyword[,keyword]]
          instrument program for profiling.  Optional keywords are as follows.
            default    - Produces an instrumented object file. This is the same
                         as specifying the /Qprof-gen option with no keyword.
            srcpos     - Produces an instrumented object file and information
                         needed for using the code coverage tool.
            globdata   - Produces an instrumented object file that includes
                         information for global data layout.
            threadsafe - Collects PGO data with guards for threaded
                         applications.
/Qprof-gen-
          disable profiling instrumentation
/Qprof-use[:<arg>]
          enable use of profiling information during optimization
            weighted  - invokes profmerge with -weighted option to scale data
                        based on run durations
            [no]merge - enable(default)/disable the invocation of the profmerge
                        tool
/Qprof-use-
          disable use of profiling information during optimization
/Qcov-gen
          instrument program for profiling.  Use /Qcov-gen- to disable
/Qcov-dir <dir>
/Qcov-file <file>
/Qfnsplit[:<n>]
          enable function splitting (enabled with /Qprof-use for IA-32 Windows)
            n - positive integer indicating the threshold number.  The blocks
                can be placed into a different code segment if their
                execution probability is less than the specified value of
                range 0 <= n <= 100
          use /Qfnsplit- to disable
/Qinstrument-functions[-]
          determine whether function entry and exit points are instrumented
/Qprof-hotness-threshold:<val>
          set the hotness threshold for function grouping and function ordering
          val indicates percentage of functions to be placed in hot region.
          This option requires /Qprof-use
           and /Qprof-func-order
/Qprof-value-profiling:<arg>[,<arg>,...]
          limit value profiling
            none      - inhibit all types of value profiling
            nodivide  - inhibit value profiling of non-compile time constants
                        used in division or remainder operations
            noindcall - inhibit value profiling of function addresses at
                        indirect call sites
/Qprofile-functions
          enable instrumentation in generated code for collecting
          function execution time profiles
/Qprofile-loops:<arg>
          loop execution time profiles
             inner    - instrument inner loops
             outer    - instrument outer loops
             all      - instrument all loops
/Qprofile-loops-report:<arg>
          Control the level of instrumentation inserted for reporting loop
          execution profiles
             1    - report loop times
             2    - report loop times and iteration counts
Optimization Reports
/Qopt-report[:n]
          generate an optimization report. Default destination is
          <target>.optrpt.  Levels of 0 - 5 are valid.
          Please see documentation for additional details of
          information provided by phase per level.
            0   disable optimization report output
            2   DEFAULT when enabled
/Qopt-report-file:[stdout | stderr | <file>]
          specify the filename or output stream for the generated report
/Qopt-report-stdout
          specify the generated report should be directed to stdout
/Qopt-report-per-object
          specify the generated report should be directed to a .optrpt file
          in the output directory (DEFAULT when another destination for the
          report is not specified)
/Qopt-report-phase:<phase>[,<phase>,...]
          specify one or more phases that reports are generated against
/Qopt-report-routine:<name>[,<name>,...]
          restrict the report to routines containing the given name
/Qopt-report-filter:<string>
          restricts the opt-report to specific files, routines or line
          number ranges. Refer to the documentation for the specific
          syntax of parameter string.
/Qopt-report-format:[text|vs]
          specify the output format to be used for the opt-report as either
          plain text or a format for use in the Microsoft* Visual Studio IDE
/Qopt-report-embed[-]
          When enabled, if an assembly file is being generated, special loop
          info annotations will be emitted in the assembly file.  If an object
          file/executable is being generated, these will be emitted into the
          object file/executable for use by the Intel VTune Amplifier
          application. Automatically enabled when symbolic debug information
          is enabled.
/Qopt-report-help
          display the optimization phases available for reporting
/Qopt-report-names:<keyword>
          Specifies whether mangled or unmangled names should appear in the
            mangled   - use mangled names
            unmangled - use unmangled names (DEFAULT)
/Qopt-report-annotate[:<keyword>]
          Annotate source files with optimization reports in specified format
            html - annotate in HTML format
            text - annotate in text format (DEFAULT)
/Qopt-report-annotate-position:<keyword>
          Specify the site where loop related optimization reports appear in
          the annotated source for inlined routines
            caller - annotate at caller site
            callee - annotate at callee site
            both   - annotate at both caller and callee site
/Qtcheck[:mode]
          enable analysis of threaded applications (requires Intel(R) Thread
          Checker; cannot be used with compiler alone)
            tci - instruments a program to perform a thread-count-independent
                  analysis
            tcd - instruments a program to perform a thread-count-dependent
                  analysis (DEFAULT when mode is not used)
            api - instruments a program at the api-imports level
/Qtcollect[:<lib>]
          inserts instrumentation probes calling the Intel(R) Trace Collector
          API.  The library <lib>.lib is linked in the default being VT.lib
          (requires Intel(R) Trace Collector)
/Qtcollect-filter:file
          Enable or disable the instrumentation of specified functions.
OpenMP* and Parallel Processing
/Qopenmp  enable the compiler to generate multi-threaded code based on the
          OpenMP* directives (same as /openmp)
          Use /Qopenmp- to disable
/Qopenmp-stubs
          enables the user to compile OpenMP programs in sequential mode.  The
          OpenMP directives are ignored and a stub OpenMP library is linked
          (sequential)
/Qopenmp-lib:<ver>
          choose which OpenMP library version to link with
            compat - use the Microsoft compatible OpenMP run-time libraries
                     (DEFAULT)
/Qopenmp-threadprivate:<ver>
          choose which threadprivate implementation to use
            compat - use the Microsoft compatible thread local storage
            legacy - use the Intel compatible implementation
                     (DEFAULT)
/Qparallel
          enable the auto-parallelizer to generate multi-threaded code for
          loops that can be safely executed in parallel
/Qpar-threshold[n]
          set threshold for the auto-parallelization of loops where n is an
          integer from 0 to 100
/Qpar-runtime-control[n]
          Control parallelizer to generate runtime check code for effective
          automatic parallelization.
            n=0    no runtime check based auto-parallelization
            n=1    generate runtime check code under conservative mode
                   (DEFAULT when enabled)
            n=2    generate runtime check code under heuristic mode
            n=3    generate runtime check code under aggressive mode
/Qpar-schedule-static[:n]
          Specifies a scheduling algorithm for DO loop iteration.
          Divides iterations into contiguous pieces.  Size n if
          specified, equal sized pieces if not.
/Qpar-schedule-static-balanced[:n]
          Divides iterations into even-sized chunks.  Size n if
/Qpar-schedule-static-steal[:n]
          Divides iterations into even-sized chunks, but allows
          threads to steal parts of chunks from neighboring threads
/Qpar-schedule-dynamic[:n]
          Assigns iterations to threads in chunks dynamically.
          Chunk size is n iterations if specified, otherwise 1.
/Qpar-schedule-guided[:n]
          Indicates a minimum number of iterations.  If specified,
          n is the minimum number, otherwise 1.
/Qpar-schedule-guided-analytical[:n]
          Divides iterations by using exponential distribution or
          dynamic distributions.
/Qpar-schedule-runtime
          Defers the scheduling decision until runtime.
/Qpar-schedule-auto
          Lets the compiler or run-time system determine the
          scheduling algorithm.
/Qpar-adjust-stack<n>
          perform fiber-based main thread stack adjustment
/Qpar-affinity=[<modifier>,...]<type>[,<permute>][,<offset>]
          tune application performance by setting different thread affinity
/Qpar-num-threads=<n>
          tune application performance by setting different number of threads
/Qparallel-source-info[:n]
          enable(DEFAULT)/disable the emission of source location information
          for parallel code generation with OpenMP and auto-parallelization
            0 - disable (same as /Qparallel-source-info-)
            1 - emit routine name and line information (DEFAULT)
            2 - emit path, file, routine name and line information
/Qpar     same as /Qparallel
/Qopenmp-simd
          Enables OpenMP* SIMD compilation.  Enabled by default with
          /Qopenmp.  Use /Qopenmp-simd- to disable.
/Qopenmp-offload[:<kind>]
          Enables OpenMP* offloading compilation for target pragmas. This
          option only applies to Intel(R) MIC Architecture and Intel(R)
          Graphics Technology. Enabled by default with /Qopenmp.
          Use /Qopenmp-offload- to disable.
          Specify kind to specify the default device for target pragmas
            host - allow target code to run on host system while still doing
                   the outlining for offload
            mic  - specify Intel(R) MIC Architecture
            gfx  - specify Intel(R) Graphics Technology
Floating Point
/fp:<name>
          enable <name> floating point model variation
            except[-] - enable/disable floating point exception semantics
            fast[=1|2]  - enables more aggressive floating point optimizations
            precise     - allows value-safe optimizations
            source      - enables intermediates in source precision
                          sets /assume:protect_parens for Fortran
            strict      - enables /fp:precise /fp:except, disables
                          contractions and enables pragma stdc fenv_access
            consistent  - enables consistent, reproducible results for
                          different optimization levels or between different
                          processors of the same architecture
            double      - rounds intermediates in 53-bit (double) precision
            extended    - rounds intermediates in 64-bit (extended) precision
/Qfp-speculation:<mode>
          enable floating point speculations with the following <mode>
          conditions:
            fast   - speculate floating point operations (DEFAULT)
            safe   - speculate only when safe
            strict - same as off
            off    - disables speculation of floating-point operations
/Qpc32    set internal FPU precision to 24 bit significand
/Qprec    improve floating-point precision
/Qprec-sqrt[-]
          determine if certain square root optimizations are enabled
/Qprec-div[-]
          improve precision of FP divides (some speed impact)
/Qfast-transcendentals[-]
          generate a faster version of the transcendental functions
/Qfp-port[-]
          round fp results at assignments and casts (some speed impact)
/Qfp-stack-check
          enable fp stack checking after every function/procedure call
/Qrcd     rounding mode to enable fast float-to-int conversions
/Qftz[-]  enable/disable flush denormal results to zero
/Qfma[-]  enable/disable the combining of floating point multiplies and
          add/subtract operations
/Qfp-trap:<arg>[,<arg>,...]
          control floating point traps at program start.  <arg> can be of the
          following values
            [no]divzero   - [Do not] trap on division by zero
            [no]inexact   - [Do not] trap on inexact result
            [no]invalid   - [Do not] trap on invalid operation
            [no]overflow  - [Do not] trap on overflow
            [no]underflow - [Do not] trap on underflow
            [no]denormal  - [Do not] trap on denormal
            all           - enable trap on all of the above
            none          - trap on none of the above
            common        - trap on most commonly used IEEE traps
                            (invalid, division by zero, overflow)
/Qfp-trap-all:<arg>[,<arg>,...]
          control floating point traps in every routine.  <arg> can be of the
          values specified in /Qfp-trap
/Qimf-absolute-error:value[:funclist]
          define the maximum allowable absolute error for math library
          function results
            value    - a positive, floating-point number conforming to the
                       format [digits][.digits][{e|E}[sign]digits]
            funclist - optional comma separated list of one or more math
                       library functions to which the attribute should be
                       applied
/Qimf-accuracy-bits:bits[:funclist]
          define the relative error, measured by the number of correct bits,
          for math library function results
            bits     - a positive, floating-point number
                       applied
/Qimf-arch-consistency:value[:funclist]
          ensures that the math library functions produce consistent results
          across different implementations of the same architecture
            value    - true or false
                       applied
/Qimf-max-error:ulps[:funclist]
          defines the maximum allowable relative error, measured in ulps, for
            ulps     - a positive, floating-point number conforming to the
                       applied
/Qimf-precision:value[:funclist]
          defines the accuracy (precision) for math library functions
            value    - defined as one of the following values
                       high   - equivalent to max-error = 0.6
                       medium - equivalent to max-error = 4 (DEFAULT)
                       low    - equivalent to accuracy-bits = 11 (single
                                precision); accuracy-bits = 26 (double
                                precision)
                       applied
/Qimf-domain-exclusion:classlist[:funclist]
          indicates the input arguments domain on which math functions
          must provide correct results.
            classlist - defined as one of the following values:
                          nans, infinities, denormals, zeros
                          all, none, common
            funclist - optional list of one or more math library functions to
                       which the attribute should be applied.
/Qimf-force-dynamic-target[:funclist]
          Instructs the compiler to use run-time dispatch in calls to math
          functions
/Qfinite-math-only
          Allow optimizations for floating point arithmetic that assume
          arguments and results are not NaNs or Infinities
Inlining
/Ob<n>    control inline expansion:
            n=0  disable inlining
            n=1  inline functions declared with __inline, and perform C++
                 inlining
            n=2  inline any function, at the compiler's discretion
/Qinline-min-size:<n>
          set size limit for inlining small routines
/Qinline-min-size-
          no size limit for inlining small routines
/Qinline-max-size:<n>
          set size limit for inlining large routines
/Qinline-max-size-
          no size limit for inlining large routines
/Qinline-max-total-size:<n>
          maximum increase in size for inline function expansion
/Qinline-max-total-size-
          no size limit for inline function expansion
/Qinline-max-per-routine:<n>
          maximum number of inline instances in any function
/Qinline-max-per-routine-
          no maximum number of inline instances in any function
/Qinline-max-per-compile:<n>
          maximum number of inline instances in the current compilation
/Qinline-max-per-compile-
          no maximum number of inline instances in the current compilation
/Qinline-factor:<n>
          set inlining upper limits by n percentage
/Qinline-factor-
          do not set set inlining upper limits
/Qinline-forceinline
          treat inline routines as forceinline
/Qinline-dllimport
          allow(DEFAULT)/disallow functions declared __declspec(dllimport) to
          be inlined
/Qinline-calloc
          directs the compiler to inline calloc() calls as malloc()/memset()
/Qinline-min-caller-growth:<n>
          set lower limit on caller growth due to inlining a single routine
/Qinline-min-caller-growth-
          no lower limit on caller growth due to inlining a single routine
Output, Debug, PCH
/c        compile to object (.obj) only, do not link
/S        compile to assembly (.asm) only, do not link
/FAs      produce assembly file with optional source annotations
/FAc      produce assembly file with optional code annotations
/FA       produce assembly file
/Fa[file]
          name assembly file (or directory for multiple files; i.e. /FaMYDIR\)
/Fo[file]
          name object file (or directory for multiple files; i.e. /FoMYDIR\)
/Fe[file]
          name executable file or directory
/Fp[file]
          name precompiled header file
/Fi[file]
          name preprocessed file (or directory for multiple files; i.e.
          /FiMYDIR\)
/Zi, /ZI, /Z7
          Produce symbolic debug information.  The /Zi and /ZI flags emit the
          debug information for types into a separate PDB file.
/Zo[-]    When symbolic debug information is being produced, enable/disable
          emission of additional symbolic debug information to describe
          optimized code.
/debug[:keyword]
          Control the emission of debug information.
          Valid [keyword] values:
             none
                 Disables debug generation.
             all, full (default if no keyword was specified)
                 Generates complete debug information.
             minimal
                 Generates line number information.
             [no]inline-debug-info
                 Controls additional debug information for inlined code.
             [no]expr-source-pos
                 Controls output of source positions for expressions.
/pdbfile[:filename]
          Specify that debug related type information should be generated to a
          program database file at link time.
/nopdbfile
          Do not generate debug related information to a program database file.
/Qtrapuv  trap uninitialized variables
/RTCu     report use of variable that was not initialized
/RTC1     equivalent to /RTCsu
/RTCs     enable stack frame runtime checks
/RTCc     enable checks for converting to smaller types
/Qmap-opts
          enable option mapping tool
/Yc[file]
          create precompiled header file
/Yu[file]
          use precompiled header file
/Y-       ignore all other precompiled header file options
/Qpchi[-]
          enable(DEFAULT)/disable PCH coexistence, to reduce build time
/FD       generate file dependencies
/FR[file]
          name extended source browser file
/Qcheck-pointers:<arg>
          Specifies what type of bounds checking occurs. Possible values are:
            none   - Disables bounds checking. This is the default.
            rw     - Checks bounds for reads and writes through pointers.
            write  - Checks bounds for writes through pointers only.
/Qcheck-pointers-mpx:<arg>
          Enables bounds checking using Intel(R) MPX support. Possible
          values are:
          This switch is only valid on targets with Intel(R) MPX support.
/Qcheck-pointers-dangling:<arg>
          Specifies what type of dangling pointer checking occurs. Possible
          values are:
            none   - Disables dangling pointer checking. This is the default.
            heap   - Check dangling references on heap.
            stack  - Check dangling references on stack.
            all    - Check dangling references on both heap and stack.
/Qcheck-pointers-undimensioned[-]
          Bounds checking occurs for memory access through arrays that are
          declared without dimensions. This checking occurs for both
          dimensioned and undimensioned arrays.
/Qcheck-pointers-narrowing[-]
          When this is disabled, Pointer Checker will not give an error when
          pointers to a structure field are moved to fields in the same
          structure.
/Qeliminate-unused-debug-types[-]
          When disabled, debug information for all types present in the
          sources will be emitted.  Using this option may cause a large
          increase in the size of the debug information.
/Qemit-build-options
          Output the options used during the compilation to a corresponding
          .dashboard file.  This file is to be consumed by the dbmerge tool
          and used by the dashboard tool.
/Qemit-messages
          Output the diagnostics emitted during the compilation to a
          corresponding .dashboard file.  This file is to be consumed by the
          dbmerge tool and used by the dashboard tool.
Preprocessor
/QA<name>[<val>]
          create an assertion <name> having value <val>
/C        do not strip comments
/D<name>[{=|#}<text>]
          define macro
/U<name>  remove predefined macro
/E        preprocess to stdout
/EP       preprocess to stdout, omitting #line directives
/EP /P    preprocess to file, omitting #line directives
/u        remove all predefined macros
/FI<file>
          force inclusion of file
/I<dir>   add directory to include file search path
/X        remove standard directories from include file search path
/QH       print include file order
/QM       generate makefile dependency information
/QMM      similar to /QM, but do not include system header files
/QMG      similar to /QM, but treat missing header files as generated files
/QMD      preprocess and compile, generating output file containing dependency
          information ending with extension .d
/QMMD     similar to /QMD, but do not include system header files
/QMF<file>
          generate makefile dependency information in file (must specify /QM
          or /QMM)
/QMT<target>
          change the default target rule for dependency generation
/QdM      output macro definitions in effect after preprocessing (use with /E)
/QdD      same as /QdM, but output #define directives in preprocessed source
/QdN      same as /QdD, but #define directives contain only macro names
/Qicl-    do not predefine the "__ICL" and "__INTEL_COMPILER" macros.
          Warning: can prevent correct Intel header compilation
Component Control
/Qoption,<tool>,<opts>
          pass options <opts> to tool specified by <tool>
/Qlocation,<tool>,<dir>
          set <dir> as the location of tool specified by <tool>
Language
/Qstd=<std>
          enable language support for <std>, as described below
            c99   conforms to ISO/IEC 9899:1999 standard for C programs
            c11   conforms to ISO/IEC 9899:2011 standard for C programs
            c++11 enables C++11 support for C++ programs
            c++14 enables experimental C++14 support for C++ programs
            c++17 enables experimental C++17 support for C++ programs
/Za       disable Microsoft Visual C++ compiler language extensions
/Zg       enable the generation of function prototypes
/Zp[n]    specify alignment constraint for structures where
          n=1,2,4,8,16. 16 is the default
/Zc:arg1[,arg2]
          specify standard conformance for the following arguments:
            forScope[-] enforce standard compliance in for loop scope
            throwingNew[-] link with the operator new implementation
            wchar_t[-]  specify that wchar_t is a native data type
            auto[-]  enforce compliance to the new standard meaning for auto
            trigraphs[-]  accept trigraph character sequences
            strictStrings[-] enforce const qualification for string literals
            rvalueCast[-] cast of lvalue to its own type results in rvalue
            threadSafeInit[-] thread-safe initialization of local statics
            inline[-] control inline expansion
/Zs       perform syntax and semantic checking only (no object file produced)
/vd{0|1|2}
          disable or enable hidden vtordisp field in C++ objects
/vm[x]    specify representation method for C++ pointers to members
/J        change default char type to unsigned
/noBool   suppresses the C++ bool, true, and false keywords
/Qtemplate-depth:n
          control the depth in which recursive templates are expanded
/Qrestrict[-]
          enable/disable the 'restrict' keyword for disambiguating pointers
/Qhelp-pragma
          output supported pragmas and their usage syntax
/check:<keyword>[,<keyword>,...]
          check run-time conditions.
          keywords:  [no]conversions, [no]stack, [no]uninit
Compiler Diagnostics
/w        disable all warnings
/W0       print only errors
/W1, /W2, /W3
          print only errors and warnings (DEFAULT)
/W4, /Wall
          print errors, warnings and most remarks
/W5       print all errors, warnings and remarks
/WL       print brief one-line diagnostics
/WX       force warnings to be reported as errors
/Werror-all
          force warnings and currently enabled remarks to be reported as errors
/Wcheck   enable more strict diagnostics
/Wport    issue portability diagnostics
/Qeffc++  enable effective C++ diagnostic warnings
/Qwo<L1>[,<L2>,...]
          issue diagnostics L1 through LN only once
/Wp64     print diagnostics for 64-bit porting
/Qdiag-enable:<v1>[,<v2>,...]
          enable the specified diagnostics or diagnostic groups
/Qdiag-disable:<v1>[,<v2>,...]
          disable the specified diagnostics or diagnostic groups
          where <vN> may be individual diagnostic numbers or group names.
          where group names include:
              thread     - diagnostics to aid in thread-enabling source
              power      - controls whether diagnostics are enabled for
                           possibly inefficient code that may affect power
                           consumption when running on Intel(R) processors
              port-linux - diagnostics for Microsoft extensions that
                           may cause errors when porting to Linux/MacOS
              openmp     - diagnostics issued by the OpenMP* parallelizer
              warn       - diagnostics that have "warning" severity level
              error      - diagnostics that have "error" severity level
              remark     - diagnostics that are remarks or comments
              vec        - diagnostics issued by the vectorizer
              par        - diagnostics issued by the auto-parallelizer
              cpu-dispatch
                         - specifies the CPU dispatch remarks
/Qdiag-error:<v1>[,<v2>,...]
          output the specified diagnostics or diagnostic groups as errors
/Qdiag-warning:<v1>[,<v2>,...]
          output the specified diagnostics or diagnostic groups as warnings
/Qdiag-remark:<v1>[,<v2>,...]
          output the the specified diagnostics or diagnostic groups as remarks
/Qdiag-dump
          display the currently enabled diagnostic messages to stdout or to a
          specified diagnostic output file.
/Qdiag-file[:<file>]
          <file> where diagnostics are emitted to.  Not specifying this causes
          messages to be output to stderr
/Qdiag-file-append[:<file>]
          <file> where diagnostics are emitted to. When <file> already exists,
          output is appended to the file
/Qdiag-id-numbers[-]
          enable(DEFAULT)/disable the diagnostic specifiers to be output in
          numeric form
/Qdiag-error-limit:<num>
          specify the maximum number of errors emitted
/Qdiag-once:<v1>[,<v2>,...]
          issue diagnostics v1 through vN only once
/Wpch-messages[-]
          enable(DEFAULT)/disable PCH information messages
Miscellaneous
/nologo   do not display compiler version information
/Qsave-temps
          store the intermediate files in current directory and name them
          based on the source file.  Only saves files that are generated by
          default
/watch:<keyword>
          tells the driver to output processing information
            keywords: all, none (same as /nowatch), [no]source,
                      [no]cmd
                      [no]mic-cmd
/nowatch  suppress processing information output (DEFAULT)
/Tc<file>
          compile file as C source
/Tp<file>
          compile file as C++ source
/TC       compile all source or unrecognized file types as C source files
/TP       compile all source or unrecognized file types as C++ source files
/showIncludes
          emit include file names
/Qmultibyte-chars[-]
          provide support for multi-byte characters
/MP[<n>]  create multiple processes that can be used to compile large numbers
          of source files at the same time
/MP-force
          Use with /MP<n> to force the given <n> processes to be created
/bigobj   generate objects with increased address capacity
/Qoffload:<arg>
          define whether offload is enabled, and if enabled, whether CPU
          fallback is permitted
            keywords:  none, optional, mandatory
/Qoffload-attribute-target:<name>
          flags every global routine and global data object in the source
          file with the offload attribute target(<name>)
            name - mic, gfx (gfx for C/C++ compilation only)
/Qoffload-option,<target>,<tool>,"option list"
          appends additional options for offload compilations given the
          target and tool.  The option list is a space separated quoted list
          of options
            target - mic, gfx (gfx for C/C++ compilation only)
            tool   - compiler, link, asm, jit (gfx only)
/Qoffload-
          disable any offload usage
/Qoffload-arch:<arch>[:<visa>]
          specify the target architecture to use when offloading code
            arch - Specifies the target architecture. On Intel(R) 64
                   architecture targeting Intel(R) MIC Architecture, arch can
                   be mic-avx512. On IA-32 and Intel(R) 64 architectures
                   targeting Intel(R) Graphics Technology, arch can be
                   haswell, broadwell, cherryview, skylake, or broxton.
            visa - Specifies the virtual ISA (vISA) version to be used. This
                   optional argument is only allowed on IA-32 and Intel(R) 64
                   architectures targeting Intel(R) Graphics Technology. You
                   can specify either visa3.1 or visa3.2.
/Qoffload-svm[-]
          Determines whether the compiler uses Shared Virtual Memory (SVM)
          mode.  This option only applies to Intel(R) Graphics Technology.
Data
/Zp[n]    specify alignment constraint for structures (n=1,2,4,8,16
          /Zp16 DEFAULT)
/GS       enable overflow security checks.  Optional <arg> can specify:
            partial - provide a stack protection level that is compatible with
                      Microsoft* Visual Studio 2008.
            strong  - provide full stack security level checking. This setting
                      is compatible with recent Microsoft* Visual Studio stack
                      protection heuristics. This is the same as specifying /GS
                      with no keyword.
            off     - Same as /GS- (DEFAULT)
/GF       enable read-only string pooling optimization
/GA       optimize for Windows application (assume .exe)
/GT       enable fiber-safe thread local storage
/Qauto-ilp32
           specify that the application cannot exceed a 32-bit address space
           (/Qipo[n] required)
/Qpatchable-addresses
           generate code such that references to statically assigned addresses
           can be patched with arbitrary 64-bit addresses.
/Qsfalign8
          may align stack for functions with 8 or 16 byte vars (DEFAULT)
/Qsfalign16
          may align stack for functions with 16 byte vars
/Qsfalign
          force stack alignment for all functions
/Qsfalign-
          disable stack alignment for all functions
/homeparams
          force to store parameters passed in registers to the stack
/Qglobal-hoist[-]
          enable(DEFAULT)/disable external globals are load safe
/Qkeep-static-consts[-]
          enable/disable(DEFAULT) the ability to preserve allocation of
          variables that are not referenced in the source
/Qlong-double
          enable 80-bit 'long double'
/Qnobss-init
          disable placement of zero-initialized variables in BSS (use DATA)
/Qzero-initialized-in-bss[-]
          put explicitly zero initialized variables into the DATA section
          instead of the BSS section
/Qfnalign:<n>
          align the start of functions on a 2 (DEFAULT) or <n> byte boundary
          where <n> is a power of 2
/Qfnalign
          align the start of functions to an optimal machine-dependent value.
          /Qfnalign- (DEFAULT) aligns on a 2-byte boundary
Compatibility
/Qms      tells the compiler to emulate Microsoft compatibility bugs
            n=0  disable Microsoft compatibility bugs
            n=1  enable most Microsoft compatibilities (DEFAULT)
            n=2  full Microsoft compatibility
/Qvc<arg>
          enable compatibility with a specific Microsoft* Visual Studio version
            12   - Microsoft* Visual Studio 2013 compatibility
            14   - Microsoft* Visual Studio 2015 compatibility
            14.1 - Microsoft* Visual Studio 2017 compatibility
/Qgcc-dialect:<version>
          enable a limited gcc-compatible dialect on Windows. The gcc
          version may be specified as 440, 450, 460, 470, 480 or 490.
            Example: /Qgcc-dialect:440 -> gcc 4.4 compatibility
Linking/Linker
/link     specify that all options following '/link' are for the linker
/F<n>     set the stack reserve amount specified to the linker
/LD[d]    produce a DLL instead of an EXE ('d' = debug version)
/MD[d]    use dynamically-loaded, multithread C runtime
/MT[d]    use statically-linked, multithread C runtime (DEFAULT with
          Microsoft Visual Studio 2005 and later)
/Zl       omit library names from object file
Deprecated Options
/Quse-asm                No replacement
/Qvc11                   No replacement
/Qcilk-serialize         No replacement
/Qopenmp-task=<arg>      use OpenMP* tasking scheme
/arch:SSE                use /arch:IA32
/arch:ICELAKE            use /arch:ICELAKE-CLIENT
/QxSSE3_ATOM             use /QxATOM_SSSE3
/QxSSSE3_ATOM            use /QxATOM_SSSE3
/QxICELAKE               use /QxICELAKE-CLIENT
/QaxICELAKE              use /QaxICELAKE-CLIENT
/Fr                      use /FR
/GX                      use /EHsc
/GZ                      use /RTC1
/H                       No replacement
/Qwn                     use /Qdiag-error-limit:<n>
/Qwd                     use /Qdiag-disable
/Qwe                     use /Qdiag-error
/Qww                     use /Qdiag-warning
/Qwr                     use /Qdiag-remark
/Qwo                     use /Qdiag-once
/Yd                      use /Zi, /ZI, /Z7
/Ze                      No replacement
/Zg                      No replacement
/help, /? [category]   print full or category help message
Valid categories include
       advanced        - Advanced Optimizations
       codegen         - Code Generation
       compatibility   - Compatibility
       component       - Component Control
       data            - Data
       deprecated      - Deprecated Options
       diagnostics     - Compiler Diagnostics
       float           - Floating Point
       help            - Help
       inline          - Inlining
       ipo             - Interprocedural Optimization (IPO)
       language        - Language
       link            - Linking/Linker
       misc            - Miscellaneous
       opt             - Optimization
       output          - Output
       pgo             - Profile Guided Optimization (PGO)
       preproc         - Preprocessor
       reports         - Optimization Reports
       openmp          - OpenMP and Parallel Processing
Copyright (C) 1985-2018, Intel Corporation.  All rights reserved.
* Other names and brands may be claimed as the property of others.
            Trying C compiler flag -PIC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp -PIC   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/PIC'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
                Rejecting compiler flag -PIC  due to
conftest.c
            Rejected C compiler flag -PIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
            Trying C compiler flag -fPIC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp -fPIC   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/fPIC'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
                Rejecting compiler flag -fPIC  due to
conftest.c
            Rejected C compiler flag -fPIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
            Trying C compiler flag -KPIC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp -KPIC   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/KPIC'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
                Rejecting compiler flag -KPIC  due to
conftest.c
            Rejected C compiler flag -KPIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
            Trying C compiler flag -qpic
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp -qpic   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/qpic'
conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
                Rejecting compiler flag -qpic  due to
conftest.c
            Rejected C compiler flag -qpic because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
              Deleting "LD_SHARED"
            Checking shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-dynamic']
Checking for program /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe...found
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -dynamic  -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: icl: command line warning #10006: ignoring unknown option '/dynamic'
              Rejecting C linker flag -dynamic due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
                      Pushing language C
                      Popping language C
stdout:
LINK : fatal error LNK1561: entry point must be defined            Rejected C compiler flag  because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -PIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -fPIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -KPIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-dynamic']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -qpic because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-dynamic']
            Checking shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-qmkshrobj']
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added C compiler flag
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -qmkshrobj  -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: icl: command line warning #10006: ignoring unknown option '/qmkshrobj'
              Rejecting C linker flag -qmkshrobj due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
int (*fprintf_ptr)(FILE*,const char*,...) = fprintf;
void  foo(void){
  fprintf_ptr(stdout,"hello");
  return;
void bar(void){foo();}
                      Pushing language C
                      Popping language C
stdout:
LINK : fatal error LNK1561: entry point must be defined            Rejected C compiler flag  because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -PIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -fPIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -KPIC because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-qmkshrobj']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Rejected C compiler flag -qpic because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-qmkshrobj']
            Checking shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
                Defined make macro "LD_SHARED" to "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl"
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -shared  -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: icl: command line warning #10006: ignoring unknown option '/shared'
              Rejecting C linker flag -shared due to
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void __declspec(dllexport)  foo(void){
  return;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconftest.dll   -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout:
Creating library C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\libconftest.lib and object C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\libconftest.exp
Possible ERROR while running linker: exit code 6400
stdout:
LINK : fatal error LNK1561: entry point must be defined            Rejected C compiler flag  because it was not compatible with shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-shared']
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
conftest.c
            Checking shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl using flags ['-LD']
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -LD  -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
              Valid C linker flag -LD
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
  return;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconftest.dll  -LD -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: Creating library C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\libconftest.lib and object C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\libconftest.exp
stdout: conftest.c
Successful compile:
Source:
__declspec(dllimport) int foo(void);
int main() {
int ret = foo();
if (ret) {}
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe   -O2 -MT -wd4996 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o  -L/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -lconftest
            Using shared linker /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl with flags ['-LD'] and library extension dll
Executing: uname -s
stdout: CYGWIN_NT-6.1
TEST checkPIC from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1065)
TESTING: checkPIC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1065)
  Determine the PIC option for each compiler
              Pushing language C
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
                      Pushing language C
                      Popping language C
            Accepted C compiler flag
              Popping language C
              Pushing language Cxx
            Trying Cxx compiler flag
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp      /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag
stdout: conftest.cc
Successful compile:
Source:
#include <stdio.h>
void  foo(void){
  return;
                  Pushing language C
                      Pushing language C
                      Popping language C
                  Popping language C
            Accepted Cxx compiler flag
              Popping language Cxx
              Pushing language FC
            Trying FC compiler flag
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Added FC compiler flag
Successful compile:
Source:
      function foo(a)
      real:: a,x,bar
      common /xx/ x
      x=a
      foo = bar(x)
      end
                  Pushing language C
                      Pushing language C
                      Popping language C
                  Popping language C
stdout:
conftest.obj : error LNK2019: unresolved external symbol BAR referenced in function FOO
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\libconftest.dll : fatal error LNK1120: 1 unresolved externals
Possible ERROR while running linker: exit code 24576
stdout:
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\libconftest.dll : fatal error LNK1120: 1 unresolved externals            Rejected FC compiler flag  because shared linker cannot handle it
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort --help
stdout:
Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
Usage: win32fe <tool> --<win32fe options> -<tool options> <files>
  <tool> must be the first argument to win32fe
<tool>: {cl,icl,df,f90,ifl,bcc32,lib,tlib}
  cl:    Microsoft 32-bit C/C++ Optimizing Compiler
  icl:   Intel C/C++ Optimizing Compiler
  df:    Compaq Visual Fortran Optimizing Compiler
  f90:   Compaq Visual Fortran90 Optimizing Compiler
  ifl:   Intel Fortran Optimizing Compiler
  ifort: Intel Fortran Optimizing Compiler
  nvcc:  NVIDIA CUDA Compiler Driver
  bcc32: Borland C++ for Win32
  lib:   Microsoft Library Manager
  tlib:  Borland Library Manager
<win32fe options>:
  --help:       Output this help message and help for <tool>
  --path <arg>: <arg> specifies an addition to the PATH that is required
                (ex. the location of a required .dll)
  --use <arg>:  <arg> specifies the variant of <tool> to use
  --verbose:    Echo to stdout the translated commandline
                and other diagnostic information
  --version:    Output version info for win32fe and <tool>
  --wait_for_debugger:  Inserts an infinite wait after creation of <tool>
                and outputs PID so one can manually attach a debugger to the
                current process.  In the debugger, one must set:
                   tool::waitfordebugger = 0
                to continue the execution normally.
  --win-l:      For compilers, define -lfoo to link foo.lib instead of libfoo.lib
  --woff:       Suppress win32fe specific warning messages
For compilers:
  win32fe will map the following <tool options> to their native options:
    -c:          Compile Only, generates an object file with .o extension
                 This will invoke the compiler once for each file listed.
    -l<library>: Link the file lib<library>.lib or if using --win-l also, <library>.lib
    -o <file>:   Output=<file> context dependent
    -D<macro>:   Define <macro>
    -I<path>:    Add <path> to the include path
    -L<path>:    Add <path> to the link path
    -g:          Generate debug symbols in objects when specified for compilation,
                 and in executables when specified for linking (some compilers
                 specification at both times for full debugging support).
    -O:          Enable compiletime and/or linktime optimizations.
Ex: win32fe cl -g -c foo.c --verbose -Iinclude
Note: win32fe will automatically find the system library paths and
      system include paths, relieving the user of the need to invoke a
      particular shell.
icl specific help:
  win32fe uses -nologo by default for nonverbose output.  Use the flag:
     -logo  to disable this feature.
  -g is identical to -Z7.
  -O is identical to -O2.
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
                         Intel(R) Fortran Compiler Help
  Intel(R) Compiler includes compiler options that optimize for instruction
  sets that are available in both Intel(R) and non-Intel microprocessors, but
  may perform additional optimizations for Intel microprocessors than for
  non-Intel microprocessors.  In addition, certain compiler options for
  Intel(R) Compiler are reserved for Intel microprocessors.  For a detailed
  description of these compiler options, including the instructions they
  implicate, please refer to "Intel(R) Compiler User and Reference Guides >
  Compiler Options."
   usage: ifort [options] file1 [file2 ...] [/link linker_options]
      where options represents zero or more compiler options
      fileN is a Fortran source (.f .for .ftn .f90 .fpp .i .i90),
      assembly (.asm), object (.obj), static library (.lib), or
      other linkable file
      linker_options represents zero or more linker options
Notes
1. Many FL32 options are supported; a warning is printed for unsupported
   options.
2. Intel Fortran compiler options may be placed in your ifort.cfg file.
   Some options listed are only available on a specific system
   i32    indicates the feature is available on systems based on IA-32
          architecture
   i64em  indicates the feature is available on systems using Intel(R) 64
          architecture
                             Compiler Option List
Optimization
/O1       optimize for maximum speed, but disable some optimizations which
          increase code size for a small speed benefit
/O2       optimize for maximum speed (DEFAULT)
/O3       optimize for maximum speed and enable more aggressive optimizations
          that may not improve performance on some programs
/Ox       enable maximum optimizations (same as /O2)
/Os       enable speed optimizations, but disable some optimizations which
          increase code size for small speed benefit (overrides /Ot)
/Ot       enable speed optimizations (overrides /Os)
/Od       disable optimizations
/Oy[-]    enable/disable using EBP as a general purpose register (no frame
          pointer) (i32 only)
/fast     enable /QxHOST /O3 /Qipo /Qprec-div- /fp:fast=2
/Oa[-]    assume no aliasing in program
/Ow[-]    assume no aliasing within functions, but assume aliasing across calls
/Qprotect-parens[-]
          enable/disable(DEFAULT) a reassociation optimization for REAL
          and COMPLEX expression evaluations by not honoring parenthesis
Code Generation
/Qx<code>
          generate specialized code to run exclusively on processors
          indicated by <code> as described below
            SSE2    May generate Intel(R) SSE2 and SSE instructions for Intel
                    processors.  Optimizes for the Intel NetBurst(R)
                    microarchitecture.
            SSE3    May generate Intel(R) SSE3, SSE2, and SSE instructions for
                    Intel processors.  Optimizes for the enhanced Pentium(R) M
                    processor microarchitecture and Intel NetBurst(R)
                    microarchitecture.
            SSSE3   May generate Intel(R) SSSE3, SSE3, SSE2, and SSE
                    instructions for Intel processors.  Optimizes for the
                    Intel(R) Core(TM) microarchitecture.
            SSE4.1  May generate Intel(R) SSE4 Vectorizing Compiler and Media
                    Accelerator instructions for Intel processors.  May
                    generate Intel(R) SSSE3, SSE3, SSE2, and SSE instructions
                    and it may optimize for Intel(R) 45nm Hi-k next generation
                    Intel Core(TM) microarchitecture.
            SSE4.2  May generate Intel(R) SSE4 Efficient Accelerated String
                    and Text Processing instructions supported by Intel(R)
                    Core(TM) i7 processors.  May generate Intel(R) SSE4
                    Vectorizing Compiler and Media Accelerator, Intel(R) SSSE3,
                    SSE3, SSE2, and SSE instructions and it may optimize for
                    the Intel(R) Core(TM) processor family.
            AVX     May generate Intel(R) Advanced Vector Extensions (Intel(R)
                    AVX), Intel(R) SSE4.2, SSE4.1, SSSE3, SSE3,
                    SSE2, and SSE instructions for Intel(R) processors.
            CORE-AVX2
                    May generate Intel(R) Advanced Vector Extensions 2
                    (Intel(R) AVX2), Intel(R) AVX, SSE4.2, SSE4.1, SSSE3, SSE3,
            CORE-AVX-I
                    AVX), including instructions in Intel(R) Core 2(TM)
                    processors in process technology smaller than 32nm,
                    Intel(R) SSE4.2, SSE4.1, SSSE3, SSE3, SSE2, and SSE
            ATOM_SSE4.2
                    May generate MOVBE instructions for Intel(R) processors,
                    depending on the setting of option /Qinstruction.
                    May also generate Intel(R) SSE4.2, SSE3, SSE2, and SSE
                    instructions for Intel processors. Optimizes for Intel(R)
                    Atom(TM) processors that support Intel(R) SSE4.2 and MOVBE
                    instructions.
            ATOM_SSSE3
                    May also generate Intel(R) SSSE3, SSE3, SSE2, and SSE
                    Intel(R) Atom(TM) processor that support Intel(R) SSE
                    and MOVBE instructions.
            MIC-AVX512
                    May generate Intel(R) Advanced Vector Extensions 512
                    (Intel(R) AVX-512) Foundation instructions, Intel(R)
                    AVX-512 Conflict Detection instructions, Intel(R) AVX-512
                    Exponential and Reciprocal instructions, Intel(R) AVX-512
                    Prefetch instructions for Intel(R) processors, and the
                    instructions enabled with CORE-AVX2. Optimizes for Intel(R)
                    processors that support Intel(R) AVX-512 instructions.
            KNM
                    May generate Quad Fused Multiply Add (QFMA) and Quad
                    Virtual Neural Network Instruction (QVNNI) and the
                    instructions enabled with MIC-AVX512. Optimizes for
                    Intel(R) Xeon Phi(TM) product family processor code named
                    Knights Mill.
            CORE-AVX512
                    Doubleword and Quadword instructions, Intel(R) AVX-512
                    Byte and Word instructions and Intel(R) AVX-512 Vector
                    Length Extensions for Intel(R) processors, and the
            COMMON-AVX512
                    AVX-512 Conflict Detection instructions, as well as the
            BROADWELL
            CANNONLAKE
            HASWELL
            ICELAKE-CLIENT (or ICELAKE)
            ICELAKE-SERVER
            IVYBRIDGE
            KNL
            KNM
            SANDYBRIDGE
            SILVERMONT
            SKYLAKE
            SKYLAKE-AVX512
                    May generate instructions for processors that support the
                    specified Intel(R) microarchitecture code name. Optimizes
                    for Intel(R) processors that support the specified Intel(R)
                    Keywords KNL and SILVERMONT are only available on Windows*
                    and Linux* systems.
/QxHost   generate instructions for the highest instruction set and processor
          available on the compilation host machine
/Qax<code1>[,<code2>,...]
          generate code specialized for processors specified by <codes>
          while also generating generic IA-32 instructions.
          <codes> includes one or more of the following:
                    processors.
                    Intel processors.
            SSE4.1  May generate Intel(R) SSE4.1, SSSE3, SSE3, SSE2, and SSE
            SSE4.2  May generate Intel(R) SSE4.2, SSE4.1, SSSE3, SSE3, SSE2,
                    and SSE instructions for Intel processors.
            CORE-AVX2
            CORE-AVX-I
            CORE-AVX512
            BROADWELL
            CANNONLAKE
            HASWELL
            ICELAKE-SERVER
            IVYBRIDGE
            KNL
            KNM
            SANDYBRIDGE
            SILVERMONT
            SKYLAKE
            SKYLAKE-AVX512
                    and Linux* systems.
            MIC-AVX512
/arch:<code>
          generate specialized code to optimize for processors indicated by
            BROADWELL
            CANNONLAKE
            HASWELL
            ICELAKE-SERVER
            IVYBRIDGE
            KNL
            KNM
            SANDYBRIDGE
            SILVERMONT
            SKYLAKE-AVX512
            SKYLAKE    May generate instructions for processors that support
                       the specified Intel(R) microarchitecture code name
            CORE-AVX2  May generate Intel(R) Advanced Vector Extensions 2
                       (Intel(R) AVX2), Intel(R) AVX, SSE4.2, SSE4.1, SSE3,
                       SSE2, SSE, and SSSE3 instructions
            CORE-AVX-I May generate Float-16 conversion instructions and the
                       RDRND instruction, Intel(R) Advanced Vector Extensions
                       (Intel(R) AVX), Intel(R) SSE4.2, SSE4.1, SSE3, SSE2,
            AVX        May generate Intel(R) AVX, SSE4.2, SSE4.1, SSSE3, SSE3,
            SSE4.1     May generate Intel(R) SSE4.1, SSSE3, SSE3, SSE2 and SSE
                       instructions
            SSSE3      May generate Intel(R) SSSE3, SSE3, SSE2 and SSE
                       instructions
            SSE3       May generate Intel(R) SSE3, SSE2 and SSE instructions
/Qinstruction:<keyword>
          Refine instruction set output for the selected target processor
            [no]movbe  - Do/do not generate MOVBE instructions with ATOM_SSSE3
                          (requires /QxATOM_SSSE3)
/guard:cf
          enable control flow protection mechanism
/Qextend-arguments:[32|64]
          By default, unprototyped scalar integer arguments are passed
          in 32-bits (sign-extended if necessary).
          On Intel(R) 64, unprototyped scalar integer arguments may be
          extended to 64-bits.
/Qm32     generate code for IA-32 architecture
/Qm64     generate code for Intel(R) 64 architecture
/Qstringop-strategy:<alg>
          Override the internal decision heuristic for the particular algorithm
          to use for inlining string operations. The allowed values for <alg>:
            rep             - Expand using 1 "rep" prefix (DEFAULT for /Os)
            const_size_loop - Expand into an inline loop when size is known at
                              compile time (DEFAULT)
            libcall         - Always use a library call.
/Qstringop-inline-threshold:<val>
          inline calls to memcall-like (memcpy, memset) functions when the
          number of bytes the functions handle are known at compile time and
          less than <val>
/Qcf-protection[:<arg>]
          Enables Control-flow Enforcement Technology (CET) protection, which
          defends your program from certain attacks that exploit
          vulnerabilities.
            shadow_stack    - Enables shadow stack protection
            branch_tracking - Enables endbranch (EB) generation
            full            - Enables both shadow stack protection and
                              endbranch (EB) generation (same as no <arg>)
            none            - Disables Control-flow Enforcement Technology
                              protection
/Qip[-]   enable(DEFAULT)/disable single-file IP optimization
          within files
/Qipo[n]  enable multi-file IP optimization between files
/Qipo-c   generate a multi-file object file (ipo_out.obj)
/Qipo-S   generate a multi-file assembly file (ipo_out.asm)
/Qip-no-inlining
          disable full and partial inlining
/Qip-no-pinlining
          disable partial inlining
/Qipo-separate
          create one object file for every source file (overrides /Qipo[n])
/Qipo-jobs<n>
          specify the number of jobs to be executed simultaneously during the
          IPO link phase
/Qunroll[n]
          set maximum number of times to unroll loops.  Omit n to use default
          heuristics.  Use n=0 to disable the loop unroller
/Qunroll-aggressive[-]
          enables more aggressive unrolling heuristics
/Qscalar-rep[-]
          enable(DEFAULT)/disable scalar replacement (requires /O3)
/Qpad[-]  enable/disable(DEFAULT) changing variable and array memory layout
/Qsafe-cray-ptr
          Cray pointers do not alias with other variables
/Qansi-alias[-]
          enable(DEFAULT)/disable use of ANSI aliasing rules optimizations;
          user asserts that the program adheres to these rules
/Qcomplex-limited-range[-]
          enable/disable(DEFAULT) the use of the basic algebraic expansions of
          some complex arithmetic operations.  This can allow for some
          performance improvement in programs which use a lot of complex
          arithmetic at the loss of some exponent range.
/reentrancy:<keyword>
          specify whether the threaded, reentrant run-time support should be
          used
          Keywords:  none (same as /noreentrancy), threaded(DEFAULT), async
/noreentrancy
          do not use threaded, reentrant run-time support
/heap-arrays[:n]
          temporary arrays of minimum size n (in kilobytes) are allocated in
          heap memory rather than on the stack.  If n is not specified,
          all temporary arrays are allocated in heap memory.
/heap-arrays-
          temporary arrays are allocated on the stack (DEFAULT)
/Qopt-multi-version-aggressive[-]
          enables more aggressive multi-versioning to check for pointer
          aliasing and scalar replacement
/Qopt-ra-region-strategy[:<keyword>]
          select the method that the register allocator uses to partition each
          routine into regions
            routine - one region per routine
            block   - one region per block
            trace   - one region per trace
            loop    - one region per loop
            default - compiler selects best option
/Qvec[-]  enables(DEFAULT)/disables vectorization
/Qvec-guard-write[-]
          enables cache/bandwidth optimization for stores under conditionals
          within vector loops
/Qvec-threshold[n]
          sets a threshold for the vectorization of loops based on the
          probability of profitable execution of the vectorized loop in
          parallel
/Qvecabi:<arg>
          select vector function ABI
            legacy - use the legacy vector function ABI
            compat - use the compatibility vector function ABI (DEFAULT)
            cmdtarget - generate an extended set of vector functions
/Qopt-malloc-options:{0|1|2|3|4}
          specify malloc configuration parameters.  Specifying a non-zero <n>
          value will cause alternate configuration parameters to be set for
          how malloc allocates and frees memory
/Qopt-jump-tables:<arg>
          control the generation of jump tables
            default - let the compiler decide when a jump table, a series of
                      if-then-else constructs or a combination is generated
            large   - generate jump tables up to a certain pre-defined size
                      (64K entries)
            <n>     - generate jump tables up to <n> in size
          use /Qopt-jump-tables- to lower switch statements as chains of
/Qopt-block-factor:<n>
          specify blocking factor for loop blocking
/Qopt-streaming-stores:<arg>
          specifies whether streaming stores are generated
            always - enables generation of streaming stores under the
                     assumption that the application is memory bound.  Also,
                     the user is responsible for inserting the right memory
                     fences for synchronization
            auto   - compiler decides when streaming stores are used (DEFAULT)
            never  - disables generation of streaming stores
/Qmkl[:<arg>]
          link to the Intel(R) Math Kernel Library (Intel(R) MKL) and bring
          in the associated headers
            parallel   - link using the threaded Intel(R) MKL libraries. This
                         is the default when /Qmkl is specified
            sequential - link using the non-threaded Intel(R) MKL libraries
            cluster    - link using the Intel(R) MKL Cluster libraries plus
                         the sequential Intel(R) MKL libraries
/Qimsl    link to the International Mathematics and Statistics Library* (IMSL*
          library)
/Qopt-subscript-in-range[-]
          assumes no overflows in the intermediate computation of the
          subscripts
/Qcoarray[:<keyword>]
          enable/disable(DEFAULT) coarray syntax for data parallel
          programming, and set the relationship between the coarray
          images.
          keywords: shared      - default if keyword is omitted
                    single      - overrides any other keyword
                    distributed - only valid with the Intel(R)
                                  Cluster Toolkit
                    coprocessor - Intel(R) 64 Linux only
/Qcoarray-num-images:n
          set default number of coarray images
/Qopt-matmul[-]
          replace matrix multiplication with calls to intrinsics and threading
          libraries for improved performance (DEFAULT at /O3 /Qparallel)
/Qsimd[-]
          enables(DEFAULT)/disables vectorization using SIMD directive
/Qguide-opts:<arg>
          tells the compiler to analyze certain code and generate
          recommendations that may improve optimizations
/Qguide-file[:<filename>]
          causes the results of guide to be output to a file
/Qguide-file-append[:<filename>]
          causes the results of guide to be appended to a file
/Qguide[:<level>]
          lets you set a level (1 - 4) of guidance for auto-vectorization,
          auto-parallelization, and data transformation (DEFAULT is 4 when the
          option is specified)
/Qguide-data-trans[:<level>]
          lets you set a level (1 - 4) of guidance for data transformation
          (DEFAULT is 4 when the option is specified)
/Qguide-par[:<level>]
          lets you set a level (1 - 4) of guidance for auto-parallelization
          lets you set a level (1 - 3) of guidance for auto-parallelization
          (DEFAULT is 2 when the option is specified)
/Qguide-vec[:<level>]
/Qguide-profile:<[file|dir]>[,[file|dir],...]
          specify a loop profiler data file (or set of files in a directory)
          when using the /Qguide option
/Qopt-mem-layout-trans[:<level>]
          controls the level of memory layout transformations performed by the
          compiler
           0 - disable memory layout transformations (same as
               /Qopt-mem-layout-trans-)
           1 - enable basic memory layout transformations
           2 - enable more memory layout transformations  (DEFAULT when the
           3 - enable aggressive memory layout transformations
/Qopt-prefetch[:n]
          enable levels of prefetch insertion, where 0 disables.
          n may be 0 through 5 inclusive.  Default is 2.
/Qopt-prefetch-
          disable(DEFAULT) prefetch insertion.  Equivalent to /Qopt-prefetch:0
/Qopt-prefetch-distance:n1[,n2]
          specify the prefetch distance (how many iterations ahead, use n1 and
          n2 values such that n1>=n2) to be used for compiler generated
          prefetches inside loops.  n1 indicates distance from memory to L2
          cache and n2 indicates distance from L2 to L1.
/Qopt-prefetch-issue-excl-hint
          generates PrefetchW instruction for Intel(R) microarchitecture
          code name Broadwell processors and beyond when /Qopt-prefetch
          is also used
/Qopt-gather-scatter-unroll:n
          specify an alternative loop unroll sequence for gather and scatter
          loops (Intel(R) MIC Architecture specific).  Disable with
          /Qopt-gather-scatter-unroll- (equivalent to n=0)
/Qopt-dynamic-align
          enable(DEFAULT) dynamic data alignment optimizations.  Specify
          /Qopt-dynamic-align- to disable
/Qalign-loops[:n]
          specify code alignment of loops to improve performance.
          n is the number of bytes for the minimum alignment boundary.  It must
          be a power of 2 between 1 and 4096.  If n is not present, an
          alignment of 16 bytes is used.
          Use of /Qalign-loops- (DEFAULT) sets alignment to 1.
/Qopt-zmm-usage:<keyword>
          Specifies the level of zmm registers usage.  You can specify one of
          the following:
            low  - Tells the compiler that the compiled program is unlikely to
                   benefit from zmm registers usage. It specifies that the
                   compiler should avoid using zmm registers unless it can
                   prove the gain from their usage.
            high - Tells the compiler to generate zmm code without restrictions
/Qoverride-limits
          provides a way to override certain internal compiler limits that are
          intended to prevent excessive memory usage or compile times for very
          large, complex compilation units.
/Qprof-dir <dir>
          specify directory for profiling output files (*.dyn and *.dpi)
/Qprof-src-root <dir>
          specify project root directory for application source files to
          enable relative path resolution during profile feedback on sources
          below that directory
/Qprof-src-root-cwd
          specify the current directory as the project root directory for
          application source files to enable relative path resolution during
          profile feedback on sources below that directory
/Qprof-src-dir[-]
          specify whether directory names of sources should be
          considered when looking up profile records within the .dpi file
/Qprof-file <file>
          specify file name for profiling summary file
/Qprof-data-order[-]
          enable/disable(DEFAULT) static data ordering with profiling
/Qprof-func-order[-]
          enable/disable(DEFAULT) function ordering with profiling
/Qprof-gen[:keyword[,keyword]]
          instrument program for profiling.  Optional keywords are as follows.
            default    - Produces an instrumented object file. This is the same
                         as specifying the /Qprof-gen option with no keyword.
            srcpos     - Produces an instrumented object file and information
                         needed for using the code coverage tool.
            globdata   - Produces an instrumented object file that includes
                         information for global data layout.
            threadsafe - Collects PGO data with guards for threaded
                         applications.
/Qprof-gen-
          disable profiling instrumentation
/Qprof-use[:<arg>]
          enable use of profiling information during optimization
            weighted  - invokes profmerge with -weighted option to scale data
                        based on run durations
            [no]merge - enable(default)/disable the invocation of the profmerge
                        tool
/Qprof-use-
          disable use of profiling information during optimization
/Qcov-gen
          instrument program for profiling.  Use /Qcov-gen- to disable
/Qcov-dir <dir>
/Qcov-file <file>
/Qfnsplit[:<n>]
          enable function splitting (enabled with /Qprof-use for IA-32 Windows)
            n - positive integer indicating the threshold number.  The blocks
                can be placed into a different code segment if their
                execution probability is less than the specified value of
                range 0 <= n <= 100
          use /Qfnsplit- to disable
/Qinstrument-functions[-]
          determine whether function entry and exit points are instrumented
/Qprof-hotness-threshold:<val>
          set the hotness threshold for function grouping and function ordering
          val indicates percentage of functions to be placed in hot region.
          This option requires /Qprof-use
           and /Qprof-func-order
/Qprof-value-profiling:<arg>[,<arg>,...]
          limit value profiling
            none      - inhibit all types of value profiling
            nodivide  - inhibit value profiling of non-compile time constants
                        used in division or remainder operations
            noindcall - inhibit value profiling of function addresses at
                        indirect call sites
/Qprofile-functions
          enable instrumentation in generated code for collecting
          function execution time profiles
/Qprofile-loops:<arg>
          loop execution time profiles
             inner    - instrument inner loops
             outer    - instrument outer loops
             all      - instrument all loops
/Qprofile-loops-report:<arg>
          Control the level of instrumentation inserted for reporting loop
          execution profiles
             1    - report loop times
             2    - report loop times and iteration counts
/Qopt-report[:n]
          generate an optimization report. Default destination is
          <target>.optrpt.  Levels of 0 - 5 are valid.
          Please see documentation for additional details of
          information provided by phase per level.
            0   disable optimization report output
            2   DEFAULT when enabled
/Qopt-report-file:[stdout | stderr | <file>]
          specify the filename or output stream for the generated report
/Qopt-report-stdout
          specify the generated report should be directed to stdout
/Qopt-report-per-object
          specify the generated report should be directed to a .optrpt file
          in the output directory (DEFAULT when another destination for the
          report is not specified)
/Qopt-report-phase:<phase>[,<phase>,...]
          specify one or more phases that reports are generated against
/Qopt-report-routine:<name>[,<name>,...]
          restrict the report to routines containing the given name
/Qopt-report-filter:<string>
          restricts the opt-report to specific files, routines or line
          number ranges. Refer to the documentation for the specific
          syntax of parameter string.
/Qopt-report-format:[text|vs]
          specify the output format to be used for the opt-report as either
          plain text or a format for use in the Microsoft* Visual Studio IDE
/Qopt-report-embed[-]
          When enabled, if an assembly file is being generated, special loop
          info annotations will be emitted in the assembly file.  If an object
          file/executable is being generated, these will be emitted into the
          object file/executable for use by the Intel VTune Amplifier
          application. Automatically enabled when symbolic debug information
          is enabled.
/Qopt-report-help
          display the optimization phases available for reporting
/Qopt-report-names:<keyword>
          Specifies whether mangled or unmangled names should appear in the
            mangled   - use mangled names
            unmangled - use unmangled names (DEFAULT)
/Qopt-report-annotate[:<keyword>]
          Annotate source files with optimization reports in specified format
            html - annotate in HTML format
            text - annotate in text format (DEFAULT)
/Qopt-report-annotate-position:<keyword>
          Specify the site where loop related optimization reports appear in
          the annotated source for inlined routines
            caller - annotate at caller site
            callee - annotate at callee site
            both   - annotate at both caller and callee site
/Qtcheck[:mode]
          enable analysis of threaded applications (requires Intel(R) Thread
          Checker; cannot be used with compiler alone)
            tci - instruments a program to perform a thread-count-independent
                  analysis
            tcd - instruments a program to perform a thread-count-dependent
                  analysis (DEFAULT when mode is not used)
            api - instruments a program at the api-imports level
/Qtcollect[:<lib>]
          inserts instrumentation probes calling the Intel(R) Trace Collector
          API.  The library <lib>.lib is linked in the default being VT.lib
          (requires Intel(R) Trace Collector)
/Qtcollect-filter:file
          Enable or disable the instrumentation of specified functions.
OpenMP* and Parallel Processing
/Qopenmp  enable the compiler to generate multi-threaded code based on the
          OpenMP* directives (same as /openmp)
          Use /Qopenmp- to disable
/Qopenmp-stubs
          enables the user to compile OpenMP programs in sequential mode.  The
          OpenMP directives are ignored and a stub OpenMP library is linked
          (sequential)
/Qopenmp-lib:<ver>
          choose which OpenMP library version to link with
            compat - use the Microsoft compatible OpenMP run-time libraries
                     (DEFAULT)
/Qopenmp-threadprivate:<ver>
          choose which threadprivate implementation to use
            compat - use the Microsoft compatible thread local storage
            legacy - use the Intel compatible implementation
                     (DEFAULT)
/Qparallel
          enable the auto-parallelizer to generate multi-threaded code for
          loops that can be safely executed in parallel
/Qpar-threshold[n]
          set threshold for the auto-parallelization of loops where n is an
          integer from 0 to 100
/Qpar-runtime-control[n]
          Control parallelizer to generate runtime check code for effective
          automatic parallelization.
            n=0    no runtime check based auto-parallelization
            n=1    generate runtime check code under conservative mode
                   (DEFAULT when enabled)
            n=2    generate runtime check code under heuristic mode
            n=3    generate runtime check code under aggressive mode
/Qpar-schedule-static[:n]
          Specifies a scheduling algorithm for DO loop iteration.
          Divides iterations into contiguous pieces.  Size n if
          specified, equal sized pieces if not.
/Qpar-schedule-static-balanced[:n]
          Divides iterations into even-sized chunks.  Size n if
/Qpar-schedule-static-steal[:n]
          Divides iterations into even-sized chunks, but allows
          threads to steal parts of chunks from neighboring threads
/Qpar-schedule-dynamic[:n]
          Assigns iterations to threads in chunks dynamically.
          Chunk size is n iterations if specified, otherwise 1.
/Qpar-schedule-guided[:n]
          Indicates a minimum number of iterations.  If specified,
          n is the minimum number, otherwise 1.
/Qpar-schedule-guided-analytical[:n]
          Divides iterations by using exponential distribution or
          dynamic distributions.
/Qpar-schedule-runtime
          Defers the scheduling decision until runtime.
/Qpar-schedule-auto
          Lets the compiler or run-time system determine the
          scheduling algorithm.
/Qpar-adjust-stack<n>
          perform fiber-based main thread stack adjustment
/Qpar-affinity=[<modifier>,...]<type>[,<permute>][,<offset>]
          tune application performance by setting different thread affinity
/Qpar-num-threads=<n>
          tune application performance by setting different number of threads
/Qparallel-source-info[:n]
          enable(DEFAULT)/disable the emission of source location information
          for parallel code generation with OpenMP and auto-parallelization
            0 - disable (same as /Qparallel-source-info-)
            1 - emit routine name and line information (DEFAULT)
            2 - emit path, file, routine name and line information
/Qpar     same as /Qparallel
/Qopenmp-simd
          Enables OpenMP* SIMD compilation.  Enabled by default with
          /Qopenmp.  Use /Qopenmp-simd- to disable.
/Qopenmp-offload[:<kind>]
          Enables OpenMP* offloading compilation for TARGET directives.
          Enabled for Intel(R) MIC Architecture by default with /Qopenmp.
          Use /Qopenmp-offload- to disable.
          Specify kind to specify the default device for TARGET directives.
            host - allow target code to run on host system while still doing
                   the outlining for offload
            mic  - specify Intel(R) MIC Architecture (DEFAULT)
Floating Point
/fp:<name>
          enable <name> floating point model variation
            except[-] - enable/disable floating point exception semantics
            fast[=1|2]  - enables more aggressive floating point optimizations
            precise     - allows value-safe optimizations
            source      - enables intermediates in source precision
                          sets /assume:protect_parens for Fortran
            strict      - enables /fp:precise /fp:except, disables
                          contractions and enables pragma stdc fenv_access
            consistent  - enables consistent, reproducible results for
                          different optimization levels or between different
                          processors of the same architecture
/Qfp-speculation:<mode>
          enable floating point speculations with the following <mode>
          conditions:
            fast   - speculate floating point operations (DEFAULT)
            safe   - speculate only when safe
            strict - same as off
            off    - disables speculation of floating-point operations
/Qpc32    set internal FPU precision to 24 bit significand
/Qprec    improve floating-point precision
/Qprec-sqrt[-]
          determine if certain square root optimizations are enabled
/Qprec-div[-]
          improve precision of FP divides (some speed impact)
/Qfast-transcendentals[-]
          generate a faster version of the transcendental functions
/Qfp-port[-]
          round fp results at assignments and casts (some speed impact)
/Qfp-stack-check
          enable fp stack checking after every function/procedure call
/Qrcd     rounding mode to enable fast float-to-int conversions
/rounding-mode:chopped
          set internal FPU rounding control to truncate
/Qftz[-]  enable/disable flush denormal results to zero
/fpe:{0|1|3}
          specifies program-wide behavior on floating point exceptions
/fpe-all:{0|1|3}
          specifies floating point exception behavior on all functions
          and subroutines.  Also sets /assume:ieee_fpe_flags
/[no]fltconsistency
          specify that improved floating-point consistency should be used
/Qfma[-]  enable/disable the combining of floating point multiplies and
          add/subtract operations
/[no]recursive
          compile all procedures for possible recursive execution
/Qimf-absolute-error:value[:funclist]
          define the maximum allowable absolute error for math library
          function results
            value    - a positive, floating-point number conforming to the
                       format [digits][.digits][{e|E}[sign]digits]
            funclist - optional comma separated list of one or more math
                       library functions to which the attribute should be
                       applied
/Qimf-accuracy-bits:bits[:funclist]
          define the relative error, measured by the number of correct bits,
          for math library function results
            bits     - a positive, floating-point number
                       applied
/Qimf-arch-consistency:value[:funclist]
          ensures that the math library functions produce consistent results
          across different implementations of the same architecture
            value    - true or false
                       applied
/Qimf-max-error:ulps[:funclist]
          defines the maximum allowable relative error, measured in ulps, for
            ulps     - a positive, floating-point number conforming to the
                       applied
/Qimf-precision:value[:funclist]
          defines the accuracy (precision) for math library functions
            value    - defined as one of the following values
                       high   - equivalent to max-error = 0.6
                       medium - equivalent to max-error = 4 (DEFAULT)
                       low    - equivalent to accuracy-bits = 11 (single
                                precision); accuracy-bits = 26 (double
                                precision)
                       applied
/Qimf-domain-exclusion:classlist[:funclist]
          indicates the input arguments domain on which math functions
          must provide correct results.
            classlist - defined as one of the following values:
                          nans, infinities, denormals, zeros
                          all, none, common
            funclist - optional list of one or more math library functions to
                       which the attribute should be applied.
/Qimf-force-dynamic-target[:funclist]
          Instructs the compiler to use run-time dispatch in calls to math
          functions
/Qfinite-math-only
          Allow optimizations for floating point arithmetic that assume
          arguments and results are not NaNs or Infinities
Inlining
/Ob<n>    control inline expansion:
            n=0  disable inlining (same as /inline:none)
            n=1  inline functions declared with ATTRIBUTES INLINE or
                   FORCEINLINE
            n=2  inline any function, at the compiler's discretion
/Qinline-min-size:<n>
          set size limit for inlining small routines
/Qinline-min-size-
          no size limit for inlining small routines
/Qinline-max-size:<n>
          set size limit for inlining large routines
/Qinline-max-size-
          no size limit for inlining large routines
/Qinline-max-total-size:<n>
          maximum increase in size for inline function expansion
/Qinline-max-total-size-
          no size limit for inline function expansion
/Qinline-max-per-routine:<n>
          maximum number of inline instances in any function
/Qinline-max-per-routine-
          no maximum number of inline instances in any function
/Qinline-max-per-compile:<n>
          maximum number of inline instances in the current compilation
/Qinline-max-per-compile-
          no maximum number of inline instances in the current compilation
/Qinline-factor:<n>
          set inlining upper limits by n percentage
/Qinline-factor-
          do not set set inlining upper limits
/Qinline-forceinline
          treat inline routines as forceinline
/Qinline-dllimport
          allow(DEFAULT)/disallow functions declared DEC$ ATTRIBUTES DLLIMPORT
          to be inlined
/Qinline-calloc
          directs the compiler to inline calloc() calls as malloc()/memset()
/inline[:keyword]
          Specifies the level of inline function expansion
            keywords: all (same as /Ob2 /Ot), size (same as /Ob2 /Os)
                      speed (same as /Ob2 /Ot), none or manual (same as /Ob0)
/Qinline-min-caller-growth:<n>
          set lower limit on caller growth due to inlining a single routine
/Qinline-min-caller-growth-
          no lower limit on caller growth due to inlining a single routine
Output, Debug, PCH
/c        compile to object (.obj) only, do not link
/nolink, /compile-only
          same as /c
/S        compile to assembly (.asm) only, do not link
/FAs      produce assembly file with optional source annotations
/FAc      produce assembly file with optional code annotations
/FA       produce assembly file
/Fa[file]
          name assembly file (or directory for multiple files; i.e. /FaMYDIR\)
/Fo[file]
          name object file (or directory for multiple files; i.e. /FoMYDIR\)
/Fe[file]
          name executable file or directory
/Fi[file]
          name preprocessed file (or directory for multiple files; i.e.
          /FiMYDIR\)
/object:<filename>
          specify the name of the object file, or the directory to which object
          file(s) should be written.  (e.g. /object:MYOBJ or /object:MYDIR\)
/exe:<filename>
          specifies the name to be used for the built program (.exe) or
          dynamic-link (.dll) library
/map:<filename>
          specify that a link map file should be generated
/list[:<filename>]
          specify that a listing file should be generated
/list-line-len:#
          overrides the default line length (80) in a listing file
/list-page-len:#
          overrides the default page length (66) in a listing file
/show:<keyword>
          controls the contents of the listing file
          keywords: all, none, [no]include, [no]map, [no]options
/Zi, /ZI, /Z7
          Produce symbolic debug information.  The /Zi and /ZI flags emit the
          debug information for types into a separate PDB file.
/Zo[-]    When symbolic debug information is being produced, enable/disable
          emission of additional symbolic debug information to describe
          optimized code.
/debug[:keyword]
          Control the emission of debug information.
          Valid [keyword] values:
             none
                 Disables debug generation.
             all, full (default if no keyword was specified)
                 Generates complete debug information.
             minimal
                 Generates line number information.
             [no]inline-debug-info
                 Controls additional debug information for inlined code.
/nodebug  Disable emission of debug information.
/debug-parameters[:keyword]
          Control output of debug information for PARAMETERS.
             none - Disables generation of debug information for PARAMETERs.
             used - Generates debug information for referenced PARAMETERs only.
             all  - Generates debug information for all PARAMETERs.
/nodebug-parameters
          Same as "/debug-parameters:none".
/Qd-lines, /[no]d-lines
          compile debug statements (indicated by D in column 1)
/pdbfile[:filename]
          Specify that debug related type information should be generated to a
          program database file at link time.
/nopdbfile
          Do not generate debug related information to a program database file.
/Qtrapuv  trap uninitialized variables
/RTCu     report use of variable that was not initialized
/Qmap-opts
          enable option mapping tool
/Qeliminate-unused-debug-types[-]
          When disabled, debug information for all types present in the
          sources will be emitted.  Using this option may cause a large
          increase in the size of the debug information.
/Qemit-build-options
          Output the options used during the compilation to a corresponding
          .dashboard file.  This file is to be consumed by the dbmerge tool
          and used by the dashboard tool.
/Qemit-messages
          Output the diagnostics emitted during the compilation to a
          corresponding .dashboard file.  This file is to be consumed by the
          dbmerge tool and used by the dashboard tool.
Preprocessor
/D<name>[{=|#}<text>]
          define macro
/define:symbol[=<value>]
          same as /D
/nodefines
          specifies that any /D macros go to the preprocessor only, and not to
          the compiler
/U<name>  remove predefined macro
/undefine:<name>
          remove predefined macro (same as /U)
/allow:nofpp-comments
          If a Fortran end-of-line comment is seen within a #define, treat it
          as part of the definition.  Default is allow:fpp-comments
/E        preprocess to stdout
/EP       preprocess to stdout, omitting #line directives
/EP /P    preprocess to file, omitting #line directives
/preprocess-only
          same as /P
/[no]keep  keep/remove preprocessed file generated by preprocessor as input to
           compiler stage.  Not affected by /Qsave-temps.  Default is /nokeep
/[no]fpp   run Fortran preprocessor on source files prior to compilation
/fpp-name:name
           Name an alternate preprocessor executable.  The name can
           include the full path.
/module:path
           specify path where mod files should be placed and first location to
           look for mod files
/u        remove all predefined macros
/I<dir>   add directory to include file search path
/[no]include:<dir>
          same as /I
/X        remove standard directories from include file search path
/gen-dep[:filename]
          generate dependency information.
          If no filename is specified, output is to stdout.
           Similar to /QMD or /QMMD
          If a filename is specified, output is to filename.
           Similar to /QMF filename
/gen-dep-
          do not generate dependency information (default)
/gen-depshow:keyword
          control what dependency information is output.
          [no]intr_mod   Intrinsic modules.  Default is nointr_mod.
/gen-depformat:keyword
          generate dependency information in the specified format.
          One of:  make, nmake
Component Control
/Qoption,<tool>,<opts>
          pass options <opts> to tool specified by <tool>
/Qlocation,<tool>,<dir>
          set <dir> as the location of tool specified by <tool>
Language
/[no]altparam
          specify if alternate form of parameter constant declarations
          (without parenthesis) is recognized. Default is to recognize
/assume:<keyword>
          specify assumptions made by the optimizer and code generator
          keywords: none, [no]byterecl, [no]buffered_io,
                    [no]buffered_stdout,
                    [no]bscc (nobscc same as /nbs),
                    [no]contiguous_pointer, [no]contiguous_assumed_shape,
                    [no]cc_omp, [no]minus0,
                    [no]dummy_aliases (same as /Qcommon-args),
                    [no]ieee_fpe_flags, [no]fpe_summary,
                    [no]old_boz, [no]old_complex_align,
                    [no]old_logical_ldio, [no]old_logical_assign,
                    [no]old_ldout_format, [no]old_maxminloc,
                    [no]old_unit_star, [no]old_xor,
                    [no]protect_allocates,
                    [no]protect_constants, [no]protect_parens,
                    [no]realloc_lhs, [no]2underscore,
                    [no]underscore (same as /us),
                    [no]std_intent_in, [no]std_minus0_rounding,
                    [no]std_mod_proc_name, [no]std_value,
                    [no]source_include,
                    [no]split_common, [no]writeable_strings
/ccdefault:<keyword>
          specify default carriage control for units 6 and *
          keywords:  default, fortran, list or none
/[no]check:<keyword>
          check run-time conditions.  Default is /nocheck
          keywords: all (same as /4Yb, /C), none (same as /nocheck, /4Nb),
                    [no]arg_temp_created, [no]bounds (same as /CB),
                    [no]contiguous,
                    [no]format, [no]output_conversion,
                    [no]pointers (same as /CA), [no]assume,
                    [no]uninit (same as /CU), [no]stack
/Qcommon-args
          assume "by reference" subprogram arguments may alias one
          another.  Same as /assume:dummy_aliases
/[no]extend-source[:<keyword>]
          specify rightmost column for fixed form sources
          keywords: 72 (same as /noextend-source and /4L72),
                    80 (same as /4L80),
                   132 (same as /4L132.  Default if you specify
                        /extend-source without a keyword.)
/fixed    specify source files are in fixed format. Same as /FI and /4Nf
          /nofixed indicates free format
/free     specify source files are in free format. Same as /FR and /4Yf
          /nofree indicates fixed format
/names:<keyword>
          specify how source code identifiers and external names are
          interpreted.
          keywords:  as_is, lowercase, uppercase
/[no]pad-source, /Qpad-source[-]
          make compiler acknowledge blanks at the end of a line
/stand[:<keyword>]
          specifies level of conformance with ANSI standard to check
          for.  If keyword is not specified, level of conformance is f08
          keywords: f90 (same as /4Ys), f95,
                    f03, f08, f15,
                    none (same as /nostand)
/standard-semantics
          explicitly sets assume keywords to conform to the semantics
          of the Fortran standard.  May result in performance loss.
          assume keywords set by /standard-semantics:
            byterecl, fpe_summary, minus0, noold_ldout_format,
            noold_maxminloc, noold_unit_star, noold_xor, protect_parens,
            realloc_lhs, std_intent_in, std_minus0_rounding,
            std_mod_proc_name, std_value
          also sets /fpscomp:logicals
          If /fp:strict or /fp:except is set
            then this also sets assume keyword ieee_fpe_flags
/[no]standard-realloc-lhs
          explicitly sets assume keyword realloc_lhs to conform to the
          standard, or to override the default. Sets /assume:[no]realloc_lhs
/syntax-only, /Zs
          perform syntax and semantic checking only (no object file produced)
/wrap-margin[-]
          controls right margin wrapping in list-directed output. By default,
          list-directed output is wrapped at 80 characters.
/w        disable all warnings
/W<n>     disable warnings (n = 0) or show warnings (n = 1 DEFAULT, same as
          /warn:general)
/warn:<keyword>
          specifies the level of warning messages issued
            keywords: all, none (same as /nowarn)
                      [no]alignments, [no]declarations, [no]errors,
                      [no]general, [no]ignore_loc, [no]interfaces,
                      [no]stderrors, [no]truncated_source, [no]uncalled,
                      [no]unused, [no]usage
/nowarn   suppress all warning messages
/WB       turn a compile-time bounds check into a warning
/[no]traceback
          specify whether the compiler generates PC correlation data used to
          display a symbolic traceback rather than a hexadecimal traceback at
          runtime failure
/[no]gen-interfaces [[no]source]
          generate interface blocks for all routines in the file.  Can be
          checked using -warn interfaces
          nosource indicates temporary source files should not be saved
/error-limit:<size>
          specify the maximum number of error-level or fatal-level compiler
          errors allowed
/noerror-limit
          set no maximum number on error-level or fatal-level error messages
/Qdiag-enable:<v1>[,<v2>,...]
          enable the specified diagnostics or diagnostic groups
/Qdiag-disable:<v1>[,<v2>,...]
          disable the specified diagnostics or diagnostic groups
          where <vN> may be individual diagnostic numbers or group names.
          where group names include:
              openmp     - diagnostics issued by the OpenMP* parallelizer
              warn       - diagnostics that have "warning" severity level
              error      - diagnostics that have "error" severity level
              remark     - diagnostics that are remarks or comments
              vec        - diagnostics issued by the vectorizer
              par        - diagnostics issued by the auto-parallelizer
              cpu-dispatch
                         - specifies the CPU dispatch remarks
/Qdiag-error:<v1>[,<v2>,...]
          output the specified diagnostics or diagnostic groups as errors
/Qdiag-warning:<v1>[,<v2>,...]
          output the specified diagnostics or diagnostic groups as warnings
/Qdiag-remark:<v1>[,<v2>,...]
          output the the specified diagnostics or diagnostic groups as remarks
/Qdiag-dump
          display the currently enabled diagnostic messages to stdout or to a
          specified diagnostic output file.
/Qdiag-file[:<file>]
          <file> where diagnostics are emitted to.  Not specifying this causes
          messages to be output to stderr
/Qdiag-file-append[:<file>]
          <file> where diagnostics are emitted to. When <file> already exists,
          output is appended to the file
/Qdiag-id-numbers[-]
          enable(DEFAULT)/disable the diagnostic specifiers to be output in
          numeric form
/Qdiag-error-limit:<num>
          specify the maximum number of errors emitted
Miscellaneous
/[no]logo
          display compiler version information.  /nologo disables the output
/bintext:<string>
          place the string specified into the object file and executable
/Qsave-temps
          store the intermediate files in current directory and name them
          based on the source file.  Only saves files that are generated by
          default
/what     display detailed compiler version information
/watch:<keyword>
          tells the driver to output processing information
            keywords: all, none (same as /nowatch), [no]source,
                      [no]cmd
                      [no]mic-cmd
/nowatch  suppress processing information output (DEFAULT)
/Tf<file>
          compile file as Fortran source
/extfor:<ext>
           specify extension of file to be recognized as a Fortran file
/extfpp:<ext>
           specify extension of file to be recognized as a preprocessor file
/libdir[:keyword]
          control the library names that should be emitted into the object file
            keywords:  all, none (same as /nolibdir), [no]automatic, [no]user
/nolibdir
          no library names should be emitted into the object file
/MP[<n>]  create multiple processes that can be used to compile large numbers
          of source files at the same time
/bigobj   generate objects with increased address capacity
/Qoffload:<arg>
          define whether offload is enabled, and if enabled, whether CPU
          fallback is permitted
            keywords:  none, optional, mandatory
/Qoffload-attribute-target:<name>
          flags every global routine and global data object in the source
          file with the offload attribute target(<name>)
            name - mic, gfx (gfx for C/C++ compilation only)
/Qoffload-option,<target>,<tool>,"option list"
          appends additional options for offload compilations given the
          target and tool.  The option list is a space separated quoted list
          of options
            target - mic, gfx (gfx for C/C++ compilation only)
            tool   - compiler, link, asm, jit (gfx only)
/Qoffload-
          disable any offload usage
/Qoffload-arch:<arch>[:<visa>]
          specify the target architecture to use when offloading code
            arch - Specifies the target architecture. On Intel(R) 64
                   architecture targeting Intel(R) MIC Architecture, arch can
                   be mic-avx512. On IA-32 and Intel(R) 64 architectures
                   targeting Intel(R) Graphics Technology, arch can be
                   haswell, broadwell, cherryview, skylake, or broxton.
            visa - Specifies the virtual ISA (vISA) version to be used. This
                   optional argument is only allowed on IA-32 and Intel(R) 64
                   architectures targeting Intel(R) Graphics Technology. You
                   can specify either visa3.1 or visa3.2.
Data
/4I{2|4|8}
          set default KIND of integer and logical variables to 2, 4, or 8
/integer-size:<size>
          specifies the default size of integer and logical variables
            size:  16, 32, 64
/4R{8|16}
          set default size of real to 8 or 16 bytes
/real-size:<size>
          specify the size of REAL and COMPLEX declarations, constants,
          functions, and intrinsics
            size: 32, 64, 128
/Qautodouble
          same as /real-size:64 or /4R8
/double-size:<size>
          defines the size of DOUBLE PRECISION and DOUBLE COMPLEX declarations,
          constants, functions, and intrinsics
/[no]fpconstant
          extends the precision of single precision constants assigned to
          double precision variables to double precision
/[no]intconstant
          use Fortran 77 semantics, rather than Fortran 90/95, to determine
          kind of integer constants
/auto     make all local variables AUTOMATIC
/Qauto-scalar
          make scalar local variables AUTOMATIC (DEFAULT)
/Qsave    save all variables (static allocation) (same as /noauto,
          opposite of /auto)
/Qzero[-]
          enable/disable(DEFAULT) implicit initialization to zero of local
          scalar variables of intrinsic type INTEGER, REAL, COMPLEX, or
          LOGICAL that are saved and not initialized
/Qinit:<keyword>
          enable/disable(DEFAULT) implicit initialization of local
          The <keyword> specifies the initial value
            keywords: zero (same as /Qzero),
                      snan (valid only for floating point variables),
                      infinity, minus_infinity (valid only for floating point)
                      tiny, minus_tiny (valid only for floating point)
                      huge, minus_huge
                      arrays
/Qdyncom<common1,common2,...>
          make given common blocks dynamically-allocated
/Zp[n]    specify alignment constraint for structures (n=1,2,4,8,16
          /Zp16 DEFAULT)
/[no]align
          analyze and reorder memory layout for variables and arrays
/align:<keyword>
          specify how data items are aligned
            keywords: all (same as /align), none (same as /noalign),
                      [no]commons, [no]dcommons,
                      [no]qcommons, [no]zcommons,
                      rec1byte, rec2byte, rec4byte,
                      rec8byte, rec16byte, rec32byte,
                      array8byte, array16byte, array32byte,
                      array64byte, array128byte, array256byte,
                      [no]records, [no]sequence
/GS       enable overflow security checks.  Optional <arg> can specify:
            partial - provide a stack protection level that is compatible with
                      Microsoft* Visual Studio 2008.
            strong  - provide full stack security level checking. This setting
                      is compatible with recent Microsoft* Visual Studio stack
                      protection heuristics. This is the same as specifying /GS
                      with no keyword.
            off     - Same as /GS- (DEFAULT)
/Qpatchable-addresses
           generate code such that references to statically assigned addresses
           can be patched with arbitrary 64-bit addresses.
/Qglobal-hoist[-]
          enable(DEFAULT)/disable external globals are load safe
/Qkeep-static-consts[-]
          enable/disable(DEFAULT) the ability to preserve allocation of
          variables that are not referenced in the source
/Qnobss-init
          disable placement of zero-initialized variables in BSS (use DATA)
/Qzero-initialized-in-bss[-]
          put explicitly zero initialized variables into the DATA section
          instead of the BSS section
/convert:<keyword>
          specify the format of unformatted files containing numeric data
            keywords: big_endian, cray, ibm, little_endian, native, vaxd, vaxg
/Qfnalign:<n>
          align the start of functions on a 2 (DEFAULT) or <n> byte boundary
          where <n> is a power of 2
/Qfnalign
          align the start of functions to an optimal machine-dependent value.
          /Qfnalign- (DEFAULT) aligns on a 2-byte boundary
Compatibility
/fpscomp[:<keyword>]
          specify the level of compatibility to adhere to with Fortran
          PowerStation
            keywords: all, none (same as /nofpscomp), [no]filesfromcmd,
                      [no]general, [no]ioformat, [no]ldio_spacing,
                      [no]libs, [no]logicals
/nofpscomp
          no specific level of compatibility with Fortran PowerStation
/f66      allow extensions that enhance FORTRAN-66 compatibility
/f77rtl   specify that the Fortran 77 specific run-time support should be used
          /nof77rtl disables
/vms      enable VMS I/O statement extensions
/Qvc<arg>
          enable compatibility with a specific Microsoft* Visual Studio version
            12   - Microsoft* Visual Studio 2013 compatibility
            14   - Microsoft* Visual Studio 2015 compatibility
            14.1 - Microsoft* Visual Studio 2017 compatibility
Linking/Linker
/link     specify that all options following '/link' are for the linker
/extlnk:<ext>
          specify extension of file to be passed directly to linker
/F<n>     set the stack reserve amount specified to the linker
/dbglibs  use the debug version of runtime libraries, when appropriate
/libs:<keyword>
          specifies which type of run-time library to link to.
          keywords: static, dll, qwin, qwins
/LD[d]    produce a DLL instead of an EXE ('d' = debug version)
/dll      same as /LD
/MD[d]    use dynamically-loaded, multithread C runtime
/MDs[d]   use dynamically-loaded, singlethread Fortran runtime,
          and multithread C runtime
/MT[d]    use statically-linked, multithread C runtime (DEFAULT with
          Microsoft Visual Studio 2005 and later)
/MG, /winapp
          use Windows API runtime libraries
/Zl       omit library names from object file
/threads  specify that multi-threaded libraries should be linked against
          /nothreads disables multi-threaded libraries
Deprecated Options
/Quse-asm                No replacement
/Qvc11                   No replacement
/Qcilk-serialize         No replacement
/Qopenmp-task=<arg>      use OpenMP* tasking scheme
/arch:SSE                use /arch:IA32
/arch:ICELAKE            use /arch:ICELAKE-CLIENT
/QxSSE3_ATOM             use /QxATOM_SSSE3
/QxSSSE3_ATOM            use /QxATOM_SSSE3
/QxICELAKE               use /QxICELAKE-CLIENT
/QaxICELAKE              use /QaxICELAKE-CLIENT
/debug:partial           No replacement
/architecture:<code>     use /arch:<code>
/Fm                      use /map
/help, /? [category]   print full or category help message
Valid categories include
       advanced        - Advanced Optimizations
       codegen         - Code Generation
       compatibility   - Compatibility
       component       - Component Control
       data            - Data
       deprecated      - Deprecated Options
       diagnostics     - Compiler Diagnostics
       float           - Floating Point
       help            - Help
       inline          - Inlining
       ipo             - Interprocedural Optimization (IPO)
       language        - Language
       link            - Linking/Linker
       misc            - Miscellaneous
       opt             - Optimization
       output          - Output
       pgo             - Profile Guided Optimization (PGO)
       preproc         - Preprocessor
       reports         - Optimization Reports
       openmp          - OpenMP and Parallel Processing
Copyright (C) 1985-2018, Intel Corporation.  All rights reserved.
* Other names and brands may be claimed as the property of others.
            Trying FC compiler flag -PIC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -PIC   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/PIC'
Successful compile:
Source:
      program main
      end
                Rejecting compiler flag -PIC  due to
            Rejected FC compiler flag -PIC because shared linker cannot handle it
            Trying FC compiler flag -fPIC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -fPIC   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/fPIC'
Successful compile:
Source:
      program main
      end
                Rejecting compiler flag -fPIC  due to
            Rejected FC compiler flag -fPIC because shared linker cannot handle it
            Trying FC compiler flag -KPIC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -KPIC   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/KPIC'
Successful compile:
Source:
      program main
      end
                Rejecting compiler flag -KPIC  due to
            Rejected FC compiler flag -KPIC because shared linker cannot handle it
            Trying FC compiler flag -qpic
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -qpic   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/qpic'
Successful compile:
Source:
      program main
      end
                Rejecting compiler flag -qpic  due to
            Rejected FC compiler flag -qpic because shared linker cannot handle it
              Popping language FC
TEST checkSharedLinkerPaths from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1413)
TESTING: checkSharedLinkerPaths from config.setCompilers(config/BuildSystem/config/setCompilers.py:1413)
  Determine the shared linker path options
       - IRIX: -rpath
       - Linux, OSF: -Wl,-rpath,
       - Solaris: -R
       - FreeBSD: -Wl,-R,
              Pushing language C
Executing: uname -s
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -V
stdout: icl: command line error: no files specified; for help type "icl /help"
            Trying C linker flag -Wl,-rpath,
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -Wl,-rpath,/home/alireza/petsc-3.9.3  -O2 -MT -wd4996 -Qopenmp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: icl: command line warning #10157: ignoring option '/W'; argument is of wrong type
              Rejecting C linker flag -Wl,-rpath,/home/alireza/petsc-3.9.3 due to
            Rejected C linker flag -Wl,-rpath,
            Trying C linker flag -R
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -R/home/alireza/petsc-3.9.3  -O2 -MT -wd4996 -Qopenmp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: icl: command line warning #10006: ignoring unknown option '/R/home/alireza/petsc-3.9.3'
              Rejecting C linker flag -R/home/alireza/petsc-3.9.3 due to
            Rejected C linker flag -R
            Trying C linker flag -rpath
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -rpath /home/alireza/petsc-3.9.3  -O2 -MT -wd4996 -Qopenmp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout:
icl: command line warning #10006: ignoring unknown option '/rpath'
icl: command line warning #10161: unrecognized source type 'E:\cygwin64\home\alireza\petsc-3.9.3'; object file assumed
ipo: error #11018: Cannot open E:\cygwin64\home\alireza\petsc-3.9.3
LINK : fatal error LNK1104: cannot open file 'E:\cygwin64\home\alireza\petsc-3.9.3'
Possible ERROR while running linker: exit code 20480
stdout:
LINK : fatal error LNK1104: cannot open file 'E:\cygwin64\home\alireza\petsc-3.9.3'              Rejecting linker flag -rpath /home/alireza/petsc-3.9.3 due to nonzero status from link
              Rejecting C linker flag -rpath /home/alireza/petsc-3.9.3 due to
            Rejected C linker flag -rpath
            Trying C linker flag -Wl,-R,
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -Wl,-R,/home/alireza/petsc-3.9.3  -O2 -MT -wd4996 -Qopenmp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
              Rejecting C linker flag -Wl,-R,/home/alireza/petsc-3.9.3 due to
            Rejected C linker flag -Wl,-R,
              Popping language C
              Pushing language Cxx
Executing: uname -s
stdout: CYGWIN_NT-6.1
            Trying Cxx linker flag -Wl,-rpath,
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp     /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
                      Pushing language CXX
                      Popping language CXX
              Rejecting Cxx linker flag -Wl,-rpath,/home/alireza/petsc-3.9.3 due to
            Rejected Cxx linker flag -Wl,-rpath,
            Trying Cxx linker flag -R
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
              Rejecting Cxx linker flag -R/home/alireza/petsc-3.9.3 due to
            Rejected Cxx linker flag -R
            Trying Cxx linker flag -rpath
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
stdout:
stdout:
              Rejecting Cxx linker flag -rpath /home/alireza/petsc-3.9.3 due to
            Rejected Cxx linker flag -rpath
            Trying Cxx linker flag -Wl,-R,
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
              Rejecting Cxx linker flag -Wl,-R,/home/alireza/petsc-3.9.3 due to
            Rejected Cxx linker flag -Wl,-R,
              Popping language Cxx
              Pushing language FC
Executing: uname -s
            Trying FC linker flag -Wl,-rpath,
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
                      Pushing language FC
                      Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -Wl,-rpath,/home/alireza/petsc-3.9.3  -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: ifort: command line warning #10157: ignoring option '/W'; argument is of wrong type
              Rejecting FC linker flag -Wl,-rpath,/home/alireza/petsc-3.9.3 due to
            Rejected FC linker flag -Wl,-rpath,
            Trying FC linker flag -R
Successful compile:
Source:
      program main
      end
                      Pushing language FC
                      Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -R/home/alireza/petsc-3.9.3  -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout: ifort: command line warning #10006: ignoring unknown option '/R/home/alireza/petsc-3.9.3'
              Rejecting FC linker flag -R/home/alireza/petsc-3.9.3 due to
            Rejected FC linker flag -R
            Trying FC linker flag -rpath
Successful compile:
Source:
      program main
      end
                      Pushing language FC
                      Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -rpath /home/alireza/petsc-3.9.3  -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
stdout:
ifort: command line warning #10006: ignoring unknown option '/rpath'
ifort: command line warning #10161: unrecognized source type 'E:\cygwin64\home\alireza\petsc-3.9.3'; object file assumed
stdout:
              Rejecting FC linker flag -rpath /home/alireza/petsc-3.9.3 due to
            Rejected FC linker flag -rpath
            Trying FC linker flag -Wl,-R,
Successful compile:
Source:
      program main
      end
                      Pushing language FC
                      Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.exe  -Wl,-R,/home/alireza/petsc-3.9.3  -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
              Rejecting FC linker flag -Wl,-R,/home/alireza/petsc-3.9.3 due to
            Rejected FC linker flag -Wl,-R,
              Popping language FC
TEST checkLibC from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1448)
TESTING: checkLibC from config.setCompilers(config/BuildSystem/config/setCompilers.py:1448)
  Test whether we need to explicitly include libc in shared linking
       - Mac OSX requires an explicit reference to libc for shared linking
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
int foo(void) {void *chunk = malloc(31); free(chunk); return 0;}
                      Pushing language C
                      Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/libconftest.dll  -LD -O2 -MT -wd4996 -Qopenmp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o
            Shared linking does not require an explicit libc reference
TEST checkDynamicLinker from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1497)
TESTING: checkDynamicLinker from config.setCompilers(config/BuildSystem/config/setCompilers.py:1497)
  Check that the linker can dynamicaly load shared libraries
Checking for header: dlfcn.h
                          All intermediate test results are stored in /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "dlfcn.h"
  #include <dlfcn.h>
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conffix.h"
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Possible ERROR while running preprocessor: exit code 512
stdout:
conftest.c
  #include <dlfcn.h>
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"Source:
#include <dlfcn.h>
Preprocess stderr before filtering::
Preprocess stderr after filtering::
            Dynamic loading disabled since dlfcn.h was missing
TEST output from config.setCompilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/setCompilers.py:1549)
TESTING: output from config.setCompilers(config/BuildSystem/config/setCompilers.py:1549)
  Output module data as defines and substitutions
              Substituting "CC" with "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl"
              Substituting "CFLAGS" with "-O2 -MT -wd4996 -Qopenmp  "
              Defined make macro "CC_LINKER_SLFLAG" to "-L"
              Substituting "CPP" with "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E"
              Substituting "CPPFLAGS" with ""
              Substituting "CXX" with "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl"
              Substituting "CXX_CXXFLAGS" with " "
              Substituting "CXXFLAGS" with "-O2 -MT -wd4996 -Qopenmp"
              Substituting "CXX_LINKER_SLFLAG" with "-L"
              Substituting "CXXCPP" with "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E"
              Substituting "CXXCPPFLAGS" with ""
              Substituting "FC" with "/home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort"
              Substituting "FFLAGS" with "-MT -O2 -Qopenmp"
              Defined make macro "FC_LINKER_SLFLAG" to "-L"
              Substituting "LDFLAGS" with ""
              Substituting "LIBS" with ""
              Substituting "SHARED_LIBRARY_FLAG" with "-LD"
Executing: uname -s
        Shared libraries (DLLs) - disabled due to fortran build on windows
TEST checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(/home/alireza/petsc-3.9.3/config/PETSc/options/sharedLibraries.py:37)
TESTING: checkSharedDynamicPicOptions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:37)
TEST configureSharedLibraries from PETSc.options.sharedLibraries(/home/alireza/petsc-3.9.3/config/PETSc/options/sharedLibraries.py:53)
TESTING: configureSharedLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:53)
  Checks whether shared libraries should be used, for which you must
      - Specify --with-shared-libraries
      - Have found a working shared linker
    Defines PETSC_USE_SHARED_LIBRARIES if they are used
              Defined make rule "shared_arch" with dependencies "" and code []
              Defined make macro "BUILDSHAREDLIB" to "no"
              Defined "HAVE_SHARED_LIBRARIES" to "1"
            Shared libraries - disabled
TEST configureDynamicLibraries from PETSc.options.sharedLibraries(/home/alireza/petsc-3.9.3/config/PETSc/options/sharedLibraries.py:97)
TESTING: configureDynamicLibraries from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:97)
  Checks whether dynamic loading is available (with dlfcn.h and libdl)
TEST configureSerializedFunctions from PETSc.options.sharedLibraries(/home/alireza/petsc-3.9.3/config/PETSc/options/sharedLibraries.py:103)
TESTING: configureSerializedFunctions from PETSc.options.sharedLibraries(config/PETSc/options/sharedLibraries.py:103)
    Defines PETSC_SERIALIZE_FUNCTIONS if they are used
    Requires shared libraries
TEST configureIndexSize from PETSc.options.indexTypes(/home/alireza/petsc-3.9.3/config/PETSc/options/indexTypes.py:31)
TESTING: configureIndexSize from PETSc.options.indexTypes(config/PETSc/options/indexTypes.py:31)
              Defined make macro "PETSC_INDEX_SIZE" to "32"
TEST configureCompilerFlags from config.compilerFlags(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilerFlags.py:72)
TESTING: configureCompilerFlags from config.compilerFlags(config/BuildSystem/config/compilerFlags.py:72)
  Get the default compiler flags
            Ignoring default options which were overridden using --CFLAGS -O2 -MT -wd4996 -Qopenmp
            Optimization options found in CFLAGS. Skipping setting defaults
            Ignoring default options which were overridden using --CXXFLAGS -O2 -MT -wd4996 -Qopenmp
            Optimization options found in CXXFLAGS. Skipping setting defaults
            Ignoring default options which were overridden using --FFLAGS -MT -O2 -Qopenmp
            Optimization options found in FFLAGS. Skipping setting defaults
              Pushing language C
              Popping language C
              Pushing language FC
              Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl --version
stdout:
Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
getCompilerVersion: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
\nIntel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
stdout:
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort --version
stdout:
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
getCompilerVersion: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort Win32 Development Tool Front End, version 1.11.3 Mon, Feb 27, 2017 11:10:38 AM
\nIntel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 18.0.3.210 Build 20180410
TEST configureDebugging from PETSc.options.debugging(/home/alireza/petsc-3.9.3/config/PETSc/options/debugging.py:25)
TESTING: configureDebugging from PETSc.options.debugging(config/PETSc/options/debugging.py:25)
              Defined "USE_ERRORCHECKING" to "1"
                              WARNING! Compiling PETSc with no debugging, this should
                                    only be done for timing and production runs. All development should
                                    be done when configured using --with-debugging=1
TEST checkRestrict from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:139)
TESTING: checkRestrict from config.compilers(config/BuildSystem/config/compilers.py:139)
  Check for the C/CXX restrict keyword
              Pushing language C
                        All intermediate test results are stored in /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
float * __restrict x;;
  return 0;
            compilers: Set C restrict keyword to __restrict
              Defined "C_RESTRICT" to "__restrict"
              Popping language C
TEST checkCFormatting from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:391)
TESTING: checkCFormatting from config.compilers(config/BuildSystem/config/compilers.py:391)
  Activate format string checking if using the GNU compilers
TEST checkCStaticInline from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:109)
TESTING: checkCStaticInline from config.compilers(config/BuildSystem/config/compilers.py:109)
  Check for C keyword: static inline
              Pushing language C
stdout: conftest.c
Successful compile:
Source:
static inline int foo(int a) {return a;}
int main() {
foo(1);;
  return 0;
            compilers: Set C StaticInline keyword to static inline
              Popping language C
              Defined "C_STATIC_INLINE" to "static inline"
TEST checkDynamicLoadFlag from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:402)
TESTING: checkDynamicLoadFlag from config.compilers(config/BuildSystem/config/compilers.py:402)
  Checks that dlopen() takes RTLD_XXX, and defines PETSC_HAVE_RTLD_XXX if it does
TEST checkCLibraries from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:203)
TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:203)
  Determines the libraries needed to link with C compiled code
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void asub(void)
{char s[16];printf("testing %s",s);}
                Popping language C
                Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.F90
Successful compile:
Source:
      program main
      print*,'testing'
      stop
      end
                         Pushing language FC
                        Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.exe   -MT -O2 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confc.o
                Popping language FC
            C libraries are not needed when using Fortran linker
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
#include <stdio.h>
void asub(void)
                Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp     /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
 int main(int argc,char **args)
{return 0;}
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.exe   -O2 -MT -wd4996 -Qopenmp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confc.o
            C libraries are not needed when using C++ linker
TEST checkDependencyGenerationFlag from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1588)
TESTING: checkDependencyGenerationFlag from config.compilers(config/BuildSystem/config/compilers.py:1588)
  Check if -MMD works for dependency generation, and add it if it does
            Trying C compiler flag -MMD -MP
            Rejected C compiler flag -MMD -MP
            Trying C compiler flag -xMMD
            Rejected C compiler flag -xMMD
            Trying C compiler flag -qmakedep=gcc
            Rejected C compiler flag -qmakedep=gcc
            Trying C compiler flag -MD
            Rejected C compiler flag -MD because no dependency file (/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.d) was generated
              Pushing language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -MMD -MP  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/MMD'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Rejecting compiler flag -MMD -MP due to
conftest.c
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -MMD  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Rejecting compiler flag -MMD due to
conftest.c
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -xMMD  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/xMMD'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Rejecting compiler flag -xMMD due to
conftest.c
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -qmakedep=gcc  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/qmakedep=gcc'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Rejecting compiler flag -qmakedep=gcc due to
conftest.c
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -MD  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10121: overriding '/MT' with '/MD'
conftest.c
Successful compile:
Source:
int main() {
  return 0;
              Popping language C
            Trying Cxx compiler flag -MMD -MP
            Rejected Cxx compiler flag -MMD -MP
            Trying Cxx compiler flag -xMMD
            Rejected Cxx compiler flag -xMMD
            Trying Cxx compiler flag -qmakedep=gcc
            Rejected Cxx compiler flag -qmakedep=gcc
            Trying Cxx compiler flag -MD
            Rejected Cxx compiler flag -MD because no dependency file (/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.d) was generated
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp   -MMD -MP   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp   -MMD   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp   -xMMD   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp   -qmakedep=gcc   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
conftest.cc
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -O2 -MT -wd4996 -Qopenmp   -MD   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout:
conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            Trying FC compiler flag -MMD -MP
            Rejected FC compiler flag -MMD -MP
            Trying FC compiler flag -xMMD
            Rejected FC compiler flag -xMMD
            Trying FC compiler flag -qmakedep=gcc
            Rejected FC compiler flag -qmakedep=gcc
            Trying FC compiler flag -MD
            Rejected FC compiler flag -MD because no dependency file (/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.d) was generated
              Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -MMD -MP  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/MMD'
Successful compile:
Source:
      program main
      end
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -MMD  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -xMMD  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/xMMD'
Successful compile:
Source:
      program main
      end
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -qmakedep=gcc  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10006: ignoring unknown option '/qmakedep=gcc'
Successful compile:
Source:
      program main
      end
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -MT -O2 -Qopenmp -MD  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line warning #10121: overriding '/MT' with '/MD'
Successful compile:
Source:
      program main
      end
              Popping language FC
TEST checkC99Flag from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1634)
TESTING: checkC99Flag from config.compilers(config/BuildSystem/config/compilers.py:1634)
  Check for -std=c99 or equivalent flag
              Pushing language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp     /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include <float.h>
int main() {
    float x[2],y;
    y = FLT_ROUNDS;
    // c++ comment
    int j = 2;
    for (int i=0; i<2; i++){
      x[i] = i*j*y;
  return 0;
            Accepted C99 compile flag:
              Defined "HAVE_C99" to "1"
              Popping language C
stdout: conftest.cc
Successful compile:
Source:
int main() {
  return 0;
            compilers: Set Cxx restrict keyword to __restrict
              Defined "CXX_RESTRICT" to "__restrict"
TEST checkCxxNamespace from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:442)
TESTING: checkCxxNamespace from config.compilers(config/BuildSystem/config/compilers.py:442)
  Checks that C++ compiler supports namespaces, and if it does defines HAVE_CXX_NAMESPACE
stdout: conftest.cc
Successful compile:
Source:
namespace petsc {int dummy;}
int main() {
  return 0;
stdout: conftest.cc
Successful compile:
Source:
template <class dummy> struct a {};
namespace trouble{
template <class dummy> struct a : public ::a<dummy> {};
trouble::a<int> uugh;
int main() {
  return 0;
            compilers: C++ has namespaces
              Defined "HAVE_CXX_NAMESPACE" to "1"
TEST checkCxxOptionalExtensions from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:415)
TESTING: checkCxxOptionalExtensions from config.compilers(config/BuildSystem/config/compilers.py:415)
  Check whether the C++ compiler (IBM xlC, OSF5) need special flag for .c files which contain C++
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.c(5): error: identifier "class" is undefined
  class somename { int i; };;
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.c(5): error: expected a ";"
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.c (code 2)
Possible ERROR while running compiler: exit code 512
stdout:
conftest.c
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.c (code 2)Source:
int main() {
  return 0;
                Rejecting compiler flag   due to nonzero status from link
conftest.c
PETSc Error: No output file produced
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp -+      /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/+'
conftest.c
stdout:
conftest.c
int main() {
  return 0;
                Rejecting compiler flag -+  due to nonzero status from link
conftest.c
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp -x cxx -tlocal      /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: Error: win32fe: Input File Not Found: E:\cygwin64\home\alireza\petsc-3.9.3\cxx
Possible ERROR while running compiler: exit code 32512
stdout:
Error: win32fe: Input File Not Found: E:\cygwin64\home\alireza\petsc-3.9.3\cxxSource:
int main() {
  return 0;
                Rejecting compiler flag -x cxx -tlocal  due to nonzero status from link
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp -Kc++      /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout:
icl: command line warning #10006: ignoring unknown option '/Kc++'
conftest.c
stdout:
conftest.c
int main() {
  return 0;
                Rejecting compiler flag -Kc++  due to nonzero status from link
conftest.c
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -TP    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.c
stdout: conftest.c
Successful compile:
Source:
int main() {
  return 0;
Added Cxx compiler flag -TP
TEST checkCxxStaticInline from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:124)
TESTING: checkCxxStaticInline from config.compilers(config/BuildSystem/config/compilers.py:124)
  Check for C++ keyword: static inline
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp   -TP   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
int main() {
foo(1);;
  return 0;
            compilers: Set Cxx StaticInline keyword to static inline
              Defined "CXX_STATIC_INLINE" to "static inline"
TEST checkCxxLibraries from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:500)
TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:500)
  Determines the libraries needed to link with C++
stdout:
conftest.cc
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.cc(7): warning #583: C++ exception handler found but /EHsc option was not specified
  try  { throw 20;  }  catch (int e)  { std::cout << "An exception occurred";  }}
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
{std::vector<int> v;
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
{return 0;}
                         Pushing language C
                        Popping language C
                Popping language C
            C++ libraries are not needed when using C linker
stdout:
conftest.cc
Successful compile:
Source:
#include <iostream>
#include <vector>
void asub(void)
                Pushing language FC
Successful compile:
Source:
      program main
      print*,'testing'
      stop
      end
                         Pushing language FC
                        Popping language FC
                Popping language FC
            C++ libraries are not needed when using FC linker
TEST checkCxx11 from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:457)
TESTING: checkCxx11 from config.compilers(config/BuildSystem/config/compilers.py:457)
  Determine the option needed to support the C++11 dialect
    We auto-detect C++11 if the compiler supports it without options,
    otherwise we require with-cxx-dialect=C++11 to try adding flags to
    support it.
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -O2 -MT -wd4996 -Qopenmp    -TP   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.cc
stdout: conftest.cc
Successful compile:
Source:
          #include <random>
          template<typename T> constexpr T Cubed( T x ) { return x*x*x; }
int main() {
          std::random_device rd;
          std::mt19937 mt(rd());
          std::normal_distribution<double> dist(0,1);
          const double x = dist(mt);
  return 0;
TEST checkFortranTypeSizes from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:713)
TESTING: checkFortranTypeSizes from config.compilers(config/BuildSystem/config/compilers.py:713)
  Check whether real*8 is supported and suggest flags which will allow support
              Pushing language FC
Successful compile:
Source:
      program main
      real*8 variable
      end
              Popping language FC
TEST checkFortranNameMangling from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:773)
TESTING: checkFortranNameMangling from config.compilers(config/BuildSystem/config/compilers.py:773)
  Checks Fortran name mangling, and defines HAVE_FORTRAN_UNDERSCORE, HAVE_FORTRAN_NOUNDERSCORE, HAVE_FORTRAN_CAPS, or HAVE_FORTRAN_STDCALL
Testing Fortran mangling type underscore with code void d1chk_(void){return;}
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
                Popping language C
                Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                        Pushing language FC
                        Popping language FC
stdout:
conftest.obj : error LNK2019: unresolved external symbol D1CHK referenced in function MAIN__
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.exe : fatal error LNK1120: 1 unresolved externals
Possible ERROR while running linker: exit code 24576
stdout:
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.exe : fatal error LNK1120: 1 unresolved externals                Popping language FC
Testing Fortran mangling type unchanged with code void d1chk(void){return;}
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
                Popping language C
                Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                        Pushing language FC
                        Popping language FC
stdout:
stdout:
Testing Fortran mangling type caps with code void D1CHK(void){return;}
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
                Popping language C
                Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                        Pushing language FC
                        Popping language FC
                Popping language FC
            compilers: Fortran name mangling is caps
              Defined "HAVE_FORTRAN_CAPS" to "1"
                    Pushing language FC
                    Popping language FC
stdout:
              Defined "FORTRAN_CHARLEN_T" to "int"
TEST checkFortranNameManglingDouble from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:814)
TESTING: checkFortranNameManglingDouble from config.compilers(config/BuildSystem/config/compilers.py:814)
  Checks if symbols containing an underscore append an extra underscore, and defines HAVE_FORTRAN_UNDERSCORE_UNDERSCORE if necessary
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
void d1_chk__(void){return;}
                Popping language C
                Pushing language FC
Successful compile:
Source:
      program main
       call d1_chk()
      end
                        Pushing language FC
                        Popping language FC
stdout:
conftest.obj : error LNK2019: unresolved external symbol D1_CHK referenced in function MAIN__
stdout:
TEST checkFortranPreprocessor from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:824)
TESTING: checkFortranPreprocessor from config.compilers(config/BuildSystem/config/compilers.py:824)
  Determine if Fortran handles preprocessing properly
            compilers: Fortran uses CPP preprocessor
              Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout:
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90(2): warning #5117: Bad # preprocessor line
#define dummy
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90(4): warning #5117: Bad # preprocessor line
#ifndef dummy
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90(3): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
           dummy
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90(6): warning #5117: Bad # preprocessor line
#endif
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90(5): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: => = . [ % ( :
       fooey
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90 (code 1)
Possible ERROR while running compiler: exit code 256
stdout:
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.setCompilers\conftest.F90 (code 1)Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -cpp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout:
ifort: command line warning #10006: ignoring unknown option '/cpp'
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
stdout:
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
                Rejecting compiler flag -cpp  due to nonzero status from link
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -xpp=cpp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout:
ifort: command line warning #10006: ignoring unknown option '/xpp=cpp'
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
stdout:
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
                Rejecting compiler flag -xpp=cpp  due to nonzero status from link
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -F   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout: ifort: command line error: option '/F' is ambiguous
stdout:
ifort: command line error: option '/F' is ambiguousSource:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
                Rejecting compiler flag -F  due to nonzero status from link
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -Cpp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
stdout:
ifort: command line warning #10006: ignoring unknown option '/Cpp'
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
stdout:
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
                Rejecting compiler flag -Cpp  due to nonzero status from link
#define dummy
#ifndef dummy
           dummy
#endif
       fooey
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -fpp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef dummy
       fooey
#endif
      end
Added FC compiler flag -fpp
              Popping language FC
TEST checkFortranDefineCompilerOption from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:848)
TESTING: checkFortranDefineCompilerOption from config.compilers(config/BuildSystem/config/compilers.py:848)
  Check if -WF,-Dfoobar or -Dfoobar is the compiler option to define a macro
              Defined make macro "FC_DEFINE_FLAG" to "-D"
            compilers: Fortran uses -D for defining macro
              Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -fpp -DTesting  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
#define dummy
           dummy
#ifndef Testing
       fooey
#endif
      end
              Popping language FC
TEST checkFortranLibraries from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:868)
TESTING: checkFortranLibraries from config.compilers(config/BuildSystem/config/compilers.py:868)
  Substitutes for FLIBS the libraries needed to link with Fortran
    This macro is intended to be used in those situations when it is
    necessary to mix, e.g. C++ and Fortran 77, source code into a single
    program or shared library.
    For example, if object files from a C++ and Fortran 77 compiler must
    be linked together, then the C++ compiler/linker must be used for
    linking (since special C++-ish things need to happen at link time
    like calling global constructors, instantiating templates, enabling
    exception support, etc.).
    However, the Fortran 77 intrinsic and run-time libraries must be
    linked in as well, but the C++ compiler/linker does not know how to
    add these Fortran 77 libraries.
    This code was translated from the autoconf macro which was packaged in
    its current form by Matthew D. Langston <langston at SLAC.Stanford.EDU>.
    However, nearly all of this macro came from the OCTAVE_FLIBS macro in
    octave-2.0.13/aclocal.m4, and full credit should go to John W. Eaton
    for writing this extremely useful macro.
              Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -MT -O2 -Qopenmp -fpp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.F90
Successful compile:
Source:
      program main
#include <mpif.h>
      call MPI_Allreduce()
      end
                      Pushing language FC
                      Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.exe   -MT -O2 -Qopenmp -fpp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o
stdout:
conftest.obj : error LNK2019: unresolved external symbol MPI_ALLREDUCE referenced in function MAIN__
conftest.obj : error LNK2001: unresolved external symbol MPI_DUP_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_NULL_DELETE_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_NULL_COPY_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_COMM_DUP_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_COMM_NULL_DELETE_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_COMM_NULL_COPY_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_WIN_DUP_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_WIN_NULL_DELETE_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_WIN_NULL_COPY_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_TYPE_DUP_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_TYPE_NULL_DELETE_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_TYPE_NULL_COPY_FN
conftest.obj : error LNK2001: unresolved external symbol MPI_CONVERSION_FN_NULL
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.exe : fatal error LNK1120: 14 unresolved externals
stdout:
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.exe : fatal error LNK1120: 14 unresolved externals              Popping language FC
                Pushing language FC
Successful compile:
Source:
subroutine asub()
      print*,'testing'
      return
      end
                Popping language FC
                Pushing language C
stdout: conftest.c
Successful compile:
Source:
{return 0;}
                         Pushing language C
                        Popping language C
                Popping language C
            Fortran libraries are not needed when using C linker
                Pushing language FC
Successful compile:
Source:
subroutine asub()
      print*,'testing'
      return
      end
                Popping language FC
stdout: conftest.cc
Successful compile:
Source:
{return 0;}
            Fortran libraries are not needed when using C++ linker
TEST checkFortranLinkingCxx from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1263)
TESTING: checkFortranLinkingCxx from config.compilers(config/BuildSystem/config/compilers.py:1263)
  Check that Fortran can be linked against C++
stdout: conftest.cc
Successful compile:
Source:
extern "C" void D1CHK(void);
void foo(void){D1CHK();}
stdout: conftest.cc
Successful compile:
Source:
                Pushing language FC
Successful compile:
Source:
      program main
       call d1chk()
      end
                        Pushing language FC
                        Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.exe   -MT -O2 -Qopenmp -fpp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/cxxobj.o  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confc.o
                Popping language FC
            compilers: Fortran can link C++ functions
TEST checkFortran90 from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1329)
TESTING: checkFortran90 from config.compilers(config/BuildSystem/config/compilers.py:1329)
  Determine whether the Fortran compiler handles F90
              Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER :: int = SELECTED_INT_KIND(8)
      INTEGER (KIND=int) :: ierr
      ierr = 1
      end
                      Pushing language FC
                      Popping language FC
              Defined "USING_F90" to "1"
            Fortran compiler supports F90
              Popping language FC
TEST checkFortran90FreeForm from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1342)
TESTING: checkFortran90FreeForm from config.compilers(config/BuildSystem/config/compilers.py:1342)
  Determine whether the Fortran compiler handles F90FreeForm
       We also require that the compiler handles lines longer than 132 characters
              Pushing language FC
Successful compile:
Source:
      program main
      INTEGER, PARAMETER ::        int = SELECTED_INT_KIND(8);              INTEGER (KIND=int) :: ierr;       ierr                            =        1
      end
                      Pushing language FC
                      Popping language FC
              Defined "USING_F90FREEFORM" to "1"
            Fortran compiler supports F90FreeForm
              Popping language FC
TEST checkFortran2003 from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1356)
TESTING: checkFortran2003 from config.compilers(config/BuildSystem/config/compilers.py:1356)
  Determine whether the Fortran compiler handles F2003
              Pushing language FC
stdout:
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(3): error #6218: This statement is positioned incorrectly and/or has syntax errors.
      module Base_module
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(4): error #6848: This attribute specification is valid only in the specification part of a module.   [PUBLIC]
        type, public :: base_type
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(7): error #6850: This attribute specification is not valid in the main scoping unit.   [PUBLIC]
           procedure, public :: Print => BasePrint
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(7): error #8258: The procedure name in a type-bound procedure declaration should be the name of an accessible module procedure or an external procedure that has an explicit interface.   [BASEPRINT]
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(13): error #6790: This is an invalid statement; an END [PROGRAM]  statement is required.
      end module Base_module
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(13): error #6785: This name does not match the unit name.   [BASE_MODULE]
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90(16): warning #5427: Program may contain only one main entry routine
      use,intrinsic :: iso_c_binding
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90 (code 1)
stdout:
      module Base_module
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.compilers\conftest.F90 (code 1)Source:
      program main
      module Base_module
           integer :: A
         contains
        end type base_type
      contains
        subroutine BasePrint(this)
          class(base_type) :: this
        end subroutine BasePrint
      Type(C_Ptr),Dimension(:),Pointer :: CArray
      character(kind=c_char),pointer   :: nullc => null()
      character(kind=c_char,len=5),dimension(:),pointer::list1
      allocate(list1(5))
      CArray = (/(c_loc(list1(i)),i=1,5),c_loc(nullc)/)
      end
                Compile failed inside link
            Fortran compiler does not support F2003
              Popping language FC
TEST checkFortran90Array from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1390)
TESTING: checkFortran90Array from config.compilers(config/BuildSystem/config/compilers.py:1390)
  Check for F90 array interfaces
Executing: uname -s
            Cygwin detected: ignoring HAVE_F90_2PTR_ARG test
TEST checkFortranModuleInclude from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1477)
TESTING: checkFortranModuleInclude from config.compilers(config/BuildSystem/config/compilers.py:1477)
  Figures out what flag is used to specify the include path for Fortran modules
              Pushing language FC
Successful compile:
Source:
      module configtest
      integer testint
      parameter (testint = 42)
      end module configtest
              Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confdir -MT -O2 -Qopenmp -fpp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.F90
Successful compile:
Source:
      program main
      use configtest
      write(*,*) testint
      end
                      Pushing language FC
                      Popping language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.exe   -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confdir -MT -O2 -Qopenmp -fpp /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/configtest.o
            compilers: Fortran module include flag -I found
              Popping language FC
TEST checkFortranModuleOutput from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1543)
TESTING: checkFortranModuleOutput from config.compilers(config/BuildSystem/config/compilers.py:1543)
              Pushing language FC
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -module /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confdir -MT -O2 -Qopenmp -fpp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.F90
Source:
      module configtest
      integer testint
            compilers: Fortran module output flag -module  compile failed
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe ifort -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -module:/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/confdir -MT -O2 -Qopenmp -fpp  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers/conftest.F90
Successful compile:
Source:
      module configtest
      integer testint
            compilers: Fortran module output flag -module: found
              Popping language FC
TEST checkFortranTypeStar from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1318)
TESTING: checkFortranTypeStar from config.compilers(config/BuildSystem/config/compilers.py:1318)
  Determine whether the Fortran compiler handles type(*)
              Pushing language FC
Successful compile:
Source:
      program main
      interface
      subroutine a(b)
      type(*) :: b(:)
      end subroutine
      end interface
      end
              Defined "HAVE_FORTRAN_TYPE_STAR" to "1"
            Fortran compiler supports type(*)
              Popping language FC
TEST checkFortranTypeInitialize from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1307)
TESTING: checkFortranTypeInitialize from config.compilers(config/BuildSystem/config/compilers.py:1307)
  Determines if PETSc objects in Fortran are initialized by default (doesn't work with common blocks)
              Defined "HAVE_FORTRAN_TYPE_INITIALIZE" to "0"
              Defined "FORTRAN_TYPE_INITIALIZE" to " = 0"
            Initializing Fortran objects
TEST configureFortranFlush from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1298)
TESTING: configureFortranFlush from config.compilers(config/BuildSystem/config/compilers.py:1298)
              Pushing language FC
Successful compile:
Source:
      program main
      call flush(6)
      end
                      Pushing language FC
                      Popping language FC
              Defined "HAVE_FORTRAN_FLUSH" to "1"
              Popping language FC
TEST setupFrameworkCompilers from config.compilers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/compilers.py:1710)
TESTING: setupFrameworkCompilers from config.compilers(config/BuildSystem/config/compilers.py:1710)
TEST configureClosure from config.utilities.closure(/home/alireza/petsc-3.9.3/config/BuildSystem/config/utilities/closure.py:18)
TESTING: configureClosure from config.utilities.closure(config/BuildSystem/config/utilities/closure.py:18)
  Determine if Apple ^close syntax is supported in C
              Pushing language C
                          All intermediate test results are stored in /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.utilities.closure\conftest.c(6): error: expected an identifier
  int (^closure)(int);;
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.utilities.closure\conftest.c (code 2)
stdout:
conftest.c
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.utilities.closure\conftest.c (code 2)Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdio.h>
int main() {
  return 0;
TEST configureFortranCPP from PETSc.options.fortranCPP(/home/alireza/petsc-3.9.3/config/PETSc/options/fortranCPP.py:21)
TESTING: configureFortranCPP from PETSc.options.fortranCPP(config/PETSc/options/fortranCPP.py:21)
  Handle case where Fortran cannot preprocess properly
              Defined make rule ".f.o .f90.o .f95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} -o $@ $<']
              Defined make rule ".f.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
              Defined make rule ".F.o .F90.o .F95.o" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} -o $@ $<']
              Defined make rule ".F.a" with dependencies "" and code ['${PETSC_MAKE_STOP_ON_ERROR}${FC} -c ${FC_FLAGS} ${FFLAGS} ${FCPPFLAGS} $<', '-${AR} ${AR_FLAGS} ${LIBNAME} $*.o', '-${RM} $*.o']
TEST checkStdC from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:105)
TESTING: checkStdC from config.headers(config/BuildSystem/config/headers.py:105)
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include <stdlib.h>
#include <stdarg.h>
#include <string.h>
#include <float.h>
int main() {
  return 0;
Source:
#include <string.h>
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#pragma once
     int* __cdecl _errno(void);
     errno_t __cdecl _set_errno( int _Value);
     errno_t __cdecl _get_errno( int* _Value);
     unsigned long* __cdecl __doserrno(void);
     errno_t __cdecl _set_doserrno( unsigned long _Value);
     errno_t __cdecl _get_doserrno( unsigned long * _Value);
#line 70 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#line 79 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#line 127 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
__pragma(pack(pop))
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime_string.h"
#pragma once
 void * __cdecl memchr(
     void const* _Buf,
                                int         _Val,
                                size_t      _MaxCount
int __cdecl memcmp(
     void const* _Buf1,
     void const* _Buf2,
                        size_t      _Size
void* __cdecl memcpy(
     void* _Dst,
           void const* _Src,
                              size_t      _Size
 void* __cdecl memmove(
     void*       _Dst,
           void const* _Src,
                                  size_t      _Size
void* __cdecl memset(
     void*  _Dst,
                              int    _Val,
                              size_t _Size
 char * __cdecl strchr(
     char const* _Str,
       int         _Val
 char * __cdecl strrchr(
     char const* _Str,
       int         _Ch
 char * __cdecl strstr(
     char const* _Str,
     char const* _SubStr
 wchar_t * __cdecl wcschr(
     wchar_t const* _Str,
       wchar_t        _Ch
 wchar_t * __cdecl wcsrchr(
       wchar_t        _Ch
 wchar_t * __cdecl wcsstr(
     wchar_t const* _SubStr
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
    static __inline errno_t __cdecl memcpy_s(
         void*       const _Destination,
                                                             rsize_t     const _DestinationSize,
                                void const* const _Source,
                                                             rsize_t     const _SourceSize
        if (_SourceSize == 0)
            return 0;
        { int _Expr_val=!!(_Destination != ((void *)0)); if (!(_Expr_val)) { (*_errno()) = 22; _invalid_parameter_noinfo(); return 22; } };
        if (_Source == ((void *)0) || _DestinationSize < _SourceSize)
            memset(_Destination, 0, _DestinationSize);
            { int _Expr_val=!!(_Source != ((void *)0)); if (!(_Expr_val)) { (*_errno()) = 22; _invalid_parameter_noinfo(); return 22; } };
            { int _Expr_val=!!(_DestinationSize >= _SourceSize); if (!(_Expr_val)) { (*_errno()) = 34; _invalid_parameter_noinfo(); return 34; } };
            return 22;
        memcpy(_Destination, _Source, _SourceSize);
        return 0;
    static __inline errno_t __cdecl memmove_s(
            return 0;
        memmove(_Destination, _Source, _SourceSize);
        return 0;
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
 int __cdecl _memicmp(
     void const* _Buf1,
     void const* _Buf2,
                            size_t      _Size
 int __cdecl _memicmp_l(
     void const* _Buf1,
     void const* _Buf2,
                            size_t      _Size,
                        _locale_t   _Locale
#line 56 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
#line 71 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_memccpy" ". See online help for details."))
     void* __cdecl memccpy(
         void*       _Dst,
           void const* _Src,
                                  int         _Val,
                                  size_t      _Size
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_memicmp" ". See online help for details."))
     int __cdecl memicmp(
         void const* _Buf1,
         void const* _Buf2,
                                size_t      _Size
#line 111 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
#pragma once
     errno_t __cdecl wcscat_s(
         wchar_t* _Destination,
         rsize_t _SizeInWords,
         wchar_t const* _Source
     errno_t __cdecl wcscpy_s(
     errno_t __cdecl wcsncat_s(
              wchar_t const* _Source,
                                    rsize_t        _MaxCount
     errno_t __cdecl wcsncpy_s(
                                 rsize_t        _MaxCount
     wchar_t* __cdecl wcstok_s(
                         wchar_t*       _String,
                                wchar_t const* _Delimiter,
          wchar_t**      _Context
 __declspec(allocator) wchar_t* __cdecl _wcsdup(
     wchar_t const* _String
#pragma warning(push)
#pragma warning(disable: 28719)
#pragma warning(disable: 28726)
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "wcscat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcscat( wchar_t *_Destination, wchar_t const* _Source);
#pragma warning(pop)
 int __cdecl wcscmp(
     wchar_t const* _String1,
     wchar_t const* _String2
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcscpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcscpy( wchar_t *_Destination, wchar_t const* _Source);
 size_t __cdecl wcscspn(
     wchar_t const* _String,
     wchar_t const* _Control
 size_t __cdecl wcslen(
 size_t __cdecl wcsnlen(
                           size_t         _MaxCount
    static __inline size_t __cdecl wcsnlen_s(
                               size_t         _MaxCount
        return (_Source == 0) ? 0 : wcsnlen(_Source, _MaxCount);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcsncat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcsncat( wchar_t *_Destination, wchar_t const* _Source, size_t _Count);
 int __cdecl wcsncmp(
     wchar_t const* _String2,
                           size_t         _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcsncpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcsncpy( wchar_t *_Destination, wchar_t const* _Source, size_t _Count);
 wchar_t * __cdecl wcspbrk(
 size_t __cdecl wcsspn(
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstok_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl wcstok(
                         wchar_t*       _String,
      wchar_t**      _Context
#line 242 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
    #pragma warning(disable: 4141 4996)
    #pragma warning(disable: 28719 28726 28727)
    static __inline wchar_t* __cdecl _wcstok(
         wchar_t*       const _String,
                wchar_t const* const _Delimiter
        return wcstok(_String, _Delimiter, 0);
#line 269 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcserror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wcserror(
     int _ErrorNumber
 errno_t __cdecl _wcserror_s(
     wchar_t* _Buffer,
                                 int      _ErrorNumber
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "__wcserror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl __wcserror(
  errno_t __cdecl __wcserror_s(
     wchar_t*       _Buffer,
                               wchar_t const* _ErrorMessage
  int __cdecl _wcsicmp(
  int __cdecl _wcsicmp_l(
     _locale_t      _Locale
  int __cdecl _wcsnicmp(
                           size_t         _MaxCount
  int __cdecl _wcsnicmp_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
  errno_t __cdecl _wcsnset_s(
                                wchar_t  _Value,
                                size_t   _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsnset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsnset( wchar_t *_String, wchar_t _Value, size_t _MaxCount);
 wchar_t* __cdecl _wcsrev(
     wchar_t* _String
  errno_t __cdecl _wcsset_s(
                                wchar_t  _Value
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsset( wchar_t *_String, wchar_t _Value);
  errno_t __cdecl _wcslwr_s(
     wchar_t* _String,
                                size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcslwr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcslwr( wchar_t *_String);
 errno_t __cdecl _wcslwr_s_l(
     wchar_t*  _String,
                            _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcslwr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcslwr_l( wchar_t *_String, _locale_t _Locale);
 errno_t __cdecl _wcsupr_s(
     wchar_t* _String,
                         size_t   _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsupr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsupr( wchar_t *_String);
 errno_t __cdecl _wcsupr_s_l(
     wchar_t*  _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsupr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsupr_l( wchar_t *_String, _locale_t _Locale);
 size_t __cdecl wcsxfrm(
              size_t         _MaxCount
 size_t __cdecl _wcsxfrm_l(
              size_t         _MaxCount,
                                      _locale_t      _Locale
 int __cdecl wcscoll(
 int __cdecl _wcscoll_l(
     _locale_t      _Locale
 int __cdecl _wcsicoll(
 int __cdecl _wcsicoll_l(
     _locale_t      _Locale
 int __cdecl _wcsncoll(
                           size_t         _MaxCount
 int __cdecl _wcsncoll_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
 int __cdecl _wcsnicoll(
                           size_t         _MaxCount
 int __cdecl _wcsnicoll_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
#line 565 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsdup" ". See online help for details."))
     wchar_t* __cdecl wcsdup(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsicmp" ". See online help for details."))
     int __cdecl wcsicmp(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsnicmp" ". See online help for details."))
     int __cdecl wcsnicmp(
                               size_t         _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsnset" ". See online help for details."))
     wchar_t* __cdecl wcsnset(
         wchar_t* _String,
                                 wchar_t  _Value,
                                 size_t   _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsrev" ". See online help for details."))
     wchar_t* __cdecl wcsrev(
         wchar_t* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsset" ". See online help for details."))
     wchar_t* __cdecl wcsset(
         wchar_t* _String,
              wchar_t  _Value
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcslwr" ". See online help for details."))
     wchar_t* __cdecl wcslwr(
         wchar_t* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsupr" ". See online help for details."))
     wchar_t* __cdecl wcsupr(
         wchar_t* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsicoll" ". See online help for details."))
     int __cdecl wcsicoll(
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
     errno_t __cdecl strcpy_s(
         char*       _Destination,
                                 rsize_t     _SizeInBytes,
                               char const* _Source
     errno_t __cdecl strcat_s(
         char*       _Destination,
                                  char const* _Source
     errno_t __cdecl strerror_s(
         char*  _Buffer,
                                 int    _ErrorNumber);
     errno_t __cdecl strncat_s(
         char*       _Destination,
              char const* _Source,
                                    rsize_t     _MaxCount
     errno_t __cdecl strncpy_s(
         char*       _Destination,
                                 rsize_t     _MaxCount
     char*  __cdecl strtok_s(
                         char*       _String,
                                char const* _Delimiter,
          char**      _Context
 void* __cdecl _memccpy(
     void*       _Dst,
                                  void const* _Src,
                                  int         _Val,
                                  size_t      _MaxCount
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "strcat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strcat( char *_Destination, char const* _Source);
int __cdecl strcmp(
     char const* _Str1,
     char const* _Str2
 int __cdecl _strcmpi(
     char const* _String1,
     char const* _String2
 int __cdecl strcoll(
 int __cdecl _strcoll_l(
       char const* _String2,
     _locale_t   _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strcpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strcpy( char *_Destination, char const* _Source);
 size_t __cdecl strcspn(
     char const* _Str,
     char const* _Control
 __declspec(allocator) char* __cdecl _strdup(
     char const* _Source
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_strerror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char*  __cdecl _strerror(
     char const* _ErrorMessage
 errno_t __cdecl _strerror_s(
     char*       _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl strerror(
     int _ErrorMessage
 int __cdecl _stricmp(
 int __cdecl _stricoll(
 int __cdecl _stricoll_l(
     _locale_t   _Locale
 int __cdecl _stricmp_l(
     _locale_t   _Locale
size_t __cdecl strlen(
     char const* _Str
 errno_t __cdecl _strlwr_s(
     char*  _String,
                         size_t _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strlwr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strlwr( char *_String);
 errno_t __cdecl _strlwr_s_l(
     char*     _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strlwr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strlwr_l( char *_String, _locale_t _Locale);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strncat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strncat( char *_Destination, char const* _Source, size_t _Count);
 int __cdecl strncmp(
     char const* _Str1,
     char const* _Str2,
                           size_t      _MaxCount
 int __cdecl _strnicmp(
                           size_t      _MaxCount
 int __cdecl _strnicmp_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 int __cdecl _strnicoll(
                           size_t      _MaxCount
 int __cdecl _strnicoll_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 int __cdecl _strncoll(
                           size_t      _MaxCount
 int __cdecl _strncoll_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 size_t __cdecl __strncnt(
     char const* _String,
                        size_t      _Count
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strncpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strncpy( char *_Destination, char const* _Source, size_t _Count);
 size_t __cdecl strnlen(
                           size_t      _MaxCount
    static __inline size_t __cdecl strnlen_s(
                               size_t      _MaxCount
        return _String == 0 ? 0 : strnlen(_String, _MaxCount);
 errno_t __cdecl _strnset_s(
     char*  _String,
                                int    _Value,
                                size_t _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strnset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strnset( char *_Destination, int _Value, size_t _Count);
 char * __cdecl strpbrk(
     char const* _Str,
 char* __cdecl _strrev(
     char* _Str
 errno_t __cdecl _strset_s(
     char*  _Destination,
                                    size_t _DestinationSize,
                                    int    _Value
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strset( char *_Destination, int _Value);
 size_t __cdecl strspn(
     char const* _Str,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "strtok_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl strtok(
     char*       _String,
 errno_t __cdecl _strupr_s(
     char*  _String,
                         size_t _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strupr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strupr( char *_String);
 errno_t __cdecl _strupr_s_l(
     char*     _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strupr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strupr_l( char *_String, _locale_t _Locale);
 size_t __cdecl strxfrm(
      char*       _Destination,
               size_t      _MaxCount
 size_t __cdecl _strxfrm_l(
      char*       _Destination,
               size_t      _MaxCount,
                                      _locale_t   _Locale
#line 528 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strdup" ". See online help for details."))
     char* __cdecl strdup(
         char const* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strcmpi" ". See online help for details."))
     int __cdecl strcmpi(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_stricmp" ". See online help for details."))
     int __cdecl stricmp(
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strlwr" ". See online help for details."))
     char* __cdecl strlwr(
         char* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strnicmp" ". See online help for details."))
     int __cdecl strnicmp(
                               size_t      _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strnset" ". See online help for details."))
     char* __cdecl strnset(
         char*  _String,
                                 int    _Value,
                                 size_t _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strrev" ". See online help for details."))
     char* __cdecl strrev(
         char* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strset" ". See online help for details."))
    char* __cdecl strset(
         char* _String,
              int   _Value);
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strupr" ". See online help for details."))
     char* __cdecl strupr(
         char* _String
__pragma(pack(pop))
#line 4 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Source:
#include <stdlib.h>
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conffix.h"
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
 __declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
     size_t _Count,
     size_t _Size
void* __cdecl calloc(
      size_t _Count,
      size_t _Size
 int __cdecl _callnewh(
     size_t _Size
void* __cdecl _expand(
               void*  _Block,
      size_t _Size
void __cdecl _free_base(
      void* _Block
void __cdecl free(
      void* _Block
void* __cdecl _malloc_base(
     size_t _Size
void* __cdecl malloc(
      size_t _Size
size_t __cdecl _msize_base(
     void* _Block
size_t __cdecl _msize(
     void* _Block
void* __cdecl _realloc_base(
       void*  _Block,
                                size_t _Size
void* __cdecl realloc(
      void*  _Block,
             size_t _Size
void* __cdecl _recalloc_base(
      void*  _Block,
                               size_t _Count,
                               size_t _Size
void* __cdecl _recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size
void __cdecl _aligned_free(
      void* _Block
void* __cdecl _aligned_malloc(
      size_t _Size,
                        size_t _Alignment
void* __cdecl _aligned_offset_malloc(
      size_t _Size,
                        size_t _Alignment,
                        size_t _Offset
size_t __cdecl _aligned_msize(
     void*  _Block,
              size_t _Alignment,
              size_t _Offset
void* __cdecl _aligned_offset_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_offset_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment
void* __cdecl _aligned_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment
#line 225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
#pragma once
#line 26 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
 extern unsigned long  __cdecl __threadid(void);
 extern uintptr_t __cdecl __threadhandle(void);
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
    typedef int (__cdecl* _CoreCrtSecureSearchSortCompareFunction)(void*, void const*, void const*);
    typedef int (__cdecl* _CoreCrtNonSecureSearchSortCompareFunction)(void const*, void const*);
     void* __cdecl bsearch_s(
                                                       void const* _Key,
         void const* _Base,
                                                       rsize_t     _NumOfElements,
                                                       rsize_t     _SizeOfElements,
                           _CoreCrtSecureSearchSortCompareFunction _CompareFunction,
                                                   void*       _Context
     void __cdecl qsort_s(
         void*   _Base,
                                                        void*   _Context
 void* __cdecl bsearch(
                                                   void const* _Key,
     void const* _Base,
                    _CoreCrtNonSecureSearchSortCompareFunction _CompareFunction
 void __cdecl qsort(
     void*  _Base,
 void* __cdecl _lfind_s(
                                                      void const*   _Key,
     void const*   _Base,
                                                   unsigned int* _NumOfElements,
                                                      void*         _Context
 void* __cdecl _lfind(
                                                      void const*   _Key,
     void const*   _Base,
                                                      unsigned int  _SizeOfElements,
 void* __cdecl _lsearch_s(
                                                            void const*   _Key,
     void*         _Base,
                                                            void*         _Context
 void* __cdecl _lsearch(
                                                            void const*   _Key,
     void*         _Base,
#line 185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lfind" ". See online help for details."))
     void* __cdecl lfind(
                                                          void const*   _Key,
         void const*   _Base,
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lsearch" ". See online help for details."))
     void* __cdecl lsearch(
                                                               void const*   _Key,
         void*         _Base,
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
#pragma once
     errno_t __cdecl _itow_s(
                                 int      _Value,
         wchar_t* _Buffer,
                                 size_t   _BufferCount,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _itow(int _Value, wchar_t *_Buffer, int _Radix);
     errno_t __cdecl _ltow_s(
                                 long     _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ltow(long _Value, wchar_t *_Buffer, int _Radix);
     errno_t __cdecl _ultow_s(
                                 unsigned long _Value,
         wchar_t*      _Buffer,
                                 int           _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ultow(unsigned long _Value, wchar_t *_Buffer, int _Radix);
     double __cdecl wcstod(
          wchar_t**      _EndPtr
     double __cdecl _wcstod_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     long __cdecl wcstol(
          wchar_t**      _EndPtr,
                             int            _Radix
     long __cdecl _wcstol_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     long long __cdecl wcstoll(
          wchar_t**      _EndPtr,
                             int            _Radix
     long long __cdecl _wcstoll_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned long __cdecl wcstoul(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned long __cdecl _wcstoul_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned long long __cdecl wcstoull(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned long long __cdecl _wcstoull_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     long double __cdecl wcstold(
          wchar_t**      _EndPtr
     long double __cdecl _wcstold_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     float __cdecl wcstof(
          wchar_t**      _EndPtr
     float __cdecl _wcstof_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     double __cdecl _wtof(
     double __cdecl _wtof_l(
         _locale_t      _Locale
     int __cdecl _wtoi(
     int __cdecl _wtoi_l(
         _locale_t      _Locale
     long __cdecl _wtol(
     long __cdecl _wtol_l(
         _locale_t      _Locale
     long long __cdecl _wtoll(
     long long __cdecl _wtoll_l(
         _locale_t      _Locale
     errno_t __cdecl _i64tow_s(
                                 __int64  _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     wchar_t* __cdecl _i64tow(
                           __int64  _Value,
          wchar_t* _Buffer,
                           int      _Radix
     errno_t __cdecl _ui64tow_s(
                                 unsigned __int64 _Value,
         wchar_t*         _Buffer,
                                 int              _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     wchar_t* __cdecl _ui64tow(
          wchar_t*         _Buffer,
                           int              _Radix
     __int64 __cdecl _wtoi64(
     __int64 __cdecl _wtoi64_l(
         _locale_t      _Locale
     __int64 __cdecl _wcstoi64(
          wchar_t**      _EndPtr,
                             int            _Radix
     __int64 __cdecl _wcstoi64_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned __int64 __cdecl _wcstoui64(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned __int64 __cdecl _wcstoui64_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     __declspec(allocator) wchar_t* __cdecl _wfullpath(
         wchar_t*       _Buffer,
                                   wchar_t const* _Path,
                                     size_t         _BufferCount
     errno_t __cdecl _wmakepath_s(
         wchar_t*       _Buffer,
                           wchar_t const* _Drive,
                           wchar_t const* _Dir,
                           wchar_t const* _Filename,
                           wchar_t const* _Ext
#line 361 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wmakepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wmakepath( wchar_t *_Buffer, wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext);
     void __cdecl _wperror(
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsplitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     void __cdecl _wsplitpath(
                           wchar_t const* _FullPath,
          wchar_t*       _Drive,
          wchar_t*       _Dir,
          wchar_t*       _Filename,
          wchar_t*       _Ext
     errno_t __cdecl _wsplitpath_s(
            wchar_t*       _Drive,
                                       size_t         _DriveCount,
              wchar_t*       _Dir,
                                       size_t         _DirCount,
         wchar_t*       _Filename,
                                       size_t         _FilenameCount,
              wchar_t*       _Ext,
                                       size_t         _ExtCount
         errno_t __cdecl _wdupenv_s(
              wchar_t**      _Buffer,
        size_t*        _BufferCount,
        wchar_t const* _VarName
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wdupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         wchar_t* __cdecl _wgetenv(
         errno_t __cdecl _wgetenv_s(
                                        size_t*        _RequiredCount,
             wchar_t*       _Buffer,
#line 438 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
         int __cdecl _wputenv(
             wchar_t const* _EnvString
         errno_t __cdecl _wputenv_s(
             wchar_t const* _Name,
             wchar_t const* _Value
         errno_t __cdecl _wsearchenv_s(
                                   wchar_t const* _VarName,
             wchar_t*       _Buffer,
                                     size_t         _BufferCount
        __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsearchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wsearchenv(wchar_t const* _Filename, wchar_t const* _VarName, wchar_t *_ResultPath);
         int __cdecl _wsystem(
             wchar_t const* _Command
__pragma(pack(pop))
#line 16 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#pragma once
#line 29 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 43 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 71 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 79 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
__pragma(pack(pop))
#line 17 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 void __cdecl _swab(
      char* _Buf1,
      char* _Buf2,
        int   _SizeInBytes
     __declspec(noreturn) void __cdecl exit( int _Code);
     __declspec(noreturn) void __cdecl _exit( int _Code);
     __declspec(noreturn) void __cdecl _Exit( int _Code);
     __declspec(noreturn) void __cdecl quick_exit( int _Code);
     __declspec(noreturn) void __cdecl abort(void);
 unsigned int __cdecl _set_abort_behavior(
     unsigned int _Flags,
     unsigned int _Mask
    typedef int (__cdecl* _onexit_t)(void);
#line 117 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
    int       __cdecl atexit(void (__cdecl*)(void));
    _onexit_t __cdecl _onexit( _onexit_t _Func);
int __cdecl at_quick_exit(void (__cdecl*)(void));
    typedef void (__cdecl* _purecall_handler)(void);
    typedef void (__cdecl* _invalid_parameter_handler)(
        wchar_t const*,
        wchar_t const*,
        wchar_t const*,
        unsigned int,
        uintptr_t
     _purecall_handler __cdecl _set_purecall_handler(
         _purecall_handler _Handler
     _purecall_handler __cdecl _get_purecall_handler(void);
     _invalid_parameter_handler __cdecl _set_invalid_parameter_handler(
         _invalid_parameter_handler _Handler
     _invalid_parameter_handler __cdecl _get_invalid_parameter_handler(void);
     _invalid_parameter_handler __cdecl _set_thread_local_invalid_parameter_handler(
     _invalid_parameter_handler __cdecl _get_thread_local_invalid_parameter_handler(void);
#line 199 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
  int __cdecl _set_error_mode( int _Mode);
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __sys_errlist(void);
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int * __cdecl __sys_nerr(void);
     void __cdecl perror( char const* _ErrMsg);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_pgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  char**    __cdecl __p__pgmptr (void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_wpgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  wchar_t** __cdecl __p__wpgmptr(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_fmode" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  int*      __cdecl __p__fmode  (void);
#line 253 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 errno_t __cdecl _get_pgmptr ( char**    _Value);
 errno_t __cdecl _get_wpgmptr( wchar_t** _Value);
 errno_t __cdecl _set_fmode  (              int       _Mode );
 errno_t __cdecl _get_fmode  (             int*      _PMode);
typedef struct _div_t
    int quot;
    int rem;
} div_t;
typedef struct _ldiv_t
    long quot;
    long rem;
} ldiv_t;
typedef struct _lldiv_t
    long long quot;
    long long rem;
} lldiv_t;
 int       __cdecl abs   ( int       _Number);
 long      __cdecl labs  ( long      _Number);
 long long __cdecl llabs ( long long _Number);
 __int64   __cdecl _abs64( __int64   _Number);
 unsigned short   __cdecl _byteswap_ushort( unsigned short   _Number);
 unsigned long    __cdecl _byteswap_ulong ( unsigned long    _Number);
 unsigned __int64 __cdecl _byteswap_uint64( unsigned __int64 _Number);
  div_t   __cdecl div  ( int       _Numerator,  int       _Denominator);
  ldiv_t  __cdecl ldiv ( long      _Numerator,  long      _Denominator);
  lldiv_t __cdecl lldiv( long long _Numerator,  long long _Denominator);
#pragma warning (push)
#pragma warning (disable:6540)
unsigned int __cdecl _rotl(
     unsigned int _Value,
     int          _Shift
unsigned long __cdecl _lrotl(
     int           _Shift
unsigned __int64 __cdecl _rotl64(
     int              _Shift
unsigned int __cdecl _rotr(
     int          _Shift
unsigned long __cdecl _lrotr(
     int           _Shift
unsigned __int64 __cdecl _rotr64(
     int              _Shift
#pragma warning (pop)
 void __cdecl srand( unsigned int _Seed);
  int __cdecl rand(void);
#line 380 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
    #pragma pack(push, 4)
    typedef struct
        unsigned char ld[10];
    } _LDOUBLE;
    #pragma pack(pop)
#line 410 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
typedef struct
    double x;
} _CRT_DOUBLE;
typedef struct
    float f;
} _CRT_FLOAT;
typedef struct
    long double x;
} _LONGDOUBLE;
typedef struct
    unsigned char ld12[12];
} _LDBL12;
#pragma pack(pop)
                     double    __cdecl atof   ( char const* _String);
   int       __cdecl atoi   ( char const* _String);
                     long      __cdecl atol   ( char const* _String);
                     long long __cdecl atoll  ( char const* _String);
                     __int64   __cdecl _atoi64( char const* _String);
  double    __cdecl _atof_l  ( char const* _String,  _locale_t _Locale);
  int       __cdecl _atoi_l  ( char const* _String,  _locale_t _Locale);
  long      __cdecl _atol_l  ( char const* _String,  _locale_t _Locale);
  long long __cdecl _atoll_l ( char const* _String,  _locale_t _Locale);
  __int64   __cdecl _atoi64_l( char const* _String,  _locale_t _Locale);
  int __cdecl _atoflt ( _CRT_FLOAT*  _Result,  char const* _String);
  int __cdecl _atodbl ( _CRT_DOUBLE* _Result,  char*       _String);
  int __cdecl _atoldbl( _LDOUBLE*    _Result,  char*       _String);
 int __cdecl _atoflt_l(
     _locale_t   _Locale
 int __cdecl _atodbl_l(
       char*        _String,
     _locale_t    _Locale
 int __cdecl _atoldbl_l(
        _LDOUBLE* _Result,
       char*     _String,
     _locale_t _Locale
 float __cdecl strtof(
      char**      _EndPtr
 float __cdecl _strtof_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 double __cdecl strtod(
      char**      _EndPtr
 double __cdecl _strtod_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 long double __cdecl strtold(
      char**      _EndPtr
 long double __cdecl _strtold_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 long __cdecl strtol(
      char**      _EndPtr,
                         int         _Radix
 long __cdecl _strtol_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 long long __cdecl strtoll(
      char**      _EndPtr,
                         int         _Radix
 long long __cdecl _strtoll_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned long __cdecl strtoul(
      char**      _EndPtr,
                         int         _Radix
 unsigned long __cdecl _strtoul_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned long long __cdecl strtoull(
      char**      _EndPtr,
                         int         _Radix
 unsigned long long __cdecl _strtoull_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 __int64 __cdecl _strtoi64(
      char**      _EndPtr,
                         int         _Radix
 __int64 __cdecl _strtoi64_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned __int64 __cdecl _strtoui64(
      char**      _EndPtr,
                         int         _Radix
 unsigned __int64 __cdecl _strtoui64_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 errno_t __cdecl _itoa_s(
                             int    _Value,
     char*  _Buffer,
                             int    _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _itoa(int _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _ltoa_s(
                             long   _Value,
     char*  _Buffer,
                             int    _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ltoa(long _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _ultoa_s(
     char*         _Buffer,
                             int           _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ultoa(unsigned long _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _i64toa_s(
                             __int64 _Value,
     char*   _Buffer,
                             int     _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _i64toa(
                       __int64 _Value,
      char*   _Buffer,
                       int     _Radix
 errno_t __cdecl _ui64toa_s(
     char*            _Buffer,
                             int              _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ui64toa(
      char*            _Buffer,
                       int              _Radix
 errno_t __cdecl _ecvt_s(
     char* _Buffer,
      double                       _Value,
      int                          _DigitCount,
     int*                         _PtDec,
     int*                         _PtSign
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ecvt(
      double _Value,
      int    _DigitCount,
     int*   _PtDec,
     int*   _PtSign
 errno_t __cdecl _fcvt_s(
     char*  _Buffer,
                             double _Value,
                             int    _FractionalDigitCount,
                            int*   _PtDec,
                            int*   _PtSign
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _fcvt(
      double _Value,
     int*   _PtDec,
     int*   _PtSign
 errno_t __cdecl _gcvt_s(
     char*  _Buffer,
                             double _Value,
                             int    _DigitCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_gcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _gcvt(
                       double _Value,
                       int    _DigitCount,
      char*  _Buffer
#line 838 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
     int __cdecl ___mb_cur_max_func(void);
     int __cdecl ___mb_cur_max_l_func(_locale_t _Locale);
 int __cdecl mblen(
      char const* _Ch,
                                            size_t      _MaxCount
 int __cdecl _mblen_l(
      char const* _Ch,
                                            size_t      _MaxCount,
                                        _locale_t   _Locale
 size_t __cdecl _mbstrlen(
     char const* _String
 size_t __cdecl _mbstrlen_l(
     _locale_t   _Locale
 size_t __cdecl _mbstrnlen(
       size_t      _MaxCount
 size_t __cdecl _mbstrnlen_l(
         size_t      _MaxCount,
     _locale_t   _Locale
 int __cdecl mbtowc(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                     size_t      _SrcSizeInBytes
 int __cdecl _mbtowc_l(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                     size_t      _SrcSizeInBytes,
                                 _locale_t   _Locale
 errno_t __cdecl mbstowcs_s(
                                                     size_t*     _PtNumOfCharConverted,
     wchar_t*    _DstBuf,
                                    char const* _SrcBuf,
                                                          size_t      _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "mbstowcs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl mbstowcs( wchar_t *_Dest, char const* _Source, size_t _MaxCount);
 errno_t __cdecl _mbstowcs_s_l(
     wchar_t*    _DstBuf,
                                                          size_t      _MaxCount,
                                                      _locale_t   _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_mbstowcs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _mbstowcs_l( wchar_t *_Dest, char const* _Source, size_t _MaxCount, _locale_t _Locale);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wctomb_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl wctomb(
     char*   _MbCh,
                               wchar_t _WCh
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctomb_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl _wctomb_l(
      char*     _MbCh,
                         wchar_t   _WCh,
                     _locale_t _Locale
     errno_t __cdecl wctomb_s(
                                                        int*    _SizeConverted,
         char*   _MbCh,
                                                             wchar_t _WCh
 errno_t __cdecl _wctomb_s_l(
     char*     _MbCh,
                                 wchar_t   _WCh,
                             _locale_t _Locale);
 errno_t __cdecl wcstombs_s(
     char*          _Dst,
        size_t         _DstSizeInBytes,
        wchar_t const* _Src,
        size_t         _MaxCountInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstombs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl wcstombs( char *_Dest, wchar_t const* _Source, size_t _MaxCount);
 errno_t __cdecl _wcstombs_s_l(
     char*          _Dst,
        size_t         _MaxCountInBytes,
                                                               _locale_t      _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcstombs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _wcstombs_l( char *_Dest, wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale);
 __declspec(allocator) char* __cdecl _fullpath(
     char*       _Buffer,
                               char const* _Path,
                                 size_t      _BufferCount
 errno_t __cdecl _makepath_s(
     char*       _Buffer,
                       char const* _Drive,
                       char const* _Dir,
                       char const* _Filename,
                       char const* _Ext
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_makepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _makepath( char *_Buffer, char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_splitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 void __cdecl _splitpath(
                       char const* _FullPath,
      char*       _Drive,
      char*       _Dir,
      char*       _Filename,
      char*       _Ext
 errno_t __cdecl _splitpath_s(
        char*       _Drive,
                                   size_t      _DriveCount,
          char*       _Dir,
                                   size_t      _DirCount,
     char*       _Filename,
          char*       _Ext,
                                   size_t      _ExtCount
 errno_t __cdecl getenv_s(
     char*       _Buffer,
                                 rsize_t     _BufferCount,
                               char const* _VarName
 int*       __cdecl __p___argc (void);
 char***    __cdecl __p___argv (void);
 wchar_t*** __cdecl __p___wargv(void);
#line 1164 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 char***    __cdecl __p__environ (void);
 wchar_t*** __cdecl __p__wenviron(void);
#line 1181 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "_dupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl getenv(
     errno_t __cdecl _dupenv_s(
          char**      _Buffer,
     int __cdecl system(
         char const* _Command
     int __cdecl _putenv(
         char const* _EnvString
     errno_t __cdecl _putenv_s(
         char const* _Name,
         char const* _Value
     errno_t __cdecl _searchenv_s(
                               char const* _VarName,
         char*       _Buffer,
                                 size_t      _BufferCount
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_searchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _searchenv(char const* _Filename, char const* _VarName, char *_Buffer);
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetErrorMode" " " "instead. See online help for details."))
     void __cdecl _seterrormode(
         int _Mode
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Beep" " " "instead. See online help for details."))
     void __cdecl _beep(
         unsigned _Frequency,
         unsigned _Duration
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Sleep" " " "instead. See online help for details."))
     void __cdecl _sleep(
         unsigned long _Duration
    #pragma warning(disable: 4141)
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ecvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ecvt(
          double _Value,
          int    _DigitCount,
         int*   _PtDec,
         int*   _PtSign
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_fcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl fcvt(
          double _Value,
         int*   _PtDec,
         int*   _PtSign
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_gcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl gcvt(
                           double _Value,
                           int    _DigitCount,
          char*  _DstBuf
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_itoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl itoa(
                           int   _Value,
          char* _Buffer,
                           int   _Radix
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ltoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ltoa(
                           long  _Value,
          char* _Buffer,
                           int   _Radix
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_swab" ". See online help for details."))
     void __cdecl swab(
         char* _Buf1,
         char* _Buf2,
                                    int   _SizeInBytes
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ultoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ultoa(
          char*         _Buffer,
                           int           _Radix
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_putenv" ". See online help for details."))
     int __cdecl putenv(
    _onexit_t __cdecl onexit( _onexit_t _Func);
__pragma(pack(pop))
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout: conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
#include <stdlib.h>
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
#define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
int main() {
        int i;
        for(i = 0; i < 256; i++) if (XOR(islower(i), ISLOWER(i)) || toupper(i) != TOUPPER(i)) exit(2);
        exit(0);
  return 0;
                          Pushing language C
                          Popping language C
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl  -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.exe   -O2 -MT -wd4996 -Qopenmp   /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.o
Testing executable /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.exe to see if it can be run
Executing: /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.exe
              Defined "STDC_HEADERS" to "1"
TEST checkStat from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:138)
TESTING: checkStat from config.headers(config/BuildSystem/config/headers.py:138)
  Checks whether stat file-mode macros are broken, and defines STAT_MACROS_BROKEN if they are
Source:
#include <sys/types.h>
#include <sys/stat.h>
#if defined(S_ISBLK) && defined(S_IFDIR)
# if S_ISBLK (S_IFDIR)
  You lose.
# endif
#endif
#if defined(S_ISBLK) && defined(S_IFCHR)
# if S_ISBLK (S_IFCHR)
  You lose.
# endif
#endif
#if defined(S_ISLNK) && defined(S_IFREG)
# if S_ISLNK (S_IFREG)
  You lose.
# endif
#endif
#if defined(S_ISSOCK) && defined(S_IFREG)
# if S_ISSOCK (S_IFREG)
  You lose.
# endif
#endif
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/types.h"
#pragma once
    typedef unsigned short _ino_t;
        typedef _ino_t ino_t;
    typedef unsigned int _dev_t;
        typedef _dev_t dev_t;
    typedef long _off_t;
        typedef _off_t off_t;
#line 5 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/stat.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/stat.h"
#pragma warning(push)
#pragma warning(disable: 4820)
struct _stat32
    _dev_t         st_dev;
    _ino_t         st_ino;
    unsigned short st_mode;
    short          st_nlink;
    short          st_uid;
    short          st_gid;
    _dev_t         st_rdev;
    _off_t         st_size;
    __time32_t     st_atime;
    __time32_t     st_mtime;
    __time32_t     st_ctime;
struct _stat32i64
    _dev_t         st_dev;
    _ino_t         st_ino;
    short          st_nlink;
    short          st_uid;
    short          st_gid;
    _dev_t         st_rdev;
    __int64        st_size;
struct _stat64i32
    _dev_t         st_dev;
    _ino_t         st_ino;
    short          st_nlink;
    short          st_uid;
    short          st_gid;
    _dev_t         st_rdev;
    _off_t         st_size;
    __time64_t     st_atime;
    __time64_t     st_mtime;
    __time64_t     st_ctime;
struct _stat64
    _dev_t         st_dev;
    _ino_t         st_ino;
    short          st_nlink;
    short          st_uid;
    short          st_gid;
    _dev_t         st_rdev;
    __int64        st_size;
    struct stat
        _dev_t         st_dev;
        _ino_t         st_ino;
        short          st_nlink;
        short          st_uid;
        short          st_gid;
        _dev_t         st_rdev;
        _off_t         st_size;
        time_t         st_atime;
        time_t         st_mtime;
        time_t         st_ctime;
#line 119 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/stat.h"
#line 129 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/stat.h"
#line 152 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/stat.h"
 int __cdecl _fstat32(
      int             _FileHandle,
     struct _stat32* _Stat
 int __cdecl _fstat32i64(
      int                _FileHandle,
     struct _stat32i64* _Stat
 int __cdecl _fstat64i32(
      int                _FileHandle,
     struct _stat64i32* _Stat
 int __cdecl _fstat64(
      int             _FileHandle,
     struct _stat64* _Stat
 int __cdecl _stat32(
     char const*     _FileName,
 int __cdecl _stat32i64(
 int __cdecl _stat64i32(
 int __cdecl _stat64(
 int __cdecl _wstat32(
 int __cdecl _wstat32i64(
 int __cdecl _wstat64i32(
 int __cdecl _wstat64(
#line 233 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/stat.h"
        static __inline int __cdecl fstat(int const _FileHandle, struct stat* const _Stat)
            typedef char __static_assert_t[(sizeof(struct stat) == sizeof(struct _stat64i32)) != 0];
            return _fstat64i32(_FileHandle, (struct _stat64i32*)_Stat);
        static __inline int __cdecl stat(char const* const _FileName, struct stat* const _Stat)
            return _stat64i32(_FileName, (struct _stat64i32*)_Stat);
#pragma warning(pop)
__pragma(pack(pop))
#line 6 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
TEST checkSysWait from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:173)
TESTING: checkSysWait from config.headers(config/BuildSystem/config/headers.py:173)
  Check for POSIX.1 compatible sys/wait.h, and defines HAVE_SYS_WAIT_H if found
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(5): catastrophic error: cannot open source file "sys/wait.h"
  #include <sys/wait.h>
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c (code 4)
Possible ERROR while running compiler: exit code 1024
stdout:
conftest.c
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c (code 4)Source:
#ifndef WEXITSTATUS
#define WEXITSTATUS(stat_val) ((unsigned)(stat_val) >> 8)
#endif
#ifndef WIFEXITED
#define WIFEXITED(stat_val) (((stat_val) & 255) == 0)
#endif
int main() {
    int s;
    wait (&s);
    s = WIFEXITED (s) ? WEXITSTATUS (s) : 1;
  return 0;
TEST checkTime from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:195)
TESTING: checkTime from config.headers(config/BuildSystem/config/headers.py:195)
  Checks if you can safely include both <sys/time.h> and <time.h>, and if so defines TIME_WITH_SYS_TIME
Checking for header: time.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wtime.h"
#pragma once
struct tm
    int tm_sec;
    int tm_min;
    int tm_hour;
    int tm_mday;
    int tm_mon;
    int tm_year;
    int tm_wday;
    int tm_yday;
    int tm_isdst;
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wasctime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wasctime(
     struct tm const* _Tm
 errno_t __cdecl _wasctime_s(
      wchar_t*         _Buffer,
                                         size_t           _SizeInWords,
 size_t __cdecl wcsftime(
      wchar_t*         _Buffer,
                            wchar_t const*   _Format,
 size_t __cdecl _wcsftime_l(
      wchar_t*         _Buffer,
                              struct tm const* _Tm,
                          _locale_t        _Locale
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wctime32(
     __time32_t const* _Time
 errno_t __cdecl _wctime32_s(
      wchar_t*          _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wctime64(
     __time64_t const* _Time
 errno_t __cdecl _wctime64_s(
      wchar_t*          _Buffer,
                                                      __time64_t const* _Time);
 errno_t __cdecl _wstrdate_s(
      wchar_t* _Buffer,
        size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wstrdate_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wstrdate( wchar_t *_Buffer);
 errno_t __cdecl _wstrtime_s(
      wchar_t* _Buffer,
        size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wstrtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wstrtime( wchar_t *_Buffer);
    #pragma warning(disable: 4996)
#line 183 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wtime.h"
        static __inline wchar_t * __cdecl _wctime(
             time_t const* const _Time)
            return _wctime64(_Time);
        static __inline errno_t __cdecl _wctime_s(
               wchar_t*      const _Buffer,
                                                            size_t        const _SizeInWords,
            return _wctime64_s(_Buffer, _SizeInWords, _Time);
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
typedef long clock_t;
struct _timespec32
    __time32_t tv_sec;
    long       tv_nsec;
struct _timespec64
    __time64_t tv_sec;
    long       tv_nsec;
    struct timespec
        time_t tv_sec;
        long   tv_nsec;
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_daylight" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int* __cdecl __daylight(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_dstbias" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 long* __cdecl __dstbias(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_timezone" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 long* __cdecl __timezone(void);
  __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_tzname" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char** __cdecl __tzname(void);
 errno_t __cdecl _get_daylight(
     int* _Daylight
 errno_t __cdecl _get_dstbias(
     long* _DaylightSavingsBias
 errno_t __cdecl _get_timezone(
     long* _TimeZone
 errno_t __cdecl _get_tzname(
                            size_t* _ReturnValue,
     char*   _Buffer,
                             size_t  _SizeInBytes,
                             int     _Index
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "asctime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl asctime(
     errno_t __cdecl asctime_s(
          char*            _Buffer,
 clock_t __cdecl clock(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ctime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ctime32(
 errno_t __cdecl _ctime32_s(
      char*             _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ctime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ctime64(
 errno_t __cdecl _ctime64_s(
      char*             _Buffer,
 double __cdecl _difftime32(
     __time32_t _Time1,
     __time32_t _Time2
 double __cdecl _difftime64(
     __time64_t _Time1,
     __time64_t _Time2
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_gmtime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _gmtime32(
 errno_t __cdecl _gmtime32_s(
     struct tm*        _Tm,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_gmtime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _gmtime64(
 errno_t __cdecl _gmtime64_s(
     struct tm*        _Tm,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_localtime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _localtime32(
 errno_t __cdecl _localtime32_s(
     struct tm*        _Tm,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_localtime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _localtime64(
 errno_t __cdecl _localtime64_s(
     struct tm*        _Tm,
 __time32_t __cdecl _mkgmtime32(
     struct tm* _Tm
 __time64_t __cdecl _mkgmtime64(
     struct tm* _Tm
 __time32_t __cdecl _mktime32(
     struct tm* _Tm
 __time64_t __cdecl _mktime64(
     struct tm* _Tm
 size_t __cdecl strftime(
      char*            _Buffer,
      char const*      _Format,
 size_t __cdecl _strftime_l(
          char*            _Buffer,
                              size_t           _MaxSize,
                          _locale_t        _Locale
 errno_t __cdecl _strdate_s(
      char*  _Buffer,
        size_t _SizeInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strdate_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strdate( char *_Buffer);
 errno_t __cdecl _strtime_s(
      char*  _Buffer,
        size_t _SizeInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strtime( char *_Buffer);
 __time32_t __cdecl _time32(
     __time32_t* _Time
 __time64_t __cdecl _time64(
     __time64_t* _Time
 int __cdecl _timespec32_get(
     struct _timespec32* _Ts,
      int                 _Base
 int __cdecl _timespec64_get(
     struct _timespec64* _Ts,
      int                 _Base
     void __cdecl _tzset(void);
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "GetLocalTime" " " "instead. See online help for details."))
     unsigned __cdecl _getsystime(
         struct tm* _Tm
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetLocalTime" " " "instead. See online help for details."))
     unsigned __cdecl _setsystime(
         struct tm* _Tm,
         unsigned   _Milliseconds
#line 474 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "ctime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
        static __inline char* __cdecl ctime(
            return _ctime64(_Time);
        static __inline double __cdecl difftime(
             time_t const _Time1,
             time_t const _Time2
            return _difftime64(_Time1, _Time2);
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "gmtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
        static __inline struct tm* __cdecl gmtime(
            return _gmtime64(_Time);
        __declspec(deprecated("This function or variable may be unsafe. Consider using " "localtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
        static __inline struct tm* __cdecl localtime(
            return _localtime64(_Time);
        static __inline time_t __cdecl _mkgmtime(
             struct tm* const _Tm
            return _mkgmtime64(_Tm);
        static __inline time_t __cdecl mktime(
            return _mktime64(_Tm);
        static __inline time_t __cdecl time(
             time_t* const _Time
            return _time64(_Time);
        static __inline int __cdecl timespec_get(
             struct timespec* const _Ts,
              int              const _Base
            return _timespec64_get((struct _timespec64*)_Ts, _Base);
            static __inline errno_t __cdecl ctime_s(
                  char*         const _Buffer,
                                                   size_t        const _SizeInBytes,
                return _ctime64_s(_Buffer, _SizeInBytes, _Time);
            static __inline errno_t __cdecl gmtime_s(
                 struct tm*    const _Tm,
                return _gmtime64_s(_Tm, _Time);
            static __inline errno_t __cdecl localtime_s(
                return _localtime64_s(_Tm, _Time);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_tzset" ". See online help for details."))  void __cdecl tzset(void);
__pragma(pack(pop))
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                Defined "HAVE_TIME_H" to "1"
Checking for header: sys/time.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/time.h"
  #include <sys/time.h>
Possible ERROR while running preprocessor: exit code 512
stdout:
conftest.c
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"Source:
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(4): catastrophic error: cannot open source file "sys/time.h"
stdout:
conftest.c
#include <time.h>
int main() {
struct tm *tp = 0;
if (tp);
  return 0;
TEST checkMath from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:203)
TESTING: checkMath from config.headers(config/BuildSystem/config/headers.py:203)
  Checks for the math headers and defines
Checking for header: math.h
stdout:
conftest.c
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 65 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 88 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 128 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
       struct _complex {
               double x,y;
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 65 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 88 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 128 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 137 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\math.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
#pragma warning(disable:4738)
#pragma warning(disable:4820)
    struct _exception
        int    type;
        char*  name;
        double arg1;
        double arg2;
        double retval;
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
    typedef float  float_t;
    typedef double double_t;
#line 74 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
        extern double const _HUGE;
void __cdecl _fperrraise( int _Except);
  short __cdecl _dclass( double _X);
  short __cdecl _ldclass( long double _X);
  short __cdecl _fdclass( float _X);
  int __cdecl _dsign( double _X);
  int __cdecl _ldsign( long double _X);
  int __cdecl _fdsign( float _X);
  int __cdecl _dpcomp( double _X,  double _Y);
  int __cdecl _ldpcomp( long double _X,  long double _Y);
  int __cdecl _fdpcomp( float _X,  float _Y);
  short __cdecl _dtest( double* _Px);
  short __cdecl _ldtest( long double* _Px);
  short __cdecl _fdtest( float* _Px);
 short __cdecl _d_int( double* _Px,  short _Xexp);
 short __cdecl _ld_int( long double* _Px,  short _Xexp);
 short __cdecl _fd_int( float* _Px,  short _Xexp);
 short __cdecl _dscale( double* _Px,  long _Lexp);
 short __cdecl _ldscale( long double* _Px,  long _Lexp);
 short __cdecl _fdscale( float* _Px,  long _Lexp);
 short __cdecl _dunscale( short* _Pex,  double* _Px);
 short __cdecl _ldunscale( short* _Pex,  long double* _Px);
 short __cdecl _fdunscale( short* _Pex,  float* _Px);
  short __cdecl _dexp( double* _Px,  double _Y,  long _Eoff);
  short __cdecl _ldexp( long double* _Px,  long double _Y,  long _Eoff);
  short __cdecl _fdexp( float* _Px,  float _Y,  long _Eoff);
  short __cdecl _dnorm( unsigned short* _Ps);
  short __cdecl _fdnorm( unsigned short* _Ps);
  double __cdecl _dpoly( double _X,  double const* _Tab,  int _N);
  long double __cdecl _ldpoly( long double _X,  long double const* _Tab,  int _N);
  float __cdecl _fdpoly( float _X,  float const* _Tab,  int _N);
  double __cdecl _dlog( double _X,  int _Baseflag);
  long double __cdecl _ldlog( long double _X,  int _Baseflag);
  float __cdecl _fdlog( float _X,  int _Baseflag);
  double __cdecl _dsin( double _X,  unsigned int _Qoff);
  long double __cdecl _ldsin( long double _X,  unsigned int _Qoff);
  float __cdecl _fdsin( float _X,  unsigned int _Qoff);
typedef union
    unsigned short _Sh[4];
    double _Val;
} _double_val;
typedef union
    unsigned short _Sh[2];
    float _Val;
} _float_val;
typedef union
    long double _Val;
} _ldouble_val;
typedef union
    unsigned short _Word[4];
    float _Float;
    double _Double;
    long double _Long_double;
} _float_const;
extern const _float_const _Denorm_C,  _Inf_C,  _Nan_C,  _Snan_C, _Hugeval_C;
extern const _float_const _FDenorm_C, _FInf_C, _FNan_C, _FSnan_C;
extern const _float_const _LDenorm_C, _LInf_C, _LNan_C, _LSnan_C;
extern const _float_const _Eps_C,  _Rteps_C;
extern const _float_const _FEps_C, _FRteps_C;
extern const _float_const _LEps_C, _LRteps_C;
extern const double      _Zero_C,  _Xbig_C;
extern const float       _FZero_C, _FXbig_C;
extern const long double _LZero_C, _LXbig_C;
#line 286 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
     int       __cdecl abs( int _X);
     long      __cdecl labs( long _X);
     long long __cdecl llabs( long long _X);
     double __cdecl acos( double _X);
     double __cdecl asin( double _X);
     double __cdecl atan( double _X);
     double __cdecl atan2( double _Y,  double _X);
     double __cdecl cos( double _X);
     double __cdecl cosh( double _X);
     double __cdecl exp( double _X);
      double __cdecl fabs( double _X);
     double __cdecl fmod( double _X,  double _Y);
     double __cdecl log( double _X);
     double __cdecl log10( double _X);
     double __cdecl pow( double _X,  double _Y);
     double __cdecl sin( double _X);
     double __cdecl sinh( double _X);
      double __cdecl sqrt( double _X);
     double __cdecl tan( double _X);
     double __cdecl tanh( double _X);
      double    __cdecl acosh( double _X);
      double    __cdecl asinh( double _X);
      double    __cdecl atanh( double _X);
       double    __cdecl atof( char const* _String);
       double    __cdecl _atof_l( char const* _String,  _locale_t _Locale);
      double    __cdecl _cabs( struct _complex _Complex_value);
      double    __cdecl cbrt( double _X);
      double    __cdecl ceil( double _X);
      double    __cdecl _chgsign( double _X);
      double    __cdecl copysign( double _Number,  double _Sign);
      double    __cdecl _copysign( double _Number,  double _Sign);
      double    __cdecl erf( double _X);
      double    __cdecl erfc( double _X);
      double    __cdecl exp2( double _X);
      double    __cdecl expm1( double _X);
      double    __cdecl fdim( double _X,  double _Y);
      double    __cdecl floor( double _X);
      double    __cdecl fma( double _X,  double _Y,  double _Z);
      double    __cdecl fmax( double _X,  double _Y);
      double    __cdecl fmin( double _X,  double _Y);
      double    __cdecl frexp( double _X,  int* _Y);
      double    __cdecl hypot( double _X,  double _Y);
      double    __cdecl _hypot( double _X,  double _Y);
      int       __cdecl ilogb( double _X);
      double    __cdecl ldexp( double _X,  int _Y);
      double    __cdecl lgamma( double _X);
      long long __cdecl llrint( double _X);
      long long __cdecl llround( double _X);
      double    __cdecl log1p( double _X);
      double    __cdecl log2( double _X);
      double    __cdecl logb( double _X);
      long      __cdecl lrint( double _X);
      long      __cdecl lround( double _X);
    int __cdecl _matherr( struct _exception* _Except);
      double __cdecl modf( double _X,  double* _Y);
      double __cdecl nan( char const* _X);
      double __cdecl nearbyint( double _X);
      double __cdecl nextafter( double _X,  double _Y);
      double __cdecl nexttoward( double _X,  long double _Y);
      double __cdecl remainder( double _X,  double _Y);
      double __cdecl remquo( double _X,  double _Y,  int* _Z);
      double __cdecl rint( double _X);
      double __cdecl round( double _X);
      double __cdecl scalbln( double _X,  long _Y);
      double __cdecl scalbn( double _X,  int _Y);
      double __cdecl tgamma( double _X);
      double __cdecl trunc( double _X);
      double __cdecl _j0( double _X );
      double __cdecl _j1( double _X );
      double __cdecl _jn(int _X,  double _Y);
      double __cdecl _y0( double _X);
      double __cdecl _y1( double _X);
      double __cdecl _yn( int _X,  double _Y);
      float     __cdecl acoshf( float _X);
      float     __cdecl asinhf( float _X);
      float     __cdecl atanhf( float _X);
      float     __cdecl cbrtf( float _X);
      float     __cdecl _chgsignf( float _X);
      float     __cdecl copysignf( float _Number,  float _Sign);
      float     __cdecl _copysignf( float _Number,  float _Sign);
      float     __cdecl erff( float _X);
      float     __cdecl erfcf( float _X);
      float     __cdecl expm1f( float _X);
      float     __cdecl exp2f( float _X);
      float     __cdecl fdimf( float _X,  float _Y);
      float     __cdecl fmaf( float _X,  float _Y,  float _Z);
      float     __cdecl fmaxf( float _X,  float _Y);
      float     __cdecl fminf( float _X,  float _Y);
      float     __cdecl _hypotf( float _X,  float _Y);
      int       __cdecl ilogbf( float _X);
      float     __cdecl lgammaf( float _X);
      long long __cdecl llrintf( float _X);
      long long __cdecl llroundf( float _X);
      float     __cdecl log1pf( float _X);
      float     __cdecl log2f( float _X);
      float     __cdecl logbf( float _X);
      long      __cdecl lrintf( float _X);
      long      __cdecl lroundf( float _X);
      float     __cdecl nanf( char const* _X);
      float     __cdecl nearbyintf( float _X);
      float     __cdecl nextafterf( float _X,  float _Y);
      float     __cdecl nexttowardf( float _X,  long double _Y);
      float     __cdecl remainderf( float _X,  float _Y);
      float     __cdecl remquof( float _X,  float _Y,  int* _Z);
      float     __cdecl rintf( float _X);
      float     __cdecl roundf( float _X);
      float     __cdecl scalblnf( float _X,  long _Y);
      float     __cdecl scalbnf( float _X,  int _Y);
      float     __cdecl tgammaf( float _X);
      float     __cdecl truncf( float _X);
          float __cdecl _logbf( float _X);
          float __cdecl _nextafterf( float _X,  float _Y);
          int   __cdecl _finitef( float _X);
          int   __cdecl _isnanf( float _X);
          int   __cdecl _fpclassf( float _X);
          int   __cdecl _set_FMA3_enable( int _Flag);
          int   __cdecl _get_FMA3_enable(void);
#line 606 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
          float __cdecl acosf( float _X);
          float __cdecl asinf( float _X);
          float __cdecl atan2f( float _Y,  float _X);
          float __cdecl atanf( float _X);
          float __cdecl ceilf( float _X);
          float __cdecl cosf( float _X);
          float __cdecl coshf( float _X);
          float __cdecl expf( float _X);
#line 663 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
         __inline float __cdecl __MS_fabsf( float _X)
            return (float)fabs(_X);
          float __cdecl floorf( float _X);
          float __cdecl fmodf( float _X,  float _Y);
#line 695 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
     __inline float __cdecl __MS_frexpf( float _X,  int *_Y)
        return (float)frexp(_X, _Y);
     __inline float __cdecl __MS_hypotf( float _X,  float _Y)
        return _hypotf(_X, _Y);
     __inline float __cdecl __MS_ldexpf( float _X,  int _Y)
        return (float)ldexp(_X, _Y);
          float  __cdecl log10f( float _X);
          float  __cdecl logf( float _X);
          float  __cdecl modff( float _X,  float *_Y);
          float  __cdecl powf( float _X,  float _Y);
          float  __cdecl sinf( float _X);
          float  __cdecl sinhf( float _X);
          float  __cdecl sqrtf( float _X);
          float  __cdecl tanf( float _X);
          float  __cdecl tanhf( float _X);
#line 774 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
      long double __cdecl acoshl( long double _X);
     __inline long double __cdecl __MS_acosl( long double _X)
        return acos((double)_X);
      long double __cdecl asinhl( long double _X);
     __inline long double __cdecl __MS_asinl( long double _X)
        return asin((double)_X);
     __inline long double __cdecl __MS_atan2l( long double _Y,  long double _X)
        return atan2((double)_Y, (double)_X);
      long double __cdecl atanhl( long double _X);
     __inline long double __cdecl __MS_atanl( long double _X)
        return atan((double)_X);
      long double __cdecl cbrtl( long double _X);
     __inline long double __cdecl __MS_ceill( long double _X)
        return ceil((double)_X);
     __inline long double __cdecl _chgsignl( long double _X)
        return _chgsign((double)_X);
      long double __cdecl copysignl( long double _Number,  long double _Sign);
     __inline long double __cdecl _copysignl( long double _Number,  long double _Sign)
        return _copysign((double)_Number, (double)_Sign);
     __inline long double __cdecl __MS_coshl( long double _X)
        return cosh((double)_X);
     __inline long double __cdecl __MS_cosl( long double _X)
        return cos((double)_X);
      long double __cdecl erfl( long double _X);
      long double __cdecl erfcl( long double _X);
     __inline long double __cdecl __MS_expl( long double _X)
        return exp((double)_X);
      long double __cdecl exp2l( long double _X);
      long double __cdecl expm1l( long double _X);
     __inline long double __cdecl __MS_fabsl( long double _X)
        return fabs((double)_X);
      long double __cdecl fdiml( long double _X,  long double _Y);
     __inline long double __cdecl __MS_floorl( long double _X)
        return floor((double)_X);
      long double __cdecl fmal( long double _X,  long double _Y,  long double _Z);
      long double __cdecl fmaxl( long double _X,  long double _Y);
      long double __cdecl fminl( long double _X,  long double _Y);
     __inline long double __cdecl __MS_fmodl( long double _X,  long double _Y)
        return fmod((double)_X, (double)_Y);
     __inline long double __cdecl __MS_frexpl( long double _X,  int *_Y)
        return frexp((double)_X, _Y);
      int __cdecl ilogbl( long double _X);
     __inline long double __cdecl _hypotl( long double _X,  long double _Y)
        return _hypot((double)_X, (double)_Y);
     __inline long double __cdecl __MS_hypotl( long double _X,  long double _Y)
     __inline long double __cdecl __MS_ldexpl( long double _X,  int _Y)
        return ldexp((double)_X, _Y);
      long double __cdecl lgammal( long double _X);
      long long __cdecl llrintl( long double _X);
      long long __cdecl llroundl( long double _X);
     __inline long double __cdecl __MS_logl( long double _X)
        return log((double)_X);
     __inline long double __cdecl __MS_log10l( long double _X)
        return log10((double)_X);
      long double __cdecl log1pl( long double _X);
      long double __cdecl log2l( long double _X);
      long double __cdecl logbl( long double _X);
      long __cdecl lrintl( long double _X);
      long __cdecl lroundl( long double _X);
     __inline long double __cdecl __MS_modfl( long double _X,  long double* _Y)
        double _F, _I;
        _F = modf((double)_X, &_I);
        *_Y = _I;
        return _F;
      long double __cdecl nanl( char const* _X);
      long double __cdecl nearbyintl( long double _X);
      long double __cdecl nextafterl( long double _X,  long double _Y);
      long double __cdecl nexttowardl( long double _X,  long double _Y);
     __inline long double __cdecl __MS_powl( long double _X,  long double _Y)
        return pow((double)_X, (double)_Y);
      long double __cdecl remainderl( long double _X,  long double _Y);
      long double __cdecl remquol( long double _X,  long double _Y,  int* _Z);
      long double __cdecl rintl( long double _X);
      long double __cdecl roundl( long double _X);
      long double __cdecl scalblnl( long double _X,  long _Y);
      long double __cdecl scalbnl( long double _X,  int _Y);
     __inline long double __cdecl __MS_sinhl( long double _X)
        return sinh((double)_X);
     __inline long double __cdecl __MS_sinl( long double _X)
        return sin((double)_X);
     __inline long double __cdecl __MS_sqrtl( long double _X)
        return sqrt((double)_X);
     __inline long double __cdecl __MS_tanhl( long double _X)
        return tanh((double)_X);
     __inline long double __cdecl __MS_tanl( long double _X)
        return tan((double)_X);
      long double __cdecl tgammal( long double _X);
      long double __cdecl truncl( long double _X);
#line 971 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_math.h"
            extern double HUGE;
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_j0" ". See online help for details."))   double __cdecl j0( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_j1" ". See online help for details."))   double __cdecl j1( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_jn" ". See online help for details."))   double __cdecl jn( int _X,  double _Y);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_y0" ". See online help for details."))   double __cdecl y0( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_y1" ". See online help for details."))   double __cdecl y1( double _X);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_yn" ". See online help for details."))   double __cdecl yn( int _X,  double _Y);
__pragma(pack(pop))
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\math.h"
#line 142 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 176 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 226 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 31 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 39 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 59 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_define.h"
#line 231 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 245 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 271 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 285 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 307 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 354 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 370 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern int fpclassifyf    ( float              __x ) ;
 extern int fpclassify     ( double           __x ) ;
 extern int fpclassifyd    ( double             __x ) ;
 extern int fpclassifyl    ( long double            __x ) ;
 extern int isinff         ( float              __x ) ;
 extern int isinf          ( double           __x ) ;
 extern int isinfd         ( double             __x ) ;
 extern int isinfl         ( long double            __x ) ;
 extern int isnanf         ( float              __x ) ;
 extern int isnan          ( double           __x ) ;
 extern int isnand         ( double             __x ) ;
 extern int isnanl         ( long double            __x ) ;
 extern int isnormalf      ( float              __x ) ;
 extern int isnormal       ( double           __x ) ;
 extern int isnormald      ( double             __x ) ;
 extern int isnormall      ( long double            __x ) ;
 extern int isfinitef      ( float              __x ) ;
 extern int isfinite       ( double           __x ) ;
 extern int isfinited      ( double             __x ) ;
 extern int isfinitel      ( long double            __x ) ;
 extern int finitef        ( float              __x ) ;
 extern int finite         ( double             __x ) ;
 extern int finited        ( double             __x ) ;
 extern int finitel        ( long double            __x ) ;
 extern int signbitf       ( float              __x ) ;
 extern int signbit        ( double             __x ) ;
 extern int signbitd       ( double             __x ) ;
 extern int signbitl       ( long double            __x ) ;
 extern int __fpclassifyf  ( float              __x ) ;
 extern int __fpclassify   ( double           __x ) ;
 extern int __fpclassifyd  ( double             __x ) ;
 extern int __fpclassifyl  ( long double            __x ) ;
 extern int __isinff       ( float              __x ) ;
 extern int __isinf        ( double           __x ) ;
 extern int __isinfd       ( double             __x ) ;
 extern int __isinfl       ( long double            __x ) ;
 extern int __isnanf       ( float              __x ) ;
 extern int __isnan        ( double           __x ) ;
 extern int __isnand       ( double             __x ) ;
 extern int __isnanl       ( long double            __x ) ;
 extern int __isnormalf    ( float              __x ) ;
 extern int __isnormal     ( double           __x ) ;
 extern int __isnormald    ( double             __x ) ;
 extern int __isnormall    ( long double            __x ) ;
 extern int __isfinitef    ( float              __x ) ;
 extern int __isfinite     ( double           __x ) ;
 extern int __isfinited    ( double             __x ) ;
 extern int __isfinitel    ( long double            __x ) ;
 extern int __finitef      ( float              __x ) ;
 extern int __finite       ( double             __x ) ;
 extern int __finited      ( double             __x ) ;
 extern int __finitel      ( long double            __x ) ;
 extern int __signbitf     ( float              __x ) ;
 extern int __signbit      ( double             __x ) ;
 extern int __signbitd     ( double             __x ) ;
 extern int __signbitl     ( long double            __x ) ;
#line 470 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 487 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 509 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 516 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern int isgreaterf( float __xf, float __yf );
 extern int isgreater( double __xd, double __yd );
 extern int isgreaterl( long double __xl, long double __yl );
 extern int __isgreaterf( float __xf, float __yf );
 extern int __isgreater( double __xd, double __yd );
 extern int __isgreaterl( long double __xl, long double __yl );
 extern int isgreaterequalf( float __xf, float __yf );
 extern int isgreaterequal( double __xd, double __yd );
 extern int isgreaterequall( long double __xl, long double __yl );
 extern int __isgreaterequalf( float __xf, float __yf );
 extern int __isgreaterequal( double __xd, double __yd );
 extern int __isgreaterequall( long double __xl, long double __yl );
 extern int islessf( float __xf, float __yf );
 extern int isless( double __xd, double __yd );
 extern int islessl( long double __xl, long double __yl );
 extern int __islessf( float __xf, float __yf );
 extern int __isless( double __xd, double __yd );
 extern int __islessl( long double __xl, long double __yl );
 int islessequalf( float __xf, float __yf );
 extern int islessequal( double __xd, double __yd );
 extern int islessequall( long double __xl, long double __yl );
 extern int __islessequalf( float __xf, float __yf );
 extern int __islessequal( double __xd, double __yd );
 extern int __islessequall( long double __xl, long double __yl );
 extern int islessgreaterf( float __xf, float __yf );
 extern int islessgreater( double __xd, double __yd );
 extern int islessgreaterl( long double __xl, long double __yl );
 extern int __islessgreaterf( float __xf, float __yf );
 extern int __islessgreater( double __xd, double __yd );
 extern int __islessgreaterl( long double __xl, long double __yl );
 extern int isunorderedf( float __xf, float __yf );
 extern int isunordered( double __xd, double __yd );
 extern int isunorderedl( long double __xl, long double __yl );
 extern int __isunorderedf( float __xf, float __yf );
 extern int __isunordered( double __xd, double __yd );
 extern int __isunorderedl( long double __xl, long double __yl );
#line 584 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 594 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 612 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern float    __cdecl acosf( float __x );
 extern float    __cdecl asinf( float __x );
 extern float    __cdecl atanf( float __x );
 extern float    __cdecl atan2f( float __y, float __x );
 extern float    __cdecl cosf( float __x );
 extern float    __cdecl sinf( float __x );
 extern float    __cdecl tanf( float __x );
 extern double   __cdecl acosh( double __x );
 extern float    __cdecl acoshf( float __x );
 extern double   __cdecl asinh( double __x );
 extern float    __cdecl asinhf( float __x );
 extern double   __cdecl atanh( double __x );
 extern float    __cdecl atanhf( float __x );
#line 647 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern float    __cdecl coshf( float __x );
 extern float    __cdecl sinhf( float __x );
 extern float    __cdecl tanhf( float __x );
 extern float    __cdecl expf( float __x );
 extern double   __cdecl expm1( double __x );
 extern float    __cdecl expm1f( float __x );
 extern double   __cdecl exp2( double __x );
 extern float    __cdecl exp2f( float __x );
#line 688 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern float    __cdecl frexpf( float __x, int *__exp );
 extern float    __cdecl ldexpf( float __x, int __exp );
 extern float    __cdecl nanf( const char* __tagp );
 extern double   __cdecl nan ( const char* __tagp );
 extern long double  __cdecl nanl( const char* __tagp );
 extern double   __cdecl scalb( double __x, double __y );
 extern float    __cdecl scalbf( float __x, float __y );
 extern double   __cdecl scalbn( double __x, int __n );
 extern float    __cdecl scalbnf( float __x, int __n );
 extern double   __cdecl scalbln( double __x, long int __n );
 extern float    __cdecl scalblnf( float __x, long int __n );
#line 728 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern float    __cdecl logf( float __x );
 extern float    __cdecl log10f( float __x );
 extern double   __cdecl log2( double __x );
 extern float    __cdecl log2f( float __x );
 extern double   __cdecl log1p( double __x );
 extern float    __cdecl log1pf( float __x );
 extern double   __cdecl logb( double __x );
 extern float    __cdecl logbf( float __x );
 extern int      __cdecl ilogb( double __x );
 extern int      __cdecl ilogbf( float __x );
 extern float    __cdecl modff( float __x, float *__iptr );
 extern double   __cdecl cbrt( double __x );
 extern float    __cdecl cbrtf( float __x );
#line 780 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern float    __cdecl fabsf( float __x );
 extern double   __cdecl hypot( double __x, double __y );
 extern float    __cdecl hypotf( float __x, float __y );
 extern float    __cdecl powf( float __x, float __y );
 extern float    __cdecl sqrtf( float __x );
 extern double   __cdecl erf( double __x );
 extern float    __cdecl erff( float __x );
 extern double   __cdecl erfc( double __x );
 extern float    __cdecl erfcf( float __x );
 extern double   __cdecl lgamma( double __x );
 extern float    __cdecl lgammaf( float __x );
extern double   __cdecl gamma( double __x );
extern float    __cdecl gammaf( float __x );
extern double   __cdecl lgamma_r(double __x, int *__signgam);
extern float    __cdecl lgammaf_r( float __x, int *__signgam );
extern double   __cdecl gamma_r( double __x, int *__signgam );
extern float    __cdecl gammaf_r( float __x, int *__signgam );
 extern double   __cdecl tgamma( double __x );
 extern float    __cdecl tgammaf( float __x );
#line 829 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
 extern float    __cdecl ceilf( float __x );
 extern float    __cdecl floorf( float __x );
 extern double   __cdecl nearbyint( double __x );
 extern float    __cdecl nearbyintf( float __x );
 extern double   __cdecl rint( double __x );
 extern float    __cdecl rintf( float __x );
 extern long int  __cdecl lrint( double __x );
 extern long int  __cdecl lrintf( float __x );
 extern long long int __cdecl llrint( double __x );
 extern long long int __cdecl llrintf( float __x );
 extern double   __cdecl round( double __x );
 extern float    __cdecl roundf( float __x );
 extern long int  __cdecl lround( double __x );
 extern long int  __cdecl lroundf( float __x );
 extern long long int __cdecl llround( double __x );
 extern long long int __cdecl llroundf( float __x );
 extern double   __cdecl trunc( double __x );
 extern float    __cdecl truncf( float __x );
 extern float    __cdecl fmodf( float __x, float __y );
 extern double   __cdecl remainder( double __x, double __y );
 extern float    __cdecl remainderf( float __x, float __y );
 extern double   __cdecl remquo( double __x, double __y, int *__quo );
 extern float    __cdecl remquof( float __x, float __y, int *__quo );
 extern double   __cdecl copysign( double __x, double __y );
 extern float    __cdecl copysignf( float __x, float __y );
 extern double   __cdecl nextafter( double __x, double __y );
 extern float    __cdecl nextafterf( float __x, float __y );
 extern double   __cdecl __libm_nexttoward64 ( double __x, long double __y );
 extern float    __cdecl __libm_nexttoward64f( float  __x, double __y );
 extern double   __cdecl __libm_nexttoward64l( double __x, double __y );
 extern double   __cdecl fdim( double __x, double __y );
 extern float    __cdecl fdimf( float __x, float __y );
 extern double   __cdecl fmax( double __x, double __y );
 extern float    __cdecl fmaxf( float __x, float __y );
 extern double   __cdecl fmin( double __x, double __y );
 extern float    __cdecl fminf( float __x, float __y );
 extern double   __cdecl fma( double __x, double __y, double __z );
 extern float    __cdecl fmaf( float __x, float __y, float __z );
 __forceinline long double  __cdecl acosl( long double __x )
  {return (long double) acos((double) __x);}
 __forceinline long double  __cdecl asinl( long double __x )
  {return (long double) asin((double) __x);}
 __forceinline long double  __cdecl atan2l( long double __y, long double __x )
  {return (long double) atan2((double)__y, (double) __x );}
 __forceinline long double  __cdecl atanl( long double __x )
  {return (long double) atan((double) __x);}
 __forceinline long double  __cdecl ceill( long double __x )
  {return (long double) ceil((double) __x);}
 __forceinline long double  __cdecl cosl( long double __x )
  {return (long double) cos((double) __x);}
 __forceinline long double  __cdecl coshl( long double __x )
  {return (long double) cosh((double) __x);}
 __forceinline long double  __cdecl expl( long double __x )
  {return (long double) exp((double) __x);}
 __forceinline long double  __cdecl fabsl( long double __x )
  {return (long double) fabs((double) __x);}
 __forceinline long double  __cdecl floorl( long double __x )
  {return (long double) floor((double) __x);}
 __forceinline long double  __cdecl fmodl( long double __x, long double __y )
  {return (long double) fmod((double)__x, (double) __y );}
 __forceinline long double  __cdecl frexpl( long double __x, int *__exp )
  {return (long double) frexp((double)__x, __exp );}
 __forceinline long double  __cdecl hypotl( long double __x, long double __y )
  {return (long double) hypot((double)__x, (double) __y );}
 __forceinline long double  __cdecl ldexpl( long double __x, int __exp )
  {return (long double) ldexp((double)__x, __exp );}
 __forceinline long double  __cdecl logl( long double __x )
  {return (long double) log((double) __x);}
 __forceinline long double  __cdecl log10l( long double __x )
  {return (long double) log10((double) __x);}
 __forceinline long double  __cdecl modfl( long double __x, long double *__iptr )
  {return (long double) modf((double)__x, (double *) __iptr );}
 __forceinline long double  __cdecl powl( long double __x, long double __y )
  {return (long double) pow((double)__x, (double) __y );}
 __forceinline long double  __cdecl sinhl( long double __x )
  {return (long double) sinh((double) __x);}
 __forceinline long double  __cdecl sinl( long double __x )
  {return (long double) sin((double) __x);}
 __forceinline long double  __cdecl sqrtl( long double __x )
  {return (long double) sqrt((double) __x);}
 __forceinline long double  __cdecl tanl( long double __x )
  {return (long double) tan((double) __x);}
 __forceinline long double  __cdecl tanhl( long double __x )
  {return (long double) tanh((double) __x);}
 __forceinline long double  __cdecl acoshl( long double __x )
  {return (long double) acosh((double) __x);}
 __forceinline long double  __cdecl asinhl( long double __x )
  {return (long double) asinh((double) __x);}
 __forceinline long double  __cdecl atanhl( long double __x )
  {return (long double) atanh((double) __x);}
 __forceinline long double  __cdecl cbrtl( long double __x )
  {return (long double) cbrt((double) __x);}
 __forceinline long double  __cdecl copysignl( long double __x, long double __y )
  {return (long double) copysign((double)__x, (double) __y );}
 __forceinline long double  __cdecl erfcl( long double __x )
  {return (long double) erfc((double) __x);}
 __forceinline long double  __cdecl erfl( long double __x )
  {return (long double) erf((double) __x);}
 __forceinline int      __cdecl ilogbl( long double __x )
  {return (long double) ilogb((double) __x);}
 __forceinline long double  __cdecl gammal( long double __x )
  {return (long double) gamma((double) __x);}
 __forceinline long double  __cdecl gammal_r( long double __x, int *__signgam )
  {return (long double) gamma_r((double) __x, __signgam);}
 __forceinline long double  __cdecl lgammal( long double __x )
  {return (long double) lgamma((double) __x);}
 __forceinline long double  __cdecl lgammal_r( long double __x, int *__signgam )
  {return (long double) lgamma_r((double) __x, __signgam);}
 __forceinline long double  __cdecl log1pl( long double __x )
  {return (long double) log1p((double) __x);}
 __forceinline long double  __cdecl logbl( long double __x )
  {return (long double) logb((double) __x);}
 __forceinline long double  __cdecl nextafterl( long double __x, long double __y )
  {return (long double) nextafter((double)__x, (double) __y );}
 __forceinline long double  __cdecl remainderl( long double __x, long double __y )
  {return (long double) remainder((double)__x, (double) __y );}
 __forceinline long double  __cdecl rintl( long double __x )
  {return (long double) rint((double) __x);}
 __forceinline long double  __cdecl scalbnl( long double __x, int __n )
  {return (long double) scalbn((double)__x, __n );}
 __forceinline long double  __cdecl exp2l( long double __x )
  {return (long double) exp2((double) __x);}
 __forceinline long double  __cdecl expm1l( long double __x )
  {return (long double) expm1((double) __x);}
 __forceinline long double  __cdecl fdiml( long double __x, long double __y )
  {return (long double) fdim((double)__x, (double) __y );}
 __forceinline long double  __cdecl fmal( long double __x, long double __y, long double __z )
  {return (long double) fma((double) __x, (double) __y, (double) __z);}
 __forceinline long double  __cdecl fmaxl( long double __x, long double __y )
  {return (long double) fmax((double)__x, (double) __y );}
 __forceinline long double  __cdecl fminl( long double __x, long double __y )
  {return (long double) fmin((double)__x, (double) __y );}
 __forceinline long long int __cdecl llrintl( long double __x )
  {return (long double) llrint((double) __x);}
 __forceinline long long int __cdecl llroundl( long double __x )
  {return (long double) llround((double) __x);}
 __forceinline long double  __cdecl log2l( long double __x )
  {return (long double) log2((double) __x);}
 __forceinline long int  __cdecl lrintl( long double __x )
  {return (long double) lrint((double) __x);}
 __forceinline long int  __cdecl lroundl( long double __x )
  {return (long double) lround((double) __x);}
 __forceinline long double  __cdecl nearbyintl( long double __x )
  {return (long double) nearbyint((double) __x);}
 __forceinline long double  __cdecl nexttowardl( long double __x, long double __y )
 {return (long double)  __libm_nexttoward64l((double)__x, (double) __y );}
 __forceinline double  __cdecl nexttoward( double __x, long double __y )
 {return __libm_nexttoward64l(__x, (double) __y );}
 __forceinline float  __cdecl nexttowardf( float __x, long double __y )
 {return __libm_nexttoward64f(__x, (double) __y );}
 __forceinline long double  __cdecl remquol( long double __x, long double __y, int *__quo )
  {return (long double) remquo((double) __x, (double) __y, __quo);}
 __forceinline long double  __cdecl roundl( long double __x )
  {return (long double) round((double) __x);}
 __forceinline long double  __cdecl scalbl( long double __x, long double __y )
 {return (long double) scalb((double)__x, (double) __y );}
 __forceinline long double  __cdecl scalblnl( long double __x, long int __n )
  {return (long double) scalbln((double)__x, __n );}
 __forceinline long double  __cdecl tgammal( long double __x )
  {return (long double) tgamma((double) __x);}
 __forceinline long double  __cdecl truncl( long double __x )
  {return (long double) trunc((double) __x);}
#line 1133 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 1147 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
typedef struct ____exception {
    int     type;
    const char  *name;
    double  arg1;
    double  arg2;
    double  retval;
} ___exception;
#line 1168 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
typedef struct ____exceptionf {
    int    type;
    const char *name;
    float  arg1;
    float  arg2;
    float  retval;
} ___exceptionf;
typedef struct ____exceptionl {
    int      type;
    const char   *name;
    long double  arg1;
    long double  arg2;
    long double  retval;
} ___exceptionl;
 extern int __cdecl matherrf( struct ____exceptionf *__e );
 extern int __cdecl matherrl( struct ____exceptionl *__e );
typedef int ( __cdecl *___pmatherr )( struct ____exception  *__e );
typedef int ( __cdecl *___pmatherrf )( struct ____exceptionf *__e );
typedef int ( __cdecl *___pmatherrl )( struct ____exceptionl *__e );
 extern ___pmatherr  __cdecl __libm_setusermatherr( ___pmatherr  __user_matherr );
 extern ___pmatherrf __cdecl __libm_setusermatherrf( ___pmatherrf __user_matherrf );
 extern ___pmatherrl __cdecl __libm_setusermatherrl( ___pmatherrl __user_matherrl );
typedef enum ___LIB_VERSIONIMF_TYPE {
     _IEEE_ = -1
    ,_SVID_
    ,_XOPEN_
    ,_POSIX_
    ,_ISOC_
} _LIB_VERSIONIMF_TYPE;
extern _LIB_VERSIONIMF_TYPE  _LIB_VERSIONIMF;
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math_common_undefine.h"
#line 1234 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\math.h"
#line 142 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 176 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 226 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\math.h"
#line 4 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
                Defined "HAVE_MATH_H" to "1"
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -c -o /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.o -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.compilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.utilities.closure -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers -O2 -MT -wd4996 -Qopenmp    /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(6): error: identifier "M_PI" is undefined
  double pi = M_PI;
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c (code 2)
Possible ERROR while running compiler: exit code 512
stdout:
conftest.c
  double pi = M_PI;
compilation aborted for C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c (code 2)Source:
#include "confdefs.h"
#include "conffix.h"
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
stdout: conftest.c
Successful compile:
Source:
#define _USE_MATH_DEFINES 1
#include <math.h>
int main() {
double pi = M_PI;
if (pi);
  return 0;
              Defined "_USE_MATH_DEFINES" to "1"
            Activated Windows math #defines, like M_PI
stdout: conftest.c
Successful compile:
Source:
#include <math.h>
int main() {
double f = INFINITY;
if (f);
  return 0;
              Defined "HAVE_MATH_INFINITY" to "1"
            Found math INFINITY
TEST check from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/socket.h
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/socket.h"
  #include <sys/socket.h>
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conffix.h"
stdout:
conftest.c
Checking for header: sys/types.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\sys/types.h"
#pragma once
    typedef unsigned short _ino_t;
        typedef _ino_t ino_t;
    typedef unsigned int _dev_t;
        typedef _dev_t dev_t;
    typedef long _off_t;
        typedef _off_t off_t;
                Defined "HAVE_SYS_TYPES_H" to "1"
Checking for header: malloc.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
 __declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
     size_t _Count,
     size_t _Size
void* __cdecl calloc(
      size_t _Count,
      size_t _Size
 int __cdecl _callnewh(
     size_t _Size
void* __cdecl _expand(
               void*  _Block,
      size_t _Size
void __cdecl _free_base(
      void* _Block
void __cdecl free(
      void* _Block
void* __cdecl _malloc_base(
     size_t _Size
void* __cdecl malloc(
      size_t _Size
size_t __cdecl _msize_base(
     void* _Block
size_t __cdecl _msize(
     void* _Block
void* __cdecl _realloc_base(
       void*  _Block,
                                size_t _Size
void* __cdecl realloc(
      void*  _Block,
             size_t _Size
void* __cdecl _recalloc_base(
      void*  _Block,
                               size_t _Count,
                               size_t _Size
void* __cdecl _recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size
void __cdecl _aligned_free(
      void* _Block
void* __cdecl _aligned_malloc(
      size_t _Size,
                        size_t _Alignment
void* __cdecl _aligned_offset_malloc(
      size_t _Size,
                        size_t _Alignment,
                        size_t _Offset
size_t __cdecl _aligned_msize(
     void*  _Block,
              size_t _Alignment,
              size_t _Offset
void* __cdecl _aligned_offset_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_offset_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment
void* __cdecl _aligned_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment
#line 225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#line 37 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
typedef struct _heapinfo
    int* _pentry;
    size_t _size;
    int _useflag;
} _HEAPINFO;
void* __cdecl _alloca( size_t _Size);
     intptr_t __cdecl _get_heap_handle(void);
     int __cdecl _heapmin(void);
         int __cdecl _heapwalk( _HEAPINFO* _EntryInfo);
          int __cdecl _heapchk(void);
     int __cdecl _resetstkoflw(void);
    typedef char __static_assert_t[(sizeof(unsigned int) <= 16) != 0];
    #pragma warning(push)
    #pragma warning(disable:6540)
    __inline void* _MarkAllocaS(  void* _Ptr, unsigned int _Marker)
        if (_Ptr)
            *((unsigned int*)_Ptr) = _Marker;
            _Ptr = (char*)_Ptr + 16;
        return _Ptr;
    __inline size_t _MallocaComputeSize(size_t _Size)
        size_t _MarkedSize = _Size + 16;
        return _MarkedSize > _Size ? _MarkedSize : 0;
    #pragma warning(pop)
#line 126 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#line 135 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
    #pragma warning(disable: 6014)
    __inline void __cdecl _freea(  void* _Memory)
        unsigned int _Marker;
        if (_Memory)
            _Memory = (char*)_Memory - 16;
            _Marker = *(unsigned int*)_Memory;
            if (_Marker == 0xDDDD)
                free(_Memory);
#line 165 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
__pragma(pack(pop))
                Defined "HAVE_MALLOC_H" to "1"
Checking for header: time.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wtime.h"
#pragma once
struct tm
    int tm_sec;
    int tm_min;
    int tm_hour;
    int tm_mday;
    int tm_mon;
    int tm_year;
    int tm_wday;
    int tm_yday;
    int tm_isdst;
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wasctime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wasctime(
     struct tm const* _Tm
 errno_t __cdecl _wasctime_s(
      wchar_t*         _Buffer,
                                         size_t           _SizeInWords,
 size_t __cdecl wcsftime(
      wchar_t*         _Buffer,
                            wchar_t const*   _Format,
 size_t __cdecl _wcsftime_l(
      wchar_t*         _Buffer,
                              struct tm const* _Tm,
                          _locale_t        _Locale
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wctime32(
     __time32_t const* _Time
 errno_t __cdecl _wctime32_s(
      wchar_t*          _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wctime64(
     __time64_t const* _Time
 errno_t __cdecl _wctime64_s(
      wchar_t*          _Buffer,
                                                      __time64_t const* _Time);
 errno_t __cdecl _wstrdate_s(
      wchar_t* _Buffer,
        size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wstrdate_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wstrdate( wchar_t *_Buffer);
 errno_t __cdecl _wstrtime_s(
      wchar_t* _Buffer,
        size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wstrtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wstrtime( wchar_t *_Buffer);
    #pragma warning(disable: 4996)
#line 183 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wtime.h"
        static __inline wchar_t * __cdecl _wctime(
             time_t const* const _Time)
            return _wctime64(_Time);
        static __inline errno_t __cdecl _wctime_s(
               wchar_t*      const _Buffer,
                                                            size_t        const _SizeInWords,
            return _wctime64_s(_Buffer, _SizeInWords, _Time);
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
typedef long clock_t;
struct _timespec32
    __time32_t tv_sec;
    long       tv_nsec;
struct _timespec64
    __time64_t tv_sec;
    long       tv_nsec;
    struct timespec
        time_t tv_sec;
        long   tv_nsec;
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_daylight" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int* __cdecl __daylight(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_dstbias" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 long* __cdecl __dstbias(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_timezone" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 long* __cdecl __timezone(void);
  __declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_tzname" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char** __cdecl __tzname(void);
 errno_t __cdecl _get_daylight(
     int* _Daylight
 errno_t __cdecl _get_dstbias(
     long* _DaylightSavingsBias
 errno_t __cdecl _get_timezone(
     long* _TimeZone
 errno_t __cdecl _get_tzname(
                            size_t* _ReturnValue,
     char*   _Buffer,
                             size_t  _SizeInBytes,
                             int     _Index
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "asctime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl asctime(
     errno_t __cdecl asctime_s(
          char*            _Buffer,
 clock_t __cdecl clock(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ctime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ctime32(
 errno_t __cdecl _ctime32_s(
      char*             _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ctime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ctime64(
 errno_t __cdecl _ctime64_s(
      char*             _Buffer,
 double __cdecl _difftime32(
     __time32_t _Time1,
     __time32_t _Time2
 double __cdecl _difftime64(
     __time64_t _Time1,
     __time64_t _Time2
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_gmtime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _gmtime32(
 errno_t __cdecl _gmtime32_s(
     struct tm*        _Tm,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_gmtime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _gmtime64(
 errno_t __cdecl _gmtime64_s(
     struct tm*        _Tm,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_localtime32_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _localtime32(
 errno_t __cdecl _localtime32_s(
     struct tm*        _Tm,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_localtime64_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 struct tm* __cdecl _localtime64(
 errno_t __cdecl _localtime64_s(
     struct tm*        _Tm,
 __time32_t __cdecl _mkgmtime32(
     struct tm* _Tm
 __time64_t __cdecl _mkgmtime64(
     struct tm* _Tm
 __time32_t __cdecl _mktime32(
     struct tm* _Tm
 __time64_t __cdecl _mktime64(
     struct tm* _Tm
 size_t __cdecl strftime(
      char*            _Buffer,
      char const*      _Format,
 size_t __cdecl _strftime_l(
          char*            _Buffer,
                              size_t           _MaxSize,
                          _locale_t        _Locale
 errno_t __cdecl _strdate_s(
      char*  _Buffer,
        size_t _SizeInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strdate_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strdate( char *_Buffer);
 errno_t __cdecl _strtime_s(
      char*  _Buffer,
        size_t _SizeInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strtime( char *_Buffer);
 __time32_t __cdecl _time32(
     __time32_t* _Time
 __time64_t __cdecl _time64(
     __time64_t* _Time
 int __cdecl _timespec32_get(
     struct _timespec32* _Ts,
      int                 _Base
 int __cdecl _timespec64_get(
     struct _timespec64* _Ts,
      int                 _Base
     void __cdecl _tzset(void);
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "GetLocalTime" " " "instead. See online help for details."))
     unsigned __cdecl _getsystime(
         struct tm* _Tm
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetLocalTime" " " "instead. See online help for details."))
     unsigned __cdecl _setsystime(
         struct tm* _Tm,
         unsigned   _Milliseconds
#line 474 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\time.h"
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "ctime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
        static __inline char* __cdecl ctime(
            return _ctime64(_Time);
        static __inline double __cdecl difftime(
             time_t const _Time1,
             time_t const _Time2
            return _difftime64(_Time1, _Time2);
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "gmtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
        static __inline struct tm* __cdecl gmtime(
            return _gmtime64(_Time);
        __declspec(deprecated("This function or variable may be unsafe. Consider using " "localtime_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
        static __inline struct tm* __cdecl localtime(
            return _localtime64(_Time);
        static __inline time_t __cdecl _mkgmtime(
             struct tm* const _Tm
            return _mkgmtime64(_Tm);
        static __inline time_t __cdecl mktime(
            return _mktime64(_Tm);
        static __inline time_t __cdecl time(
             time_t* const _Time
            return _time64(_Time);
        static __inline int __cdecl timespec_get(
             struct timespec* const _Ts,
              int              const _Base
            return _timespec64_get((struct _timespec64*)_Ts, _Base);
            static __inline errno_t __cdecl ctime_s(
                  char*         const _Buffer,
                                                   size_t        const _SizeInBytes,
                return _ctime64_s(_Buffer, _SizeInBytes, _Time);
            static __inline errno_t __cdecl gmtime_s(
                 struct tm*    const _Tm,
                return _gmtime64_s(_Tm, _Time);
            static __inline errno_t __cdecl localtime_s(
                return _localtime64_s(_Tm, _Time);
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_tzset" ". See online help for details."))  void __cdecl tzset(void);
__pragma(pack(pop))
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                Defined "HAVE_TIME_H" to "1"
Checking for header: Direct.h
stdout:
conftest.c
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\Direct.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\Direct.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wdirect.h"
#pragma once
 __declspec(allocator) wchar_t* __cdecl _wgetcwd(
     wchar_t* _DstBuf,
                                 int      _SizeInWords
 __declspec(allocator) wchar_t* __cdecl _wgetdcwd(
                                 int      _Drive,
     wchar_t* _DstBuf,
                                 int      _SizeInWords
 int __cdecl _wchdir(
     wchar_t const* _Path
 int __cdecl _wmkdir(
 int __cdecl _wrmdir(
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\Direct.h"
        struct _diskfree_t
            unsigned total_clusters;
            unsigned avail_clusters;
            unsigned sectors_per_cluster;
            unsigned bytes_per_sector;
         unsigned __cdecl _getdiskfree(
              unsigned            _Drive,
             struct _diskfree_t* _DiskFree
          int __cdecl _chdrive( int _Drive);
          int __cdecl _getdrive(void);
          unsigned long __cdecl _getdrives(void);
 __declspec(allocator) char* __cdecl _getcwd(
     char* _DstBuf,
                                 int   _SizeInBytes
 __declspec(allocator) char* __cdecl _getdcwd(
                                 int   _Drive,
     char* _DstBuf,
                                 int   _SizeInBytes
  int __cdecl _chdir( char const* _Path);
  int __cdecl _mkdir( char const* _Path);
  int __cdecl _rmdir( char const* _Path);
          __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_getcwd" ". See online help for details."))
         char* __cdecl getcwd(
             char* _DstBuf,
                                         int   _SizeInBytes
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_chdir" ". See online help for details."))
         int __cdecl chdir(
             char const* _Path
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_mkdir" ". See online help for details."))
     int __cdecl mkdir(
         char const* _Path
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_rmdir" ". See online help for details."))
     int __cdecl rmdir(
         char const* _Path
__pragma(pack(pop))
                Defined "HAVE_DIRECT_H" to "1"
Checking for header: Ws2tcpip.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\Ws2tcpip.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#pragma warning(disable:4001)
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winpackagefamily.h"
#pragma once
#line 57 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winpackagefamily.h"
#line 84 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winpackagefamily.h"
#line 27 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#line 143 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#line 154 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#line 26 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\Ws2tcpip.h"
#pragma warning(disable:4365)
#pragma warning(disable:4574)
#pragma warning(disable:4668)
#pragma warning(disable:4820)
#line 42 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\Ws2tcpip.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winsock2.h"
#pragma once
#line 36 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winsock2.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#pragma once
#line 44 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 64 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 76 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 100 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 152 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 205 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 224 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 232 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 266 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdkddkver.h"
#line 23 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#pragma once
#pragma region Application Family or OneCore Family
#line 105 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#line 112 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#pragma warning(disable:4116)
#pragma warning(disable:4514)
#pragma warning(disable:4103)
#pragma warning(disable:4201)
#pragma warning(disable:4214)
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\excpt.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
#line 13 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\excpt.h"
typedef enum _EXCEPTION_DISPOSITION
    ExceptionContinueExecution,
    ExceptionContinueSearch,
    ExceptionNestedException,
    ExceptionCollidedUnwind
} EXCEPTION_DISPOSITION;
#line 44 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\excpt.h"
        struct _EXCEPTION_RECORD;
        struct _CONTEXT;
        struct _DISPATCHER_CONTEXT;
         EXCEPTION_DISPOSITION __cdecl __C_specific_handler(
                struct _EXCEPTION_RECORD*   ExceptionRecord,
                void*                       EstablisherFrame,
             struct _CONTEXT*            ContextRecord,
             struct _DISPATCHER_CONTEXT* DispatcherContext
#line 68 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\excpt.h"
unsigned long __cdecl _exception_code(void);
void *        __cdecl _exception_info(void);
int           __cdecl _abnormal_termination(void);
__pragma(pack(pop))
#line 168 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdarg.h"
#pragma once
__pragma(pack(pop))
#line 169 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\windef.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#pragma once
#line 39 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 58 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 100 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 186 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 320 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 329 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 346 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 361 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 378 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 417 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 433 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 458 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 497 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 566 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 577 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 606 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 668 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_undef.h"
#line 456 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_undef.h"
#line 189 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 395 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 438 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 462 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 655 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 835 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 1065 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 1122 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 1136 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings_strict.h"
#line 675 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 694 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\sdv_driverspecs.h"
#line 126 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#pragma once
#line 255 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 267 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 292 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 299 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 341 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 865 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 885 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\driverspecs.h"
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\specstrings.h"
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
typedef unsigned long ULONG;
typedef ULONG *PULONG;
typedef unsigned short USHORT;
typedef USHORT *PUSHORT;
typedef unsigned char UCHAR;
typedef UCHAR *PUCHAR;
typedef  char *PSZ;
#line 69 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
#line 114 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
#line 141 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
#line 155 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
typedef unsigned long       DWORD;
typedef int                 BOOL;
typedef unsigned char       BYTE;
typedef unsigned short      WORD;
typedef float               FLOAT;
typedef FLOAT               *PFLOAT;
typedef BOOL            *PBOOL;
typedef BOOL             *LPBOOL;
typedef BYTE            *PBYTE;
typedef BYTE             *LPBYTE;
typedef int             *PINT;
typedef int              *LPINT;
typedef WORD            *PWORD;
typedef WORD             *LPWORD;
typedef long             *LPLONG;
typedef DWORD           *PDWORD;
typedef DWORD            *LPDWORD;
typedef void             *LPVOID;
typedef const void       *LPCVOID;
typedef int                 INT;
typedef unsigned int        UINT;
typedef unsigned int        *PUINT;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#pragma warning(disable:4200)
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
#pragma once
#pragma once
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wctype.h"
#pragma once
     const unsigned short* __cdecl __pctype_func(void);
     const wctype_t*       __cdecl __pwctype_func(void);
#line 42 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wctype.h"
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wctype.h"
  int __cdecl iswalnum  ( wint_t _C);
  int __cdecl iswalpha  ( wint_t _C);
  int __cdecl iswascii  ( wint_t _C);
  int __cdecl iswblank  ( wint_t _C);
  int __cdecl iswcntrl  ( wint_t _C);
  int __cdecl iswdigit  ( wint_t _C);
  int __cdecl iswgraph  ( wint_t _C);
  int __cdecl iswlower  ( wint_t _C);
  int __cdecl iswprint  ( wint_t _C);
  int __cdecl iswpunct  ( wint_t _C);
  int __cdecl iswspace  ( wint_t _C);
  int __cdecl iswupper  ( wint_t _C);
  int __cdecl iswxdigit ( wint_t _C);
  int __cdecl __iswcsymf( wint_t _C);
  int __cdecl __iswcsym ( wint_t _C);
  int __cdecl _iswalnum_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswalpha_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswblank_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswcntrl_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswdigit_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswgraph_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswlower_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswprint_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswpunct_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswspace_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswupper_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswxdigit_l( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswcsymf_l ( wint_t _C,  _locale_t _Locale);
  int __cdecl _iswcsym_l  ( wint_t _C,  _locale_t _Locale);
  wint_t __cdecl towupper( wint_t _C);
  wint_t __cdecl towlower( wint_t _C);
  int    __cdecl iswctype( wint_t _C,  wctype_t _Type);
  wint_t __cdecl _towupper_l( wint_t _C,  _locale_t _Locale);
  wint_t __cdecl _towlower_l( wint_t _C,  _locale_t _Locale);
  int    __cdecl _iswctype_l( wint_t _C,  wctype_t _Type,  _locale_t _Locale);
      int __cdecl isleadbyte( int _C);
      int __cdecl _isleadbyte_l( int _C,  _locale_t _Locale);
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "iswctype" " " "instead. See online help for details."))  int __cdecl is_wctype( wint_t _C,  wctype_t _Type);
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wctype.h"
#line 150 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wctype.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
  int __cdecl _isctype( int _C,  int _Type);
  int __cdecl _isctype_l( int _C,  int _Type,  _locale_t _Locale);
   int __cdecl isalpha( int _C);
  int __cdecl _isalpha_l( int _C,  _locale_t _Locale);
   int __cdecl isupper( int _C);
  int __cdecl _isupper_l( int _C,  _locale_t _Locale);
   int __cdecl islower( int _C);
  int __cdecl _islower_l( int _C,  _locale_t _Locale);
   int __cdecl isdigit( int _C);
  int __cdecl _isdigit_l( int _C,  _locale_t _Locale);
  int __cdecl isxdigit( int _C);
  int __cdecl _isxdigit_l( int _C,  _locale_t _Locale);
   int __cdecl isspace( int _C);
  int __cdecl _isspace_l( int _C,  _locale_t _Locale);
  int __cdecl ispunct( int _C);
  int __cdecl _ispunct_l( int _C,  _locale_t _Locale);
  int __cdecl isblank( int _C);
  int __cdecl _isblank_l( int _C,  _locale_t _Locale);
   int __cdecl isalnum( int _C);
  int __cdecl _isalnum_l( int _C,  _locale_t _Locale);
  int __cdecl isprint( int _C);
  int __cdecl _isprint_l( int _C,  _locale_t _Locale);
  int __cdecl isgraph( int _C);
  int __cdecl _isgraph_l( int _C,  _locale_t _Locale);
  int __cdecl iscntrl( int _C);
  int __cdecl _iscntrl_l( int _C,  _locale_t _Locale);
   int __cdecl toupper( int _C);
   int __cdecl tolower( int _C);
   int __cdecl _tolower( int _C);
  int __cdecl _tolower_l( int _C,  _locale_t _Locale);
   int __cdecl _toupper( int _C);
  int __cdecl _toupper_l( int _C,  _locale_t _Locale);
  int __cdecl __isascii( int _C);
  int __cdecl __toascii( int _C);
  int __cdecl __iscsymf( int _C);
  int __cdecl __iscsym( int _C);
#line 91 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
         int __cdecl ___mb_cur_max_func(void);
         int __cdecl ___mb_cur_max_l_func(_locale_t _Locale);
#line 116 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
#line 127 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
#line 144 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
    __inline __crt_locale_data_public* __cdecl __acrt_get_locale_data_prefix(void const volatile* const _LocalePointers)
        _locale_t const _TypedLocalePointers = (_locale_t)_LocalePointers;
        return (__crt_locale_data_public*)_TypedLocalePointers->locinfo;
    __inline int __cdecl _chvalidchk_l(
             int       const _C,
             int       const _Mask,
         _locale_t const _Locale
        if (_Locale)
            return __acrt_get_locale_data_prefix(_Locale)->_locale_pctype[(unsigned char)_C] & _Mask;
        return (__pctype_func()[(unsigned char)(_C)] & (_Mask));
    __inline int __cdecl _ischartype_l(
             int       const _C,
             int       const _Mask,
        if (_Locale && __acrt_get_locale_data_prefix(_Locale)->_locale_mb_cur_max > 1)
            return _isctype_l(_C, _Mask, _Locale);
        return _chvalidchk_l(_C, _Mask, _Locale);
#line 202 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
#line 230 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\ctype.h"
__pragma(pack(pop))
#line 35 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 64 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 82 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\kernelspecs.h"
#pragma once
#line 69 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\kernelspecs.h"
#line 257 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\kernelspecs.h"
#line 87 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 113 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 124 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 138 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 156 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
 typedef unsigned __int64 POINTER_64_INT;
#line 49 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
#line 63 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
#pragma once
typedef signed char         INT8, *PINT8;
typedef signed short        INT16, *PINT16;
typedef signed int          INT32, *PINT32;
typedef signed __int64      INT64, *PINT64;
typedef unsigned char       UINT8, *PUINT8;
typedef unsigned short      UINT16, *PUINT16;
typedef unsigned int        UINT32, *PUINT32;
typedef unsigned __int64    UINT64, *PUINT64;
typedef signed int LONG32, *PLONG32;
typedef unsigned int ULONG32, *PULONG32;
typedef unsigned int DWORD32, *PDWORD32;
#line 104 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
#line 122 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
    typedef __int64 INT_PTR, *PINT_PTR;
    typedef unsigned __int64 UINT_PTR, *PUINT_PTR;
    typedef __int64 LONG_PTR, *PLONG_PTR;
    typedef unsigned __int64 ULONG_PTR, *PULONG_PTR;
#line 144 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
typedef __int64 SHANDLE_PTR;
typedef unsigned __int64 HANDLE_PTR;
typedef unsigned int UHALF_PTR, *PUHALF_PTR;
typedef int HALF_PTR, *PHALF_PTR;
__inline
unsigned long
HandleToULong(
    const void *h
    return((unsigned long) (ULONG_PTR) h );
__inline
long
HandleToLong(
    const void *h
    return((long) (LONG_PTR) h );
__inline
void *
ULongToHandle(
    const unsigned long h
    return((void *) (UINT_PTR) h );
__inline
void *
LongToHandle(
    const long h
    return((void *) (INT_PTR) h );
__inline
unsigned long
PtrToUlong(
    const void  *p
    return((unsigned long) (ULONG_PTR) p );
__inline
unsigned int
PtrToUint(
    const void  *p
    return((unsigned int) (UINT_PTR) p );
__inline
unsigned short
PtrToUshort(
    const void  *p
    return((unsigned short) (unsigned long) (ULONG_PTR) p );
__inline
long
PtrToLong(
    const void  *p
    return((long) (LONG_PTR) p );
__inline
int
PtrToInt(
    const void  *p
    return((int) (INT_PTR) p );
__inline
short
PtrToShort(
    const void  *p
    return((short) (long) (LONG_PTR) p );
__inline
void *
IntToPtr(
    const int i
    return( (void *)(INT_PTR)i );
__inline
void *
UIntToPtr(
    const unsigned int ui
    return( (void *)(UINT_PTR)ui );
__inline
void *
LongToPtr(
    const long l
    return( (void *)(LONG_PTR)l );
__inline
void *
ULongToPtr(
    const unsigned long ul
    return( (void *)(ULONG_PTR)ul );
__inline
void *
Ptr32ToPtr(
    const void * __ptr32 p
    return((void *) (ULONG_PTR) (unsigned long) p);
__inline
void *
Handle32ToHandle(
    const void * __ptr32 h
    return((void *) (LONG_PTR) (long) h);
__inline
void * __ptr32
PtrToPtr32(
    const void *p
    return((void * __ptr32) (unsigned long) (ULONG_PTR) p);
#line 397 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\basetsd.h"
typedef ULONG_PTR SIZE_T, *PSIZE_T;
typedef LONG_PTR SSIZE_T, *PSSIZE_T;
typedef ULONG_PTR DWORD_PTR, *PDWORD_PTR;
typedef __int64 LONG64, *PLONG64;
typedef unsigned __int64 ULONG64, *PULONG64;
typedef unsigned __int64 DWORD64, *PDWORD64;
typedef ULONG_PTR KAFFINITY;
typedef KAFFINITY *PKAFFINITY;
#line 180 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 189 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 197 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 205 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 213 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 223 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 235 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 243 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 251 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 259 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 267 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 275 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 283 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 291 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 300 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 308 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 316 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 324 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 334 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 367 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 382 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef void *PVOID;
typedef void * __ptr64 PVOID64;
#line 400 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 423 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef char CHAR;
typedef short SHORT;
typedef long LONG;
typedef int INT;
typedef wchar_t WCHAR;
typedef WCHAR *PWCHAR, *LPWCH, *PWCH;
typedef const WCHAR *LPCWCH, *PCWCH;
typedef  WCHAR *NWPSTR, *LPWSTR, *PWSTR;
typedef  PWSTR *PZPWSTR;
typedef  const PWSTR *PCZPWSTR;
typedef  WCHAR __unaligned *LPUWSTR, *PUWSTR;
typedef  const WCHAR *LPCWSTR, *PCWSTR;
typedef  PCWSTR *PZPCWSTR;
typedef  const PCWSTR *PCZPCWSTR;
typedef  const WCHAR __unaligned *LPCUWSTR, *PCUWSTR;
typedef  WCHAR *PZZWSTR;
typedef  const WCHAR *PCZZWSTR;
typedef  WCHAR __unaligned *PUZZWSTR;
typedef  const WCHAR __unaligned *PCUZZWSTR;
typedef  WCHAR *PNZWCH;
typedef  const WCHAR *PCNZWCH;
typedef  WCHAR __unaligned *PUNZWCH;
typedef  const WCHAR __unaligned *PCUNZWCH;
typedef const WCHAR *LPCWCHAR, *PCWCHAR;
typedef const WCHAR __unaligned *LPCUWCHAR, *PCUWCHAR;
typedef unsigned long UCSCHAR;
typedef UCSCHAR *PUCSCHAR;
typedef const UCSCHAR *PCUCSCHAR;
typedef UCSCHAR *PUCSSTR;
typedef UCSCHAR __unaligned *PUUCSSTR;
typedef const UCSCHAR *PCUCSSTR;
typedef const UCSCHAR __unaligned *PCUUCSSTR;
typedef UCSCHAR __unaligned *PUUCSCHAR;
typedef const UCSCHAR __unaligned *PCUUCSCHAR;
typedef CHAR *PCHAR, *LPCH, *PCH;
typedef const CHAR *LPCCH, *PCCH;
typedef  CHAR *NPSTR, *LPSTR, *PSTR;
typedef  PSTR *PZPSTR;
typedef  const PSTR *PCZPSTR;
typedef  const CHAR *LPCSTR, *PCSTR;
typedef  PCSTR *PZPCSTR;
typedef  const PCSTR *PCZPCSTR;
typedef  CHAR *PZZSTR;
typedef  const CHAR *PCZZSTR;
typedef  CHAR *PNZCH;
typedef  const CHAR *PCNZCH;
#line 565 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef char TCHAR, *PTCHAR;
typedef unsigned char TBYTE , *PTBYTE ;
typedef LPCH LPTCH, PTCH;
typedef LPCCH LPCTCH, PCTCH;
typedef LPSTR PTSTR, LPTSTR, PUTSTR, LPUTSTR;
typedef LPCSTR PCTSTR, LPCTSTR, PCUTSTR, LPCUTSTR;
typedef PZZSTR PZZTSTR, PUZZTSTR;
typedef PCZZSTR PCZZTSTR, PCUZZTSTR;
typedef PZPSTR PZPTSTR;
typedef PNZCH PNZTCH, PUNZTCH;
typedef PCNZCH PCNZTCH, PCUNZTCH;
typedef SHORT *PSHORT;
typedef LONG *PLONG;
typedef struct _PROCESSOR_NUMBER {
    WORD   Group;
    BYTE  Number;
    BYTE  Reserved;
} PROCESSOR_NUMBER, *PPROCESSOR_NUMBER;
typedef struct _GROUP_AFFINITY {
    KAFFINITY Mask;
    WORD   Group;
    WORD   Reserved[3];
} GROUP_AFFINITY, *PGROUP_AFFINITY;
typedef void *HANDLE;
#line 643 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef HANDLE *PHANDLE;
typedef BYTE   FCHAR;
typedef WORD   FSHORT;
typedef DWORD  FLONG;
typedef  long HRESULT;
#line 679 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 690 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 703 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef char CCHAR;
typedef DWORD LCID;
typedef PDWORD PLCID;
typedef WORD   LANGID;
typedef enum {
    UNSPECIFIED_COMPARTMENT_ID = 0,
    DEFAULT_COMPARTMENT_ID
} COMPARTMENT_ID, *PCOMPARTMENT_ID;
typedef struct _FLOAT128 {
    __int64 LowPart;
    __int64 HighPart;
} FLOAT128;
typedef FLOAT128 *PFLOAT128;
typedef __int64 LONGLONG;
typedef unsigned __int64 ULONGLONG;
#line 810 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef LONGLONG *PLONGLONG;
typedef ULONGLONG *PULONGLONG;
typedef LONGLONG USN;
typedef union _LARGE_INTEGER {
    struct {
        DWORD LowPart;
        LONG HighPart;
    struct {
        DWORD LowPart;
        LONG HighPart;
    } u;
    LONGLONG QuadPart;
} LARGE_INTEGER;
typedef LARGE_INTEGER *PLARGE_INTEGER;
typedef union _ULARGE_INTEGER {
    struct {
        DWORD LowPart;
        DWORD HighPart;
    struct {
        DWORD LowPart;
        DWORD HighPart;
    } u;
    ULONGLONG QuadPart;
} ULARGE_INTEGER;
typedef ULARGE_INTEGER *PULARGE_INTEGER;
typedef LONG_PTR RTL_REFERENCE_COUNT, *PRTL_REFERENCE_COUNT;
typedef LONG RTL_REFERENCE_COUNT32, *PRTL_REFERENCE_COUNT32;
typedef struct _LUID {
    DWORD LowPart;
    LONG HighPart;
} LUID, *PLUID;
typedef ULONGLONG  DWORDLONG;
typedef DWORDLONG *PDWORDLONG;
#line 1011 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
unsigned char
__cdecl
_rotl8 (
     unsigned char Value,
     unsigned char Shift
unsigned short
__cdecl
_rotl16 (
     unsigned short Value,
     unsigned char Shift
unsigned char
__cdecl
_rotr8 (
     unsigned char Shift
unsigned short
__cdecl
_rotr16 (
     unsigned char Shift
#pragma intrinsic(_rotl8)
#pragma intrinsic(_rotl16)
#pragma intrinsic(_rotr8)
#pragma intrinsic(_rotr16)
unsigned int
__cdecl
_rotl (
     unsigned int Value,
     int Shift
unsigned __int64
__cdecl
_rotl64 (
     unsigned __int64 Value,
     int Shift
unsigned int
__cdecl
_rotr (
     unsigned int Value,
     int Shift
unsigned __int64
__cdecl
_rotr64 (
     int Shift
#pragma intrinsic(_rotl)
#pragma intrinsic(_rotl64)
#pragma intrinsic(_rotr)
#pragma intrinsic(_rotr64)
typedef BYTE  BOOLEAN;
typedef BOOLEAN *PBOOLEAN;
typedef struct _LIST_ENTRY {
   struct _LIST_ENTRY *Flink;
   struct _LIST_ENTRY *Blink;
} LIST_ENTRY, *PLIST_ENTRY, * PRLIST_ENTRY;
typedef struct _SINGLE_LIST_ENTRY {
    struct _SINGLE_LIST_ENTRY *Next;
} SINGLE_LIST_ENTRY, *PSINGLE_LIST_ENTRY;
typedef struct LIST_ENTRY32 {
    DWORD Flink;
    DWORD Blink;
} LIST_ENTRY32;
typedef LIST_ENTRY32 *PLIST_ENTRY32;
typedef struct LIST_ENTRY64 {
    ULONGLONG Flink;
    ULONGLONG Blink;
} LIST_ENTRY64;
typedef LIST_ENTRY64 *PLIST_ENTRY64;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 22 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
typedef struct _GUID {
    unsigned long  Data1;
    unsigned short Data2;
    unsigned short Data3;
    unsigned char  Data4[ 8 ];
} GUID;
#line 38 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 54 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 67 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
typedef GUID *LPGUID;
typedef const GUID *LPCGUID;
typedef GUID IID;
typedef IID *LPIID;
typedef GUID CLSID;
typedef CLSID *LPCLSID;
typedef GUID FMTID;
typedef FMTID *LPFMTID;
#line 113 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 122 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 131 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#pragma once
     int* __cdecl _errno(void);
     errno_t __cdecl _set_errno( int _Value);
     errno_t __cdecl _get_errno( int* _Value);
     unsigned long* __cdecl __doserrno(void);
     errno_t __cdecl _set_doserrno( unsigned long _Value);
     errno_t __cdecl _get_doserrno( unsigned long * _Value);
#line 70 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#line 79 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#line 127 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
__pragma(pack(pop))
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime_string.h"
#pragma once
 void * __cdecl memchr(
     void const* _Buf,
                                int         _Val,
                                size_t      _MaxCount
int __cdecl memcmp(
     void const* _Buf1,
     void const* _Buf2,
                        size_t      _Size
void* __cdecl memcpy(
     void* _Dst,
           void const* _Src,
                              size_t      _Size
 void* __cdecl memmove(
     void*       _Dst,
           void const* _Src,
                                  size_t      _Size
void* __cdecl memset(
     void*  _Dst,
                              int    _Val,
                              size_t _Size
 char * __cdecl strchr(
     char const* _Str,
       int         _Val
 char * __cdecl strrchr(
     char const* _Str,
       int         _Ch
 char * __cdecl strstr(
     char const* _Str,
     char const* _SubStr
 wchar_t * __cdecl wcschr(
     wchar_t const* _Str,
       wchar_t        _Ch
 wchar_t * __cdecl wcsrchr(
       wchar_t        _Ch
 wchar_t * __cdecl wcsstr(
     wchar_t const* _SubStr
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
    static __inline errno_t __cdecl memcpy_s(
         void*       const _Destination,
                                                             rsize_t     const _DestinationSize,
                                void const* const _Source,
                                                             rsize_t     const _SourceSize
        if (_SourceSize == 0)
            return 0;
        { int _Expr_val=!!(_Destination != ((void *)0)); if (!(_Expr_val)) { (*_errno()) = 22; _invalid_parameter_noinfo(); return 22; } };
        if (_Source == ((void *)0) || _DestinationSize < _SourceSize)
            memset(_Destination, 0, _DestinationSize);
            { int _Expr_val=!!(_Source != ((void *)0)); if (!(_Expr_val)) { (*_errno()) = 22; _invalid_parameter_noinfo(); return 22; } };
            { int _Expr_val=!!(_DestinationSize >= _SourceSize); if (!(_Expr_val)) { (*_errno()) = 34; _invalid_parameter_noinfo(); return 34; } };
            return 22;
        memcpy(_Destination, _Source, _SourceSize);
        return 0;
    static __inline errno_t __cdecl memmove_s(
            return 0;
        memmove(_Destination, _Source, _SourceSize);
        return 0;
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
 int __cdecl _memicmp(
     void const* _Buf1,
     void const* _Buf2,
                            size_t      _Size
 int __cdecl _memicmp_l(
     void const* _Buf1,
     void const* _Buf2,
                            size_t      _Size,
                        _locale_t   _Locale
#line 56 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
#line 71 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_memccpy" ". See online help for details."))
     void* __cdecl memccpy(
         void*       _Dst,
           void const* _Src,
                                  int         _Val,
                                  size_t      _Size
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_memicmp" ". See online help for details."))
     int __cdecl memicmp(
         void const* _Buf1,
         void const* _Buf2,
                                size_t      _Size
#line 111 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
#pragma once
     errno_t __cdecl wcscat_s(
         wchar_t* _Destination,
         rsize_t _SizeInWords,
         wchar_t const* _Source
     errno_t __cdecl wcscpy_s(
     errno_t __cdecl wcsncat_s(
              wchar_t const* _Source,
                                    rsize_t        _MaxCount
     errno_t __cdecl wcsncpy_s(
                                 rsize_t        _MaxCount
     wchar_t* __cdecl wcstok_s(
                         wchar_t*       _String,
                                wchar_t const* _Delimiter,
          wchar_t**      _Context
 __declspec(allocator) wchar_t* __cdecl _wcsdup(
     wchar_t const* _String
#pragma warning(disable: 28719)
#pragma warning(disable: 28726)
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "wcscat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcscat( wchar_t *_Destination, wchar_t const* _Source);
 int __cdecl wcscmp(
     wchar_t const* _String1,
     wchar_t const* _String2
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcscpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcscpy( wchar_t *_Destination, wchar_t const* _Source);
 size_t __cdecl wcscspn(
     wchar_t const* _String,
     wchar_t const* _Control
 size_t __cdecl wcslen(
 size_t __cdecl wcsnlen(
                           size_t         _MaxCount
    static __inline size_t __cdecl wcsnlen_s(
                               size_t         _MaxCount
        return (_Source == 0) ? 0 : wcsnlen(_Source, _MaxCount);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcsncat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcsncat( wchar_t *_Destination, wchar_t const* _Source, size_t _Count);
 int __cdecl wcsncmp(
     wchar_t const* _String2,
                           size_t         _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcsncpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcsncpy( wchar_t *_Destination, wchar_t const* _Source, size_t _Count);
 wchar_t * __cdecl wcspbrk(
 size_t __cdecl wcsspn(
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstok_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl wcstok(
                         wchar_t*       _String,
      wchar_t**      _Context
#line 242 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
    #pragma warning(disable: 4141 4996)
    #pragma warning(disable: 28719 28726 28727)
    static __inline wchar_t* __cdecl _wcstok(
         wchar_t*       const _String,
                wchar_t const* const _Delimiter
        return wcstok(_String, _Delimiter, 0);
#line 269 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcserror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wcserror(
     int _ErrorNumber
 errno_t __cdecl _wcserror_s(
     wchar_t* _Buffer,
                                 int      _ErrorNumber
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "__wcserror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl __wcserror(
  errno_t __cdecl __wcserror_s(
     wchar_t*       _Buffer,
                               wchar_t const* _ErrorMessage
  int __cdecl _wcsicmp(
  int __cdecl _wcsicmp_l(
     _locale_t      _Locale
  int __cdecl _wcsnicmp(
                           size_t         _MaxCount
  int __cdecl _wcsnicmp_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
  errno_t __cdecl _wcsnset_s(
                                wchar_t  _Value,
                                size_t   _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsnset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsnset( wchar_t *_String, wchar_t _Value, size_t _MaxCount);
 wchar_t* __cdecl _wcsrev(
     wchar_t* _String
  errno_t __cdecl _wcsset_s(
                                wchar_t  _Value
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsset( wchar_t *_String, wchar_t _Value);
  errno_t __cdecl _wcslwr_s(
     wchar_t* _String,
                                size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcslwr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcslwr( wchar_t *_String);
 errno_t __cdecl _wcslwr_s_l(
     wchar_t*  _String,
                            _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcslwr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcslwr_l( wchar_t *_String, _locale_t _Locale);
 errno_t __cdecl _wcsupr_s(
     wchar_t* _String,
                         size_t   _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsupr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsupr( wchar_t *_String);
 errno_t __cdecl _wcsupr_s_l(
     wchar_t*  _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsupr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsupr_l( wchar_t *_String, _locale_t _Locale);
 size_t __cdecl wcsxfrm(
              size_t         _MaxCount
 size_t __cdecl _wcsxfrm_l(
              size_t         _MaxCount,
                                      _locale_t      _Locale
 int __cdecl wcscoll(
 int __cdecl _wcscoll_l(
     _locale_t      _Locale
 int __cdecl _wcsicoll(
 int __cdecl _wcsicoll_l(
     _locale_t      _Locale
 int __cdecl _wcsncoll(
                           size_t         _MaxCount
 int __cdecl _wcsncoll_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
 int __cdecl _wcsnicoll(
                           size_t         _MaxCount
 int __cdecl _wcsnicoll_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
#line 565 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsdup" ". See online help for details."))
     wchar_t* __cdecl wcsdup(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsicmp" ". See online help for details."))
     int __cdecl wcsicmp(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsnicmp" ". See online help for details."))
     int __cdecl wcsnicmp(
                               size_t         _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsnset" ". See online help for details."))
     wchar_t* __cdecl wcsnset(
         wchar_t* _String,
                                 wchar_t  _Value,
                                 size_t   _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsrev" ". See online help for details."))
     wchar_t* __cdecl wcsrev(
         wchar_t* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsset" ". See online help for details."))
     wchar_t* __cdecl wcsset(
         wchar_t* _String,
              wchar_t  _Value
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcslwr" ". See online help for details."))
     wchar_t* __cdecl wcslwr(
         wchar_t* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsupr" ". See online help for details."))
     wchar_t* __cdecl wcsupr(
         wchar_t* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsicoll" ". See online help for details."))
     int __cdecl wcsicoll(
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
__pragma(pack(push, 8))
     errno_t __cdecl strcpy_s(
         char*       _Destination,
                                 rsize_t     _SizeInBytes,
                               char const* _Source
     errno_t __cdecl strcat_s(
         char*       _Destination,
                                  char const* _Source
     errno_t __cdecl strerror_s(
         char*  _Buffer,
                                 int    _ErrorNumber);
     errno_t __cdecl strncat_s(
         char*       _Destination,
              char const* _Source,
                                    rsize_t     _MaxCount
     errno_t __cdecl strncpy_s(
         char*       _Destination,
                                 rsize_t     _MaxCount
     char*  __cdecl strtok_s(
                         char*       _String,
                                char const* _Delimiter,
          char**      _Context
 void* __cdecl _memccpy(
     void*       _Dst,
                                  void const* _Src,
                                  int         _Val,
                                  size_t      _MaxCount
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "strcat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strcat( char *_Destination, char const* _Source);
int __cdecl strcmp(
     char const* _Str1,
     char const* _Str2
 int __cdecl _strcmpi(
     char const* _String1,
     char const* _String2
 int __cdecl strcoll(
 int __cdecl _strcoll_l(
       char const* _String2,
     _locale_t   _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strcpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strcpy( char *_Destination, char const* _Source);
 size_t __cdecl strcspn(
     char const* _Str,
     char const* _Control
 __declspec(allocator) char* __cdecl _strdup(
     char const* _Source
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_strerror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char*  __cdecl _strerror(
     char const* _ErrorMessage
 errno_t __cdecl _strerror_s(
     char*       _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl strerror(
     int _ErrorMessage
 int __cdecl _stricmp(
 int __cdecl _stricoll(
 int __cdecl _stricoll_l(
     _locale_t   _Locale
 int __cdecl _stricmp_l(
     _locale_t   _Locale
size_t __cdecl strlen(
     char const* _Str
 errno_t __cdecl _strlwr_s(
     char*  _String,
                         size_t _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strlwr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strlwr( char *_String);
 errno_t __cdecl _strlwr_s_l(
     char*     _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strlwr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strlwr_l( char *_String, _locale_t _Locale);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strncat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strncat( char *_Destination, char const* _Source, size_t _Count);
 int __cdecl strncmp(
     char const* _Str1,
     char const* _Str2,
                           size_t      _MaxCount
 int __cdecl _strnicmp(
                           size_t      _MaxCount
 int __cdecl _strnicmp_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 int __cdecl _strnicoll(
                           size_t      _MaxCount
 int __cdecl _strnicoll_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 int __cdecl _strncoll(
                           size_t      _MaxCount
 int __cdecl _strncoll_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 size_t __cdecl __strncnt(
     char const* _String,
                        size_t      _Count
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strncpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strncpy( char *_Destination, char const* _Source, size_t _Count);
 size_t __cdecl strnlen(
                           size_t      _MaxCount
    static __inline size_t __cdecl strnlen_s(
                               size_t      _MaxCount
        return _String == 0 ? 0 : strnlen(_String, _MaxCount);
 errno_t __cdecl _strnset_s(
     char*  _String,
                                int    _Value,
                                size_t _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strnset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strnset( char *_Destination, int _Value, size_t _Count);
 char * __cdecl strpbrk(
     char const* _Str,
 char* __cdecl _strrev(
     char* _Str
 errno_t __cdecl _strset_s(
     char*  _Destination,
                                    size_t _DestinationSize,
                                    int    _Value
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strset( char *_Destination, int _Value);
 size_t __cdecl strspn(
     char const* _Str,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "strtok_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl strtok(
     char*       _String,
 errno_t __cdecl _strupr_s(
     char*  _String,
                         size_t _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strupr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strupr( char *_String);
 errno_t __cdecl _strupr_s_l(
     char*     _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strupr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strupr_l( char *_String, _locale_t _Locale);
 size_t __cdecl strxfrm(
      char*       _Destination,
               size_t      _MaxCount
 size_t __cdecl _strxfrm_l(
      char*       _Destination,
               size_t      _MaxCount,
                                      _locale_t   _Locale
#line 528 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strdup" ". See online help for details."))
     char* __cdecl strdup(
         char const* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strcmpi" ". See online help for details."))
     int __cdecl strcmpi(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_stricmp" ". See online help for details."))
     int __cdecl stricmp(
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strlwr" ". See online help for details."))
     char* __cdecl strlwr(
         char* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strnicmp" ". See online help for details."))
     int __cdecl strnicmp(
                               size_t      _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strnset" ". See online help for details."))
     char* __cdecl strnset(
         char*  _String,
                                 int    _Value,
                                 size_t _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strrev" ". See online help for details."))
     char* __cdecl strrev(
         char* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strset" ". See online help for details."))
    char* __cdecl strset(
         char* _String,
              int   _Value);
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strupr" ". See online help for details."))
     char* __cdecl strupr(
         char* _String
__pragma(pack(pop))
#line 147 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 165 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\guiddef.h"
#line 1154 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct  _OBJECTID {
    GUID Lineage;
    DWORD Uniquifier;
} OBJECTID;
#line 1173 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1302 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef
__stdcall
EXCEPTION_ROUTINE (
     struct _EXCEPTION_RECORD *ExceptionRecord,
     PVOID EstablisherFrame,
     struct _CONTEXT *ContextRecord,
     PVOID DispatcherContext
typedef EXCEPTION_ROUTINE *PEXCEPTION_ROUTINE;
#line 1412 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1577 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1769 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1819 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2059 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2083 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2200 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2300 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2333 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2360 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2428 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2509 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef ULONG_PTR KSPIN_LOCK;
typedef KSPIN_LOCK *PKSPIN_LOCK;
typedef struct __declspec(align(16)) _M128A {
    ULONGLONG Low;
    LONGLONG High;
} M128A, *PM128A;
typedef struct __declspec(align(16)) _XSAVE_FORMAT {
    WORD   ControlWord;
    WORD   StatusWord;
    BYTE  TagWord;
    BYTE  Reserved1;
    WORD   ErrorOpcode;
    DWORD ErrorOffset;
    WORD   ErrorSelector;
    WORD   Reserved2;
    DWORD DataOffset;
    WORD   DataSelector;
    WORD   Reserved3;
    DWORD MxCsr;
    DWORD MxCsr_Mask;
    M128A FloatRegisters[8];
    M128A XmmRegisters[16];
    BYTE  Reserved4[96];
#line 2562 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
} XSAVE_FORMAT, *PXSAVE_FORMAT;
typedef struct __declspec(align(8)) _XSAVE_AREA_HEADER {
    DWORD64 Mask;
    DWORD64 CompactionMask;
    DWORD64 Reserved2[6];
} XSAVE_AREA_HEADER, *PXSAVE_AREA_HEADER;
typedef struct __declspec(align(16)) _XSAVE_AREA {
    XSAVE_FORMAT LegacyState;
    XSAVE_AREA_HEADER Header;
} XSAVE_AREA, *PXSAVE_AREA;
typedef struct _XSTATE_CONTEXT {
    DWORD64 Mask;
    DWORD Length;
    DWORD Reserved1;
     PXSAVE_AREA Area;
    PVOID Buffer;
} XSTATE_CONTEXT, *PXSTATE_CONTEXT;
typedef struct _SCOPE_TABLE_AMD64 {
    DWORD Count;
    struct {
        DWORD BeginAddress;
        DWORD EndAddress;
        DWORD HandlerAddress;
        DWORD JumpTarget;
    } ScopeRecord[1];
} SCOPE_TABLE_AMD64, *PSCOPE_TABLE_AMD64;
#line 2637 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2650 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
BOOLEAN
_bittest (
     LONG const *Base,
     LONG Offset
BOOLEAN
_bittestandcomplement (
     LONG *Base,
     LONG Offset
BOOLEAN
_bittestandset (
     LONG *Base,
     LONG Offset
BOOLEAN
_bittestandreset (
     LONG *Base,
     LONG Offset
BOOLEAN
_interlockedbittestandset (
      LONG volatile *Base,
     LONG Offset
BOOLEAN
_interlockedbittestandreset (
     LONG Offset
BOOLEAN
_bittest64 (
     LONG64 const *Base,
     LONG64 Offset
BOOLEAN
_bittestandcomplement64 (
     LONG64 *Base,
     LONG64 Offset
BOOLEAN
_bittestandset64 (
     LONG64 *Base,
     LONG64 Offset
BOOLEAN
_bittestandreset64 (
     LONG64 *Base,
     LONG64 Offset
BOOLEAN
_interlockedbittestandset64 (
      LONG64 volatile *Base,
     LONG64 Offset
BOOLEAN
_interlockedbittestandreset64 (
     LONG64 Offset
#pragma intrinsic(_bittest)
#pragma intrinsic(_bittestandcomplement)
#pragma intrinsic(_bittestandset)
#pragma intrinsic(_bittestandreset)
#pragma intrinsic(_interlockedbittestandset)
#pragma intrinsic(_interlockedbittestandreset)
#pragma intrinsic(_bittest64)
#pragma intrinsic(_bittestandcomplement64)
#pragma intrinsic(_bittestandset64)
#pragma intrinsic(_bittestandreset64)
#pragma intrinsic(_interlockedbittestandset64)
#pragma intrinsic(_interlockedbittestandreset64)
BOOLEAN
_BitScanForward (
     DWORD *Index,
     DWORD Mask
BOOLEAN
_BitScanReverse (
     DWORD *Index,
     DWORD Mask
BOOLEAN
_BitScanForward64 (
     DWORD *Index,
     DWORD64 Mask
BOOLEAN
_BitScanReverse64 (
     DWORD *Index,
     DWORD64 Mask
#pragma intrinsic(_BitScanForward)
#pragma intrinsic(_BitScanReverse)
#pragma intrinsic(_BitScanForward64)
#pragma intrinsic(_BitScanReverse64)
#line 2796 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2832 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2871 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2879 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 2887 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
SHORT
_InterlockedIncrement16 (
      SHORT volatile *Addend
SHORT
_InterlockedDecrement16 (
SHORT
_InterlockedCompareExchange16 (
      SHORT volatile *Destination,
     SHORT ExChange,
     SHORT Comperand
LONG
_InterlockedAnd (
      LONG volatile *Destination,
     LONG Value
LONG
_InterlockedOr (
     LONG Value
LONG
_InterlockedXor (
     LONG Value
LONG64
_InterlockedAnd64 (
      LONG64 volatile *Destination,
     LONG64 Value
LONG64
_InterlockedOr64 (
     LONG64 Value
LONG64
_InterlockedXor64 (
     LONG64 Value
LONG
_InterlockedIncrement (
      LONG volatile *Addend
LONG
_InterlockedDecrement (
LONG
_InterlockedExchange (
      LONG volatile *Target,
     LONG Value
LONG
_InterlockedExchangeAdd (
      LONG volatile *Addend,
     LONG Value
__forceinline
LONG
_InlineInterlockedAdd (
     LONG Value
    return _InterlockedExchangeAdd(Addend, Value) + Value;
LONG
_InterlockedCompareExchange (
     LONG ExChange,
     LONG Comperand
LONG64
_InterlockedIncrement64 (
      LONG64 volatile *Addend
LONG64
_InterlockedDecrement64 (
LONG64
_InterlockedExchange64 (
      LONG64 volatile *Target,
     LONG64 Value
LONG64
_InterlockedExchangeAdd64 (
      LONG64 volatile *Addend,
     LONG64 Value
__forceinline
LONG64
_InlineInterlockedAdd64 (
     LONG64 Value
    return _InterlockedExchangeAdd64(Addend, Value) + Value;
LONG64
_InterlockedCompareExchange64 (
     LONG64 ExChange,
     LONG64 Comperand
BOOLEAN
_InterlockedCompareExchange128 (
     LONG64 ExchangeHigh,
     LONG64 ExchangeLow,
     LONG64 *ComparandResult
 PVOID
_InterlockedCompareExchangePointer (
     PVOID volatile *Destination,
     PVOID Exchange,
     PVOID Comperand
 PVOID
_InterlockedExchangePointer(
     PVOID volatile *Target,
     PVOID Value
#pragma intrinsic(_InterlockedIncrement16)
#pragma intrinsic(_InterlockedDecrement16)
#pragma intrinsic(_InterlockedCompareExchange16)
#pragma intrinsic(_InterlockedAnd)
#pragma intrinsic(_InterlockedOr)
#pragma intrinsic(_InterlockedXor)
#pragma intrinsic(_InterlockedIncrement)
#pragma intrinsic(_InterlockedDecrement)
#pragma intrinsic(_InterlockedExchange)
#pragma intrinsic(_InterlockedExchangeAdd)
#pragma intrinsic(_InterlockedCompareExchange)
#pragma intrinsic(_InterlockedAnd64)
#pragma intrinsic(_InterlockedOr64)
#pragma intrinsic(_InterlockedXor64)
#pragma intrinsic(_InterlockedIncrement64)
#pragma intrinsic(_InterlockedDecrement64)
#pragma intrinsic(_InterlockedExchange64)
#pragma intrinsic(_InterlockedExchangeAdd64)
#pragma intrinsic(_InterlockedCompareExchange64)
#pragma intrinsic(_InterlockedCompareExchange128)
#pragma intrinsic(_InterlockedExchangePointer)
#pragma intrinsic(_InterlockedCompareExchangePointer)
CHAR
_InterlockedExchange8 (
      CHAR volatile *Target,
     CHAR Value
SHORT
_InterlockedExchange16 (
     SHORT ExChange
#pragma intrinsic(_InterlockedExchange8)
#pragma intrinsic(_InterlockedExchange16)
#line 3116 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
char
_InterlockedExchangeAdd8 (
      char volatile * _Addend,
     char _Value
char
_InterlockedAnd8 (
      char volatile *Destination,
     char Value
char
_InterlockedOr8 (
     char Value
char
_InterlockedXor8 (
     char Value
SHORT
_InterlockedAnd16(
     SHORT Value
SHORT
_InterlockedOr16(
     SHORT Value
SHORT
_InterlockedXor16(
     SHORT Value
#pragma intrinsic (_InterlockedExchangeAdd8)
#pragma intrinsic (_InterlockedAnd8)
#pragma intrinsic (_InterlockedOr8)
#pragma intrinsic (_InterlockedXor8)
#pragma intrinsic (_InterlockedAnd16)
#pragma intrinsic (_InterlockedOr16)
#pragma intrinsic (_InterlockedXor16)
void
__cpuidex (
    int CPUInfo[4],
    int Function,
    int SubLeaf
#pragma intrinsic(__cpuidex)
void
_mm_clflush (
     void const *Address
#pragma intrinsic(_mm_clflush)
void
_ReadWriteBarrier (
    void
#pragma intrinsic(_ReadWriteBarrier)
void
__faststorefence (
    void
void
_mm_lfence (
    void
void
_mm_mfence (
    void
void
_mm_sfence (
    void
void
_mm_pause (
    void
void
_mm_prefetch (
     CHAR const *a,
     int sel
void
_m_prefetchw (
     volatile const void *Source
#pragma intrinsic(__faststorefence)
#pragma intrinsic(_mm_pause)
#pragma intrinsic(_mm_prefetch)
#pragma intrinsic(_mm_lfence)
#pragma intrinsic(_mm_mfence)
#pragma intrinsic(_mm_sfence)
#pragma intrinsic(_m_prefetchw)
unsigned int
_mm_getcsr (
    void
void
_mm_setcsr (
     unsigned int MxCsr
#pragma intrinsic(_mm_getcsr)
#pragma intrinsic(_mm_setcsr)
unsigned __int32
__getcallerseflags (
    void
#pragma intrinsic(__getcallerseflags)
DWORD
__segmentlimit (
     DWORD Selector
#pragma intrinsic(__segmentlimit)
DWORD64
__readpmc (
     DWORD Counter
#pragma intrinsic(__readpmc)
DWORD64
__rdtsc (
    void
#pragma intrinsic(__rdtsc)
void
__movsb (
     PBYTE  Destination,
     BYTE  const *Source,
     SIZE_T Count
void
__movsw (
     PWORD   Destination,
     WORD   const *Source,
     SIZE_T Count
void
__movsd (
     PDWORD Destination,
     DWORD const *Source,
     SIZE_T Count
void
__movsq (
     PDWORD64 Destination,
     DWORD64 const *Source,
     SIZE_T Count
#pragma intrinsic(__movsb)
#pragma intrinsic(__movsw)
#pragma intrinsic(__movsd)
#pragma intrinsic(__movsq)
void
__stosb (
     PBYTE  Destination,
     BYTE  Value,
     SIZE_T Count
void
__stosw (
     PWORD   Destination,
     WORD   Value,
     SIZE_T Count
void
__stosd (
     PDWORD Destination,
     DWORD Value,
     SIZE_T Count
void
__stosq (
     DWORD64 Value,
     SIZE_T Count
#pragma intrinsic(__stosb)
#pragma intrinsic(__stosw)
#pragma intrinsic(__stosd)
#pragma intrinsic(__stosq)
LONGLONG
__mulh (
     LONG64 Multiplier,
     LONG64 Multiplicand
ULONGLONG
__umulh (
     DWORD64 Multiplier,
     DWORD64 Multiplicand
#pragma intrinsic(__mulh)
#pragma intrinsic(__umulh)
DWORD64
__popcnt64 (
     DWORD64 operand
#pragma intrinsic(__popcnt64)
DWORD64
__shiftleft128 (
     DWORD64 LowPart,
     DWORD64 HighPart,
     BYTE  Shift
DWORD64
__shiftright128 (
     DWORD64 LowPart,
     DWORD64 HighPart,
     BYTE  Shift
#pragma intrinsic(__shiftleft128)
#pragma intrinsic(__shiftright128)
LONG64
_mul128 (
     LONG64 Multiplier,
     LONG64 Multiplicand,
     LONG64 *HighProduct
#pragma intrinsic(_mul128)
DWORD64
_umul128 (
     DWORD64 Multiplier,
     DWORD64 Multiplicand,
     DWORD64 *HighProduct
#pragma intrinsic(_umul128)
__forceinline
LONG64
MultiplyExtract128 (
     LONG64 Multiplier,
     BYTE  Shift
    LONG64 extractedProduct;
    LONG64 highProduct;
    LONG64 lowProduct;
    BOOLEAN negate;
    DWORD64 uhighProduct;
    DWORD64 ulowProduct;
    lowProduct = _mul128(Multiplier, Multiplicand, &highProduct);
    negate = 0;
    uhighProduct = (DWORD64)highProduct;
    ulowProduct = (DWORD64)lowProduct;
    if (highProduct < 0) {
        negate = 1;
        uhighProduct = (DWORD64)(-highProduct);
        ulowProduct = (DWORD64)(-lowProduct);
        if (ulowProduct != 0) {
            uhighProduct -= 1;
    extractedProduct = (LONG64)__shiftright128(ulowProduct, uhighProduct, Shift);
    if (negate != 0) {
        extractedProduct = -extractedProduct;
    return extractedProduct;
__forceinline
DWORD64
UnsignedMultiplyExtract128 (
     DWORD64 Multiplier,
     BYTE  Shift
    DWORD64 extractedProduct;
    DWORD64 highProduct;
    DWORD64 lowProduct;
    lowProduct = _umul128(Multiplier, Multiplicand, &highProduct);
    extractedProduct = __shiftright128(lowProduct, highProduct, Shift);
BYTE
__readgsbyte (
     DWORD Offset
WORD
__readgsword (
     DWORD Offset
DWORD
__readgsdword (
     DWORD Offset
DWORD64
__readgsqword (
     DWORD Offset
void
__writegsbyte (
     DWORD Offset,
     BYTE  Data
void
__writegsword (
     DWORD Offset,
     WORD   Data
void
__writegsdword (
     DWORD Offset,
     DWORD Data
void
__writegsqword (
     DWORD Offset,
     DWORD64 Data
#pragma intrinsic(__readgsbyte)
#pragma intrinsic(__readgsword)
#pragma intrinsic(__readgsdword)
#pragma intrinsic(__readgsqword)
#pragma intrinsic(__writegsbyte)
#pragma intrinsic(__writegsword)
#pragma intrinsic(__writegsdword)
#pragma intrinsic(__writegsqword)
void
__incgsbyte (
     DWORD Offset
void
__addgsbyte (
     DWORD Offset,
     BYTE  Value
void
__incgsword (
     DWORD Offset
void
__addgsword (
     DWORD Offset,
     WORD   Value
void
__incgsdword (
     DWORD Offset
void
__addgsdword (
     DWORD Offset,
     DWORD Value
void
__incgsqword (
     DWORD Offset
void
__addgsqword (
     DWORD Offset,
     DWORD64 Value
#line 3714 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef XSAVE_FORMAT XMM_SAVE_AREA32, *PXMM_SAVE_AREA32;
typedef struct __declspec(align(16)) _CONTEXT {
    DWORD64 P1Home;
    DWORD64 P2Home;
    DWORD64 P3Home;
    DWORD64 P4Home;
    DWORD64 P5Home;
    DWORD64 P6Home;
    DWORD ContextFlags;
    DWORD MxCsr;
    WORD   SegCs;
    WORD   SegDs;
    WORD   SegEs;
    WORD   SegFs;
    WORD   SegGs;
    WORD   SegSs;
    DWORD EFlags;
    DWORD64 Dr0;
    DWORD64 Dr1;
    DWORD64 Dr2;
    DWORD64 Dr3;
    DWORD64 Dr6;
    DWORD64 Dr7;
    DWORD64 Rax;
    DWORD64 Rcx;
    DWORD64 Rdx;
    DWORD64 Rbx;
    DWORD64 Rsp;
    DWORD64 Rbp;
    DWORD64 Rsi;
    DWORD64 Rdi;
    DWORD64 R8;
    DWORD64 R9;
    DWORD64 R10;
    DWORD64 R11;
    DWORD64 R12;
    DWORD64 R13;
    DWORD64 R14;
    DWORD64 R15;
    DWORD64 Rip;
    union {
        XMM_SAVE_AREA32 FltSave;
        struct {
            M128A Header[2];
            M128A Legacy[8];
            M128A Xmm0;
            M128A Xmm1;
            M128A Xmm2;
            M128A Xmm3;
            M128A Xmm4;
            M128A Xmm5;
            M128A Xmm6;
            M128A Xmm7;
            M128A Xmm8;
            M128A Xmm9;
            M128A Xmm10;
            M128A Xmm11;
            M128A Xmm12;
            M128A Xmm13;
            M128A Xmm14;
            M128A Xmm15;
    M128A VectorRegister[26];
    DWORD64 VectorControl;
    DWORD64 DebugControl;
    DWORD64 LastBranchToRip;
    DWORD64 LastBranchFromRip;
    DWORD64 LastExceptionToRip;
    DWORD64 LastExceptionFromRip;
} CONTEXT, *PCONTEXT;
typedef struct _IMAGE_RUNTIME_FUNCTION_ENTRY RUNTIME_FUNCTION, *PRUNTIME_FUNCTION;
typedef SCOPE_TABLE_AMD64 SCOPE_TABLE, *PSCOPE_TABLE;
typedef struct _UNWIND_HISTORY_TABLE_ENTRY {
    DWORD64 ImageBase;
    PRUNTIME_FUNCTION FunctionEntry;
} UNWIND_HISTORY_TABLE_ENTRY, *PUNWIND_HISTORY_TABLE_ENTRY;
typedef struct _UNWIND_HISTORY_TABLE {
    DWORD Count;
    BYTE  LocalHint;
    BYTE  GlobalHint;
    BYTE  Search;
    BYTE  Once;
    DWORD64 LowAddress;
    DWORD64 HighAddress;
    UNWIND_HISTORY_TABLE_ENTRY Entry[12];
} UNWIND_HISTORY_TABLE, *PUNWIND_HISTORY_TABLE;
typedef
PRUNTIME_FUNCTION
GET_RUNTIME_FUNCTION_CALLBACK (
     DWORD64 ControlPc,
     PVOID Context
typedef GET_RUNTIME_FUNCTION_CALLBACK *PGET_RUNTIME_FUNCTION_CALLBACK;
typedef
DWORD
OUT_OF_PROCESS_FUNCTION_TABLE_CALLBACK (
     HANDLE Process,
     PVOID TableAddress,
     PDWORD Entries,
     PRUNTIME_FUNCTION* Functions
typedef OUT_OF_PROCESS_FUNCTION_TABLE_CALLBACK *POUT_OF_PROCESS_FUNCTION_TABLE_CALLBACK;
typedef struct _DISPATCHER_CONTEXT {
    DWORD64 ControlPc;
    DWORD64 ImageBase;
    DWORD64 EstablisherFrame;
    DWORD64 TargetIp;
    PCONTEXT ContextRecord;
    PEXCEPTION_ROUTINE LanguageHandler;
    PVOID HandlerData;
    PUNWIND_HISTORY_TABLE HistoryTable;
    DWORD ScopeIndex;
    DWORD Fill0;
} DISPATCHER_CONTEXT, *PDISPATCHER_CONTEXT;
struct _EXCEPTION_POINTERS;
typedef
LONG
(*PEXCEPTION_FILTER) (
    struct _EXCEPTION_POINTERS *ExceptionPointers,
typedef
void
(*PTERMINATION_HANDLER) (
    BOOLEAN _abnormal_termination,
typedef struct _KNONVOLATILE_CONTEXT_POINTERS {
    union {
        PM128A FloatingContext[16];
        struct {
            PM128A Xmm0;
            PM128A Xmm1;
            PM128A Xmm2;
            PM128A Xmm3;
            PM128A Xmm4;
            PM128A Xmm5;
            PM128A Xmm6;
            PM128A Xmm7;
            PM128A Xmm8;
            PM128A Xmm9;
            PM128A Xmm10;
            PM128A Xmm11;
            PM128A Xmm12;
            PM128A Xmm13;
            PM128A Xmm14;
            PM128A Xmm15;
    union {
        PDWORD64 IntegerContext[16];
        struct {
            PDWORD64 Rax;
            PDWORD64 Rcx;
            PDWORD64 Rdx;
            PDWORD64 Rbx;
            PDWORD64 Rsp;
            PDWORD64 Rbp;
            PDWORD64 Rsi;
            PDWORD64 Rdi;
            PDWORD64 R8;
            PDWORD64 R9;
            PDWORD64 R10;
            PDWORD64 R11;
            PDWORD64 R12;
            PDWORD64 R13;
            PDWORD64 R14;
            PDWORD64 R15;
} KNONVOLATILE_CONTEXT_POINTERS, *PKNONVOLATILE_CONTEXT_POINTERS;
typedef struct _SCOPE_TABLE_ARM {
    DWORD Count;
    struct
        DWORD BeginAddress;
        DWORD EndAddress;
        DWORD JumpTarget;
    } ScopeRecord[1];
} SCOPE_TABLE_ARM, *PSCOPE_TABLE_ARM;
#line 5075 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _SCOPE_TABLE_ARM64 {
    DWORD Count;
    struct
        DWORD BeginAddress;
        DWORD EndAddress;
        DWORD JumpTarget;
    } ScopeRecord[1];
} SCOPE_TABLE_ARM64, *PSCOPE_TABLE_ARM64;
#line 6260 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _KNONVOLATILE_CONTEXT_POINTERS_ARM64 {
    PDWORD64 X19;
    PDWORD64 X20;
    PDWORD64 X21;
    PDWORD64 X22;
    PDWORD64 X23;
    PDWORD64 X24;
    PDWORD64 X25;
    PDWORD64 X26;
    PDWORD64 X27;
    PDWORD64 X28;
    PDWORD64 Fp;
    PDWORD64 Lr;
    PDWORD64 D8;
    PDWORD64 D9;
    PDWORD64 D10;
    PDWORD64 D11;
    PDWORD64 D12;
    PDWORD64 D13;
    PDWORD64 D14;
    PDWORD64 D15;
} KNONVOLATILE_CONTEXT_POINTERS_ARM64, *PKNONVOLATILE_CONTEXT_POINTERS_ARM64;
#line 6311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 6336 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
void
__int2c (
    void
#pragma intrinsic(__int2c)
#line 6463 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 7628 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _LDT_ENTRY {
    WORD    LimitLow;
    WORD    BaseLow;
    union {
        struct {
            BYTE    BaseMid;
            BYTE    Flags1;
            BYTE    Flags2;
            BYTE    BaseHi;
        } Bytes;
        struct {
            DWORD   BaseMid : 8;
            DWORD   Type : 5;
            DWORD   Dpl : 2;
            DWORD   Pres : 1;
            DWORD   LimitHi : 4;
            DWORD   Sys : 1;
            DWORD   Reserved_0 : 1;
            DWORD   Default_Big : 1;
            DWORD   Granularity : 1;
            DWORD   BaseHi : 8;
        } Bits;
    } HighWord;
} LDT_ENTRY, *PLDT_ENTRY;
__forceinline
CHAR
ReadAcquire8 (
      CHAR const volatile *Source
    CHAR Value;
    Value = *Source;
    return Value;
__forceinline
CHAR
ReadNoFence8 (
    CHAR Value;
    Value = *Source;
    return Value;
__forceinline
void
WriteRelease8 (
      CHAR volatile *Destination,
     CHAR Value
    *Destination = Value;
    return;
__forceinline
void
WriteNoFence8 (
     CHAR Value
    return;
__forceinline
SHORT
ReadAcquire16 (
      SHORT const volatile *Source
    SHORT Value;
    Value = *Source;
    return Value;
__forceinline
SHORT
ReadNoFence16 (
    SHORT Value;
    Value = *Source;
    return Value;
__forceinline
void
WriteRelease16 (
     SHORT Value
    return;
__forceinline
void
WriteNoFence16 (
     SHORT Value
    return;
__forceinline
LONG
ReadAcquire (
      LONG const volatile *Source
    LONG Value;
    Value = *Source;
    return Value;
__forceinline
LONG
ReadNoFence (
    LONG Value;
    Value = *Source;
    return Value;
__forceinline
void
WriteRelease (
     LONG Value
    return;
__forceinline
void
WriteNoFence (
     LONG Value
    return;
__forceinline
LONG64
ReadAcquire64 (
      LONG64 const volatile *Source
    LONG64 Value;
    Value = *Source;
    return Value;
__forceinline
LONG64
ReadNoFence64 (
    LONG64 Value;
    Value = *Source;
    return Value;
__forceinline
void
WriteRelease64 (
     LONG64 Value
    return;
__forceinline
void
WriteNoFence64 (
     LONG64 Value
    return;
__forceinline
CHAR
ReadRaw8 (
    CHAR Value;
    Value = *(CHAR *)Source;
    return Value;
__forceinline
void
WriteRaw8 (
     CHAR Value
    *(CHAR *)Destination = Value;
    return;
__forceinline
SHORT
ReadRaw16 (
    SHORT Value;
    Value = *(SHORT *)Source;
    return Value;
__forceinline
void
WriteRaw16 (
     SHORT Value
    *(SHORT *)Destination = Value;
    return;
__forceinline
LONG
ReadRaw (
    LONG Value;
    Value = *(LONG *)Source;
    return Value;
__forceinline
void
WriteRaw (
     LONG Value
    *(LONG *)Destination = Value;
    return;
__forceinline
LONG64
ReadRaw64 (
    LONG64 Value;
    Value = *(LONG64 *)Source;
    return Value;
__forceinline
void
WriteRaw64 (
     LONG64 Value
    *(LONG64 *)Destination = Value;
    return;
__forceinline
BYTE
ReadUCharAcquire (
      BYTE  const volatile *Source
    return (BYTE )ReadAcquire8((PCHAR)Source);
__forceinline
BYTE
ReadUCharNoFence (
    return (BYTE )ReadNoFence8((PCHAR)Source);
__forceinline
BYTE
ReadBooleanAcquire (
      BOOLEAN const volatile *Source
    return (BOOLEAN)ReadAcquire8((PCHAR)Source);
__forceinline
BYTE
ReadBooleanNoFence (
    return (BOOLEAN)ReadNoFence8((PCHAR)Source);
__forceinline
BYTE
ReadUCharRaw (
    return (BYTE )ReadRaw8((PCHAR)Source);
__forceinline
void
WriteUCharRelease (
      BYTE  volatile *Destination,
     BYTE  Value
    WriteRelease8((PCHAR)Destination, (CHAR)Value);
    return;
__forceinline
void
WriteUCharNoFence (
     BYTE  Value
    WriteNoFence8((PCHAR)Destination, (CHAR)Value);
    return;
__forceinline
void
WriteBooleanRelease (
      BOOLEAN volatile *Destination,
     BOOLEAN Value
    return;
__forceinline
void
WriteBooleanNoFence (
     BOOLEAN Value
    return;
__forceinline
void
WriteUCharRaw (
     BYTE  Value
    WriteRaw8((PCHAR)Destination, (CHAR)Value);
    return;
__forceinline
WORD
ReadUShortAcquire (
      WORD   const volatile *Source
    return (WORD  )ReadAcquire16((PSHORT)Source);
__forceinline
WORD
ReadUShortNoFence (
    return (WORD  )ReadNoFence16((PSHORT)Source);
__forceinline
WORD
ReadUShortRaw (
    return (WORD  )ReadRaw16((PSHORT)Source);
__forceinline
void
WriteUShortRelease (
      WORD   volatile *Destination,
     WORD   Value
    WriteRelease16((PSHORT)Destination, (SHORT)Value);
    return;
__forceinline
void
WriteUShortNoFence (
     WORD   Value
    WriteNoFence16((PSHORT)Destination, (SHORT)Value);
    return;
__forceinline
void
WriteUShortRaw (
     WORD   Value
    WriteRaw16((PSHORT)Destination, (SHORT)Value);
    return;
__forceinline
DWORD
ReadULongAcquire (
      DWORD const volatile *Source
    return (DWORD)ReadAcquire((PLONG)Source);
__forceinline
DWORD
ReadULongNoFence (
    return (DWORD)ReadNoFence((PLONG)Source);
__forceinline
DWORD
ReadULongRaw (
    return (DWORD)ReadRaw((PLONG)Source);
__forceinline
void
WriteULongRelease (
      DWORD volatile *Destination,
     DWORD Value
    WriteRelease((PLONG)Destination, (LONG)Value);
    return;
__forceinline
void
WriteULongNoFence (
     DWORD Value
    WriteNoFence((PLONG)Destination, (LONG)Value);
    return;
__forceinline
void
WriteULongRaw (
     DWORD Value
    WriteRaw((PLONG)Destination, (LONG)Value);
    return;
__forceinline
DWORD64
ReadULong64Acquire (
      DWORD64 const volatile *Source
    return (DWORD64)ReadAcquire64((PLONG64)Source);
__forceinline
DWORD64
ReadULong64NoFence (
    return (DWORD64)ReadNoFence64((PLONG64)Source);
__forceinline
DWORD64
ReadULong64Raw (
    return (DWORD64)ReadRaw64((PLONG64)Source);
__forceinline
void
WriteULong64Release (
      DWORD64 volatile *Destination,
     DWORD64 Value
    WriteRelease64((PLONG64)Destination, (LONG64)Value);
    return;
__forceinline
void
WriteULong64NoFence (
     DWORD64 Value
    WriteNoFence64((PLONG64)Destination, (LONG64)Value);
    return;
__forceinline
void
WriteULong64Raw (
     DWORD64 Value
    WriteRaw64((PLONG64)Destination, (LONG64)Value);
    return;
#line 8455 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
__forceinline
PVOID
ReadPointerAcquire (
      PVOID const volatile *Source
    return (PVOID)ReadAcquire64((PLONG64)Source);
__forceinline
PVOID
ReadPointerNoFence (
    return (PVOID)ReadNoFence64((PLONG64)Source);
__forceinline
PVOID
ReadPointerRaw (
    return (PVOID)ReadRaw64((PLONG64)Source);
__forceinline
void
WritePointerRelease (
     PVOID Value
    return;
__forceinline
void
WritePointerNoFence (
     PVOID Value
    return;
__forceinline
void
WritePointerRaw (
     PVOID Value
    return;
#line 8570 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _WOW64_FLOATING_SAVE_AREA {
    DWORD   ControlWord;
    DWORD   StatusWord;
    DWORD   TagWord;
    DWORD   ErrorOffset;
    DWORD   ErrorSelector;
    DWORD   DataOffset;
    DWORD   DataSelector;
    BYTE    RegisterArea[80];
    DWORD   Cr0NpxState;
} WOW64_FLOATING_SAVE_AREA;
typedef WOW64_FLOATING_SAVE_AREA *PWOW64_FLOATING_SAVE_AREA;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\pshpack4.h"
#pragma warning(disable:4103)
#pragma pack(push,4)
#line 8609 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _WOW64_CONTEXT {
    DWORD ContextFlags;
    DWORD   Dr0;
    DWORD   Dr1;
    DWORD   Dr2;
    DWORD   Dr3;
    DWORD   Dr6;
    DWORD   Dr7;
    WOW64_FLOATING_SAVE_AREA FloatSave;
    DWORD   SegGs;
    DWORD   SegFs;
    DWORD   SegEs;
    DWORD   SegDs;
    DWORD   Edi;
    DWORD   Esi;
    DWORD   Ebx;
    DWORD   Edx;
    DWORD   Ecx;
    DWORD   Eax;
    DWORD   Ebp;
    DWORD   Eip;
    DWORD   SegCs;
    DWORD   EFlags;
    DWORD   Esp;
    DWORD   SegSs;
    BYTE    ExtendedRegisters[512];
} WOW64_CONTEXT;
typedef WOW64_CONTEXT *PWOW64_CONTEXT;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\poppack.h"
#pragma pack(pop)
#line 8709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _WOW64_LDT_ENTRY {
    WORD    LimitLow;
    WORD    BaseLow;
    union {
        struct {
            BYTE    BaseMid;
            BYTE    Flags1;
            BYTE    Flags2;
            BYTE    BaseHi;
        } Bytes;
        struct {
            DWORD   BaseMid : 8;
            DWORD   Type : 5;
            DWORD   Dpl : 2;
            DWORD   Pres : 1;
            DWORD   LimitHi : 4;
            DWORD   Sys : 1;
            DWORD   BaseHi : 8;
        } Bits;
    } HighWord;
} WOW64_LDT_ENTRY, *PWOW64_LDT_ENTRY;
typedef struct _WOW64_DESCRIPTOR_TABLE_ENTRY {
    DWORD Selector;
    WOW64_LDT_ENTRY Descriptor;
} WOW64_DESCRIPTOR_TABLE_ENTRY, *PWOW64_DESCRIPTOR_TABLE_ENTRY;
#line 8748 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _EXCEPTION_RECORD {
    DWORD    ExceptionCode;
    DWORD ExceptionFlags;
    struct _EXCEPTION_RECORD *ExceptionRecord;
    PVOID ExceptionAddress;
    DWORD NumberParameters;
    ULONG_PTR ExceptionInformation[15];
    } EXCEPTION_RECORD;
typedef EXCEPTION_RECORD *PEXCEPTION_RECORD;
typedef struct _EXCEPTION_RECORD32 {
    DWORD ExceptionRecord;
    DWORD ExceptionAddress;
    DWORD ExceptionInformation[15];
} EXCEPTION_RECORD32, *PEXCEPTION_RECORD32;
typedef struct _EXCEPTION_RECORD64 {
    DWORD64 ExceptionRecord;
    DWORD64 ExceptionAddress;
    DWORD __unusedAlignment;
    DWORD64 ExceptionInformation[15];
} EXCEPTION_RECORD64, *PEXCEPTION_RECORD64;
typedef struct _EXCEPTION_POINTERS {
    PEXCEPTION_RECORD ExceptionRecord;
} EXCEPTION_POINTERS, *PEXCEPTION_POINTERS;
#line 8819 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef PVOID PACCESS_TOKEN;
typedef PVOID PSECURITY_DESCRIPTOR;
typedef PVOID PSID;
typedef PVOID PCLAIMS_BLOB;
typedef DWORD ACCESS_MASK;
typedef ACCESS_MASK *PACCESS_MASK;
typedef struct _GENERIC_MAPPING {
    ACCESS_MASK GenericRead;
    ACCESS_MASK GenericWrite;
    ACCESS_MASK GenericExecute;
    ACCESS_MASK GenericAll;
} GENERIC_MAPPING;
typedef GENERIC_MAPPING *PGENERIC_MAPPING;
#line 8943 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _LUID_AND_ATTRIBUTES {
    LUID Luid;
    DWORD Attributes;
    } LUID_AND_ATTRIBUTES, * PLUID_AND_ATTRIBUTES;
typedef LUID_AND_ATTRIBUTES LUID_AND_ATTRIBUTES_ARRAY[1];
typedef LUID_AND_ATTRIBUTES_ARRAY *PLUID_AND_ATTRIBUTES_ARRAY;
#pragma pack(pop)
#line 8952 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _SID_IDENTIFIER_AUTHORITY {
    BYTE  Value[6];
} SID_IDENTIFIER_AUTHORITY, *PSID_IDENTIFIER_AUTHORITY;
typedef struct _SID {
   BYTE  Revision;
   BYTE  SubAuthorityCount;
   SID_IDENTIFIER_AUTHORITY IdentifierAuthority;
   DWORD SubAuthority[1];
} SID, *PISID;
typedef union _SE_SID {
    SID Sid;
    BYTE  Buffer[(sizeof(SID) - sizeof(DWORD) + ((15) * sizeof(DWORD)))];
} SE_SID, *PSE_SID;
typedef enum _SID_NAME_USE {
    SidTypeUser = 1,
    SidTypeGroup,
    SidTypeDomain,
    SidTypeAlias,
    SidTypeWellKnownGroup,
    SidTypeDeletedAccount,
    SidTypeInvalid,
    SidTypeUnknown,
    SidTypeComputer,
    SidTypeLabel,
    SidTypeLogonSession
} SID_NAME_USE, *PSID_NAME_USE;
typedef struct _SID_AND_ATTRIBUTES {
    PSID Sid;
    DWORD Attributes;
    } SID_AND_ATTRIBUTES, * PSID_AND_ATTRIBUTES;
typedef SID_AND_ATTRIBUTES SID_AND_ATTRIBUTES_ARRAY[1];
typedef SID_AND_ATTRIBUTES_ARRAY *PSID_AND_ATTRIBUTES_ARRAY;
typedef ULONG_PTR SID_HASH_ENTRY, *PSID_HASH_ENTRY;
typedef struct _SID_AND_ATTRIBUTES_HASH {
    DWORD SidCount;
    PSID_AND_ATTRIBUTES SidAttr;
    SID_HASH_ENTRY Hash[32];
} SID_AND_ATTRIBUTES_HASH, *PSID_AND_ATTRIBUTES_HASH;
#line 9100 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9320 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9339 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9360 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9376 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9400 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9415 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9439 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9457 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum {
    WinNullSid                                  = 0,
    WinWorldSid                                 = 1,
    WinLocalSid                                 = 2,
    WinCreatorOwnerSid                          = 3,
    WinCreatorGroupSid                          = 4,
    WinCreatorOwnerServerSid                    = 5,
    WinCreatorGroupServerSid                    = 6,
    WinNtAuthoritySid                           = 7,
    WinDialupSid                                = 8,
    WinNetworkSid                               = 9,
    WinBatchSid                                 = 10,
    WinInteractiveSid                           = 11,
    WinServiceSid                               = 12,
    WinAnonymousSid                             = 13,
    WinProxySid                                 = 14,
    WinEnterpriseControllersSid                 = 15,
    WinSelfSid                                  = 16,
    WinAuthenticatedUserSid                     = 17,
    WinRestrictedCodeSid                        = 18,
    WinTerminalServerSid                        = 19,
    WinRemoteLogonIdSid                         = 20,
    WinLogonIdsSid                              = 21,
    WinLocalSystemSid                           = 22,
    WinLocalServiceSid                          = 23,
    WinNetworkServiceSid                        = 24,
    WinBuiltinDomainSid                         = 25,
    WinBuiltinAdministratorsSid                 = 26,
    WinBuiltinUsersSid                          = 27,
    WinBuiltinGuestsSid                         = 28,
    WinBuiltinPowerUsersSid                     = 29,
    WinBuiltinAccountOperatorsSid               = 30,
    WinBuiltinSystemOperatorsSid                = 31,
    WinBuiltinPrintOperatorsSid                 = 32,
    WinBuiltinBackupOperatorsSid                = 33,
    WinBuiltinReplicatorSid                     = 34,
    WinBuiltinPreWindows2000CompatibleAccessSid = 35,
    WinBuiltinRemoteDesktopUsersSid             = 36,
    WinBuiltinNetworkConfigurationOperatorsSid  = 37,
    WinAccountAdministratorSid                  = 38,
    WinAccountGuestSid                          = 39,
    WinAccountKrbtgtSid                         = 40,
    WinAccountDomainAdminsSid                   = 41,
    WinAccountDomainUsersSid                    = 42,
    WinAccountDomainGuestsSid                   = 43,
    WinAccountComputersSid                      = 44,
    WinAccountControllersSid                    = 45,
    WinAccountCertAdminsSid                     = 46,
    WinAccountSchemaAdminsSid                   = 47,
    WinAccountEnterpriseAdminsSid               = 48,
    WinAccountPolicyAdminsSid                   = 49,
    WinAccountRasAndIasServersSid               = 50,
    WinNTLMAuthenticationSid                    = 51,
    WinDigestAuthenticationSid                  = 52,
    WinSChannelAuthenticationSid                = 53,
    WinThisOrganizationSid                      = 54,
    WinOtherOrganizationSid                     = 55,
    WinBuiltinIncomingForestTrustBuildersSid    = 56,
    WinBuiltinPerfMonitoringUsersSid            = 57,
    WinBuiltinPerfLoggingUsersSid               = 58,
    WinBuiltinAuthorizationAccessSid            = 59,
    WinBuiltinTerminalServerLicenseServersSid   = 60,
    WinBuiltinDCOMUsersSid                      = 61,
    WinBuiltinIUsersSid                         = 62,
    WinIUserSid                                 = 63,
    WinBuiltinCryptoOperatorsSid                = 64,
    WinUntrustedLabelSid                        = 65,
    WinLowLabelSid                              = 66,
    WinMediumLabelSid                           = 67,
    WinHighLabelSid                             = 68,
    WinSystemLabelSid                           = 69,
    WinWriteRestrictedCodeSid                   = 70,
    WinCreatorOwnerRightsSid                    = 71,
    WinCacheablePrincipalsGroupSid              = 72,
    WinNonCacheablePrincipalsGroupSid           = 73,
    WinEnterpriseReadonlyControllersSid         = 74,
    WinAccountReadonlyControllersSid            = 75,
    WinBuiltinEventLogReadersGroup              = 76,
    WinNewEnterpriseReadonlyControllersSid      = 77,
    WinBuiltinCertSvcDComAccessGroup            = 78,
    WinMediumPlusLabelSid                       = 79,
    WinLocalLogonSid                            = 80,
    WinConsoleLogonSid                          = 81,
    WinThisOrganizationCertificateSid           = 82,
    WinApplicationPackageAuthoritySid           = 83,
    WinBuiltinAnyPackageSid                     = 84,
    WinCapabilityInternetClientSid              = 85,
    WinCapabilityInternetClientServerSid        = 86,
    WinCapabilityPrivateNetworkClientServerSid  = 87,
    WinCapabilityPicturesLibrarySid             = 88,
    WinCapabilityVideosLibrarySid               = 89,
    WinCapabilityMusicLibrarySid                = 90,
    WinCapabilityDocumentsLibrarySid            = 91,
    WinCapabilitySharedUserCertificatesSid      = 92,
    WinCapabilityEnterpriseAuthenticationSid    = 93,
    WinCapabilityRemovableStorageSid            = 94,
    WinBuiltinRDSRemoteAccessServersSid         = 95,
    WinBuiltinRDSEndpointServersSid             = 96,
    WinBuiltinRDSManagementServersSid           = 97,
    WinUserModeDriversSid                       = 98,
    WinBuiltinHyperVAdminsSid                   = 99,
    WinAccountCloneableControllersSid           = 100,
    WinBuiltinAccessControlAssistanceOperatorsSid = 101,
    WinBuiltinRemoteManagementUsersSid          = 102,
    WinAuthenticationAuthorityAssertedSid       = 103,
    WinAuthenticationServiceAssertedSid         = 104,
    WinLocalAccountSid                          = 105,
    WinLocalAccountAndAdministratorSid          = 106,
    WinAccountProtectedUsersSid                 = 107,
    WinCapabilityAppointmentsSid                = 108,
    WinCapabilityContactsSid                    = 109,
    WinAccountDefaultSystemManagedSid           = 110,
    WinBuiltinDefaultSystemManagedGroupSid      = 111,
    WinBuiltinStorageReplicaAdminsSid           = 112,
    WinAccountKeyAdminsSid                      = 113,
    WinAccountEnterpriseKeyAdminsSid            = 114,
    WinAuthenticationKeyTrustSid                = 115,
    WinAuthenticationKeyPropertyMFASid          = 116,
    WinAuthenticationKeyPropertyAttestationSid  = 117,
    WinAuthenticationFreshKeyAuthSid            = 118,
    WinBuiltinDeviceOwnersSid                   = 119,
} WELL_KNOWN_SID_TYPE;
#line 9632 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9642 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9694 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _ACL {
    BYTE  AclRevision;
    BYTE  Sbz1;
    WORD   AclSize;
    WORD   AceCount;
    WORD   Sbz2;
} ACL;
typedef ACL *PACL;
typedef struct _ACE_HEADER {
    BYTE  AceType;
    BYTE  AceFlags;
    WORD   AceSize;
} ACE_HEADER;
typedef ACE_HEADER *PACE_HEADER;
#line 9743 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9753 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9765 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9772 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 9785 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _ACCESS_ALLOWED_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} ACCESS_ALLOWED_ACE;
typedef ACCESS_ALLOWED_ACE *PACCESS_ALLOWED_ACE;
typedef struct _ACCESS_DENIED_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} ACCESS_DENIED_ACE;
typedef ACCESS_DENIED_ACE *PACCESS_DENIED_ACE;
typedef struct _SYSTEM_AUDIT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_AUDIT_ACE;
typedef SYSTEM_AUDIT_ACE *PSYSTEM_AUDIT_ACE;
typedef struct _SYSTEM_ALARM_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_ALARM_ACE;
typedef SYSTEM_ALARM_ACE *PSYSTEM_ALARM_ACE;
typedef struct _SYSTEM_RESOURCE_ATTRIBUTE_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_RESOURCE_ATTRIBUTE_ACE, *PSYSTEM_RESOURCE_ATTRIBUTE_ACE;
typedef struct _SYSTEM_SCOPED_POLICY_ID_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_SCOPED_POLICY_ID_ACE, *PSYSTEM_SCOPED_POLICY_ID_ACE;
typedef struct _SYSTEM_MANDATORY_LABEL_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_MANDATORY_LABEL_ACE, *PSYSTEM_MANDATORY_LABEL_ACE;
typedef struct _SYSTEM_PROCESS_TRUST_LABEL_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_PROCESS_TRUST_LABEL_ACE, *PSYSTEM_PROCESS_TRUST_LABEL_ACE;
typedef struct _SYSTEM_ACCESS_FILTER_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_ACCESS_FILTER_ACE, *PSYSTEM_ACCESS_FILTER_ACE;
typedef struct _ACCESS_ALLOWED_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    GUID InheritedObjectType;
    DWORD SidStart;
} ACCESS_ALLOWED_OBJECT_ACE, *PACCESS_ALLOWED_OBJECT_ACE;
typedef struct _ACCESS_DENIED_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} ACCESS_DENIED_OBJECT_ACE, *PACCESS_DENIED_OBJECT_ACE;
typedef struct _SYSTEM_AUDIT_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} SYSTEM_AUDIT_OBJECT_ACE, *PSYSTEM_AUDIT_OBJECT_ACE;
typedef struct _SYSTEM_ALARM_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} SYSTEM_ALARM_OBJECT_ACE, *PSYSTEM_ALARM_OBJECT_ACE;
typedef struct _ACCESS_ALLOWED_CALLBACK_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} ACCESS_ALLOWED_CALLBACK_ACE, *PACCESS_ALLOWED_CALLBACK_ACE;
typedef struct _ACCESS_DENIED_CALLBACK_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} ACCESS_DENIED_CALLBACK_ACE, *PACCESS_DENIED_CALLBACK_ACE;
typedef struct _SYSTEM_AUDIT_CALLBACK_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_AUDIT_CALLBACK_ACE, *PSYSTEM_AUDIT_CALLBACK_ACE;
typedef struct _SYSTEM_ALARM_CALLBACK_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD SidStart;
} SYSTEM_ALARM_CALLBACK_ACE, *PSYSTEM_ALARM_CALLBACK_ACE;
typedef struct _ACCESS_ALLOWED_CALLBACK_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} ACCESS_ALLOWED_CALLBACK_OBJECT_ACE, *PACCESS_ALLOWED_CALLBACK_OBJECT_ACE;
typedef struct _ACCESS_DENIED_CALLBACK_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} ACCESS_DENIED_CALLBACK_OBJECT_ACE, *PACCESS_DENIED_CALLBACK_OBJECT_ACE;
typedef struct _SYSTEM_AUDIT_CALLBACK_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} SYSTEM_AUDIT_CALLBACK_OBJECT_ACE, *PSYSTEM_AUDIT_CALLBACK_OBJECT_ACE;
typedef struct _SYSTEM_ALARM_CALLBACK_OBJECT_ACE {
    ACE_HEADER Header;
    ACCESS_MASK Mask;
    DWORD Flags;
    GUID ObjectType;
    DWORD SidStart;
} SYSTEM_ALARM_CALLBACK_OBJECT_ACE, *PSYSTEM_ALARM_CALLBACK_OBJECT_ACE;
typedef enum _ACL_INFORMATION_CLASS {
    AclRevisionInformation = 1,
    AclSizeInformation
} ACL_INFORMATION_CLASS;
typedef struct _ACL_REVISION_INFORMATION {
    DWORD AclRevision;
} ACL_REVISION_INFORMATION;
typedef ACL_REVISION_INFORMATION *PACL_REVISION_INFORMATION;
typedef struct _ACL_SIZE_INFORMATION {
    DWORD AceCount;
    DWORD AclBytesInUse;
    DWORD AclBytesFree;
} ACL_SIZE_INFORMATION;
typedef ACL_SIZE_INFORMATION *PACL_SIZE_INFORMATION;
typedef WORD   SECURITY_DESCRIPTOR_CONTROL, *PSECURITY_DESCRIPTOR_CONTROL;
#line 10121 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _SECURITY_DESCRIPTOR_RELATIVE {
    BYTE  Revision;
    BYTE  Sbz1;
    SECURITY_DESCRIPTOR_CONTROL Control;
    DWORD Owner;
    DWORD Group;
    DWORD Sacl;
    DWORD Dacl;
    } SECURITY_DESCRIPTOR_RELATIVE, *PISECURITY_DESCRIPTOR_RELATIVE;
typedef struct _SECURITY_DESCRIPTOR {
   BYTE  Revision;
   BYTE  Sbz1;
   PSID Owner;
   PSID Group;
   PACL Sacl;
   PACL Dacl;
   } SECURITY_DESCRIPTOR, *PISECURITY_DESCRIPTOR;
typedef struct _SECURITY_OBJECT_AI_PARAMS {
    DWORD Size;
    DWORD ConstraintMask;
} SECURITY_OBJECT_AI_PARAMS, *PSECURITY_OBJECT_AI_PARAMS;
typedef struct _OBJECT_TYPE_LIST {
    WORD   Level;
    WORD   Sbz;
    GUID *ObjectType;
} OBJECT_TYPE_LIST, *POBJECT_TYPE_LIST;
typedef enum _AUDIT_EVENT_TYPE {
    AuditEventObjectAccess,
    AuditEventDirectoryServiceAccess
} AUDIT_EVENT_TYPE, *PAUDIT_EVENT_TYPE;
typedef struct _PRIVILEGE_SET {
    DWORD PrivilegeCount;
    DWORD Control;
    LUID_AND_ATTRIBUTES Privilege[1];
    } PRIVILEGE_SET, * PPRIVILEGE_SET;
typedef enum _ACCESS_REASON_TYPE{
    AccessReasonNone                    = 0x00000000,
    AccessReasonAllowedAce                  = 0x00010000,
    AccessReasonDeniedAce                   = 0x00020000,
    AccessReasonAllowedParentAce            = 0x00030000,
    AccessReasonDeniedParentAce             = 0x00040000,
    AccessReasonNotGrantedByCape            = 0x00050000,
    AccessReasonNotGrantedByParentCape      = 0x00060000,
    AccessReasonNotGrantedToAppContainer    = 0x00070000,
    AccessReasonMissingPrivilege            = 0x00100000,
    AccessReasonFromPrivilege               = 0x00200000,
    AccessReasonIntegrityLevel              = 0x00300000,
    AccessReasonOwnership                   = 0x00400000,
    AccessReasonNullDacl                    = 0x00500000,
    AccessReasonEmptyDacl                   = 0x00600000,
    AccessReasonNoSD                        = 0x00700000,
    AccessReasonNoGrant                     = 0x00800000,
    AccessReasonTrustLabel                  = 0x00900000,
    AccessReasonFilterAce                   = 0x00a00000
ACCESS_REASON_TYPE;
typedef DWORD ACCESS_REASON;
typedef struct _ACCESS_REASONS{
        ACCESS_REASON Data[32];
} ACCESS_REASONS, *PACCESS_REASONS;
typedef struct _SE_SECURITY_DESCRIPTOR
    DWORD Size;
    DWORD Flags;
    PSECURITY_DESCRIPTOR SecurityDescriptor;
} SE_SECURITY_DESCRIPTOR, *PSE_SECURITY_DESCRIPTOR;
typedef struct _SE_ACCESS_REQUEST
    DWORD Size;
    PSE_SECURITY_DESCRIPTOR SeSecurityDescriptor;
    ACCESS_MASK DesiredAccess;
    ACCESS_MASK PreviouslyGrantedAccess;
    PSID PrincipalSelfSid;
    PGENERIC_MAPPING GenericMapping;
    DWORD ObjectTypeListCount;
    POBJECT_TYPE_LIST ObjectTypeList;
} SE_ACCESS_REQUEST, *PSE_ACCESS_REQUEST;
typedef struct _SE_ACCESS_REPLY
    DWORD Size;
    DWORD ResultListCount;
    PACCESS_MASK GrantedAccess;
    PDWORD    AccessStatus;
    PACCESS_REASONS AccessReason;
    PPRIVILEGE_SET* Privileges;
} SE_ACCESS_REPLY, *PSE_ACCESS_REPLY;
#line 10524 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum _SECURITY_IMPERSONATION_LEVEL {
    SecurityAnonymous,
    SecurityIdentification,
    SecurityImpersonation,
    SecurityDelegation
    } SECURITY_IMPERSONATION_LEVEL, * PSECURITY_IMPERSONATION_LEVEL;
#line 10591 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 10601 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 10608 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum _TOKEN_TYPE {
    TokenPrimary = 1,
    TokenImpersonation
    } TOKEN_TYPE;
typedef TOKEN_TYPE *PTOKEN_TYPE;
typedef enum _TOKEN_ELEVATION_TYPE {
    TokenElevationTypeDefault = 1,
    TokenElevationTypeFull,
    TokenElevationTypeLimited,
} TOKEN_ELEVATION_TYPE, *PTOKEN_ELEVATION_TYPE;
typedef enum _TOKEN_INFORMATION_CLASS {
    TokenUser = 1,
    TokenGroups,
    TokenPrivileges,
    TokenOwner,
    TokenPrimaryGroup,
    TokenDefaultDacl,
    TokenSource,
    TokenType,
    TokenImpersonationLevel,
    TokenStatistics,
    TokenRestrictedSids,
    TokenSessionId,
    TokenGroupsAndPrivileges,
    TokenSessionReference,
    TokenSandBoxInert,
    TokenAuditPolicy,
    TokenOrigin,
    TokenElevationType,
    TokenLinkedToken,
    TokenElevation,
    TokenHasRestrictions,
    TokenAccessInformation,
    TokenVirtualizationAllowed,
    TokenVirtualizationEnabled,
    TokenIntegrityLevel,
    TokenUIAccess,
    TokenMandatoryPolicy,
    TokenLogonSid,
    TokenIsAppContainer,
    TokenCapabilities,
    TokenAppContainerSid,
    TokenAppContainerNumber,
    TokenUserClaimAttributes,
    TokenDeviceClaimAttributes,
    TokenRestrictedUserClaimAttributes,
    TokenRestrictedDeviceClaimAttributes,
    TokenDeviceGroups,
    TokenRestrictedDeviceGroups,
    TokenSecurityAttributes,
    TokenIsRestricted,
    TokenProcessTrustLevel,
    TokenPrivateNameSpace,
    TokenSingletonAttributes,
    TokenBnoIsolation,
    TokenChildProcessFlags,
    MaxTokenInfoClass
} TOKEN_INFORMATION_CLASS, *PTOKEN_INFORMATION_CLASS;
typedef struct _TOKEN_USER {
    SID_AND_ATTRIBUTES User;
} TOKEN_USER, *PTOKEN_USER;
typedef struct _SE_TOKEN_USER {
    union {
        TOKEN_USER TokenUser;
    union {
        SID Sid;
} SE_TOKEN_USER , PSE_TOKEN_USER;
typedef struct _TOKEN_GROUPS {
    DWORD GroupCount;
    SID_AND_ATTRIBUTES Groups[1];
} TOKEN_GROUPS, *PTOKEN_GROUPS;
typedef struct _TOKEN_PRIVILEGES {
    LUID_AND_ATTRIBUTES Privileges[1];
} TOKEN_PRIVILEGES, *PTOKEN_PRIVILEGES;
typedef struct _TOKEN_OWNER {
    PSID Owner;
} TOKEN_OWNER, *PTOKEN_OWNER;
typedef struct _TOKEN_PRIMARY_GROUP {
    PSID PrimaryGroup;
} TOKEN_PRIMARY_GROUP, *PTOKEN_PRIMARY_GROUP;
typedef struct _TOKEN_DEFAULT_DACL {
    PACL DefaultDacl;
} TOKEN_DEFAULT_DACL, *PTOKEN_DEFAULT_DACL;
typedef struct _TOKEN_USER_CLAIMS {
    PCLAIMS_BLOB UserClaims;
} TOKEN_USER_CLAIMS, *PTOKEN_USER_CLAIMS;
typedef struct _TOKEN_DEVICE_CLAIMS {
    PCLAIMS_BLOB DeviceClaims;
} TOKEN_DEVICE_CLAIMS, *PTOKEN_DEVICE_CLAIMS;
typedef struct _TOKEN_GROUPS_AND_PRIVILEGES {
    DWORD SidCount;
    DWORD SidLength;
    PSID_AND_ATTRIBUTES Sids;
    DWORD RestrictedSidCount;
    DWORD RestrictedSidLength;
    PSID_AND_ATTRIBUTES RestrictedSids;
    DWORD PrivilegeLength;
    PLUID_AND_ATTRIBUTES Privileges;
    LUID AuthenticationId;
} TOKEN_GROUPS_AND_PRIVILEGES, *PTOKEN_GROUPS_AND_PRIVILEGES;
typedef struct _TOKEN_LINKED_TOKEN {
    HANDLE LinkedToken;
} TOKEN_LINKED_TOKEN, *PTOKEN_LINKED_TOKEN;
typedef struct _TOKEN_ELEVATION {
    DWORD TokenIsElevated;
} TOKEN_ELEVATION, *PTOKEN_ELEVATION;
typedef struct _TOKEN_MANDATORY_LABEL {
    SID_AND_ATTRIBUTES Label;
} TOKEN_MANDATORY_LABEL, *PTOKEN_MANDATORY_LABEL;
typedef struct _TOKEN_MANDATORY_POLICY {
    DWORD Policy;
} TOKEN_MANDATORY_POLICY, *PTOKEN_MANDATORY_POLICY;
typedef PVOID PSECURITY_ATTRIBUTES_OPAQUE;
typedef struct _TOKEN_ACCESS_INFORMATION {
    PSID_AND_ATTRIBUTES_HASH SidHash;
    PSID_AND_ATTRIBUTES_HASH RestrictedSidHash;
    PTOKEN_PRIVILEGES Privileges;
    TOKEN_TYPE TokenType;
    SECURITY_IMPERSONATION_LEVEL ImpersonationLevel;
    TOKEN_MANDATORY_POLICY MandatoryPolicy;
    DWORD Flags;
    DWORD AppContainerNumber;
    PSID PackageSid;
    PSID_AND_ATTRIBUTES_HASH CapabilitiesHash;
    PSID TrustLevelSid;
    PSECURITY_ATTRIBUTES_OPAQUE SecurityAttributes;
} TOKEN_ACCESS_INFORMATION, *PTOKEN_ACCESS_INFORMATION;
typedef struct _TOKEN_AUDIT_POLICY {
    BYTE  PerUserPolicy[(((59)) >> 1) + 1];
} TOKEN_AUDIT_POLICY, *PTOKEN_AUDIT_POLICY;
typedef struct _TOKEN_SOURCE {
    CHAR SourceName[8];
    LUID SourceIdentifier;
} TOKEN_SOURCE, *PTOKEN_SOURCE;
typedef struct _TOKEN_STATISTICS {
    LUID TokenId;
    LARGE_INTEGER ExpirationTime;
    DWORD DynamicCharged;
    DWORD DynamicAvailable;
    DWORD GroupCount;
    LUID ModifiedId;
} TOKEN_STATISTICS, *PTOKEN_STATISTICS;
typedef struct _TOKEN_CONTROL {
    LUID TokenId;
    LUID ModifiedId;
    TOKEN_SOURCE TokenSource;
} TOKEN_CONTROL, *PTOKEN_CONTROL;
typedef struct _TOKEN_ORIGIN {
    LUID OriginatingLogonSession ;
} TOKEN_ORIGIN, * PTOKEN_ORIGIN ;
typedef enum _MANDATORY_LEVEL {
    MandatoryLevelUntrusted = 0,
    MandatoryLevelLow,
    MandatoryLevelMedium,
    MandatoryLevelHigh,
    MandatoryLevelSystem,
    MandatoryLevelSecureProcess,
    MandatoryLevelCount
} MANDATORY_LEVEL, *PMANDATORY_LEVEL;
typedef struct _TOKEN_APPCONTAINER_INFORMATION {
    PSID TokenAppContainer;
} TOKEN_APPCONTAINER_INFORMATION, *PTOKEN_APPCONTAINER_INFORMATION;
typedef struct _TOKEN_SID_INFORMATION {
    PSID Sid;
} TOKEN_SID_INFORMATION, *PTOKEN_SID_INFORMATION;
typedef struct _TOKEN_BNO_ISOLATION_INFORMATION {
    PWSTR       IsolationPrefix;
    BOOLEAN     IsolationEnabled;
} TOKEN_BNO_ISOLATION_INFORMATION, *PTOKEN_BNO_ISOLATION_INFORMATION;
typedef struct _CLAIM_SECURITY_ATTRIBUTE_FQBN_VALUE {
    DWORD64             Version;
    PWSTR               Name;
} CLAIM_SECURITY_ATTRIBUTE_FQBN_VALUE, *PCLAIM_SECURITY_ATTRIBUTE_FQBN_VALUE;
typedef struct _CLAIM_SECURITY_ATTRIBUTE_OCTET_STRING_VALUE {
    PVOID   pValue;
    DWORD   ValueLength;
} CLAIM_SECURITY_ATTRIBUTE_OCTET_STRING_VALUE,
    *PCLAIM_SECURITY_ATTRIBUTE_OCTET_STRING_VALUE;
#line 11008 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _CLAIM_SECURITY_ATTRIBUTE_V1 {
    PWSTR   Name;
    WORD    ValueType;
    WORD    Reserved;
    DWORD   Flags;
    DWORD   ValueCount;
    union {
        PLONG64                                         pInt64;
        PDWORD64                                        pUint64;
        PWSTR                                           *ppString;
        PCLAIM_SECURITY_ATTRIBUTE_FQBN_VALUE            pFqbn;
        PCLAIM_SECURITY_ATTRIBUTE_OCTET_STRING_VALUE    pOctetString;
    } Values;
} CLAIM_SECURITY_ATTRIBUTE_V1, *PCLAIM_SECURITY_ATTRIBUTE_V1;
typedef struct _CLAIM_SECURITY_ATTRIBUTE_RELATIVE_V1 {
    DWORD   Name;
    WORD    ValueType;
    WORD    Reserved;
    DWORD   Flags;
    DWORD   ValueCount;
    union {
        DWORD pInt64[1];
        DWORD pUint64[1];
        DWORD ppString[1];
        DWORD pFqbn[1];
        DWORD pOctetString[1];
    } Values;
} CLAIM_SECURITY_ATTRIBUTE_RELATIVE_V1, *PCLAIM_SECURITY_ATTRIBUTE_RELATIVE_V1;
typedef struct _CLAIM_SECURITY_ATTRIBUTES_INFORMATION {
    WORD    Version;
    WORD    Reserved;
    DWORD   AttributeCount;
    union {
        PCLAIM_SECURITY_ATTRIBUTE_V1    pAttributeV1;
    } Attribute;
} CLAIM_SECURITY_ATTRIBUTES_INFORMATION, *PCLAIM_SECURITY_ATTRIBUTES_INFORMATION;
typedef BOOLEAN SECURITY_CONTEXT_TRACKING_MODE,
                    * PSECURITY_CONTEXT_TRACKING_MODE;
typedef struct _SECURITY_QUALITY_OF_SERVICE {
    DWORD Length;
    SECURITY_CONTEXT_TRACKING_MODE ContextTrackingMode;
    BOOLEAN EffectiveOnly;
    } SECURITY_QUALITY_OF_SERVICE, * PSECURITY_QUALITY_OF_SERVICE;
typedef struct _SE_IMPERSONATION_STATE {
    PACCESS_TOKEN Token;
    BOOLEAN CopyOnOpen;
    SECURITY_IMPERSONATION_LEVEL Level;
} SE_IMPERSONATION_STATE, *PSE_IMPERSONATION_STATE;
typedef DWORD SECURITY_INFORMATION, *PSECURITY_INFORMATION;
#line 11212 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef BYTE  SE_SIGNING_LEVEL, *PSE_SIGNING_LEVEL;
#line 11242 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum _SE_IMAGE_SIGNATURE_TYPE
    SeImageSignatureNone = 0,
    SeImageSignatureEmbedded,
    SeImageSignatureCache,
    SeImageSignatureCatalogCached,
    SeImageSignatureCatalogNotCached,
    SeImageSignatureCatalogHint,
    SeImageSignaturePackageCatalog,
} SE_IMAGE_SIGNATURE_TYPE, *PSE_IMAGE_SIGNATURE_TYPE;
typedef enum _SE_LEARNING_MODE_DATA_TYPE {
    SeLearningModeInvalidType = 0,
    SeLearningModeSettings,
    SeLearningModeMax
} SE_LEARNING_MODE_DATA_TYPE;
typedef struct _SECURITY_CAPABILITIES {
    PSID AppContainerSid;
    PSID_AND_ATTRIBUTES Capabilities;
    DWORD CapabilityCount;
    DWORD Reserved;
} SECURITY_CAPABILITIES, *PSECURITY_CAPABILITIES, *LPSECURITY_CAPABILITIES;
#line 11305 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 11315 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 11334 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _JOB_SET_ARRAY {
    HANDLE JobHandle;
    DWORD MemberLevel;
    DWORD Flags;
} JOB_SET_ARRAY, *PJOB_SET_ARRAY;
typedef struct _EXCEPTION_REGISTRATION_RECORD {
    struct _EXCEPTION_REGISTRATION_RECORD *Next;
    PEXCEPTION_ROUTINE Handler;
} EXCEPTION_REGISTRATION_RECORD;
typedef EXCEPTION_REGISTRATION_RECORD *PEXCEPTION_REGISTRATION_RECORD;
typedef struct _NT_TIB {
    struct _EXCEPTION_REGISTRATION_RECORD *ExceptionList;
    PVOID StackBase;
    PVOID StackLimit;
    PVOID SubSystemTib;
    union {
        PVOID FiberData;
        DWORD Version;
    PVOID ArbitraryUserPointer;
    struct _NT_TIB *Self;
} NT_TIB;
typedef NT_TIB *PNT_TIB;
typedef struct _NT_TIB32 {
    DWORD ExceptionList;
    DWORD StackBase;
    DWORD StackLimit;
    DWORD SubSystemTib;
    union {
        DWORD FiberData;
        DWORD Version;
    DWORD ArbitraryUserPointer;
    DWORD Self;
} NT_TIB32, *PNT_TIB32;
typedef struct _NT_TIB64 {
    DWORD64 ExceptionList;
    DWORD64 StackBase;
    DWORD64 StackLimit;
    DWORD64 SubSystemTib;
    union {
        DWORD64 FiberData;
        DWORD Version;
    DWORD64 ArbitraryUserPointer;
    DWORD64 Self;
} NT_TIB64, *PNT_TIB64;
typedef struct _UMS_CREATE_THREAD_ATTRIBUTES {
    DWORD UmsVersion;
        PVOID UmsContext;
        PVOID UmsCompletionList;
} UMS_CREATE_THREAD_ATTRIBUTES, *PUMS_CREATE_THREAD_ATTRIBUTES;
typedef struct _WOW64_ARCHITECTURE_INFORMATION {
    DWORD Machine : 16;
    DWORD KernelMode : 1;
    DWORD UserMode : 1;
    DWORD Native : 1;
    DWORD Process : 1;
    DWORD ReservedZero0 : 12;
} WOW64_ARCHITECTURE_INFORMATION;
#line 11448 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _QUOTA_LIMITS {
    SIZE_T PagedPoolLimit;
    SIZE_T NonPagedPoolLimit;
    SIZE_T MinimumWorkingSetSize;
    SIZE_T MaximumWorkingSetSize;
    SIZE_T PagefileLimit;
    LARGE_INTEGER TimeLimit;
} QUOTA_LIMITS, *PQUOTA_LIMITS;
typedef union _RATE_QUOTA_LIMIT {
    DWORD RateData;
    struct {
        DWORD RatePercent : 7;
        DWORD Reserved0   : 25;
} RATE_QUOTA_LIMIT, *PRATE_QUOTA_LIMIT;
typedef struct _QUOTA_LIMITS_EX {
    SIZE_T WorkingSetLimit;
    SIZE_T Reserved2;
    SIZE_T Reserved3;
    SIZE_T Reserved4;
    DWORD  Flags;
    RATE_QUOTA_LIMIT CpuRateLimit;
} QUOTA_LIMITS_EX, *PQUOTA_LIMITS_EX;
typedef struct _IO_COUNTERS {
    ULONGLONG  ReadOperationCount;
    ULONGLONG  WriteOperationCount;
    ULONGLONG  OtherOperationCount;
    ULONGLONG ReadTransferCount;
    ULONGLONG WriteTransferCount;
    ULONGLONG OtherTransferCount;
} IO_COUNTERS;
typedef IO_COUNTERS *PIO_COUNTERS;
typedef enum _HARDWARE_COUNTER_TYPE {
    PMCCounter,
    MaxHardwareCounterType
} HARDWARE_COUNTER_TYPE, *PHARDWARE_COUNTER_TYPE;
typedef enum _PROCESS_MITIGATION_POLICY {
    ProcessDEPPolicy,
    ProcessASLRPolicy,
    ProcessDynamicCodePolicy,
    ProcessStrictHandleCheckPolicy,
    ProcessSystemCallDisablePolicy,
    ProcessMitigationOptionsMask,
    ProcessExtensionPointDisablePolicy,
    ProcessControlFlowGuardPolicy,
    ProcessSignaturePolicy,
    ProcessFontDisablePolicy,
    ProcessImageLoadPolicy,
    ProcessSystemCallFilterPolicy,
    ProcessPayloadRestrictionPolicy,
    ProcessChildProcessPolicy,
    MaxProcessMitigationPolicy
} PROCESS_MITIGATION_POLICY, *PPROCESS_MITIGATION_POLICY;
typedef struct _PROCESS_MITIGATION_ASLR_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD EnableBottomUpRandomization : 1;
            DWORD EnableForceRelocateImages : 1;
            DWORD EnableHighEntropy : 1;
            DWORD DisallowStrippedImages : 1;
            DWORD ReservedFlags : 28;
} PROCESS_MITIGATION_ASLR_POLICY, *PPROCESS_MITIGATION_ASLR_POLICY;
typedef struct _PROCESS_MITIGATION_DEP_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD Enable : 1;
            DWORD DisableAtlThunkEmulation : 1;
            DWORD ReservedFlags : 30;
    BOOLEAN Permanent;
} PROCESS_MITIGATION_DEP_POLICY, *PPROCESS_MITIGATION_DEP_POLICY;
typedef struct _PROCESS_MITIGATION_STRICT_HANDLE_CHECK_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD RaiseExceptionOnInvalidHandleReference : 1;
            DWORD HandleExceptionsPermanentlyEnabled : 1;
} PROCESS_MITIGATION_STRICT_HANDLE_CHECK_POLICY, *PPROCESS_MITIGATION_STRICT_HANDLE_CHECK_POLICY;
typedef struct _PROCESS_MITIGATION_SYSTEM_CALL_DISABLE_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD DisallowWin32kSystemCalls : 1;
            DWORD AuditDisallowWin32kSystemCalls : 1;
} PROCESS_MITIGATION_SYSTEM_CALL_DISABLE_POLICY, *PPROCESS_MITIGATION_SYSTEM_CALL_DISABLE_POLICY;
typedef struct _PROCESS_MITIGATION_EXTENSION_POINT_DISABLE_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD DisableExtensionPoints : 1;
            DWORD ReservedFlags : 31;
} PROCESS_MITIGATION_EXTENSION_POINT_DISABLE_POLICY, *PPROCESS_MITIGATION_EXTENSION_POINT_DISABLE_POLICY;
typedef struct _PROCESS_MITIGATION_DYNAMIC_CODE_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD ProhibitDynamicCode : 1;
            DWORD AllowThreadOptOut : 1;
            DWORD AllowRemoteDowngrade : 1;
            DWORD AuditProhibitDynamicCode : 1;
} PROCESS_MITIGATION_DYNAMIC_CODE_POLICY, *PPROCESS_MITIGATION_DYNAMIC_CODE_POLICY;
typedef struct _PROCESS_MITIGATION_CONTROL_FLOW_GUARD_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD EnableControlFlowGuard : 1;
            DWORD EnableExportSuppression : 1;
            DWORD StrictMode : 1;
            DWORD ReservedFlags : 29;
} PROCESS_MITIGATION_CONTROL_FLOW_GUARD_POLICY, *PPROCESS_MITIGATION_CONTROL_FLOW_GUARD_POLICY;
typedef struct _PROCESS_MITIGATION_BINARY_SIGNATURE_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD MicrosoftSignedOnly : 1;
            DWORD StoreSignedOnly : 1;
            DWORD MitigationOptIn : 1;
            DWORD AuditMicrosoftSignedOnly : 1;
            DWORD AuditStoreSignedOnly : 1;
            DWORD ReservedFlags : 27;
} PROCESS_MITIGATION_BINARY_SIGNATURE_POLICY, *PPROCESS_MITIGATION_BINARY_SIGNATURE_POLICY;
typedef struct _PROCESS_MITIGATION_FONT_DISABLE_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD DisableNonSystemFonts     : 1;
            DWORD AuditNonSystemFontLoading : 1;
} PROCESS_MITIGATION_FONT_DISABLE_POLICY, *PPROCESS_MITIGATION_FONT_DISABLE_POLICY;
typedef struct _PROCESS_MITIGATION_IMAGE_LOAD_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD NoRemoteImages : 1;
            DWORD NoLowMandatoryLabelImages : 1;
            DWORD PreferSystem32Images : 1;
            DWORD AuditNoRemoteImages : 1;
            DWORD AuditNoLowMandatoryLabelImages : 1;
} PROCESS_MITIGATION_IMAGE_LOAD_POLICY, *PPROCESS_MITIGATION_IMAGE_LOAD_POLICY;
typedef struct _PROCESS_MITIGATION_SYSTEM_CALL_FILTER_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD FilterId: 4;
} PROCESS_MITIGATION_SYSTEM_CALL_FILTER_POLICY, *PPROCESS_MITIGATION_SYSTEM_CALL_FILTER_POLICY;
typedef struct _PROCESS_MITIGATION_PAYLOAD_RESTRICTION_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD EnableExportAddressFilter     : 1;
            DWORD AuditExportAddressFilter      : 1;
            DWORD EnableExportAddressFilterPlus : 1;
            DWORD AuditExportAddressFilterPlus  : 1;
            DWORD EnableImportAddressFilter     : 1;
            DWORD AuditImportAddressFilter      : 1;
            DWORD EnableRopStackPivot           : 1;
            DWORD AuditRopStackPivot            : 1;
            DWORD EnableRopCallerCheck          : 1;
            DWORD AuditRopCallerCheck           : 1;
            DWORD EnableRopSimExec              : 1;
            DWORD AuditRopSimExec               : 1;
            DWORD ReservedFlags                 : 20;
} PROCESS_MITIGATION_PAYLOAD_RESTRICTION_POLICY, *PPROCESS_MITIGATION_PAYLOAD_RESTRICTION_POLICY;
typedef struct _PROCESS_MITIGATION_CHILD_PROCESS_POLICY {
    union {
        DWORD Flags;
        struct {
            DWORD NoChildProcessCreation : 1;
            DWORD AuditNoChildProcessCreation : 1;
            DWORD AllowSecureProcessCreation : 1;
} PROCESS_MITIGATION_CHILD_PROCESS_POLICY, *PPROCESS_MITIGATION_CHILD_PROCESS_POLICY;
typedef struct _JOBOBJECT_BASIC_ACCOUNTING_INFORMATION {
    LARGE_INTEGER TotalUserTime;
    LARGE_INTEGER TotalKernelTime;
    LARGE_INTEGER ThisPeriodTotalUserTime;
    LARGE_INTEGER ThisPeriodTotalKernelTime;
    DWORD TotalPageFaultCount;
    DWORD TotalProcesses;
    DWORD ActiveProcesses;
    DWORD TotalTerminatedProcesses;
} JOBOBJECT_BASIC_ACCOUNTING_INFORMATION, *PJOBOBJECT_BASIC_ACCOUNTING_INFORMATION;
typedef struct _JOBOBJECT_BASIC_LIMIT_INFORMATION {
    LARGE_INTEGER PerProcessUserTimeLimit;
    LARGE_INTEGER PerJobUserTimeLimit;
    DWORD LimitFlags;
    DWORD ActiveProcessLimit;
    ULONG_PTR Affinity;
    DWORD PriorityClass;
    DWORD SchedulingClass;
} JOBOBJECT_BASIC_LIMIT_INFORMATION, *PJOBOBJECT_BASIC_LIMIT_INFORMATION;
typedef struct _JOBOBJECT_EXTENDED_LIMIT_INFORMATION {
    JOBOBJECT_BASIC_LIMIT_INFORMATION BasicLimitInformation;
    IO_COUNTERS IoInfo;
    SIZE_T ProcessMemoryLimit;
    SIZE_T JobMemoryLimit;
    SIZE_T PeakProcessMemoryUsed;
    SIZE_T PeakJobMemoryUsed;
} JOBOBJECT_EXTENDED_LIMIT_INFORMATION, *PJOBOBJECT_EXTENDED_LIMIT_INFORMATION;
typedef struct _JOBOBJECT_BASIC_PROCESS_ID_LIST {
    DWORD NumberOfAssignedProcesses;
    DWORD NumberOfProcessIdsInList;
    ULONG_PTR ProcessIdList[1];
} JOBOBJECT_BASIC_PROCESS_ID_LIST, *PJOBOBJECT_BASIC_PROCESS_ID_LIST;
typedef struct _JOBOBJECT_BASIC_UI_RESTRICTIONS {
    DWORD UIRestrictionsClass;
} JOBOBJECT_BASIC_UI_RESTRICTIONS, *PJOBOBJECT_BASIC_UI_RESTRICTIONS;
typedef struct _JOBOBJECT_SECURITY_LIMIT_INFORMATION {
    DWORD SecurityLimitFlags ;
    HANDLE JobToken ;
    PTOKEN_GROUPS SidsToDisable ;
    PTOKEN_PRIVILEGES PrivilegesToDelete ;
    PTOKEN_GROUPS RestrictedSids ;
} JOBOBJECT_SECURITY_LIMIT_INFORMATION, *PJOBOBJECT_SECURITY_LIMIT_INFORMATION ;
typedef struct _JOBOBJECT_END_OF_JOB_TIME_INFORMATION {
    DWORD EndOfJobTimeAction;
} JOBOBJECT_END_OF_JOB_TIME_INFORMATION, *PJOBOBJECT_END_OF_JOB_TIME_INFORMATION;
typedef struct _JOBOBJECT_ASSOCIATE_COMPLETION_PORT {
    PVOID CompletionKey;
    HANDLE CompletionPort;
} JOBOBJECT_ASSOCIATE_COMPLETION_PORT, *PJOBOBJECT_ASSOCIATE_COMPLETION_PORT;
typedef struct _JOBOBJECT_BASIC_AND_IO_ACCOUNTING_INFORMATION {
    JOBOBJECT_BASIC_ACCOUNTING_INFORMATION BasicInfo;
    IO_COUNTERS IoInfo;
} JOBOBJECT_BASIC_AND_IO_ACCOUNTING_INFORMATION, *PJOBOBJECT_BASIC_AND_IO_ACCOUNTING_INFORMATION;
typedef struct _JOBOBJECT_JOBSET_INFORMATION {
    DWORD MemberLevel;
} JOBOBJECT_JOBSET_INFORMATION, *PJOBOBJECT_JOBSET_INFORMATION;
typedef enum _JOBOBJECT_RATE_CONTROL_TOLERANCE {
    ToleranceLow = 1,
    ToleranceMedium,
    ToleranceHigh
} JOBOBJECT_RATE_CONTROL_TOLERANCE, *PJOBOBJECT_RATE_CONTROL_TOLERANCE;
typedef enum _JOBOBJECT_RATE_CONTROL_TOLERANCE_INTERVAL {
    ToleranceIntervalShort = 1,
    ToleranceIntervalMedium,
    ToleranceIntervalLong
} JOBOBJECT_RATE_CONTROL_TOLERANCE_INTERVAL,
  *PJOBOBJECT_RATE_CONTROL_TOLERANCE_INTERVAL;
typedef struct _JOBOBJECT_NOTIFICATION_LIMIT_INFORMATION {
    DWORD64 IoReadBytesLimit;
    DWORD64 IoWriteBytesLimit;
    DWORD64 JobMemoryLimit;
    JOBOBJECT_RATE_CONTROL_TOLERANCE RateControlTolerance;
    JOBOBJECT_RATE_CONTROL_TOLERANCE_INTERVAL RateControlToleranceInterval;
    DWORD LimitFlags;
} JOBOBJECT_NOTIFICATION_LIMIT_INFORMATION, *PJOBOBJECT_NOTIFICATION_LIMIT_INFORMATION;
typedef struct JOBOBJECT_NOTIFICATION_LIMIT_INFORMATION_2 {
    union {
        DWORD64 JobHighMemoryLimit;
    union {
        JOBOBJECT_RATE_CONTROL_TOLERANCE CpuRateControlTolerance;
    union {
            CpuRateControlToleranceInterval;
    DWORD LimitFlags;
    JOBOBJECT_RATE_CONTROL_TOLERANCE IoRateControlTolerance;
    DWORD64 JobLowMemoryLimit;
    JOBOBJECT_RATE_CONTROL_TOLERANCE_INTERVAL IoRateControlToleranceInterval;
    JOBOBJECT_RATE_CONTROL_TOLERANCE NetRateControlTolerance;
    JOBOBJECT_RATE_CONTROL_TOLERANCE_INTERVAL NetRateControlToleranceInterval;
} JOBOBJECT_NOTIFICATION_LIMIT_INFORMATION_2;
typedef struct _JOBOBJECT_LIMIT_VIOLATION_INFORMATION {
    DWORD LimitFlags;
    DWORD ViolationLimitFlags;
    DWORD64 IoReadBytes;
    DWORD64 IoWriteBytes;
    LARGE_INTEGER PerJobUserTime;
    DWORD64 JobMemory;
    JOBOBJECT_RATE_CONTROL_TOLERANCE RateControlToleranceLimit;
} JOBOBJECT_LIMIT_VIOLATION_INFORMATION, *PJOBOBJECT_LIMIT_VIOLATION_INFORMATION;
typedef struct JOBOBJECT_LIMIT_VIOLATION_INFORMATION_2 {
    DWORD LimitFlags;
    DWORD64 JobMemory;
    union {
    union {
    union {
        JOBOBJECT_RATE_CONTROL_TOLERANCE CpuRateControlToleranceLimit;
    JOBOBJECT_RATE_CONTROL_TOLERANCE IoRateControlToleranceLimit;
    JOBOBJECT_RATE_CONTROL_TOLERANCE NetRateControlToleranceLimit;
} JOBOBJECT_LIMIT_VIOLATION_INFORMATION_2;
typedef struct _JOBOBJECT_CPU_RATE_CONTROL_INFORMATION {
    DWORD ControlFlags;
    union {
        DWORD CpuRate;
        DWORD Weight;
        struct {
            WORD   MinRate;
            WORD   MaxRate;
} JOBOBJECT_CPU_RATE_CONTROL_INFORMATION, *PJOBOBJECT_CPU_RATE_CONTROL_INFORMATION;
typedef enum JOB_OBJECT_NET_RATE_CONTROL_FLAGS {
    JOB_OBJECT_NET_RATE_CONTROL_ENABLE = 0x1,
    JOB_OBJECT_NET_RATE_CONTROL_MAX_BANDWIDTH = 0x2,
    JOB_OBJECT_NET_RATE_CONTROL_DSCP_TAG = 0x4,
    JOB_OBJECT_NET_RATE_CONTROL_VALID_FLAGS = 0x7
} JOB_OBJECT_NET_RATE_CONTROL_FLAGS;
typedef char __C_ASSERT__[(JOB_OBJECT_NET_RATE_CONTROL_VALID_FLAGS == (JOB_OBJECT_NET_RATE_CONTROL_ENABLE + JOB_OBJECT_NET_RATE_CONTROL_MAX_BANDWIDTH + JOB_OBJECT_NET_RATE_CONTROL_DSCP_TAG))?1:-1];
typedef struct JOBOBJECT_NET_RATE_CONTROL_INFORMATION {
    DWORD64 MaxBandwidth;
    JOB_OBJECT_NET_RATE_CONTROL_FLAGS ControlFlags;
    BYTE  DscpTag;
} JOBOBJECT_NET_RATE_CONTROL_INFORMATION;
typedef enum JOB_OBJECT_IO_RATE_CONTROL_FLAGS {
    JOB_OBJECT_IO_RATE_CONTROL_ENABLE = 0x1,
    JOB_OBJECT_IO_RATE_CONTROL_STANDALONE_VOLUME = 0x2,
    JOB_OBJECT_IO_RATE_CONTROL_FORCE_UNIT_ACCESS_ALL = 0x4,
    JOB_OBJECT_IO_RATE_CONTROL_FORCE_UNIT_ACCESS_ON_SOFT_CAP = 0x8,
    JOB_OBJECT_IO_RATE_CONTROL_VALID_FLAGS = JOB_OBJECT_IO_RATE_CONTROL_ENABLE |
                                             JOB_OBJECT_IO_RATE_CONTROL_STANDALONE_VOLUME |
                                             JOB_OBJECT_IO_RATE_CONTROL_FORCE_UNIT_ACCESS_ALL |
} JOB_OBJECT_IO_RATE_CONTROL_FLAGS;
typedef struct JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE {
    LONG64 MaxIops;
    LONG64 MaxBandwidth;
    LONG64 ReservationIops;
    PWSTR VolumeName;
    DWORD BaseIoSize;
    JOB_OBJECT_IO_RATE_CONTROL_FLAGS ControlFlags;
    WORD   VolumeNameLength;
} JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE;
typedef JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE
    JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE_V1;
typedef struct JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE_V2 {
    LONG64 MaxIops;
    PWSTR VolumeName;
    DWORD BaseIoSize;
    LONG64 CriticalReservationIops;
    LONG64 ReservationBandwidth;
    LONG64 CriticalReservationBandwidth;
    LONG64 MaxTimePercent;
    LONG64 ReservationTimePercent;
    LONG64 CriticalReservationTimePercent;
} JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE_V2;
typedef struct JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE_V3 {
    LONG64 MaxIops;
    PWSTR VolumeName;
    DWORD BaseIoSize;
    LONG64 SoftMaxIops;
    LONG64 SoftMaxBandwidth;
    LONG64 SoftMaxTimePercent;
    LONG64 LimitExcessNotifyIops;
    LONG64 LimitExcessNotifyBandwidth;
    LONG64 LimitExcessNotifyTimePercent;
} JOBOBJECT_IO_RATE_CONTROL_INFORMATION_NATIVE_V3;
typedef enum JOBOBJECT_IO_ATTRIBUTION_CONTROL_FLAGS {
    JOBOBJECT_IO_ATTRIBUTION_CONTROL_ENABLE = 0x1,
    JOBOBJECT_IO_ATTRIBUTION_CONTROL_DISABLE = 0x2,
    JOBOBJECT_IO_ATTRIBUTION_CONTROL_VALID_FLAGS = 0x3
} JOBOBJECT_IO_ATTRIBUTION_CONTROL_FLAGS;
typedef struct _JOBOBJECT_IO_ATTRIBUTION_STATS {
    ULONG_PTR IoCount;
    ULONGLONG TotalNonOverlappedQueueTime;
    ULONGLONG TotalNonOverlappedServiceTime;
    ULONGLONG TotalSize;
} JOBOBJECT_IO_ATTRIBUTION_STATS, *PJOBOBJECT_IO_ATTRIBUTION_STATS;
typedef struct _JOBOBJECT_IO_ATTRIBUTION_INFORMATION {
    DWORD ControlFlags;
    JOBOBJECT_IO_ATTRIBUTION_STATS ReadStats;
    JOBOBJECT_IO_ATTRIBUTION_STATS WriteStats;
} JOBOBJECT_IO_ATTRIBUTION_INFORMATION, *PJOBOBJECT_IO_ATTRIBUTION_INFORMATION;
#line 12035 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12058 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12071 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12082 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12100 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12116 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12138 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum _JOBOBJECTINFOCLASS {
    JobObjectBasicAccountingInformation = 1,
    JobObjectBasicLimitInformation,
    JobObjectBasicProcessIdList,
    JobObjectBasicUIRestrictions,
    JobObjectSecurityLimitInformation,
    JobObjectEndOfJobTimeInformation,
    JobObjectAssociateCompletionPortInformation,
    JobObjectBasicAndIoAccountingInformation,
    JobObjectExtendedLimitInformation,
    JobObjectJobSetInformation,
    JobObjectGroupInformation,
    JobObjectNotificationLimitInformation,
    JobObjectLimitViolationInformation,
    JobObjectGroupInformationEx,
    JobObjectCpuRateControlInformation,
    JobObjectCompletionFilter,
    JobObjectCompletionCounter,
    JobObjectReserved1Information = 18,
    JobObjectReserved2Information,
    JobObjectReserved3Information,
    JobObjectReserved4Information,
    JobObjectReserved5Information,
    JobObjectReserved6Information,
    JobObjectReserved7Information,
    JobObjectReserved8Information,
    JobObjectReserved9Information,
    JobObjectReserved10Information,
    JobObjectReserved11Information,
    JobObjectReserved12Information,
    JobObjectReserved13Information,
    JobObjectReserved14Information = 31,
    JobObjectNetRateControlInformation,
    JobObjectNotificationLimitInformation2,
    JobObjectLimitViolationInformation2,
    JobObjectCreateSilo,
    JobObjectSiloBasicInformation,
    JobObjectReserved15Information = 37,
    JobObjectReserved16Information = 38,
    JobObjectReserved17Information = 39,
    JobObjectReserved18Information = 40,
    JobObjectReserved19Information = 41,
    JobObjectReserved20Information = 42,
    JobObjectReserved21Information = 43,
    JobObjectReserved22Information = 44,
    JobObjectReserved23Information = 45,
    JobObjectReserved24Information = 46,
    JobObjectReserved25Information = 47,
    MaxJobObjectInfoClass
} JOBOBJECTINFOCLASS;
typedef struct _SILOOBJECT_BASIC_INFORMATION {
    DWORD SiloId;
    DWORD SiloParentId;
    DWORD NumberOfProcesses;
    BOOLEAN IsInServerSilo;
    BYTE  Reserved[3];
} SILOOBJECT_BASIC_INFORMATION, *PSILOOBJECT_BASIC_INFORMATION;
typedef enum _SERVERSILO_STATE {
    SERVERSILO_INITING = 0,
    SERVERSILO_STARTED,
    SERVERSILO_SHUTTING_DOWN,
    SERVERSILO_TERMINATING,
    SERVERSILO_TERMINATED,
} SERVERSILO_STATE, *PSERVERSILO_STATE;
typedef struct _SERVERSILO_BASIC_INFORMATION {
    DWORD ServiceSessionId;
    SERVERSILO_STATE State;
    DWORD    ExitStatus;
} SERVERSILO_BASIC_INFORMATION, *PSERVERSILO_BASIC_INFORMATION;
typedef enum _FIRMWARE_TYPE {
    FirmwareTypeUnknown,
    FirmwareTypeBios,
    FirmwareTypeUefi,
    FirmwareTypeMax
} FIRMWARE_TYPE, *PFIRMWARE_TYPE;
typedef enum _LOGICAL_PROCESSOR_RELATIONSHIP {
    RelationProcessorCore,
    RelationNumaNode,
    RelationCache,
    RelationProcessorPackage,
    RelationGroup,
    RelationAll = 0xffff
} LOGICAL_PROCESSOR_RELATIONSHIP;
typedef enum _PROCESSOR_CACHE_TYPE {
    CacheUnified,
    CacheInstruction,
    CacheData,
    CacheTrace
} PROCESSOR_CACHE_TYPE;
typedef struct _CACHE_DESCRIPTOR {
    BYTE   Level;
    BYTE   Associativity;
    WORD   LineSize;
    DWORD  Size;
    PROCESSOR_CACHE_TYPE Type;
} CACHE_DESCRIPTOR, *PCACHE_DESCRIPTOR;
typedef struct _SYSTEM_LOGICAL_PROCESSOR_INFORMATION {
    ULONG_PTR   ProcessorMask;
    LOGICAL_PROCESSOR_RELATIONSHIP Relationship;
    union {
        struct {
            BYTE  Flags;
        } ProcessorCore;
        struct {
            DWORD NodeNumber;
        } NumaNode;
        CACHE_DESCRIPTOR Cache;
        ULONGLONG  Reserved[2];
} SYSTEM_LOGICAL_PROCESSOR_INFORMATION, *PSYSTEM_LOGICAL_PROCESSOR_INFORMATION;
typedef struct _PROCESSOR_RELATIONSHIP {
    BYTE  Flags;
    BYTE  EfficiencyClass;
    BYTE  Reserved[20];
    WORD   GroupCount;
     GROUP_AFFINITY GroupMask[1];
} PROCESSOR_RELATIONSHIP, *PPROCESSOR_RELATIONSHIP;
typedef struct _NUMA_NODE_RELATIONSHIP {
    DWORD NodeNumber;
    BYTE  Reserved[20];
    GROUP_AFFINITY GroupMask;
} NUMA_NODE_RELATIONSHIP, *PNUMA_NODE_RELATIONSHIP;
typedef struct _CACHE_RELATIONSHIP {
    BYTE  Level;
    BYTE  Associativity;
    WORD   LineSize;
    DWORD CacheSize;
    BYTE  Reserved[20];
} CACHE_RELATIONSHIP, *PCACHE_RELATIONSHIP;
typedef struct _PROCESSOR_GROUP_INFO {
    BYTE  MaximumProcessorCount;
    BYTE  ActiveProcessorCount;
    BYTE  Reserved[38];
    KAFFINITY ActiveProcessorMask;
} PROCESSOR_GROUP_INFO, *PPROCESSOR_GROUP_INFO;
typedef struct _GROUP_RELATIONSHIP {
    WORD   MaximumGroupCount;
    WORD   ActiveGroupCount;
    BYTE  Reserved[20];
    PROCESSOR_GROUP_INFO GroupInfo[1];
} GROUP_RELATIONSHIP, *PGROUP_RELATIONSHIP;
 struct _SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX {
    DWORD Size;
    union {
        PROCESSOR_RELATIONSHIP Processor;
        NUMA_NODE_RELATIONSHIP NumaNode;
        CACHE_RELATIONSHIP Cache;
        GROUP_RELATIONSHIP Group;
typedef struct _SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX SYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX, *PSYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX;
typedef enum _CPU_SET_INFORMATION_TYPE {
    CpuSetInformation
} CPU_SET_INFORMATION_TYPE, *PCPU_SET_INFORMATION_TYPE;
 struct _SYSTEM_CPU_SET_INFORMATION {
    DWORD Size;
    CPU_SET_INFORMATION_TYPE Type;
    union {
        struct {
            DWORD Id;
            WORD   Group;
            BYTE  LogicalProcessorIndex;
            BYTE  CoreIndex;
            BYTE  LastLevelCacheIndex;
            BYTE  NumaNodeIndex;
            union {
                BYTE  AllFlags;
                struct {
                    BYTE  Parked : 1;
                    BYTE  Allocated : 1;
                    BYTE  AllocatedToTargetProcess : 1;
                    BYTE  RealTime : 1;
                    BYTE  ReservedFlags : 4;
            union {
                DWORD Reserved;
                BYTE  SchedulingClass;
            DWORD64 AllocationTag;
        } CpuSet;
typedef struct _SYSTEM_CPU_SET_INFORMATION SYSTEM_CPU_SET_INFORMATION, *PSYSTEM_CPU_SET_INFORMATION;
typedef struct _SYSTEM_PROCESSOR_CYCLE_TIME_INFORMATION {
    DWORD64 CycleTime;
} SYSTEM_PROCESSOR_CYCLE_TIME_INFORMATION, *PSYSTEM_PROCESSOR_CYCLE_TIME_INFORMATION;
#line 12423 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12439 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12475 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12506 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12534 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _XSTATE_FEATURE {
    DWORD Offset;
    DWORD Size;
} XSTATE_FEATURE, *PXSTATE_FEATURE;
typedef struct _XSTATE_CONFIGURATION {
    DWORD64 EnabledFeatures;
    DWORD64 EnabledVolatileFeatures;
    DWORD Size;
    union {
        DWORD ControlFlags;
        struct
            DWORD OptimizedSave : 1;
            DWORD CompactionEnabled : 1;
    XSTATE_FEATURE Features[(64)];
    DWORD64 EnabledSupervisorFeatures;
    DWORD64 AlignedFeatures;
    DWORD AllFeatureSize;
    DWORD AllFeatures[(64)];
} XSTATE_CONFIGURATION, *PXSTATE_CONFIGURATION;
typedef struct _MEMORY_BASIC_INFORMATION {
    PVOID BaseAddress;
    PVOID AllocationBase;
    DWORD AllocationProtect;
    SIZE_T RegionSize;
    DWORD State;
    DWORD Protect;
    DWORD Type;
} MEMORY_BASIC_INFORMATION, *PMEMORY_BASIC_INFORMATION;
typedef struct _MEMORY_BASIC_INFORMATION32 {
    DWORD BaseAddress;
    DWORD AllocationBase;
    DWORD RegionSize;
    DWORD State;
    DWORD Protect;
    DWORD Type;
} MEMORY_BASIC_INFORMATION32, *PMEMORY_BASIC_INFORMATION32;
typedef struct __declspec(align(16)) _MEMORY_BASIC_INFORMATION64 {
    ULONGLONG BaseAddress;
    ULONGLONG AllocationBase;
    DWORD     __alignment1;
    ULONGLONG RegionSize;
    DWORD     State;
    DWORD     Protect;
    DWORD     Type;
    DWORD     __alignment2;
} MEMORY_BASIC_INFORMATION64, *PMEMORY_BASIC_INFORMATION64;
typedef struct _CFG_CALL_TARGET_INFO {
    ULONG_PTR Offset;
    ULONG_PTR Flags;
} CFG_CALL_TARGET_INFO, *PCFG_CALL_TARGET_INFO;
#line 12674 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12730 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct MEM_ADDRESS_REQUIREMENTS {
    PVOID LowestStartingAddress;
    PVOID HighestEndingAddress;
    SIZE_T Alignment;
} MEM_ADDRESS_REQUIREMENTS, *PMEM_ADDRESS_REQUIREMENTS;
typedef enum MEM_EXTENDED_PARAMETER_TYPE {
    MemExtendedParameterInvalidType = 0,
    MemExtendedParameterAddressRequirements,
    MemExtendedParameterNumaNode,
    MemExtendedParameterPartitionHandle,
    MemExtendedParameterMax
} MEM_EXTENDED_PARAMETER_TYPE, *PMEM_EXTENDED_PARAMETER_TYPE;
typedef struct __declspec(align(8)) MEM_EXTENDED_PARAMETER {
    struct {
        DWORD64 Type : 8;
        DWORD64 Reserved : 64 - 8;
    union {
        DWORD64 ULong64;
        PVOID Pointer;
        SIZE_T Size;
        HANDLE Handle;
        DWORD ULong;
} MEM_EXTENDED_PARAMETER, *PMEM_EXTENDED_PARAMETER;
#line 12779 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _ENCLAVE_CREATE_INFO_SGX {
    BYTE  Secs[4096];
} ENCLAVE_CREATE_INFO_SGX, *PENCLAVE_CREATE_INFO_SGX;
typedef struct _ENCLAVE_INIT_INFO_SGX {
    BYTE  SigStruct[1808];
    BYTE  Reserved1[240];
    BYTE  EInitToken[304];
    BYTE  Reserved2[1744];
} ENCLAVE_INIT_INFO_SGX, *PENCLAVE_INIT_INFO_SGX;
typedef struct _ENCLAVE_CREATE_INFO_VBS {
    DWORD Flags;
    BYTE  OwnerID[32];
} ENCLAVE_CREATE_INFO_VBS, *PENCLAVE_CREATE_INFO_VBS;
typedef struct _ENCLAVE_INIT_INFO_VBS {
    DWORD Length;
    DWORD ThreadCount;
} ENCLAVE_INIT_INFO_VBS, *PENCLAVE_INIT_INFO_VBS;
typedef PVOID (ENCLAVE_TARGET_FUNCTION)(PVOID);
typedef ENCLAVE_TARGET_FUNCTION (*PENCLAVE_TARGET_FUNCTION);
typedef PENCLAVE_TARGET_FUNCTION LPENCLAVE_TARGET_FUNCTION;
#line 12870 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12933 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 12953 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _FILE_ID_128 {
    BYTE  Identifier[16];
} FILE_ID_128, *PFILE_ID_128;
typedef struct _FILE_NOTIFY_INFORMATION {
    DWORD NextEntryOffset;
    DWORD Action;
    DWORD FileNameLength;
    WCHAR FileName[1];
} FILE_NOTIFY_INFORMATION, *PFILE_NOTIFY_INFORMATION;
typedef struct _FILE_NOTIFY_EXTENDED_INFORMATION {
    DWORD Action;
    LARGE_INTEGER CreationTime;
    LARGE_INTEGER LastModificationTime;
    LARGE_INTEGER LastChangeTime;
    LARGE_INTEGER LastAccessTime;
    LARGE_INTEGER AllocatedLength;
    LARGE_INTEGER FileSize;
    DWORD FileAttributes;
    DWORD ReparsePointTag;
    LARGE_INTEGER FileId;
    LARGE_INTEGER ParentFileId;
    WCHAR FileName[1];
} FILE_NOTIFY_EXTENDED_INFORMATION, *PFILE_NOTIFY_EXTENDED_INFORMATION;
typedef union _FILE_SEGMENT_ELEMENT {
    PVOID64 Buffer;
    ULONGLONG Alignment;
}FILE_SEGMENT_ELEMENT, *PFILE_SEGMENT_ELEMENT;
typedef struct _REPARSE_GUID_DATA_BUFFER {
    DWORD  ReparseTag;
    WORD   ReparseDataLength;
    WORD   Reserved;
    GUID   ReparseGuid;
    struct {
        BYTE   DataBuffer[1];
    } GenericReparseBuffer;
} REPARSE_GUID_DATA_BUFFER, *PREPARSE_GUID_DATA_BUFFER;
#line 13197 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 13208 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _SCRUB_DATA_INPUT {
    DWORD Size;
    DWORD Flags;
    DWORD MaximumIos;
    DWORD ObjectId[4];
    DWORD Reserved[13];
    BYTE  ResumeContext[816];
} SCRUB_DATA_INPUT, *PSCRUB_DATA_INPUT;
typedef struct _SCRUB_PARITY_EXTENT {
    LONGLONG Offset;
    ULONGLONG Length;
} SCRUB_PARITY_EXTENT, *PSCRUB_PARITY_EXTENT;
typedef struct _SCRUB_PARITY_EXTENT_DATA {
    WORD   Size;
    WORD   Flags;
    WORD   NumberOfParityExtents;
    WORD   MaximumNumberOfParityExtents;
    SCRUB_PARITY_EXTENT ParityExtents[1];
} SCRUB_PARITY_EXTENT_DATA, *PSCRUB_PARITY_EXTENT_DATA;
typedef struct _SCRUB_DATA_OUTPUT {
    DWORD Size;
    DWORD Flags;
    DWORD Status;
    ULONGLONG ErrorFileOffset;
    ULONGLONG ErrorLength;
    ULONGLONG NumberOfBytesRepaired;
    ULONGLONG NumberOfBytesFailed;
    ULONGLONG InternalFileReference;
    WORD   ResumeContextLength;
    WORD   ParityExtentDataOffset;
    DWORD Reserved[5];
#line 13402 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
} SCRUB_DATA_OUTPUT, *PSCRUB_DATA_OUTPUT;
typedef enum _SharedVirtualDiskSupportType
    SharedVirtualDisksUnsupported = 0,
    SharedVirtualDisksSupported = 1,
    SharedVirtualDiskSnapshotsSupported = 3,
    SharedVirtualDiskCDPSnapshotsSupported = 7
} SharedVirtualDiskSupportType;
typedef enum _SharedVirtualDiskHandleState
    SharedVirtualDiskHandleStateNone = 0,
    SharedVirtualDiskHandleStateFileShared = 1,
    SharedVirtualDiskHandleStateHandleShared = 3
} SharedVirtualDiskHandleState;
typedef struct _SHARED_VIRTUAL_DISK_SUPPORT {
    SharedVirtualDiskSupportType SharedVirtualDiskSupport;
    SharedVirtualDiskHandleState HandleState;
} SHARED_VIRTUAL_DISK_SUPPORT, *PSHARED_VIRTUAL_DISK_SUPPORT;
typedef struct _NETWORK_APP_INSTANCE_EA {
    GUID AppInstanceID;
    DWORD CsvFlags;
} NETWORK_APP_INSTANCE_EA, *PNETWORK_APP_INSTANCE_EA;
extern const GUID GUID_MAX_POWER_SAVINGS;
extern const GUID GUID_MIN_POWER_SAVINGS;
extern const GUID GUID_TYPICAL_POWER_SAVINGS;
extern const GUID NO_SUBGROUP_GUID;
extern const GUID ALL_POWERSCHEMES_GUID;
extern const GUID GUID_POWERSCHEME_PERSONALITY;
extern const GUID GUID_ACTIVE_POWERSCHEME;
extern const GUID GUID_IDLE_RESILIENCY_SUBGROUP;
extern const GUID GUID_IDLE_RESILIENCY_PERIOD;
extern const GUID GUID_DEEP_SLEEP_ENABLED;
extern const GUID GUID_DEEP_SLEEP_PLATFORM_STATE;
extern const GUID GUID_DISK_COALESCING_POWERDOWN_TIMEOUT;
extern const GUID GUID_EXECUTION_REQUIRED_REQUEST_TIMEOUT;
extern const GUID GUID_VIDEO_SUBGROUP;
extern const GUID GUID_VIDEO_POWERDOWN_TIMEOUT;
extern const GUID GUID_VIDEO_ANNOYANCE_TIMEOUT;
extern const GUID GUID_VIDEO_ADAPTIVE_PERCENT_INCREASE;
extern const GUID GUID_VIDEO_DIM_TIMEOUT;
extern const GUID GUID_VIDEO_ADAPTIVE_POWERDOWN;
extern const GUID GUID_MONITOR_POWER_ON;
extern const GUID GUID_DEVICE_POWER_POLICY_VIDEO_BRIGHTNESS;
extern const GUID GUID_DEVICE_POWER_POLICY_VIDEO_DIM_BRIGHTNESS;
extern const GUID GUID_VIDEO_CURRENT_MONITOR_BRIGHTNESS;
extern const GUID GUID_VIDEO_ADAPTIVE_DISPLAY_BRIGHTNESS;
extern const GUID GUID_CONSOLE_DISPLAY_STATE;
extern const GUID GUID_ALLOW_DISPLAY_REQUIRED;
extern const GUID GUID_VIDEO_CONSOLE_LOCK_TIMEOUT;
extern const GUID GUID_ADAPTIVE_POWER_BEHAVIOR_SUBGROUP;
extern const GUID GUID_NON_ADAPTIVE_INPUT_TIMEOUT;
extern const GUID GUID_ADAPTIVE_INPUT_CONTROLLER_STATE;
extern const GUID GUID_DISK_SUBGROUP;
extern const GUID GUID_DISK_MAX_POWER;
extern const GUID GUID_DISK_POWERDOWN_TIMEOUT;
extern const GUID GUID_DISK_IDLE_TIMEOUT;
extern const GUID GUID_DISK_BURST_IGNORE_THRESHOLD;
extern const GUID GUID_DISK_ADAPTIVE_POWERDOWN;
extern const GUID GUID_SLEEP_SUBGROUP;
extern const GUID GUID_SLEEP_IDLE_THRESHOLD;
extern const GUID GUID_STANDBY_TIMEOUT;
extern const GUID GUID_UNATTEND_SLEEP_TIMEOUT;
extern const GUID GUID_HIBERNATE_TIMEOUT;
extern const GUID GUID_HIBERNATE_FASTS4_POLICY;
extern const GUID GUID_CRITICAL_POWER_TRANSITION;
extern const GUID GUID_SYSTEM_AWAYMODE;
extern const GUID GUID_ALLOW_AWAYMODE;
extern const GUID GUID_USER_PRESENCE_PREDICTION;
extern const GUID GUID_STANDBY_BUDGET_GRACE_PERIOD;
extern const GUID GUID_STANDBY_BUDGET_PERCENT;
extern const GUID GUID_STANDBY_RESERVE_GRACE_PERIOD;
extern const GUID GUID_STANDBY_RESERVE_TIME;
extern const GUID GUID_STANDBY_RESET_PERCENT;
extern const GUID GUID_ALLOW_STANDBY_STATES;
extern const GUID GUID_ALLOW_RTC_WAKE;
extern const GUID GUID_LEGACY_RTC_MITIGATION;
extern const GUID GUID_ALLOW_SYSTEM_REQUIRED;
extern const GUID GUID_POWER_SAVING_STATUS;
extern const GUID GUID_ENERGY_SAVER_SUBGROUP;
extern const GUID GUID_ENERGY_SAVER_BATTERY_THRESHOLD;
extern const GUID GUID_ENERGY_SAVER_BRIGHTNESS;
extern const GUID GUID_ENERGY_SAVER_POLICY;
extern const GUID GUID_SYSTEM_BUTTON_SUBGROUP;
extern const GUID GUID_POWERBUTTON_ACTION;
extern const GUID GUID_SLEEPBUTTON_ACTION;
extern const GUID GUID_USERINTERFACEBUTTON_ACTION;
extern const GUID GUID_LIDCLOSE_ACTION;
extern const GUID GUID_LIDOPEN_POWERSTATE;
extern const GUID GUID_BATTERY_SUBGROUP;
extern const GUID GUID_BATTERY_DISCHARGE_ACTION_0;
extern const GUID GUID_BATTERY_DISCHARGE_LEVEL_0;
extern const GUID GUID_BATTERY_DISCHARGE_FLAGS_0;
extern const GUID GUID_BATTERY_DISCHARGE_ACTION_1;
extern const GUID GUID_BATTERY_DISCHARGE_LEVEL_1;
extern const GUID GUID_BATTERY_DISCHARGE_FLAGS_1;
extern const GUID GUID_BATTERY_DISCHARGE_ACTION_2;
extern const GUID GUID_BATTERY_DISCHARGE_LEVEL_2;
extern const GUID GUID_BATTERY_DISCHARGE_FLAGS_2;
extern const GUID GUID_BATTERY_DISCHARGE_ACTION_3;
extern const GUID GUID_BATTERY_DISCHARGE_LEVEL_3;
extern const GUID GUID_BATTERY_DISCHARGE_FLAGS_3;
extern const GUID GUID_PROCESSOR_SETTINGS_SUBGROUP;
extern const GUID GUID_PROCESSOR_THROTTLE_POLICY;
extern const GUID GUID_PROCESSOR_THROTTLE_MAXIMUM;
extern const GUID GUID_PROCESSOR_THROTTLE_MAXIMUM_1;
extern const GUID GUID_PROCESSOR_THROTTLE_MINIMUM;
extern const GUID GUID_PROCESSOR_THROTTLE_MINIMUM_1;
extern const GUID GUID_PROCESSOR_FREQUENCY_LIMIT;
extern const GUID GUID_PROCESSOR_FREQUENCY_LIMIT_1;
extern const GUID GUID_PROCESSOR_ALLOW_THROTTLING;
extern const GUID GUID_PROCESSOR_IDLESTATE_POLICY;
extern const GUID GUID_PROCESSOR_PERFSTATE_POLICY;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_THRESHOLD;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_THRESHOLD_1;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_THRESHOLD;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_THRESHOLD_1;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_POLICY;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_POLICY_1;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_POLICY;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_POLICY_1;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_TIME;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_TIME_1;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_TIME;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_TIME_1;
extern const GUID GUID_PROCESSOR_PERF_TIME_CHECK;
extern const GUID GUID_PROCESSOR_PERF_BOOST_POLICY;
extern const GUID GUID_PROCESSOR_PERF_BOOST_MODE;
#line 14399 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
extern const GUID GUID_PROCESSOR_PERF_AUTONOMOUS_MODE;
extern const GUID GUID_PROCESSOR_PERF_ENERGY_PERFORMANCE_PREFERENCE;
extern const GUID GUID_PROCESSOR_PERF_AUTONOMOUS_ACTIVITY_WINDOW;
extern const GUID GUID_PROCESSOR_DUTY_CYCLING;
extern const GUID GUID_PROCESSOR_IDLE_ALLOW_SCALING;
extern const GUID GUID_PROCESSOR_IDLE_DISABLE;
extern const GUID GUID_PROCESSOR_IDLE_STATE_MAXIMUM;
extern const GUID GUID_PROCESSOR_IDLE_TIME_CHECK;
extern const GUID GUID_PROCESSOR_IDLE_DEMOTE_THRESHOLD;
extern const GUID GUID_PROCESSOR_IDLE_PROMOTE_THRESHOLD;
extern const GUID GUID_PROCESSOR_CORE_PARKING_INCREASE_THRESHOLD;
extern const GUID GUID_PROCESSOR_CORE_PARKING_DECREASE_THRESHOLD;
extern const GUID GUID_PROCESSOR_CORE_PARKING_INCREASE_POLICY;
extern const GUID GUID_PROCESSOR_CORE_PARKING_DECREASE_POLICY;
extern const GUID GUID_PROCESSOR_CORE_PARKING_MAX_CORES;
extern const GUID GUID_PROCESSOR_CORE_PARKING_MAX_CORES_1;
extern const GUID GUID_PROCESSOR_CORE_PARKING_MIN_CORES;
extern const GUID GUID_PROCESSOR_CORE_PARKING_MIN_CORES_1;
extern const GUID GUID_PROCESSOR_CORE_PARKING_INCREASE_TIME;
extern const GUID GUID_PROCESSOR_CORE_PARKING_DECREASE_TIME;
extern const GUID GUID_PROCESSOR_CORE_PARKING_AFFINITY_HISTORY_DECREASE_FACTOR;
extern const GUID GUID_PROCESSOR_CORE_PARKING_AFFINITY_HISTORY_THRESHOLD;
extern const GUID GUID_PROCESSOR_CORE_PARKING_AFFINITY_WEIGHTING;
extern const GUID GUID_PROCESSOR_CORE_PARKING_OVER_UTILIZATION_HISTORY_DECREASE_FACTOR;
extern const GUID GUID_PROCESSOR_CORE_PARKING_OVER_UTILIZATION_HISTORY_THRESHOLD;
extern const GUID GUID_PROCESSOR_CORE_PARKING_OVER_UTILIZATION_WEIGHTING;
extern const GUID GUID_PROCESSOR_CORE_PARKING_OVER_UTILIZATION_THRESHOLD;
extern const GUID GUID_PROCESSOR_PARKING_CORE_OVERRIDE;
extern const GUID GUID_PROCESSOR_PARKING_PERF_STATE;
extern const GUID GUID_PROCESSOR_PARKING_PERF_STATE_1;
extern const GUID GUID_PROCESSOR_PARKING_CONCURRENCY_THRESHOLD;
extern const GUID GUID_PROCESSOR_PARKING_HEADROOM_THRESHOLD;
extern const GUID GUID_PROCESSOR_PARKING_DISTRIBUTION_THRESHOLD;
extern const GUID GUID_PROCESSOR_PERF_HISTORY;
extern const GUID GUID_PROCESSOR_PERF_HISTORY_1;
extern const GUID GUID_PROCESSOR_PERF_INCREASE_HISTORY;
extern const GUID GUID_PROCESSOR_PERF_DECREASE_HISTORY;
extern const GUID GUID_PROCESSOR_PERF_CORE_PARKING_HISTORY;
extern const GUID GUID_PROCESSOR_PERF_LATENCY_HINT;
extern const GUID GUID_PROCESSOR_PERF_LATENCY_HINT_PERF;
extern const GUID GUID_PROCESSOR_PERF_LATENCY_HINT_PERF_1;
extern const GUID GUID_PROCESSOR_LATENCY_HINT_MIN_UNPARK;
extern const GUID GUID_PROCESSOR_LATENCY_HINT_MIN_UNPARK_1;
extern const GUID GUID_PROCESSOR_DISTRIBUTE_UTILITY;
extern const GUID GUID_PROCESSOR_HETEROGENEOUS_POLICY;
extern const GUID GUID_PROCESSOR_HETERO_DECREASE_TIME;
extern const GUID GUID_PROCESSOR_HETERO_INCREASE_TIME;
extern const GUID GUID_PROCESSOR_HETERO_DECREASE_THRESHOLD;
extern const GUID GUID_PROCESSOR_HETERO_INCREASE_THRESHOLD;
extern const GUID GUID_PROCESSOR_CLASS0_FLOOR_PERF;
extern const GUID GUID_PROCESSOR_CLASS1_INITIAL_PERF;
extern const GUID GUID_PROCESSOR_THREAD_SCHEDULING_POLICY;
extern const GUID GUID_PROCESSOR_SHORT_THREAD_SCHEDULING_POLICY;
extern const GUID GUID_SYSTEM_COOLING_POLICY;
extern const GUID GUID_LOCK_CONSOLE_ON_WAKE;
extern const GUID GUID_DEVICE_IDLE_POLICY;
extern const GUID GUID_CONNECTIVITY_IN_STANDBY;
extern const GUID GUID_DISCONNECTED_STANDBY_MODE;
extern const GUID GUID_ACDC_POWER_SOURCE;
extern const GUID GUID_LIDSWITCH_STATE_CHANGE;
extern const GUID GUID_BATTERY_PERCENTAGE_REMAINING;
extern const GUID GUID_BATTERY_COUNT;
extern const GUID GUID_GLOBAL_USER_PRESENCE;
extern const GUID GUID_SESSION_DISPLAY_STATUS;
extern const GUID GUID_SESSION_USER_PRESENCE;
extern const GUID GUID_IDLE_BACKGROUND_TASK;
extern const GUID GUID_BACKGROUND_TASK_NOTIFICATION;
extern const GUID GUID_APPLAUNCH_BUTTON;
extern const GUID GUID_PCIEXPRESS_SETTINGS_SUBGROUP;
extern const GUID GUID_PCIEXPRESS_ASPM_POLICY;
extern const GUID GUID_ENABLE_SWITCH_FORCED_SHUTDOWN;
extern const GUID GUID_INTSTEER_SUBGROUP;
extern const GUID GUID_INTSTEER_MODE;
extern const GUID GUID_INTSTEER_LOAD_PER_PROC_TRIGGER;
extern const GUID GUID_INTSTEER_TIME_UNPARK_TRIGGER;
extern const GUID GUID_GRAPHICS_SUBGROUP;
extern const GUID GUID_GPU_PREFERENCE_POLICY;
extern const GUID GUID_MIXED_REALITY_MODE;
extern const GUID GUID_SPR_ACTIVE_SESSION_CHANGE;
typedef enum _SYSTEM_POWER_STATE {
    PowerSystemUnspecified = 0,
    PowerSystemWorking     = 1,
    PowerSystemSleeping1   = 2,
    PowerSystemSleeping2   = 3,
    PowerSystemSleeping3   = 4,
    PowerSystemHibernate   = 5,
    PowerSystemShutdown    = 6,
    PowerSystemMaximum     = 7
} SYSTEM_POWER_STATE, *PSYSTEM_POWER_STATE;
typedef enum {
    PowerActionNone = 0,
    PowerActionReserved,
    PowerActionSleep,
    PowerActionHibernate,
    PowerActionShutdown,
    PowerActionShutdownReset,
    PowerActionShutdownOff,
    PowerActionWarmEject,
    PowerActionDisplayOff
} POWER_ACTION, *PPOWER_ACTION;
typedef enum _DEVICE_POWER_STATE {
    PowerDeviceUnspecified = 0,
    PowerDeviceD0,
    PowerDeviceD1,
    PowerDeviceD2,
    PowerDeviceD3,
    PowerDeviceMaximum
} DEVICE_POWER_STATE, *PDEVICE_POWER_STATE;
typedef enum _MONITOR_DISPLAY_STATE {
    PowerMonitorOff = 0,
    PowerMonitorOn,
    PowerMonitorDim
} MONITOR_DISPLAY_STATE, *PMONITOR_DISPLAY_STATE;
typedef enum _USER_ACTIVITY_PRESENCE {
    PowerUserPresent = 0,
    PowerUserNotPresent,
    PowerUserInactive,
    PowerUserMaximum,
    PowerUserInvalid = PowerUserMaximum
} USER_ACTIVITY_PRESENCE, *PUSER_ACTIVITY_PRESENCE;
typedef DWORD EXECUTION_STATE, *PEXECUTION_STATE;
typedef enum {
    LT_DONT_CARE,
    LT_LOWEST_LATENCY
} LATENCY_TIME;
typedef enum _POWER_REQUEST_TYPE {
    PowerRequestDisplayRequired,
    PowerRequestSystemRequired,
    PowerRequestAwayModeRequired,
    PowerRequestExecutionRequired
} POWER_REQUEST_TYPE, *PPOWER_REQUEST_TYPE;
#line 15202 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct CM_Power_Data_s {
    DWORD               PD_Size;
    DEVICE_POWER_STATE  PD_MostRecentPowerState;
    DWORD               PD_Capabilities;
    DWORD               PD_D1Latency;
    DWORD               PD_D2Latency;
    DWORD               PD_D3Latency;
    DEVICE_POWER_STATE  PD_PowerStateMapping[7];
    SYSTEM_POWER_STATE  PD_DeepestSystemWake;
} CM_POWER_DATA, *PCM_POWER_DATA;
typedef enum {
    SystemPowerPolicyAc,
    SystemPowerPolicyDc,
    VerifySystemPolicyAc,
    VerifySystemPolicyDc,
    SystemPowerCapabilities,
    SystemBatteryState,
    SystemPowerStateHandler,
    ProcessorStateHandler,
    SystemPowerPolicyCurrent,
    AdministratorPowerPolicy,
    SystemReserveHiberFile,
    ProcessorInformation,
    SystemPowerInformation,
    ProcessorStateHandler2,
    LastWakeTime,
    LastSleepTime,
    SystemExecutionState,
    SystemPowerStateNotifyHandler,
    ProcessorPowerPolicyAc,
    ProcessorPowerPolicyDc,
    VerifyProcessorPowerPolicyAc,
    VerifyProcessorPowerPolicyDc,
    ProcessorPowerPolicyCurrent,
    SystemPowerStateLogging,
    SystemPowerLoggingEntry,
    SetPowerSettingValue,
    NotifyUserPowerSetting,
    PowerInformationLevelUnused0,
    SystemMonitorHiberBootPowerOff,
    SystemVideoState,
    TraceApplicationPowerMessage,
    TraceApplicationPowerMessageEnd,
    ProcessorPerfStates,
    ProcessorIdleStates,
    ProcessorCap,
    SystemWakeSource,
    SystemHiberFileInformation,
    TraceServicePowerMessage,
    ProcessorLoad,
    PowerShutdownNotification,
    MonitorCapabilities,
    SessionPowerInit,
    SessionDisplayState,
    PowerRequestCreate,
    PowerRequestAction,
    GetPowerRequestList,
    ProcessorInformationEx,
    NotifyUserModeLegacyPowerEvent,
    GroupPark,
    ProcessorIdleDomains,
    WakeTimerList,
    SystemHiberFileSize,
    ProcessorIdleStatesHv,
    ProcessorPerfStatesHv,
    ProcessorPerfCapHv,
    ProcessorSetIdle,
    LogicalProcessorIdling,
    UserPresence,
    PowerSettingNotificationName,
    GetPowerSettingValue,
    IdleResiliency,
    SessionRITState,
    SessionConnectNotification,
    SessionPowerCleanup,
    SessionLockState,
    SystemHiberbootState,
    PlatformInformation,
    PdcInvocation,
    MonitorInvocation,
    FirmwareTableInformationRegistered,
    SetShutdownSelectedTime,
    SuspendResumeInvocation,
    PlmPowerRequestCreate,
    ScreenOff,
    CsDeviceNotification,
    PlatformRole,
    LastResumePerformance,
    DisplayBurst,
    ExitLatencySamplingPercentage,
    RegisterSpmPowerSettings,
    PlatformIdleStates,
    ProcessorIdleVeto,
    PlatformIdleVeto,
    SystemBatteryStatePrecise,
    ThermalEvent,
    PowerRequestActionInternal,
    BatteryDeviceState,
    PowerInformationInternal,
    ThermalStandby,
    SystemHiberFileType,
    PhysicalPowerButtonPress,
    QueryPotentialDripsConstraint,
    EnergyTrackerCreate,
    EnergyTrackerQuery,
    UpdateBlackBoxRecorder,
    PowerInformationLevelMaximum
} POWER_INFORMATION_LEVEL;
typedef enum {
    UserNotPresent = 0,
    UserPresent = 1,
    UserUnknown = 0xff
} POWER_USER_PRESENCE_TYPE, *PPOWER_USER_PRESENCE_TYPE;
typedef struct _POWER_USER_PRESENCE {
    POWER_USER_PRESENCE_TYPE UserPresence;
} POWER_USER_PRESENCE, *PPOWER_USER_PRESENCE;
typedef struct _POWER_SESSION_CONNECT {
    BOOLEAN Connected;
    BOOLEAN Console;
} POWER_SESSION_CONNECT, *PPOWER_SESSION_CONNECT;
typedef struct _POWER_SESSION_TIMEOUTS {
    DWORD InputTimeout;
    DWORD DisplayTimeout;
} POWER_SESSION_TIMEOUTS, *PPOWER_SESSION_TIMEOUTS;
typedef struct _POWER_SESSION_RIT_STATE {
    BOOLEAN Active;
    DWORD LastInputTime;
} POWER_SESSION_RIT_STATE, *PPOWER_SESSION_RIT_STATE;
typedef struct _POWER_SESSION_WINLOGON {
    DWORD SessionId;
    BOOLEAN Console;
    BOOLEAN Locked;
} POWER_SESSION_WINLOGON, *PPOWER_SESSION_WINLOGON;
typedef struct _POWER_IDLE_RESILIENCY {
    DWORD CoalescingTimeout;
    DWORD IdleResiliencyPeriod;
} POWER_IDLE_RESILIENCY, *PPOWER_IDLE_RESILIENCY;
typedef enum {
    MonitorRequestReasonUnknown,
    MonitorRequestReasonPowerButton,
    MonitorRequestReasonRemoteConnection,
    MonitorRequestReasonScMonitorpower,
    MonitorRequestReasonUserInput,
    MonitorRequestReasonAcDcDisplayBurst,
    MonitorRequestReasonUserDisplayBurst,
    MonitorRequestReasonPoSetSystemState,
    MonitorRequestReasonSetThreadExecutionState,
    MonitorRequestReasonFullWake,
    MonitorRequestReasonSessionUnlock,
    MonitorRequestReasonScreenOffRequest,
    MonitorRequestReasonIdleTimeout,
    MonitorRequestReasonPolicyChange,
    MonitorRequestReasonSleepButton,
    MonitorRequestReasonLid,
    MonitorRequestReasonBatteryCountChange,
    MonitorRequestReasonGracePeriod,
    MonitorRequestReasonPnP,
    MonitorRequestReasonDP,
    MonitorRequestReasonSxTransition,
    MonitorRequestReasonSystemIdle,
    MonitorRequestReasonNearProximity,
    MonitorRequestReasonThermalStandby,
    MonitorRequestReasonResumePdc,
    MonitorRequestReasonResumeS4,
    MonitorRequestReasonTerminal,
    MonitorRequestReasonPdcSignal,
    MonitorRequestReasonAcDcDisplayBurstSuppressed,
    MonitorRequestReasonSystemStateEntered,
    MonitorRequestReasonWinrt,
    MonitorRequestReasonUserInputKeyboard,
    MonitorRequestReasonUserInputMouse,
    MonitorRequestReasonUserInputTouch,
    MonitorRequestReasonUserInputPen,
    MonitorRequestReasonUserInputAccelerometer,
    MonitorRequestReasonUserInputHid,
    MonitorRequestReasonUserInputPoUserPresent,
    MonitorRequestReasonUserInputSessionSwitch,
    MonitorRequestReasonUserInputInitialization,
    MonitorRequestReasonPdcSignalWindowsMobilePwrNotif,
    MonitorRequestReasonPdcSignalWindowsMobileShell,
    MonitorRequestReasonPdcSignalHeyCortana,
    MonitorRequestReasonPdcSignalHolographicShell,
    MonitorRequestReasonPdcSignalFingerprint,
    MonitorRequestReasonMax
} POWER_MONITOR_REQUEST_REASON;
typedef enum _POWER_MONITOR_REQUEST_TYPE {
    MonitorRequestTypeOff,
    MonitorRequestTypeOnAndPresent,
    MonitorRequestTypeToggleOn
} POWER_MONITOR_REQUEST_TYPE;
typedef struct _POWER_MONITOR_INVOCATION {
    BOOLEAN Console;
    POWER_MONITOR_REQUEST_REASON RequestReason;
} POWER_MONITOR_INVOCATION, *PPOWER_MONITOR_INVOCATION;
typedef struct _RESUME_PERFORMANCE {
    DWORD PostTimeMs;
    ULONGLONG TotalResumeTimeMs;
    ULONGLONG ResumeCompleteTimestamp;
} RESUME_PERFORMANCE, *PRESUME_PERFORMANCE;
typedef enum {
    PoAc,
    PoDc,
    PoHot,
    PoConditionMaximum
} SYSTEM_POWER_CONDITION;
typedef struct {
    DWORD       Version;
    GUID        Guid;
    SYSTEM_POWER_CONDITION PowerCondition;
    DWORD       DataLength;
    BYTE    Data[1];
} SET_POWER_SETTING_VALUE, *PSET_POWER_SETTING_VALUE;
typedef struct {
    GUID Guid;
} NOTIFY_USER_POWER_SETTING, *PNOTIFY_USER_POWER_SETTING;
typedef struct _APPLICATIONLAUNCH_SETTING_VALUE {
    LARGE_INTEGER       ActivationTime;
    DWORD               Flags;
    DWORD               ButtonInstanceID;
} APPLICATIONLAUNCH_SETTING_VALUE, *PAPPLICATIONLAUNCH_SETTING_VALUE;
typedef enum _POWER_PLATFORM_ROLE {
    PlatformRoleUnspecified = 0,
    PlatformRoleDesktop,
    PlatformRoleMobile,
    PlatformRoleWorkstation,
    PlatformRoleEnterpriseServer,
    PlatformRoleSOHOServer,
    PlatformRoleAppliancePC,
    PlatformRolePerformanceServer,
    PlatformRoleSlate,
    PlatformRoleMaximum
} POWER_PLATFORM_ROLE, *PPOWER_PLATFORM_ROLE;
#line 15558 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _POWER_PLATFORM_INFORMATION {
    BOOLEAN AoAc;
} POWER_PLATFORM_INFORMATION, *PPOWER_PLATFORM_INFORMATION;
typedef struct {
    DWORD       Granularity;
    DWORD       Capacity;
} BATTERY_REPORTING_SCALE, *PBATTERY_REPORTING_SCALE;
typedef struct {
    DWORD   Frequency;
    DWORD   Flags;
    DWORD   PercentFrequency;
} PPM_WMI_LEGACY_PERFSTATE, *PPPM_WMI_LEGACY_PERFSTATE;
typedef struct {
    DWORD Latency;
    DWORD Power;
    DWORD TimeCheck;
    BYTE  PromotePercent;
    BYTE  DemotePercent;
    BYTE  StateType;
    BYTE  Reserved;
    DWORD StateFlags;
    DWORD Context;
    DWORD IdleHandler;
    DWORD Reserved1;
} PPM_WMI_IDLE_STATE, *PPPM_WMI_IDLE_STATE;
typedef struct {
    DWORD Type;
    DWORD Count;
    DWORD TargetState;
    DWORD OldState;
    DWORD64 TargetProcessors;
    PPM_WMI_IDLE_STATE State[1];
} PPM_WMI_IDLE_STATES, *PPPM_WMI_IDLE_STATES;
typedef struct {
    DWORD Type;
    DWORD Count;
    DWORD TargetState;
    DWORD OldState;
    PVOID TargetProcessors;
} PPM_WMI_IDLE_STATES_EX, *PPPM_WMI_IDLE_STATES_EX;
typedef struct {
    DWORD Frequency;
    DWORD Power;
    BYTE  PercentFrequency;
    BYTE  IncreaseLevel;
    BYTE  DecreaseLevel;
    BYTE  Type;
    DWORD IncreaseTime;
    DWORD DecreaseTime;
    DWORD64 Control;
    DWORD64 Status;
    DWORD HitCount;
    DWORD Reserved1;
    DWORD64 Reserved2;
    DWORD64 Reserved3;
} PPM_WMI_PERF_STATE, *PPPM_WMI_PERF_STATE;
typedef struct {
    DWORD Count;
    DWORD MaxFrequency;
    DWORD CurrentState;
    DWORD MaxPerfState;
    DWORD MinPerfState;
    DWORD LowestPerfState;
    DWORD ThermalConstraint;
    BYTE  BusyAdjThreshold;
    BYTE  PolicyType;
    BYTE  Type;
    BYTE  Reserved;
    DWORD TimerInterval;
    DWORD PStateHandler;
    DWORD PStateContext;
    DWORD TStateHandler;
    DWORD TStateContext;
    DWORD FeedbackHandler;
    DWORD Reserved1;
    DWORD64 Reserved2;
    PPM_WMI_PERF_STATE State[1];
} PPM_WMI_PERF_STATES, *PPPM_WMI_PERF_STATES;
typedef struct {
    DWORD Count;
    DWORD MaxFrequency;
    DWORD CurrentState;
    DWORD MaxPerfState;
    DWORD MinPerfState;
    BYTE  PolicyType;
    BYTE  Type;
    BYTE  Reserved;
    DWORD Reserved1;
    DWORD64 Reserved2;
} PPM_WMI_PERF_STATES_EX, *PPPM_WMI_PERF_STATES_EX;
typedef struct {
    DWORD IdleTransitions;
    DWORD FailedTransitions;
    DWORD InvalidBucketIndex;
    DWORD64 TotalTime;
    DWORD IdleTimeBuckets[6];
} PPM_IDLE_STATE_ACCOUNTING, *PPPM_IDLE_STATE_ACCOUNTING;
typedef struct {
    DWORD StateCount;
    DWORD TotalTransitions;
    DWORD ResetCount;
    DWORD64 StartTime;
    PPM_IDLE_STATE_ACCOUNTING State[1];
} PPM_IDLE_ACCOUNTING, *PPPM_IDLE_ACCOUNTING;
typedef struct {
    DWORD64 TotalTimeUs;
    DWORD MinTimeUs;
    DWORD MaxTimeUs;
    DWORD Count;
} PPM_IDLE_STATE_BUCKET_EX, *PPPM_IDLE_STATE_BUCKET_EX;
typedef struct {
    DWORD64 TotalTime;
    DWORD MinTimeUs;
    DWORD MaxTimeUs;
    DWORD CancelledTransitions;
    PPM_IDLE_STATE_BUCKET_EX IdleTimeBuckets[16];
} PPM_IDLE_STATE_ACCOUNTING_EX, *PPPM_IDLE_STATE_ACCOUNTING_EX;
typedef struct {
    DWORD StateCount;
    DWORD ResetCount;
    DWORD AbortCount;
    DWORD64 StartTime;
     PPM_IDLE_STATE_ACCOUNTING_EX State[1];
} PPM_IDLE_ACCOUNTING_EX, *PPPM_IDLE_ACCOUNTING_EX;
#line 15773 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
extern const GUID PPM_PERFSTATE_CHANGE_GUID;
extern const GUID PPM_PERFSTATE_DOMAIN_CHANGE_GUID;
extern const GUID PPM_IDLESTATE_CHANGE_GUID;
extern const GUID PPM_PERFSTATES_DATA_GUID;
extern const GUID PPM_IDLESTATES_DATA_GUID;
extern const GUID PPM_IDLE_ACCOUNTING_GUID;
extern const GUID PPM_IDLE_ACCOUNTING_EX_GUID;
extern const GUID PPM_THERMALCONSTRAINT_GUID;
extern const GUID PPM_PERFMON_PERFSTATE_GUID;
extern const GUID PPM_THERMAL_POLICY_CHANGE_GUID;
typedef struct {
    DWORD State;
    DWORD Status;
    DWORD Latency;
    DWORD Speed;
    DWORD Processor;
} PPM_PERFSTATE_EVENT, *PPPM_PERFSTATE_EVENT;
typedef struct {
    DWORD State;
    DWORD Latency;
    DWORD Speed;
    DWORD64 Processors;
} PPM_PERFSTATE_DOMAIN_EVENT, *PPPM_PERFSTATE_DOMAIN_EVENT;
typedef struct {
    DWORD NewState;
    DWORD OldState;
    DWORD64 Processors;
} PPM_IDLESTATE_EVENT, *PPPM_IDLESTATE_EVENT;
typedef struct {
    DWORD64 Processors;
} PPM_THERMALCHANGE_EVENT, *PPPM_THERMALCHANGE_EVENT;
#pragma warning(push)
#pragma warning(disable:4121)
typedef struct {
    BYTE  Mode;
    DWORD64 Processors;
} PPM_THERMAL_POLICY_EVENT, *PPPM_THERMAL_POLICY_EVENT;
#pragma warning(pop)
typedef struct {
    POWER_ACTION    Action;
    DWORD           Flags;
    DWORD           EventCode;
} POWER_ACTION_POLICY, *PPOWER_ACTION_POLICY;
#line 15895 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 15904 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct {
    BOOLEAN                 Enable;
    BYTE                    Spare[3];
    DWORD                   BatteryLevel;
    POWER_ACTION_POLICY     PowerPolicy;
    SYSTEM_POWER_STATE      MinSystemState;
} SYSTEM_POWER_LEVEL, *PSYSTEM_POWER_LEVEL;
typedef struct _SYSTEM_POWER_POLICY {
    DWORD                   Revision;
    POWER_ACTION_POLICY     PowerButton;
    POWER_ACTION_POLICY     SleepButton;
    POWER_ACTION_POLICY     LidClose;
    SYSTEM_POWER_STATE      LidOpenWake;
    DWORD                   Reserved;
    POWER_ACTION_POLICY     Idle;
    DWORD                   IdleTimeout;
    BYTE                    IdleSensitivity;
    BYTE                    DynamicThrottle;
    BYTE                    Spare2[2];
    SYSTEM_POWER_STATE      MinSleep;
    SYSTEM_POWER_STATE      MaxSleep;
    SYSTEM_POWER_STATE      ReducedLatencySleep;
    DWORD                   WinLogonFlags;
    DWORD                   Spare3;
    DWORD                   DozeS4Timeout;
    DWORD                   BroadcastCapacityResolution;
    SYSTEM_POWER_LEVEL      DischargePolicy[4];
    DWORD                   VideoTimeout;
    BOOLEAN                 VideoDimDisplay;
    DWORD                   VideoReserved[3];
    DWORD                   SpindownTimeout;
    BOOLEAN                 OptimizeForPower;
    BYTE                    FanThrottleTolerance;
    BYTE                    ForcedThrottle;
    BYTE                    MinThrottle;
    POWER_ACTION_POLICY     OverThrottled;
} SYSTEM_POWER_POLICY, *PSYSTEM_POWER_POLICY;
typedef struct {
    DWORD TimeCheck;
    BYTE  DemotePercent;
    BYTE  Spare[2];
} PROCESSOR_IDLESTATE_INFO, *PPROCESSOR_IDLESTATE_INFO;
typedef struct {
    WORD   Revision;
    union {
        WORD   AsWORD  ;
        struct {
            WORD   AllowScaling : 1;
            WORD   Disabled : 1;
            WORD   Reserved : 14;
    } Flags;
    DWORD PolicyCount;
    PROCESSOR_IDLESTATE_INFO Policy[0x3];
} PROCESSOR_IDLESTATE_POLICY, *PPROCESSOR_IDLESTATE_POLICY;
typedef struct _PROCESSOR_POWER_POLICY_INFO {
    DWORD                   TimeCheck;
    DWORD                   DemoteLimit;
    DWORD                   PromoteLimit;
    BYTE                    DemotePercent;
    BYTE                    Spare[2];
    DWORD                   AllowDemotion:1;
    DWORD                   AllowPromotion:1;
    DWORD                   Reserved:30;
} PROCESSOR_POWER_POLICY_INFO, *PPROCESSOR_POWER_POLICY_INFO;
typedef struct _PROCESSOR_POWER_POLICY {
    DWORD                       Revision;
    BYTE                        Spare[3];
    DWORD                       DisableCStates:1;
    DWORD                       Reserved:31;
    DWORD                       PolicyCount;
    PROCESSOR_POWER_POLICY_INFO Policy[3];
} PROCESSOR_POWER_POLICY, *PPROCESSOR_POWER_POLICY;
typedef struct {
    DWORD Revision;
    BYTE  MaxThrottle;
    BYTE  MinThrottle;
    union {
        BYTE  Spare;
        union {
            BYTE  AsBYTE ;
            struct {
                BYTE  NoDomainAccounting : 1;
                BYTE  IncreasePolicy: 2;
                BYTE  DecreasePolicy: 2;
                BYTE  Reserved : 3;
        } Flags;
    DWORD TimeCheck;
    DWORD IncreaseTime;
    DWORD DecreaseTime;
    DWORD IncreasePercent;
    DWORD DecreasePercent;
} PROCESSOR_PERFSTATE_POLICY, *PPROCESSOR_PERFSTATE_POLICY;
typedef struct _ADMINISTRATOR_POWER_POLICY {
    DWORD                   MinVideoTimeout;
    DWORD                   MaxVideoTimeout;
    DWORD                   MinSpindownTimeout;
    DWORD                   MaxSpindownTimeout;
} ADMINISTRATOR_POWER_POLICY, *PADMINISTRATOR_POWER_POLICY;
typedef enum _HIBERFILE_BUCKET_SIZE {
    HiberFileBucket1GB = 0,
    HiberFileBucket2GB,
    HiberFileBucket4GB,
    HiberFileBucket8GB,
    HiberFileBucket16GB,
    HiberFileBucket32GB,
    HiberFileBucketUnlimited,
    HiberFileBucketMax
} HIBERFILE_BUCKET_SIZE, *PHIBERFILE_BUCKET_SIZE;
typedef struct _HIBERFILE_BUCKET {
    DWORD64 MaxPhysicalMemory;
    DWORD PhysicalMemoryPercent[0x03];
} HIBERFILE_BUCKET, *PHIBERFILE_BUCKET;
typedef struct {
    BOOLEAN             PowerButtonPresent;
    BOOLEAN             SleepButtonPresent;
    BOOLEAN             LidPresent;
    BOOLEAN             SystemS1;
    BOOLEAN             SystemS2;
    BOOLEAN             SystemS3;
    BOOLEAN             SystemS4;
    BOOLEAN             SystemS5;
    BOOLEAN             HiberFilePresent;
    BOOLEAN             FullWake;
    BOOLEAN             VideoDimPresent;
    BOOLEAN             ApmPresent;
    BOOLEAN             UpsPresent;
    BOOLEAN             ThermalControl;
    BOOLEAN             ProcessorThrottle;
    BYTE                ProcessorMinThrottle;
    BYTE                ProcessorMaxThrottle;
    BOOLEAN             FastSystemS4;
    BOOLEAN             Hiberboot;
    BOOLEAN             WakeAlarmPresent;
    BOOLEAN             AoAc;
    BOOLEAN             DiskSpinDown;
    BYTE                HiberFileType;
    BOOLEAN             AoAcConnectivitySupported;
    BYTE                spare3[6];
    BOOLEAN             SystemBatteriesPresent;
    BOOLEAN             BatteriesAreShortTerm;
    BATTERY_REPORTING_SCALE BatteryScale[3];
    SYSTEM_POWER_STATE  AcOnLineWake;
    SYSTEM_POWER_STATE  SoftLidWake;
    SYSTEM_POWER_STATE  RtcWake;
    SYSTEM_POWER_STATE  MinDeviceWakeState;
    SYSTEM_POWER_STATE  DefaultLowLatencyWake;
} SYSTEM_POWER_CAPABILITIES, *PSYSTEM_POWER_CAPABILITIES;
typedef struct {
    BOOLEAN             AcOnLine;
    BOOLEAN             BatteryPresent;
    BOOLEAN             Charging;
    BOOLEAN             Discharging;
    BOOLEAN             Spare1[3];
    BYTE                Tag;
    DWORD               MaxCapacity;
    DWORD               RemainingCapacity;
    DWORD               Rate;
    DWORD               EstimatedTime;
    DWORD               DefaultAlert1;
    DWORD               DefaultAlert2;
} SYSTEM_BATTERY_STATE, *PSYSTEM_BATTERY_STATE;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\pshpack4.h"
#pragma warning(disable:4103)
#pragma pack(push,4)
#line 16217 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\pshpack2.h"
#pragma pack(push,2)
#line 16225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16235 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_DOS_HEADER {
    WORD   e_magic;
    WORD   e_cblp;
    WORD   e_cp;
    WORD   e_crlc;
    WORD   e_cparhdr;
    WORD   e_minalloc;
    WORD   e_maxalloc;
    WORD   e_ss;
    WORD   e_sp;
    WORD   e_csum;
    WORD   e_ip;
    WORD   e_cs;
    WORD   e_lfarlc;
    WORD   e_ovno;
    WORD   e_res[4];
    WORD   e_oemid;
    WORD   e_oeminfo;
    WORD   e_res2[10];
    LONG   e_lfanew;
  } IMAGE_DOS_HEADER, *PIMAGE_DOS_HEADER;
typedef struct _IMAGE_OS2_HEADER {
    WORD   ne_magic;
    CHAR   ne_ver;
    CHAR   ne_rev;
    WORD   ne_enttab;
    WORD   ne_cbenttab;
    LONG   ne_crc;
    WORD   ne_flags;
    WORD   ne_autodata;
    WORD   ne_heap;
    WORD   ne_stack;
    LONG   ne_csip;
    LONG   ne_sssp;
    WORD   ne_cseg;
    WORD   ne_cmod;
    WORD   ne_cbnrestab;
    WORD   ne_segtab;
    WORD   ne_rsrctab;
    WORD   ne_restab;
    WORD   ne_modtab;
    WORD   ne_imptab;
    LONG   ne_nrestab;
    WORD   ne_cmovent;
    WORD   ne_align;
    WORD   ne_cres;
    BYTE   ne_exetyp;
    BYTE   ne_flagsothers;
    WORD   ne_pretthunks;
    WORD   ne_psegrefbytes;
    WORD   ne_swaparea;
    WORD   ne_expver;
  } IMAGE_OS2_HEADER, *PIMAGE_OS2_HEADER;
typedef struct _IMAGE_VXD_HEADER {
    WORD   e32_magic;
    BYTE   e32_border;
    BYTE   e32_worder;
    DWORD  e32_level;
    WORD   e32_cpu;
    WORD   e32_os;
    DWORD  e32_ver;
    DWORD  e32_mflags;
    DWORD  e32_mpages;
    DWORD  e32_startobj;
    DWORD  e32_eip;
    DWORD  e32_stackobj;
    DWORD  e32_esp;
    DWORD  e32_pagesize;
    DWORD  e32_lastpagesize;
    DWORD  e32_fixupsize;
    DWORD  e32_fixupsum;
    DWORD  e32_ldrsize;
    DWORD  e32_ldrsum;
    DWORD  e32_objtab;
    DWORD  e32_objcnt;
    DWORD  e32_objmap;
    DWORD  e32_itermap;
    DWORD  e32_rsrctab;
    DWORD  e32_rsrccnt;
    DWORD  e32_restab;
    DWORD  e32_enttab;
    DWORD  e32_dirtab;
    DWORD  e32_dircnt;
    DWORD  e32_fpagetab;
    DWORD  e32_frectab;
    DWORD  e32_impmod;
    DWORD  e32_impmodcnt;
    DWORD  e32_impproc;
    DWORD  e32_pagesum;
    DWORD  e32_datapage;
    DWORD  e32_preload;
    DWORD  e32_nrestab;
    DWORD  e32_cbnrestab;
    DWORD  e32_nressum;
    DWORD  e32_autodata;
    DWORD  e32_debuginfo;
    DWORD  e32_debuglen;
    DWORD  e32_instpreload;
    DWORD  e32_instdemand;
    DWORD  e32_heapsize;
    BYTE   e32_res3[12];
    DWORD  e32_winresoff;
    DWORD  e32_winreslen;
    WORD   e32_devid;
    WORD   e32_ddkver;
  } IMAGE_VXD_HEADER, *PIMAGE_VXD_HEADER;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\poppack.h"
#pragma pack(pop)
#line 16347 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_FILE_HEADER {
    WORD    Machine;
    WORD    NumberOfSections;
    DWORD   TimeDateStamp;
    DWORD   PointerToSymbolTable;
    DWORD   NumberOfSymbols;
    WORD    SizeOfOptionalHeader;
    WORD    Characteristics;
} IMAGE_FILE_HEADER, *PIMAGE_FILE_HEADER;
#line 16380 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16413 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_DATA_DIRECTORY {
    DWORD   VirtualAddress;
    DWORD   Size;
} IMAGE_DATA_DIRECTORY, *PIMAGE_DATA_DIRECTORY;
typedef struct _IMAGE_OPTIONAL_HEADER {
    WORD    Magic;
    BYTE    MajorLinkerVersion;
    BYTE    MinorLinkerVersion;
    DWORD   SizeOfCode;
    DWORD   SizeOfInitializedData;
    DWORD   SizeOfUninitializedData;
    DWORD   AddressOfEntryPoint;
    DWORD   BaseOfCode;
    DWORD   BaseOfData;
    DWORD   ImageBase;
    DWORD   SectionAlignment;
    DWORD   FileAlignment;
    WORD    MajorOperatingSystemVersion;
    WORD    MinorOperatingSystemVersion;
    WORD    MajorImageVersion;
    WORD    MinorImageVersion;
    WORD    MajorSubsystemVersion;
    WORD    MinorSubsystemVersion;
    DWORD   Win32VersionValue;
    DWORD   SizeOfImage;
    DWORD   SizeOfHeaders;
    DWORD   CheckSum;
    WORD    Subsystem;
    WORD    DllCharacteristics;
    DWORD   SizeOfStackReserve;
    DWORD   SizeOfStackCommit;
    DWORD   SizeOfHeapReserve;
    DWORD   SizeOfHeapCommit;
    DWORD   LoaderFlags;
    DWORD   NumberOfRvaAndSizes;
    IMAGE_DATA_DIRECTORY DataDirectory[16];
} IMAGE_OPTIONAL_HEADER32, *PIMAGE_OPTIONAL_HEADER32;
typedef struct _IMAGE_ROM_OPTIONAL_HEADER {
    WORD   Magic;
    DWORD  SizeOfCode;
    DWORD  BaseOfCode;
    DWORD  BaseOfData;
    DWORD  BaseOfBss;
    DWORD  GprMask;
    DWORD  CprMask[4];
    DWORD  GpValue;
} IMAGE_ROM_OPTIONAL_HEADER, *PIMAGE_ROM_OPTIONAL_HEADER;
typedef struct _IMAGE_OPTIONAL_HEADER64 {
    WORD        Magic;
    DWORD       SizeOfCode;
    DWORD       BaseOfCode;
    ULONGLONG   ImageBase;
    DWORD       SizeOfImage;
    DWORD       CheckSum;
    WORD        Subsystem;
    ULONGLONG   SizeOfStackReserve;
    ULONGLONG   SizeOfStackCommit;
    ULONGLONG   SizeOfHeapReserve;
    ULONGLONG   SizeOfHeapCommit;
    DWORD       LoaderFlags;
} IMAGE_OPTIONAL_HEADER64, *PIMAGE_OPTIONAL_HEADER64;
typedef IMAGE_OPTIONAL_HEADER64             IMAGE_OPTIONAL_HEADER;
typedef PIMAGE_OPTIONAL_HEADER64            PIMAGE_OPTIONAL_HEADER;
#line 16535 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_NT_HEADERS64 {
    DWORD Signature;
    IMAGE_FILE_HEADER FileHeader;
    IMAGE_OPTIONAL_HEADER64 OptionalHeader;
} IMAGE_NT_HEADERS64, *PIMAGE_NT_HEADERS64;
typedef struct _IMAGE_NT_HEADERS {
    DWORD Signature;
    IMAGE_OPTIONAL_HEADER32 OptionalHeader;
} IMAGE_NT_HEADERS32, *PIMAGE_NT_HEADERS32;
typedef struct _IMAGE_ROM_HEADERS {
    IMAGE_ROM_OPTIONAL_HEADER OptionalHeader;
} IMAGE_ROM_HEADERS, *PIMAGE_ROM_HEADERS;
typedef IMAGE_NT_HEADERS64                  IMAGE_NT_HEADERS;
typedef PIMAGE_NT_HEADERS64                 PIMAGE_NT_HEADERS;
#line 16586 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16604 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16614 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16623 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct ANON_OBJECT_HEADER {
    WORD    Sig1;
    WORD    Sig2;
    WORD    Version;
    WORD    Machine;
    CLSID   ClassID;
    DWORD   SizeOfData;
} ANON_OBJECT_HEADER;
typedef struct ANON_OBJECT_HEADER_V2 {
    WORD    Sig1;
    WORD    Sig2;
    WORD    Version;
    WORD    Machine;
    CLSID   ClassID;
    DWORD   SizeOfData;
    DWORD   Flags;
    DWORD   MetaDataSize;
    DWORD   MetaDataOffset;
} ANON_OBJECT_HEADER_V2;
typedef struct ANON_OBJECT_HEADER_BIGOBJ {
    WORD    Sig1;
    WORD    Sig2;
    WORD    Version;
    WORD    Machine;
    CLSID   ClassID;
    DWORD   SizeOfData;
    DWORD   Flags;
    DWORD   MetaDataSize;
    DWORD   NumberOfSections;
} ANON_OBJECT_HEADER_BIGOBJ;
typedef struct _IMAGE_SECTION_HEADER {
    BYTE    Name[8];
    union {
            DWORD   PhysicalAddress;
            DWORD   VirtualSize;
    } Misc;
    DWORD   SizeOfRawData;
    DWORD   PointerToRawData;
    DWORD   PointerToRelocations;
    DWORD   PointerToLinenumbers;
    WORD    NumberOfRelocations;
    WORD    NumberOfLinenumbers;
    DWORD   Characteristics;
} IMAGE_SECTION_HEADER, *PIMAGE_SECTION_HEADER;
#line 16738 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16749 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16757 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_SYMBOL {
    union {
        BYTE    ShortName[8];
        struct {
            DWORD   Short;
            DWORD   Long;
        } Name;
        DWORD   LongName[2];
    } N;
    DWORD   Value;
    SHORT   SectionNumber;
    WORD    Type;
    BYTE    StorageClass;
    BYTE    NumberOfAuxSymbols;
} IMAGE_SYMBOL;
typedef IMAGE_SYMBOL __unaligned *PIMAGE_SYMBOL;
typedef struct _IMAGE_SYMBOL_EX {
    union {
        BYTE     ShortName[8];
        struct {
            DWORD   Short;
            DWORD   Long;
        } Name;
        DWORD   LongName[2];
    } N;
    DWORD   Value;
    LONG    SectionNumber;
    WORD    Type;
    BYTE    StorageClass;
} IMAGE_SYMBOL_EX;
typedef IMAGE_SYMBOL_EX __unaligned *PIMAGE_SYMBOL_EX;
#line 16833 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16865 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16886 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16918 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 16920 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct IMAGE_AUX_SYMBOL_TOKEN_DEF {
    BYTE  bAuxType;
    BYTE  bReserved;
    DWORD SymbolTableIndex;
    BYTE  rgbReserved[12];
} IMAGE_AUX_SYMBOL_TOKEN_DEF;
typedef IMAGE_AUX_SYMBOL_TOKEN_DEF __unaligned *PIMAGE_AUX_SYMBOL_TOKEN_DEF;
#pragma pack(pop)
#line 16931 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef union _IMAGE_AUX_SYMBOL {
    struct {
        DWORD    TagIndex;
        union {
            struct {
                WORD    Linenumber;
                WORD    Size;
            } LnSz;
           DWORD    TotalSize;
        } Misc;
        union {
            struct {
                DWORD    PointerToLinenumber;
                DWORD    PointerToNextFunction;
            } Function;
            struct {
                WORD     Dimension[4];
            } Array;
        } FcnAry;
        WORD    TvIndex;
    } Sym;
    struct {
        BYTE    Name[18];
    } File;
    struct {
        DWORD   Length;
        DWORD   CheckSum;
        SHORT   Number;
        BYTE    Selection;
	BYTE    bReserved;
	SHORT   HighNumber;
    } Section;
    IMAGE_AUX_SYMBOL_TOKEN_DEF TokenDef;
    struct {
        DWORD crc;
        BYTE  rgbReserved[14];
    } CRC;
} IMAGE_AUX_SYMBOL;
typedef IMAGE_AUX_SYMBOL __unaligned *PIMAGE_AUX_SYMBOL;
typedef union _IMAGE_AUX_SYMBOL_EX {
    struct {
        DWORD   WeakDefaultSymIndex;
        DWORD   WeakSearchType;
    } Sym;
    struct {
        BYTE    Name[sizeof(IMAGE_SYMBOL_EX)];
    } File;
    struct {
        DWORD   Length;
        DWORD   CheckSum;
        SHORT   Number;
        BYTE    Selection;
        BYTE    bReserved;
        SHORT   HighNumber;
        BYTE    rgbReserved[2];
    } Section;
    struct{
    struct {
        DWORD crc;
        BYTE  rgbReserved[16];
    } CRC;
} IMAGE_AUX_SYMBOL_EX;
typedef IMAGE_AUX_SYMBOL_EX __unaligned *PIMAGE_AUX_SYMBOL_EX;
typedef enum IMAGE_AUX_SYMBOL_TYPE {
    IMAGE_AUX_SYMBOL_TYPE_TOKEN_DEF = 1,
} IMAGE_AUX_SYMBOL_TYPE;
#line 17025 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_RELOCATION {
    union {
        DWORD   RelocCount;
    WORD    Type;
} IMAGE_RELOCATION;
typedef IMAGE_RELOCATION __unaligned *PIMAGE_RELOCATION;
#line 17059 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17079 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17107 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17121 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17135 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17168 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17203 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17214 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17235 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17256 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17275 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17290 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17301 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17312 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17329 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_LINENUMBER {
    union {
    } Type;
    WORD    Linenumber;
} IMAGE_LINENUMBER;
typedef IMAGE_LINENUMBER __unaligned *PIMAGE_LINENUMBER;
#pragma pack(pop)
#line 17448 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_BASE_RELOCATION {
    DWORD   SizeOfBlock;
} IMAGE_BASE_RELOCATION;
typedef IMAGE_BASE_RELOCATION __unaligned * PIMAGE_BASE_RELOCATION;
#line 17476 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17501 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_ARCHIVE_MEMBER_HEADER {
    BYTE     Name[16];
    BYTE     Date[12];
    BYTE     UserID[6];
    BYTE     GroupID[6];
    BYTE     Mode[8];
    BYTE     Size[10];
    BYTE     EndHeader[2];
} IMAGE_ARCHIVE_MEMBER_HEADER, *PIMAGE_ARCHIVE_MEMBER_HEADER;
typedef struct _IMAGE_EXPORT_DIRECTORY {
    WORD    MajorVersion;
    WORD    MinorVersion;
    DWORD   Name;
    DWORD   Base;
    DWORD   NumberOfFunctions;
    DWORD   NumberOfNames;
    DWORD   AddressOfFunctions;
    DWORD   AddressOfNames;
    DWORD   AddressOfNameOrdinals;
} IMAGE_EXPORT_DIRECTORY, *PIMAGE_EXPORT_DIRECTORY;
typedef struct _IMAGE_IMPORT_BY_NAME {
    WORD    Hint;
    CHAR   Name[1];
} IMAGE_IMPORT_BY_NAME, *PIMAGE_IMPORT_BY_NAME;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\pshpack8.h"
#pragma pack(push,8)
#line 17547 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_THUNK_DATA64 {
    union {
        ULONGLONG ForwarderString;
        ULONGLONG Function;
        ULONGLONG Ordinal;
        ULONGLONG AddressOfData;
    } u1;
} IMAGE_THUNK_DATA64;
typedef IMAGE_THUNK_DATA64 * PIMAGE_THUNK_DATA64;
#pragma pack(pop)
#line 17559 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_THUNK_DATA32 {
    union {
        DWORD ForwarderString;
        DWORD Function;
        DWORD Ordinal;
        DWORD AddressOfData;
    } u1;
} IMAGE_THUNK_DATA32;
typedef IMAGE_THUNK_DATA32 * PIMAGE_THUNK_DATA32;
#line 17576 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef void
(__stdcall *PIMAGE_TLS_CALLBACK) (
    PVOID DllHandle,
    DWORD Reason,
    PVOID Reserved
typedef struct _IMAGE_TLS_DIRECTORY64 {
    ULONGLONG StartAddressOfRawData;
    ULONGLONG EndAddressOfRawData;
    ULONGLONG AddressOfIndex;
    ULONGLONG AddressOfCallBacks;
    DWORD SizeOfZeroFill;
    union {
        struct {
            DWORD Reserved0 : 20;
            DWORD Alignment : 4;
            DWORD Reserved1 : 8;
} IMAGE_TLS_DIRECTORY64;
typedef IMAGE_TLS_DIRECTORY64 * PIMAGE_TLS_DIRECTORY64;
typedef struct _IMAGE_TLS_DIRECTORY32 {
    DWORD   StartAddressOfRawData;
    DWORD   EndAddressOfRawData;
    DWORD   AddressOfIndex;
    DWORD   AddressOfCallBacks;
    union {
        struct {
} IMAGE_TLS_DIRECTORY32;
typedef IMAGE_TLS_DIRECTORY32 * PIMAGE_TLS_DIRECTORY32;
typedef IMAGE_THUNK_DATA64              IMAGE_THUNK_DATA;
typedef PIMAGE_THUNK_DATA64             PIMAGE_THUNK_DATA;
typedef IMAGE_TLS_DIRECTORY64           IMAGE_TLS_DIRECTORY;
typedef PIMAGE_TLS_DIRECTORY64          PIMAGE_TLS_DIRECTORY;
#line 17642 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_IMPORT_DESCRIPTOR {
    union {
        DWORD   OriginalFirstThunk;
    DWORD   ForwarderChain;
    DWORD   Name;
    DWORD   FirstThunk;
} IMAGE_IMPORT_DESCRIPTOR;
typedef IMAGE_IMPORT_DESCRIPTOR __unaligned *PIMAGE_IMPORT_DESCRIPTOR;
typedef struct _IMAGE_BOUND_IMPORT_DESCRIPTOR {
    WORD    OffsetModuleName;
    WORD    NumberOfModuleForwarderRefs;
} IMAGE_BOUND_IMPORT_DESCRIPTOR,  *PIMAGE_BOUND_IMPORT_DESCRIPTOR;
typedef struct _IMAGE_BOUND_FORWARDER_REF {
    WORD    Reserved;
} IMAGE_BOUND_FORWARDER_REF, *PIMAGE_BOUND_FORWARDER_REF;
typedef struct _IMAGE_DELAYLOAD_DESCRIPTOR {
    union {
        DWORD AllAttributes;
        struct {
            DWORD RvaBased : 1;
            DWORD ReservedAttributes : 31;
    } Attributes;
    DWORD DllNameRVA;
    DWORD ModuleHandleRVA;
    DWORD ImportAddressTableRVA;
    DWORD ImportNameTableRVA;
    DWORD BoundImportAddressTableRVA;
    DWORD UnloadInformationTableRVA;
} IMAGE_DELAYLOAD_DESCRIPTOR, *PIMAGE_DELAYLOAD_DESCRIPTOR;
typedef const IMAGE_DELAYLOAD_DESCRIPTOR *PCIMAGE_DELAYLOAD_DESCRIPTOR;
typedef struct _IMAGE_RESOURCE_DIRECTORY {
    WORD    MajorVersion;
    WORD    MinorVersion;
    WORD    NumberOfNamedEntries;
    WORD    NumberOfIdEntries;
} IMAGE_RESOURCE_DIRECTORY, *PIMAGE_RESOURCE_DIRECTORY;
typedef struct _IMAGE_RESOURCE_DIRECTORY_ENTRY {
    union {
        struct {
            DWORD NameOffset:31;
            DWORD NameIsString:1;
        DWORD   Name;
        WORD    Id;
    union {
        DWORD   OffsetToData;
        struct {
            DWORD   OffsetToDirectory:31;
            DWORD   DataIsDirectory:1;
} IMAGE_RESOURCE_DIRECTORY_ENTRY, *PIMAGE_RESOURCE_DIRECTORY_ENTRY;
typedef struct _IMAGE_RESOURCE_DIRECTORY_STRING {
    WORD    Length;
    CHAR    NameString[ 1 ];
} IMAGE_RESOURCE_DIRECTORY_STRING, *PIMAGE_RESOURCE_DIRECTORY_STRING;
typedef struct _IMAGE_RESOURCE_DIR_STRING_U {
    WORD    Length;
    WCHAR   NameString[ 1 ];
} IMAGE_RESOURCE_DIR_STRING_U, *PIMAGE_RESOURCE_DIR_STRING_U;
typedef struct _IMAGE_RESOURCE_DATA_ENTRY {
    DWORD   OffsetToData;
    DWORD   Size;
    DWORD   CodePage;
    DWORD   Reserved;
} IMAGE_RESOURCE_DATA_ENTRY, *PIMAGE_RESOURCE_DATA_ENTRY;
typedef struct _IMAGE_LOAD_CONFIG_CODE_INTEGRITY {
    WORD    Flags;
    WORD    Catalog;
    DWORD   CatalogOffset;
    DWORD   Reserved;
} IMAGE_LOAD_CONFIG_CODE_INTEGRITY, *PIMAGE_LOAD_CONFIG_CODE_INTEGRITY;
typedef struct _IMAGE_DYNAMIC_RELOCATION_TABLE {
    DWORD Version;
    DWORD Size;
} IMAGE_DYNAMIC_RELOCATION_TABLE, *PIMAGE_DYNAMIC_RELOCATION_TABLE;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\pshpack1.h"
#pragma pack(push,1)
#line 17826 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_DYNAMIC_RELOCATION32 {
    DWORD      Symbol;
    DWORD      BaseRelocSize;
} IMAGE_DYNAMIC_RELOCATION32, *PIMAGE_DYNAMIC_RELOCATION32;
typedef struct _IMAGE_DYNAMIC_RELOCATION64 {
    ULONGLONG  Symbol;
} IMAGE_DYNAMIC_RELOCATION64, *PIMAGE_DYNAMIC_RELOCATION64;
typedef struct _IMAGE_DYNAMIC_RELOCATION32_V2 {
    DWORD      HeaderSize;
    DWORD      FixupInfoSize;
    DWORD      Symbol;
    DWORD      SymbolGroup;
    DWORD      Flags;
} IMAGE_DYNAMIC_RELOCATION32_V2, *PIMAGE_DYNAMIC_RELOCATION32_V2;
typedef struct _IMAGE_DYNAMIC_RELOCATION64_V2 {
    DWORD      HeaderSize;
    ULONGLONG  Symbol;
    DWORD      SymbolGroup;
    DWORD      Flags;
} IMAGE_DYNAMIC_RELOCATION64_V2, *PIMAGE_DYNAMIC_RELOCATION64_V2;
#pragma pack(pop)
#line 17860 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef IMAGE_DYNAMIC_RELOCATION64          IMAGE_DYNAMIC_RELOCATION;
typedef PIMAGE_DYNAMIC_RELOCATION64         PIMAGE_DYNAMIC_RELOCATION;
typedef IMAGE_DYNAMIC_RELOCATION64_V2       IMAGE_DYNAMIC_RELOCATION_V2;
typedef PIMAGE_DYNAMIC_RELOCATION64_V2      PIMAGE_DYNAMIC_RELOCATION_V2;
#line 17872 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 17881 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_PROLOGUE_DYNAMIC_RELOCATION_HEADER {
    BYTE       PrologueByteCount;
} IMAGE_PROLOGUE_DYNAMIC_RELOCATION_HEADER;
typedef IMAGE_PROLOGUE_DYNAMIC_RELOCATION_HEADER __unaligned * PIMAGE_PROLOGUE_DYNAMIC_RELOCATION_HEADER;
typedef struct _IMAGE_EPILOGUE_DYNAMIC_RELOCATION_HEADER {
    DWORD      EpilogueCount;
    BYTE       EpilogueByteCount;
    BYTE       BranchDescriptorElementSize;
    WORD       BranchDescriptorCount;
} IMAGE_EPILOGUE_DYNAMIC_RELOCATION_HEADER;
typedef IMAGE_EPILOGUE_DYNAMIC_RELOCATION_HEADER __unaligned * PIMAGE_EPILOGUE_DYNAMIC_RELOCATION_HEADER;
#pragma pack(pop)
#line 17899 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_LOAD_CONFIG_DIRECTORY32 {
    DWORD   Size;
    WORD    MajorVersion;
    WORD    MinorVersion;
    DWORD   GlobalFlagsClear;
    DWORD   GlobalFlagsSet;
    DWORD   CriticalSectionDefaultTimeout;
    DWORD   DeCommitFreeBlockThreshold;
    DWORD   DeCommitTotalFreeThreshold;
    DWORD   LockPrefixTable;
    DWORD   MaximumAllocationSize;
    DWORD   VirtualMemoryThreshold;
    DWORD   ProcessHeapFlags;
    DWORD   ProcessAffinityMask;
    WORD    CSDVersion;
    WORD    DependentLoadFlags;
    DWORD   EditList;
    DWORD   SecurityCookie;
    DWORD   SEHandlerTable;
    DWORD   SEHandlerCount;
    DWORD   GuardCFCheckFunctionPointer;
    DWORD   GuardCFDispatchFunctionPointer;
    DWORD   GuardCFFunctionTable;
    DWORD   GuardCFFunctionCount;
    DWORD   GuardFlags;
    IMAGE_LOAD_CONFIG_CODE_INTEGRITY CodeIntegrity;
    DWORD   GuardAddressTakenIatEntryTable;
    DWORD   GuardAddressTakenIatEntryCount;
    DWORD   GuardLongJumpTargetTable;
    DWORD   GuardLongJumpTargetCount;
    DWORD   DynamicValueRelocTable;
    DWORD   CHPEMetadataPointer;
    DWORD   GuardRFFailureRoutine;
    DWORD   GuardRFFailureRoutineFunctionPointer;
    DWORD   DynamicValueRelocTableOffset;
    WORD    DynamicValueRelocTableSection;
    WORD    Reserved2;
    DWORD   GuardRFVerifyStackPointerFunctionPointer;
    DWORD   HotPatchTableOffset;
    DWORD   Reserved3;
    DWORD   EnclaveConfigurationPointer;
} IMAGE_LOAD_CONFIG_DIRECTORY32, *PIMAGE_LOAD_CONFIG_DIRECTORY32;
typedef struct _IMAGE_LOAD_CONFIG_DIRECTORY64 {
    DWORD      Size;
    WORD       MajorVersion;
    WORD       MinorVersion;
    ULONGLONG  DeCommitFreeBlockThreshold;
    ULONGLONG  DeCommitTotalFreeThreshold;
    ULONGLONG  LockPrefixTable;
    ULONGLONG  MaximumAllocationSize;
    ULONGLONG  VirtualMemoryThreshold;
    ULONGLONG  ProcessAffinityMask;
    WORD       CSDVersion;
    ULONGLONG  EditList;
    ULONGLONG  SecurityCookie;
    ULONGLONG  SEHandlerTable;
    ULONGLONG  SEHandlerCount;
    ULONGLONG  GuardCFCheckFunctionPointer;
    ULONGLONG  GuardCFDispatchFunctionPointer;
    ULONGLONG  GuardCFFunctionTable;
    ULONGLONG  GuardCFFunctionCount;
    DWORD      GuardFlags;
    ULONGLONG  GuardAddressTakenIatEntryTable;
    ULONGLONG  GuardAddressTakenIatEntryCount;
    ULONGLONG  GuardLongJumpTargetTable;
    ULONGLONG  GuardLongJumpTargetCount;
    ULONGLONG  DynamicValueRelocTable;
    ULONGLONG  CHPEMetadataPointer;
    ULONGLONG  GuardRFFailureRoutine;
    ULONGLONG  GuardRFFailureRoutineFunctionPointer;
    WORD       Reserved2;
    ULONGLONG  GuardRFVerifyStackPointerFunctionPointer;
    DWORD      Reserved3;
    ULONGLONG  EnclaveConfigurationPointer;
} IMAGE_LOAD_CONFIG_DIRECTORY64, *PIMAGE_LOAD_CONFIG_DIRECTORY64;
typedef IMAGE_LOAD_CONFIG_DIRECTORY64     IMAGE_LOAD_CONFIG_DIRECTORY;
typedef PIMAGE_LOAD_CONFIG_DIRECTORY64    PIMAGE_LOAD_CONFIG_DIRECTORY;
typedef struct _IMAGE_HOT_PATCH_INFO {
    DWORD Version;
    DWORD Size;
    DWORD SequenceNumber;
    DWORD BaseImageList;
    DWORD BaseImageCount;
    DWORD BufferOffset;
} IMAGE_HOT_PATCH_INFO, *PIMAGE_HOT_PATCH_INFO;
typedef struct _IMAGE_HOT_PATCH_BASE {
    DWORD Flags;
    DWORD OriginalTimeDateStamp;
    DWORD OriginalCheckSum;
    DWORD CodeIntegrityInfo;
    DWORD CodeIntegritySize;
    DWORD PatchTable;
    DWORD BufferOffset;
} IMAGE_HOT_PATCH_BASE, *PIMAGE_HOT_PATCH_BASE;
typedef struct _IMAGE_HOT_PATCH_HASHES {
    BYTE  SHA256[32];
    BYTE  SHA1[20];
} IMAGE_HOT_PATCH_HASHES, *PIMAGE_HOT_PATCH_HASHES;
#line 18039 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 18048 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 18056 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 18064 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_CE_RUNTIME_FUNCTION_ENTRY {
    DWORD FuncStart;
    DWORD PrologLen : 8;
    DWORD FuncLen : 22;
    DWORD ThirtyTwoBit : 1;
    DWORD ExceptionFlag : 1;
} IMAGE_CE_RUNTIME_FUNCTION_ENTRY, * PIMAGE_CE_RUNTIME_FUNCTION_ENTRY;
typedef struct _IMAGE_ARM_RUNTIME_FUNCTION_ENTRY {
    DWORD BeginAddress;
    union {
        DWORD UnwindData;
        struct {
            DWORD Flag : 2;
            DWORD FunctionLength : 11;
            DWORD Ret : 2;
            DWORD H : 1;
            DWORD Reg : 3;
            DWORD R : 1;
            DWORD L : 1;
            DWORD C : 1;
            DWORD StackAdjust : 10;
} IMAGE_ARM_RUNTIME_FUNCTION_ENTRY, * PIMAGE_ARM_RUNTIME_FUNCTION_ENTRY;
typedef struct _IMAGE_ARM64_RUNTIME_FUNCTION_ENTRY {
    DWORD BeginAddress;
    union {
        DWORD UnwindData;
        struct {
            DWORD Flag : 2;
            DWORD RegF : 3;
            DWORD RegI : 4;
            DWORD H : 1;
            DWORD CR : 2;
            DWORD FrameSize : 9;
} IMAGE_ARM64_RUNTIME_FUNCTION_ENTRY, * PIMAGE_ARM64_RUNTIME_FUNCTION_ENTRY;
typedef struct _IMAGE_ALPHA64_RUNTIME_FUNCTION_ENTRY {
    ULONGLONG BeginAddress;
    ULONGLONG EndAddress;
    ULONGLONG ExceptionHandler;
    ULONGLONG HandlerData;
    ULONGLONG PrologEndAddress;
} IMAGE_ALPHA64_RUNTIME_FUNCTION_ENTRY, *PIMAGE_ALPHA64_RUNTIME_FUNCTION_ENTRY;
typedef struct _IMAGE_ALPHA_RUNTIME_FUNCTION_ENTRY {
    DWORD BeginAddress;
    DWORD EndAddress;
    DWORD ExceptionHandler;
    DWORD HandlerData;
    DWORD PrologEndAddress;
} IMAGE_ALPHA_RUNTIME_FUNCTION_ENTRY, *PIMAGE_ALPHA_RUNTIME_FUNCTION_ENTRY;
typedef struct _IMAGE_RUNTIME_FUNCTION_ENTRY {
    DWORD BeginAddress;
    DWORD EndAddress;
    union {
        DWORD UnwindInfoAddress;
        DWORD UnwindData;
} _IMAGE_RUNTIME_FUNCTION_ENTRY, *_PIMAGE_RUNTIME_FUNCTION_ENTRY;
typedef  _IMAGE_RUNTIME_FUNCTION_ENTRY  IMAGE_IA64_RUNTIME_FUNCTION_ENTRY;
typedef _PIMAGE_RUNTIME_FUNCTION_ENTRY PIMAGE_IA64_RUNTIME_FUNCTION_ENTRY;
#line 18174 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef  _IMAGE_RUNTIME_FUNCTION_ENTRY  IMAGE_RUNTIME_FUNCTION_ENTRY;
typedef _PIMAGE_RUNTIME_FUNCTION_ENTRY PIMAGE_RUNTIME_FUNCTION_ENTRY;
typedef struct _IMAGE_ENCLAVE_CONFIG32 {
    DWORD Size;
    DWORD MinimumRequiredConfigSize;
    DWORD PolicyFlags;
    DWORD NumberOfImports;
    DWORD ImportList;
    DWORD ImportEntrySize;
    BYTE  FamilyID[16];
    BYTE  ImageID[16];
    DWORD ImageVersion;
    DWORD SecurityVersion;
    DWORD EnclaveSize;
    DWORD NumberOfThreads;
    DWORD EnclaveFlags;
} IMAGE_ENCLAVE_CONFIG32, *PIMAGE_ENCLAVE_CONFIG32;
typedef struct _IMAGE_ENCLAVE_CONFIG64 {
    DWORD Size;
    DWORD PolicyFlags;
    DWORD ImportList;
    BYTE  FamilyID[16];
    BYTE  ImageID[16];
    DWORD ImageVersion;
    ULONGLONG EnclaveSize;
    DWORD EnclaveFlags;
} IMAGE_ENCLAVE_CONFIG64, *PIMAGE_ENCLAVE_CONFIG64;
typedef IMAGE_ENCLAVE_CONFIG64          IMAGE_ENCLAVE_CONFIG;
typedef PIMAGE_ENCLAVE_CONFIG64         PIMAGE_ENCLAVE_CONFIG;
typedef struct _IMAGE_ENCLAVE_IMPORT {
    DWORD MatchType;
    DWORD MinimumSecurityVersion;
    BYTE  UniqueOrAuthorID[32];
    BYTE  FamilyID[16];
    BYTE  ImageID[16];
    DWORD ImportName;
    DWORD Reserved;
} IMAGE_ENCLAVE_IMPORT, *PIMAGE_ENCLAVE_IMPORT;
typedef struct _IMAGE_DEBUG_DIRECTORY {
    WORD    MajorVersion;
    WORD    MinorVersion;
    DWORD   Type;
    DWORD   SizeOfData;
    DWORD   AddressOfRawData;
} IMAGE_DEBUG_DIRECTORY, *PIMAGE_DEBUG_DIRECTORY;
#line 18281 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _IMAGE_COFF_SYMBOLS_HEADER {
    DWORD   LvaToFirstSymbol;
    DWORD   NumberOfLinenumbers;
    DWORD   LvaToFirstLinenumber;
    DWORD   RvaToFirstByteOfCode;
    DWORD   RvaToLastByteOfCode;
    DWORD   RvaToFirstByteOfData;
    DWORD   RvaToLastByteOfData;
} IMAGE_COFF_SYMBOLS_HEADER, *PIMAGE_COFF_SYMBOLS_HEADER;
typedef struct _FPO_DATA {
    DWORD       ulOffStart;
    DWORD       cbProcSize;
    DWORD       cdwLocals;
    WORD        cdwParams;
    WORD        cbProlog : 8;
    WORD        cbRegs   : 3;
    WORD        fHasSEH  : 1;
    WORD        fUseBP   : 1;
    WORD        reserved : 1;
    WORD        cbFrame  : 2;
} FPO_DATA, *PFPO_DATA;
typedef struct _IMAGE_DEBUG_MISC {
    DWORD       DataType;
    DWORD       Length;
    BOOLEAN     Unicode;
    BYTE        Reserved[ 3 ];
    BYTE        Data[ 1 ];
} IMAGE_DEBUG_MISC, *PIMAGE_DEBUG_MISC;
typedef struct _IMAGE_FUNCTION_ENTRY {
    DWORD   StartingAddress;
    DWORD   EndingAddress;
    DWORD   EndOfPrologue;
} IMAGE_FUNCTION_ENTRY, *PIMAGE_FUNCTION_ENTRY;
typedef struct _IMAGE_FUNCTION_ENTRY64 {
    ULONGLONG   StartingAddress;
    ULONGLONG   EndingAddress;
    union {
        ULONGLONG   EndOfPrologue;
        ULONGLONG   UnwindInfoAddress;
} IMAGE_FUNCTION_ENTRY64, *PIMAGE_FUNCTION_ENTRY64;
typedef struct _IMAGE_SEPARATE_DEBUG_HEADER {
    WORD        Signature;
    WORD        Flags;
    WORD        Machine;
    DWORD       CheckSum;
    DWORD       ImageBase;
    DWORD       SizeOfImage;
    DWORD       ExportedNamesSize;
    DWORD       DebugDirectorySize;
    DWORD       Reserved[2];
} IMAGE_SEPARATE_DEBUG_HEADER, *PIMAGE_SEPARATE_DEBUG_HEADER;
typedef struct _NON_PAGED_DEBUG_INFO {
    WORD        Signature;
    WORD        Flags;
    DWORD       Size;
    WORD        Machine;
    DWORD       CheckSum;
    DWORD       SizeOfImage;
} NON_PAGED_DEBUG_INFO, *PNON_PAGED_DEBUG_INFO;
#line 18408 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _ImageArchitectureHeader {
    unsigned int AmaskValue: 1;
    int :7;
    unsigned int AmaskShift: 8;
    int :16;
    DWORD FirstEntryRVA;
} IMAGE_ARCHITECTURE_HEADER, *PIMAGE_ARCHITECTURE_HEADER;
typedef struct _ImageArchitectureEntry {
    DWORD FixupInstRVA;
    DWORD NewInst;
} IMAGE_ARCHITECTURE_ENTRY, *PIMAGE_ARCHITECTURE_ENTRY;
#pragma pack(pop)
#line 18436 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct IMPORT_OBJECT_HEADER {
    WORD    Sig1;
    WORD    Sig2;
    WORD    Version;
    WORD    Machine;
    DWORD   SizeOfData;
    union {
        WORD    Ordinal;
        WORD    Hint;
    WORD    Type : 2;
    WORD    NameType : 3;
    WORD    Reserved : 11;
} IMPORT_OBJECT_HEADER;
typedef enum IMPORT_OBJECT_TYPE
    IMPORT_OBJECT_CODE = 0,
    IMPORT_OBJECT_DATA = 1,
    IMPORT_OBJECT_CONST = 2,
} IMPORT_OBJECT_TYPE;
typedef enum IMPORT_OBJECT_NAME_TYPE
    IMPORT_OBJECT_ORDINAL = 0,
    IMPORT_OBJECT_NAME = 1,
    IMPORT_OBJECT_NAME_NO_PREFIX = 2,
    IMPORT_OBJECT_NAME_UNDECORATE = 3,
    IMPORT_OBJECT_NAME_EXPORTAS = 4,
} IMPORT_OBJECT_NAME_TYPE;
typedef enum ReplacesCorHdrNumericDefines
    COMIMAGE_FLAGS_ILONLY               =0x00000001,
    COMIMAGE_FLAGS_32BITREQUIRED        =0x00000002,
    COMIMAGE_FLAGS_IL_LIBRARY           =0x00000004,
    COMIMAGE_FLAGS_STRONGNAMESIGNED     =0x00000008,
    COMIMAGE_FLAGS_NATIVE_ENTRYPOINT    =0x00000010,
    COMIMAGE_FLAGS_TRACKDEBUGDATA       =0x00010000,
    COMIMAGE_FLAGS_32BITPREFERRED       =0x00020000,
    COR_VERSION_MAJOR_V2                =2,
    COR_VERSION_MAJOR                   =COR_VERSION_MAJOR_V2,
    COR_VERSION_MINOR                   =5,
    COR_DELETED_NAME_LENGTH             =8,
    COR_VTABLEGAP_NAME_LENGTH           =8,
    NATIVE_TYPE_MAX_CB                  =1,
    COR_ILMETHOD_SECT_SMALL_MAX_DATASIZE=0xFF,
    IMAGE_COR_MIH_METHODRVA             =0x01,
    IMAGE_COR_MIH_EHRVA                 =0x02,
    IMAGE_COR_MIH_BASICBLOCK            =0x08,
    COR_VTABLE_32BIT                    =0x01,
    COR_VTABLE_64BIT                    =0x02,
    COR_VTABLE_FROM_UNMANAGED           =0x04,
    COR_VTABLE_FROM_UNMANAGED_RETAIN_APPDOMAIN  =0x08,
    COR_VTABLE_CALL_MOST_DERIVED        =0x10,
    IMAGE_COR_EATJ_THUNK_SIZE           =32,
    MAX_CLASS_NAME                      =1024,
    MAX_PACKAGE_NAME                    =1024,
} ReplacesCorHdrNumericDefines;
typedef struct IMAGE_COR20_HEADER
    DWORD                   cb;
    WORD                    MajorRuntimeVersion;
    WORD                    MinorRuntimeVersion;
    IMAGE_DATA_DIRECTORY    MetaData;
    DWORD                   Flags;
    union {
        DWORD               EntryPointToken;
        DWORD               EntryPointRVA;
    IMAGE_DATA_DIRECTORY    Resources;
    IMAGE_DATA_DIRECTORY    StrongNameSignature;
    IMAGE_DATA_DIRECTORY    CodeManagerTable;
    IMAGE_DATA_DIRECTORY    VTableFixups;
    IMAGE_DATA_DIRECTORY    ExportAddressTableJumps;
    IMAGE_DATA_DIRECTORY    ManagedNativeHeader;
} IMAGE_COR20_HEADER, *PIMAGE_COR20_HEADER;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apiset.h"
#line 83 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apiset.h"
#line 94 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apiset.h"
#line 103 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apiset.h"
#line 125 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apiset.h"
#line 18566 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#pragma region Application or OneCore Family
__declspec(dllimport)
WORD
__stdcall
RtlCaptureStackBackTrace(
     DWORD FramesToSkip,
     DWORD FramesToCapture,
     PVOID* BackTrace,
     PDWORD BackTraceHash
#pragma endregion
#pragma region Desktop Family or OneCore Family
void
__stdcall
RtlCaptureContext(
     PCONTEXT ContextRecord
#pragma endregion
void
__stdcall
RtlUnwind(
     PVOID TargetFrame,
     PVOID TargetIp,
     PEXCEPTION_RECORD ExceptionRecord,
     PVOID ReturnValue
#pragma endregion
BOOLEAN
__cdecl
RtlAddFunctionTable(
     PRUNTIME_FUNCTION FunctionTable,
     DWORD EntryCount,
     DWORD64 BaseAddress
BOOLEAN
__cdecl
RtlDeleteFunctionTable(
BOOLEAN
__cdecl
RtlInstallFunctionTableCallback(
     DWORD64 TableIdentifier,
     DWORD64 BaseAddress,
     DWORD Length,
     PGET_RUNTIME_FUNCTION_CALLBACK Callback,
     PVOID Context,
     PCWSTR OutOfProcessCallbackDll
DWORD
__stdcall
RtlAddGrowableFunctionTable(
     PVOID* DynamicTable,
     DWORD EntryCount,
     DWORD MaximumEntryCount,
     ULONG_PTR RangeBase,
     ULONG_PTR RangeEnd
void
__stdcall
RtlGrowFunctionTable(
     PVOID DynamicTable,
     DWORD NewEntryCount
void
__stdcall
RtlDeleteGrowableFunctionTable(
     PVOID DynamicTable
#pragma endregion
PRUNTIME_FUNCTION
__stdcall
RtlLookupFunctionEntry(
     DWORD64 ControlPc,
     PDWORD64 ImageBase,
     PUNWIND_HISTORY_TABLE HistoryTable
#pragma endregion
void
__cdecl
RtlRestoreContext(
     PCONTEXT ContextRecord,
     struct _EXCEPTION_RECORD* ExceptionRecord
#pragma endregion
void
__stdcall
RtlUnwindEx(
     PVOID TargetFrame,
     PVOID TargetIp,
     PVOID ReturnValue,
#pragma endregion
PEXCEPTION_ROUTINE
__stdcall
RtlVirtualUnwind(
     DWORD HandlerType,
     DWORD64 ImageBase,
     DWORD64 ControlPc,
     PRUNTIME_FUNCTION FunctionEntry,
     PVOID* HandlerData,
     PDWORD64 EstablisherFrame,
     PKNONVOLATILE_CONTEXT_POINTERS ContextPointers
#pragma endregion
#line 18922 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 19068 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 19107 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
PVOID
__stdcall
RtlPcToFileHeader(
     PVOID PcValue,
     PVOID* BaseOfImage
#pragma endregion
SIZE_T
__stdcall
RtlCompareMemory(
     const void* Source1,
     const void* Source2,
     SIZE_T Length
#pragma endregion
#line 19156 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#pragma warning(disable:4324)
typedef struct __declspec(align(16)) _SLIST_ENTRY {
    struct _SLIST_ENTRY *Next;
} SLIST_ENTRY, *PSLIST_ENTRY;
typedef union __declspec(align(16)) _SLIST_HEADER {
    struct {
        ULONGLONG Alignment;
        ULONGLONG Region;
    struct {
        ULONGLONG Depth:16;
        ULONGLONG Sequence:48;
        ULONGLONG Reserved:4;
        ULONGLONG NextEntry:60;
    } HeaderX64;
} SLIST_HEADER, *PSLIST_HEADER;
#line 19241 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
void
__stdcall
RtlInitializeSListHead (
     PSLIST_HEADER ListHead
PSLIST_ENTRY
__stdcall
RtlFirstEntrySList (
     const SLIST_HEADER *ListHead
PSLIST_ENTRY
__stdcall
RtlInterlockedPopEntrySList (
PSLIST_ENTRY
__stdcall
RtlInterlockedPushEntrySList (
     PSLIST_HEADER ListHead,
      PSLIST_ENTRY ListEntry
PSLIST_ENTRY
__stdcall
RtlInterlockedPushListSListEx (
      PSLIST_ENTRY List,
     PSLIST_ENTRY ListEnd,
     DWORD Count
PSLIST_ENTRY
__stdcall
RtlInterlockedFlushSList (
WORD
__stdcall
RtlQueryDepthSList (
#pragma endregion
typedef union _RTL_RUN_ONCE {
    PVOID Ptr;
} RTL_RUN_ONCE, *PRTL_RUN_ONCE;
typedef struct _RTL_BARRIER {
            DWORD Reserved1;
            DWORD Reserved2;
            ULONG_PTR Reserved3[2];
            DWORD Reserved4;
            DWORD Reserved5;
} RTL_BARRIER, *PRTL_BARRIER;
#line 19414 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
__declspec(noreturn)
void
__fastfail(
     unsigned int Code
#pragma intrinsic(__fastfail)
#line 19443 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
__forceinline
DWORD
HEAP_MAKE_TAG_FLAGS (
     DWORD TagBase,
     DWORD Tag
    return ((DWORD)((TagBase) + ((Tag) << 18)));
#pragma endregion
#line 19490 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 19514 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
__forceinline
PVOID
RtlSecureZeroMemory(
     PVOID ptr,
     SIZE_T cnt
    volatile char *vptr = (volatile char *)ptr;
    __stosb((PBYTE )((DWORD64)vptr), 0, cnt);
#line 19557 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
    return ptr;
#line 19578 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _MESSAGE_RESOURCE_ENTRY {
    WORD   Length;
    WORD   Flags;
    BYTE  Text[ 1 ];
} MESSAGE_RESOURCE_ENTRY, *PMESSAGE_RESOURCE_ENTRY;
typedef struct _MESSAGE_RESOURCE_BLOCK {
    DWORD LowId;
    DWORD HighId;
    DWORD OffsetToEntries;
} MESSAGE_RESOURCE_BLOCK, *PMESSAGE_RESOURCE_BLOCK;
typedef struct _MESSAGE_RESOURCE_DATA {
    DWORD NumberOfBlocks;
    MESSAGE_RESOURCE_BLOCK Blocks[ 1 ];
} MESSAGE_RESOURCE_DATA, *PMESSAGE_RESOURCE_DATA;
typedef struct _OSVERSIONINFOA {
    DWORD dwOSVersionInfoSize;
    DWORD dwMajorVersion;
    DWORD dwMinorVersion;
    DWORD dwBuildNumber;
    DWORD dwPlatformId;
    CHAR   szCSDVersion[ 128 ];
} OSVERSIONINFOA, *POSVERSIONINFOA, *LPOSVERSIONINFOA;
typedef struct _OSVERSIONINFOW {
    DWORD dwPlatformId;
    WCHAR  szCSDVersion[ 128 ];
} OSVERSIONINFOW, *POSVERSIONINFOW, *LPOSVERSIONINFOW, RTL_OSVERSIONINFOW, *PRTL_OSVERSIONINFOW;
typedef OSVERSIONINFOA OSVERSIONINFO;
typedef POSVERSIONINFOA POSVERSIONINFO;
typedef LPOSVERSIONINFOA LPOSVERSIONINFO;
typedef struct _OSVERSIONINFOEXA {
    DWORD dwPlatformId;
    WORD   wServicePackMajor;
    WORD   wServicePackMinor;
    WORD   wSuiteMask;
    BYTE  wProductType;
    BYTE  wReserved;
} OSVERSIONINFOEXA, *POSVERSIONINFOEXA, *LPOSVERSIONINFOEXA;
typedef struct _OSVERSIONINFOEXW {
    DWORD dwPlatformId;
    WORD   wSuiteMask;
    BYTE  wProductType;
    BYTE  wReserved;
} OSVERSIONINFOEXW, *POSVERSIONINFOEXW, *LPOSVERSIONINFOEXW, RTL_OSVERSIONINFOEXW, *PRTL_OSVERSIONINFOEXW;
typedef OSVERSIONINFOEXA OSVERSIONINFOEX;
typedef POSVERSIONINFOEXA POSVERSIONINFOEX;
typedef LPOSVERSIONINFOEXA LPOSVERSIONINFOEX;
#line 19680 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 19696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
ULONGLONG
__stdcall
VerSetConditionMask(
     ULONGLONG ConditionMask,
     DWORD TypeMask,
     BYTE  Condition
#pragma endregion
BOOLEAN
__stdcall
RtlGetProductInfo(
      DWORD  OSMajorVersion,
      DWORD  OSMinorVersion,
      DWORD  SpMajorVersion,
      DWORD  SpMinorVersion,
     PDWORD ReturnedProductType
#pragma endregion
typedef enum _RTL_UMS_THREAD_INFO_CLASS {
    UmsThreadInvalidInfoClass = 0,
    UmsThreadUserContext,
    UmsThreadPriority,
    UmsThreadAffinity,
    UmsThreadTeb,
    UmsThreadIsSuspended,
    UmsThreadIsTerminated,
    UmsThreadMaxInfoClass
} RTL_UMS_THREAD_INFO_CLASS, *PRTL_UMS_THREAD_INFO_CLASS;
typedef enum _RTL_UMS_SCHEDULER_REASON {
    UmsSchedulerStartup = 0,
    UmsSchedulerThreadBlocked,
    UmsSchedulerThreadYield,
} RTL_UMS_SCHEDULER_REASON, *PRTL_UMS_SCHEDULER_REASON;
typedef
void
__stdcall
RTL_UMS_SCHEDULER_ENTRY_POINT(
     RTL_UMS_SCHEDULER_REASON Reason,
     ULONG_PTR ActivationPayload,
     PVOID SchedulerParam
typedef RTL_UMS_SCHEDULER_ENTRY_POINT *PRTL_UMS_SCHEDULER_ENTRY_POINT;
DWORD
__stdcall
RtlCrc32(
     const void *Buffer,
     size_t Size,
     DWORD InitialCrc
ULONGLONG
__stdcall
RtlCrc64(
     const void *Buffer,
     size_t Size,
     ULONGLONG InitialCrc
#pragma endregion
typedef enum _OS_DEPLOYEMENT_STATE_VALUES {
    OS_DEPLOYMENT_STANDARD = 1,
    OS_DEPLOYMENT_COMPACT
} OS_DEPLOYEMENT_STATE_VALUES;
__stdcall
RtlOsDeploymentState(
     DWORD Flags
typedef struct _NV_MEMORY_RANGE {
    void *BaseAddress;
    SIZE_T Length;
} NV_MEMORY_RANGE, *PNV_MEMORY_RANGE;
DWORD
__stdcall
RtlGetNonVolatileToken (
     PVOID NvBuffer,
     SIZE_T Size,
     PVOID *NvToken
DWORD
__stdcall
RtlFreeNonVolatileToken (
     PVOID NvToken
DWORD
__stdcall
RtlFlushNonVolatileMemory (
     PVOID NvToken,
     PVOID NvBuffer,
     SIZE_T Size,
     DWORD Flags
DWORD
__stdcall
RtlDrainNonVolatileFlush (
     PVOID NvToken
DWORD
__stdcall
RtlWriteNonVolatileMemory (
     PVOID NvToken,
     void __unaligned *NvDestination,
     void __unaligned *Source,
     SIZE_T Size,
     DWORD Flags
DWORD
__stdcall
RtlFlushNonVolatileMemoryRanges (
     PVOID NvToken,
     PNV_MEMORY_RANGE NvRanges,
     SIZE_T NumRanges,
     DWORD Flags
typedef struct CORRELATION_VECTOR {
    CHAR Version;
    CHAR Vector[129];
} CORRELATION_VECTOR;
typedef CORRELATION_VECTOR *PCORRELATION_VECTOR;
DWORD
__stdcall
RtlInitializeCorrelationVector(
     PCORRELATION_VECTOR CorrelationVector,
      int Version,
      const GUID * Guid
DWORD
__stdcall
RtlIncrementCorrelationVector(
DWORD
__stdcall
RtlExtendCorrelationVector(
DWORD
__stdcall
RtlValidateCorrelationVector(
     PCORRELATION_VECTOR Vector
typedef struct _CUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG {
    DWORD Size;
    PCWSTR TriggerId;
} CUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG, *PCUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG;
__forceinline
void
CUSTOM_SYSTEM_EVENT_TRIGGER_INIT(
        PCUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG Config,
     PCWSTR TriggerId
    memset((Config),0,(sizeof(CUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG)));
    Config->Size = sizeof(CUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG);
    Config->TriggerId = TriggerId;
DWORD
__stdcall
RtlRaiseCustomSystemEventTrigger(
     PCUSTOM_SYSTEM_EVENT_TRIGGER_CONFIG TriggerConfig
typedef enum _IMAGE_POLICY_ENTRY_TYPE {
    ImagePolicyEntryTypeNone = 0,
    ImagePolicyEntryTypeBool,
    ImagePolicyEntryTypeInt8,
    ImagePolicyEntryTypeUInt8,
    ImagePolicyEntryTypeInt16,
    ImagePolicyEntryTypeUInt16,
    ImagePolicyEntryTypeInt32,
    ImagePolicyEntryTypeUInt32,
    ImagePolicyEntryTypeInt64,
    ImagePolicyEntryTypeUInt64,
    ImagePolicyEntryTypeAnsiString,
    ImagePolicyEntryTypeUnicodeString,
    ImagePolicyEntryTypeOverride,
    ImagePolicyEntryTypeMaximum
} IMAGE_POLICY_ENTRY_TYPE;
typedef enum _IMAGE_POLICY_ID {
    ImagePolicyIdNone = 0,
    ImagePolicyIdEtw,
    ImagePolicyIdDebug,
    ImagePolicyIdCrashDump,
    ImagePolicyIdCrashDumpKey,
    ImagePolicyIdCrashDumpKeyGuid,
    ImagePolicyIdParentSd,
    ImagePolicyIdParentSdRev,
    ImagePolicyIdSvn,
    ImagePolicyIdDeviceId,
    ImagePolicyIdCapability,
    ImagePolicyIdScenarioId,
    ImagePolicyIdMaximum
} IMAGE_POLICY_ID;
typedef struct _IMAGE_POLICY_ENTRY {
    IMAGE_POLICY_ENTRY_TYPE Type;
    IMAGE_POLICY_ID PolicyId;
    union {
        const void* None;
        BOOLEAN BoolValue;
        INT8 Int8Value;
        UINT8 UInt8Value;
        INT16 Int16Value;
        UINT16 UInt16Value;
        INT32 Int32Value;
        UINT32 UInt32Value;
        INT64 Int64Value;
        UINT64 UInt64Value;
        PCSTR AnsiStringValue;
        PCWSTR UnicodeStringValue;
    } u;
} IMAGE_POLICY_ENTRY;
typedef const IMAGE_POLICY_ENTRY* PCIMAGE_POLICY_ENTRY;
#pragma warning(disable:4200)
typedef struct _IMAGE_POLICY_METADATA {
    BYTE  Version;
    BYTE  Reserved0[7];
    ULONGLONG ApplicationId;
    IMAGE_POLICY_ENTRY Policies[];
} IMAGE_POLICY_METADATA;
typedef const IMAGE_POLICY_METADATA* PCIMAGE_POLICY_METADATA;
#line 20189 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _RTL_CRITICAL_SECTION_DEBUG {
    WORD   Type;
    WORD   CreatorBackTraceIndex;
    struct _RTL_CRITICAL_SECTION *CriticalSection;
    LIST_ENTRY ProcessLocksList;
    DWORD EntryCount;
    DWORD ContentionCount;
    DWORD Flags;
    WORD   CreatorBackTraceIndexHigh;
    WORD   SpareWORD  ;
} RTL_CRITICAL_SECTION_DEBUG, *PRTL_CRITICAL_SECTION_DEBUG, RTL_RESOURCE_DEBUG, *PRTL_RESOURCE_DEBUG;
#line 20255 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#pragma pack(push, 8)
typedef struct _RTL_CRITICAL_SECTION {
    PRTL_CRITICAL_SECTION_DEBUG DebugInfo;
    LONG LockCount;
    LONG RecursionCount;
    HANDLE OwningThread;
    HANDLE LockSemaphore;
    ULONG_PTR SpinCount;
} RTL_CRITICAL_SECTION, *PRTL_CRITICAL_SECTION;
#pragma pack(pop)
typedef struct _RTL_SRWLOCK {
        PVOID Ptr;
} RTL_SRWLOCK, *PRTL_SRWLOCK;
typedef struct _RTL_CONDITION_VARIABLE {
        PVOID Ptr;
} RTL_CONDITION_VARIABLE, *PRTL_CONDITION_VARIABLE;
typedef
void
(__stdcall *PAPCFUNC)(
     ULONG_PTR Parameter
typedef LONG (__stdcall *PVECTORED_EXCEPTION_HANDLER)(
    struct _EXCEPTION_POINTERS *ExceptionInfo
typedef enum _HEAP_INFORMATION_CLASS {
    HeapCompatibilityInformation = 0,
    HeapEnableTerminationOnCorruption = 1
    HeapOptimizeResources = 3
} HEAP_INFORMATION_CLASS;
typedef struct _HEAP_OPTIMIZE_RESOURCES_INFORMATION {
    DWORD Version;
    DWORD Flags;
} HEAP_OPTIMIZE_RESOURCES_INFORMATION, *PHEAP_OPTIMIZE_RESOURCES_INFORMATION;
#line 20339 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef void (__stdcall * WAITORTIMERCALLBACKFUNC) (PVOID, BOOLEAN );
typedef void (__stdcall * WORKERCALLBACKFUNC) (PVOID );
typedef void (__stdcall * APC_CALLBACK_FUNCTION) (DWORD   , PVOID, PVOID);
typedef WAITORTIMERCALLBACKFUNC WAITORTIMERCALLBACK;
typedef
void
(__stdcall *PFLS_CALLBACK_FUNCTION) (
     PVOID lpFlsData
typedef
BOOLEAN
(__stdcall *PSECURE_MEMORY_CACHE_CALLBACK) (
     PVOID Addr,
     SIZE_T Range
typedef enum _ACTIVATION_CONTEXT_INFO_CLASS {
    ActivationContextBasicInformation                       = 1,
    ActivationContextDetailedInformation                    = 2,
    AssemblyDetailedInformationInActivationContext          = 3,
    FileInformationInAssemblyOfAssemblyInActivationContext  = 4,
    RunlevelInformationInActivationContext                  = 5,
    CompatibilityInformationInActivationContext             = 6,
    ActivationContextManifestResourceName                   = 7,
    MaxActivationContextInfoClass,
    AssemblyDetailedInformationInActivationContxt           = 3,
    FileInformationInAssemblyOfAssemblyInActivationContxt   = 4
} ACTIVATION_CONTEXT_INFO_CLASS;
typedef struct _ACTIVATION_CONTEXT_QUERY_INDEX {
    DWORD ulAssemblyIndex;
    DWORD ulFileIndexInAssembly;
} ACTIVATION_CONTEXT_QUERY_INDEX, * PACTIVATION_CONTEXT_QUERY_INDEX;
typedef const struct _ACTIVATION_CONTEXT_QUERY_INDEX * PCACTIVATION_CONTEXT_QUERY_INDEX;
typedef struct _ASSEMBLY_FILE_DETAILED_INFORMATION {
    DWORD ulFlags;
    DWORD ulFilenameLength;
    DWORD ulPathLength;
    PCWSTR lpFileName;
    PCWSTR lpFilePath;
} ASSEMBLY_FILE_DETAILED_INFORMATION, *PASSEMBLY_FILE_DETAILED_INFORMATION;
typedef const ASSEMBLY_FILE_DETAILED_INFORMATION *PCASSEMBLY_FILE_DETAILED_INFORMATION;
typedef struct _ACTIVATION_CONTEXT_ASSEMBLY_DETAILED_INFORMATION {
    DWORD ulFlags;
    DWORD ulEncodedAssemblyIdentityLength;
    DWORD ulManifestPathType;
    DWORD ulManifestPathLength;
    LARGE_INTEGER liManifestLastWriteTime;
    DWORD ulPolicyPathType;
    DWORD ulPolicyPathLength;
    LARGE_INTEGER liPolicyLastWriteTime;
    DWORD ulMetadataSatelliteRosterIndex;
    DWORD ulManifestVersionMajor;
    DWORD ulManifestVersionMinor;
    DWORD ulPolicyVersionMajor;
    DWORD ulPolicyVersionMinor;
    DWORD ulAssemblyDirectoryNameLength;
    PCWSTR lpAssemblyEncodedAssemblyIdentity;
    PCWSTR lpAssemblyManifestPath;
    PCWSTR lpAssemblyPolicyPath;
    PCWSTR lpAssemblyDirectoryName;
    DWORD  ulFileCount;
} ACTIVATION_CONTEXT_ASSEMBLY_DETAILED_INFORMATION, * PACTIVATION_CONTEXT_ASSEMBLY_DETAILED_INFORMATION;
typedef const struct _ACTIVATION_CONTEXT_ASSEMBLY_DETAILED_INFORMATION * PCACTIVATION_CONTEXT_ASSEMBLY_DETAILED_INFORMATION ;
typedef enum
    ACTCTX_RUN_LEVEL_UNSPECIFIED = 0,
    ACTCTX_RUN_LEVEL_AS_INVOKER,
    ACTCTX_RUN_LEVEL_HIGHEST_AVAILABLE,
    ACTCTX_RUN_LEVEL_REQUIRE_ADMIN,
    ACTCTX_RUN_LEVEL_NUMBERS
} ACTCTX_REQUESTED_RUN_LEVEL;
typedef struct _ACTIVATION_CONTEXT_RUN_LEVEL_INFORMATION {
    DWORD ulFlags;
    ACTCTX_REQUESTED_RUN_LEVEL  RunLevel;
    DWORD UiAccess;
} ACTIVATION_CONTEXT_RUN_LEVEL_INFORMATION, * PACTIVATION_CONTEXT_RUN_LEVEL_INFORMATION;
typedef const struct _ACTIVATION_CONTEXT_RUN_LEVEL_INFORMATION * PCACTIVATION_CONTEXT_RUN_LEVEL_INFORMATION ;
typedef enum
    ACTCTX_COMPATIBILITY_ELEMENT_TYPE_UNKNOWN = 0,
    ACTCTX_COMPATIBILITY_ELEMENT_TYPE_OS,
    ACTCTX_COMPATIBILITY_ELEMENT_TYPE_MITIGATION
} ACTCTX_COMPATIBILITY_ELEMENT_TYPE;
typedef struct _COMPATIBILITY_CONTEXT_ELEMENT {
    GUID Id;
    ACTCTX_COMPATIBILITY_ELEMENT_TYPE Type;
} COMPATIBILITY_CONTEXT_ELEMENT, *PCOMPATIBILITY_CONTEXT_ELEMENT;
typedef const struct _COMPATIBILITY_CONTEXT_ELEMENT *PCCOMPATIBILITY_CONTEXT_ELEMENT;
typedef struct _ACTIVATION_CONTEXT_COMPATIBILITY_INFORMATION {
    DWORD ElementCount;
    COMPATIBILITY_CONTEXT_ELEMENT Elements[];
} ACTIVATION_CONTEXT_COMPATIBILITY_INFORMATION, * PACTIVATION_CONTEXT_COMPATIBILITY_INFORMATION;
typedef const struct _ACTIVATION_CONTEXT_COMPATIBILITY_INFORMATION * PCACTIVATION_CONTEXT_COMPATIBILITY_INFORMATION;
typedef struct _SUPPORTED_OS_INFO {
    WORD   MajorVersion;
    WORD   MinorVersion;
} SUPPORTED_OS_INFO, *PSUPPORTED_OS_INFO;
typedef struct _ACTIVATION_CONTEXT_DETAILED_INFORMATION {
    DWORD dwFlags;
    DWORD ulFormatVersion;
    DWORD ulAssemblyCount;
    DWORD ulRootManifestPathType;
    DWORD ulRootManifestPathChars;
    DWORD ulRootConfigurationPathType;
    DWORD ulRootConfigurationPathChars;
    DWORD ulAppDirPathType;
    DWORD ulAppDirPathChars;
    PCWSTR lpRootManifestPath;
    PCWSTR lpRootConfigurationPath;
    PCWSTR lpAppDirPath;
} ACTIVATION_CONTEXT_DETAILED_INFORMATION, *PACTIVATION_CONTEXT_DETAILED_INFORMATION;
typedef const struct _ACTIVATION_CONTEXT_DETAILED_INFORMATION *PCACTIVATION_CONTEXT_DETAILED_INFORMATION;
typedef struct _HARDWARE_COUNTER_DATA {
    HARDWARE_COUNTER_TYPE Type;
    DWORD Reserved;
    DWORD64 Value;
} HARDWARE_COUNTER_DATA, *PHARDWARE_COUNTER_DATA;
typedef struct _PERFORMANCE_DATA {
    WORD   Size;
    BYTE  Version;
    BYTE  HwCountersCount;
    DWORD ContextSwitchCount;
    DWORD64 WaitReasonBitMap;
    DWORD64 CycleTime;
    DWORD RetryCount;
    DWORD Reserved;
    HARDWARE_COUNTER_DATA HwCounters[16];
} PERFORMANCE_DATA, *PPERFORMANCE_DATA;
#line 20565 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20602 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
void
__stdcall
RtlGetDeviceFamilyInfoEnum(
     ULONGLONG *pullUAPInfo,
     DWORD *pulDeviceFamily,
     DWORD *pulDeviceForm
DWORD
__stdcall
RtlConvertDeviceFamilyInfoToString(
     PDWORD pulDeviceFamilyBufferSize,
     PDWORD pulDeviceFormBufferSize,
     PWSTR DeviceFamily,
     PWSTR DeviceForm
DWORD
__stdcall
RtlSwitchedVVI(
     PRTL_OSVERSIONINFOEXW VersionInfo,
     DWORD TypeMask,
#pragma endregion
#line 20659 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _EVENTLOGRECORD {
    DWORD  Length;
    DWORD  Reserved;
    DWORD  RecordNumber;
    DWORD  TimeGenerated;
    DWORD  TimeWritten;
    DWORD  EventID;
    WORD   EventType;
    WORD   NumStrings;
    WORD   EventCategory;
    WORD   ReservedFlags;
    DWORD  ClosingRecordNumber;
    DWORD  StringOffset;
    DWORD  UserSidLength;
    DWORD  UserSidOffset;
    DWORD  DataLength;
    DWORD  DataOffset;
} EVENTLOGRECORD, *PEVENTLOGRECORD;
#pragma warning(disable : 4200)
struct _EVENTSFORLOGFILE;
typedef struct _EVENTSFORLOGFILE EVENTSFORLOGFILE, *PEVENTSFORLOGFILE;
struct _PACKEDEVENTINFO;
typedef struct _PACKEDEVENTINFO PACKEDEVENTINFO, *PPACKEDEVENTINFO;
    DWORD           ulSize;
    WCHAR           szLogicalLogFile[256];
    DWORD           ulNumRecords;
    EVENTLOGRECORD  pEventLogRecords[];
    DWORD               ulSize;
    DWORD               ulNumEventsForLogFile;
    DWORD               ulOffsets[];
#line 20768 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20775 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20796 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20833 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20874 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20898 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20921 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 20960 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum _CM_SERVICE_NODE_TYPE {
    DriverType               = 0x00000001,
    FileSystemType           = 0x00000002,
    Win32ServiceOwnProcess   = 0x00000010,
    Win32ServiceShareProcess = 0x00000020,
    AdapterType              = 0x00000004,
    RecognizerType           = 0x00000008
} SERVICE_NODE_TYPE;
typedef enum _CM_SERVICE_LOAD_TYPE {
    BootLoad    = 0x00000000,
    SystemLoad  = 0x00000001,
    AutoLoad    = 0x00000002,
    DemandLoad  = 0x00000003,
    DisableLoad = 0x00000004
} SERVICE_LOAD_TYPE;
typedef enum _CM_ERROR_CONTROL_TYPE {
    IgnoreError   = 0x00000000,
    NormalError   = 0x00000001,
    SevereError   = 0x00000002,
    CriticalError = 0x00000003
} SERVICE_ERROR_TYPE;
#line 21047 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21060 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _TAPE_ERASE {
    DWORD Type;
    BOOLEAN Immediate;
} TAPE_ERASE, *PTAPE_ERASE;
#line 21087 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _TAPE_PREPARE {
    DWORD Operation;
    BOOLEAN Immediate;
} TAPE_PREPARE, *PTAPE_PREPARE;
typedef struct _TAPE_WRITE_MARKS {
    DWORD Type;
    DWORD Count;
    BOOLEAN Immediate;
} TAPE_WRITE_MARKS, *PTAPE_WRITE_MARKS;
typedef struct _TAPE_GET_POSITION {
    DWORD Type;
    DWORD Partition;
    LARGE_INTEGER Offset;
} TAPE_GET_POSITION, *PTAPE_GET_POSITION;
#line 21136 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef struct _TAPE_SET_POSITION {
    DWORD Method;
    DWORD Partition;
    BOOLEAN Immediate;
} TAPE_SET_POSITION, *PTAPE_SET_POSITION;
typedef struct _TAPE_GET_DRIVE_PARAMETERS {
    BOOLEAN ECC;
    BOOLEAN Compression;
    BOOLEAN DataPadding;
    BOOLEAN ReportSetmarks;
    DWORD DefaultBlockSize;
    DWORD MaximumBlockSize;
    DWORD MinimumBlockSize;
    DWORD MaximumPartitionCount;
    DWORD FeaturesLow;
    DWORD FeaturesHigh;
    DWORD EOTWarningZoneSize;
} TAPE_GET_DRIVE_PARAMETERS, *PTAPE_GET_DRIVE_PARAMETERS;
typedef struct _TAPE_SET_DRIVE_PARAMETERS {
    BOOLEAN ECC;
} TAPE_SET_DRIVE_PARAMETERS, *PTAPE_SET_DRIVE_PARAMETERS;
typedef struct _TAPE_GET_MEDIA_PARAMETERS {
    LARGE_INTEGER Capacity;
    LARGE_INTEGER Remaining;
    DWORD BlockSize;
    DWORD PartitionCount;
    BOOLEAN WriteProtected;
} TAPE_GET_MEDIA_PARAMETERS, *PTAPE_GET_MEDIA_PARAMETERS;
typedef struct _TAPE_SET_MEDIA_PARAMETERS {
    DWORD BlockSize;
} TAPE_SET_MEDIA_PARAMETERS, *PTAPE_SET_MEDIA_PARAMETERS;
typedef struct _TAPE_CREATE_PARTITION {
    DWORD Method;
    DWORD Count;
    DWORD Size;
} TAPE_CREATE_PARTITION, *PTAPE_CREATE_PARTITION;
typedef struct _TAPE_WMI_OPERATIONS {
   DWORD Method;
   DWORD DataBufferSize;
   PVOID DataBuffer;
} TAPE_WMI_OPERATIONS, *PTAPE_WMI_OPERATIONS;
typedef enum _TAPE_DRIVE_PROBLEM_TYPE {
   TapeDriveProblemNone, TapeDriveReadWriteWarning,
   TapeDriveReadWriteError, TapeDriveReadWarning,
   TapeDriveWriteWarning, TapeDriveReadError,
   TapeDriveWriteError, TapeDriveHardwareError,
   TapeDriveUnsupportedMedia, TapeDriveScsiConnectionError,
   TapeDriveTimetoClean, TapeDriveCleanDriveNow,
   TapeDriveMediaLifeExpired, TapeDriveSnappedTape
} TAPE_DRIVE_PROBLEM_TYPE;
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\ktmtypes.h"
#pragma warning(disable:4820)
typedef GUID UOW, *PUOW;
typedef GUID CRM_PROTOCOL_ID, *PCRM_PROTOCOL_ID;
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\ktmtypes.h"
typedef ULONG NOTIFICATION_MASK;
#line 109 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\ktmtypes.h"
typedef struct _TRANSACTION_NOTIFICATION {
    PVOID         TransactionKey;
    ULONG         TransactionNotification;
    LARGE_INTEGER TmVirtualClock;
    ULONG         ArgumentLength;
} TRANSACTION_NOTIFICATION, *PTRANSACTION_NOTIFICATION;
typedef struct _TRANSACTION_NOTIFICATION_RECOVERY_ARGUMENT {
    GUID   EnlistmentId;
    UOW    UOW;
} TRANSACTION_NOTIFICATION_RECOVERY_ARGUMENT, *PTRANSACTION_NOTIFICATION_RECOVERY_ARGUMENT;
typedef struct _TRANSACTION_NOTIFICATION_TM_ONLINE_ARGUMENT {
    GUID TmIdentity;
    ULONG Flags;
} TRANSACTION_NOTIFICATION_TM_ONLINE_ARGUMENT, *PTRANSACTION_NOTIFICATION_TM_ONLINE_ARGUMENT;
typedef ULONG SAVEPOINT_ID, *PSAVEPOINT_ID;
typedef struct _TRANSACTION_NOTIFICATION_SAVEPOINT_ARGUMENT {
    SAVEPOINT_ID SavepointId;
} TRANSACTION_NOTIFICATION_SAVEPOINT_ARGUMENT, *PTRANSACTION_NOTIFICATION_SAVEPOINT_ARGUMENT;
typedef struct _TRANSACTION_NOTIFICATION_PROPAGATE_ARGUMENT {
    ULONG PropagationCookie;
    GUID  UOW;
    GUID  TmIdentity;
    ULONG BufferLength;
} TRANSACTION_NOTIFICATION_PROPAGATE_ARGUMENT, *PTRANSACTION_NOTIFICATION_PROPAGATE_ARGUMENT;
typedef struct _TRANSACTION_NOTIFICATION_MARSHAL_ARGUMENT {
    ULONG MarshalCookie;
    GUID  UOW;
} TRANSACTION_NOTIFICATION_MARSHAL_ARGUMENT, *PTRANSACTION_NOTIFICATION_MARSHAL_ARGUMENT;
typedef TRANSACTION_NOTIFICATION_PROPAGATE_ARGUMENT TRANSACTION_NOTIFICATION_PROMOTE_ARGUMENT, *PTRANSACTION_NOTIFICATION_PROMOTE_ARGUMENT;
typedef struct _KCRM_MARSHAL_HEADER {
    ULONG              VersionMajor;
    ULONG              VersionMinor;
    ULONG              NumProtocols;
    ULONG              Unused;
} KCRM_MARSHAL_HEADER, *PKCRM_MARSHAL_HEADER, * PRKCRM_MARSHAL_HEADER;
typedef struct _KCRM_TRANSACTION_BLOB {
    UOW                UOW;
    GUID               TmIdentity;
    ULONG              IsolationLevel;
    ULONG              IsolationFlags;
    ULONG              Timeout;
    WCHAR              Description[64];
} KCRM_TRANSACTION_BLOB, *PKCRM_TRANSACTION_BLOB, * PRKCRM_TRANSACTION_BLOB;
typedef struct _KCRM_PROTOCOL_BLOB {
    CRM_PROTOCOL_ID    ProtocolId;
     ULONG StaticInfoLength;
    ULONG              TransactionIdInfoLength;
    ULONG              Unused1;
    ULONG              Unused2;
} KCRM_PROTOCOL_BLOB, *PKCRM_PROTOCOL_BLOB, * PRKCRM_PROTOCOL_BLOB;
#line 21330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21387 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21407 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21425 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21436 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21452 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 21459 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
typedef enum _TRANSACTION_OUTCOME {
    TransactionOutcomeUndetermined = 1,
    TransactionOutcomeCommitted,
    TransactionOutcomeAborted,
} TRANSACTION_OUTCOME;
typedef enum _TRANSACTION_STATE {
    TransactionStateNormal = 1,
    TransactionStateIndoubt,
    TransactionStateCommittedNotify,
} TRANSACTION_STATE;
typedef struct _TRANSACTION_BASIC_INFORMATION {
    GUID    TransactionId;
    DWORD   State;
    DWORD   Outcome;
} TRANSACTION_BASIC_INFORMATION, *PTRANSACTION_BASIC_INFORMATION;
typedef struct _TRANSACTIONMANAGER_BASIC_INFORMATION {
    GUID    TmIdentity;
    LARGE_INTEGER VirtualClock;
} TRANSACTIONMANAGER_BASIC_INFORMATION, *PTRANSACTIONMANAGER_BASIC_INFORMATION;
typedef struct _TRANSACTIONMANAGER_LOG_INFORMATION {
    GUID  LogIdentity;
} TRANSACTIONMANAGER_LOG_INFORMATION, *PTRANSACTIONMANAGER_LOG_INFORMATION;
typedef struct _TRANSACTIONMANAGER_LOGPATH_INFORMATION {
    DWORD LogPathLength;
     WCHAR LogPath[1];
} TRANSACTIONMANAGER_LOGPATH_INFORMATION, *PTRANSACTIONMANAGER_LOGPATH_INFORMATION;
typedef struct _TRANSACTIONMANAGER_RECOVERY_INFORMATION {
    ULONGLONG  LastRecoveredLsn;
} TRANSACTIONMANAGER_RECOVERY_INFORMATION, *PTRANSACTIONMANAGER_RECOVERY_INFORMATION;
typedef struct _TRANSACTIONMANAGER_OLDEST_INFORMATION {
    GUID OldestTransactionGuid;
} TRANSACTIONMANAGER_OLDEST_INFORMATION, *PTRANSACTIONMANAGER_OLDEST_INFORMATION;
typedef struct _TRANSACTION_PROPERTIES_INFORMATION {
    DWORD              IsolationLevel;
    DWORD              IsolationFlags;
    LARGE_INTEGER      Timeout;
    DWORD              Outcome;
    DWORD              DescriptionLength;
    WCHAR              Description[1];
} TRANSACTION_PROPERTIES_INFORMATION, *PTRANSACTION_PROPERTIES_INFORMATION;
typedef struct _TRANSACTION_BIND_INFORMATION {
    HANDLE TmHandle;
} TRANSACTION_BIND_INFORMATION, *PTRANSACTION_BIND_INFORMATION;
typedef struct _TRANSACTION_ENLISTMENT_PAIR {
    GUID   EnlistmentId;
    GUID   ResourceManagerId;
} TRANSACTION_ENLISTMENT_PAIR, *PTRANSACTION_ENLISTMENT_PAIR;
typedef struct _TRANSACTION_ENLISTMENTS_INFORMATION {
    DWORD                       NumberOfEnlistments;
    TRANSACTION_ENLISTMENT_PAIR EnlistmentPair[1];
} TRANSACTION_ENLISTMENTS_INFORMATION, *PTRANSACTION_ENLISTMENTS_INFORMATION;
typedef struct _TRANSACTION_SUPERIOR_ENLISTMENT_INFORMATION {
    TRANSACTION_ENLISTMENT_PAIR SuperiorEnlistmentPair;
} TRANSACTION_SUPERIOR_ENLISTMENT_INFORMATION, *PTRANSACTION_SUPERIOR_ENLISTMENT_INFORMATION;
typedef struct _RESOURCEMANAGER_BASIC_INFORMATION {
} RESOURCEMANAGER_BASIC_INFORMATION, *PRESOURCEMANAGER_BASIC_INFORMATION;
typedef struct _RESOURCEMANAGER_COMPLETION_INFORMATION {
    HANDLE    IoCompletionPortHandle;
    ULONG_PTR CompletionKey;
} RESOURCEMANAGER_COMPLETION_INFORMATION, *PRESOURCEMANAGER_COMPLETION_INFORMATION;
typedef enum _TRANSACTION_INFORMATION_CLASS {
    TransactionBasicInformation,
    TransactionPropertiesInformation,
    TransactionEnlistmentInformation,
    TransactionSuperiorEnlistmentInformation
    TransactionBindInformation,
    TransactionDTCPrivateInformation
} TRANSACTION_INFORMATION_CLASS;
typedef enum _TRANSACTIONMANAGER_INFORMATION_CLASS {
    TransactionManagerBasicInformation,
    TransactionManagerLogInformation,
    TransactionManagerLogPathInformation,
    TransactionManagerRecoveryInformation = 4
    TransactionManagerOnlineProbeInformation = 3,
    TransactionManagerOldestTransactionInformation = 5
} TRANSACTIONMANAGER_INFORMATION_CLASS;
typedef enum _RESOURCEMANAGER_INFORMATION_CLASS {
    ResourceManagerBasicInformation,
    ResourceManagerCompletionInformation,
} RESOURCEMANAGER_INFORMATION_CLASS;
typedef struct _ENLISTMENT_BASIC_INFORMATION {
    GUID    EnlistmentId;
    GUID    TransactionId;
} ENLISTMENT_BASIC_INFORMATION, *PENLISTMENT_BASIC_INFORMATION;
typedef struct _ENLISTMENT_CRM_INFORMATION {
    GUID   CrmTransactionManagerId;
    GUID   CrmResourceManagerId;
    GUID   CrmEnlistmentId;
} ENLISTMENT_CRM_INFORMATION, *PENLISTMENT_CRM_INFORMATION;
typedef enum _ENLISTMENT_INFORMATION_CLASS {
    EnlistmentBasicInformation,
    EnlistmentRecoveryInformation,
    EnlistmentCrmInformation
} ENLISTMENT_INFORMATION_CLASS;
typedef struct _TRANSACTION_LIST_ENTRY {
    UOW    UOW;
} TRANSACTION_LIST_ENTRY, *PTRANSACTION_LIST_ENTRY;
typedef struct _TRANSACTION_LIST_INFORMATION {
    DWORD   NumberOfTransactions;
    TRANSACTION_LIST_ENTRY TransactionInformation[1];
} TRANSACTION_LIST_INFORMATION, *PTRANSACTION_LIST_INFORMATION;
typedef enum _KTMOBJECT_TYPE {
    KTMOBJECT_TRANSACTION,
    KTMOBJECT_TRANSACTION_MANAGER,
    KTMOBJECT_RESOURCE_MANAGER,
    KTMOBJECT_ENLISTMENT,
    KTMOBJECT_INVALID
} KTMOBJECT_TYPE, *PKTMOBJECT_TYPE;
typedef struct _KTMOBJECT_CURSOR {
    GUID    LastQuery;
    DWORD   ObjectIdCount;
    GUID    ObjectIds[1];
} KTMOBJECT_CURSOR, *PKTMOBJECT_CURSOR;
#pragma warning(pop)
typedef DWORD TP_VERSION, *PTP_VERSION;
typedef struct _TP_CALLBACK_INSTANCE TP_CALLBACK_INSTANCE, *PTP_CALLBACK_INSTANCE;
typedef void (__stdcall *PTP_SIMPLE_CALLBACK)(
         PTP_CALLBACK_INSTANCE Instance,
     PVOID                 Context
typedef struct _TP_POOL TP_POOL, *PTP_POOL;
typedef enum _TP_CALLBACK_PRIORITY {
    TP_CALLBACK_PRIORITY_HIGH,
    TP_CALLBACK_PRIORITY_NORMAL,
    TP_CALLBACK_PRIORITY_LOW,
    TP_CALLBACK_PRIORITY_INVALID,
    TP_CALLBACK_PRIORITY_COUNT = TP_CALLBACK_PRIORITY_INVALID
} TP_CALLBACK_PRIORITY;
typedef struct _TP_POOL_STACK_INFORMATION {
    SIZE_T StackReserve;
    SIZE_T StackCommit;
}TP_POOL_STACK_INFORMATION, *PTP_POOL_STACK_INFORMATION;
typedef struct _TP_CLEANUP_GROUP TP_CLEANUP_GROUP, *PTP_CLEANUP_GROUP;
typedef void (__stdcall *PTP_CLEANUP_GROUP_CANCEL_CALLBACK)(
     PVOID ObjectContext,
     PVOID CleanupContext
typedef struct _TP_CALLBACK_ENVIRON_V3 {
    TP_VERSION                         Version;
    PTP_POOL                           Pool;
    PTP_CLEANUP_GROUP                  CleanupGroup;
    PTP_CLEANUP_GROUP_CANCEL_CALLBACK  CleanupGroupCancelCallback;
    PVOID                              RaceDll;
    struct _ACTIVATION_CONTEXT        *ActivationContext;
    PTP_SIMPLE_CALLBACK                FinalizationCallback;
    union {
        DWORD                          Flags;
        struct {
            DWORD                      LongFunction :  1;
            DWORD                      Persistent   :  1;
            DWORD                      Private      : 30;
        } s;
    } u;
    TP_CALLBACK_PRIORITY               CallbackPriority;
    DWORD                              Size;
} TP_CALLBACK_ENVIRON_V3;
typedef TP_CALLBACK_ENVIRON_V3 TP_CALLBACK_ENVIRON, *PTP_CALLBACK_ENVIRON;
#line 21807 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
__forceinline
void
TpInitializeCallbackEnviron(
     PTP_CALLBACK_ENVIRON CallbackEnviron
    CallbackEnviron->Version = 3;
    CallbackEnviron->Pool = ((void *)0);
    CallbackEnviron->CleanupGroup = ((void *)0);
    CallbackEnviron->CleanupGroupCancelCallback = ((void *)0);
    CallbackEnviron->RaceDll = ((void *)0);
    CallbackEnviron->ActivationContext = ((void *)0);
    CallbackEnviron->FinalizationCallback = ((void *)0);
    CallbackEnviron->u.Flags = 0;
    CallbackEnviron->CallbackPriority = TP_CALLBACK_PRIORITY_NORMAL;
    CallbackEnviron->Size = sizeof(TP_CALLBACK_ENVIRON);
__forceinline
void
TpSetCallbackThreadpool(
     PTP_CALLBACK_ENVIRON CallbackEnviron,
        PTP_POOL             Pool
    CallbackEnviron->Pool = Pool;
__forceinline
void
TpSetCallbackCleanupGroup(
         PTP_CLEANUP_GROUP                 CleanupGroup,
    CallbackEnviron->CleanupGroup = CleanupGroup;
    CallbackEnviron->CleanupGroupCancelCallback = CleanupGroupCancelCallback;
__forceinline
void
TpSetCallbackActivationContext(
    CallbackEnviron->ActivationContext = ActivationContext;
__forceinline
void
TpSetCallbackNoActivationContext(
    CallbackEnviron->ActivationContext = (struct _ACTIVATION_CONTEXT *)(LONG_PTR) -1;
__forceinline
void
TpSetCallbackLongFunction(
    CallbackEnviron->u.s.LongFunction = 1;
__forceinline
void
TpSetCallbackRaceWithDll(
        PVOID                DllHandle
    CallbackEnviron->RaceDll = DllHandle;
__forceinline
void
TpSetCallbackFinalizationCallback(
    CallbackEnviron->FinalizationCallback = FinalizationCallback;
__forceinline
void
TpSetCallbackPriority(
        TP_CALLBACK_PRIORITY Priority
    CallbackEnviron->CallbackPriority = Priority;
__forceinline
void
TpSetCallbackPersistent(
    CallbackEnviron->u.s.Persistent = 1;
__forceinline
void
TpDestroyCallbackEnviron(
    (CallbackEnviron);
typedef struct _TP_WORK TP_WORK, *PTP_WORK;
typedef void (__stdcall *PTP_WORK_CALLBACK)(
     PVOID                 Context,
         PTP_WORK              Work
typedef struct _TP_TIMER TP_TIMER, *PTP_TIMER;
typedef void (__stdcall *PTP_TIMER_CALLBACK)(
     PVOID                 Context,
         PTP_TIMER             Timer
typedef DWORD    TP_WAIT_RESULT;
typedef struct _TP_WAIT TP_WAIT, *PTP_WAIT;
typedef void (__stdcall *PTP_WAIT_CALLBACK)(
     PVOID                 Context,
         PTP_WAIT              Wait,
            TP_WAIT_RESULT        WaitResult
typedef struct _TP_IO TP_IO, *PTP_IO;
__forceinline
struct _TEB *
NtCurrentTeb (
    void
    return (struct _TEB *)__readgsqword(((LONG)(LONG_PTR)&(((NT_TIB *)0)->Self)));
__forceinline
PVOID
GetCurrentFiber (
    void
    return (PVOID)__readgsqword(((LONG)(LONG_PTR)&(((NT_TIB *)0)->FiberData)));
__forceinline
PVOID
GetFiberData (
    void
    return *(PVOID *)GetCurrentFiber();
#line 22053 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 22086 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 22099 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 22113 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winnt.h"
#line 183 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
typedef UINT_PTR            WPARAM;
typedef LONG_PTR            LPARAM;
typedef LONG_PTR            LRESULT;
#line 208 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
typedef HANDLE          *SPHANDLE;
typedef HANDLE           *LPHANDLE;
typedef HANDLE              HGLOBAL;
typedef HANDLE              HLOCAL;
typedef HANDLE              GLOBALHANDLE;
typedef HANDLE              LOCALHANDLE;
#pragma warning(push)
#pragma warning(disable:4255)
typedef INT_PTR ( __stdcall *FARPROC)();
typedef INT_PTR ( __stdcall *NEARPROC)();
typedef INT_PTR (__stdcall *PROC)();
#line 237 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
#line 244 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\minwindef.h"
typedef WORD                ATOM;
struct HKEY__{int unused;}; typedef struct HKEY__ *HKEY;
typedef HKEY *PHKEY;
struct HMETAFILE__{int unused;}; typedef struct HMETAFILE__ *HMETAFILE;
struct HINSTANCE__{int unused;}; typedef struct HINSTANCE__ *HINSTANCE;
typedef HINSTANCE HMODULE;
struct HRGN__{int unused;}; typedef struct HRGN__ *HRGN;
struct HRSRC__{int unused;}; typedef struct HRSRC__ *HRSRC;
struct HSPRITE__{int unused;}; typedef struct HSPRITE__ *HSPRITE;
struct HLSURF__{int unused;}; typedef struct HLSURF__ *HLSURF;
struct HSTR__{int unused;}; typedef struct HSTR__ *HSTR;
struct HTASK__{int unused;}; typedef struct HTASK__ *HTASK;
struct HWINSTA__{int unused;}; typedef struct HWINSTA__ *HWINSTA;
struct HKL__{int unused;}; typedef struct HKL__ *HKL;
typedef int HFILE;
typedef struct _FILETIME {
    DWORD dwLowDateTime;
    DWORD dwHighDateTime;
} FILETIME, *PFILETIME, *LPFILETIME;
#pragma endregion
#line 25 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\windef.h"
#pragma region Application Family or OneCore Family
struct HWND__{int unused;}; typedef struct HWND__ *HWND;
struct HHOOK__{int unused;}; typedef struct HHOOK__ *HHOOK;
#pragma endregion
#line 57 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\windef.h"
typedef void * HGDIOBJ;
struct HACCEL__{int unused;}; typedef struct HACCEL__ *HACCEL;
struct HBITMAP__{int unused;}; typedef struct HBITMAP__ *HBITMAP;
struct HBRUSH__{int unused;}; typedef struct HBRUSH__ *HBRUSH;
struct HCOLORSPACE__{int unused;}; typedef struct HCOLORSPACE__ *HCOLORSPACE;
struct HDC__{int unused;}; typedef struct HDC__ *HDC;
struct HGLRC__{int unused;}; typedef struct HGLRC__ *HGLRC;
struct HDESK__{int unused;}; typedef struct HDESK__ *HDESK;
struct HENHMETAFILE__{int unused;}; typedef struct HENHMETAFILE__ *HENHMETAFILE;
struct HFONT__{int unused;}; typedef struct HFONT__ *HFONT;
struct HICON__{int unused;}; typedef struct HICON__ *HICON;
struct HMENU__{int unused;}; typedef struct HMENU__ *HMENU;
struct HPALETTE__{int unused;}; typedef struct HPALETTE__ *HPALETTE;
struct HPEN__{int unused;}; typedef struct HPEN__ *HPEN;
struct HWINEVENTHOOK__{int unused;}; typedef struct HWINEVENTHOOK__ *HWINEVENTHOOK;
#pragma endregion
struct HMONITOR__{int unused;}; typedef struct HMONITOR__ *HMONITOR;
#pragma endregion
struct HUMPD__{int unused;}; typedef struct HUMPD__ *HUMPD;
#pragma endregion
typedef HICON HCURSOR;
typedef DWORD   COLORREF;
#pragma endregion
typedef DWORD   *LPCOLORREF;
#pragma endregion
typedef struct tagRECT
    LONG    left;
    LONG    top;
    LONG    right;
    LONG    bottom;
} RECT, *PRECT,  *NPRECT,  *LPRECT;
typedef const RECT * LPCRECT;
typedef struct _RECTL
    LONG    left;
    LONG    top;
    LONG    right;
    LONG    bottom;
} RECTL, *PRECTL, *LPRECTL;
typedef const RECTL * LPCRECTL;
typedef struct tagPOINT
    LONG  x;
    LONG  y;
} POINT, *PPOINT,  *NPPOINT,  *LPPOINT;
typedef struct _POINTL
    LONG  x;
    LONG  y;
} POINTL, *PPOINTL;
typedef struct tagSIZE
    LONG        cx;
    LONG        cy;
} SIZE, *PSIZE, *LPSIZE;
typedef SIZE               SIZEL;
typedef SIZE               *PSIZEL, *LPSIZEL;
typedef struct tagPOINTS
    SHORT   x;
    SHORT   y;
} POINTS, *PPOINTS, *LPPOINTS;
#pragma endregion
#line 239 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\windef.h"
struct DPI_AWARENESS_CONTEXT__{int unused;}; typedef struct DPI_AWARENESS_CONTEXT__ *DPI_AWARENESS_CONTEXT;
typedef enum DPI_AWARENESS {
    DPI_AWARENESS_INVALID           = -1,
    DPI_AWARENESS_UNAWARE           = 0,
    DPI_AWARENESS_SYSTEM_AWARE      = 1,
    DPI_AWARENESS_PER_MONITOR_AWARE = 2
} DPI_AWARENESS;
typedef enum DPI_HOSTING_BEHAVIOR {
    DPI_HOSTING_BEHAVIOR_INVALID     = -1,
    DPI_HOSTING_BEHAVIOR_DEFAULT     = 0,
    DPI_HOSTING_BEHAVIOR_MIXED       = 1
} DPI_HOSTING_BEHAVIOR;
#line 172 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\windows.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma once
#pragma warning(disable:4668)
#pragma warning(disable:4001)
#pragma warning(disable:4201)
#pragma warning(disable:4214)
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 19 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 27 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 35 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 53 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 61 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 69 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 77 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 85 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 93 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\apisetcconv.h"
#line 35 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
#pragma once
#pragma warning(disable:4514)
#pragma warning(disable:4103)
typedef struct _SECURITY_ATTRIBUTES {
    DWORD nLength;
    LPVOID lpSecurityDescriptor;
    BOOL bInheritHandle;
} SECURITY_ATTRIBUTES, *PSECURITY_ATTRIBUTES, *LPSECURITY_ATTRIBUTES;
typedef struct _OVERLAPPED {
    ULONG_PTR Internal;
    ULONG_PTR InternalHigh;
    union {
        struct {
            DWORD Offset;
            DWORD OffsetHigh;
        PVOID Pointer;
    HANDLE  hEvent;
} OVERLAPPED, *LPOVERLAPPED;
typedef struct _OVERLAPPED_ENTRY {
    ULONG_PTR lpCompletionKey;
    LPOVERLAPPED lpOverlapped;
    ULONG_PTR Internal;
    DWORD dwNumberOfBytesTransferred;
} OVERLAPPED_ENTRY, *LPOVERLAPPED_ENTRY;
#line 85 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
typedef struct _SYSTEMTIME {
    WORD wYear;
    WORD wMonth;
    WORD wDayOfWeek;
    WORD wDay;
    WORD wHour;
    WORD wMinute;
    WORD wSecond;
    WORD wMilliseconds;
} SYSTEMTIME, *PSYSTEMTIME, *LPSYSTEMTIME;
typedef struct _WIN32_FIND_DATAA {
    DWORD dwFileAttributes;
    FILETIME ftCreationTime;
    FILETIME ftLastAccessTime;
    FILETIME ftLastWriteTime;
    DWORD nFileSizeHigh;
    DWORD nFileSizeLow;
    DWORD dwReserved0;
    DWORD dwReserved1;
     CHAR   cFileName[ 260 ];
     CHAR   cAlternateFileName[ 14 ];
} WIN32_FIND_DATAA, *PWIN32_FIND_DATAA, *LPWIN32_FIND_DATAA;
typedef struct _WIN32_FIND_DATAW {
    DWORD nFileSizeLow;
    DWORD dwReserved0;
    DWORD dwReserved1;
     WCHAR  cFileName[ 260 ];
     WCHAR  cAlternateFileName[ 14 ];
} WIN32_FIND_DATAW, *PWIN32_FIND_DATAW, *LPWIN32_FIND_DATAW;
typedef WIN32_FIND_DATAA WIN32_FIND_DATA;
typedef PWIN32_FIND_DATAA PWIN32_FIND_DATA;
typedef LPWIN32_FIND_DATAA LPWIN32_FIND_DATA;
typedef enum _FINDEX_INFO_LEVELS {
    FindExInfoStandard,
    FindExInfoBasic,
    FindExInfoMaxInfoLevel
} FINDEX_INFO_LEVELS;
typedef enum _FINDEX_SEARCH_OPS {
    FindExSearchNameMatch,
    FindExSearchLimitToDirectories,
    FindExSearchLimitToDevices,
    FindExSearchMaxSearchOp
} FINDEX_SEARCH_OPS;
typedef enum _READ_DIRECTORY_NOTIFY_INFORMATION_CLASS {
    ReadDirectoryNotifyInformation         = 1,
    ReadDirectoryNotifyExtendedInformation
} READ_DIRECTORY_NOTIFY_INFORMATION_CLASS, *PREAD_DIRECTORY_NOTIFY_INFORMATION_CLASS;
typedef enum _GET_FILEEX_INFO_LEVELS {
    GetFileExInfoStandard,
    GetFileExMaxInfoLevel
} GET_FILEEX_INFO_LEVELS;
typedef enum _FILE_INFO_BY_HANDLE_CLASS {
    FileBasicInfo,
    FileStandardInfo,
    FileNameInfo,
    FileRenameInfo,
    FileDispositionInfo,
    FileAllocationInfo,
    FileEndOfFileInfo,
    FileStreamInfo,
    FileCompressionInfo,
    FileAttributeTagInfo,
    FileIdBothDirectoryInfo,
    FileIdBothDirectoryRestartInfo,
    FileIoPriorityHintInfo,
    FileRemoteProtocolInfo,
    FileFullDirectoryInfo,
    FileFullDirectoryRestartInfo,
    FileStorageInfo,
    FileAlignmentInfo,
    FileIdInfo,
    FileIdExtdDirectoryInfo,
    FileIdExtdDirectoryRestartInfo,
    FileDispositionInfoEx,
    FileRenameInfoEx,
    MaximumFileInfoByHandleClass
} FILE_INFO_BY_HANDLE_CLASS, *PFILE_INFO_BY_HANDLE_CLASS;
typedef RTL_CRITICAL_SECTION CRITICAL_SECTION;
typedef PRTL_CRITICAL_SECTION PCRITICAL_SECTION;
typedef PRTL_CRITICAL_SECTION LPCRITICAL_SECTION;
typedef RTL_CRITICAL_SECTION_DEBUG CRITICAL_SECTION_DEBUG;
typedef PRTL_CRITICAL_SECTION_DEBUG PCRITICAL_SECTION_DEBUG;
typedef PRTL_CRITICAL_SECTION_DEBUG LPCRITICAL_SECTION_DEBUG;
typedef
void
(__stdcall *LPOVERLAPPED_COMPLETION_ROUTINE)(
        DWORD dwErrorCode,
        DWORD dwNumberOfBytesTransfered,
typedef struct _PROCESS_HEAP_ENTRY {
    PVOID lpData;
    DWORD cbData;
    BYTE cbOverhead;
    BYTE iRegionIndex;
    WORD wFlags;
    union {
        struct {
            HANDLE hMem;
            DWORD dwReserved[ 3 ];
        } Block;
        struct {
            DWORD dwCommittedSize;
            DWORD dwUnCommittedSize;
            LPVOID lpFirstBlock;
            LPVOID lpLastBlock;
        } Region;
} PROCESS_HEAP_ENTRY, *LPPROCESS_HEAP_ENTRY, *PPROCESS_HEAP_ENTRY;
#line 260 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
typedef struct _REASON_CONTEXT {
    ULONG Version;
    DWORD Flags;
    union {
        struct {
            HMODULE LocalizedReasonModule;
            ULONG LocalizedReasonId;
            ULONG ReasonStringCount;
            LPWSTR *ReasonStrings;
        } Detailed;
        LPWSTR SimpleReasonString;
    } Reason;
} REASON_CONTEXT, *PREASON_CONTEXT;
#line 289 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
typedef DWORD (__stdcall *PTHREAD_START_ROUTINE)(
    LPVOID lpThreadParameter
typedef PTHREAD_START_ROUTINE LPTHREAD_START_ROUTINE;
typedef LPVOID (__stdcall *PENCLAVE_ROUTINE)(
typedef PENCLAVE_ROUTINE LPENCLAVE_ROUTINE;
typedef struct _EXCEPTION_DEBUG_INFO {
    EXCEPTION_RECORD ExceptionRecord;
    DWORD dwFirstChance;
} EXCEPTION_DEBUG_INFO, *LPEXCEPTION_DEBUG_INFO;
typedef struct _CREATE_THREAD_DEBUG_INFO {
    HANDLE hThread;
    LPVOID lpThreadLocalBase;
    LPTHREAD_START_ROUTINE lpStartAddress;
} CREATE_THREAD_DEBUG_INFO, *LPCREATE_THREAD_DEBUG_INFO;
typedef struct _CREATE_PROCESS_DEBUG_INFO {
    HANDLE hFile;
    HANDLE hProcess;
    HANDLE hThread;
    LPVOID lpBaseOfImage;
    DWORD dwDebugInfoFileOffset;
    DWORD nDebugInfoSize;
    LPVOID lpImageName;
    WORD fUnicode;
} CREATE_PROCESS_DEBUG_INFO, *LPCREATE_PROCESS_DEBUG_INFO;
typedef struct _EXIT_THREAD_DEBUG_INFO {
    DWORD dwExitCode;
} EXIT_THREAD_DEBUG_INFO, *LPEXIT_THREAD_DEBUG_INFO;
typedef struct _EXIT_PROCESS_DEBUG_INFO {
    DWORD dwExitCode;
} EXIT_PROCESS_DEBUG_INFO, *LPEXIT_PROCESS_DEBUG_INFO;
typedef struct _LOAD_DLL_DEBUG_INFO {
    HANDLE hFile;
    LPVOID lpBaseOfDll;
    LPVOID lpImageName;
    WORD fUnicode;
} LOAD_DLL_DEBUG_INFO, *LPLOAD_DLL_DEBUG_INFO;
typedef struct _UNLOAD_DLL_DEBUG_INFO {
    LPVOID lpBaseOfDll;
} UNLOAD_DLL_DEBUG_INFO, *LPUNLOAD_DLL_DEBUG_INFO;
typedef struct _OUTPUT_DEBUG_STRING_INFO {
    LPSTR lpDebugStringData;
    WORD fUnicode;
    WORD nDebugStringLength;
} OUTPUT_DEBUG_STRING_INFO, *LPOUTPUT_DEBUG_STRING_INFO;
typedef struct _RIP_INFO {
    DWORD dwError;
    DWORD dwType;
} RIP_INFO, *LPRIP_INFO;
typedef struct _DEBUG_EVENT {
    DWORD dwDebugEventCode;
    DWORD dwProcessId;
    DWORD dwThreadId;
    union {
        EXCEPTION_DEBUG_INFO Exception;
        CREATE_THREAD_DEBUG_INFO CreateThread;
        CREATE_PROCESS_DEBUG_INFO CreateProcessInfo;
        EXIT_THREAD_DEBUG_INFO ExitThread;
        EXIT_PROCESS_DEBUG_INFO ExitProcess;
        LOAD_DLL_DEBUG_INFO LoadDll;
        UNLOAD_DLL_DEBUG_INFO UnloadDll;
        OUTPUT_DEBUG_STRING_INFO DebugString;
        RIP_INFO RipInfo;
    } u;
} DEBUG_EVENT, *LPDEBUG_EVENT;
typedef PCONTEXT LPCONTEXT;
#line 413 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
#line 424 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
#line 459 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\minwinbase.h"
#line 36 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\processenv.h"
#pragma once
BOOL
__stdcall
SetEnvironmentStringsW(
       LPWCH NewEnvironment
#pragma endregion
#pragma region PC Family or OneCore Family
HANDLE
__stdcall
GetStdHandle(
     DWORD nStdHandle
BOOL
__stdcall
SetStdHandle(
     DWORD nStdHandle,
     HANDLE hHandle
BOOL
__stdcall
SetStdHandleEx(
     DWORD nStdHandle,
     HANDLE hHandle,
     PHANDLE phPrevValue
#pragma endregion
LPSTR
__stdcall
GetCommandLineA(
    void
LPWSTR
__stdcall
GetCommandLineW(
    void
LPCH
__stdcall
GetEnvironmentStrings(
    void
LPWCH
__stdcall
GetEnvironmentStringsW(
    void
BOOL
__stdcall
FreeEnvironmentStringsA(
       LPCH penv
BOOL
__stdcall
FreeEnvironmentStringsW(
       LPWCH penv
DWORD
__stdcall
GetEnvironmentVariableA(
     LPCSTR lpName,
     LPSTR lpBuffer,
     DWORD nSize
DWORD
__stdcall
GetEnvironmentVariableW(
     LPCWSTR lpName,
     LPWSTR lpBuffer,
     DWORD nSize
BOOL
__stdcall
SetEnvironmentVariableA(
     LPCSTR lpName,
     LPCSTR lpValue
BOOL
__stdcall
SetEnvironmentVariableW(
     LPCWSTR lpName,
     LPCWSTR lpValue
DWORD
__stdcall
ExpandEnvironmentStringsA(
     LPCSTR lpSrc,
     LPSTR lpDst,
     DWORD nSize
DWORD
__stdcall
ExpandEnvironmentStringsW(
     LPCWSTR lpSrc,
     LPWSTR lpDst,
     DWORD nSize
BOOL
__stdcall
SetCurrentDirectoryA(
     LPCSTR lpPathName
BOOL
__stdcall
SetCurrentDirectoryW(
     LPCWSTR lpPathName
DWORD
__stdcall
GetCurrentDirectoryA(
     DWORD nBufferLength,
     LPSTR lpBuffer
DWORD
__stdcall
GetCurrentDirectoryW(
     LPWSTR lpBuffer
#pragma endregion
DWORD
__stdcall
SearchPathW(
     LPCWSTR lpPath,
     LPCWSTR lpFileName,
     LPCWSTR lpExtension,
     LPWSTR lpBuffer,
     LPWSTR* lpFilePart
DWORD
__stdcall
SearchPathA(
     LPCSTR lpPath,
     LPCSTR lpFileName,
     LPCSTR lpExtension,
     LPSTR lpBuffer,
     LPSTR* lpFilePart
BOOL
__stdcall
NeedCurrentDirectoryForExePathA(
     LPCSTR ExeName
BOOL
__stdcall
NeedCurrentDirectoryForExePathW(
     LPCWSTR ExeName
#pragma endregion
#line 42 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\fileapi.h"
#pragma once
#pragma endregion
LONG
__stdcall
CompareFileTime(
     const FILETIME* lpFileTime1,
     const FILETIME* lpFileTime2
BOOL
__stdcall
CreateDirectoryA(
     LPCSTR lpPathName,
     LPSECURITY_ATTRIBUTES lpSecurityAttributes
BOOL
__stdcall
CreateDirectoryW(
     LPCWSTR lpPathName,
#pragma endregion
HANDLE
__stdcall
CreateFileA(
     LPCSTR lpFileName,
     DWORD dwDesiredAccess,
     DWORD dwShareMode,
     LPSECURITY_ATTRIBUTES lpSecurityAttributes,
     DWORD dwCreationDisposition,
     DWORD dwFlagsAndAttributes,
     HANDLE hTemplateFile
HANDLE
__stdcall
CreateFileW(
     LPCWSTR lpFileName,
     DWORD dwShareMode,
BOOL
__stdcall
DefineDosDeviceW(
     DWORD dwFlags,
     LPCWSTR lpDeviceName,
     LPCWSTR lpTargetPath
#pragma endregion
BOOL
__stdcall
DeleteFileA(
     LPCSTR lpFileName
BOOL
__stdcall
DeleteFileW(
     LPCWSTR lpFileName
BOOL
__stdcall
DeleteVolumeMountPointW(
     LPCWSTR lpszVolumeMountPoint
BOOL
__stdcall
FileTimeToLocalFileTime(
     const FILETIME* lpFileTime,
     LPFILETIME lpLocalFileTime
BOOL
__stdcall
FindClose(
     HANDLE hFindFile
#pragma endregion
BOOL
__stdcall
FindCloseChangeNotification(
     HANDLE hChangeHandle
HANDLE
__stdcall
FindFirstChangeNotificationA(
     LPCSTR lpPathName,
     BOOL bWatchSubtree,
     DWORD dwNotifyFilter
HANDLE
__stdcall
FindFirstChangeNotificationW(
     LPCWSTR lpPathName,
     BOOL bWatchSubtree,
#pragma endregion
HANDLE
__stdcall
FindFirstFileA(
     LPCSTR lpFileName,
     LPWIN32_FIND_DATAA lpFindFileData
HANDLE
__stdcall
FindFirstFileW(
     LPCWSTR lpFileName,
     LPWIN32_FIND_DATAW lpFindFileData
HANDLE
__stdcall
FindFirstFileExA(
     LPCSTR lpFileName,
     FINDEX_INFO_LEVELS fInfoLevelId,
     LPVOID lpFindFileData,
     FINDEX_SEARCH_OPS fSearchOp,
     LPVOID lpSearchFilter,
     DWORD dwAdditionalFlags
HANDLE
__stdcall
FindFirstFileExW(
     LPCWSTR lpFileName,
#pragma endregion
HANDLE
__stdcall
FindFirstVolumeW(
     LPWSTR lpszVolumeName,
     DWORD cchBufferLength
BOOL
__stdcall
FindNextChangeNotification(
#pragma endregion
BOOL
__stdcall
FindNextFileA(
     HANDLE hFindFile,
BOOL
__stdcall
FindNextFileW(
     HANDLE hFindFile,
#pragma endregion
BOOL
__stdcall
FindNextVolumeW(
     HANDLE hFindVolume,
BOOL
__stdcall
FindVolumeClose(
     HANDLE hFindVolume
#pragma endregion
BOOL
__stdcall
FlushFileBuffers(
     HANDLE hFile
#pragma endregion
BOOL
__stdcall
GetDiskFreeSpaceA(
     LPCSTR lpRootPathName,
     LPDWORD lpSectorsPerCluster,
     LPDWORD lpBytesPerSector,
     LPDWORD lpNumberOfFreeClusters,
     LPDWORD lpTotalNumberOfClusters
BOOL
__stdcall
GetDiskFreeSpaceW(
     LPCWSTR lpRootPathName,
BOOL
__stdcall
GetDiskFreeSpaceExA(
     LPCSTR lpDirectoryName,
     PULARGE_INTEGER lpFreeBytesAvailableToCaller,
     PULARGE_INTEGER lpTotalNumberOfBytes,
     PULARGE_INTEGER lpTotalNumberOfFreeBytes
BOOL
__stdcall
GetDiskFreeSpaceExW(
     LPCWSTR lpDirectoryName,
UINT
__stdcall
GetDriveTypeA(
UINT
__stdcall
GetDriveTypeW(
#pragma endregion
typedef struct _WIN32_FILE_ATTRIBUTE_DATA {
    DWORD nFileSizeLow;
} WIN32_FILE_ATTRIBUTE_DATA, *LPWIN32_FILE_ATTRIBUTE_DATA;
DWORD
__stdcall
GetFileAttributesA(
     LPCSTR lpFileName
DWORD
__stdcall
GetFileAttributesW(
     LPCWSTR lpFileName
BOOL
__stdcall
GetFileAttributesExA(
     LPCSTR lpFileName,
     GET_FILEEX_INFO_LEVELS fInfoLevelId,
     LPVOID lpFileInformation
BOOL
__stdcall
GetFileAttributesExW(
     LPCWSTR lpFileName,
#pragma endregion
typedef struct _BY_HANDLE_FILE_INFORMATION {
    DWORD dwVolumeSerialNumber;
    DWORD nFileSizeLow;
    DWORD nNumberOfLinks;
    DWORD nFileIndexHigh;
    DWORD nFileIndexLow;
} BY_HANDLE_FILE_INFORMATION, *PBY_HANDLE_FILE_INFORMATION, *LPBY_HANDLE_FILE_INFORMATION;
BOOL
__stdcall
GetFileInformationByHandle(
     HANDLE hFile,
     LPBY_HANDLE_FILE_INFORMATION lpFileInformation
DWORD
__stdcall
GetFileSize(
     HANDLE hFile,
     LPDWORD lpFileSizeHigh
#pragma endregion
BOOL
__stdcall
GetFileSizeEx(
     HANDLE hFile,
     PLARGE_INTEGER lpFileSize
DWORD
__stdcall
GetFileType(
     HANDLE hFile
DWORD
__stdcall
GetFinalPathNameByHandleA(
     HANDLE hFile,
     LPSTR lpszFilePath,
     DWORD cchFilePath,
     DWORD dwFlags
DWORD
__stdcall
GetFinalPathNameByHandleW(
     HANDLE hFile,
     LPWSTR lpszFilePath,
     DWORD cchFilePath,
     DWORD dwFlags
BOOL
__stdcall
GetFileTime(
     HANDLE hFile,
     LPFILETIME lpCreationTime,
     LPFILETIME lpLastAccessTime,
     LPFILETIME lpLastWriteTime
DWORD
__stdcall
GetFullPathNameW(
     LPCWSTR lpFileName,
     LPWSTR lpBuffer,
     LPWSTR* lpFilePart
DWORD
__stdcall
GetFullPathNameA(
     LPCSTR lpFileName,
     LPSTR lpBuffer,
     LPSTR* lpFilePart
DWORD
__stdcall
GetLogicalDrives(
    void
#pragma endregion
DWORD
__stdcall
GetLogicalDriveStringsW(
     LPWSTR lpBuffer
DWORD
__stdcall
GetLongPathNameA(
     LPCSTR lpszShortPath,
     LPSTR lpszLongPath,
     DWORD cchBuffer
#pragma endregion
DWORD
__stdcall
GetLongPathNameW(
     LPCWSTR lpszShortPath,
     LPWSTR lpszLongPath,
     DWORD cchBuffer
#pragma endregion
DWORD
__stdcall
GetShortPathNameW(
     LPCWSTR lpszLongPath,
     LPWSTR lpszShortPath,
     DWORD cchBuffer
#pragma endregion
UINT
__stdcall
GetTempFileNameW(
     LPCWSTR lpPathName,
     LPCWSTR lpPrefixString,
     UINT uUnique,
     LPWSTR lpTempFileName
#pragma endregion
BOOL
__stdcall
GetVolumeInformationByHandleW(
     HANDLE hFile,
     LPWSTR lpVolumeNameBuffer,
     DWORD nVolumeNameSize,
     LPDWORD lpVolumeSerialNumber,
     LPDWORD lpMaximumComponentLength,
     LPDWORD lpFileSystemFlags,
     LPWSTR lpFileSystemNameBuffer,
     DWORD nFileSystemNameSize
#pragma endregion
BOOL
__stdcall
GetVolumeInformationW(
#pragma endregion
BOOL
__stdcall
GetVolumePathNameW(
     LPCWSTR lpszFileName,
     LPWSTR lpszVolumePathName,
#pragma endregion
BOOL
__stdcall
LocalFileTimeToFileTime(
     const FILETIME* lpLocalFileTime,
     LPFILETIME lpFileTime
BOOL
__stdcall
LockFile(
     HANDLE hFile,
     DWORD dwFileOffsetLow,
     DWORD dwFileOffsetHigh,
     DWORD nNumberOfBytesToLockLow,
     DWORD nNumberOfBytesToLockHigh
BOOL
__stdcall
LockFileEx(
     HANDLE hFile,
     DWORD dwFlags,
     DWORD dwReserved,
     DWORD nNumberOfBytesToLockHigh,
#pragma endregion
DWORD
__stdcall
QueryDosDeviceW(
     LPWSTR lpTargetPath,
     DWORD ucchMax
#pragma endregion
BOOL
__stdcall
ReadFile(
     HANDLE hFile,
      LPVOID lpBuffer,
     DWORD nNumberOfBytesToRead,
     LPDWORD lpNumberOfBytesRead,
BOOL
__stdcall
ReadFileEx(
     HANDLE hFile,
      LPVOID lpBuffer,
     LPOVERLAPPED lpOverlapped,
     LPOVERLAPPED_COMPLETION_ROUTINE lpCompletionRoutine
#pragma endregion
BOOL
__stdcall
ReadFileScatter(
     HANDLE hFile,
     FILE_SEGMENT_ELEMENT aSegmentArray[],
     LPDWORD lpReserved,
#pragma endregion
BOOL
__stdcall
RemoveDirectoryA(
     LPCSTR lpPathName
BOOL
__stdcall
RemoveDirectoryW(
     LPCWSTR lpPathName
BOOL
__stdcall
SetEndOfFile(
     HANDLE hFile
BOOL
__stdcall
SetFileAttributesA(
     LPCSTR lpFileName,
BOOL
__stdcall
SetFileAttributesW(
     LPCWSTR lpFileName,
BOOL
__stdcall
SetFileInformationByHandle(
     HANDLE hFile,
     FILE_INFO_BY_HANDLE_CLASS FileInformationClass,
     LPVOID lpFileInformation,
     DWORD dwBufferSize
DWORD
__stdcall
SetFilePointer(
     HANDLE hFile,
     LONG lDistanceToMove,
     PLONG lpDistanceToMoveHigh,
     DWORD dwMoveMethod
BOOL
__stdcall
SetFilePointerEx(
     HANDLE hFile,
     LARGE_INTEGER liDistanceToMove,
     PLARGE_INTEGER lpNewFilePointer,
     DWORD dwMoveMethod
BOOL
__stdcall
SetFileTime(
     HANDLE hFile,
     const FILETIME* lpCreationTime,
     const FILETIME* lpLastAccessTime,
     const FILETIME* lpLastWriteTime
#pragma endregion
BOOL
__stdcall
SetFileValidData(
     HANDLE hFile,
     LONGLONG ValidDataLength
#pragma endregion
BOOL
__stdcall
UnlockFile(
     HANDLE hFile,
     DWORD nNumberOfBytesToUnlockLow,
     DWORD nNumberOfBytesToUnlockHigh
BOOL
__stdcall
UnlockFileEx(
     HANDLE hFile,
     DWORD dwReserved,
     DWORD nNumberOfBytesToUnlockHigh,
BOOL
__stdcall
WriteFile(
     HANDLE hFile,
     LPCVOID lpBuffer,
     DWORD nNumberOfBytesToWrite,
     LPDWORD lpNumberOfBytesWritten,
BOOL
__stdcall
WriteFileEx(
     HANDLE hFile,
     LPCVOID lpBuffer,
#pragma endregion
BOOL
__stdcall
WriteFileGather(
     HANDLE hFile,
     LPDWORD lpReserved,
#pragma endregion
DWORD
__stdcall
GetTempPathW(
     LPWSTR lpBuffer
#pragma endregion
BOOL
__stdcall
GetVolumeNameForVolumeMountPointW(
     LPCWSTR lpszVolumeMountPoint,
BOOL
__stdcall
GetVolumePathNamesForVolumeNameW(
     LPCWSTR lpszVolumeName,
       LPWCH lpszVolumePathNames,
     DWORD cchBufferLength,
     PDWORD lpcchReturnLength
#pragma endregion
typedef struct _CREATEFILE2_EXTENDED_PARAMETERS {
    DWORD dwSize;
    DWORD dwFileFlags;
    DWORD dwSecurityQosFlags;
    LPSECURITY_ATTRIBUTES lpSecurityAttributes;
    HANDLE hTemplateFile;
} CREATEFILE2_EXTENDED_PARAMETERS, *PCREATEFILE2_EXTENDED_PARAMETERS, *LPCREATEFILE2_EXTENDED_PARAMETERS;
HANDLE
__stdcall
CreateFile2(
     LPCWSTR lpFileName,
     DWORD dwShareMode,
     LPCREATEFILE2_EXTENDED_PARAMETERS pCreateExParams
#pragma endregion
BOOL
__stdcall
SetFileIoOverlappedRange(
     HANDLE FileHandle,
     PUCHAR OverlappedRangeStart,
     ULONG Length
#pragma endregion
DWORD
__stdcall
GetCompressedFileSizeA(
     LPCSTR lpFileName,
DWORD
__stdcall
GetCompressedFileSizeW(
     LPCWSTR lpFileName,
#pragma endregion
typedef enum _STREAM_INFO_LEVELS {
    FindStreamInfoStandard,
    FindStreamInfoMaxInfoLevel
} STREAM_INFO_LEVELS;
typedef struct _WIN32_FIND_STREAM_DATA {
    LARGE_INTEGER StreamSize;
    WCHAR cStreamName[ 260 + 36 ];
} WIN32_FIND_STREAM_DATA, *PWIN32_FIND_STREAM_DATA;
HANDLE
__stdcall
FindFirstStreamW(
     LPCWSTR lpFileName,
     STREAM_INFO_LEVELS InfoLevel,
     LPVOID lpFindStreamData,
     DWORD dwFlags
BOOL
__stdcall
FindNextStreamW(
     HANDLE hFindStream,
BOOL
__stdcall
AreFileApisANSI(
    void
#pragma endregion
DWORD
__stdcall
GetTempPathA(
     LPSTR lpBuffer
#pragma endregion
HANDLE
__stdcall
FindFirstFileNameW(
     LPCWSTR lpFileName,
     DWORD dwFlags,
     LPDWORD StringLength,
     PWSTR LinkName
BOOL
__stdcall
FindNextFileNameW(
     HANDLE hFindStream,
     PWSTR LinkName
#pragma endregion
BOOL
__stdcall
GetVolumeInformationA(
     LPSTR lpVolumeNameBuffer,
     LPSTR lpFileSystemNameBuffer,
UINT
__stdcall
GetTempFileNameA(
     LPCSTR lpPathName,
     LPCSTR lpPrefixString,
     UINT uUnique,
     LPSTR lpTempFileName
#pragma endregion
void
__stdcall
SetFileApisToOEM(
    void
void
__stdcall
SetFileApisToANSI(
    void
#pragma endregion
#line 43 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\debugapi.h"
#pragma once
BOOL
__stdcall
IsDebuggerPresent(
    void
#pragma endregion
void
__stdcall
DebugBreak(
    void
void
__stdcall
OutputDebugStringA(
     LPCSTR lpOutputString
void
__stdcall
OutputDebugStringW(
     LPCWSTR lpOutputString
#pragma endregion
BOOL
__stdcall
ContinueDebugEvent(
     DWORD dwProcessId,
     DWORD dwThreadId,
     DWORD dwContinueStatus
BOOL
__stdcall
WaitForDebugEvent(
     LPDEBUG_EVENT lpDebugEvent,
     DWORD dwMilliseconds
BOOL
__stdcall
DebugActiveProcess(
     DWORD dwProcessId
BOOL
__stdcall
DebugActiveProcessStop(
     DWORD dwProcessId
BOOL
__stdcall
CheckRemoteDebuggerPresent(
     HANDLE hProcess,
     PBOOL pbDebuggerPresent
#pragma endregion
BOOL
__stdcall
WaitForDebugEventEx(
#pragma endregion
#line 44 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\utilapiset.h"
#pragma once
PVOID
__stdcall
EncodePointer(
     PVOID Ptr
PVOID
__stdcall
DecodePointer(
     PVOID Ptr
#pragma endregion
PVOID
__stdcall
EncodeSystemPointer(
     PVOID Ptr
PVOID
__stdcall
DecodeSystemPointer(
     PVOID Ptr
HRESULT
__stdcall
EncodeRemotePointer(
     HANDLE ProcessHandle,
     PVOID Ptr,
     PVOID* EncodedPtr
HRESULT
__stdcall
DecodeRemotePointer(
     PVOID Ptr,
     PVOID* DecodedPtr
#pragma endregion
BOOL
__stdcall
Beep(
     DWORD dwFreq,
     DWORD dwDuration
#pragma endregion
#line 45 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\handleapi.h"
#pragma once
BOOL
__stdcall
CloseHandle(
      HANDLE hObject
BOOL
__stdcall
DuplicateHandle(
     HANDLE hSourceProcessHandle,
     HANDLE hSourceHandle,
     HANDLE hTargetProcessHandle,
     LPHANDLE lpTargetHandle,
     BOOL bInheritHandle,
     DWORD dwOptions
BOOL
__stdcall
CompareObjectHandles(
     HANDLE hFirstObjectHandle,
     HANDLE hSecondObjectHandle
#pragma endregion
BOOL
__stdcall
GetHandleInformation(
     HANDLE hObject,
     LPDWORD lpdwFlags
BOOL
__stdcall
SetHandleInformation(
     HANDLE hObject,
     DWORD dwMask,
     DWORD dwFlags
#pragma endregion
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\errhandlingapi.h"
#pragma once
typedef LONG (__stdcall *PTOP_LEVEL_EXCEPTION_FILTER)(
typedef PTOP_LEVEL_EXCEPTION_FILTER LPTOP_LEVEL_EXCEPTION_FILTER;
__declspec(dllimport)
void
__stdcall
RaiseException(
     DWORD dwExceptionCode,
     DWORD dwExceptionFlags,
     DWORD nNumberOfArguments,
     const ULONG_PTR* lpArguments
#pragma endregion
#pragma region Desktop Family or OneCore Family
LONG
__stdcall
UnhandledExceptionFilter(
     struct _EXCEPTION_POINTERS* ExceptionInfo
#pragma endregion
__stdcall
SetUnhandledExceptionFilter(
     LPTOP_LEVEL_EXCEPTION_FILTER lpTopLevelExceptionFilter
DWORD
__stdcall
GetLastError(
    void
void
__stdcall
SetLastError(
     DWORD dwErrCode
#pragma endregion
UINT
__stdcall
GetErrorMode(
    void
#pragma endregion
UINT
__stdcall
SetErrorMode(
     UINT uMode
#pragma endregion
PVOID
__stdcall
AddVectoredExceptionHandler(
     ULONG First,
     PVECTORED_EXCEPTION_HANDLER Handler
ULONG
__stdcall
RemoveVectoredExceptionHandler(
     PVOID Handle
PVOID
__stdcall
AddVectoredContinueHandler(
     ULONG First,
ULONG
__stdcall
RemoveVectoredContinueHandler(
     PVOID Handle
#line 202 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\errhandlingapi.h"
#pragma endregion
void
__stdcall
RaiseFailFastException(
     PEXCEPTION_RECORD pExceptionRecord,
     PCONTEXT pContextRecord,
     DWORD dwFlags
#pragma endregion
void
__stdcall
FatalAppExitA(
     UINT uAction,
     LPCSTR lpMessageText
void
__stdcall
FatalAppExitW(
     UINT uAction,
     LPCWSTR lpMessageText
#pragma endregion
DWORD
__stdcall
GetThreadErrorMode(
    void
BOOL
__stdcall
SetThreadErrorMode(
     DWORD dwNewMode,
     LPDWORD lpOldMode
#pragma endregion
void
__stdcall
TerminateProcessOnMemoryExhaustion(
     SIZE_T FailedAllocationSize
#pragma endregion
#line 47 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\fibersapi.h"
#pragma once
DWORD
__stdcall
FlsAlloc(
     PFLS_CALLBACK_FUNCTION lpCallback
PVOID
__stdcall
FlsGetValue(
     DWORD dwFlsIndex
BOOL
__stdcall
FlsSetValue(
     DWORD dwFlsIndex,
     PVOID lpFlsData
BOOL
__stdcall
FlsFree(
     DWORD dwFlsIndex
#pragma endregion
BOOL
__stdcall
IsThreadAFiber(
    void
#pragma endregion
#line 48 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\namedpipeapi.h"
#pragma once
BOOL
__stdcall
CreatePipe(
     PHANDLE hReadPipe,
     PHANDLE hWritePipe,
     LPSECURITY_ATTRIBUTES lpPipeAttributes,
     DWORD nSize
BOOL
__stdcall
ConnectNamedPipe(
     HANDLE hNamedPipe,
BOOL
__stdcall
DisconnectNamedPipe(
     HANDLE hNamedPipe
BOOL
__stdcall
SetNamedPipeHandleState(
     HANDLE hNamedPipe,
     LPDWORD lpMode,
     LPDWORD lpMaxCollectionCount,
     LPDWORD lpCollectDataTimeout
BOOL
__stdcall
PeekNamedPipe(
     HANDLE hNamedPipe,
     LPVOID lpBuffer,
     DWORD nBufferSize,
     LPDWORD lpBytesRead,
     LPDWORD lpTotalBytesAvail,
     LPDWORD lpBytesLeftThisMessage
BOOL
__stdcall
TransactNamedPipe(
     HANDLE hNamedPipe,
     LPVOID lpInBuffer,
     DWORD nInBufferSize,
     LPVOID lpOutBuffer,
     DWORD nOutBufferSize,
HANDLE
__stdcall
CreateNamedPipeW(
     LPCWSTR lpName,
     DWORD dwOpenMode,
     DWORD dwPipeMode,
     DWORD nMaxInstances,
     DWORD nDefaultTimeOut,
BOOL
__stdcall
WaitNamedPipeW(
     LPCWSTR lpNamedPipeName,
     DWORD nTimeOut
BOOL
__stdcall
GetNamedPipeClientComputerNameW(
     HANDLE Pipe,
     LPWSTR ClientComputerName,
     ULONG ClientComputerNameLength
BOOL
__stdcall
ImpersonateNamedPipeClient(
     HANDLE hNamedPipe
BOOL
__stdcall
GetNamedPipeInfo(
     HANDLE hNamedPipe,
     LPDWORD lpFlags,
     LPDWORD lpOutBufferSize,
     LPDWORD lpInBufferSize,
     LPDWORD lpMaxInstances
BOOL
__stdcall
GetNamedPipeHandleStateW(
     HANDLE hNamedPipe,
     LPDWORD lpState,
     LPDWORD lpCurInstances,
     LPDWORD lpCollectDataTimeout,
     LPWSTR lpUserName,
     DWORD nMaxUserNameSize
#pragma endregion
BOOL
__stdcall
CallNamedPipeW(
     LPVOID lpInBuffer,
     LPVOID lpOutBuffer,
     DWORD nTimeOut
#pragma endregion
#line 49 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\profileapi.h"
#pragma once
BOOL
__stdcall
QueryPerformanceCounter(
     LARGE_INTEGER* lpPerformanceCount
BOOL
__stdcall
QueryPerformanceFrequency(
     LARGE_INTEGER* lpFrequency
#pragma endregion
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\heapapi.h"
#pragma once
typedef struct _HEAP_SUMMARY {
    DWORD cb;
    SIZE_T cbAllocated;
    SIZE_T cbCommitted;
    SIZE_T cbReserved;
    SIZE_T cbMaxReserve;
} HEAP_SUMMARY, *PHEAP_SUMMARY;
typedef PHEAP_SUMMARY LPHEAP_SUMMARY;
#pragma endregion
HANDLE
__stdcall
HeapCreate(
     DWORD flOptions,
     SIZE_T dwInitialSize,
     SIZE_T dwMaximumSize
BOOL
__stdcall
HeapDestroy(
     HANDLE hHeap
__declspec(allocator)
LPVOID
__stdcall
HeapAlloc(
     HANDLE hHeap,
     DWORD dwFlags,
     SIZE_T dwBytes
LPVOID
__stdcall
HeapReAlloc(
     HANDLE hHeap,
     DWORD dwFlags,
     LPVOID lpMem,
     SIZE_T dwBytes
BOOL
__stdcall
HeapFree(
     HANDLE hHeap,
     DWORD dwFlags,
      LPVOID lpMem
SIZE_T
__stdcall
HeapSize(
     HANDLE hHeap,
     DWORD dwFlags,
     LPCVOID lpMem
HANDLE
__stdcall
GetProcessHeap(
    void
SIZE_T
__stdcall
HeapCompact(
     HANDLE hHeap,
     DWORD dwFlags
BOOL
__stdcall
HeapSetInformation(
     HANDLE HeapHandle,
     HEAP_INFORMATION_CLASS HeapInformationClass,
     PVOID HeapInformation,
     SIZE_T HeapInformationLength
#pragma endregion
BOOL
__stdcall
HeapValidate(
     HANDLE hHeap,
     DWORD dwFlags,
     LPCVOID lpMem
#pragma endregion
BOOL
__stdcall
HeapSummary(
     HANDLE hHeap,
     DWORD dwFlags,
     LPHEAP_SUMMARY lpSummary
#pragma endregion
DWORD
__stdcall
GetProcessHeaps(
     DWORD NumberOfHeaps,
     PHANDLE ProcessHeaps
BOOL
__stdcall
HeapLock(
     HANDLE hHeap
BOOL
__stdcall
HeapUnlock(
     HANDLE hHeap
BOOL
__stdcall
HeapWalk(
     HANDLE hHeap,
     LPPROCESS_HEAP_ENTRY lpEntry
BOOL
__stdcall
HeapQueryInformation(
     HANDLE HeapHandle,
     SIZE_T HeapInformationLength,
     PSIZE_T ReturnLength
#pragma endregion
#line 51 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\ioapiset.h"
#pragma once
HANDLE
__stdcall
CreateIoCompletionPort(
     HANDLE FileHandle,
     HANDLE ExistingCompletionPort,
     ULONG_PTR CompletionKey,
     DWORD NumberOfConcurrentThreads
BOOL
__stdcall
GetQueuedCompletionStatus(
     HANDLE CompletionPort,
     LPDWORD lpNumberOfBytesTransferred,
     PULONG_PTR lpCompletionKey,
     LPOVERLAPPED* lpOverlapped,
BOOL
__stdcall
GetQueuedCompletionStatusEx(
     LPOVERLAPPED_ENTRY lpCompletionPortEntries,
     ULONG ulCount,
     PULONG ulNumEntriesRemoved,
     DWORD dwMilliseconds,
     BOOL fAlertable
BOOL
__stdcall
PostQueuedCompletionStatus(
     DWORD dwNumberOfBytesTransferred,
     ULONG_PTR dwCompletionKey,
#pragma endregion
BOOL
__stdcall
DeviceIoControl(
     HANDLE hDevice,
     DWORD dwIoControlCode,
     LPVOID lpInBuffer,
     LPVOID lpOutBuffer,
     LPDWORD lpBytesReturned,
#pragma endregion
BOOL
__stdcall
GetOverlappedResult(
     HANDLE hFile,
     BOOL bWait
BOOL
__stdcall
CancelIoEx(
     HANDLE hFile,
#pragma endregion
BOOL
__stdcall
CancelIo(
     HANDLE hFile
BOOL
__stdcall
GetOverlappedResultEx(
     HANDLE hFile,
     BOOL bAlertable
#pragma endregion
BOOL
__stdcall
CancelSynchronousIo(
     HANDLE hThread
#pragma endregion
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\synchapi.h"
#pragma once
#pragma region Application or OneCore Family
typedef RTL_SRWLOCK SRWLOCK, *PSRWLOCK;
#pragma endregion
void
__stdcall
InitializeSRWLock(
     PSRWLOCK SRWLock
void
__stdcall
ReleaseSRWLockExclusive(
     PSRWLOCK SRWLock
void
__stdcall
ReleaseSRWLockShared(
     PSRWLOCK SRWLock
void
__stdcall
AcquireSRWLockExclusive(
     PSRWLOCK SRWLock
void
__stdcall
AcquireSRWLockShared(
     PSRWLOCK SRWLock
BOOLEAN
__stdcall
TryAcquireSRWLockExclusive(
     PSRWLOCK SRWLock
BOOLEAN
__stdcall
TryAcquireSRWLockShared(
     PSRWLOCK SRWLock
#line 119 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\synchapi.h"
void
__stdcall
InitializeCriticalSection(
     LPCRITICAL_SECTION lpCriticalSection
void
__stdcall
EnterCriticalSection(
void
__stdcall
LeaveCriticalSection(
BOOL
__stdcall
InitializeCriticalSectionAndSpinCount(
     LPCRITICAL_SECTION lpCriticalSection,
     DWORD dwSpinCount
BOOL
__stdcall
InitializeCriticalSectionEx(
     DWORD dwSpinCount,
     DWORD Flags
DWORD
__stdcall
SetCriticalSectionSpinCount(
     DWORD dwSpinCount
BOOL
__stdcall
TryEnterCriticalSection(
void
__stdcall
DeleteCriticalSection(
typedef RTL_RUN_ONCE INIT_ONCE;
typedef PRTL_RUN_ONCE PINIT_ONCE;
typedef PRTL_RUN_ONCE LPINIT_ONCE;
typedef
BOOL
(__stdcall *PINIT_ONCE_FN) (
     PINIT_ONCE InitOnce,
     PVOID Parameter,
     PVOID *Context
void
__stdcall
InitOnceInitialize(
     PINIT_ONCE InitOnce
BOOL
__stdcall
InitOnceExecuteOnce(
      PINIT_ONCE_FN InitFn,
     PVOID Parameter,
     LPVOID* Context
BOOL
__stdcall
InitOnceBeginInitialize(
     LPINIT_ONCE lpInitOnce,
     DWORD dwFlags,
     PBOOL fPending,
     LPVOID* lpContext
BOOL
__stdcall
InitOnceComplete(
     DWORD dwFlags,
     LPVOID lpContext
typedef RTL_CONDITION_VARIABLE CONDITION_VARIABLE, *PCONDITION_VARIABLE;
void
__stdcall
InitializeConditionVariable(
     PCONDITION_VARIABLE ConditionVariable
void
__stdcall
WakeConditionVariable(
void
__stdcall
WakeAllConditionVariable(
BOOL
__stdcall
SleepConditionVariableCS(
     PCONDITION_VARIABLE ConditionVariable,
     PCRITICAL_SECTION CriticalSection,
BOOL
__stdcall
SleepConditionVariableSRW(
     PSRWLOCK SRWLock,
     ULONG Flags
BOOL
__stdcall
SetEvent(
     HANDLE hEvent
BOOL
__stdcall
ResetEvent(
     HANDLE hEvent
BOOL
__stdcall
ReleaseSemaphore(
     HANDLE hSemaphore,
     LONG lReleaseCount,
     LPLONG lpPreviousCount
BOOL
__stdcall
ReleaseMutex(
     HANDLE hMutex
DWORD
__stdcall
WaitForSingleObject(
     HANDLE hHandle,
DWORD
__stdcall
SleepEx(
     BOOL bAlertable
DWORD
__stdcall
WaitForSingleObjectEx(
     HANDLE hHandle,
     BOOL bAlertable
DWORD
__stdcall
WaitForMultipleObjectsEx(
     DWORD nCount,
     const HANDLE* lpHandles,
     BOOL bWaitAll,
     BOOL bAlertable
HANDLE
__stdcall
CreateMutexA(
     LPSECURITY_ATTRIBUTES lpMutexAttributes,
     BOOL bInitialOwner,
     LPCSTR lpName
HANDLE
__stdcall
CreateMutexW(
     BOOL bInitialOwner,
     LPCWSTR lpName
HANDLE
__stdcall
OpenMutexW(
     LPCWSTR lpName
HANDLE
__stdcall
CreateEventA(
     LPSECURITY_ATTRIBUTES lpEventAttributes,
     BOOL bManualReset,
     BOOL bInitialState,
     LPCSTR lpName
HANDLE
__stdcall
CreateEventW(
     BOOL bManualReset,
     BOOL bInitialState,
     LPCWSTR lpName
HANDLE
__stdcall
OpenEventA(
     LPCSTR lpName
HANDLE
__stdcall
OpenEventW(
     LPCWSTR lpName
HANDLE
__stdcall
OpenSemaphoreW(
     LPCWSTR lpName
typedef
void
(__stdcall *PTIMERAPCROUTINE)(
     LPVOID lpArgToCompletionRoutine,
         DWORD dwTimerLowValue,
         DWORD dwTimerHighValue
HANDLE
__stdcall
OpenWaitableTimerW(
     LPCWSTR lpTimerName
BOOL
__stdcall
SetWaitableTimerEx(
     HANDLE hTimer,
     const LARGE_INTEGER* lpDueTime,
     LONG lPeriod,
     PTIMERAPCROUTINE pfnCompletionRoutine,
     PREASON_CONTEXT WakeContext,
     ULONG TolerableDelay
BOOL
__stdcall
SetWaitableTimer(
     HANDLE hTimer,
     LONG lPeriod,
     BOOL fResume
BOOL
__stdcall
CancelWaitableTimer(
     HANDLE hTimer
HANDLE
__stdcall
CreateMutexExA(
     LPCSTR lpName,
     DWORD dwFlags,
HANDLE
__stdcall
CreateMutexExW(
     LPCWSTR lpName,
     DWORD dwFlags,
HANDLE
__stdcall
CreateEventExA(
     LPCSTR lpName,
     DWORD dwFlags,
HANDLE
__stdcall
CreateEventExW(
     LPCWSTR lpName,
     DWORD dwFlags,
HANDLE
__stdcall
CreateSemaphoreExW(
     LPSECURITY_ATTRIBUTES lpSemaphoreAttributes,
     LONG lInitialCount,
     LONG lMaximumCount,
     LPCWSTR lpName,
     DWORD dwFlags,
HANDLE
__stdcall
CreateWaitableTimerExW(
     LPSECURITY_ATTRIBUTES lpTimerAttributes,
     LPCWSTR lpTimerName,
     DWORD dwFlags,
#pragma endregion
#pragma region Desktop or OneCore Family
typedef RTL_BARRIER SYNCHRONIZATION_BARRIER;
typedef PRTL_BARRIER PSYNCHRONIZATION_BARRIER;
typedef PRTL_BARRIER LPSYNCHRONIZATION_BARRIER;
BOOL
__stdcall
EnterSynchronizationBarrier(
     LPSYNCHRONIZATION_BARRIER lpBarrier,
     DWORD dwFlags
BOOL
__stdcall
InitializeSynchronizationBarrier(
     LONG lTotalThreads,
     LONG lSpinCount
BOOL
__stdcall
DeleteSynchronizationBarrier(
#pragma endregion
void
__stdcall
Sleep(
BOOL
__stdcall
WaitOnAddress(
     volatile void* Address,
     PVOID CompareAddress,
     SIZE_T AddressSize,
void
__stdcall
WakeByAddressSingle(
     PVOID Address
void
__stdcall
WakeByAddressAll(
     PVOID Address
#pragma endregion
DWORD
__stdcall
SignalObjectAndWait(
     HANDLE hObjectToSignal,
     HANDLE hObjectToWaitOn,
     BOOL bAlertable
#pragma endregion
DWORD
__stdcall
WaitForMultipleObjects(
     DWORD nCount,
     BOOL bWaitAll,
HANDLE
__stdcall
CreateSemaphoreW(
     LONG lInitialCount,
     LONG lMaximumCount,
     LPCWSTR lpName
HANDLE
__stdcall
CreateWaitableTimerW(
     BOOL bManualReset,
     LPCWSTR lpTimerName
#pragma endregion
#line 53 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\interlockedapi.h"
#pragma once
void
__stdcall
InitializeSListHead(
     PSLIST_HEADER ListHead
PSLIST_ENTRY
__stdcall
InterlockedPopEntrySList(
PSLIST_ENTRY
__stdcall
InterlockedPushEntrySList(
     PSLIST_HEADER ListHead,
      PSLIST_ENTRY ListEntry
PSLIST_ENTRY
__stdcall
InterlockedPushListSListEx(
     PSLIST_ENTRY List,
     PSLIST_ENTRY ListEnd,
     ULONG Count
PSLIST_ENTRY
__stdcall
InterlockedFlushSList(
USHORT
__stdcall
QueryDepthSList(
#pragma endregion
#line 54 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\processthreadsapi.h"
#pragma once
typedef struct _PROCESS_INFORMATION {
    HANDLE hProcess;
    HANDLE hThread;
    DWORD dwProcessId;
    DWORD dwThreadId;
} PROCESS_INFORMATION, *PPROCESS_INFORMATION, *LPPROCESS_INFORMATION;
typedef struct _STARTUPINFOA {
    DWORD   cb;
    LPSTR   lpReserved;
    LPSTR   lpDesktop;
    LPSTR   lpTitle;
    DWORD   dwX;
    DWORD   dwY;
    DWORD   dwXSize;
    DWORD   dwYSize;
    DWORD   dwXCountChars;
    DWORD   dwYCountChars;
    DWORD   dwFillAttribute;
    DWORD   dwFlags;
    WORD    wShowWindow;
    WORD    cbReserved2;
    LPBYTE  lpReserved2;
    HANDLE  hStdInput;
    HANDLE  hStdOutput;
    HANDLE  hStdError;
} STARTUPINFOA, *LPSTARTUPINFOA;
typedef struct _STARTUPINFOW {
    DWORD   cb;
    LPWSTR  lpReserved;
    LPWSTR  lpDesktop;
    LPWSTR  lpTitle;
    DWORD   dwX;
    DWORD   dwY;
    DWORD   dwXSize;
    DWORD   dwYSize;
    DWORD   dwFlags;
    WORD    wShowWindow;
    WORD    cbReserved2;
    LPBYTE  lpReserved2;
    HANDLE  hStdInput;
    HANDLE  hStdOutput;
    HANDLE  hStdError;
} STARTUPINFOW, *LPSTARTUPINFOW;
typedef STARTUPINFOA STARTUPINFO;
typedef LPSTARTUPINFOA LPSTARTUPINFO;
#pragma endregion
DWORD
__stdcall
QueueUserAPC(
     PAPCFUNC pfnAPC,
     HANDLE hThread,
     ULONG_PTR dwData
BOOL
__stdcall
GetProcessTimes(
     HANDLE hProcess,
     LPFILETIME lpExitTime,
     LPFILETIME lpKernelTime,
     LPFILETIME lpUserTime
HANDLE
__stdcall
GetCurrentProcess(
    void
DWORD
__stdcall
GetCurrentProcessId(
    void
#pragma endregion
__declspec(noreturn)
void
__stdcall
ExitProcess(
     UINT uExitCode
#pragma endregion
BOOL
__stdcall
TerminateProcess(
     HANDLE hProcess,
     UINT uExitCode
BOOL
__stdcall
GetExitCodeProcess(
     HANDLE hProcess,
     LPDWORD lpExitCode
BOOL
__stdcall
SwitchToThread(
    void
HANDLE
__stdcall
CreateThread(
     LPSECURITY_ATTRIBUTES lpThreadAttributes,
     SIZE_T dwStackSize,
     LPTHREAD_START_ROUTINE lpStartAddress,
      LPVOID lpParameter,
     DWORD dwCreationFlags,
     LPDWORD lpThreadId
#pragma endregion
HANDLE
__stdcall
CreateRemoteThread(
     HANDLE hProcess,
     SIZE_T dwStackSize,
     LPVOID lpParameter,
     LPDWORD lpThreadId
#pragma endregion
HANDLE
__stdcall
GetCurrentThread(
    void
DWORD
__stdcall
GetCurrentThreadId(
    void
HANDLE
__stdcall
OpenThread(
     DWORD dwThreadId
BOOL
__stdcall
SetThreadPriority(
     HANDLE hThread,
     int nPriority
BOOL
__stdcall
SetThreadPriorityBoost(
     HANDLE hThread,
     BOOL bDisablePriorityBoost
BOOL
__stdcall
GetThreadPriorityBoost(
     HANDLE hThread,
     PBOOL pDisablePriorityBoost
int
__stdcall
GetThreadPriority(
     HANDLE hThread
void
__stdcall
ExitThread(
     DWORD dwExitCode
#pragma endregion
BOOL
__stdcall
TerminateThread(
     HANDLE hThread,
     DWORD dwExitCode
#pragma endregion
BOOL
__stdcall
GetExitCodeThread(
     HANDLE hThread,
     LPDWORD lpExitCode
DWORD
__stdcall
SuspendThread(
     HANDLE hThread
DWORD
__stdcall
ResumeThread(
     HANDLE hThread
DWORD
__stdcall
TlsAlloc(
    void
LPVOID
__stdcall
TlsGetValue(
     DWORD dwTlsIndex
BOOL
__stdcall
TlsSetValue(
     DWORD dwTlsIndex,
     LPVOID lpTlsValue
BOOL
__stdcall
TlsFree(
     DWORD dwTlsIndex
BOOL
__stdcall
CreateProcessA(
     LPCSTR lpApplicationName,
     LPSTR lpCommandLine,
     LPSECURITY_ATTRIBUTES lpProcessAttributes,
     BOOL bInheritHandles,
     LPVOID lpEnvironment,
     LPCSTR lpCurrentDirectory,
     LPSTARTUPINFOA lpStartupInfo,
     LPPROCESS_INFORMATION lpProcessInformation
BOOL
__stdcall
CreateProcessW(
     LPCWSTR lpApplicationName,
     LPWSTR lpCommandLine,
     LPCWSTR lpCurrentDirectory,
     LPSTARTUPINFOW lpStartupInfo,
#pragma endregion
BOOL
__stdcall
SetProcessShutdownParameters(
     DWORD dwLevel,
     DWORD dwFlags
DWORD
__stdcall
GetProcessVersion(
     DWORD ProcessId
void
__stdcall
GetStartupInfoW(
BOOL
__stdcall
CreateProcessAsUserW(
     HANDLE hToken,
__forceinline
HANDLE
GetCurrentProcessToken (
    void
    return (HANDLE)(LONG_PTR) -4;
__forceinline
HANDLE
GetCurrentThreadToken (
    void
    return (HANDLE)(LONG_PTR) -5;
__forceinline
HANDLE
GetCurrentThreadEffectiveToken (
    void
    return (HANDLE)(LONG_PTR) -6;
#pragma endregion
BOOL
__stdcall
SetThreadToken(
     PHANDLE Thread,
     HANDLE Token
BOOL
__stdcall
OpenProcessToken(
     DWORD DesiredAccess,
     PHANDLE TokenHandle
BOOL
__stdcall
OpenThreadToken(
     HANDLE ThreadHandle,
     BOOL OpenAsSelf,
     PHANDLE TokenHandle
BOOL
__stdcall
SetPriorityClass(
     HANDLE hProcess,
     DWORD dwPriorityClass
DWORD
__stdcall
GetPriorityClass(
     HANDLE hProcess
#pragma endregion
BOOL
__stdcall
SetThreadStackGuarantee(
     PULONG StackSizeInBytes
BOOL
__stdcall
ProcessIdToSessionId(
     DWORD dwProcessId,
     DWORD* pSessionId
typedef struct _PROC_THREAD_ATTRIBUTE_LIST *PPROC_THREAD_ATTRIBUTE_LIST, *LPPROC_THREAD_ATTRIBUTE_LIST;
#pragma endregion
DWORD
__stdcall
GetProcessId(
     HANDLE Process
DWORD
__stdcall
GetThreadId(
     HANDLE Thread
void
__stdcall
FlushProcessWriteBuffers(
    void
#pragma endregion
DWORD
__stdcall
GetProcessIdOfThread(
     HANDLE Thread
BOOL
__stdcall
InitializeProcThreadAttributeList(
     LPPROC_THREAD_ATTRIBUTE_LIST lpAttributeList,
     DWORD dwAttributeCount,
     DWORD dwFlags,
      PSIZE_T lpSize
void
__stdcall
DeleteProcThreadAttributeList(
BOOL
__stdcall
SetProcessAffinityUpdateMode(
     HANDLE hProcess,
     DWORD dwFlags
BOOL
__stdcall
QueryProcessAffinityUpdateMode(
     HANDLE hProcess,
     LPDWORD lpdwFlags
BOOL
__stdcall
UpdateProcThreadAttribute(
     DWORD dwFlags,
     DWORD_PTR Attribute,
     PVOID lpValue,
     SIZE_T cbSize,
     PVOID lpPreviousValue,
     PSIZE_T lpReturnSize
#pragma endregion
HANDLE
__stdcall
CreateRemoteThreadEx(
     HANDLE hProcess,
     SIZE_T dwStackSize,
     LPVOID lpParameter,
     LPDWORD lpThreadId
#pragma endregion
void
__stdcall
GetCurrentThreadStackLimits(
     PULONG_PTR LowLimit,
     PULONG_PTR HighLimit
BOOL
__stdcall
GetThreadContext(
     HANDLE hThread,
     LPCONTEXT lpContext
BOOL
__stdcall
GetProcessMitigationPolicy(
     HANDLE hProcess,
     PROCESS_MITIGATION_POLICY MitigationPolicy,
     PVOID lpBuffer,
     SIZE_T dwLength
#pragma endregion
BOOL
__stdcall
SetThreadContext(
     HANDLE hThread,
     const CONTEXT* lpContext
BOOL
__stdcall
SetProcessMitigationPolicy(
     PVOID lpBuffer,
     SIZE_T dwLength
#pragma endregion
BOOL
__stdcall
FlushInstructionCache(
     HANDLE hProcess,
     LPCVOID lpBaseAddress,
     SIZE_T dwSize
BOOL
__stdcall
GetThreadTimes(
     HANDLE hThread,
HANDLE
__stdcall
OpenProcess(
     DWORD dwProcessId
BOOL
__stdcall
IsProcessorFeaturePresent(
     DWORD ProcessorFeature
#pragma endregion
BOOL
__stdcall
GetProcessHandleCount(
     HANDLE hProcess,
     PDWORD pdwHandleCount
#pragma endregion
DWORD
__stdcall
GetCurrentProcessorNumber(
    void
#pragma endregion
BOOL
__stdcall
SetThreadIdealProcessorEx(
     HANDLE hThread,
     PPROCESSOR_NUMBER lpIdealProcessor,
     PPROCESSOR_NUMBER lpPreviousIdealProcessor
BOOL
__stdcall
GetThreadIdealProcessorEx(
     HANDLE hThread,
void
__stdcall
GetCurrentProcessorNumberEx(
     PPROCESSOR_NUMBER ProcNumber
#pragma endregion
BOOL
__stdcall
GetProcessPriorityBoost(
     HANDLE hProcess,
BOOL
__stdcall
SetProcessPriorityBoost(
     HANDLE hProcess,
#pragma endregion
BOOL
__stdcall
GetThreadIOPendingFlag(
     HANDLE hThread,
     PBOOL lpIOIsPending
BOOL
__stdcall
GetSystemTimes(
     PFILETIME lpIdleTime,
#pragma endregion
typedef enum _THREAD_INFORMATION_CLASS {
    ThreadMemoryPriority,
    ThreadAbsoluteCpuPriority,
    ThreadDynamicCodePolicy,
    ThreadPowerThrottling,
    ThreadInformationClassMax
} THREAD_INFORMATION_CLASS;
typedef struct _MEMORY_PRIORITY_INFORMATION {
    ULONG MemoryPriority;
} MEMORY_PRIORITY_INFORMATION, *PMEMORY_PRIORITY_INFORMATION;
BOOL
__stdcall
GetThreadInformation(
     HANDLE hThread,
     THREAD_INFORMATION_CLASS ThreadInformationClass,
     LPVOID ThreadInformation,
     DWORD ThreadInformationSize
BOOL
__stdcall
SetThreadInformation(
     HANDLE hThread,
typedef struct _THREAD_POWER_THROTTLING_STATE {
    ULONG Version;
    ULONG ControlMask;
    ULONG StateMask;
} THREAD_POWER_THROTTLING_STATE;
#pragma endregion
BOOL
__stdcall
IsProcessCritical(
     HANDLE hProcess,
     PBOOL Critical
BOOL
__stdcall
SetProtectedPolicy(
     LPCGUID PolicyGuid,
     ULONG_PTR PolicyValue,
     PULONG_PTR OldPolicyValue
BOOL
__stdcall
QueryProtectedPolicy(
     LPCGUID PolicyGuid,
     PULONG_PTR PolicyValue
#pragma endregion
DWORD
__stdcall
SetThreadIdealProcessor(
     HANDLE hThread,
     DWORD dwIdealProcessor
#pragma endregion
typedef enum _PROCESS_INFORMATION_CLASS {
    ProcessMemoryPriority,
    ProcessMemoryExhaustionInfo,
    ProcessAppMemoryInfo,
    ProcessInPrivateInfo,
    ProcessPowerThrottling,
    ProcessReservedValue1,
    ProcessTelemetryCoverageInfo,
    ProcessProtectionLevelInfo,
    ProcessInformationClassMax
} PROCESS_INFORMATION_CLASS;
typedef struct _APP_MEMORY_INFORMATION {
    ULONG64 AvailableCommit;
    ULONG64 PrivateCommitUsage;
    ULONG64 PeakPrivateCommitUsage;
    ULONG64 TotalCommitUsage;
} APP_MEMORY_INFORMATION, *PAPP_MEMORY_INFORMATION;
typedef enum _PROCESS_MEMORY_EXHAUSTION_TYPE {
    PMETypeFailFastOnCommitFailure,
    PMETypeMax
} PROCESS_MEMORY_EXHAUSTION_TYPE, *PPROCESS_MEMORY_EXHAUSTION_TYPE;
typedef struct _PROCESS_MEMORY_EXHAUSTION_INFO {
    USHORT Version;
    USHORT Reserved;
    PROCESS_MEMORY_EXHAUSTION_TYPE Type;
    ULONG_PTR Value;
} PROCESS_MEMORY_EXHAUSTION_INFO, *PPROCESS_MEMORY_EXHAUSTION_INFO;
typedef struct _PROCESS_POWER_THROTTLING_STATE {
    ULONG Version;
    ULONG ControlMask;
    ULONG StateMask;
} PROCESS_POWER_THROTTLING_STATE, *PPROCESS_POWER_THROTTLING_STATE;
typedef struct PROCESS_PROTECTION_LEVEL_INFORMATION {
    DWORD ProtectionLevel;
} PROCESS_PROTECTION_LEVEL_INFORMATION;
BOOL
__stdcall
SetProcessInformation(
     HANDLE hProcess,
     PROCESS_INFORMATION_CLASS ProcessInformationClass,
     LPVOID ProcessInformation,
     DWORD ProcessInformationSize
BOOL
__stdcall
GetProcessInformation(
     HANDLE hProcess,
BOOL
__stdcall
GetSystemCpuSetInformation(
     PSYSTEM_CPU_SET_INFORMATION Information,
     ULONG BufferLength,
     PULONG ReturnedLength,
     HANDLE Process,
     ULONG Flags
BOOL
__stdcall
GetProcessDefaultCpuSets(
     HANDLE Process,
     PULONG CpuSetIds,
     ULONG CpuSetIdCount,
     PULONG RequiredIdCount
BOOL
__stdcall
SetProcessDefaultCpuSets(
     HANDLE Process,
     const ULONG* CpuSetIds,
     ULONG CpuSetIdCount
BOOL
__stdcall
GetThreadSelectedCpuSets(
     HANDLE Thread,
     PULONG CpuSetIds,
BOOL
__stdcall
SetThreadSelectedCpuSets(
     HANDLE Thread,
     ULONG CpuSetIdCount
#pragma endregion
BOOL
__stdcall
CreateProcessAsUserA(
     HANDLE hToken,
BOOL
__stdcall
GetProcessShutdownParameters(
     LPDWORD lpdwLevel,
     LPDWORD lpdwFlags
#pragma endregion
HRESULT
__stdcall
SetThreadDescription(
     HANDLE hThread,
     PCWSTR lpThreadDescription
HRESULT
__stdcall
GetThreadDescription(
     HANDLE hThread,
     PWSTR* ppszThreadDescription
#line 55 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\sysinfoapi.h"
#pragma once
typedef struct _SYSTEM_INFO {
    union {
        DWORD dwOemId;
        struct {
            WORD wProcessorArchitecture;
            WORD wReserved;
    DWORD dwPageSize;
    LPVOID lpMinimumApplicationAddress;
    LPVOID lpMaximumApplicationAddress;
    DWORD_PTR dwActiveProcessorMask;
    DWORD dwNumberOfProcessors;
    DWORD dwProcessorType;
    DWORD dwAllocationGranularity;
    WORD wProcessorLevel;
    WORD wProcessorRevision;
} SYSTEM_INFO, *LPSYSTEM_INFO;
#pragma endregion
typedef struct _MEMORYSTATUSEX {
    DWORD dwLength;
    DWORD dwMemoryLoad;
    DWORDLONG ullTotalPhys;
    DWORDLONG ullAvailPhys;
    DWORDLONG ullTotalPageFile;
    DWORDLONG ullAvailPageFile;
    DWORDLONG ullTotalVirtual;
    DWORDLONG ullAvailVirtual;
    DWORDLONG ullAvailExtendedVirtual;
} MEMORYSTATUSEX, *LPMEMORYSTATUSEX;
BOOL
__stdcall
GlobalMemoryStatusEx(
     LPMEMORYSTATUSEX lpBuffer
void
__stdcall
GetSystemInfo(
     LPSYSTEM_INFO lpSystemInfo
void
__stdcall
GetSystemTime(
     LPSYSTEMTIME lpSystemTime
void
__stdcall
GetSystemTimeAsFileTime(
     LPFILETIME lpSystemTimeAsFileTime
void
__stdcall
GetLocalTime(
#pragma endregion
__declspec(deprecated)
DWORD
__stdcall
GetVersion(
    void
BOOL
__stdcall
SetLocalTime(
     const SYSTEMTIME* lpSystemTime
#pragma endregion
DWORD
__stdcall
GetTickCount(
    void
ULONGLONG
__stdcall
GetTickCount64(
    void
#pragma endregion
BOOL
__stdcall
GetSystemTimeAdjustment(
     PDWORD lpTimeAdjustment,
     PDWORD lpTimeIncrement,
     PBOOL lpTimeAdjustmentDisabled
BOOL
__stdcall
GetSystemTimeAdjustmentPrecise(
     PDWORD64 lpTimeAdjustment,
     PDWORD64 lpTimeIncrement,
#pragma endregion
UINT
__stdcall
GetSystemDirectoryA(
     LPSTR lpBuffer,
     UINT uSize
UINT
__stdcall
GetSystemDirectoryW(
     LPWSTR lpBuffer,
     UINT uSize
#pragma endregion
UINT
__stdcall
GetWindowsDirectoryA(
     LPSTR lpBuffer,
     UINT uSize
UINT
__stdcall
GetWindowsDirectoryW(
     LPWSTR lpBuffer,
     UINT uSize
UINT
__stdcall
GetSystemWindowsDirectoryA(
     LPSTR lpBuffer,
     UINT uSize
UINT
__stdcall
GetSystemWindowsDirectoryW(
     LPWSTR lpBuffer,
     UINT uSize
#pragma endregion
typedef enum _COMPUTER_NAME_FORMAT {
    ComputerNameNetBIOS,
    ComputerNameDnsHostname,
    ComputerNameDnsDomain,
    ComputerNameDnsFullyQualified,
    ComputerNamePhysicalNetBIOS,
    ComputerNamePhysicalDnsHostname,
    ComputerNamePhysicalDnsDomain,
    ComputerNamePhysicalDnsFullyQualified,
    ComputerNameMax
} COMPUTER_NAME_FORMAT ;
#pragma endregion
BOOL
__stdcall
GetComputerNameExA(
     COMPUTER_NAME_FORMAT NameType,
     LPSTR lpBuffer,
     LPDWORD nSize
BOOL
__stdcall
GetComputerNameExW(
     LPWSTR lpBuffer,
     LPDWORD nSize
#pragma endregion
BOOL
__stdcall
SetComputerNameExW(
     LPCWSTR lpBuffer
BOOL
__stdcall
SetSystemTime(
#pragma endregion
BOOL
__stdcall
GetVersionExA(
     LPOSVERSIONINFOA lpVersionInformation
BOOL
__stdcall
GetVersionExW(
     LPOSVERSIONINFOW lpVersionInformation
BOOL
__stdcall
GetLogicalProcessorInformation(
     PSYSTEM_LOGICAL_PROCESSOR_INFORMATION Buffer,
     PDWORD ReturnedLength
BOOL
__stdcall
GetLogicalProcessorInformationEx(
     LOGICAL_PROCESSOR_RELATIONSHIP RelationshipType,
     PSYSTEM_LOGICAL_PROCESSOR_INFORMATION_EX Buffer,
#pragma endregion
void
__stdcall
GetNativeSystemInfo(
void
__stdcall
GetSystemTimePreciseAsFileTime(
#pragma endregion
BOOL
__stdcall
GetProductInfo(
     DWORD dwOSMajorVersion,
     DWORD dwOSMinorVersion,
     DWORD dwSpMajorVersion,
     DWORD dwSpMinorVersion,
     PDWORD pdwReturnedProductType
ULONGLONG
__stdcall
VerSetConditionMask(
     ULONGLONG ConditionMask,
     ULONG TypeMask,
     UCHAR Condition
BOOL
__stdcall
GetOsSafeBootMode(
     PDWORD Flags
#pragma endregion
#pragma region OneCore Family or App Family
UINT
__stdcall
EnumSystemFirmwareTables(
     DWORD FirmwareTableProviderSignature,
     PVOID pFirmwareTableEnumBuffer,
     DWORD BufferSize
UINT
__stdcall
GetSystemFirmwareTable(
     DWORD FirmwareTableID,
     PVOID pFirmwareTableBuffer,
     DWORD BufferSize
#pragma endregion
BOOL
__stdcall
DnsHostnameToComputerNameExW(
     LPCWSTR Hostname,
     LPWSTR ComputerName,
     LPDWORD nSize
BOOL
__stdcall
GetPhysicallyInstalledSystemMemory(
     PULONGLONG TotalMemoryInKilobytes
BOOL
__stdcall
SetComputerNameEx2W(
     DWORD Flags,
     LPCWSTR lpBuffer
BOOL
__stdcall
SetSystemTimeAdjustment(
     DWORD dwTimeAdjustment,
     BOOL bTimeAdjustmentDisabled
BOOL
__stdcall
SetSystemTimeAdjustmentPrecise(
     DWORD64 dwTimeAdjustment,
BOOL
__stdcall
InstallELAMCertificateInfo(
     HANDLE ELAMFile
#pragma endregion
BOOL
__stdcall
GetProcessorSystemCycleTime(
     USHORT Group,
     PSYSTEM_PROCESSOR_CYCLE_TIME_INFORMATION Buffer,
BOOL
__stdcall
GetOsManufacturingMode(
     PBOOL pbEnabled
#pragma endregion
#pragma region App Family or OneCore Family
HRESULT
__stdcall
GetIntegratedDisplaySize(
     double* sizeInInches
#pragma endregion
BOOL
__stdcall
SetComputerNameA(
     LPCSTR lpComputerName
BOOL
__stdcall
SetComputerNameW(
     LPCWSTR lpComputerName
BOOL
__stdcall
SetComputerNameExA(
     LPCSTR lpBuffer
#pragma endregion
#line 700 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\sysinfoapi.h"
#line 56 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\memoryapi.h"
#pragma once
#pragma endregion
LPVOID
__stdcall
VirtualAlloc(
     LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD flAllocationType,
     DWORD flProtect
BOOL
__stdcall
VirtualProtect(
     LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD flNewProtect,
     PDWORD lpflOldProtect
#pragma endregion
BOOL
__stdcall
VirtualFree(
       LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD dwFreeType
SIZE_T
__stdcall
VirtualQuery(
     LPCVOID lpAddress,
     PMEMORY_BASIC_INFORMATION lpBuffer,
     SIZE_T dwLength
#pragma endregion
LPVOID
__stdcall
VirtualAllocEx(
     HANDLE hProcess,
     LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD flProtect
BOOL
__stdcall
VirtualProtectEx(
     HANDLE hProcess,
     LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD flNewProtect,
SIZE_T
__stdcall
VirtualQueryEx(
     HANDLE hProcess,
     LPCVOID lpAddress,
     SIZE_T dwLength
BOOL
__stdcall
ReadProcessMemory(
     HANDLE hProcess,
     LPVOID lpBuffer,
     SIZE_T nSize,
     SIZE_T* lpNumberOfBytesRead
BOOL
__stdcall
WriteProcessMemory(
     HANDLE hProcess,
     LPVOID lpBaseAddress,
     LPCVOID lpBuffer,
     SIZE_T nSize,
     SIZE_T* lpNumberOfBytesWritten
HANDLE
__stdcall
CreateFileMappingW(
     HANDLE hFile,
     LPSECURITY_ATTRIBUTES lpFileMappingAttributes,
     DWORD flProtect,
     DWORD dwMaximumSizeHigh,
     DWORD dwMaximumSizeLow,
     LPCWSTR lpName
HANDLE
__stdcall
OpenFileMappingW(
     LPCWSTR lpName
LPVOID
__stdcall
MapViewOfFile(
     HANDLE hFileMappingObject,
     SIZE_T dwNumberOfBytesToMap
LPVOID
__stdcall
MapViewOfFileEx(
     SIZE_T dwNumberOfBytesToMap,
#pragma endregion
BOOL
__stdcall
VirtualFreeEx(
     HANDLE hProcess,
       LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD dwFreeType
BOOL
__stdcall
FlushViewOfFile(
     SIZE_T dwNumberOfBytesToFlush
BOOL
__stdcall
UnmapViewOfFile(
#pragma endregion
SIZE_T
__stdcall
GetLargePageMinimum(
    void
BOOL
__stdcall
GetProcessWorkingSetSizeEx(
     HANDLE hProcess,
     PSIZE_T lpMinimumWorkingSetSize,
     PSIZE_T lpMaximumWorkingSetSize,
     PDWORD Flags
BOOL
__stdcall
SetProcessWorkingSetSizeEx(
     HANDLE hProcess,
     SIZE_T dwMinimumWorkingSetSize,
     SIZE_T dwMaximumWorkingSetSize,
     DWORD Flags
#pragma endregion
BOOL
__stdcall
VirtualLock(
     LPVOID lpAddress,
     SIZE_T dwSize
BOOL
__stdcall
VirtualUnlock(
     LPVOID lpAddress,
     SIZE_T dwSize
#pragma endregion
UINT
__stdcall
GetWriteWatch(
     DWORD dwFlags,
     SIZE_T dwRegionSize,
     PVOID* lpAddresses,
     ULONG_PTR* lpdwCount,
     LPDWORD lpdwGranularity
UINT
__stdcall
ResetWriteWatch(
     SIZE_T dwRegionSize
#pragma endregion
typedef enum _MEMORY_RESOURCE_NOTIFICATION_TYPE {
    LowMemoryResourceNotification,
    HighMemoryResourceNotification
} MEMORY_RESOURCE_NOTIFICATION_TYPE;
HANDLE
__stdcall
CreateMemoryResourceNotification(
     MEMORY_RESOURCE_NOTIFICATION_TYPE NotificationType
BOOL
__stdcall
QueryMemoryResourceNotification(
     HANDLE ResourceNotificationHandle,
     PBOOL ResourceState
BOOL
__stdcall
GetSystemFileCacheSize(
     PSIZE_T lpMinimumFileCacheSize,
     PSIZE_T lpMaximumFileCacheSize,
     PDWORD lpFlags
BOOL
__stdcall
SetSystemFileCacheSize(
     SIZE_T MinimumFileCacheSize,
     SIZE_T MaximumFileCacheSize,
     DWORD Flags
HANDLE
__stdcall
CreateFileMappingNumaW(
     HANDLE hFile,
     DWORD flProtect,
     LPCWSTR lpName,
     DWORD nndPreferred
typedef struct _WIN32_MEMORY_RANGE_ENTRY {
    PVOID VirtualAddress;
    SIZE_T NumberOfBytes;
} WIN32_MEMORY_RANGE_ENTRY, *PWIN32_MEMORY_RANGE_ENTRY;
BOOL
__stdcall
PrefetchVirtualMemory(
     HANDLE hProcess,
     ULONG_PTR NumberOfEntries,
     PWIN32_MEMORY_RANGE_ENTRY VirtualAddresses,
     ULONG Flags
#pragma endregion
HANDLE
__stdcall
CreateFileMappingFromApp(
     HANDLE hFile,
     PSECURITY_ATTRIBUTES SecurityAttributes,
     ULONG PageProtection,
     ULONG64 MaximumSize,
     PCWSTR Name
PVOID
__stdcall
MapViewOfFileFromApp(
     ULONG DesiredAccess,
     ULONG64 FileOffset,
     SIZE_T NumberOfBytesToMap
BOOL
__stdcall
UnmapViewOfFileEx(
     PVOID BaseAddress,
     ULONG UnmapFlags
#pragma endregion
BOOL
__stdcall
AllocateUserPhysicalPages(
     HANDLE hProcess,
     PULONG_PTR NumberOfPages,
     PULONG_PTR PageArray
BOOL
__stdcall
FreeUserPhysicalPages(
     HANDLE hProcess,
BOOL
__stdcall
MapUserPhysicalPages(
     PVOID VirtualAddress,
BOOL
__stdcall
AllocateUserPhysicalPagesNuma(
     HANDLE hProcess,
     PULONG_PTR PageArray,
     DWORD nndPreferred
LPVOID
__stdcall
VirtualAllocExNuma(
     HANDLE hProcess,
     LPVOID lpAddress,
     SIZE_T dwSize,
     DWORD flProtect,
     DWORD nndPreferred
BOOL
__stdcall
GetMemoryErrorHandlingCapabilities(
     PULONG Capabilities
typedef
void
__stdcall
BAD_MEMORY_CALLBACK_ROUTINE(
    void
typedef BAD_MEMORY_CALLBACK_ROUTINE *PBAD_MEMORY_CALLBACK_ROUTINE;
PVOID
__stdcall
RegisterBadMemoryNotification(
     PBAD_MEMORY_CALLBACK_ROUTINE Callback
BOOL
__stdcall
UnregisterBadMemoryNotification(
     PVOID RegistrationHandle
#pragma endregion
typedef enum OFFER_PRIORITY {
    VmOfferPriorityVeryLow = 1,
    VmOfferPriorityLow,
    VmOfferPriorityBelowNormal,
    VmOfferPriorityNormal
} OFFER_PRIORITY;
DWORD
__stdcall
OfferVirtualMemory(
     SIZE_T Size,
     OFFER_PRIORITY Priority
DWORD
__stdcall
ReclaimVirtualMemory(
     void const* VirtualAddress,
     SIZE_T Size
DWORD
__stdcall
DiscardVirtualMemory(
     SIZE_T Size
#pragma endregion
BOOL
__stdcall
SetProcessValidCallTargets(
     HANDLE hProcess,
     SIZE_T RegionSize,
     ULONG NumberOfOffsets,
     PCFG_CALL_TARGET_INFO OffsetInformation
PVOID
__stdcall
VirtualAllocFromApp(
     PVOID BaseAddress,
     SIZE_T Size,
     ULONG AllocationType,
     ULONG Protection
BOOL
__stdcall
VirtualProtectFromApp(
     PVOID Address,
     SIZE_T Size,
     ULONG NewProtection,
     PULONG OldProtection
HANDLE
__stdcall
OpenFileMappingFromApp(
     BOOL InheritHandle,
     PCWSTR Name
#pragma endregion
#line 853 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\memoryapi.h"
#pragma endregion
typedef enum WIN32_MEMORY_INFORMATION_CLASS {
    MemoryRegionInfo
} WIN32_MEMORY_INFORMATION_CLASS;
typedef struct WIN32_MEMORY_REGION_INFORMATION {
    PVOID AllocationBase;
    ULONG AllocationProtect;
    union {
        ULONG Flags;
        struct {
            ULONG Private : 1;
            ULONG MappedDataFile : 1;
            ULONG MappedImage : 1;
            ULONG MappedPageFile : 1;
            ULONG MappedPhysical : 1;
            ULONG DirectMapped : 1;
            ULONG Reserved : 26;
    SIZE_T RegionSize;
    SIZE_T CommitSize;
} WIN32_MEMORY_REGION_INFORMATION;
#pragma warning(pop)
BOOL
__stdcall
QueryVirtualMemoryInformation(
     HANDLE Process,
     const void* VirtualAddress,
     WIN32_MEMORY_INFORMATION_CLASS MemoryInformationClass,
     PVOID MemoryInformation,
     SIZE_T MemoryInformationSize,
     PSIZE_T ReturnSize
#pragma endregion
PVOID
__stdcall
MapViewOfFileNuma2(
     HANDLE FileMappingHandle,
     ULONG64 Offset,
     PVOID BaseAddress,
     SIZE_T ViewSize,
     ULONG PreferredNode
__forceinline
PVOID
MapViewOfFile2(
     ULONG64 Offset,
     PVOID BaseAddress,
     SIZE_T ViewSize,
    return MapViewOfFileNuma2(FileMappingHandle,
                              ProcessHandle,
                              Offset,
                              BaseAddress,
                              ViewSize,
                              AllocationType,
                              PageProtection,
                              ((DWORD) -1));
#pragma endregion
BOOL
__stdcall
UnmapViewOfFile2(
     HANDLE Process,
     PVOID BaseAddress,
     ULONG UnmapFlags
BOOL
__stdcall
VirtualUnlockEx(
     HANDLE Process,
     LPVOID Address,
     SIZE_T Size
#pragma endregion
PVOID
__stdcall
VirtualAlloc2(
     HANDLE Process,
     PVOID BaseAddress,
     SIZE_T Size,
     MEM_EXTENDED_PARAMETER* ExtendedParameters,
     ULONG ParameterCount
PVOID
__stdcall
MapViewOfFile3(
     HANDLE FileMapping,
     HANDLE Process,
     PVOID BaseAddress,
     ULONG64 Offset,
     SIZE_T ViewSize,
#pragma endregion
PVOID
__stdcall
VirtualAlloc2FromApp(
     HANDLE Process,
     PVOID BaseAddress,
     SIZE_T Size,
PVOID
__stdcall
MapViewOfFile3FromApp(
     HANDLE FileMapping,
     HANDLE Process,
     PVOID BaseAddress,
     ULONG64 Offset,
     SIZE_T ViewSize,
#pragma endregion
#line 57 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\enclaveapi.h"
#pragma once
#pragma region Desktop Family or OneCore Or App Family
BOOL
__stdcall
IsEnclaveTypeSupported(
     DWORD flEnclaveType
LPVOID
__stdcall
CreateEnclave(
     HANDLE hProcess,
     LPVOID lpAddress,
     SIZE_T dwSize,
     SIZE_T dwInitialCommitment,
     DWORD flEnclaveType,
     LPCVOID lpEnclaveInformation,
     DWORD dwInfoLength,
     LPDWORD lpEnclaveError
BOOL
__stdcall
LoadEnclaveData(
     HANDLE hProcess,
     LPVOID lpAddress,
     LPCVOID lpBuffer,
     SIZE_T nSize,
     DWORD flProtect,
     LPCVOID lpPageInformation,
     DWORD dwInfoLength,
     PSIZE_T lpNumberOfBytesWritten,
BOOL
__stdcall
InitializeEnclave(
     HANDLE hProcess,
     LPVOID lpAddress,
     DWORD dwInfoLength,
#pragma endregion
BOOL
__stdcall
LoadEnclaveImageA(
     LPVOID lpEnclaveAddress,
     LPCSTR lpImageName
BOOL
__stdcall
LoadEnclaveImageW(
     LPCWSTR lpImageName
BOOL
__stdcall
CallEnclave(
     LPENCLAVE_ROUTINE lpRoutine,
     LPVOID lpParameter,
     BOOL fWaitForThread,
     LPVOID* lpReturnValue
BOOL
__stdcall
TerminateEnclave(
     LPVOID lpAddress,
     BOOL fWait
BOOL
__stdcall
DeleteEnclave(
     LPVOID lpAddress
#pragma endregion
#line 58 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\threadpoollegacyapiset.h"
#pragma once
BOOL
__stdcall
QueueUserWorkItem(
     LPTHREAD_START_ROUTINE Function,
     PVOID Context,
     ULONG Flags
BOOL
__stdcall
UnregisterWaitEx(
     HANDLE WaitHandle,
     HANDLE CompletionEvent
HANDLE
__stdcall
CreateTimerQueue(
    void
BOOL
__stdcall
CreateTimerQueueTimer(
     PHANDLE phNewTimer,
     HANDLE TimerQueue,
     WAITORTIMERCALLBACK Callback,
     PVOID Parameter,
     DWORD DueTime,
     DWORD Period,
     ULONG Flags
BOOL
__stdcall
ChangeTimerQueueTimer(
     HANDLE TimerQueue,
     HANDLE Timer,
     ULONG DueTime,
     ULONG Period
BOOL
__stdcall
DeleteTimerQueueTimer(
     HANDLE TimerQueue,
     HANDLE Timer,
BOOL
__stdcall
DeleteTimerQueueEx(
     HANDLE TimerQueue,
#pragma endregion
#line 59 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\threadpoolapiset.h"
#pragma once
#pragma region Application Family or OneCore Family
typedef
void
(__stdcall *PTP_WIN32_IO_CALLBACK)(
         PTP_CALLBACK_INSTANCE Instance,
     PVOID                 Context,
     PVOID                 Overlapped,
            ULONG                 IoResult,
            ULONG_PTR             NumberOfBytesTransferred,
         PTP_IO                Io
PTP_POOL
__stdcall
CreateThreadpool(
     PVOID reserved
void
__stdcall
SetThreadpoolThreadMaximum(
     PTP_POOL ptpp,
     DWORD cthrdMost
BOOL
__stdcall
SetThreadpoolThreadMinimum(
     PTP_POOL ptpp,
     DWORD cthrdMic
BOOL
__stdcall
SetThreadpoolStackInformation(
     PTP_POOL ptpp,
     PTP_POOL_STACK_INFORMATION ptpsi
BOOL
__stdcall
QueryThreadpoolStackInformation(
     PTP_POOL ptpp,
void
__stdcall
CloseThreadpool(
     PTP_POOL ptpp
PTP_CLEANUP_GROUP
__stdcall
CreateThreadpoolCleanupGroup(
    void
void
__stdcall
CloseThreadpoolCleanupGroupMembers(
     PTP_CLEANUP_GROUP ptpcg,
     BOOL fCancelPendingCallbacks,
     PVOID pvCleanupContext
void
__stdcall
CloseThreadpoolCleanupGroup(
void
__stdcall
SetEventWhenCallbackReturns(
     PTP_CALLBACK_INSTANCE pci,
     HANDLE evt
void
__stdcall
ReleaseSemaphoreWhenCallbackReturns(
     HANDLE sem,
     DWORD crel
void
__stdcall
ReleaseMutexWhenCallbackReturns(
     HANDLE mut
void
__stdcall
LeaveCriticalSectionWhenCallbackReturns(
     PCRITICAL_SECTION pcs
void
__stdcall
FreeLibraryWhenCallbackReturns(
     HMODULE mod
BOOL
__stdcall
CallbackMayRunLong(
void
__stdcall
DisassociateCurrentThreadFromCallback(
BOOL
__stdcall
TrySubmitThreadpoolCallback(
     PTP_SIMPLE_CALLBACK pfns,
     PVOID pv,
     PTP_CALLBACK_ENVIRON pcbe
PTP_WORK
__stdcall
CreateThreadpoolWork(
     PTP_WORK_CALLBACK pfnwk,
     PVOID pv,
void
__stdcall
SubmitThreadpoolWork(
     PTP_WORK pwk
void
__stdcall
WaitForThreadpoolWorkCallbacks(
     PTP_WORK pwk,
void
__stdcall
CloseThreadpoolWork(
     PTP_WORK pwk
PTP_TIMER
__stdcall
CreateThreadpoolTimer(
     PTP_TIMER_CALLBACK pfnti,
     PVOID pv,
void
__stdcall
SetThreadpoolTimer(
     PTP_TIMER pti,
     PFILETIME pftDueTime,
     DWORD msPeriod,
     DWORD msWindowLength
BOOL
__stdcall
IsThreadpoolTimerSet(
     PTP_TIMER pti
void
__stdcall
WaitForThreadpoolTimerCallbacks(
     PTP_TIMER pti,
void
__stdcall
CloseThreadpoolTimer(
     PTP_TIMER pti
PTP_WAIT
__stdcall
CreateThreadpoolWait(
     PTP_WAIT_CALLBACK pfnwa,
     PVOID pv,
void
__stdcall
SetThreadpoolWait(
     PTP_WAIT pwa,
     HANDLE h,
     PFILETIME pftTimeout
void
__stdcall
WaitForThreadpoolWaitCallbacks(
     PTP_WAIT pwa,
void
__stdcall
CloseThreadpoolWait(
     PTP_WAIT pwa
PTP_IO
__stdcall
CreateThreadpoolIo(
     HANDLE fl,
     PTP_WIN32_IO_CALLBACK pfnio,
     PVOID pv,
void
__stdcall
StartThreadpoolIo(
     PTP_IO pio
void
__stdcall
CancelThreadpoolIo(
     PTP_IO pio
void
__stdcall
WaitForThreadpoolIoCallbacks(
     PTP_IO pio,
void
__stdcall
CloseThreadpoolIo(
     PTP_IO pio
BOOL
__stdcall
SetThreadpoolTimerEx(
     PTP_TIMER pti,
     DWORD msPeriod,
BOOL
__stdcall
SetThreadpoolWaitEx(
     PTP_WAIT pwa,
     HANDLE h,
     PFILETIME pftTimeout,
     PVOID Reserved
#pragma endregion
#pragma endregion
#line 60 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\jobapi.h"
#pragma once
BOOL
__stdcall
IsProcessInJob(
     HANDLE JobHandle,
     PBOOL Result
#pragma endregion
#line 61 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\jobapi2.h"
#pragma once
typedef struct JOBOBJECT_IO_RATE_CONTROL_INFORMATION {
    LONG64 MaxIops;
    LONG64 MaxBandwidth;
    LONG64 ReservationIops;
    PCWSTR VolumeName;
    ULONG BaseIoSize;
    ULONG ControlFlags;
} JOBOBJECT_IO_RATE_CONTROL_INFORMATION;
HANDLE
__stdcall
CreateJobObjectW(
     LPSECURITY_ATTRIBUTES lpJobAttributes,
     LPCWSTR lpName
void
__stdcall
FreeMemoryJobObject(
      void* Buffer
HANDLE
__stdcall
OpenJobObjectW(
     LPCWSTR lpName
BOOL
__stdcall
AssignProcessToJobObject(
     HANDLE hJob,
     HANDLE hProcess
BOOL
__stdcall
TerminateJobObject(
     HANDLE hJob,
     UINT uExitCode
BOOL
__stdcall
SetInformationJobObject(
     HANDLE hJob,
     JOBOBJECTINFOCLASS JobObjectInformationClass,
     LPVOID lpJobObjectInformation,
     DWORD cbJobObjectInformationLength
DWORD
__stdcall
SetIoRateControlInformationJobObject(
     HANDLE hJob,
     JOBOBJECT_IO_RATE_CONTROL_INFORMATION* IoRateControlInfo
BOOL
__stdcall
QueryInformationJobObject(
     HANDLE hJob,
     DWORD cbJobObjectInformationLength,
     LPDWORD lpReturnLength
DWORD
__stdcall
QueryIoRateControlInformationJobObject(
     HANDLE hJob,
     PCWSTR VolumeName,
     JOBOBJECT_IO_RATE_CONTROL_INFORMATION** InfoBlocks,
     ULONG* InfoBlockCount
#pragma endregion
#line 62 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\wow64apiset.h"
#pragma once
BOOL
__stdcall
Wow64DisableWow64FsRedirection(
     PVOID* OldValue
BOOL
__stdcall
Wow64RevertWow64FsRedirection(
     PVOID OlValue
#pragma endregion
BOOL
__stdcall
IsWow64Process(
     HANDLE hProcess,
     PBOOL Wow64Process
#pragma endregion
UINT
__stdcall
GetSystemWow64DirectoryA(
     LPSTR lpBuffer,
     UINT uSize
UINT
__stdcall
GetSystemWow64DirectoryW(
     LPWSTR lpBuffer,
     UINT uSize
USHORT
__stdcall
Wow64SetThreadDefaultGuestMachine(
     USHORT Machine
#pragma endregion
BOOL
__stdcall
IsWow64Process2(
     HANDLE hProcess,
     USHORT* pProcessMachine,
     USHORT* pNativeMachine
#pragma endregion
UINT
__stdcall
GetSystemWow64Directory2A(
     LPSTR lpBuffer,
     UINT uSize,
     WORD ImageFileMachineType
UINT
__stdcall
GetSystemWow64Directory2W(
     LPWSTR lpBuffer,
     UINT uSize,
HRESULT
__stdcall
IsWow64GuestMachineSupported(
     USHORT WowGuestMachine,
     BOOL* MachineIsSupported
#pragma endregion
#line 63 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\libloaderapi.h"
#pragma once
typedef struct tagENUMUILANG {
    ULONG  NumOfEnumUILang;
    ULONG  SizeOfEnumUIBuffer;
    LANGID *pEnumUIBuffer;
} ENUMUILANG, *PENUMUILANG;
typedef BOOL (__stdcall* ENUMRESLANGPROCA)(
     HMODULE hModule,
     LPCSTR lpType,
     LPCSTR lpName,
     WORD wLanguage,
     LONG_PTR lParam);
typedef BOOL (__stdcall* ENUMRESLANGPROCW)(
     HMODULE hModule,
     LPCWSTR lpType,
     LPCWSTR lpName,
     WORD wLanguage,
     LONG_PTR lParam);
typedef BOOL (__stdcall* ENUMRESNAMEPROCA)(
     HMODULE hModule,
     LPCSTR lpType,
     LPSTR lpName,
     LONG_PTR lParam);
typedef BOOL (__stdcall* ENUMRESNAMEPROCW)(
     HMODULE hModule,
     LPCWSTR lpType,
     LPWSTR lpName,
     LONG_PTR lParam);
typedef BOOL (__stdcall* ENUMRESTYPEPROCA)(
     HMODULE hModule,
     LPSTR lpType,
     LONG_PTR lParam
typedef BOOL (__stdcall* ENUMRESTYPEPROCW)(
     HMODULE hModule,
     LPWSTR lpType,
     LONG_PTR lParam
#line 123 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\libloaderapi.h"
#pragma endregion
BOOL
__stdcall
DisableThreadLibraryCalls(
     HMODULE hLibModule
#pragma endregion
HRSRC
__stdcall
FindResourceExW(
     HMODULE hModule,
     LPCWSTR lpType,
     LPCWSTR lpName,
     WORD wLanguage
#pragma endregion
int
__stdcall
FindStringOrdinal(
     DWORD dwFindStringOrdinalFlags,
     LPCWSTR lpStringSource,
     int cchSource,
     LPCWSTR lpStringValue,
     int cchValue,
     BOOL bIgnoreCase
BOOL
__stdcall
FreeLibrary(
     HMODULE hLibModule
void
__stdcall
FreeLibraryAndExitThread(
     HMODULE hLibModule,
     DWORD dwExitCode
#pragma endregion
BOOL
__stdcall
FreeResource(
     HGLOBAL hResData
#pragma endregion
DWORD
__stdcall
GetModuleFileNameA(
     HMODULE hModule,
     LPSTR lpFilename,
     DWORD nSize
DWORD
__stdcall
GetModuleFileNameW(
     HMODULE hModule,
     LPWSTR lpFilename,
     DWORD nSize
#pragma endregion
HMODULE
__stdcall
GetModuleHandleA(
     LPCSTR lpModuleName
HMODULE
__stdcall
GetModuleHandleW(
     LPCWSTR lpModuleName
typedef
BOOL
(__stdcall*
PGET_MODULE_HANDLE_EXA)(
            DWORD        dwFlags,
        LPCSTR     lpModuleName,
     HMODULE*    phModule
typedef
BOOL
(__stdcall*
PGET_MODULE_HANDLE_EXW)(
            DWORD        dwFlags,
        LPCWSTR     lpModuleName,
     HMODULE*    phModule
BOOL
__stdcall
GetModuleHandleExA(
     DWORD dwFlags,
     HMODULE* phModule
BOOL
__stdcall
GetModuleHandleExW(
     DWORD dwFlags,
     HMODULE* phModule
#pragma endregion
FARPROC
__stdcall
GetProcAddress(
     HMODULE hModule,
     LPCSTR lpProcName
#pragma endregion
HMODULE
__stdcall
LoadLibraryExA(
     LPCSTR lpLibFileName,
     HANDLE hFile,
     DWORD dwFlags
HMODULE
__stdcall
LoadLibraryExW(
     LPCWSTR lpLibFileName,
     HANDLE hFile,
     DWORD dwFlags
#line 393 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\libloaderapi.h"
#line 410 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\libloaderapi.h"
HGLOBAL
__stdcall
LoadResource(
     HMODULE hModule,
     HRSRC hResInfo
#pragma endregion
int
__stdcall
LoadStringA(
     HINSTANCE hInstance,
     UINT uID,
     LPSTR lpBuffer,
     int cchBufferMax
int
__stdcall
LoadStringW(
     UINT uID,
     LPWSTR lpBuffer,
     int cchBufferMax
#pragma endregion
LPVOID
__stdcall
LockResource(
     HGLOBAL hResData
DWORD
__stdcall
SizeofResource(
     HMODULE hModule,
     HRSRC hResInfo
#pragma endregion
typedef PVOID DLL_DIRECTORY_COOKIE, *PDLL_DIRECTORY_COOKIE;
__stdcall
AddDllDirectory(
     PCWSTR NewDirectory
BOOL
__stdcall
RemoveDllDirectory(
     DLL_DIRECTORY_COOKIE Cookie
BOOL
__stdcall
SetDefaultDllDirectories(
     DWORD DirectoryFlags
#pragma endregion
BOOL
__stdcall
EnumResourceLanguagesExA(
     HMODULE hModule,
     LPCSTR lpType,
     LPCSTR lpName,
     ENUMRESLANGPROCA lpEnumFunc,
     LONG_PTR lParam,
    DWORD dwFlags,
    LANGID LangId
BOOL
__stdcall
EnumResourceLanguagesExW(
     HMODULE hModule,
     LPCWSTR lpType,
     LPCWSTR lpName,
     ENUMRESLANGPROCW lpEnumFunc,
     LONG_PTR lParam,
    DWORD dwFlags,
    LANGID LangId
BOOL
__stdcall
EnumResourceNamesExA(
     HMODULE hModule,
     LPCSTR lpType,
     ENUMRESNAMEPROCA lpEnumFunc,
     LONG_PTR lParam,
    DWORD dwFlags,
    LANGID LangId
BOOL
__stdcall
EnumResourceNamesExW(
     HMODULE hModule,
     LPCWSTR lpType,
     ENUMRESNAMEPROCW lpEnumFunc,
     LONG_PTR lParam,
    DWORD dwFlags,
    LANGID LangId
BOOL
__stdcall
EnumResourceTypesExA(
     HMODULE hModule,
     ENUMRESTYPEPROCA lpEnumFunc,
     LONG_PTR lParam,
    DWORD dwFlags,
    LANGID LangId
BOOL
__stdcall
EnumResourceTypesExW(
     HMODULE hModule,
     ENUMRESTYPEPROCW lpEnumFunc,
     LONG_PTR lParam,
    DWORD dwFlags,
    LANGID LangId
#pragma endregion
HRSRC
__stdcall
FindResourceW(
     HMODULE hModule,
     LPCWSTR lpName,
     LPCWSTR lpType
HMODULE
__stdcall
LoadLibraryA(
HMODULE
__stdcall
LoadLibraryW(
#pragma endregion
BOOL
__stdcall
EnumResourceNamesW(
     HMODULE hModule,
     LPCWSTR lpType,
     LONG_PTR lParam
#pragma endregion
#line 64 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\securitybaseapi.h"
#pragma once
BOOL
__stdcall
AccessCheck(
     PSECURITY_DESCRIPTOR pSecurityDescriptor,
     HANDLE ClientToken,
     PGENERIC_MAPPING GenericMapping,
     PPRIVILEGE_SET PrivilegeSet,
     LPDWORD PrivilegeSetLength,
     LPDWORD GrantedAccess,
     LPBOOL AccessStatus
BOOL
__stdcall
AccessCheckAndAuditAlarmW(
     LPCWSTR SubsystemName,
     LPVOID HandleId,
     LPWSTR ObjectTypeName,
     LPWSTR ObjectName,
     PSECURITY_DESCRIPTOR SecurityDescriptor,
     BOOL ObjectCreation,
     LPBOOL AccessStatus,
     LPBOOL pfGenerateOnClose
BOOL
__stdcall
AccessCheckByType(
     PSID PrincipalSelfSid,
     HANDLE ClientToken,
     POBJECT_TYPE_LIST ObjectTypeList,
     DWORD ObjectTypeListLength,
     LPBOOL AccessStatus
BOOL
__stdcall
AccessCheckByTypeResultList(
     HANDLE ClientToken,
     LPDWORD GrantedAccessList,
     LPDWORD AccessStatusList
BOOL
__stdcall
AccessCheckByTypeAndAuditAlarmW(
     LPVOID HandleId,
     LPCWSTR ObjectTypeName,
     LPCWSTR ObjectName,
     AUDIT_EVENT_TYPE AuditType,
     DWORD Flags,
BOOL
__stdcall
AccessCheckByTypeResultListAndAuditAlarmW(
     LPVOID HandleId,
     LPCWSTR ObjectName,
     DWORD Flags,
     LPDWORD AccessStatusList,
BOOL
__stdcall
AccessCheckByTypeResultListAndAuditAlarmByHandleW(
     LPVOID HandleId,
     HANDLE ClientToken,
     LPCWSTR ObjectName,
     DWORD Flags,
#pragma endregion
BOOL
__stdcall
AddAccessAllowedAce(
     PACL pAcl,
     DWORD dwAceRevision,
     DWORD AccessMask,
     PSID pSid
BOOL
__stdcall
AddAccessAllowedAceEx(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     PSID pSid
#pragma endregion
BOOL
__stdcall
AddAccessAllowedObjectAce(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     GUID* ObjectTypeGuid,
     GUID* InheritedObjectTypeGuid,
     PSID pSid
BOOL
__stdcall
AddAccessDeniedAce(
     PACL pAcl,
     DWORD AccessMask,
     PSID pSid
BOOL
__stdcall
AddAccessDeniedAceEx(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     PSID pSid
BOOL
__stdcall
AddAccessDeniedObjectAce(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     PSID pSid
#pragma endregion
BOOL
__stdcall
AddAce(
     PACL pAcl,
     DWORD dwStartingAceIndex,
     LPVOID pAceList,
     DWORD nAceListLength
#pragma endregion
BOOL
__stdcall
AddAuditAccessAce(
     PACL pAcl,
     DWORD dwAccessMask,
     PSID pSid,
     BOOL bAuditSuccess,
     BOOL bAuditFailure
BOOL
__stdcall
AddAuditAccessAceEx(
     PACL pAcl,
     DWORD AceFlags,
     DWORD dwAccessMask,
     PSID pSid,
     BOOL bAuditSuccess,
     BOOL bAuditFailure
BOOL
__stdcall
AddAuditAccessObjectAce(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     PSID pSid,
     BOOL bAuditSuccess,
     BOOL bAuditFailure
#pragma endregion
BOOL
__stdcall
AddMandatoryAce(
     PACL pAcl,
     DWORD AceFlags,
     DWORD MandatoryPolicy,
     PSID pLabelSid
#pragma endregion
BOOL
__stdcall
AddResourceAttributeAce(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     PSID pSid,
     PCLAIM_SECURITY_ATTRIBUTES_INFORMATION pAttributeInfo,
     PDWORD pReturnLength
BOOL
__stdcall
AddScopedPolicyIDAce(
     PACL pAcl,
     DWORD AceFlags,
     DWORD AccessMask,
     PSID pSid
#pragma endregion
BOOL
__stdcall
AdjustTokenGroups(
     HANDLE TokenHandle,
     BOOL ResetToDefault,
     PTOKEN_GROUPS NewState,
     DWORD BufferLength,
     PTOKEN_GROUPS PreviousState,
     PDWORD ReturnLength
BOOL
__stdcall
AdjustTokenPrivileges(
     HANDLE TokenHandle,
     BOOL DisableAllPrivileges,
     PTOKEN_PRIVILEGES NewState,
     DWORD BufferLength,
     PTOKEN_PRIVILEGES PreviousState,
     PDWORD ReturnLength
BOOL
__stdcall
AllocateAndInitializeSid(
     PSID_IDENTIFIER_AUTHORITY pIdentifierAuthority,
     BYTE nSubAuthorityCount,
     DWORD nSubAuthority0,
     DWORD nSubAuthority1,
     DWORD nSubAuthority2,
     DWORD nSubAuthority3,
     DWORD nSubAuthority4,
     DWORD nSubAuthority5,
     DWORD nSubAuthority6,
     DWORD nSubAuthority7,
     PSID* pSid
BOOL
__stdcall
AllocateLocallyUniqueId(
     PLUID Luid
#pragma endregion
BOOL
__stdcall
AreAllAccessesGranted(
     DWORD DesiredAccess
BOOL
__stdcall
AreAnyAccessesGranted(
     DWORD DesiredAccess
#pragma endregion
BOOL
__stdcall
CheckTokenMembership(
     HANDLE TokenHandle,
     PSID SidToCheck,
     PBOOL IsMember
#pragma endregion
BOOL
__stdcall
CheckTokenCapability(
     HANDLE TokenHandle,
     PSID CapabilitySidToCheck,
     PBOOL HasCapability
BOOL
__stdcall
GetAppContainerAce(
     PACL Acl,
     DWORD StartingAceIndex,
     PVOID* AppContainerAce,
     DWORD* AppContainerAceIndex
#pragma endregion
BOOL
__stdcall
CheckTokenMembershipEx(
     HANDLE TokenHandle,
     PSID SidToCheck,
     DWORD Flags,
     PBOOL IsMember
#pragma endregion
BOOL
__stdcall
ConvertToAutoInheritPrivateObjectSecurity(
     PSECURITY_DESCRIPTOR ParentDescriptor,
     PSECURITY_DESCRIPTOR CurrentSecurityDescriptor,
     PSECURITY_DESCRIPTOR* NewSecurityDescriptor,
     GUID* ObjectType,
     BOOLEAN IsDirectoryObject,
#pragma endregion
BOOL
__stdcall
CopySid(
     DWORD nDestinationSidLength,
     PSID pDestinationSid,
     PSID pSourceSid
#pragma endregion
BOOL
__stdcall
CreatePrivateObjectSecurity(
     PSECURITY_DESCRIPTOR CreatorDescriptor,
     PSECURITY_DESCRIPTOR* NewDescriptor,
     BOOL IsDirectoryObject,
     HANDLE Token,
BOOL
__stdcall
CreatePrivateObjectSecurityEx(
     GUID* ObjectType,
     BOOL IsContainerObject,
     ULONG AutoInheritFlags,
     HANDLE Token,
BOOL
__stdcall
CreatePrivateObjectSecurityWithMultipleInheritance(
     GUID** ObjectTypes,
     ULONG GuidCount,
     HANDLE Token,
BOOL
__stdcall
CreateRestrictedToken(
     HANDLE ExistingTokenHandle,
     DWORD Flags,
     DWORD DisableSidCount,
     PSID_AND_ATTRIBUTES SidsToDisable,
     DWORD DeletePrivilegeCount,
     PLUID_AND_ATTRIBUTES PrivilegesToDelete,
     DWORD RestrictedSidCount,
     PSID_AND_ATTRIBUTES SidsToRestrict,
     PHANDLE NewTokenHandle
#pragma endregion
BOOL
__stdcall
CreateWellKnownSid(
     WELL_KNOWN_SID_TYPE WellKnownSidType,
     PSID DomainSid,
     PSID pSid,
     DWORD* cbSid
BOOL
__stdcall
EqualDomainSid(
     PSID pSid1,
     PSID pSid2,
     BOOL* pfEqual
BOOL
__stdcall
DeleteAce(
     PACL pAcl,
     DWORD dwAceIndex
#pragma endregion
BOOL
__stdcall
DestroyPrivateObjectSecurity(
      PSECURITY_DESCRIPTOR* ObjectDescriptor
#pragma endregion
BOOL
__stdcall
DuplicateToken(
     SECURITY_IMPERSONATION_LEVEL ImpersonationLevel,
     PHANDLE DuplicateTokenHandle
BOOL
__stdcall
DuplicateTokenEx(
     HANDLE hExistingToken,
     DWORD dwDesiredAccess,
     LPSECURITY_ATTRIBUTES lpTokenAttributes,
     TOKEN_TYPE TokenType,
     PHANDLE phNewToken
#pragma endregion
BOOL
__stdcall
EqualPrefixSid(
     PSID pSid1,
     PSID pSid2
BOOL
__stdcall
EqualSid(
     PSID pSid1,
     PSID pSid2
BOOL
__stdcall
FindFirstFreeAce(
     PACL pAcl,
     LPVOID* pAce
#pragma endregion
PVOID
__stdcall
FreeSid(
     PSID pSid
BOOL
__stdcall
GetAce(
     PACL pAcl,
     DWORD dwAceIndex,
     LPVOID* pAce
BOOL
__stdcall
GetAclInformation(
     PACL pAcl,
     LPVOID pAclInformation,
     DWORD nAclInformationLength,
     ACL_INFORMATION_CLASS dwAclInformationClass
#pragma endregion
BOOL
__stdcall
GetFileSecurityW(
     LPCWSTR lpFileName,
     SECURITY_INFORMATION RequestedInformation,
     DWORD nLength,
     LPDWORD lpnLengthNeeded
#pragma endregion
BOOL
__stdcall
GetKernelObjectSecurity(
     HANDLE Handle,
     DWORD nLength,
DWORD
__stdcall
GetLengthSid(
      PSID pSid
#pragma endregion
BOOL
__stdcall
GetPrivateObjectSecurity(
     PSECURITY_DESCRIPTOR ObjectDescriptor,
     SECURITY_INFORMATION SecurityInformation,
     PSECURITY_DESCRIPTOR ResultantDescriptor,
     DWORD DescriptorLength,
     PDWORD ReturnLength
#pragma endregion
BOOL
__stdcall
GetSecurityDescriptorControl(
     PSECURITY_DESCRIPTOR_CONTROL pControl,
     LPDWORD lpdwRevision
BOOL
__stdcall
GetSecurityDescriptorDacl(
     LPBOOL lpbDaclPresent,
     PACL* pDacl,
     LPBOOL lpbDaclDefaulted
BOOL
__stdcall
GetSecurityDescriptorGroup(
     PSID* pGroup,
     LPBOOL lpbGroupDefaulted
DWORD
__stdcall
GetSecurityDescriptorLength(
BOOL
__stdcall
GetSecurityDescriptorOwner(
     PSID* pOwner,
     LPBOOL lpbOwnerDefaulted
DWORD
__stdcall
GetSecurityDescriptorRMControl(
     PUCHAR RMControl
BOOL
__stdcall
GetSecurityDescriptorSacl(
     LPBOOL lpbSaclPresent,
     PACL* pSacl,
     LPBOOL lpbSaclDefaulted
__stdcall
GetSidIdentifierAuthority(
     PSID pSid
DWORD
__stdcall
GetSidLengthRequired(
     UCHAR nSubAuthorityCount
PDWORD
__stdcall
GetSidSubAuthority(
     PSID pSid,
     DWORD nSubAuthority
PUCHAR
__stdcall
GetSidSubAuthorityCount(
     PSID pSid
BOOL
__stdcall
GetTokenInformation(
     HANDLE TokenHandle,
     TOKEN_INFORMATION_CLASS TokenInformationClass,
     LPVOID TokenInformation,
     DWORD TokenInformationLength,
     PDWORD ReturnLength
BOOL
__stdcall
GetWindowsAccountDomainSid(
     PSID pSid,
     PSID pDomainSid,
     DWORD* cbDomainSid
#pragma endregion
BOOL
__stdcall
ImpersonateAnonymousToken(
     HANDLE ThreadHandle
BOOL
__stdcall
ImpersonateLoggedOnUser(
     HANDLE hToken
BOOL
__stdcall
ImpersonateSelf(
#pragma endregion
BOOL
__stdcall
InitializeAcl(
     PACL pAcl,
     DWORD nAclLength,
     DWORD dwAclRevision
BOOL
__stdcall
InitializeSecurityDescriptor(
     DWORD dwRevision
BOOL
__stdcall
InitializeSid(
     PSID Sid,
#pragma endregion
BOOL
__stdcall
IsTokenRestricted(
     HANDLE TokenHandle
#pragma endregion
BOOL
__stdcall
IsValidAcl(
     PACL pAcl
BOOL
__stdcall
IsValidSecurityDescriptor(
BOOL
__stdcall
IsValidSid(
     PSID pSid
BOOL
__stdcall
IsWellKnownSid(
     PSID pSid,
BOOL
__stdcall
MakeAbsoluteSD(
     PSECURITY_DESCRIPTOR pSelfRelativeSecurityDescriptor,
     PSECURITY_DESCRIPTOR pAbsoluteSecurityDescriptor,
     LPDWORD lpdwAbsoluteSecurityDescriptorSize,
     PACL pDacl,
     LPDWORD lpdwDaclSize,
     PACL pSacl,
     LPDWORD lpdwSaclSize,
     PSID pOwner,
     LPDWORD lpdwOwnerSize,
     PSID pPrimaryGroup,
     LPDWORD lpdwPrimaryGroupSize
BOOL
__stdcall
MakeSelfRelativeSD(
     LPDWORD lpdwBufferLength
#pragma endregion
void
__stdcall
MapGenericMask(
     PDWORD AccessMask,
BOOL
__stdcall
ObjectCloseAuditAlarmW(
     LPVOID HandleId,
     BOOL GenerateOnClose
BOOL
__stdcall
ObjectDeleteAuditAlarmW(
     LPVOID HandleId,
BOOL
__stdcall
ObjectOpenAuditAlarmW(
     LPVOID HandleId,
     LPWSTR ObjectName,
     HANDLE ClientToken,
     PPRIVILEGE_SET Privileges,
     BOOL AccessGranted,
     LPBOOL GenerateOnClose
BOOL
__stdcall
ObjectPrivilegeAuditAlarmW(
     LPVOID HandleId,
     HANDLE ClientToken,
     BOOL AccessGranted
BOOL
__stdcall
PrivilegeCheck(
     HANDLE ClientToken,
     PPRIVILEGE_SET RequiredPrivileges,
     LPBOOL pfResult
BOOL
__stdcall
PrivilegedServiceAuditAlarmW(
     LPCWSTR ServiceName,
     HANDLE ClientToken,
     BOOL AccessGranted
void
__stdcall
QuerySecurityAccessMask(
     LPDWORD DesiredAccess
BOOL
__stdcall
RevertToSelf(
    void
BOOL
__stdcall
SetAclInformation(
     PACL pAcl,
BOOL
__stdcall
SetFileSecurityW(
     LPCWSTR lpFileName,
#pragma endregion
BOOL
__stdcall
SetKernelObjectSecurity(
     HANDLE Handle,
#pragma endregion
BOOL
__stdcall
SetPrivateObjectSecurity(
     PSECURITY_DESCRIPTOR ModificationDescriptor,
     PSECURITY_DESCRIPTOR* ObjectsSecurityDescriptor,
     HANDLE Token
BOOL
__stdcall
SetPrivateObjectSecurityEx(
     HANDLE Token
void
__stdcall
SetSecurityAccessMask(
#pragma endregion
BOOL
__stdcall
SetSecurityDescriptorControl(
     SECURITY_DESCRIPTOR_CONTROL ControlBitsOfInterest,
     SECURITY_DESCRIPTOR_CONTROL ControlBitsToSet
BOOL
__stdcall
SetSecurityDescriptorDacl(
     BOOL bDaclPresent,
     PACL pDacl,
     BOOL bDaclDefaulted
BOOL
__stdcall
SetSecurityDescriptorGroup(
     PSID pGroup,
     BOOL bGroupDefaulted
BOOL
__stdcall
SetSecurityDescriptorOwner(
     PSID pOwner,
     BOOL bOwnerDefaulted
DWORD
__stdcall
SetSecurityDescriptorRMControl(
     PUCHAR RMControl
BOOL
__stdcall
SetSecurityDescriptorSacl(
     BOOL bSaclPresent,
     PACL pSacl,
     BOOL bSaclDefaulted
BOOL
__stdcall
SetTokenInformation(
     HANDLE TokenHandle,
#pragma endregion
BOOL
__stdcall
SetCachedSigningLevel(
     PHANDLE SourceFiles,
     ULONG SourceFileCount,
     ULONG Flags,
     HANDLE TargetFile
BOOL
__stdcall
GetCachedSigningLevel(
     HANDLE File,
     PULONG Flags,
     PULONG SigningLevel,
     PUCHAR Thumbprint,
     PULONG ThumbprintSize,
     PULONG ThumbprintAlgorithm
#pragma endregion
LONG
__stdcall
CveEventWrite(
     PCWSTR CveId,
     PCWSTR AdditionalDetails
#pragma endregion
BOOL
__stdcall
DeriveCapabilitySidsFromName(
     LPCWSTR CapName,
     PSID** CapabilityGroupSids,
     DWORD* CapabilityGroupSidCount,
     PSID** CapabilitySids,
     DWORD* CapabilitySidCount
#pragma endregion
#line 65 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\namespaceapi.h"
#pragma once
HANDLE
__stdcall
CreatePrivateNamespaceW(
     LPSECURITY_ATTRIBUTES lpPrivateNamespaceAttributes,
     LPVOID lpBoundaryDescriptor,
     LPCWSTR lpAliasPrefix
HANDLE
__stdcall
OpenPrivateNamespaceW(
BOOLEAN
__stdcall
ClosePrivateNamespace(
     HANDLE Handle,
     ULONG Flags
HANDLE
__stdcall
CreateBoundaryDescriptorW(
     LPCWSTR Name,
     ULONG Flags
BOOL
__stdcall
AddSIDToBoundaryDescriptor(
     HANDLE* BoundaryDescriptor,
     PSID RequiredSid
void
__stdcall
DeleteBoundaryDescriptor(
     HANDLE BoundaryDescriptor
#pragma endregion
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\systemtopologyapi.h"
#pragma once
BOOL
__stdcall
GetNumaHighestNodeNumber(
     PULONG HighestNodeNumber
BOOL
__stdcall
GetNumaNodeProcessorMaskEx(
     USHORT Node,
     PGROUP_AFFINITY ProcessorMask
BOOL
__stdcall
GetNumaProximityNodeEx(
     ULONG ProximityId,
     PUSHORT NodeNumber
#pragma endregion
#line 67 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\processtopologyapi.h"
#pragma once
__declspec(dllimport)
BOOL
__stdcall
GetProcessGroupAffinity(
     HANDLE hProcess,
     PUSHORT GroupCount,
     PUSHORT GroupArray
#pragma endregion
#pragma region Desktop Family or OneCore Family
BOOL
__stdcall
GetThreadGroupAffinity(
     HANDLE hThread,
     PGROUP_AFFINITY GroupAffinity
BOOL
__stdcall
SetThreadGroupAffinity(
     HANDLE hThread,
     const GROUP_AFFINITY* GroupAffinity,
     PGROUP_AFFINITY PreviousGroupAffinity
#pragma endregion
#line 68 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\securityappcontainer.h"
#pragma once
BOOL
__stdcall
GetAppContainerNamedObjectPath(
     HANDLE Token,
     PSID AppContainerSid,
     ULONG ObjectPathLength,
     LPWSTR ObjectPath,
     PULONG ReturnLength
#pragma endregion
#line 69 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\realtimeapiset.h"
#pragma once
BOOL
__stdcall
QueryThreadCycleTime(
     PULONG64 CycleTime
BOOL
__stdcall
QueryProcessCycleTime(
     HANDLE ProcessHandle,
     PULONG64 CycleTime
BOOL
__stdcall
QueryIdleProcessorCycleTime(
     PULONG BufferLength,
     PULONG64 ProcessorIdleCycleTime
BOOL
__stdcall
QueryIdleProcessorCycleTimeEx(
     USHORT Group,
#pragma endregion
void
__stdcall
QueryInterruptTimePrecise(
     PULONGLONG lpInterruptTimePrecise
void
__stdcall
QueryUnbiasedInterruptTimePrecise(
     PULONGLONG lpUnbiasedInterruptTimePrecise
void
__stdcall
QueryInterruptTime(
BOOL
__stdcall
QueryUnbiasedInterruptTime(
     PULONGLONG UnbiasedTime
HRESULT
__stdcall
QueryAuxiliaryCounterFrequency(
     PULONGLONG lpAuxiliaryCounterFrequency
HRESULT
__stdcall
ConvertAuxiliaryCounterToPerformanceCounter(
     ULONGLONG ullAuxiliaryCounterValue,
     PULONGLONG lpPerformanceCounterValue,
     PULONGLONG lpConversionError
HRESULT
__stdcall
ConvertPerformanceCounterToAuxiliaryCounter(
     ULONGLONG ullPerformanceCounterValue,
     PULONGLONG lpAuxiliaryCounterValue,
#pragma endregion
#line 70 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
#pragma endregion
#line 140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 263 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
typedef void (__stdcall *PFIBER_START_ROUTINE)(
    LPVOID lpFiberParameter
typedef PFIBER_START_ROUTINE LPFIBER_START_ROUTINE;
typedef LPVOID (__stdcall *PFIBER_CALLOUT_ROUTINE)(
    LPVOID lpParameter
typedef LPVOID LPLDT_ENTRY;
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 353 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 365 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 390 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 414 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
typedef struct _COMMPROP {
    WORD wPacketLength;
    WORD wPacketVersion;
    DWORD dwServiceMask;
    DWORD dwReserved1;
    DWORD dwMaxTxQueue;
    DWORD dwMaxRxQueue;
    DWORD dwMaxBaud;
    DWORD dwProvSubType;
    DWORD dwProvCapabilities;
    DWORD dwSettableParams;
    DWORD dwSettableBaud;
    WORD wSettableData;
    WORD wSettableStopParity;
    DWORD dwCurrentTxQueue;
    DWORD dwCurrentRxQueue;
    DWORD dwProvSpec1;
    DWORD dwProvSpec2;
    WCHAR wcProvChar[1];
} COMMPROP,*LPCOMMPROP;
typedef struct _COMSTAT {
    DWORD fCtsHold : 1;
    DWORD fDsrHold : 1;
    DWORD fRlsdHold : 1;
    DWORD fXoffHold : 1;
    DWORD fXoffSent : 1;
    DWORD fEof : 1;
    DWORD fTxim : 1;
    DWORD fReserved : 25;
    DWORD cbInQue;
    DWORD cbOutQue;
} COMSTAT, *LPCOMSTAT;
typedef struct _DCB {
    DWORD DCBlength;
    DWORD BaudRate;
    DWORD fBinary: 1;
    DWORD fParity: 1;
    DWORD fOutxCtsFlow:1;
    DWORD fOutxDsrFlow:1;
    DWORD fDtrControl:2;
    DWORD fDsrSensitivity:1;
    DWORD fTXContinueOnXoff: 1;
    DWORD fOutX: 1;
    DWORD fInX: 1;
    DWORD fErrorChar: 1;
    DWORD fNull: 1;
    DWORD fRtsControl:2;
    DWORD fAbortOnError:1;
    DWORD fDummy2:17;
    WORD wReserved;
    WORD XonLim;
    WORD XoffLim;
    BYTE ByteSize;
    BYTE Parity;
    BYTE StopBits;
    char XonChar;
    char XoffChar;
    char ErrorChar;
    char EofChar;
    char EvtChar;
    WORD wReserved1;
} DCB, *LPDCB;
typedef struct _COMMTIMEOUTS {
    DWORD ReadIntervalTimeout;
    DWORD ReadTotalTimeoutMultiplier;
    DWORD ReadTotalTimeoutConstant;
    DWORD WriteTotalTimeoutMultiplier;
    DWORD WriteTotalTimeoutConstant;
} COMMTIMEOUTS,*LPCOMMTIMEOUTS;
typedef struct _COMMCONFIG {
    DWORD dwSize;
    WORD wVersion;
    WORD wReserved;
    DCB dcb;
    DWORD dwProviderSubType;
    DWORD dwProviderOffset;
    DWORD dwProviderSize;
    WCHAR wcProviderData[1];
} COMMCONFIG,*LPCOMMCONFIG;
#line 545 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
typedef struct _MEMORYSTATUS {
    DWORD dwLength;
    DWORD dwMemoryLoad;
    SIZE_T dwTotalPhys;
    SIZE_T dwAvailPhys;
    SIZE_T dwTotalPageFile;
    SIZE_T dwAvailPageFile;
    SIZE_T dwTotalVirtual;
    SIZE_T dwAvailVirtual;
} MEMORYSTATUS, *LPMEMORYSTATUS;
#line 629 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
typedef struct _JIT_DEBUG_INFO {
    DWORD dwSize;
    DWORD dwProcessorArchitecture;
    DWORD dwThreadID;
    DWORD dwReserved0;
    ULONG64 lpExceptionAddress;
    ULONG64 lpExceptionRecord;
    ULONG64 lpContextRecord;
} JIT_DEBUG_INFO, *LPJIT_DEBUG_INFO;
typedef JIT_DEBUG_INFO JIT_DEBUG_INFO32, *LPJIT_DEBUG_INFO32;
typedef JIT_DEBUG_INFO JIT_DEBUG_INFO64, *LPJIT_DEBUG_INFO64;
typedef PEXCEPTION_RECORD LPEXCEPTION_RECORD;
typedef PEXCEPTION_POINTERS LPEXCEPTION_POINTERS;
#line 678 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 730 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 746 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 755 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 773 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 834 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 851 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 863 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 880 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
typedef struct _OFSTRUCT {
    BYTE cBytes;
    BYTE fFixedDisk;
    WORD nErrCode;
    WORD Reserved1;
    WORD Reserved2;
    CHAR szPathName[128];
} OFSTRUCT, *LPOFSTRUCT, *POFSTRUCT;
#pragma endregion
int
__stdcall
WinMain (
     HINSTANCE hPrevInstance,
     LPSTR lpCmdLine,
     int nShowCmd
int
__stdcall
wWinMain(
     LPWSTR lpCmdLine,
     int nShowCmd
#pragma endregion
__declspec(allocator)
HGLOBAL
__stdcall
GlobalAlloc(
     UINT uFlags,
     SIZE_T dwBytes
#pragma endregion
HGLOBAL
__stdcall
GlobalReAlloc (
     HGLOBAL hMem,
     SIZE_T dwBytes,
     UINT uFlags
#pragma endregion
SIZE_T
__stdcall
GlobalSize (
     HGLOBAL hMem
BOOL
__stdcall
GlobalUnlock(
     HGLOBAL hMem
LPVOID
__stdcall
GlobalLock (
     HGLOBAL hMem
#pragma endregion
UINT
__stdcall
GlobalFlags (
     HGLOBAL hMem
HGLOBAL
__stdcall
GlobalHandle (
     LPCVOID pMem
#pragma endregion
HGLOBAL
__stdcall
GlobalFree(
     HGLOBAL hMem
#pragma endregion
SIZE_T
__stdcall
GlobalCompact(
     DWORD dwMinFree
void
__stdcall
GlobalFix(
     HGLOBAL hMem
void
__stdcall
GlobalUnfix(
     HGLOBAL hMem
LPVOID
__stdcall
GlobalWire(
     HGLOBAL hMem
BOOL
__stdcall
GlobalUnWire(
     HGLOBAL hMem
void
__stdcall
GlobalMemoryStatus(
     LPMEMORYSTATUS lpBuffer
#pragma endregion
HLOCAL
__stdcall
LocalAlloc(
     UINT uFlags,
     SIZE_T uBytes
HLOCAL
__stdcall
LocalReAlloc(
     HLOCAL hMem,
     SIZE_T uBytes,
     UINT uFlags
#pragma endregion
LPVOID
__stdcall
LocalLock(
     HLOCAL hMem
#pragma endregion
HLOCAL
__stdcall
LocalHandle(
     LPCVOID pMem
#pragma endregion
BOOL
__stdcall
LocalUnlock(
     HLOCAL hMem
#pragma endregion
SIZE_T
__stdcall
LocalSize(
     HLOCAL hMem
UINT
__stdcall
LocalFlags(
     HLOCAL hMem
#pragma endregion
HLOCAL
__stdcall
LocalFree(
     HLOCAL hMem
#pragma endregion
SIZE_T
__stdcall
LocalShrink(
     HLOCAL hMem,
     UINT cbNewSize
SIZE_T
__stdcall
LocalCompact(
     UINT uMinFree
#line 1213 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
GetBinaryTypeA(
     LPDWORD  lpBinaryType
BOOL
__stdcall
GetBinaryTypeW(
DWORD
__stdcall
GetShortPathNameA(
     LPCSTR lpszLongPath,
     LPSTR  lpszShortPath,
     DWORD cchBuffer
DWORD
__stdcall
GetLongPathNameTransactedA(
         LPCSTR lpszShortPath,
     LPSTR  lpszLongPath,
         DWORD cchBuffer,
         HANDLE hTransaction
DWORD
__stdcall
GetLongPathNameTransactedW(
         LPCWSTR lpszShortPath,
     LPWSTR  lpszLongPath,
         DWORD cchBuffer,
         HANDLE hTransaction
#pragma endregion
BOOL
__stdcall
GetProcessAffinityMask(
      HANDLE hProcess,
     PDWORD_PTR lpProcessAffinityMask,
     PDWORD_PTR lpSystemAffinityMask
BOOL
__stdcall
SetProcessAffinityMask(
     HANDLE hProcess,
     DWORD_PTR dwProcessAffinityMask
#pragma endregion
BOOL
__stdcall
GetProcessIoCounters(
      HANDLE hProcess,
     PIO_COUNTERS lpIoCounters
#pragma endregion
BOOL
__stdcall
GetProcessWorkingSetSize(
      HANDLE hProcess,
#pragma endregion
BOOL
__stdcall
SetProcessWorkingSetSize(
     HANDLE hProcess,
void
__stdcall
FatalExit(
     int ExitCode
#pragma endregion
BOOL
__stdcall
SetEnvironmentStringsA(
       LPCH NewEnvironment
#pragma endregion
void
__stdcall
SwitchToFiber(
     LPVOID lpFiber
void
__stdcall
DeleteFiber(
     LPVOID lpFiber
BOOL
__stdcall
ConvertFiberToThread(
    void
LPVOID
__stdcall
CreateFiberEx(
         SIZE_T dwStackCommitSize,
         SIZE_T dwStackReserveSize,
         DWORD dwFlags,
         LPFIBER_START_ROUTINE lpStartAddress,
     LPVOID lpParameter
LPVOID
__stdcall
ConvertThreadToFiberEx(
     LPVOID lpParameter,
         DWORD dwFlags
#pragma endregion
LPVOID
__stdcall
CreateFiber(
         SIZE_T dwStackSize,
     LPVOID lpParameter
LPVOID
__stdcall
ConvertThreadToFiber(
     LPVOID lpParameter
#pragma endregion
typedef void *PUMS_CONTEXT;
typedef void *PUMS_COMPLETION_LIST;
typedef enum _RTL_UMS_THREAD_INFO_CLASS UMS_THREAD_INFO_CLASS, *PUMS_THREAD_INFO_CLASS;
typedef enum _RTL_UMS_SCHEDULER_REASON UMS_SCHEDULER_REASON;
typedef PRTL_UMS_SCHEDULER_ENTRY_POINT PUMS_SCHEDULER_ENTRY_POINT;
typedef struct _UMS_SCHEDULER_STARTUP_INFO {
    ULONG UmsVersion;
    PUMS_COMPLETION_LIST CompletionList;
    PUMS_SCHEDULER_ENTRY_POINT SchedulerProc;
    PVOID SchedulerParam;
} UMS_SCHEDULER_STARTUP_INFO, *PUMS_SCHEDULER_STARTUP_INFO;
typedef struct _UMS_SYSTEM_THREAD_INFORMATION {
    ULONG UmsVersion;
    union {
        struct {
            ULONG IsUmsSchedulerThread : 1;
            ULONG IsUmsWorkerThread : 1;
        ULONG ThreadUmsFlags;
} UMS_SYSTEM_THREAD_INFORMATION, *PUMS_SYSTEM_THREAD_INFORMATION;
BOOL
__stdcall
CreateUmsCompletionList(
     PUMS_COMPLETION_LIST* UmsCompletionList
BOOL
__stdcall
DequeueUmsCompletionListItems(
     PUMS_COMPLETION_LIST UmsCompletionList,
     DWORD WaitTimeOut,
     PUMS_CONTEXT* UmsThreadList
BOOL
__stdcall
GetUmsCompletionListEvent(
     PHANDLE UmsCompletionEvent
BOOL
__stdcall
ExecuteUmsThread(
     PUMS_CONTEXT UmsThread
BOOL
__stdcall
UmsThreadYield(
BOOL
__stdcall
DeleteUmsCompletionList(
PUMS_CONTEXT
__stdcall
GetCurrentUmsThread(
    void
PUMS_CONTEXT
__stdcall
GetNextUmsListItem(
     PUMS_CONTEXT UmsContext
BOOL
__stdcall
QueryUmsThreadInformation(
     PUMS_CONTEXT UmsThread,
     UMS_THREAD_INFO_CLASS UmsThreadInfoClass,
     PVOID UmsThreadInformation,
     ULONG UmsThreadInformationLength,
     PULONG ReturnLength
BOOL
__stdcall
SetUmsThreadInformation(
BOOL
__stdcall
DeleteUmsThreadContext(
BOOL
__stdcall
CreateUmsThreadContext(
     PUMS_CONTEXT *lpUmsThread
BOOL
__stdcall
EnterUmsSchedulingMode(
     PUMS_SCHEDULER_STARTUP_INFO SchedulerStartupInfo
BOOL
__stdcall
GetUmsSystemThreadInformation(
     PUMS_SYSTEM_THREAD_INFORMATION SystemThreadInfo
#pragma endregion
DWORD_PTR
__stdcall
SetThreadAffinityMask(
     HANDLE hThread,
     DWORD_PTR dwThreadAffinityMask
#pragma endregion
BOOL
__stdcall
SetProcessDEPPolicy(
     DWORD dwFlags
BOOL
__stdcall
GetProcessDEPPolicy(
     HANDLE hProcess,
     LPDWORD lpFlags,
     PBOOL lpPermanent
BOOL
__stdcall
RequestWakeupLatency(
     LATENCY_TIME latency
BOOL
__stdcall
IsSystemResumeAutomatic(
    void
BOOL
__stdcall
GetThreadSelectorEntry(
      HANDLE hThread,
      DWORD dwSelector,
     LPLDT_ENTRY lpSelectorEntry
EXECUTION_STATE
__stdcall
SetThreadExecutionState(
     EXECUTION_STATE esFlags
typedef REASON_CONTEXT POWER_REQUEST_CONTEXT, *PPOWER_REQUEST_CONTEXT, *LPPOWER_REQUEST_CONTEXT;
HANDLE
__stdcall
PowerCreateRequest (
     PREASON_CONTEXT Context
BOOL
__stdcall
PowerSetRequest (
     HANDLE PowerRequest,
     POWER_REQUEST_TYPE RequestType
BOOL
__stdcall
PowerClearRequest (
#pragma endregion
#pragma endregion
#line 1780 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
BOOL
__stdcall
SetFileCompletionNotificationModes(
     HANDLE FileHandle,
     UCHAR Flags
#pragma endregion
BOOL
__stdcall
Wow64GetThreadContext(
        HANDLE hThread,
     PWOW64_CONTEXT lpContext
BOOL
__stdcall
Wow64SetThreadContext(
     HANDLE hThread,
     const WOW64_CONTEXT *lpContext
BOOL
__stdcall
Wow64GetThreadSelectorEntry(
     HANDLE hThread,
     DWORD dwSelector,
     PWOW64_LDT_ENTRY lpSelectorEntry
DWORD
__stdcall
Wow64SuspendThread(
     HANDLE hThread
BOOL
__stdcall
DebugSetProcessKillOnExit(
     BOOL KillOnExit
BOOL
__stdcall
DebugBreakProcess (
     HANDLE Process
#pragma endregion
#pragma endregion
BOOL
__stdcall
PulseEvent(
     HANDLE hEvent
ATOM
__stdcall
GlobalDeleteAtom(
     ATOM nAtom
BOOL
__stdcall
InitAtomTable(
     DWORD nSize
ATOM
__stdcall
DeleteAtom(
     ATOM nAtom
UINT
__stdcall
SetHandleCount(
     UINT uNumber
BOOL
__stdcall
RequestDeviceWakeup(
     HANDLE hDevice
BOOL
__stdcall
CancelDeviceWakeupRequest(
     HANDLE hDevice
BOOL
__stdcall
GetDevicePowerState(
      HANDLE hDevice,
     BOOL *pfOn
BOOL
__stdcall
SetMessageWaitingIndicator(
     HANDLE hMsgIndicator,
     ULONG ulMsgCount
BOOL
__stdcall
SetFileShortNameA(
     HANDLE hFile,
     LPCSTR lpShortName
BOOL
__stdcall
SetFileShortNameW(
     HANDLE hFile,
     LPCWSTR lpShortName
DWORD
__stdcall
LoadModule(
     LPVOID lpParameterBlock
UINT
__stdcall
WinExec(
     LPCSTR lpCmdLine,
     UINT uCmdShow
#pragma endregion
#pragma region Desktop Family or OneCore or App Family
BOOL
__stdcall
ClearCommBreak(
     HANDLE hFile
BOOL
__stdcall
ClearCommError(
          HANDLE hFile,
     LPDWORD lpErrors,
     LPCOMSTAT lpStat
BOOL
__stdcall
SetupComm(
     HANDLE hFile,
     DWORD dwInQueue,
     DWORD dwOutQueue
BOOL
__stdcall
EscapeCommFunction(
     HANDLE hFile,
     DWORD dwFunc
BOOL
__stdcall
GetCommConfig(
          HANDLE hCommDev,
     LPCOMMCONFIG lpCC,
       LPDWORD lpdwSize
BOOL
__stdcall
GetCommMask(
      HANDLE hFile,
     LPDWORD lpEvtMask
BOOL
__stdcall
GetCommProperties(
        HANDLE hFile,
     LPCOMMPROP lpCommProp
BOOL
__stdcall
GetCommModemStatus(
      HANDLE hFile,
     LPDWORD lpModemStat
BOOL
__stdcall
GetCommState(
      HANDLE hFile,
     LPDCB lpDCB
BOOL
__stdcall
GetCommTimeouts(
      HANDLE hFile,
     LPCOMMTIMEOUTS lpCommTimeouts
BOOL
__stdcall
PurgeComm(
     HANDLE hFile,
     DWORD dwFlags
BOOL
__stdcall
SetCommBreak(
     HANDLE hFile
BOOL
__stdcall
SetCommConfig(
     HANDLE hCommDev,
     LPCOMMCONFIG lpCC,
     DWORD dwSize
BOOL
__stdcall
SetCommMask(
     HANDLE hFile,
     DWORD dwEvtMask
BOOL
__stdcall
SetCommState(
     HANDLE hFile,
     LPDCB lpDCB
BOOL
__stdcall
SetCommTimeouts(
     HANDLE hFile,
BOOL
__stdcall
TransmitCommChar(
     HANDLE hFile,
     char cChar
BOOL
__stdcall
WaitCommEvent(
            HANDLE hFile,
         LPDWORD lpEvtMask,
     LPOVERLAPPED lpOverlapped
HANDLE
__stdcall
OpenCommPort(
     ULONG uPortNumber,
     DWORD dwFlagsAndAttributes
ULONG
__stdcall
GetCommPorts(
     PULONG lpPortNumbers,
                                ULONG uPortNumbersCount,
                               PULONG puPortNumbersFound
#pragma endregion
DWORD
__stdcall
SetTapePosition(
     HANDLE hDevice,
     DWORD dwPositionMethod,
     DWORD dwPartition,
     DWORD dwOffsetLow,
     DWORD dwOffsetHigh,
     BOOL bImmediate
DWORD
__stdcall
GetTapePosition(
      HANDLE hDevice,
      DWORD dwPositionType,
     LPDWORD lpdwPartition,
     LPDWORD lpdwOffsetLow,
     LPDWORD lpdwOffsetHigh
DWORD
__stdcall
PrepareTape(
     HANDLE hDevice,
     DWORD dwOperation,
     BOOL bImmediate
DWORD
__stdcall
EraseTape(
     HANDLE hDevice,
     DWORD dwEraseType,
     BOOL bImmediate
DWORD
__stdcall
CreateTapePartition(
     HANDLE hDevice,
     DWORD dwPartitionMethod,
     DWORD dwCount,
     DWORD dwSize
DWORD
__stdcall
WriteTapemark(
     HANDLE hDevice,
     DWORD dwTapemarkType,
     DWORD dwTapemarkCount,
     BOOL bImmediate
DWORD
__stdcall
GetTapeStatus(
     HANDLE hDevice
DWORD
__stdcall
GetTapeParameters(
        HANDLE hDevice,
        DWORD dwOperation,
     LPDWORD lpdwSize,
     LPVOID lpTapeInformation
DWORD
__stdcall
SetTapeParameters(
     HANDLE hDevice,
     DWORD dwOperation,
#pragma endregion
int
__stdcall
MulDiv(
     int nNumber,
     int nNumerator,
     int nDenominator
#pragma endregion
typedef enum _DEP_SYSTEM_POLICY_TYPE {
    DEPPolicyAlwaysOff = 0,
    DEPPolicyAlwaysOn,
    DEPPolicyOptIn,
    DEPPolicyOptOut,
    DEPTotalPolicyCount
} DEP_SYSTEM_POLICY_TYPE;
__stdcall
GetSystemDEPPolicy(
    void
BOOL
__stdcall
GetSystemRegistryQuota(
     PDWORD pdwQuotaAllowed,
     PDWORD pdwQuotaUsed
BOOL
__stdcall
FileTimeToDosDateTime(
      const FILETIME *lpFileTime,
     LPWORD lpFatDate,
     LPWORD lpFatTime
BOOL
__stdcall
DosDateTimeToFileTime(
      WORD wFatDate,
      WORD wFatTime,
     LPFILETIME lpFileTime
#pragma endregion
DWORD
__stdcall
FormatMessageA(
         DWORD dwFlags,
     LPCVOID lpSource,
         DWORD dwMessageId,
         DWORD dwLanguageId,
             LPSTR lpBuffer,
         DWORD nSize,
     va_list *Arguments
DWORD
__stdcall
FormatMessageW(
         DWORD dwFlags,
     LPCVOID lpSource,
         DWORD dwMessageId,
         DWORD dwLanguageId,
             LPWSTR lpBuffer,
         DWORD nSize,
     va_list *Arguments
#line 2449 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 2456 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
HANDLE
__stdcall
CreateMailslotA(
         LPCSTR lpName,
         DWORD nMaxMessageSize,
         DWORD lReadTimeout,
     LPSECURITY_ATTRIBUTES lpSecurityAttributes
HANDLE
__stdcall
CreateMailslotW(
         LPCWSTR lpName,
         DWORD lReadTimeout,
BOOL
__stdcall
GetMailslotInfo(
          HANDLE hMailslot,
     LPDWORD lpMaxMessageSize,
     LPDWORD lpNextSize,
     LPDWORD lpMessageCount,
     LPDWORD lpReadTimeout
BOOL
__stdcall
SetMailslotInfo(
     HANDLE hMailslot,
     DWORD lReadTimeout
BOOL
__stdcall
EncryptFileA(
     LPCSTR lpFileName
BOOL
__stdcall
EncryptFileW(
     LPCWSTR lpFileName
BOOL
__stdcall
DecryptFileA(
           LPCSTR lpFileName,
     DWORD dwReserved
BOOL
__stdcall
DecryptFileW(
           LPCWSTR lpFileName,
     DWORD dwReserved
#line 2563 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
FileEncryptionStatusA(
      LPCSTR lpFileName,
     LPDWORD  lpStatus
BOOL
__stdcall
FileEncryptionStatusW(
      LPCWSTR lpFileName,
     LPDWORD  lpStatus
typedef
DWORD
(__stdcall *PFE_EXPORT_FUNC)(
     PBYTE pbData,
     PVOID pvCallbackContext,
         ULONG ulLength
typedef
DWORD
(__stdcall *PFE_IMPORT_FUNC)(
     PBYTE pbData,
      PULONG ulLength
DWORD
__stdcall
OpenEncryptedFileRawA(
            LPCSTR lpFileName,
            ULONG    ulFlags,
     PVOID   *pvContext
DWORD
__stdcall
OpenEncryptedFileRawW(
            LPCWSTR lpFileName,
            ULONG    ulFlags,
     PVOID   *pvContext
DWORD
__stdcall
ReadEncryptedFileRaw(
         PFE_EXPORT_FUNC pfExportCallback,
         PVOID           pvContext
DWORD
__stdcall
WriteEncryptedFileRaw(
         PFE_IMPORT_FUNC pfImportCallback,
         PVOID           pvContext
void
__stdcall
CloseEncryptedFileRaw(
     PVOID           pvContext
#pragma endregion
int
__stdcall
lstrcmpA(
     LPCSTR lpString1,
     LPCSTR lpString2
int
__stdcall
lstrcmpW(
     LPCWSTR lpString1,
     LPCWSTR lpString2
int
__stdcall
lstrcmpiA(
     LPCSTR lpString1,
     LPCSTR lpString2
int
__stdcall
lstrcmpiW(
     LPCWSTR lpString1,
     LPCWSTR lpString2
#pragma warning(push)
#pragma warning(disable:4995)
LPSTR
__stdcall
lstrcpynA(
     LPSTR lpString1,
     LPCSTR lpString2,
     int iMaxLength
LPWSTR
__stdcall
lstrcpynW(
     LPWSTR lpString1,
     LPCWSTR lpString2,
     int iMaxLength
LPSTR
__stdcall
lstrcpyA(
     LPSTR lpString1,
      LPCSTR lpString2
LPWSTR
__stdcall
lstrcpyW(
     LPWSTR lpString1,
      LPCWSTR lpString2
LPSTR
__stdcall
lstrcatA(
     LPSTR lpString1,
        LPCSTR lpString2
LPWSTR
__stdcall
lstrcatW(
     LPWSTR lpString1,
        LPCWSTR lpString2
int
__stdcall
lstrlenA(
     LPCSTR lpString
int
__stdcall
lstrlenW(
     LPCWSTR lpString
#pragma endregion
HFILE
__stdcall
OpenFile(
        LPCSTR lpFileName,
     LPOFSTRUCT lpReOpenBuff,
        UINT uStyle
HFILE
__stdcall
_lopen(
     LPCSTR lpPathName,
     int iReadWrite
HFILE
__stdcall
_lcreat(
     LPCSTR lpPathName,
     int  iAttribute
UINT
__stdcall
_lread(
     HFILE hFile,
     LPVOID lpBuffer,
     UINT uBytes
UINT
__stdcall
_lwrite(
     HFILE hFile,
     LPCCH lpBuffer,
     UINT uBytes
long
__stdcall
_hread(
     HFILE hFile,
     LPVOID lpBuffer,
     long lBytes
long
__stdcall
_hwrite(
     HFILE hFile,
     LPCCH lpBuffer,
     long lBytes
HFILE
__stdcall
_lclose(
     HFILE hFile
LONG
__stdcall
_llseek(
     HFILE hFile,
     LONG lOffset,
     int iOrigin
BOOL
__stdcall
IsTextUnicode(
     const void* lpv,
            int iSize,
     LPINT lpiResult
#pragma endregion
DWORD
__stdcall
SignalObjectAndWait(
     HANDLE hObjectToSignal,
     HANDLE hObjectToWaitOn,
     DWORD dwMilliseconds,
     BOOL bAlertable
#pragma endregion
BOOL
__stdcall
BackupRead(
        HANDLE hFile,
     LPBYTE lpBuffer,
        DWORD nNumberOfBytesToRead,
       LPDWORD lpNumberOfBytesRead,
        BOOL bAbort,
        BOOL bProcessSecurity,
     LPVOID *lpContext
BOOL
__stdcall
BackupSeek(
        HANDLE hFile,
        DWORD  dwLowBytesToSeek,
        DWORD  dwHighBytesToSeek,
       LPDWORD lpdwLowByteSeeked,
       LPDWORD lpdwHighByteSeeked,
     LPVOID *lpContext
BOOL
__stdcall
BackupWrite(
        HANDLE hFile,
     LPBYTE lpBuffer,
        DWORD nNumberOfBytesToWrite,
       LPDWORD lpNumberOfBytesWritten,
        BOOL bAbort,
     LPVOID *lpContext
typedef struct _WIN32_STREAM_ID {
        DWORD          dwStreamId ;
        DWORD          dwStreamAttributes ;
        LARGE_INTEGER  Size ;
        DWORD          dwStreamNameSize ;
        WCHAR          cStreamName[ 1 ] ;
} WIN32_STREAM_ID, *LPWIN32_STREAM_ID ;
#line 2993 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 3004 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 3018 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
typedef struct _STARTUPINFOEXA {
    STARTUPINFOA StartupInfo;
    LPPROC_THREAD_ATTRIBUTE_LIST lpAttributeList;
} STARTUPINFOEXA, *LPSTARTUPINFOEXA;
typedef struct _STARTUPINFOEXW {
    STARTUPINFOW StartupInfo;
} STARTUPINFOEXW, *LPSTARTUPINFOEXW;
typedef STARTUPINFOEXA STARTUPINFOEX;
typedef LPSTARTUPINFOEXA LPSTARTUPINFOEX;
#pragma endregion
HANDLE
__stdcall
OpenMutexA(
     BOOL bInheritHandle,
     LPCSTR lpName
HANDLE
__stdcall
CreateSemaphoreA(
     LPSECURITY_ATTRIBUTES lpSemaphoreAttributes,
         LONG lInitialCount,
         LONG lMaximumCount,
     LPCSTR lpName
#pragma endregion
HANDLE
__stdcall
OpenSemaphoreA(
     LPCSTR lpName
#pragma endregion
HANDLE
__stdcall
CreateWaitableTimerA(
     LPSECURITY_ATTRIBUTES lpTimerAttributes,
         BOOL bManualReset,
     LPCSTR lpTimerName
HANDLE
__stdcall
OpenWaitableTimerA(
     LPCSTR lpTimerName
HANDLE
__stdcall
CreateSemaphoreExA(
            LONG lInitialCount,
            LONG lMaximumCount,
        LPCSTR lpName,
      DWORD dwFlags,
HANDLE
__stdcall
CreateWaitableTimerExA(
     LPCSTR lpTimerName,
         DWORD dwFlags,
#pragma endregion
HANDLE
__stdcall
CreateFileMappingA(
         HANDLE hFile,
         DWORD flProtect,
     LPCSTR lpName
HANDLE
__stdcall
CreateFileMappingNumaA(
         HANDLE hFile,
         DWORD flProtect,
     LPCSTR lpName,
         DWORD nndPreferred
HANDLE
__stdcall
OpenFileMappingA(
     LPCSTR lpName
#pragma endregion
DWORD
__stdcall
GetLogicalDriveStringsA(
     DWORD nBufferLength,
     LPSTR lpBuffer
#pragma endregion
#pragma endregion
HMODULE
__stdcall
LoadPackagedLibrary (
           LPCWSTR lpwLibFileName,
     DWORD Reserved
#pragma endregion
BOOL
__stdcall
QueryFullProcessImageNameA(
     HANDLE hProcess,
     DWORD dwFlags,
     LPSTR lpExeName,
     PDWORD lpdwSize
BOOL
__stdcall
QueryFullProcessImageNameW(
     HANDLE hProcess,
     DWORD dwFlags,
     LPWSTR lpExeName,
     PDWORD lpdwSize
typedef enum _PROC_THREAD_ATTRIBUTE_NUM {
    ProcThreadAttributeParentProcess                = 0,
    ProcThreadAttributeHandleList                   = 2,
    ProcThreadAttributeGroupAffinity                = 3,
    ProcThreadAttributePreferredNode                = 4,
    ProcThreadAttributeIdealProcessor               = 5,
    ProcThreadAttributeUmsThread                    = 6,
    ProcThreadAttributeMitigationPolicy             = 7,
    ProcThreadAttributeSecurityCapabilities         = 9,
    ProcThreadAttributeProtectionLevel              = 11,
    ProcThreadAttributeJobList                      = 13,
    ProcThreadAttributeChildProcessPolicy           = 14,
    ProcThreadAttributeAllApplicationPackagesPolicy = 15,
    ProcThreadAttributeWin32kFilter                 = 16,
    ProcThreadAttributeSafeOpenPromptOriginClaim    = 17,
    ProcThreadAttributeDesktopAppPolicy = 18,
} PROC_THREAD_ATTRIBUTE_NUM;
#line 3413 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
void
__stdcall
GetStartupInfoA(
     LPSTARTUPINFOA lpStartupInfo
#line 3753 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 3773 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
DWORD
__stdcall
GetFirmwareEnvironmentVariableA(
     LPCSTR lpName,
     LPCSTR lpGuid,
     PVOID pBuffer,
     DWORD    nSize
DWORD
__stdcall
GetFirmwareEnvironmentVariableW(
     LPCWSTR lpName,
     LPCWSTR lpGuid,
     PVOID pBuffer,
     DWORD    nSize
DWORD
__stdcall
GetFirmwareEnvironmentVariableExA(
     LPCSTR lpName,
     LPCSTR lpGuid,
     PVOID pBuffer,
     DWORD    nSize,
     PDWORD pdwAttribubutes
DWORD
__stdcall
GetFirmwareEnvironmentVariableExW(
     LPCWSTR lpName,
     LPCWSTR lpGuid,
     PVOID pBuffer,
     DWORD    nSize,
BOOL
__stdcall
SetFirmwareEnvironmentVariableA(
     LPCSTR lpName,
     LPCSTR lpGuid,
     PVOID pValue,
     DWORD    nSize
BOOL
__stdcall
SetFirmwareEnvironmentVariableW(
     LPCWSTR lpName,
     LPCWSTR lpGuid,
     PVOID pValue,
     DWORD    nSize
BOOL
__stdcall
SetFirmwareEnvironmentVariableExA(
     LPCSTR lpName,
     LPCSTR lpGuid,
     PVOID pValue,
     DWORD    nSize,
     DWORD    dwAttributes
BOOL
__stdcall
SetFirmwareEnvironmentVariableExW(
     LPCWSTR lpName,
     LPCWSTR lpGuid,
     PVOID pValue,
     DWORD    nSize,
     DWORD    dwAttributes
#pragma endregion
BOOL
__stdcall
GetFirmwareType (
     PFIRMWARE_TYPE FirmwareType
BOOL
__stdcall
IsNativeVhdBoot (
     PBOOL NativeVhdBoot
HRSRC
__stdcall
FindResourceA(
     HMODULE hModule,
         LPCSTR lpName,
         LPCSTR lpType
HRSRC
__stdcall
FindResourceExA(
     HMODULE hModule,
         LPCSTR lpType,
         LPCSTR lpName,
         WORD    wLanguage
BOOL
__stdcall
EnumResourceTypesA(
     HMODULE hModule,
         LONG_PTR lParam
BOOL
__stdcall
EnumResourceTypesW(
     HMODULE hModule,
         LONG_PTR lParam
BOOL
__stdcall
EnumResourceNamesA(
     HMODULE hModule,
         LPCSTR lpType,
         LONG_PTR lParam
BOOL
__stdcall
EnumResourceLanguagesA(
     HMODULE hModule,
         LPCSTR lpType,
         LPCSTR lpName,
         LONG_PTR lParam
BOOL
__stdcall
EnumResourceLanguagesW(
     HMODULE hModule,
         LPCWSTR lpType,
         LPCWSTR lpName,
         LONG_PTR lParam
HANDLE
__stdcall
BeginUpdateResourceA(
     LPCSTR pFileName,
     BOOL bDeleteExistingResources
HANDLE
__stdcall
BeginUpdateResourceW(
     LPCWSTR pFileName,
BOOL
__stdcall
UpdateResourceA(
     HANDLE hUpdate,
     LPCSTR lpType,
     LPCSTR lpName,
     WORD wLanguage,
     LPVOID lpData,
     DWORD cb
BOOL
__stdcall
UpdateResourceW(
     HANDLE hUpdate,
     LPCWSTR lpType,
     LPCWSTR lpName,
     WORD wLanguage,
     LPVOID lpData,
     DWORD cb
BOOL
__stdcall
EndUpdateResourceA(
     HANDLE hUpdate,
     BOOL   fDiscard
BOOL
__stdcall
EndUpdateResourceW(
     HANDLE hUpdate,
     BOOL   fDiscard
ATOM
__stdcall
GlobalAddAtomA(
     LPCSTR lpString
ATOM
__stdcall
GlobalAddAtomW(
     LPCWSTR lpString
ATOM
__stdcall
GlobalAddAtomExA(
     LPCSTR lpString,
     DWORD Flags
ATOM
__stdcall
GlobalAddAtomExW(
     LPCWSTR lpString,
     DWORD Flags
ATOM
__stdcall
GlobalFindAtomA(
     LPCSTR lpString
ATOM
__stdcall
GlobalFindAtomW(
     LPCWSTR lpString
UINT
__stdcall
GlobalGetAtomNameA(
     ATOM nAtom,
     LPSTR lpBuffer,
     int nSize
UINT
__stdcall
GlobalGetAtomNameW(
     ATOM nAtom,
     LPWSTR lpBuffer,
     int nSize
ATOM
__stdcall
AddAtomA(
     LPCSTR lpString
ATOM
__stdcall
AddAtomW(
     LPCWSTR lpString
ATOM
__stdcall
FindAtomA(
     LPCSTR lpString
ATOM
__stdcall
FindAtomW(
     LPCWSTR lpString
UINT
__stdcall
GetAtomNameA(
     ATOM nAtom,
     LPSTR lpBuffer,
     int nSize
UINT
__stdcall
GetAtomNameW(
     ATOM nAtom,
     LPWSTR lpBuffer,
     int nSize
#pragma endregion
UINT
__stdcall
GetProfileIntA(
     LPCSTR lpAppName,
     LPCSTR lpKeyName,
     INT nDefault
UINT
__stdcall
GetProfileIntW(
     LPCWSTR lpAppName,
     LPCWSTR lpKeyName,
     INT nDefault
DWORD
__stdcall
GetProfileStringA(
     LPCSTR lpAppName,
     LPCSTR lpKeyName,
     LPCSTR lpDefault,
     LPSTR lpReturnedString,
         DWORD nSize
DWORD
__stdcall
GetProfileStringW(
     LPCWSTR lpAppName,
     LPCWSTR lpKeyName,
     LPCWSTR lpDefault,
     LPWSTR lpReturnedString,
         DWORD nSize
#pragma endregion
BOOL
__stdcall
WriteProfileStringA(
     LPCSTR lpAppName,
     LPCSTR lpKeyName,
     LPCSTR lpString
BOOL
__stdcall
WriteProfileStringW(
     LPCWSTR lpAppName,
     LPCWSTR lpKeyName,
     LPCWSTR lpString
#pragma endregion
DWORD
__stdcall
GetProfileSectionA(
     LPCSTR lpAppName,
     DWORD nSize
DWORD
__stdcall
GetProfileSectionW(
     LPCWSTR lpAppName,
     DWORD nSize
#pragma endregion
BOOL
__stdcall
WriteProfileSectionA(
     LPCSTR lpAppName,
     LPCSTR lpString
BOOL
__stdcall
WriteProfileSectionW(
     LPCWSTR lpAppName,
     LPCWSTR lpString
#pragma endregion
UINT
__stdcall
GetPrivateProfileIntA(
         LPCSTR lpAppName,
         LPCSTR lpKeyName,
         INT nDefault,
     LPCSTR lpFileName
UINT
__stdcall
GetPrivateProfileIntW(
         LPCWSTR lpAppName,
         LPCWSTR lpKeyName,
         INT nDefault,
     LPCWSTR lpFileName
#line 4397 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
DWORD
__stdcall
GetPrivateProfileStringA(
     LPCSTR lpAppName,
     LPCSTR lpKeyName,
     LPCSTR lpDefault,
         DWORD nSize,
     LPCSTR lpFileName
DWORD
__stdcall
GetPrivateProfileStringW(
     LPCWSTR lpAppName,
     LPCWSTR lpKeyName,
     LPCWSTR lpDefault,
         DWORD nSize,
     LPCWSTR lpFileName
#line 4453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
WritePrivateProfileStringA(
     LPCSTR lpAppName,
     LPCSTR lpKeyName,
     LPCSTR lpString,
     LPCSTR lpFileName
BOOL
__stdcall
WritePrivateProfileStringW(
     LPCWSTR lpAppName,
     LPCWSTR lpKeyName,
     LPCWSTR lpString,
     LPCWSTR lpFileName
DWORD
__stdcall
GetPrivateProfileSectionA(
         LPCSTR lpAppName,
         DWORD nSize,
     LPCSTR lpFileName
DWORD
__stdcall
GetPrivateProfileSectionW(
         LPCWSTR lpAppName,
         DWORD nSize,
     LPCWSTR lpFileName
#line 4525 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
WritePrivateProfileSectionA(
     LPCSTR lpAppName,
     LPCSTR lpString,
     LPCSTR lpFileName
BOOL
__stdcall
WritePrivateProfileSectionW(
     LPCWSTR lpAppName,
     LPCWSTR lpString,
     LPCWSTR lpFileName
#pragma endregion
DWORD
__stdcall
GetPrivateProfileSectionNamesA(
     LPSTR lpszReturnBuffer,
         DWORD nSize,
     LPCSTR lpFileName
DWORD
__stdcall
GetPrivateProfileSectionNamesW(
     LPWSTR lpszReturnBuffer,
         DWORD nSize,
     LPCWSTR lpFileName
#line 4597 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
GetPrivateProfileStructA(
         LPCSTR lpszSection,
         LPCSTR lpszKey,
     LPVOID   lpStruct,
         UINT     uSizeStruct,
     LPCSTR szFile
BOOL
__stdcall
GetPrivateProfileStructW(
         LPCWSTR lpszSection,
         LPCWSTR lpszKey,
     LPVOID   lpStruct,
         UINT     uSizeStruct,
     LPCWSTR szFile
#line 4649 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
WritePrivateProfileStructA(
         LPCSTR lpszSection,
         LPCSTR lpszKey,
     LPVOID lpStruct,
         UINT     uSizeStruct,
     LPCSTR szFile
BOOL
__stdcall
WritePrivateProfileStructW(
         LPCWSTR lpszKey,
     LPVOID lpStruct,
         UINT     uSizeStruct,
     LPCWSTR szFile
#line 4699 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOLEAN
__stdcall
Wow64EnableWow64FsRedirection (
     BOOLEAN Wow64FsEnableRedirection
typedef UINT (__stdcall* PGET_SYSTEM_WOW64_DIRECTORY_A)( LPSTR lpBuffer,  UINT uSize);
typedef UINT (__stdcall* PGET_SYSTEM_WOW64_DIRECTORY_W)( LPWSTR lpBuffer,  UINT uSize);
#line 4727 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 4737 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 4758 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 4778 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
SetDllDirectoryA(
     LPCSTR lpPathName
BOOL
__stdcall
SetDllDirectoryW(
     LPCWSTR lpPathName
DWORD
__stdcall
GetDllDirectoryA(
     LPSTR lpBuffer
DWORD
__stdcall
GetDllDirectoryW(
     LPWSTR lpBuffer
BOOL
__stdcall
SetSearchPathMode (
     DWORD Flags
#pragma endregion
#line 4860 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
BOOL
__stdcall
CreateDirectoryExA(
         LPCSTR lpTemplateDirectory,
         LPCSTR lpNewDirectory,
BOOL
__stdcall
CreateDirectoryExW(
         LPCWSTR lpTemplateDirectory,
         LPCWSTR lpNewDirectory,
#pragma endregion
BOOL
__stdcall
CreateDirectoryTransactedA(
     LPSECURITY_ATTRIBUTES lpSecurityAttributes,
         HANDLE hTransaction
BOOL
__stdcall
CreateDirectoryTransactedW(
         HANDLE hTransaction
BOOL
__stdcall
RemoveDirectoryTransactedA(
     LPCSTR lpPathName,
         HANDLE hTransaction
BOOL
__stdcall
RemoveDirectoryTransactedW(
     LPCWSTR lpPathName,
         HANDLE hTransaction
DWORD
__stdcall
GetFullPathNameTransactedA(
                LPCSTR lpFileName,
     LPSTR lpBuffer,
     LPSTR *lpFilePart,
                HANDLE hTransaction
DWORD
__stdcall
GetFullPathNameTransactedW(
                LPCWSTR lpFileName,
     LPWSTR lpBuffer,
     LPWSTR *lpFilePart,
                HANDLE hTransaction
#pragma endregion
BOOL
__stdcall
DefineDosDeviceA(
         DWORD dwFlags,
         LPCSTR lpDeviceName,
     LPCSTR lpTargetPath
DWORD
__stdcall
QueryDosDeviceA(
     LPSTR lpTargetPath,
         DWORD ucchMax
#pragma endregion
HANDLE
__stdcall
CreateFileTransactedA(
           LPCSTR lpFileName,
           DWORD dwShareMode,
           DWORD dwCreationDisposition,
           DWORD dwFlagsAndAttributes,
       HANDLE hTemplateFile,
           HANDLE hTransaction,
       PUSHORT pusMiniVersion,
     PVOID  lpExtendedParameter
HANDLE
__stdcall
CreateFileTransactedW(
           LPCWSTR lpFileName,
           DWORD dwShareMode,
#pragma endregion
HANDLE
__stdcall
ReOpenFile(
     HANDLE  hOriginalFile,
     DWORD   dwShareMode,
#pragma endregion
BOOL
__stdcall
SetFileAttributesTransactedA(
         LPCSTR lpFileName,
         DWORD dwFileAttributes,
         HANDLE hTransaction
BOOL
__stdcall
SetFileAttributesTransactedW(
         LPCWSTR lpFileName,
         HANDLE hTransaction
BOOL
__stdcall
GetFileAttributesTransactedA(
      LPCSTR lpFileName,
      GET_FILEEX_INFO_LEVELS fInfoLevelId,
     LPVOID lpFileInformation,
         HANDLE hTransaction
BOOL
__stdcall
GetFileAttributesTransactedW(
      LPCWSTR lpFileName,
         HANDLE hTransaction
DWORD
__stdcall
GetCompressedFileSizeTransactedA(
          LPCSTR lpFileName,
     LPDWORD  lpFileSizeHigh,
          HANDLE hTransaction
DWORD
__stdcall
GetCompressedFileSizeTransactedW(
          LPCWSTR lpFileName,
          HANDLE hTransaction
BOOL
__stdcall
DeleteFileTransactedA(
         LPCSTR lpFileName,
         HANDLE hTransaction
BOOL
__stdcall
DeleteFileTransactedW(
         LPCWSTR lpFileName,
         HANDLE hTransaction
#pragma endregion
#line 5197 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
BOOL
__stdcall
CheckNameLegalDOS8Dot3A(
          LPCSTR lpName,
     LPSTR lpOemName,
          DWORD OemNameSize,
     PBOOL pbNameContainsSpaces ,
         PBOOL pbNameLegal
BOOL
__stdcall
CheckNameLegalDOS8Dot3W(
          LPCWSTR lpName,
     LPSTR lpOemName,
          DWORD OemNameSize,
         PBOOL pbNameLegal
#pragma endregion
HANDLE
__stdcall
FindFirstFileTransactedA(
           LPCSTR lpFileName,
           FINDEX_INFO_LEVELS fInfoLevelId,
     LPVOID lpFindFileData,
           FINDEX_SEARCH_OPS fSearchOp,
     LPVOID lpSearchFilter,
           DWORD dwAdditionalFlags,
           HANDLE hTransaction
HANDLE
__stdcall
FindFirstFileTransactedW(
           LPCWSTR lpFileName,
           HANDLE hTransaction
#pragma endregion
BOOL
__stdcall
CopyFileA(
     LPCSTR lpExistingFileName,
     LPCSTR lpNewFileName,
     BOOL bFailIfExists
BOOL
__stdcall
CopyFileW(
     LPCWSTR lpExistingFileName,
     LPCWSTR lpNewFileName,
     BOOL bFailIfExists
#line 5328 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
typedef
DWORD
(__stdcall *LPPROGRESS_ROUTINE)(
         LARGE_INTEGER TotalFileSize,
         LARGE_INTEGER TotalBytesTransferred,
         LARGE_INTEGER StreamSize,
         LARGE_INTEGER StreamBytesTransferred,
         DWORD dwStreamNumber,
         DWORD dwCallbackReason,
         HANDLE hSourceFile,
         HANDLE hDestinationFile,
     LPVOID lpData
BOOL
__stdcall
CopyFileExA(
        LPPROGRESS_ROUTINE lpProgressRoutine,
        LPVOID lpData,
     LPBOOL pbCancel,
            DWORD dwCopyFlags
BOOL
__stdcall
CopyFileExW(
        LPVOID lpData,
     LPBOOL pbCancel,
            DWORD dwCopyFlags
#pragma endregion
BOOL
__stdcall
CopyFileTransactedA(
     LPVOID lpData,
     LPBOOL pbCancel,
         DWORD dwCopyFlags,
         HANDLE hTransaction
BOOL
__stdcall
CopyFileTransactedW(
     LPVOID lpData,
     LPBOOL pbCancel,
         DWORD dwCopyFlags,
         HANDLE hTransaction
#pragma endregion
typedef enum _COPYFILE2_MESSAGE_TYPE {
     COPYFILE2_CALLBACK_NONE = 0,
     COPYFILE2_CALLBACK_CHUNK_STARTED,
     COPYFILE2_CALLBACK_CHUNK_FINISHED,
     COPYFILE2_CALLBACK_STREAM_STARTED,
     COPYFILE2_CALLBACK_STREAM_FINISHED,
     COPYFILE2_CALLBACK_POLL_CONTINUE,
     COPYFILE2_CALLBACK_ERROR,
     COPYFILE2_CALLBACK_MAX,
} COPYFILE2_MESSAGE_TYPE;
typedef enum _COPYFILE2_MESSAGE_ACTION {
    COPYFILE2_PROGRESS_CONTINUE = 0,
    COPYFILE2_PROGRESS_CANCEL,
    COPYFILE2_PROGRESS_STOP,
    COPYFILE2_PROGRESS_QUIET,
    COPYFILE2_PROGRESS_PAUSE,
} COPYFILE2_MESSAGE_ACTION;
typedef enum _COPYFILE2_COPY_PHASE {
    COPYFILE2_PHASE_NONE = 0,
    COPYFILE2_PHASE_PREPARE_SOURCE,
    COPYFILE2_PHASE_PREPARE_DEST,
    COPYFILE2_PHASE_READ_SOURCE,
    COPYFILE2_PHASE_WRITE_DESTINATION,
    COPYFILE2_PHASE_SERVER_COPY,
    COPYFILE2_PHASE_NAMEGRAFT_COPY,
    COPYFILE2_PHASE_MAX,
} COPYFILE2_COPY_PHASE;
typedef struct COPYFILE2_MESSAGE {
    COPYFILE2_MESSAGE_TYPE  Type;
    DWORD                   dwPadding;
    union {
        struct {
            DWORD           dwStreamNumber;
            DWORD           dwReserved;
            HANDLE           hSourceFile;
            HANDLE           hDestinationFile;
            ULARGE_INTEGER  uliChunkNumber;
            ULARGE_INTEGER  uliChunkSize;
            ULARGE_INTEGER  uliStreamSize;
            ULARGE_INTEGER  uliTotalFileSize;
        } ChunkStarted;
        struct {
            DWORD           dwFlags;
            HANDLE           hSourceFile;
            ULARGE_INTEGER  uliStreamBytesTransferred;
            ULARGE_INTEGER  uliTotalBytesTransferred;
        } ChunkFinished;
        struct {
            DWORD           dwReserved;
            HANDLE           hSourceFile;
        } StreamStarted;
        struct {
            DWORD           dwReserved;
            HANDLE           hSourceFile;
        } StreamFinished;
        struct {
            DWORD           dwReserved;
        } PollContinue;
        struct {
            COPYFILE2_COPY_PHASE    CopyPhase;
            HRESULT                 hrFailure;
            DWORD                   dwReserved;
        } Error;
    } Info;
} COPYFILE2_MESSAGE;
typedef
COPYFILE2_MESSAGE_ACTION (__stdcall *PCOPYFILE2_PROGRESS_ROUTINE)(
        const COPYFILE2_MESSAGE     *pMessage,
typedef struct COPYFILE2_EXTENDED_PARAMETERS {
  DWORD                         dwSize;
  DWORD                         dwCopyFlags;
  BOOL                          *pfCancel;
  PCOPYFILE2_PROGRESS_ROUTINE   pProgressRoutine;
  PVOID                         pvCallbackContext;
} COPYFILE2_EXTENDED_PARAMETERS;
HRESULT
__stdcall
CopyFile2(
        PCWSTR                          pwszExistingFileName,
        PCWSTR                          pwszNewFileName,
    COPYFILE2_EXTENDED_PARAMETERS   *pExtendedParameters
#pragma endregion
BOOL
__stdcall
MoveFileA(
BOOL
__stdcall
MoveFileW(
#line 5609 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
#pragma region Application Family or OneCore Family
BOOL
__stdcall
MoveFileExA(
         DWORD    dwFlags
BOOL
__stdcall
MoveFileExW(
         DWORD    dwFlags
#pragma endregion
BOOL
__stdcall
MoveFileWithProgressA(
     LPVOID lpData,
         DWORD dwFlags
BOOL
__stdcall
MoveFileWithProgressW(
     LPVOID lpData,
         DWORD dwFlags
#line 5671 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
BOOL
__stdcall
MoveFileTransactedA(
     LPVOID lpData,
         DWORD dwFlags,
         HANDLE hTransaction
BOOL
__stdcall
MoveFileTransactedW(
     LPVOID lpData,
         DWORD dwFlags,
         HANDLE hTransaction
#line 5707 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
#line 5722 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
#pragma endregion
BOOL
__stdcall
ReplaceFileA(
           LPCSTR lpReplacedFileName,
           LPCSTR lpReplacementFileName,
       LPCSTR lpBackupFileName,
           DWORD    dwReplaceFlags,
     LPVOID   lpExclude,
     LPVOID  lpReserved
BOOL
__stdcall
ReplaceFileW(
           LPCWSTR lpReplacedFileName,
           LPCWSTR lpReplacementFileName,
       LPCWSTR lpBackupFileName,
     LPVOID   lpExclude,
     LPVOID  lpReserved
#line 5766 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
BOOL
__stdcall
CreateHardLinkA(
           LPCSTR lpFileName,
BOOL
__stdcall
CreateHardLinkW(
           LPCWSTR lpFileName,
#pragma endregion
BOOL
__stdcall
CreateHardLinkTransactedA(
           LPCSTR lpFileName,
           HANDLE hTransaction
BOOL
__stdcall
CreateHardLinkTransactedW(
           LPCWSTR lpFileName,
           HANDLE hTransaction
HANDLE
__stdcall
FindFirstStreamTransactedW (
           LPCWSTR lpFileName,
           STREAM_INFO_LEVELS InfoLevel,
     LPVOID lpFindStreamData,
     DWORD dwFlags,
           HANDLE hTransaction
HANDLE
__stdcall
FindFirstFileNameTransactedW (
         LPCWSTR lpFileName,
         DWORD dwFlags,
      LPDWORD StringLength,
     PWSTR LinkName,
     HANDLE hTransaction
#pragma endregion
HANDLE
__stdcall
CreateNamedPipeA(
         LPCSTR lpName,
         DWORD dwOpenMode,
         DWORD dwPipeMode,
         DWORD nMaxInstances,
         DWORD nOutBufferSize,
         DWORD nInBufferSize,
         DWORD nDefaultTimeOut,
#pragma endregion
BOOL
__stdcall
GetNamedPipeHandleStateA(
          HANDLE hNamedPipe,
     LPDWORD lpState,
     LPDWORD lpCurInstances,
     LPDWORD lpMaxCollectionCount,
     LPDWORD lpCollectDataTimeout,
     LPSTR lpUserName,
          DWORD nMaxUserNameSize
BOOL
__stdcall
CallNamedPipeA(
      LPCSTR lpNamedPipeName,
     LPVOID lpInBuffer,
     LPVOID lpOutBuffer,
     LPDWORD lpBytesRead,
      DWORD nTimeOut
BOOL
__stdcall
WaitNamedPipeA(
     DWORD nTimeOut
#pragma endregion
#pragma endregion
BOOL
__stdcall
GetNamedPipeClientComputerNameA(
     HANDLE Pipe,
      LPSTR ClientComputerName,
     ULONG ClientComputerNameLength
#pragma endregion
BOOL
__stdcall
GetNamedPipeClientProcessId(
     HANDLE Pipe,
     PULONG ClientProcessId
BOOL
__stdcall
GetNamedPipeClientSessionId(
     HANDLE Pipe,
     PULONG ClientSessionId
BOOL
__stdcall
GetNamedPipeServerProcessId(
     HANDLE Pipe,
     PULONG ServerProcessId
BOOL
__stdcall
GetNamedPipeServerSessionId(
     HANDLE Pipe,
     PULONG ServerSessionId
#pragma endregion
#pragma region Application Family or Desktop Family
BOOL
__stdcall
SetVolumeLabelA(
     LPCSTR lpRootPathName,
     LPCSTR lpVolumeName
BOOL
__stdcall
SetVolumeLabelW(
     LPCWSTR lpRootPathName,
     LPCWSTR lpVolumeName
#pragma endregion
BOOL
__stdcall
SetFileBandwidthReservation(
      HANDLE  hFile,
      DWORD   nPeriodMilliseconds,
      DWORD   nBytesPerPeriod,
      BOOL    bDiscardable,
     LPDWORD lpTransferSize,
     LPDWORD lpNumOutstandingRequests
BOOL
__stdcall
GetFileBandwidthReservation(
      HANDLE  hFile,
     LPDWORD lpPeriodMilliseconds,
     LPDWORD lpBytesPerPeriod,
     LPBOOL  pDiscardable,
BOOL
__stdcall
ClearEventLogA (
         HANDLE hEventLog,
BOOL
__stdcall
ClearEventLogW (
         HANDLE hEventLog,
BOOL
__stdcall
BackupEventLogA (
     HANDLE hEventLog,
BOOL
__stdcall
BackupEventLogW (
     HANDLE hEventLog,
BOOL
__stdcall
CloseEventLog (
     HANDLE hEventLog
BOOL
__stdcall
DeregisterEventSource (
     HANDLE hEventLog
BOOL
__stdcall
NotifyChangeEventLog(
     HANDLE  hEventLog,
     HANDLE  hEvent
BOOL
__stdcall
GetNumberOfEventLogRecords (
      HANDLE hEventLog,
     PDWORD NumberOfRecords
BOOL
__stdcall
GetOldestEventLogRecord (
      HANDLE hEventLog,
     PDWORD OldestRecord
HANDLE
__stdcall
OpenEventLogA (
     LPCSTR lpUNCServerName,
         LPCSTR lpSourceName
HANDLE
__stdcall
OpenEventLogW (
     LPCWSTR lpUNCServerName,
         LPCWSTR lpSourceName
HANDLE
__stdcall
RegisterEventSourceA (
         LPCSTR lpSourceName
HANDLE
__stdcall
RegisterEventSourceW (
HANDLE
__stdcall
OpenBackupEventLogA (
         LPCSTR lpFileName
HANDLE
__stdcall
OpenBackupEventLogW (
         LPCWSTR lpFileName
BOOL
__stdcall
ReadEventLogA (
      HANDLE     hEventLog,
      DWORD      dwReadFlags,
      DWORD      dwRecordOffset,
     LPVOID     lpBuffer,
     DWORD      *pnBytesRead,
     DWORD      *pnMinNumberOfBytesNeeded
BOOL
__stdcall
ReadEventLogW (
      HANDLE     hEventLog,
      DWORD      dwReadFlags,
     LPVOID     lpBuffer,
     DWORD      *pnBytesRead,
BOOL
__stdcall
ReportEventA (
         HANDLE     hEventLog,
         WORD       wType,
         WORD       wCategory,
         DWORD      dwEventID,
     PSID       lpUserSid,
         WORD       wNumStrings,
         DWORD      dwDataSize,
     LPCSTR *lpStrings,
     LPVOID lpRawData
BOOL
__stdcall
ReportEventW (
         HANDLE     hEventLog,
         WORD       wType,
         WORD       wCategory,
         DWORD      dwEventID,
     PSID       lpUserSid,
         WORD       wNumStrings,
         DWORD      dwDataSize,
     LPCWSTR *lpStrings,
     LPVOID lpRawData
typedef struct _EVENTLOG_FULL_INFORMATION
    DWORD    dwFull;
EVENTLOG_FULL_INFORMATION, *LPEVENTLOG_FULL_INFORMATION;
BOOL
__stdcall
GetEventLogInformation (
      HANDLE     hEventLog,
      DWORD      dwInfoLevel,
     LPVOID lpBuffer,
      DWORD      cbBufSize,
     LPDWORD    pcbBytesNeeded
typedef ULONG OPERATION_ID;
typedef struct _OPERATION_START_PARAMETERS {
    ULONG Version;
    OPERATION_ID OperationId;
    ULONG Flags;
} OPERATION_START_PARAMETERS, *POPERATION_START_PARAMETERS;
typedef struct _OPERATION_END_PARAMETERS {
    ULONG Version;
    ULONG Flags;
} OPERATION_END_PARAMETERS, *POPERATION_END_PARAMETERS;
BOOL
__stdcall
OperationStart (
     OPERATION_START_PARAMETERS* OperationStartParams
BOOL
__stdcall
OperationEnd (
     OPERATION_END_PARAMETERS* OperationEndParams
BOOL
__stdcall
AccessCheckAndAuditAlarmA (
         LPCSTR SubsystemName,
     LPVOID HandleId,
         LPSTR ObjectTypeName,
     LPSTR ObjectName,
         DWORD DesiredAccess,
BOOL
__stdcall
AccessCheckByTypeAndAuditAlarmA (
         LPVOID HandleId,
         LPCSTR ObjectTypeName,
     LPCSTR ObjectName,
         DWORD Flags,
BOOL
__stdcall
AccessCheckByTypeResultListAndAuditAlarmA (
         LPVOID HandleId,
     LPCSTR ObjectName,
         DWORD Flags,
BOOL
__stdcall
AccessCheckByTypeResultListAndAuditAlarmByHandleA (
         LPVOID HandleId,
         HANDLE ClientToken,
     LPCSTR ObjectName,
         DWORD Flags,
BOOL
__stdcall
ObjectOpenAuditAlarmA (
         LPVOID HandleId,
     LPSTR ObjectName,
         HANDLE ClientToken,
         BOOL AccessGranted,
BOOL
__stdcall
ObjectPrivilegeAuditAlarmA (
     LPVOID HandleId,
     HANDLE ClientToken,
     BOOL AccessGranted
BOOL
__stdcall
ObjectCloseAuditAlarmA (
     LPVOID HandleId,
BOOL
__stdcall
ObjectDeleteAuditAlarmA (
     LPVOID HandleId,
BOOL
__stdcall
PrivilegedServiceAuditAlarmA (
     LPCSTR ServiceName,
     HANDLE ClientToken,
     BOOL AccessGranted
BOOL
__stdcall
AddConditionalAce (
     PACL pAcl,
        DWORD AceFlags,
        UCHAR AceType,
        DWORD AccessMask,
        PSID pSid,
      PWCHAR ConditionStr,
     DWORD *ReturnLength
#pragma endregion
BOOL
__stdcall
SetFileSecurityA (
     LPCSTR lpFileName,
BOOL
__stdcall
GetFileSecurityA (
      LPCSTR lpFileName,
      DWORD nLength,
#pragma endregion
BOOL
__stdcall
ReadDirectoryChangesW(
            HANDLE hDirectory,
     LPVOID lpBuffer,
            BOOL bWatchSubtree,
            DWORD dwNotifyFilter,
       LPDWORD lpBytesReturned,
     LPOVERLAPPED lpOverlapped,
        LPOVERLAPPED_COMPLETION_ROUTINE lpCompletionRoutine
BOOL
__stdcall
ReadDirectoryChangesExW(
            HANDLE hDirectory,
     LPVOID lpBuffer,
            BOOL bWatchSubtree,
        LPOVERLAPPED_COMPLETION_ROUTINE lpCompletionRoutine,
            READ_DIRECTORY_NOTIFY_INFORMATION_CLASS ReadDirectoryNotifyInformationClass
#pragma endregion
LPVOID
__stdcall
MapViewOfFileExNuma(
         HANDLE hFileMappingObject,
         DWORD dwFileOffsetHigh,
         DWORD dwFileOffsetLow,
         SIZE_T dwNumberOfBytesToMap,
     LPVOID lpBaseAddress,
         DWORD nndPreferred
BOOL
__stdcall
IsBadReadPtr(
     const void *lp,
         UINT_PTR ucb
BOOL
__stdcall
IsBadWritePtr(
     LPVOID lp,
         UINT_PTR ucb
BOOL
__stdcall
IsBadHugeReadPtr(
     const void *lp,
         UINT_PTR ucb
BOOL
__stdcall
IsBadHugeWritePtr(
     LPVOID lp,
         UINT_PTR ucb
BOOL
__stdcall
IsBadCodePtr(
     FARPROC lpfn
BOOL
__stdcall
IsBadStringPtrA(
     LPCSTR lpsz,
         UINT_PTR ucchMax
BOOL
__stdcall
IsBadStringPtrW(
     LPCWSTR lpsz,
         UINT_PTR ucchMax
#pragma endregion
 BOOL
__stdcall
LookupAccountSidA(
     LPCSTR lpSystemName,
     PSID Sid,
     LPSTR Name,
      LPDWORD cchName,
     LPSTR ReferencedDomainName,
     LPDWORD cchReferencedDomainName,
     PSID_NAME_USE peUse
 BOOL
__stdcall
LookupAccountSidW(
     LPCWSTR lpSystemName,
     PSID Sid,
     LPWSTR Name,
      LPDWORD cchName,
     LPWSTR ReferencedDomainName,
     PSID_NAME_USE peUse
 BOOL
__stdcall
LookupAccountNameA(
         LPCSTR lpAccountName,
     PSID Sid,
      LPDWORD cbSid,
        PSID_NAME_USE peUse
 BOOL
__stdcall
LookupAccountNameW(
         LPCWSTR lpAccountName,
     PSID Sid,
      LPDWORD cbSid,
        PSID_NAME_USE peUse
#pragma endregion
 BOOL
__stdcall
LookupAccountNameLocalA(
     PSID Sid,
      LPDWORD cbSid,
        PSID_NAME_USE peUse
 BOOL
__stdcall
LookupAccountNameLocalW(
     PSID Sid,
      LPDWORD cbSid,
        PSID_NAME_USE peUse
 BOOL
__stdcall
LookupAccountSidLocalA(
     PSID Sid,
     LPSTR Name,
      LPDWORD cchName,
     PSID_NAME_USE peUse
 BOOL
__stdcall
LookupAccountSidLocalW(
     PSID Sid,
     LPWSTR Name,
      LPDWORD cchName,
     PSID_NAME_USE peUse
#line 6844 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#pragma endregion
BOOL
__stdcall
LookupPrivilegeValueA(
         LPCSTR lpName,
        PLUID   lpLuid
BOOL
__stdcall
LookupPrivilegeValueW(
         LPCWSTR lpName,
        PLUID   lpLuid
 BOOL
__stdcall
LookupPrivilegeNameA(
         PLUID   lpLuid,
     LPSTR lpName,
      LPDWORD cchName
 BOOL
__stdcall
LookupPrivilegeNameW(
         PLUID   lpLuid,
     LPWSTR lpName,
      LPDWORD cchName
 BOOL
__stdcall
LookupPrivilegeDisplayNameA(
         LPCSTR lpName,
     LPSTR lpDisplayName,
      LPDWORD cchDisplayName,
        LPDWORD lpLanguageId
 BOOL
__stdcall
LookupPrivilegeDisplayNameW(
         LPCWSTR lpName,
     LPWSTR lpDisplayName,
#pragma endregion
BOOL
__stdcall
BuildCommDCBA(
      LPCSTR lpDef,
     LPDCB lpDCB
BOOL
__stdcall
BuildCommDCBW(
      LPCWSTR lpDef,
     LPDCB lpDCB
BOOL
__stdcall
BuildCommDCBAndTimeoutsA(
      LPCSTR lpDef,
     LPDCB lpDCB,
BOOL
__stdcall
BuildCommDCBAndTimeoutsW(
      LPCWSTR lpDef,
     LPDCB lpDCB,
BOOL
__stdcall
CommConfigDialogA(
         LPCSTR lpszName,
     HWND hWnd,
      LPCOMMCONFIG lpCC
BOOL
__stdcall
CommConfigDialogW(
         LPCWSTR lpszName,
     HWND hWnd,
      LPCOMMCONFIG lpCC
BOOL
__stdcall
GetDefaultCommConfigA(
        LPCSTR lpszName,
     LPCOMMCONFIG lpCC,
     LPDWORD lpdwSize
BOOL
__stdcall
GetDefaultCommConfigW(
        LPCWSTR lpszName,
     LPCOMMCONFIG lpCC,
     LPDWORD lpdwSize
BOOL
__stdcall
SetDefaultCommConfigA(
     LPCSTR lpszName,
     LPCOMMCONFIG lpCC,
     DWORD dwSize
BOOL
__stdcall
SetDefaultCommConfigW(
     LPCWSTR lpszName,
     LPCOMMCONFIG lpCC,
     DWORD dwSize
#pragma endregion
BOOL
__stdcall
GetComputerNameA (
     LPSTR lpBuffer,
     LPDWORD nSize
BOOL
__stdcall
GetComputerNameW (
     LPWSTR lpBuffer,
     LPDWORD nSize
#pragma endregion
BOOL
__stdcall
DnsHostnameToComputerNameA (
        LPCSTR Hostname,
     LPSTR ComputerName,
     LPDWORD nSize
BOOL
__stdcall
DnsHostnameToComputerNameW (
        LPCWSTR Hostname,
     LPWSTR ComputerName,
     LPDWORD nSize
BOOL
__stdcall
GetUserNameA (
     LPSTR lpBuffer,
     LPDWORD pcbBuffer
BOOL
__stdcall
GetUserNameW (
     LPWSTR lpBuffer,
     LPDWORD pcbBuffer
#line 7139 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
#line 7151 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
LogonUserA (
            LPCSTR lpszUsername,
        LPCSTR lpszDomain,
        LPCSTR lpszPassword,
            DWORD dwLogonType,
            DWORD dwLogonProvider,
     PHANDLE phToken
BOOL
__stdcall
LogonUserW (
            LPCWSTR lpszUsername,
        LPCWSTR lpszDomain,
        LPCWSTR lpszPassword,
            DWORD dwLogonType,
     PHANDLE phToken
BOOL
__stdcall
LogonUserExA (
            LPCSTR lpszDomain,
                DWORD dwLogonType,
     PHANDLE phToken,
     PSID  *ppLogonSid,
     PVOID *ppProfileBuffer,
           LPDWORD pdwProfileLength,
           PQUOTA_LIMITS pQuotaLimits
BOOL
__stdcall
LogonUserExW (
            LPCWSTR lpszDomain,
                DWORD dwLogonType,
     PHANDLE phToken,
     PSID  *ppLogonSid,
#pragma endregion
 BOOL
__stdcall
CreateProcessWithLogonW(
            LPCWSTR lpUsername,
        LPCWSTR lpDomain,
            LPCWSTR lpPassword,
            DWORD dwLogonFlags,
        LPCWSTR lpApplicationName,
     LPWSTR lpCommandLine,
            DWORD dwCreationFlags,
        LPVOID lpEnvironment,
        LPCWSTR lpCurrentDirectory,
            LPSTARTUPINFOW lpStartupInfo,
           LPPROCESS_INFORMATION lpProcessInformation
 BOOL
__stdcall
CreateProcessWithTokenW(
            HANDLE hToken,
            DWORD dwLogonFlags,
BOOL
__stdcall
IsTokenUntrusted(
     HANDLE TokenHandle
BOOL
__stdcall
RegisterWaitForSingleObject(
     PHANDLE phNewWaitObject,
            HANDLE hObject,
            WAITORTIMERCALLBACK Callback,
        PVOID Context,
            ULONG dwMilliseconds,
            ULONG dwFlags
BOOL
__stdcall
UnregisterWait(
     HANDLE WaitHandle
BOOL
__stdcall
BindIoCompletionCallback (
     HANDLE FileHandle,
     LPOVERLAPPED_COMPLETION_ROUTINE Function,
     ULONG Flags
HANDLE
__stdcall
SetTimerQueueTimer(
     HANDLE TimerQueue,
     PVOID Parameter,
         DWORD DueTime,
         DWORD Period,
         BOOL PreferIo
BOOL
__stdcall
CancelTimerQueueTimer(
     HANDLE TimerQueue,
         HANDLE Timer
BOOL
__stdcall
DeleteTimerQueue(
     HANDLE TimerQueue
__forceinline
void
InitializeThreadpoolEnvironment(
     PTP_CALLBACK_ENVIRON pcbe
    TpInitializeCallbackEnviron(pcbe);
__forceinline
void
SetThreadpoolCallbackPool(
     PTP_CALLBACK_ENVIRON pcbe,
        PTP_POOL             ptpp
    TpSetCallbackThreadpool(pcbe, ptpp);
__forceinline
void
SetThreadpoolCallbackCleanupGroup(
         PTP_CLEANUP_GROUP                 ptpcg,
     PTP_CLEANUP_GROUP_CANCEL_CALLBACK pfng
    TpSetCallbackCleanupGroup(pcbe, ptpcg, pfng);
__forceinline
void
SetThreadpoolCallbackRunsLong(
    TpSetCallbackLongFunction(pcbe);
__forceinline
void
SetThreadpoolCallbackLibrary(
        PVOID                mod
    TpSetCallbackRaceWithDll(pcbe, mod);
__forceinline
void
SetThreadpoolCallbackPriority(
        TP_CALLBACK_PRIORITY Priority
    TpSetCallbackPriority(pcbe, Priority);
__forceinline
void
DestroyThreadpoolEnvironment(
    TpDestroyCallbackEnviron(pcbe);
__forceinline
void
SetThreadpoolCallbackPersistent(
    TpSetCallbackPersistent(pcbe);
#pragma endregion
HANDLE
__stdcall
CreatePrivateNamespaceA(
         LPCSTR lpAliasPrefix
HANDLE
__stdcall
OpenPrivateNamespaceA(
HANDLE
__stdcall
CreateBoundaryDescriptorA(
     LPCSTR Name,
     ULONG Flags
#pragma endregion
BOOL
__stdcall
AddIntegrityLabelToBoundaryDescriptor(
     HANDLE * BoundaryDescriptor,
     PSID IntegrityLabel
#pragma endregion
typedef struct tagHW_PROFILE_INFOA {
    DWORD  dwDockInfo;
    CHAR   szHwProfileGuid[39];
    CHAR   szHwProfileName[80];
} HW_PROFILE_INFOA, *LPHW_PROFILE_INFOA;
typedef struct tagHW_PROFILE_INFOW {
    DWORD  dwDockInfo;
    WCHAR  szHwProfileGuid[39];
    WCHAR  szHwProfileName[80];
} HW_PROFILE_INFOW, *LPHW_PROFILE_INFOW;
typedef HW_PROFILE_INFOA HW_PROFILE_INFO;
typedef LPHW_PROFILE_INFOA LPHW_PROFILE_INFO;
BOOL
__stdcall
GetCurrentHwProfileA (
     LPHW_PROFILE_INFOA  lpHwProfileInfo
BOOL
__stdcall
GetCurrentHwProfileW (
     LPHW_PROFILE_INFOW  lpHwProfileInfo
#line 7588 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\um\\winbase.h"
BOOL
__stdcall
VerifyVersionInfoA(
     LPOSVERSIONINFOEXA lpVersionInformation,
        DWORD dwTypeMask,
        DWORDLONG dwlConditionMask
BOOL
__stdcall
VerifyVersionInfoW(
     LPOSVERSIONINFOEXW lpVersionInformation,
        DWORD dwTypeMask,
#pragma endregion
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
#pragma once
#line 23 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
#line 202 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
__forceinline  HRESULT HRESULT_FROM_WIN32(unsigned long x) { return (HRESULT)(x) <= 0 ? (HRESULT)(x) : (HRESULT) (((x) & 0x0000FFFF) | (7 << 16) | 0x80000000);}
#line 28738 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
#line 29723 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
#line 30012 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
#line 45990 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winerror.h"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                Defined "HAVE_WS2TCPIP_H" to "1"
TEST check from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: endian.h
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "endian.h"
  #include <endian.h>
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conffix.h"
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Possible ERROR while running preprocessor: exit code 512
stdout:
conftest.c
  #include <endian.h>
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"Source:
#include "confdefs.h"
#include "conffix.h"
#include <endian.h>
Checking for header: immintrin.h
stdout:
conftest.c
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\wmmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\nmmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\smmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\tmmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\pmmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\emmintrin.h"
#line 33 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\emmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\mmintrin.h"
#line 46 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\mmintrin.h"
#line 54 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\mmintrin.h"
#line 82 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\mmintrin.h"
typedef union __declspec(align(8)) __declspec(intrin_type) __m64 {
    unsigned __int64    m64_u64;
    float               m64_f32[2];
    __int8              m64_i8[8];
    __int16             m64_i16[4];
    __int32             m64_i32[2];
    __int64             m64_i64;
    unsigned __int8     m64_u8[8];
    unsigned __int16    m64_u16[4];
    unsigned __int32    m64_u32[2];
    __int64 __m;
} __m64;
#line 197 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\mmintrin.h"
#line 256 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\mmintrin.h"
#line 25 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 32 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
   typedef union  __declspec(align(16)) __declspec(intrin_type) __m128 {
    float               m128_f32[4];
    unsigned __int64    m128_u64[2];
    __int8              m128_i8[16];
    __int16             m128_i16[8];
    __int32             m128_i32[4];
    __int64             m128_i64[2];
    unsigned __int8     m128_u8[16];
    unsigned __int16    m128_u16[8];
    unsigned __int32    m128_u32[4];
    float f[4];
   } __m128;
#line 66 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
 __declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
     size_t _Count,
     size_t _Size
void* __cdecl calloc(
      size_t _Count,
      size_t _Size
 int __cdecl _callnewh(
     size_t _Size
void* __cdecl _expand(
               void*  _Block,
      size_t _Size
void __cdecl _free_base(
      void* _Block
void __cdecl free(
      void* _Block
void* __cdecl _malloc_base(
     size_t _Size
void* __cdecl malloc(
      size_t _Size
size_t __cdecl _msize_base(
     void* _Block
size_t __cdecl _msize(
     void* _Block
void* __cdecl _realloc_base(
       void*  _Block,
                                size_t _Size
void* __cdecl realloc(
      void*  _Block,
             size_t _Size
void* __cdecl _recalloc_base(
      void*  _Block,
                               size_t _Count,
                               size_t _Size
void* __cdecl _recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size
void __cdecl _aligned_free(
      void* _Block
void* __cdecl _aligned_malloc(
      size_t _Size,
                        size_t _Alignment
void* __cdecl _aligned_offset_malloc(
      size_t _Size,
                        size_t _Alignment,
                        size_t _Offset
size_t __cdecl _aligned_msize(
     void*  _Block,
              size_t _Alignment,
              size_t _Offset
void* __cdecl _aligned_offset_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_offset_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment
void* __cdecl _aligned_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment
#line 225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#line 37 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
typedef struct _heapinfo
    int* _pentry;
    size_t _size;
    int _useflag;
} _HEAPINFO;
void* __cdecl _alloca( size_t _Size);
     intptr_t __cdecl _get_heap_handle(void);
     int __cdecl _heapmin(void);
         int __cdecl _heapwalk( _HEAPINFO* _EntryInfo);
          int __cdecl _heapchk(void);
     int __cdecl _resetstkoflw(void);
    typedef char __static_assert_t[(sizeof(unsigned int) <= 16) != 0];
    #pragma warning(disable:6540)
    __inline void* _MarkAllocaS(  void* _Ptr, unsigned int _Marker)
        if (_Ptr)
            *((unsigned int*)_Ptr) = _Marker;
            _Ptr = (char*)_Ptr + 16;
        return _Ptr;
    __inline size_t _MallocaComputeSize(size_t _Size)
        size_t _MarkedSize = _Size + 16;
        return _MarkedSize > _Size ? _MarkedSize : 0;
    #pragma warning(pop)
#line 126 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
#line 135 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
    #pragma warning(disable: 6014)
    __inline void __cdecl _freea(  void* _Memory)
        unsigned int _Marker;
        if (_Memory)
            _Memory = (char*)_Memory - 16;
            _Marker = *(unsigned int*)_Memory;
            if (_Marker == 0xDDDD)
                free(_Memory);
#line 165 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\malloc.h"
__pragma(pack(pop))
#line 73 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 123 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 134 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 143 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 151 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 343 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 367 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 390 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 407 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\xmmintrin.h"
#line 40 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\emmintrin.h"
typedef struct __declspec(align(16)) __declspec(intrin_type) __m128d {
    double              m128d_f64[2];
} __m128d;
typedef union  __declspec(align(16)) __declspec(intrin_type) __m128i {
#line 56 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\emmintrin.h"
    __int8              m128i_i8[16];
    __int16             m128i_i16[8];
    __int32             m128i_i32[4];
    __int64             m128i_i64[2];
    unsigned __int8     m128i_u8[16];
    unsigned __int16    m128i_u16[8];
    unsigned __int32    m128i_u32[4];
    unsigned __int64    m128i_u64[2];
    char c[16];
} __m128i;
#line 434 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\emmintrin.h"
#line 22 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\pmmintrin.h"
#line 75 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\pmmintrin.h"
extern void __cdecl _mm_monitor(void const *, unsigned, unsigned);
extern void __cdecl _mm_mwait(unsigned, unsigned);
#line 15 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\tmmintrin.h"
#line 97 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\tmmintrin.h"
#line 24 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\smmintrin.h"
#line 45 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\smmintrin.h"
#line 165 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\smmintrin.h"
#line 179 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\smmintrin.h"
#line 279 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\smmintrin.h"
#line 25 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\nmmintrin.h"
#line 137 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\nmmintrin.h"
#line 24 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\wmmintrin.h"
#line 79 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\wmmintrin.h"
#line 15 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 31 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
typedef union  __declspec(align(32)) __declspec(intrin_type) __m256 {
    float m256_f32[8];
} __m256;
typedef struct __declspec(align(32)) __declspec(intrin_type) __m256d {
    double m256d_f64[4];
} __m256d;
typedef union  __declspec(align(32)) __declspec(intrin_type) __m256i {
#line 47 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
    __int8              m256i_i8[32];
    __int16             m256i_i16[16];
    __int32             m256i_i32[8];
    __int64             m256i_i64[4];
    unsigned __int8     m256i_u8[32];
    unsigned __int16    m256i_u16[16];
    unsigned __int32    m256i_u32[8];
    unsigned __int64    m256i_u64[4];
} __m256i;
#line 80 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 121 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern void __cdecl _allow_cpu_features(unsigned __int64);
extern int __cdecl _may_i_use_cpu_feature(unsigned __int64);
#line 181 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern __int64 __cdecl _rdtsc(void);
extern __int64 __cdecl _rdpmc(int);
extern int __cdecl _bswap(int);
extern int __cdecl _bit_scan_forward(int);
extern int __cdecl _bit_scan_reverse(int);
#line 223 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern int __cdecl _popcnt32(int);
extern unsigned short __cdecl _rotwl(unsigned short, int);
extern unsigned short __cdecl _rotwr(unsigned short, int);
extern unsigned int __cdecl _rotl(unsigned int, int);
extern unsigned int __cdecl _rotr(unsigned int, int);
extern unsigned long __cdecl _lrotl(unsigned long, int);
extern unsigned long __cdecl _lrotr(unsigned long, int);
extern unsigned __int64 __cdecl _rotl64(unsigned __int64, int);
extern unsigned __int64 __cdecl _rotr64(unsigned __int64, int);
#line 456 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 475 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 489 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 508 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 531 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1206 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1242 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1250 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1258 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1420 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1437 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1567 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1601 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 1702 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 2288 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern unsigned int     __cdecl _bextr_u32(unsigned int,
                                                  unsigned int,
                                                  unsigned int);
extern unsigned int     __cdecl _bextr2_u32(unsigned int,
                                                   unsigned int);
extern unsigned int     __cdecl _blsi_u32(unsigned int);
extern unsigned int     __cdecl _blsmsk_u32(unsigned int);
extern unsigned int     __cdecl _blsr_u32(unsigned int);
extern unsigned int     __cdecl _bzhi_u32(unsigned int,
                                                 unsigned int);
extern unsigned int     __cdecl _pext_u32(unsigned int,
                                                 unsigned int);
extern unsigned int     __cdecl _pdep_u32(unsigned int,
                                                 unsigned int);
extern unsigned int     __cdecl _andn_u32(unsigned int,
                                                 unsigned int);
#line 2315 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern unsigned __int64 __cdecl _bextr_u64(unsigned __int64,
                                                  unsigned int,
                                                  unsigned int);
extern unsigned __int64 __cdecl _bextr2_u64(unsigned __int64,
                                                   unsigned __int64);
extern unsigned __int64 __cdecl _blsi_u64(unsigned __int64);
extern unsigned __int64 __cdecl _blsmsk_u64(unsigned __int64);
extern unsigned __int64 __cdecl _blsr_u64(unsigned __int64);
extern unsigned __int64 __cdecl _bzhi_u64(unsigned __int64,
                                                 unsigned int);
extern unsigned __int64 __cdecl _pext_u64(unsigned __int64,
                                                 unsigned __int64);
extern unsigned __int64 __cdecl _pdep_u64(unsigned __int64,
                                                 unsigned __int64);
extern unsigned __int64 __cdecl _andn_u64(unsigned __int64,
                                                 unsigned __int64);
#line 2341 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern unsigned int     __cdecl _lzcnt_u32(unsigned int);
extern unsigned __int64 __cdecl _lzcnt_u64(unsigned __int64);
extern unsigned int     __cdecl _tzcnt_u32(unsigned int);
extern unsigned __int64 __cdecl _tzcnt_u64(unsigned __int64);
extern void __cdecl _invpcid(unsigned int  ,
                                    void *  );
#line 2385 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern unsigned int     __cdecl _xbegin(void);
extern void             __cdecl _xend(void);
extern void             __cdecl _xabort(const unsigned int);
extern unsigned char    __cdecl _xtest(void);
extern int __cdecl _rdseed16_step(unsigned short *);
extern int __cdecl _rdseed32_step(unsigned int *);
extern int __cdecl _rdseed64_step(unsigned __int64 *);
extern unsigned char __cdecl _addcarry_u32(unsigned char  ,
                                                  unsigned int  ,
                                                  unsigned int  ,
                                                  unsigned int *  );
extern unsigned char __cdecl _addcarry_u64(unsigned char  ,
                                                  unsigned __int64  ,
                                                  unsigned __int64  ,
                                                  unsigned __int64 *  );
extern unsigned char __cdecl _subborrow_u32(unsigned char  ,
                                                   unsigned int  ,
                                                   unsigned int  ,
                                                   unsigned int *  );
extern unsigned char __cdecl _subborrow_u64(unsigned char  ,
                                                   unsigned __int64  ,
                                                   unsigned __int64  ,
extern unsigned char __cdecl _addcarryx_u32(unsigned char  ,
                                                   unsigned int  ,
                                                   unsigned int  ,
                                                   unsigned int *  );
extern unsigned char __cdecl _addcarryx_u64(unsigned char  ,
                                                   unsigned __int64  ,
                                                   unsigned __int64  ,
#line 2502 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
extern void * __cdecl _bnd_set_ptr_bounds(const void *, size_t);
extern void * __cdecl _bnd_narrow_ptr_bounds(const void *, const void *,
                                                    size_t);
extern void * __cdecl _bnd_copy_ptr_bounds(const void *, const void *);
extern void * __cdecl _bnd_init_ptr_bounds(const void *);
extern void __cdecl _bnd_store_ptr_bounds(const void **, const void *);
extern void __cdecl _bnd_chk_ptr_lbounds(const void *);
extern void __cdecl _bnd_chk_ptr_ubounds(const void *);
extern void __cdecl _bnd_chk_ptr_bounds(const void *, size_t);
extern const void * __cdecl _bnd_get_ptr_lbound(const void *);
extern const void * __cdecl _bnd_get_ptr_ubound(const void *);
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef unsigned char       __mmask8;
typedef unsigned short      __mmask16;
typedef unsigned int        __mmask32;
typedef unsigned __int64    __mmask64;
typedef __mmask16 __mmask;
#line 61 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef union __declspec(align(64)) __declspec(intrin_type) __m512 {
    float       __m512_f32[16];
} __m512;
typedef union __declspec(align(64)) __declspec(intrin_type) __m512d {
    double      __m512d_f64[8];
} __m512d;
typedef union __declspec(align(64)) __declspec(intrin_type) __m512i {
#line 78 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
    __int8              m512i_i8[64];
    __int16             m512i_i16[32];
    __int32             m512i_i32[16];
    __int64             m512i_i64[8];
    unsigned __int8     m512i_u8[64];
    unsigned __int16    m512i_u16[32];
    unsigned __int32    m512i_u32[16];
    unsigned __int64    m512i_u64[8];
    int                 __m512i_i32[16];
} __m512i;
#line 106 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_SWIZ_REG_NONE,
    _MM_SWIZ_REG_CDAB,
    _MM_SWIZ_REG_BADC,
    _MM_SWIZ_REG_AAAA,
    _MM_SWIZ_REG_BBBB,
    _MM_SWIZ_REG_CCCC,
    _MM_SWIZ_REG_DDDD,
    _MM_SWIZ_REG_DACB
} _MM_SWIZZLE_ENUM;
typedef enum {
    _MM_BROADCAST32_NONE,
    _MM_BROADCAST_1X16,
    _MM_BROADCAST_4X16
} _MM_BROADCAST32_ENUM;
typedef enum {
    _MM_BROADCAST64_NONE,
    _MM_BROADCAST_1X8,
    _MM_BROADCAST_4X8
} _MM_BROADCAST64_ENUM;
typedef enum {
    _MM_ROUND_MODE_NEAREST,
    _MM_ROUND_MODE_DOWN,
    _MM_ROUND_MODE_UP,
    _MM_ROUND_MODE_TOWARD_ZERO,
    _MM_ROUND_MODE_DEFAULT
} _MM_ROUND_MODE_ENUM;
typedef enum {
    _MM_EXPADJ_NONE,
    _MM_EXPADJ_4,
    _MM_EXPADJ_5,
    _MM_EXPADJ_8,
    _MM_EXPADJ_16,
    _MM_EXPADJ_24,
    _MM_EXPADJ_31,
    _MM_EXPADJ_32
} _MM_EXP_ADJ_ENUM;
typedef enum {
    _MM_SCALE_1 = 1,
    _MM_SCALE_2 = 2,
    _MM_SCALE_4 = 4,
    _MM_SCALE_8 = 8
} _MM_INDEX_SCALE_ENUM;
typedef enum {
    _MM_PERM_AAAA = 0x00, _MM_PERM_AAAB = 0x01, _MM_PERM_AAAC = 0x02,
    _MM_PERM_AAAD = 0x03, _MM_PERM_AABA = 0x04, _MM_PERM_AABB = 0x05,
    _MM_PERM_AABC = 0x06, _MM_PERM_AABD = 0x07, _MM_PERM_AACA = 0x08,
    _MM_PERM_AACB = 0x09, _MM_PERM_AACC = 0x0A, _MM_PERM_AACD = 0x0B,
    _MM_PERM_AADA = 0x0C, _MM_PERM_AADB = 0x0D, _MM_PERM_AADC = 0x0E,
    _MM_PERM_AADD = 0x0F, _MM_PERM_ABAA = 0x10, _MM_PERM_ABAB = 0x11,
    _MM_PERM_ABAC = 0x12, _MM_PERM_ABAD = 0x13, _MM_PERM_ABBA = 0x14,
    _MM_PERM_ABBB = 0x15, _MM_PERM_ABBC = 0x16, _MM_PERM_ABBD = 0x17,
    _MM_PERM_ABCA = 0x18, _MM_PERM_ABCB = 0x19, _MM_PERM_ABCC = 0x1A,
    _MM_PERM_ABCD = 0x1B, _MM_PERM_ABDA = 0x1C, _MM_PERM_ABDB = 0x1D,
    _MM_PERM_ABDC = 0x1E, _MM_PERM_ABDD = 0x1F, _MM_PERM_ACAA = 0x20,
    _MM_PERM_ACAB = 0x21, _MM_PERM_ACAC = 0x22, _MM_PERM_ACAD = 0x23,
    _MM_PERM_ACBA = 0x24, _MM_PERM_ACBB = 0x25, _MM_PERM_ACBC = 0x26,
    _MM_PERM_ACBD = 0x27, _MM_PERM_ACCA = 0x28, _MM_PERM_ACCB = 0x29,
    _MM_PERM_ACCC = 0x2A, _MM_PERM_ACCD = 0x2B, _MM_PERM_ACDA = 0x2C,
    _MM_PERM_ACDB = 0x2D, _MM_PERM_ACDC = 0x2E, _MM_PERM_ACDD = 0x2F,
    _MM_PERM_ADAA = 0x30, _MM_PERM_ADAB = 0x31, _MM_PERM_ADAC = 0x32,
    _MM_PERM_ADAD = 0x33, _MM_PERM_ADBA = 0x34, _MM_PERM_ADBB = 0x35,
    _MM_PERM_ADBC = 0x36, _MM_PERM_ADBD = 0x37, _MM_PERM_ADCA = 0x38,
    _MM_PERM_ADCB = 0x39, _MM_PERM_ADCC = 0x3A, _MM_PERM_ADCD = 0x3B,
    _MM_PERM_ADDA = 0x3C, _MM_PERM_ADDB = 0x3D, _MM_PERM_ADDC = 0x3E,
    _MM_PERM_ADDD = 0x3F, _MM_PERM_BAAA = 0x40, _MM_PERM_BAAB = 0x41,
    _MM_PERM_BAAC = 0x42, _MM_PERM_BAAD = 0x43, _MM_PERM_BABA = 0x44,
    _MM_PERM_BABB = 0x45, _MM_PERM_BABC = 0x46, _MM_PERM_BABD = 0x47,
    _MM_PERM_BACA = 0x48, _MM_PERM_BACB = 0x49, _MM_PERM_BACC = 0x4A,
    _MM_PERM_BACD = 0x4B, _MM_PERM_BADA = 0x4C, _MM_PERM_BADB = 0x4D,
    _MM_PERM_BADC = 0x4E, _MM_PERM_BADD = 0x4F, _MM_PERM_BBAA = 0x50,
    _MM_PERM_BBAB = 0x51, _MM_PERM_BBAC = 0x52, _MM_PERM_BBAD = 0x53,
    _MM_PERM_BBBA = 0x54, _MM_PERM_BBBB = 0x55, _MM_PERM_BBBC = 0x56,
    _MM_PERM_BBBD = 0x57, _MM_PERM_BBCA = 0x58, _MM_PERM_BBCB = 0x59,
    _MM_PERM_BBCC = 0x5A, _MM_PERM_BBCD = 0x5B, _MM_PERM_BBDA = 0x5C,
    _MM_PERM_BBDB = 0x5D, _MM_PERM_BBDC = 0x5E, _MM_PERM_BBDD = 0x5F,
    _MM_PERM_BCAA = 0x60, _MM_PERM_BCAB = 0x61, _MM_PERM_BCAC = 0x62,
    _MM_PERM_BCAD = 0x63, _MM_PERM_BCBA = 0x64, _MM_PERM_BCBB = 0x65,
    _MM_PERM_BCBC = 0x66, _MM_PERM_BCBD = 0x67, _MM_PERM_BCCA = 0x68,
    _MM_PERM_BCCB = 0x69, _MM_PERM_BCCC = 0x6A, _MM_PERM_BCCD = 0x6B,
    _MM_PERM_BCDA = 0x6C, _MM_PERM_BCDB = 0x6D, _MM_PERM_BCDC = 0x6E,
    _MM_PERM_BCDD = 0x6F, _MM_PERM_BDAA = 0x70, _MM_PERM_BDAB = 0x71,
    _MM_PERM_BDAC = 0x72, _MM_PERM_BDAD = 0x73, _MM_PERM_BDBA = 0x74,
    _MM_PERM_BDBB = 0x75, _MM_PERM_BDBC = 0x76, _MM_PERM_BDBD = 0x77,
    _MM_PERM_BDCA = 0x78, _MM_PERM_BDCB = 0x79, _MM_PERM_BDCC = 0x7A,
    _MM_PERM_BDCD = 0x7B, _MM_PERM_BDDA = 0x7C, _MM_PERM_BDDB = 0x7D,
    _MM_PERM_BDDC = 0x7E, _MM_PERM_BDDD = 0x7F, _MM_PERM_CAAA = 0x80,
    _MM_PERM_CAAB = 0x81, _MM_PERM_CAAC = 0x82, _MM_PERM_CAAD = 0x83,
    _MM_PERM_CABA = 0x84, _MM_PERM_CABB = 0x85, _MM_PERM_CABC = 0x86,
    _MM_PERM_CABD = 0x87, _MM_PERM_CACA = 0x88, _MM_PERM_CACB = 0x89,
    _MM_PERM_CACC = 0x8A, _MM_PERM_CACD = 0x8B, _MM_PERM_CADA = 0x8C,
    _MM_PERM_CADB = 0x8D, _MM_PERM_CADC = 0x8E, _MM_PERM_CADD = 0x8F,
    _MM_PERM_CBAA = 0x90, _MM_PERM_CBAB = 0x91, _MM_PERM_CBAC = 0x92,
    _MM_PERM_CBAD = 0x93, _MM_PERM_CBBA = 0x94, _MM_PERM_CBBB = 0x95,
    _MM_PERM_CBBC = 0x96, _MM_PERM_CBBD = 0x97, _MM_PERM_CBCA = 0x98,
    _MM_PERM_CBCB = 0x99, _MM_PERM_CBCC = 0x9A, _MM_PERM_CBCD = 0x9B,
    _MM_PERM_CBDA = 0x9C, _MM_PERM_CBDB = 0x9D, _MM_PERM_CBDC = 0x9E,
    _MM_PERM_CBDD = 0x9F, _MM_PERM_CCAA = 0xA0, _MM_PERM_CCAB = 0xA1,
    _MM_PERM_CCAC = 0xA2, _MM_PERM_CCAD = 0xA3, _MM_PERM_CCBA = 0xA4,
    _MM_PERM_CCBB = 0xA5, _MM_PERM_CCBC = 0xA6, _MM_PERM_CCBD = 0xA7,
    _MM_PERM_CCCA = 0xA8, _MM_PERM_CCCB = 0xA9, _MM_PERM_CCCC = 0xAA,
    _MM_PERM_CCCD = 0xAB, _MM_PERM_CCDA = 0xAC, _MM_PERM_CCDB = 0xAD,
    _MM_PERM_CCDC = 0xAE, _MM_PERM_CCDD = 0xAF, _MM_PERM_CDAA = 0xB0,
    _MM_PERM_CDAB = 0xB1, _MM_PERM_CDAC = 0xB2, _MM_PERM_CDAD = 0xB3,
    _MM_PERM_CDBA = 0xB4, _MM_PERM_CDBB = 0xB5, _MM_PERM_CDBC = 0xB6,
    _MM_PERM_CDBD = 0xB7, _MM_PERM_CDCA = 0xB8, _MM_PERM_CDCB = 0xB9,
    _MM_PERM_CDCC = 0xBA, _MM_PERM_CDCD = 0xBB, _MM_PERM_CDDA = 0xBC,
    _MM_PERM_CDDB = 0xBD, _MM_PERM_CDDC = 0xBE, _MM_PERM_CDDD = 0xBF,
    _MM_PERM_DAAA = 0xC0, _MM_PERM_DAAB = 0xC1, _MM_PERM_DAAC = 0xC2,
    _MM_PERM_DAAD = 0xC3, _MM_PERM_DABA = 0xC4, _MM_PERM_DABB = 0xC5,
    _MM_PERM_DABC = 0xC6, _MM_PERM_DABD = 0xC7, _MM_PERM_DACA = 0xC8,
    _MM_PERM_DACB = 0xC9, _MM_PERM_DACC = 0xCA, _MM_PERM_DACD = 0xCB,
    _MM_PERM_DADA = 0xCC, _MM_PERM_DADB = 0xCD, _MM_PERM_DADC = 0xCE,
    _MM_PERM_DADD = 0xCF, _MM_PERM_DBAA = 0xD0, _MM_PERM_DBAB = 0xD1,
    _MM_PERM_DBAC = 0xD2, _MM_PERM_DBAD = 0xD3, _MM_PERM_DBBA = 0xD4,
    _MM_PERM_DBBB = 0xD5, _MM_PERM_DBBC = 0xD6, _MM_PERM_DBBD = 0xD7,
    _MM_PERM_DBCA = 0xD8, _MM_PERM_DBCB = 0xD9, _MM_PERM_DBCC = 0xDA,
    _MM_PERM_DBCD = 0xDB, _MM_PERM_DBDA = 0xDC, _MM_PERM_DBDB = 0xDD,
    _MM_PERM_DBDC = 0xDE, _MM_PERM_DBDD = 0xDF, _MM_PERM_DCAA = 0xE0,
    _MM_PERM_DCAB = 0xE1, _MM_PERM_DCAC = 0xE2, _MM_PERM_DCAD = 0xE3,
    _MM_PERM_DCBA = 0xE4, _MM_PERM_DCBB = 0xE5, _MM_PERM_DCBC = 0xE6,
    _MM_PERM_DCBD = 0xE7, _MM_PERM_DCCA = 0xE8, _MM_PERM_DCCB = 0xE9,
    _MM_PERM_DCCC = 0xEA, _MM_PERM_DCCD = 0xEB, _MM_PERM_DCDA = 0xEC,
    _MM_PERM_DCDB = 0xED, _MM_PERM_DCDC = 0xEE, _MM_PERM_DCDD = 0xEF,
    _MM_PERM_DDAA = 0xF0, _MM_PERM_DDAB = 0xF1, _MM_PERM_DDAC = 0xF2,
    _MM_PERM_DDAD = 0xF3, _MM_PERM_DDBA = 0xF4, _MM_PERM_DDBB = 0xF5,
    _MM_PERM_DDBC = 0xF6, _MM_PERM_DDBD = 0xF7, _MM_PERM_DDCA = 0xF8,
    _MM_PERM_DDCB = 0xF9, _MM_PERM_DDCC = 0xFA, _MM_PERM_DDCD = 0xFB,
    _MM_PERM_DDDA = 0xFC, _MM_PERM_DDDB = 0xFD, _MM_PERM_DDDC = 0xFE,
    _MM_PERM_DDDD = 0xFF
} _MM_PERM_ENUM;
typedef enum {
    _MM_FIXUP_NO_CHANGE,
    _MM_FIXUP_NEG_INF,
    _MM_FIXUP_NEG_ZERO,
    _MM_FIXUP_POS_ZERO,
    _MM_FIXUP_POS_INF,
    _MM_FIXUP_NAN,
    _MM_FIXUP_MAX_FLOAT,
    _MM_FIXUP_MIN_FLOAT
} _MM_FIXUPRESULT_ENUM;
#line 298 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_UPCONV_PS_NONE,
    _MM_UPCONV_PS_FLOAT16,
    _MM_UPCONV_PS_UINT8,
    _MM_UPCONV_PS_SINT8,
    _MM_UPCONV_PS_UINT16,
    _MM_UPCONV_PS_SINT16
} _MM_UPCONV_PS_ENUM;
#line 343 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_UPCONV_EPI32_NONE,
    _MM_UPCONV_EPI32_UINT8,
    _MM_UPCONV_EPI32_SINT8,
    _MM_UPCONV_EPI32_UINT16,
    _MM_UPCONV_EPI32_SINT16
} _MM_UPCONV_EPI32_ENUM;
#line 368 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 375 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_UPCONV_PD_NONE
} _MM_UPCONV_PD_ENUM;
#line 397 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_UPCONV_EPI64_NONE
} _MM_UPCONV_EPI64_ENUM;
#line 442 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_DOWNCONV_PS_NONE,
    _MM_DOWNCONV_PS_FLOAT16,
    _MM_DOWNCONV_PS_UINT8,
    _MM_DOWNCONV_PS_SINT8,
    _MM_DOWNCONV_PS_UINT16,
    _MM_DOWNCONV_PS_SINT16
} _MM_DOWNCONV_PS_ENUM;
typedef enum {
    _MM_DOWNCONV_EPI32_NONE,
    _MM_DOWNCONV_EPI32_UINT8,
    _MM_DOWNCONV_EPI32_SINT8,
    _MM_DOWNCONV_EPI32_UINT16,
    _MM_DOWNCONV_EPI32_SINT16
} _MM_DOWNCONV_EPI32_ENUM;
typedef enum {
    _MM_DOWNCONV_PD_NONE
} _MM_DOWNCONV_PD_ENUM;
typedef enum {
    _MM_DOWNCONV_EPI64_NONE
} _MM_DOWNCONV_EPI64_ENUM;
#line 515 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 549 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 573 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 683 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 708 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 780 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 823 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_CMPINT_EQ,
    _MM_CMPINT_LT,
    _MM_CMPINT_LE,
    _MM_CMPINT_UNUSED,
    _MM_CMPINT_NE,
    _MM_CMPINT_NLT,
    _MM_CMPINT_NLE
} _MM_CMPINT_ENUM;
#line 848 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 873 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 881 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 906 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 913 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 943 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 956 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 986 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 999 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1040 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1073 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1091 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1142 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1227 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1278 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1334 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1421 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1478 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1500 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
typedef enum {
    _MM_MANT_NORM_1_2,
    _MM_MANT_NORM_p5_2,
    _MM_MANT_NORM_p5_1,
    _MM_MANT_NORM_p75_1p5
} _MM_MANTISSA_NORM_ENUM;
typedef enum {
    _MM_MANT_SIGN_src,
    _MM_MANT_SIGN_zero,
    _MM_MANT_SIGN_nan
} _MM_MANTISSA_SIGN_ENUM;
#line 1535 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1631 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1638 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1645 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1652 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1659 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1666 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1673 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1680 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1687 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1754 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1761 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1768 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1843 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1866 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1895 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1917 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1939 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1961 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 1983 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2005 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2046 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2128 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2146 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2192 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2231 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2259 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2287 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2316 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2349 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2408 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2425 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2439 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2456 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2472 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2511 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2551 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2890 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2960 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3042 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3061 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3091 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3202 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3219 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3236 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3261 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3269 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3294 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3366 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3373 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3381 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3388 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3396 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3407 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3626 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3633 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3641 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3648 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3656 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3663 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3671 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3678 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3687 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3694 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3702 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3709 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3717 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3724 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3732 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3739 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3761 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3768 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3776 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3783 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3935 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3942 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3950 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 3957 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4120 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4128 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4136 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4144 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4157 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4164 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4172 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4180 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4189 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4197 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4205 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4213 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4222 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4230 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4238 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4245 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4253 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4261 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4269 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4277 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4285 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4293 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4301 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4309 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4317 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4324 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4332 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4339 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4457 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4470 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4524 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4533 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4546 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4555 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4572 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4580 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4588 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4596 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4658 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4668 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4679 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4689 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4705 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4725 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4746 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4775 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4814 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4823 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4841 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4855 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4869 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4883 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4892 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4914 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4928 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4942 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 4956 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5007 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5017 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5029 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5039 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5050 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5060 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5072 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5082 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5093 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5103 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5126 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5137 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5147 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5170 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5196 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5327 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5337 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5347 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5357 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5364 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5371 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5381 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5391 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5404 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5411 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5418 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5453 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5469 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5500 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5514 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5528 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5546 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5572 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5629 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5636 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5643 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5650 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5657 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5664 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5671 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5678 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5685 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5692 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5699 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 5759 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6363 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6388 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6396 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6421 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6429 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6454 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6462 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6487 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6495 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6520 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6528 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6553 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6561 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6586 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6636 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6661 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6692 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6699 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6724 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6731 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6756 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6787 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6794 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6819 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6826 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6851 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6882 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6889 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6914 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6921 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6946 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6977 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 6984 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7009 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7016 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7041 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7444 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7452 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7467 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7475 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7520 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7528 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7543 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7551 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7568 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7576 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7593 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7601 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7649 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7657 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7672 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7680 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7695 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7703 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7718 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7726 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7743 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7751 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7766 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7774 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 7796 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 8755 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 8818 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 8835 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 8906 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 8924 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 10361 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 10401 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 10563 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 11159 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"
#line 2523 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\immintrin.h"
#line 4 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                Defined "HAVE_IMMINTRIN_H" to "1"
TEST check from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: ieeefp.h
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "ieeefp.h"
  #include <ieeefp.h>
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conffix.h"
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Possible ERROR while running preprocessor: exit code 512
stdout:
conftest.c
  #include <ieeefp.h>
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"Source:
#include "confdefs.h"
#include "conffix.h"
#include <ieeefp.h>
Checking for header: strings.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "strings.h"
  #include <strings.h>
stdout:
conftest.c
Checking for header: inttypes.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\stdint.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\stdint.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#pragma once
typedef signed char        int8_t;
typedef short              int16_t;
typedef int                int32_t;
typedef long long          int64_t;
typedef unsigned char      uint8_t;
typedef unsigned short     uint16_t;
typedef unsigned int       uint32_t;
typedef unsigned long long uint64_t;
typedef signed char        int_least8_t;
typedef short              int_least16_t;
typedef int                int_least32_t;
typedef long long          int_least64_t;
typedef unsigned char      uint_least8_t;
typedef unsigned short     uint_least16_t;
typedef unsigned int       uint_least32_t;
typedef unsigned long long uint_least64_t;
typedef signed char        int_fast8_t;
typedef int                int_fast16_t;
typedef int                int_fast32_t;
typedef long long          int_fast64_t;
typedef unsigned char      uint_fast8_t;
typedef unsigned int       uint_fast16_t;
typedef unsigned int       uint_fast32_t;
typedef unsigned long long uint_fast64_t;
typedef long long          intmax_t;
typedef unsigned long long uintmax_t;
#line 60 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 73 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 86 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 96 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 23 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\stdint.h"
#line 47 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\stdint.h"
#line 23 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\stdint.h"
#line 47 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\stdint.h"
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
typedef struct
    intmax_t quot;
    intmax_t rem;
} _Lldiv_t;
typedef _Lldiv_t imaxdiv_t;
 intmax_t __cdecl imaxabs(
     intmax_t _Number
 imaxdiv_t __cdecl imaxdiv(
     intmax_t _Numerator,
     intmax_t _Denominator
 intmax_t __cdecl strtoimax(
                       char const* _String,
      char**      _EndPtr,
                         int         _Radix
 intmax_t __cdecl _strtoimax_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 uintmax_t __cdecl strtoumax(
      char**      _EndPtr,
                         int         _Radix
 uintmax_t __cdecl _strtoumax_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 intmax_t __cdecl wcstoimax(
                       wchar_t const* _String,
      wchar_t**      _EndPtr,
                         int            _Radix
 intmax_t __cdecl _wcstoimax_l(
      wchar_t**      _EndPtr,
                         int            _Radix,
                     _locale_t      _Locale
 uintmax_t __cdecl wcstoumax(
      wchar_t**      _EndPtr,
                         int            _Radix
 uintmax_t __cdecl _wcstoumax_l(
      wchar_t**      _EndPtr,
                         int            _Radix,
                     _locale_t      _Locale
#line 128 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 147 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 166 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 204 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 223 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 249 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 268 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 287 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 306 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
#line 325 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\inttypes.h"
__pragma(pack(pop))
                Defined "HAVE_INTTYPES_H" to "1"
Checking for header: sched.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sched.h"
  #include <sched.h>
stdout:
conftest.c
  #include <sched.h>
#include <sched.h>
Checking for header: cxxabi.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "cxxabi.h"
  #include <cxxabi.h>
stdout:
conftest.c
  #include <cxxabi.h>
#include <cxxabi.h>
Checking for header: sys/systeminfo.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/systeminfo.h"
  #include <sys/systeminfo.h>
stdout:
conftest.c
Checking for header: dos.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\dos.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\dos.h"
#line 26 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\dos.h"
        struct _diskfree_t
            unsigned total_clusters;
            unsigned avail_clusters;
            unsigned sectors_per_cluster;
            unsigned bytes_per_sector;
         unsigned __cdecl _getdiskfree(
              unsigned            _Drive,
             struct _diskfree_t* _DiskFree
__pragma(pack(pop))
                Defined "HAVE_DOS_H" to "1"
Checking for header: WindowsX.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#pragma warning(push)
#pragma warning(disable:4001)
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winpackagefamily.h"
#pragma once
#line 57 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winpackagefamily.h"
#line 84 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winpackagefamily.h"
#pragma warning(pop)
#line 27 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#line 143 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#line 154 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\winapifamily.h"
#line 18 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#pragma region Desktop Family
#line 42 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 93 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 153 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 171 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 423 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 654 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 980 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1053 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1096 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1262 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1295 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#line 1367 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\shared\\WindowsX.h"
#pragma endregion
                Defined "HAVE_WINDOWSX_H" to "1"
Checking for header: sys/sysinfo.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/sysinfo.h"
  #include <sys/sysinfo.h>
stdout:
conftest.c
Checking for header: zmmintrin.h
stdout:
conftest.c
E:\PROGRA~2\INTELS~1\COMPIL~2\windows\compiler\include\icc\zmmintrin.h(15): catastrophic error: #error directive: "Header should only be included from <immintrin.h>."
  #error "Header should only be included from <immintrin.h>."
Possible ERROR while running preprocessor: exit code 1024
stdout:
conftest.c
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\icc\\zmmintrin.h"Source:
#include <zmmintrin.h>
Checking for header: sys/wait.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/wait.h"
  #include <sys/wait.h>
stdout:
conftest.c
Checking for header: stdlib.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
#pragma once
#line 52 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
 __declspec(allocator) __declspec(restrict)
void* __cdecl _calloc_base(
     size_t _Count,
     size_t _Size
void* __cdecl calloc(
      size_t _Count,
      size_t _Size
 int __cdecl _callnewh(
     size_t _Size
void* __cdecl _expand(
               void*  _Block,
      size_t _Size
void __cdecl _free_base(
      void* _Block
void __cdecl free(
      void* _Block
void* __cdecl _malloc_base(
     size_t _Size
void* __cdecl malloc(
      size_t _Size
size_t __cdecl _msize_base(
     void* _Block
size_t __cdecl _msize(
     void* _Block
void* __cdecl _realloc_base(
       void*  _Block,
                                size_t _Size
void* __cdecl realloc(
      void*  _Block,
             size_t _Size
void* __cdecl _recalloc_base(
      void*  _Block,
                               size_t _Count,
                               size_t _Size
void* __cdecl _recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size
void __cdecl _aligned_free(
      void* _Block
void* __cdecl _aligned_malloc(
      size_t _Size,
                        size_t _Alignment
void* __cdecl _aligned_offset_malloc(
      size_t _Size,
                        size_t _Alignment,
                        size_t _Offset
size_t __cdecl _aligned_msize(
     void*  _Block,
              size_t _Alignment,
              size_t _Offset
void* __cdecl _aligned_offset_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_offset_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment,
                               size_t _Offset
void* __cdecl _aligned_realloc(
      void*  _Block,
             size_t _Size,
                               size_t _Alignment
void* __cdecl _aligned_recalloc(
      void*  _Block,
             size_t _Count,
             size_t _Size,
                               size_t _Alignment
#line 225 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_malloc.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
#pragma once
#line 26 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
     int* __cdecl _errno(void);
     errno_t __cdecl _set_errno( int _Value);
     errno_t __cdecl _get_errno( int* _Value);
#line 50 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stddef.h"
 extern unsigned long  __cdecl __threadid(void);
 extern uintptr_t __cdecl __threadhandle(void);
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
    typedef int (__cdecl* _CoreCrtSecureSearchSortCompareFunction)(void*, void const*, void const*);
    typedef int (__cdecl* _CoreCrtNonSecureSearchSortCompareFunction)(void const*, void const*);
     void* __cdecl bsearch_s(
                                                       void const* _Key,
         void const* _Base,
                                                       rsize_t     _NumOfElements,
                                                       rsize_t     _SizeOfElements,
                           _CoreCrtSecureSearchSortCompareFunction _CompareFunction,
                                                   void*       _Context
     void __cdecl qsort_s(
         void*   _Base,
                                                        void*   _Context
 void* __cdecl bsearch(
                                                   void const* _Key,
     void const* _Base,
                    _CoreCrtNonSecureSearchSortCompareFunction _CompareFunction
 void __cdecl qsort(
     void*  _Base,
 void* __cdecl _lfind_s(
                                                      void const*   _Key,
     void const*   _Base,
                                                   unsigned int* _NumOfElements,
                                                      void*         _Context
 void* __cdecl _lfind(
                                                      void const*   _Key,
     void const*   _Base,
                                                      unsigned int  _SizeOfElements,
 void* __cdecl _lsearch_s(
                                                            void const*   _Key,
     void*         _Base,
                                                            void*         _Context
 void* __cdecl _lsearch(
                                                            void const*   _Key,
     void*         _Base,
#line 185 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_search.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lfind" ". See online help for details."))
     void* __cdecl lfind(
                                                          void const*   _Key,
         void const*   _Base,
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lsearch" ". See online help for details."))
     void* __cdecl lsearch(
                                                               void const*   _Key,
         void*         _Base,
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
#pragma once
     errno_t __cdecl _itow_s(
                                 int      _Value,
         wchar_t* _Buffer,
                                 size_t   _BufferCount,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _itow(int _Value, wchar_t *_Buffer, int _Radix);
     errno_t __cdecl _ltow_s(
                                 long     _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ltow(long _Value, wchar_t *_Buffer, int _Radix);
     errno_t __cdecl _ultow_s(
                                 unsigned long _Value,
         wchar_t*      _Buffer,
                                 int           _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _ultow(unsigned long _Value, wchar_t *_Buffer, int _Radix);
     double __cdecl wcstod(
          wchar_t**      _EndPtr
     double __cdecl _wcstod_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     long __cdecl wcstol(
          wchar_t**      _EndPtr,
                             int            _Radix
     long __cdecl _wcstol_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     long long __cdecl wcstoll(
          wchar_t**      _EndPtr,
                             int            _Radix
     long long __cdecl _wcstoll_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned long __cdecl wcstoul(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned long __cdecl _wcstoul_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned long long __cdecl wcstoull(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned long long __cdecl _wcstoull_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     long double __cdecl wcstold(
          wchar_t**      _EndPtr
     long double __cdecl _wcstold_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     float __cdecl wcstof(
          wchar_t**      _EndPtr
     float __cdecl _wcstof_l(
          wchar_t**      _EndPtr,
                         _locale_t      _Locale
     double __cdecl _wtof(
     double __cdecl _wtof_l(
         _locale_t      _Locale
     int __cdecl _wtoi(
     int __cdecl _wtoi_l(
         _locale_t      _Locale
     long __cdecl _wtol(
     long __cdecl _wtol_l(
         _locale_t      _Locale
     long long __cdecl _wtoll(
     long long __cdecl _wtoll_l(
         _locale_t      _Locale
     errno_t __cdecl _i64tow_s(
                                 __int64  _Value,
         wchar_t* _Buffer,
                                 int      _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     wchar_t* __cdecl _i64tow(
                           __int64  _Value,
          wchar_t* _Buffer,
                           int      _Radix
     errno_t __cdecl _ui64tow_s(
                                 unsigned __int64 _Value,
         wchar_t*         _Buffer,
                                 int              _Radix
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64tow_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     wchar_t* __cdecl _ui64tow(
          wchar_t*         _Buffer,
                           int              _Radix
     __int64 __cdecl _wtoi64(
     __int64 __cdecl _wtoi64_l(
         _locale_t      _Locale
     __int64 __cdecl _wcstoi64(
          wchar_t**      _EndPtr,
                             int            _Radix
     __int64 __cdecl _wcstoi64_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     unsigned __int64 __cdecl _wcstoui64(
          wchar_t**      _EndPtr,
                             int            _Radix
     unsigned __int64 __cdecl _wcstoui64_l(
          wchar_t**      _EndPtr,
                             int            _Radix,
                         _locale_t      _Locale
     __declspec(allocator) wchar_t* __cdecl _wfullpath(
         wchar_t*       _Buffer,
                                   wchar_t const* _Path,
                                     size_t         _BufferCount
     errno_t __cdecl _wmakepath_s(
         wchar_t*       _Buffer,
                           wchar_t const* _Drive,
                           wchar_t const* _Dir,
                           wchar_t const* _Filename,
                           wchar_t const* _Ext
#line 361 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
#pragma warning(disable: 28719)
#pragma warning(disable: 28726)
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wmakepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wmakepath( wchar_t *_Buffer, wchar_t const* _Drive, wchar_t const* _Dir, wchar_t const* _Filename, wchar_t const* _Ext);
     void __cdecl _wperror(
         wchar_t const* _ErrorMessage
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsplitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     void __cdecl _wsplitpath(
                           wchar_t const* _FullPath,
          wchar_t*       _Drive,
          wchar_t*       _Dir,
          wchar_t*       _Filename,
          wchar_t*       _Ext
     errno_t __cdecl _wsplitpath_s(
            wchar_t*       _Drive,
                                       size_t         _DriveCount,
              wchar_t*       _Dir,
                                       size_t         _DirCount,
         wchar_t*       _Filename,
                                       size_t         _FilenameCount,
              wchar_t*       _Ext,
                                       size_t         _ExtCount
         errno_t __cdecl _wdupenv_s(
              wchar_t**      _Buffer,
        size_t*        _BufferCount,
        wchar_t const* _VarName
         __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wdupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         wchar_t* __cdecl _wgetenv(
         errno_t __cdecl _wgetenv_s(
                                        size_t*        _RequiredCount,
             wchar_t*       _Buffer,
#line 438 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstdlib.h"
         int __cdecl _wputenv(
             wchar_t const* _EnvString
         errno_t __cdecl _wputenv_s(
             wchar_t const* _Name,
             wchar_t const* _Value
         errno_t __cdecl _wsearchenv_s(
                                   wchar_t const* _VarName,
             wchar_t*       _Buffer,
                                     size_t         _BufferCount
        __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsearchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _wsearchenv(wchar_t const* _Filename, wchar_t const* _VarName, wchar_t *_ResultPath);
         int __cdecl _wsystem(
             wchar_t const* _Command
__pragma(pack(pop))
#line 16 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#pragma once
#line 29 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 43 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 71 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
#line 79 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
__pragma(pack(pop))
#line 17 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 void __cdecl _swab(
      char* _Buf1,
      char* _Buf2,
        int   _SizeInBytes
     __declspec(noreturn) void __cdecl exit( int _Code);
     __declspec(noreturn) void __cdecl _exit( int _Code);
     __declspec(noreturn) void __cdecl _Exit( int _Code);
     __declspec(noreturn) void __cdecl quick_exit( int _Code);
     __declspec(noreturn) void __cdecl abort(void);
 unsigned int __cdecl _set_abort_behavior(
     unsigned int _Flags,
     unsigned int _Mask
    typedef int (__cdecl* _onexit_t)(void);
#line 117 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
#line 140 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
    int       __cdecl atexit(void (__cdecl*)(void));
    _onexit_t __cdecl _onexit( _onexit_t _Func);
int __cdecl at_quick_exit(void (__cdecl*)(void));
    typedef void (__cdecl* _purecall_handler)(void);
    typedef void (__cdecl* _invalid_parameter_handler)(
        wchar_t const*,
        wchar_t const*,
        wchar_t const*,
        unsigned int,
        uintptr_t
     _purecall_handler __cdecl _set_purecall_handler(
         _purecall_handler _Handler
     _purecall_handler __cdecl _get_purecall_handler(void);
     _invalid_parameter_handler __cdecl _set_invalid_parameter_handler(
         _invalid_parameter_handler _Handler
     _invalid_parameter_handler __cdecl _get_invalid_parameter_handler(void);
     _invalid_parameter_handler __cdecl _set_thread_local_invalid_parameter_handler(
     _invalid_parameter_handler __cdecl _get_thread_local_invalid_parameter_handler(void);
#line 199 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
  int __cdecl _set_error_mode( int _Mode);
     unsigned long* __cdecl __doserrno(void);
     errno_t __cdecl _set_doserrno( unsigned long _Value);
     errno_t __cdecl _get_doserrno( unsigned long * _Value);
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char** __cdecl __sys_errlist(void);
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) int * __cdecl __sys_nerr(void);
     void __cdecl perror( char const* _ErrMsg);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_pgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  char**    __cdecl __p__pgmptr (void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_wpgmptr" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  wchar_t** __cdecl __p__wpgmptr(void);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_get_fmode" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))  int*      __cdecl __p__fmode  (void);
#line 253 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 errno_t __cdecl _get_pgmptr ( char**    _Value);
 errno_t __cdecl _get_wpgmptr( wchar_t** _Value);
 errno_t __cdecl _set_fmode  (              int       _Mode );
 errno_t __cdecl _get_fmode  (             int*      _PMode);
typedef struct _div_t
    int quot;
    int rem;
} div_t;
typedef struct _ldiv_t
    long quot;
    long rem;
} ldiv_t;
typedef struct _lldiv_t
    long long quot;
    long long rem;
} lldiv_t;
 int       __cdecl abs   ( int       _Number);
 long      __cdecl labs  ( long      _Number);
 long long __cdecl llabs ( long long _Number);
 __int64   __cdecl _abs64( __int64   _Number);
 unsigned short   __cdecl _byteswap_ushort( unsigned short   _Number);
 unsigned long    __cdecl _byteswap_ulong ( unsigned long    _Number);
 unsigned __int64 __cdecl _byteswap_uint64( unsigned __int64 _Number);
  div_t   __cdecl div  ( int       _Numerator,  int       _Denominator);
  ldiv_t  __cdecl ldiv ( long      _Numerator,  long      _Denominator);
  lldiv_t __cdecl lldiv( long long _Numerator,  long long _Denominator);
#pragma warning (push)
#pragma warning (disable:6540)
unsigned int __cdecl _rotl(
     unsigned int _Value,
     int          _Shift
unsigned long __cdecl _lrotl(
     int           _Shift
unsigned __int64 __cdecl _rotl64(
     int              _Shift
unsigned int __cdecl _rotr(
     int          _Shift
unsigned long __cdecl _lrotr(
     int           _Shift
unsigned __int64 __cdecl _rotr64(
     int              _Shift
#pragma warning (pop)
 void __cdecl srand( unsigned int _Seed);
  int __cdecl rand(void);
#line 380 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
    #pragma pack(push, 4)
    typedef struct
        unsigned char ld[10];
    } _LDOUBLE;
    #pragma pack(pop)
#line 410 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
typedef struct
    double x;
} _CRT_DOUBLE;
typedef struct
    float f;
} _CRT_FLOAT;
typedef struct
    long double x;
} _LONGDOUBLE;
typedef struct
    unsigned char ld12[12];
} _LDBL12;
#pragma pack(pop)
                     double    __cdecl atof   ( char const* _String);
   int       __cdecl atoi   ( char const* _String);
                     long      __cdecl atol   ( char const* _String);
                     long long __cdecl atoll  ( char const* _String);
                     __int64   __cdecl _atoi64( char const* _String);
  double    __cdecl _atof_l  ( char const* _String,  _locale_t _Locale);
  int       __cdecl _atoi_l  ( char const* _String,  _locale_t _Locale);
  long      __cdecl _atol_l  ( char const* _String,  _locale_t _Locale);
  long long __cdecl _atoll_l ( char const* _String,  _locale_t _Locale);
  __int64   __cdecl _atoi64_l( char const* _String,  _locale_t _Locale);
  int __cdecl _atoflt ( _CRT_FLOAT*  _Result,  char const* _String);
  int __cdecl _atodbl ( _CRT_DOUBLE* _Result,  char*       _String);
  int __cdecl _atoldbl( _LDOUBLE*    _Result,  char*       _String);
 int __cdecl _atoflt_l(
     _locale_t   _Locale
 int __cdecl _atodbl_l(
       char*        _String,
     _locale_t    _Locale
 int __cdecl _atoldbl_l(
        _LDOUBLE* _Result,
       char*     _String,
     _locale_t _Locale
 float __cdecl strtof(
      char**      _EndPtr
 float __cdecl _strtof_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 double __cdecl strtod(
      char**      _EndPtr
 double __cdecl _strtod_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 long double __cdecl strtold(
      char**      _EndPtr
 long double __cdecl _strtold_l(
      char**      _EndPtr,
                     _locale_t   _Locale
 long __cdecl strtol(
      char**      _EndPtr,
                         int         _Radix
 long __cdecl _strtol_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 long long __cdecl strtoll(
      char**      _EndPtr,
                         int         _Radix
 long long __cdecl _strtoll_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned long __cdecl strtoul(
      char**      _EndPtr,
                         int         _Radix
 unsigned long __cdecl _strtoul_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned long long __cdecl strtoull(
      char**      _EndPtr,
                         int         _Radix
 unsigned long long __cdecl _strtoull_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 __int64 __cdecl _strtoi64(
      char**      _EndPtr,
                         int         _Radix
 __int64 __cdecl _strtoi64_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 unsigned __int64 __cdecl _strtoui64(
      char**      _EndPtr,
                         int         _Radix
 unsigned __int64 __cdecl _strtoui64_l(
      char**      _EndPtr,
                         int         _Radix,
                     _locale_t   _Locale
 errno_t __cdecl _itoa_s(
                             int    _Value,
     char*  _Buffer,
                             int    _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _itoa(int _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _ltoa_s(
                             long   _Value,
     char*  _Buffer,
                             int    _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ltoa(long _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _ultoa_s(
     char*         _Buffer,
                             int           _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _ultoa(unsigned long _Value, char *_Buffer, int _Radix);
 errno_t __cdecl _i64toa_s(
                             __int64 _Value,
     char*   _Buffer,
                             int     _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_i64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _i64toa(
                       __int64 _Value,
      char*   _Buffer,
                       int     _Radix
 errno_t __cdecl _ui64toa_s(
     char*            _Buffer,
                             int              _Radix
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_ui64toa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ui64toa(
      char*            _Buffer,
                       int              _Radix
 errno_t __cdecl _ecvt_s(
     char* _Buffer,
      double                       _Value,
      int                          _DigitCount,
     int*                         _PtDec,
     int*                         _PtSign
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _ecvt(
      double _Value,
      int    _DigitCount,
     int*   _PtDec,
     int*   _PtSign
 errno_t __cdecl _fcvt_s(
     char*  _Buffer,
                             double _Value,
                             int    _FractionalDigitCount,
                            int*   _PtDec,
                            int*   _PtSign
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _fcvt(
      double _Value,
     int*   _PtDec,
     int*   _PtSign
 errno_t __cdecl _gcvt_s(
     char*  _Buffer,
                             double _Value,
                             int    _DigitCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_gcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl _gcvt(
                       double _Value,
                       int    _DigitCount,
      char*  _Buffer
#line 838 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
     int __cdecl ___mb_cur_max_func(void);
     int __cdecl ___mb_cur_max_l_func(_locale_t _Locale);
 int __cdecl mblen(
      char const* _Ch,
                                            size_t      _MaxCount
 int __cdecl _mblen_l(
      char const* _Ch,
                                            size_t      _MaxCount,
                                        _locale_t   _Locale
 size_t __cdecl _mbstrlen(
     char const* _String
 size_t __cdecl _mbstrlen_l(
     _locale_t   _Locale
 size_t __cdecl _mbstrnlen(
       size_t      _MaxCount
 size_t __cdecl _mbstrnlen_l(
         size_t      _MaxCount,
     _locale_t   _Locale
 int __cdecl mbtowc(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                     size_t      _SrcSizeInBytes
 int __cdecl _mbtowc_l(
                    wchar_t*    _DstCh,
     char const* _SrcCh,
                                     size_t      _SrcSizeInBytes,
                                 _locale_t   _Locale
 errno_t __cdecl mbstowcs_s(
                                                     size_t*     _PtNumOfCharConverted,
     wchar_t*    _DstBuf,
                                                          size_t      _SizeInWords,
                                    char const* _SrcBuf,
                                                          size_t      _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "mbstowcs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl mbstowcs( wchar_t *_Dest, char const* _Source, size_t _MaxCount);
 errno_t __cdecl _mbstowcs_s_l(
     wchar_t*    _DstBuf,
                                                          size_t      _MaxCount,
                                                      _locale_t   _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_mbstowcs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _mbstowcs_l( wchar_t *_Dest, char const* _Source, size_t _MaxCount, _locale_t _Locale);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wctomb_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl wctomb(
     char*   _MbCh,
                               wchar_t _WCh
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wctomb_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl _wctomb_l(
      char*     _MbCh,
                         wchar_t   _WCh,
                     _locale_t _Locale
     errno_t __cdecl wctomb_s(
                                                        int*    _SizeConverted,
         char*   _MbCh,
                                                             rsize_t _SizeInBytes,
                                                             wchar_t _WCh
 errno_t __cdecl _wctomb_s_l(
     char*     _MbCh,
                                 wchar_t   _WCh,
                             _locale_t _Locale);
 errno_t __cdecl wcstombs_s(
     char*          _Dst,
        size_t         _DstSizeInBytes,
        wchar_t const* _Src,
        size_t         _MaxCountInBytes
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstombs_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl wcstombs( char *_Dest, wchar_t const* _Source, size_t _MaxCount);
 errno_t __cdecl _wcstombs_s_l(
     char*          _Dst,
        size_t         _MaxCountInBytes,
                                                               _locale_t      _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcstombs_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) size_t __cdecl _wcstombs_l( char *_Dest, wchar_t const* _Source, size_t _MaxCount, _locale_t _Locale);
 __declspec(allocator) char* __cdecl _fullpath(
     char*       _Buffer,
                               char const* _Path,
                                 size_t      _BufferCount
 errno_t __cdecl _makepath_s(
     char*       _Buffer,
                       char const* _Drive,
                       char const* _Dir,
                       char const* _Filename,
                       char const* _Ext
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_makepath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _makepath( char *_Buffer, char const* _Drive, char const* _Dir, char const* _Filename, char const* _Ext);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_splitpath_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 void __cdecl _splitpath(
                       char const* _FullPath,
      char*       _Drive,
      char*       _Dir,
      char*       _Filename,
      char*       _Ext
 errno_t __cdecl _splitpath_s(
        char*       _Drive,
                                   size_t      _DriveCount,
          char*       _Dir,
                                   size_t      _DirCount,
     char*       _Filename,
          char*       _Ext,
                                   size_t      _ExtCount
 errno_t __cdecl getenv_s(
     char*       _Buffer,
                                 rsize_t     _BufferCount,
                               char const* _VarName
 int*       __cdecl __p___argc (void);
 char***    __cdecl __p___argv (void);
 wchar_t*** __cdecl __p___wargv(void);
#line 1164 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
 char***    __cdecl __p__environ (void);
 wchar_t*** __cdecl __p__wenviron(void);
#line 1181 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\stdlib.h"
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "_dupenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl getenv(
     errno_t __cdecl _dupenv_s(
          char**      _Buffer,
     int __cdecl system(
         char const* _Command
     int __cdecl _putenv(
         char const* _EnvString
     errno_t __cdecl _putenv_s(
         char const* _Name,
         char const* _Value
     errno_t __cdecl _searchenv_s(
                               char const* _VarName,
         char*       _Buffer,
                                 size_t      _BufferCount
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_searchenv_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) void __cdecl _searchenv(char const* _Filename, char const* _VarName, char *_Buffer);
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "SetErrorMode" " " "instead. See online help for details."))
     void __cdecl _seterrormode(
         int _Mode
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Beep" " " "instead. See online help for details."))
     void __cdecl _beep(
         unsigned _Frequency,
         unsigned _Duration
    __declspec(deprecated("This function or variable has been superceded by newer library " "or operating system functionality. Consider using " "Sleep" " " "instead. See online help for details."))
     void __cdecl _sleep(
         unsigned long _Duration
    #pragma warning(disable: 4141)
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ecvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ecvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ecvt(
          double _Value,
          int    _DigitCount,
         int*   _PtDec,
         int*   _PtSign
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_fcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl fcvt(
          double _Value,
         int*   _PtDec,
         int*   _PtSign
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_gcvt" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_fcvt_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl gcvt(
                           double _Value,
                           int    _DigitCount,
          char*  _DstBuf
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_itoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_itoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl itoa(
                           int   _Value,
          char* _Buffer,
                           int   _Radix
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ltoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ltoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ltoa(
                           long  _Value,
          char* _Buffer,
                           int   _Radix
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_swab" ". See online help for details."))
     void __cdecl swab(
         char* _Buf1,
         char* _Buf2,
                                    int   _SizeInBytes
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_ultoa" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_ultoa_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     char* __cdecl ultoa(
          char*         _Buffer,
                           int           _Radix
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_putenv" ". See online help for details."))
     int __cdecl putenv(
    _onexit_t __cdecl onexit( _onexit_t _Func);
__pragma(pack(pop))
                Defined "HAVE_STDLIB_H" to "1"
Checking for header: pthread.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "pthread.h"
  #include <pthread.h>
stdout:
conftest.c
Checking for header: setjmp.h
stdout:
conftest.c
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\setjmp.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
#line 12 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\setjmp.h"
#line 20 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\setjmp.h"
#line 47 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\setjmp.h"
    typedef struct __declspec(align(16)) _SETJMP_FLOAT128
        unsigned __int64 Part[2];
    } SETJMP_FLOAT128;
    typedef SETJMP_FLOAT128 _JBTYPE;
    typedef struct _JUMP_BUFFER
        unsigned __int64 Frame;
        unsigned __int64 Rbx;
        unsigned __int64 Rsp;
        unsigned __int64 Rbp;
        unsigned __int64 Rsi;
        unsigned __int64 Rdi;
        unsigned __int64 R12;
        unsigned __int64 R13;
        unsigned __int64 R14;
        unsigned __int64 R15;
        unsigned __int64 Rip;
        unsigned long MxCsr;
        unsigned short FpCsr;
        unsigned short Spare;
        SETJMP_FLOAT128 Xmm6;
        SETJMP_FLOAT128 Xmm7;
        SETJMP_FLOAT128 Xmm8;
        SETJMP_FLOAT128 Xmm9;
        SETJMP_FLOAT128 Xmm10;
        SETJMP_FLOAT128 Xmm11;
        SETJMP_FLOAT128 Xmm12;
        SETJMP_FLOAT128 Xmm13;
        SETJMP_FLOAT128 Xmm14;
        SETJMP_FLOAT128 Xmm15;
    } _JUMP_BUFFER;
#line 139 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\setjmp.h"
    typedef _JBTYPE jmp_buf[16];
int __cdecl _setjmp(
     jmp_buf _Buf
#line 167 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\setjmp.h"
    __declspec(noreturn) void __cdecl longjmp(
         jmp_buf _Buf,
         int     _Value
__pragma(pack(pop))
                Defined "HAVE_SETJMP_H" to "1"
Checking for header: sys/utsname.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/utsname.h"
  #include <sys/utsname.h>
stdout:
conftest.c
Checking for header: machine/endian.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "machine/endian.h"
  #include <machine/endian.h>
stdout:
conftest.c
Checking for header: limits.h
stdout:
conftest.c
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
#line 12 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\limits.h"
__pragma(pack(pop))
                Defined "HAVE_LIMITS_H" to "1"
Checking for header: fcntl.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\fcntl.h"
#pragma once
#line 41 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\fcntl.h"
#line 60 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\fcntl.h"
                Defined "HAVE_FCNTL_H" to "1"
Checking for header: string.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#pragma once
#line 70 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#line 79 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
#line 127 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\errno.h"
__pragma(pack(pop))
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime_string.h"
#pragma once
 void * __cdecl memchr(
     void const* _Buf,
                                int         _Val,
                                size_t      _MaxCount
int __cdecl memcmp(
     void const* _Buf1,
     void const* _Buf2,
                        size_t      _Size
void* __cdecl memcpy(
     void* _Dst,
           void const* _Src,
                              size_t      _Size
 void* __cdecl memmove(
     void*       _Dst,
           void const* _Src,
                                  size_t      _Size
void* __cdecl memset(
     void*  _Dst,
                              int    _Val,
                              size_t _Size
 char * __cdecl strchr(
     char const* _Str,
       int         _Val
 char * __cdecl strrchr(
     char const* _Str,
       int         _Ch
 char * __cdecl strstr(
     char const* _Str,
     char const* _SubStr
 wchar_t * __cdecl wcschr(
     wchar_t const* _Str,
       wchar_t        _Ch
 wchar_t * __cdecl wcsrchr(
       wchar_t        _Ch
 wchar_t * __cdecl wcsstr(
     wchar_t const* _SubStr
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memcpy_s.h"
    static __inline errno_t __cdecl memcpy_s(
         void*       const _Destination,
                                                             rsize_t     const _DestinationSize,
                                void const* const _Source,
                                                             rsize_t     const _SourceSize
        if (_SourceSize == 0)
            return 0;
        { int _Expr_val=!!(_Destination != ((void *)0)); if (!(_Expr_val)) { (*_errno()) = 22; _invalid_parameter_noinfo(); return 22; } };
        if (_Source == ((void *)0) || _DestinationSize < _SourceSize)
            memset(_Destination, 0, _DestinationSize);
            { int _Expr_val=!!(_Source != ((void *)0)); if (!(_Expr_val)) { (*_errno()) = 22; _invalid_parameter_noinfo(); return 22; } };
            { int _Expr_val=!!(_DestinationSize >= _SourceSize); if (!(_Expr_val)) { (*_errno()) = 34; _invalid_parameter_noinfo(); return 34; } };
            return 22;
        memcpy(_Destination, _Source, _SourceSize);
        return 0;
    static __inline errno_t __cdecl memmove_s(
            return 0;
        memmove(_Destination, _Source, _SourceSize);
        return 0;
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
 int __cdecl _memicmp(
     void const* _Buf1,
     void const* _Buf2,
                            size_t      _Size
 int __cdecl _memicmp_l(
     void const* _Buf1,
     void const* _Buf2,
                            size_t      _Size,
                        _locale_t   _Locale
#line 56 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
#line 71 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_memccpy" ". See online help for details."))
     void* __cdecl memccpy(
         void*       _Dst,
           void const* _Src,
                                  int         _Val,
                                  size_t      _Size
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_memicmp" ". See online help for details."))
     int __cdecl memicmp(
         void const* _Buf1,
         void const* _Buf2,
                                size_t      _Size
#line 111 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_memory.h"
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
#pragma once
     errno_t __cdecl wcscat_s(
         wchar_t* _Destination,
         rsize_t _SizeInWords,
     errno_t __cdecl wcscpy_s(
     errno_t __cdecl wcsncat_s(
                                    rsize_t        _MaxCount
     errno_t __cdecl wcsncpy_s(
                                 rsize_t        _MaxCount
     wchar_t* __cdecl wcstok_s(
                         wchar_t*       _String,
                                wchar_t const* _Delimiter,
          wchar_t**      _Context
 __declspec(allocator) wchar_t* __cdecl _wcsdup(
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "wcscat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcscat( wchar_t *_Destination, wchar_t const* _Source);
 int __cdecl wcscmp(
     wchar_t const* _String1,
     wchar_t const* _String2
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcscpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcscpy( wchar_t *_Destination, wchar_t const* _Source);
 size_t __cdecl wcscspn(
     wchar_t const* _Control
 size_t __cdecl wcslen(
 size_t __cdecl wcsnlen(
                           size_t         _MaxCount
    static __inline size_t __cdecl wcsnlen_s(
                               size_t         _MaxCount
        return (_Source == 0) ? 0 : wcsnlen(_Source, _MaxCount);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcsncat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcsncat( wchar_t *_Destination, wchar_t const* _Source, size_t _Count);
 int __cdecl wcsncmp(
     wchar_t const* _String2,
                           size_t         _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "wcsncpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl wcsncpy( wchar_t *_Destination, wchar_t const* _Source, size_t _Count);
 wchar_t * __cdecl wcspbrk(
 size_t __cdecl wcsspn(
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "wcstok_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl wcstok(
                         wchar_t*       _String,
      wchar_t**      _Context
#line 242 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
    #pragma warning(disable: 4141 4996)
    #pragma warning(disable: 28719 28726 28727)
    static __inline wchar_t* __cdecl _wcstok(
         wchar_t*       const _String,
                wchar_t const* const _Delimiter
        return wcstok(_String, _Delimiter, 0);
#line 269 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcserror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl _wcserror(
     int _ErrorNumber
 errno_t __cdecl _wcserror_s(
     wchar_t* _Buffer,
                                 int      _ErrorNumber
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "__wcserror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 wchar_t* __cdecl __wcserror(
  errno_t __cdecl __wcserror_s(
     wchar_t*       _Buffer,
  int __cdecl _wcsicmp(
  int __cdecl _wcsicmp_l(
     _locale_t      _Locale
  int __cdecl _wcsnicmp(
                           size_t         _MaxCount
  int __cdecl _wcsnicmp_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
  errno_t __cdecl _wcsnset_s(
                                wchar_t  _Value,
                                size_t   _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsnset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsnset( wchar_t *_String, wchar_t _Value, size_t _MaxCount);
 wchar_t* __cdecl _wcsrev(
     wchar_t* _String
  errno_t __cdecl _wcsset_s(
                                wchar_t  _Value
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsset( wchar_t *_String, wchar_t _Value);
  errno_t __cdecl _wcslwr_s(
     wchar_t* _String,
                                size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcslwr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcslwr( wchar_t *_String);
 errno_t __cdecl _wcslwr_s_l(
     wchar_t*  _String,
                            _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcslwr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcslwr_l( wchar_t *_String, _locale_t _Locale);
 errno_t __cdecl _wcsupr_s(
     wchar_t* _String,
                         size_t   _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsupr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsupr( wchar_t *_String);
 errno_t __cdecl _wcsupr_s_l(
     wchar_t*  _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wcsupr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wcsupr_l( wchar_t *_String, _locale_t _Locale);
 size_t __cdecl wcsxfrm(
              size_t         _MaxCount
 size_t __cdecl _wcsxfrm_l(
              size_t         _MaxCount,
                                      _locale_t      _Locale
 int __cdecl wcscoll(
 int __cdecl _wcscoll_l(
     _locale_t      _Locale
 int __cdecl _wcsicoll(
 int __cdecl _wcsicoll_l(
     _locale_t      _Locale
 int __cdecl _wcsncoll(
                           size_t         _MaxCount
 int __cdecl _wcsncoll_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
 int __cdecl _wcsnicoll(
                           size_t         _MaxCount
 int __cdecl _wcsnicoll_l(
                           size_t         _MaxCount,
                       _locale_t      _Locale
#line 565 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wstring.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsdup" ". See online help for details."))
     wchar_t* __cdecl wcsdup(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsicmp" ". See online help for details."))
     int __cdecl wcsicmp(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsnicmp" ". See online help for details."))
     int __cdecl wcsnicmp(
                               size_t         _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsnset" ". See online help for details."))
     wchar_t* __cdecl wcsnset(
         wchar_t* _String,
                                 wchar_t  _Value,
                                 size_t   _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsrev" ". See online help for details."))
     wchar_t* __cdecl wcsrev(
         wchar_t* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsset" ". See online help for details."))
     wchar_t* __cdecl wcsset(
         wchar_t* _String,
              wchar_t  _Value
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcslwr" ". See online help for details."))
     wchar_t* __cdecl wcslwr(
         wchar_t* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsupr" ". See online help for details."))
     wchar_t* __cdecl wcsupr(
         wchar_t* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_wcsicoll" ". See online help for details."))
     int __cdecl wcsicoll(
__pragma(pack(pop))
#line 15 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
     errno_t __cdecl strcpy_s(
         char*       _Destination,
                               char const* _Source
     errno_t __cdecl strcat_s(
         char*       _Destination,
                                  char const* _Source
     errno_t __cdecl strerror_s(
         char*  _Buffer,
                                 int    _ErrorNumber);
     errno_t __cdecl strncat_s(
         char*       _Destination,
                                    rsize_t     _MaxCount
     errno_t __cdecl strncpy_s(
         char*       _Destination,
                                 rsize_t     _MaxCount
     char*  __cdecl strtok_s(
                         char*       _String,
                                char const* _Delimiter,
          char**      _Context
 void* __cdecl _memccpy(
     void*       _Dst,
                                  void const* _Src,
                                  int         _Val,
                                  size_t      _MaxCount
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "strcat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strcat( char *_Destination, char const* _Source);
int __cdecl strcmp(
     char const* _Str1,
     char const* _Str2
 int __cdecl _strcmpi(
     char const* _String1,
     char const* _String2
 int __cdecl strcoll(
 int __cdecl _strcoll_l(
       char const* _String2,
     _locale_t   _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strcpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strcpy( char *_Destination, char const* _Source);
 size_t __cdecl strcspn(
     char const* _Str,
     char const* _Control
 __declspec(allocator) char* __cdecl _strdup(
     char const* _Source
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_strerror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char*  __cdecl _strerror(
     char const* _ErrorMessage
 errno_t __cdecl _strerror_s(
     char*       _Buffer,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "strerror_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl strerror(
     int _ErrorMessage
 int __cdecl _stricmp(
 int __cdecl _stricoll(
 int __cdecl _stricoll_l(
     _locale_t   _Locale
 int __cdecl _stricmp_l(
     _locale_t   _Locale
size_t __cdecl strlen(
     char const* _Str
 errno_t __cdecl _strlwr_s(
     char*  _String,
                         size_t _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strlwr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strlwr( char *_String);
 errno_t __cdecl _strlwr_s_l(
     char*     _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strlwr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strlwr_l( char *_String, _locale_t _Locale);
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strncat_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strncat( char *_Destination, char const* _Source, size_t _Count);
 int __cdecl strncmp(
     char const* _Str1,
     char const* _Str2,
                           size_t      _MaxCount
 int __cdecl _strnicmp(
                           size_t      _MaxCount
 int __cdecl _strnicmp_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 int __cdecl _strnicoll(
                           size_t      _MaxCount
 int __cdecl _strnicoll_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 int __cdecl _strncoll(
                           size_t      _MaxCount
 int __cdecl _strncoll_l(
                           size_t      _MaxCount,
                       _locale_t   _Locale
 size_t __cdecl __strncnt(
                        size_t      _Count
__declspec(deprecated("This function or variable may be unsafe. Consider using " "strncpy_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl strncpy( char *_Destination, char const* _Source, size_t _Count);
 size_t __cdecl strnlen(
                           size_t      _MaxCount
    static __inline size_t __cdecl strnlen_s(
                               size_t      _MaxCount
        return _String == 0 ? 0 : strnlen(_String, _MaxCount);
 errno_t __cdecl _strnset_s(
     char*  _String,
                                int    _Value,
                                size_t _MaxCount
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strnset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strnset( char *_Destination, int _Value, size_t _Count);
 char * __cdecl strpbrk(
     char const* _Str,
 char* __cdecl _strrev(
     char* _Str
 errno_t __cdecl _strset_s(
     char*  _Destination,
                                    size_t _DestinationSize,
                                    int    _Value
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strset_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strset( char *_Destination, int _Value);
 size_t __cdecl strspn(
     char const* _Str,
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "strtok_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 char* __cdecl strtok(
     char*       _String,
 errno_t __cdecl _strupr_s(
     char*  _String,
                         size_t _Size
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strupr_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strupr( char *_String);
 errno_t __cdecl _strupr_s_l(
     char*     _String,
                         size_t    _Size,
                     _locale_t _Locale
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_strupr_s_l" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char* __cdecl _strupr_l( char *_String, _locale_t _Locale);
 size_t __cdecl strxfrm(
      char*       _Destination,
               size_t      _MaxCount
 size_t __cdecl _strxfrm_l(
      char*       _Destination,
               size_t      _MaxCount,
                                      _locale_t   _Locale
#line 528 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\string.h"
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strdup" ". See online help for details."))
     char* __cdecl strdup(
         char const* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strcmpi" ". See online help for details."))
     int __cdecl strcmpi(
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_stricmp" ". See online help for details."))
     int __cdecl stricmp(
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strlwr" ". See online help for details."))
     char* __cdecl strlwr(
         char* _String
     __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strnicmp" ". See online help for details."))
     int __cdecl strnicmp(
                               size_t      _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strnset" ". See online help for details."))
     char* __cdecl strnset(
         char*  _String,
                                 int    _Value,
                                 size_t _MaxCount
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strrev" ". See online help for details."))
     char* __cdecl strrev(
         char* _String
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strset" ". See online help for details."))
    char* __cdecl strset(
         char* _String,
              int   _Value);
    __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_strupr" ". See online help for details."))
     char* __cdecl strupr(
         char* _String
__pragma(pack(pop))
#line 4 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Preprocess stderr before filtering::
Preprocess stderr after filtering::
                Defined "HAVE_STRING_H" to "1"
TEST check from config.headers(/home/alireza/petsc-3.9.3/config/BuildSystem/config/headers.py:77)
TESTING: check from config.headers(config/BuildSystem/config/headers.py:77)
  Checks for "header", and defines HAVE_"header" if found
Checking for header: sys/times.h
Executing: /home/alireza/petsc-3.9.3/lib/petsc/bin/win32fe/win32fe icl -E  -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.setCompilers -I/cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers  /cygdrive/c/Users/AliReza/AppData/Local/Temp/petsc-fh63UE/config.headers/conftest.c
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "sys/times.h"
  #include <sys/times.h>
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\confdefs.h"
#line 2 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
#line 1 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conffix.h"
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"
Possible ERROR while running preprocessor: exit code 512
stdout:
conftest.c
#line 3 "C:\\Users\\AliReza\\AppData\\Local\\Temp\\petsc-fh63UE\\config.headers\\conftest.c"Source:
#include "confdefs.h"
#include "conffix.h"
Checking for header: io.h
stdout:
conftest.c
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\io.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_share.h"
#pragma once
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wio.h"
#pragma once
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#pragma once
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#pragma once
#line 46 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma once
#line 179 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 188 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 200 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 207 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 223 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 324 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 351 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 496 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 503 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 540 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 576 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 596 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 603 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma region Input Buffer SAL 1 compatibility macros
#line 1007 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1291 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1382 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1390 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1410 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#pragma endregion Input Buffer SAL 1 compatibility macros
#line 1555 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1611 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1663 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2047 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2061 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2083 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2091 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2367 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2624 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2835 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2858 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2868 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2878 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2891 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2899 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2911 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 2945 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#pragma once
#line 265 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 286 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 305 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 331 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 344 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\concurrencysal.h"
#line 2971 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\sal.h"
#line 48 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma once
#pragma pack(push, 8)
        typedef unsigned __int64  uintptr_t;
        typedef char* va_list;
#line 61 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 111 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
    void __cdecl __va_start(va_list* , ...);
#line 120 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#line 159 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vadefs.h"
#pragma pack(pop)
#line 49 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 74 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
__pragma(pack(push, 8))
#line 94 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 118 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 126 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 135 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 174 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef unsigned __int64 size_t;
    typedef __int64          ptrdiff_t;
    typedef __int64          intptr_t;
#line 196 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    typedef _Bool __vcrt_bool;
    typedef unsigned short wchar_t;
#line 225 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 243 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 262 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
#line 275 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\vcruntime.h"
    void __cdecl __security_init_cookie(void);
        void __cdecl __security_check_cookie( uintptr_t _StackCookie);
        __declspec(noreturn) void __cdecl __report_gsfailure( uintptr_t _StackCookie);
extern uintptr_t __security_cookie;
__pragma(pack(pop))
#line 11 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 46 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 66 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 88 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 98 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 137 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 145 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
    typedef _Bool __crt_bool;
#line 167 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 184 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 216 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 228 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 252 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
 void __cdecl _invalid_parameter_noinfo(void);
 __declspec(noreturn) void __cdecl _invalid_parameter_noinfo_noreturn(void);
 void __cdecl _invoke_watson(
     wchar_t const* _Expression,
     wchar_t const* _FunctionName,
     wchar_t const* _FileName,
           unsigned int _LineNo,
           uintptr_t _Reserved);
#line 311 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 330 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 338 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 356 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 372 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 401 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 422 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 431 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 441 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 453 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 461 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 470 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
typedef int                           errno_t;
typedef unsigned short                wint_t;
typedef unsigned short                wctype_t;
typedef long                          __time32_t;
typedef __int64                       __time64_t;
typedef struct __crt_locale_data_public
      unsigned short const* _locale_pctype;
     int _locale_mb_cur_max;
               unsigned int _locale_lc_codepage;
} __crt_locale_data_public;
typedef struct __crt_locale_pointers
    struct __crt_locale_data*    locinfo;
    struct __crt_multibyte_data* mbcinfo;
} __crt_locale_pointers;
typedef __crt_locale_pointers* _locale_t;
typedef struct _Mbstatet
    unsigned long _Wchar;
    unsigned short _Byte, _State;
} _Mbstatet;
typedef _Mbstatet mbstate_t;
        typedef __time64_t time_t;
    typedef size_t rsize_t;
#line 696 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 709 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1787 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
#line 1979 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt.h"
__pragma(pack(pop))
#line 12 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wio.h"
#pragma warning(push)
#pragma warning(disable:4820)
#line 33 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wio.h"
typedef unsigned long _fsize_t;
struct _wfinddata32_t
    unsigned   attrib;
    __time32_t time_create;
    __time32_t time_access;
    __time32_t time_write;
    _fsize_t   size;
    wchar_t    name[260];
struct _wfinddata32i64_t
    unsigned   attrib;
    __int64    size;
    wchar_t    name[260];
struct _wfinddata64i32_t
    unsigned   attrib;
    __time64_t time_create;
    __time64_t time_access;
    __time64_t time_write;
    _fsize_t   size;
    wchar_t    name[260];
struct _wfinddata64_t
    unsigned   attrib;
    __int64    size;
    wchar_t    name[260];
#line 94 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wio.h"
 int __cdecl _waccess(
       int            _AccessMode
 errno_t __cdecl _waccess_s(
       int            _AccessMode
 int __cdecl _wchmod(
       int            _Mode
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_wsopen_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 int __cdecl _wcreat(
       int            _PermissionMode
 intptr_t __cdecl _wfindfirst32(
      struct _wfinddata32_t* _FindData
 int __cdecl _wfindnext32(
      intptr_t               _FindHandle,
 int __cdecl _wunlink(
 int __cdecl _wrename(
     wchar_t const* _OldFileName,
     wchar_t const* _NewFileName
 errno_t __cdecl _wmktemp_s(
     wchar_t* _TemplateName,
                                size_t   _SizeInWords
__declspec(deprecated("This function or variable may be unsafe. Consider using " "_wmktemp_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) wchar_t* __cdecl _wmktemp( wchar_t *_TemplateName);
 intptr_t __cdecl _wfindfirst32i64(
      struct _wfinddata32i64_t* _FindData
 intptr_t __cdecl _wfindfirst64i32(
      struct _wfinddata64i32_t* _FindData
 intptr_t __cdecl _wfindfirst64(
      struct _wfinddata64_t* _FindData
 int __cdecl _wfindnext32i64(
 int __cdecl _wfindnext64i32(
 int __cdecl _wfindnext64(
 errno_t __cdecl _wsopen_s(
      int*           _FileHandle,
       int            _OpenFlag,
       int            _ShareFlag,
       int            _PermissionFlag
 errno_t __cdecl _wsopen_dispatch(
       int            _OFlag,
       int            _ShFlag,
       int            _PMode,
      int*           _PFileHandle,
       int            _BSecure
#line 253 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_wio.h"
     int __cdecl _wopen(
           int            _OpenFlag,
     int __cdecl _wsopen(
           int            _OpenFlag,
           int            _ShareFlag,
#pragma warning(pop)
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
struct _finddata32_t
    unsigned    attrib;
    _fsize_t    size;
    char        name[260];
struct _finddata32i64_t
    unsigned    attrib;
    __int64     size;
    char        name[260];
struct _finddata64i32_t
    unsigned    attrib;
    _fsize_t    size;
    char        name[260];
struct __finddata64_t
    unsigned    attrib;
    __int64     size;
    char        name[260];
#line 85 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
#line 104 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
     int __cdecl _access(
         char const* _FileName,
           int         _AccessMode
     errno_t __cdecl _access_s(
           int         _AccessMode
     int __cdecl _chmod(
           int         _Mode
     int __cdecl _chsize(
         int  _FileHandle,
         long _Size
     errno_t __cdecl _chsize_s(
         int     _FileHandle,
         __int64 _Size
     int __cdecl _close(
         int _FileHandle
     int __cdecl _commit(
         int _FileHandle
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "_sopen_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     int __cdecl _creat(
           int         _PermissionMode
     int __cdecl _dup(
         int _FileHandle
     int __cdecl _dup2(
         int _FileHandleSrc,
         int _FileHandleDst
     int __cdecl _eof(
         int _FileHandle
     long __cdecl _filelength(
         int _FileHandle
     intptr_t __cdecl _findfirst32(
          struct _finddata32_t* _FindData
     int __cdecl _findnext32(
     int __cdecl _findclose(
     intptr_t __cdecl _get_osfhandle(
             int _FileHandle
     int __cdecl _isatty(
         int _FileHandle
     int __cdecl _locking(
             int  _FileHandle,
             int  _LockMode,
             long _NumOfBytes
     long __cdecl _lseek(
         int  _FileHandle,
         long _Offset,
         int  _Origin
     errno_t __cdecl _mktemp_s(
         char*  _TemplateName,
                             size_t _Size
     __declspec(deprecated("This function or variable may be unsafe. Consider using " "_mktemp_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details.")) char * __cdecl _mktemp( char *_TemplateName);
     int __cdecl _open_osfhandle(
         intptr_t _OSFileHandle,
         int      _Flags
         int __cdecl _pipe(
                int*         _PtHandles,
                           unsigned int _PipeSize,
                           int          _TextMode
     int __cdecl _read(
                                      int          _FileHandle,
         void*        _DstBuf,
                                      unsigned int _MaxCharCount
     int __cdecl remove(
     int __cdecl rename(
         char const* _OldFilename,
         char const* _NewFilename
     int __cdecl _unlink(
     int __cdecl _setmode(
         int _FileHandle,
         int _Mode
     long __cdecl _tell(
         int _FileHandle
    __declspec(deprecated("This function or variable may be unsafe. Consider using " "_umask_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
     int __cdecl _umask(
         int _Mode
     errno_t __cdecl _umask_s(
          int  _NewMode,
         int* _OldMode
     int __cdecl _write(
                                    int          _FileHandle,
         void const*  _Buf,
     __int64 __cdecl _filelengthi64(
         int _FileHandle
     intptr_t __cdecl _findfirst32i64(
          struct _finddata32i64_t* _FindData
     intptr_t __cdecl _findfirst64i32(
          struct _finddata64i32_t* _FindData
     intptr_t __cdecl _findfirst64(
          struct __finddata64_t* _FindData
     int __cdecl _findnext32i64(
     int __cdecl _findnext64i32(
     int __cdecl _findnext64(
     __int64 __cdecl _lseeki64(
         int     _FileHandle,
         __int64 _Offset,
         int     _Origin
     __int64 __cdecl _telli64(
         int _FileHandle
     errno_t __cdecl _sopen_s(
          int*        _FileHandle,
           int         _OpenFlag,
           int         _ShareFlag,
           int         _PermissionMode
     errno_t __cdecl _sopen_s_nolock(
          int*        _FileHandle,
           int         _OpenFlag,
           int         _ShareFlag,
           int         _PermissionMode
     errno_t __cdecl _sopen_dispatch(
           int         _OFlag,
           int         _ShFlag,
           int         _PMode,
          int*        _PFileHandle,
           int         _BSecure
#line 417 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\corecrt_io.h"
         int __cdecl _open(
               int         _OpenFlag,
         int __cdecl _sopen(
               int         _OpenFlag,
               int         _ShareFlag,
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_access" ". See online help for details."))
         int __cdecl access(
               int         _AccessMode
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_chmod" ". See online help for details."))
         int __cdecl chmod(
               int         _AccessMode
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_chsize" ". See online help for details."))
         int __cdecl chsize(
             int  _FileHandle,
             long _Size
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_close" ". See online help for details."))
         int __cdecl close(
             int _FileHandle
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_creat" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_sopen_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         int __cdecl creat(
               int         _PermissionMode
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_dup" ". See online help for details."))
         int __cdecl dup(
             int _FileHandle
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_dup2" ". See online help for details."))
         int __cdecl dup2(
             int _FileHandleSrc,
             int _FileHandleDst
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_eof" ". See online help for details."))
         int __cdecl eof(
             int _FileHandle
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_filelength" ". See online help for details."))
         long __cdecl filelength(
             int _FileHandle
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_isatty" ". See online help for details."))
         int __cdecl isatty(
             int _FileHandle
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_locking" ". See online help for details."))
         int __cdecl locking(
             int  _FileHandle,
             int  _LockMode,
             long _NumOfBytes
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_lseek" ". See online help for details."))
         long __cdecl lseek(
             int  _FileHandle,
             long _Offset,
             int  _Origin
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_mktemp" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_mktemp_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         char * __cdecl mktemp(
             char* _TemplateName
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_open" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_sopen_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         int __cdecl open(
               int         _OpenFlag,
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_read" ". See online help for details."))
         int __cdecl read(
                                          int          _FileHandle,
             void*        _DstBuf,
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_setmode" ". See online help for details."))
         int __cdecl setmode(
             int _FileHandle,
             int _Mode
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_sopen" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_sopen_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         int __cdecl sopen(
             int         _OpenFlag,
             int         _ShareFlag,
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_tell" ". See online help for details."))
         long __cdecl tell(
             int _FileHandle
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_umask" ". See online help for details.")) __declspec(deprecated("This function or variable may be unsafe. Consider using " "_umask_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
         int __cdecl umask(
             int _Mode
        __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_unlink" ". See online help for details."))
         int __cdecl unlink(
         __declspec(deprecated("The POSIX name for this item is deprecated. Instead, use the ISO C " "and C++ conformant name: " "_write" ". See online help for details."))
         int __cdecl write(
                                        int          _FileHandle,
             void const*  _Buf,
__pragma(pack(pop))
#line 13 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\io.h"
                Defined "HAVE_IO_H" to "1"
Checking for header: stdint.h
stdout:
conftest.c
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\stdint.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\stdint.h"
#line 1 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
#line 14 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
typedef signed char        int8_t;
typedef short              int16_t;
typedef int                int32_t;
typedef long long          int64_t;
typedef unsigned char      uint8_t;
typedef unsigned short     uint16_t;
typedef unsigned int       uint32_t;
typedef unsigned long long uint64_t;
typedef signed char        int_least8_t;
typedef short              int_least16_t;
typedef int                int_least32_t;
typedef long long          int_least64_t;
typedef unsigned char      uint_least8_t;
typedef unsigned short     uint_least16_t;
typedef unsigned int       uint_least32_t;
typedef unsigned long long uint_least64_t;
typedef signed char        int_fast8_t;
typedef int                int_fast16_t;
typedef int                int_fast32_t;
typedef long long          int_fast64_t;
typedef unsigned char      uint_fast8_t;
typedef unsigned int       uint_fast16_t;
typedef unsigned int       uint_fast32_t;
typedef unsigned long long uint_fast64_t;
typedef long long          intmax_t;
typedef unsigned long long uintmax_t;
#line 60 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 73 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 86 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 96 "e:\\Program Files (x86)\\Microsoft Visual Studio\\2017\\Enterprise\\VC\\Tools\\MSVC\\14.15.26726\\include\\stdint.h"
#line 23 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\stdint.h"
#line 47 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\stdint.h"
#line 23 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\stdint.h"
#line 47 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\stdint.h"
                Defined "HAVE_STDINT_H" to "1"
Checking for header: pwd.h
stdout:
conftest.c
C:\Users\AliReza\AppData\Local\Temp\petsc-fh63UE\config.headers\conftest.c(3): error #2379: cannot open source file "pwd.h"
  #include <pwd.h>
stdout:
conftest.c
  #include <pwd.h>
#include <pwd.h>
Checking for header: float.h
stdout:
conftest.c
#line 1 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\float.h"
#line 1 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 1 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma once
#pragma pack(pop)
__pragma(pack(pop))
} _Mbstatet;
__pragma(pack(pop))
#line 14 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 30 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 59 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 80 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 96 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 109 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 125 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 138 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 179 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 203 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
 unsigned int __cdecl _clearfp(void);
 __declspec(deprecated("This function or variable may be unsafe. Consider using " "_controlfp_s" " instead. To disable deprecation, use _CRT_SECURE_NO_WARNINGS. " "See online help for details."))
 unsigned int __cdecl _controlfp(
     unsigned int _NewValue,
     unsigned int _Mask
 void __cdecl _set_controlfp(
     unsigned int _Mask
 errno_t __cdecl _controlfp_s(
     unsigned int* _CurrentState,
          unsigned int  _Mask
 unsigned int __cdecl _statusfp(void);
 void __cdecl _fpreset(void);
#line 268 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
 unsigned int __cdecl _control87(
     unsigned int _Mask
#line 287 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
 int* __cdecl __fpecode(void);
 int __cdecl __fpe_flt_rounds(void);
  double __cdecl _copysign( double _Number,  double _Sign);
  double __cdecl _chgsign( double _X);
  double __cdecl _scalb( double _X,  long _Y);
  double __cdecl _logb( double _X);
  double __cdecl _nextafter( double _X,  double _Y);
  int    __cdecl _finite( double _X);
  int    __cdecl _isnan( double _X);
  int    __cdecl _fpclass( double _X);
      float __cdecl _scalbf( float _X,  long _Y);
     void __cdecl fpreset(void);
#line 354 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 378 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
#line 390 "C:\\Program Files (x86)\\Windows Kits\\10\\include\\10.0.17134.0\\ucrt\\float.h"
__pragma(pack(pop))
#line 15 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 48 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
    extern int __cdecl __libm_flt_rounds (void) ;
#line 84 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 96 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 110 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 121 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 131 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 142 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 150 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 186 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 201 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 273 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 347 "E:\\PROGRA~2\\INTELS~1\\COMPIL~2\\windows\\compiler\\include\\float.h"
#line 15 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\float.h"
#line 48 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\float.h"
#line 349 "E:\\Program Files (x86)\\IntelSWTools\\compilers_and_libraries\\windows\\compiler\\include\\float.h"
