[petsc-users] Setting TimeStep in TS
Smith, Barry F. bsmith at mcs.anl.gov
Wed Aug 8 10:37:30 CDT 2018
  I don't understand. One of the arguments to your TSPseudoSetVerifyTimeStep() routine is the "update - latest solution vector" but you seem to want access to the "next" solution that has yet to be computed? There is no way to access that because it has not yet been computed and cannot be computed until the next time step has been decided on.
   Barry
> On Aug 8, 2018, at 3:25 AM, Amir <mhbaghaei at mail.sjtu.edu.cn> wrote:
> Hi
> Trying to set the time step for next step, using TSPseudoSetVerifyTimeStep(), by TTE method. It seems we need to use the new solution at the next step. We can get that by TSSetPostEvaluate(). However, it is called before TimeStep routine. Is there any way that I can access to new solution, while I can set the the time step?
> Thanks for your great time.
> Amir
