[petsc-users] Setting TimeStep in TS
Amir mhbaghaei at mail.sjtu.edu.cn
Wed Aug 8 12:31:23 CDT 2018
You are right! It does have the "latest solution vector". But, I tried to use TSGetSolution() to get it but it seems it gives me the solution at the current time step, not the new solution.
On Aug 8 2018, at 11:37 pm, Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> I don't understand. One of the arguments to your TSPseudoSetVerifyTimeStep() routine is the "update - latest solution vector" but you seem to want access to the "next" solution that has yet to be computed? There is no way to access that because it has not yet been computed and cannot be computed until the next time step has been decided on.
> Barry
> > On Aug 8, 2018, at 3:25 AM, Amir <mhbaghaei at mail.sjtu.edu.cn> wrote:
> > Hi
> > Trying to set the time step for next step, using TSPseudoSetVerifyTimeStep(), by TTE method. It seems we need to use the new solution at the next step. We can get that by TSSetPostEvaluate(). However, it is called before TimeStep routine. Is there any way that I can access to new solution, while I can set the the time step?
> > Thanks for your great time.
> > Amir
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180809/d7c3aa96/attachment.html>
