[petsc-users] Setting TimeStep in TS
Amir
mhbaghaei at mail.sjtu.edu.cn
Wed Aug 8 04:25:30 CDT 2018
Hi
Trying to set the time step for next step, using TSPseudoSetVerifyTimeStep(), by TTE method. It seems we need to use the new solution at the next step. We can get that by TSSetPostEvaluate(). However, it is called before TimeStep routine. Is there any way that I can access to new solution, while I can set the the time step?
Thanks for your great time.
Amir
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180808/f40be36d/attachment.html>
