[petsc-users] DMSetLabelValue takes a lot of time for large domain
Danyang Su danyang.su at gmail.com
Wed Apr 25 11:40:28 CDT 2018
Hi Matthew,
In the worst case, every node/cell may have different label.
Below is one of the worst scenario with 102299 nodes and 102299
different labels for test. I found the time cost increase during the
loop. The first 9300 loop takes least time (<0.5) while the last 9300
loops takes much more time (>7.7), as shown below. If I use larger mesh
with >1 million nodes, it runs very very slowly in this part. The PETSc
is configured with optimization on.
Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-mpich --download-scalapack --download-parmetis
--download-metis --download-ptscotch --download-fblaslapack
--download-hypre --download-superlu_dist --download-hdf5=yes
--download-ctetgen --with-debugging=0 COPTFLAGS="-O3 -march=native
-mtune=native" CXXOPTFLAGS="-O3 -march=native -mtune=native"
FOPTFLAGS="-O3 -march=native -mtune=native"
istart 	iend 	progress 	CPU_Time 	time cost - old (sec) 	time cost - new
(sec)
0 	9299 	0 	1524670045.51166
9300 	18599 	0.100010753 	1524670045.99605 	0.4843890667 	0.497246027
18600 	27899 	0.200010747 	1524670047.32635 	1.330302 	1.3820912838
27900 	37199 	0.300010741 	1524670049.3066 	1.9802515507 	2.2439446449
37200 	46499 	0.400010765 	1524670052.1594 	2.852804184 	3.0739262104
46500 	55799 	0.500010729 	1524670055.90961 	3.7502081394 	3.9270553589
55800 	65099 	0.600010753 	1524670060.47654 	4.5669286251 	4.7571902275
65100 	74399 	0.700010777 	1524670066.0941 	5.6175630093 	5.7428796291
74400 	83699 	0.800010741 	1524670072.53886 	6.44475317 	6.5761549473
83700 	92998 	0.900010765 	1524670079.99072 	7.4518604279 	7.4606924057
92999 	102298 	1 	1524670087.71066 	7.7199423313 	8.2424075603
old code
         do ipoint = 0, istart-1
           !c output time cost, use 1 processor to test
           if (b_enable_output .and. rank == 0) then
             if (mod(ipoint,iprogress) == 0 .or. ipoint == istart-1) then
               !write(*,'(f3.1,1x)',advance="no") (ipoint+1.0)/istart
               write(*,*) ipoint, (ipoint+1.0)/istart,"time",MPI_Wtime()
             end if
           end if
           call DMSetLabelValue(dmda_flow%da,"cid_lg2g",ipoint,         &
                                ipoint+1,ierr)
           CHKERRQ(ierr)
         end do
new code
         call DMCreateLabel(dmda_flow%da,'cid_lg2g',ierr)
         CHKERRQ(ierr)
         call DMGetLabel(dmda_flow%da,'cid_lg2g',label, ierr)
         CHKERRQ(ierr)
             end if
           end if
           call DMLabelSetValue(label,ipoint,ipoint+1,ierr)
           CHKERRQ(ierr)
         end do
Danyang
On 2018-04-25 03:16 AM, Matthew Knepley wrote:
> On Tue, Apr 24, 2018 at 11:57 PM, Danyang Su <danyang.su at gmail.com
> <mailto:danyang.su at gmail.com>> wrote:
>     Hi All,
>     I use DMPlex in unstructured grid code and recently found
>     DMSetLabelValue takes a lot of time for large problem, e.g., num.
>     of cells > 1 million. In my code, I use
> I read your code wrong. For large loop, you should not use the
> convenience function. You should use
>     DMPlexCreateFromCellList ()
> DMGetLabel(dm, name, &label)
>     Loop over all cells/nodes{
>     DMSetLabelValue
> Replace this by DMLabelSetValue(label, point, val)
>     DMPlexDistribute
>     The code works fine except DMSetLabelValue takes a lot of time for
>     large problem. I use DMSetLabelValue to set material id for all
>     the nodes or cells so that each subdomain has a copy of material
>     id. Is there any other functions that can be used more efficient,
>     e.g. set labels by array, not 1 by 1?
> That should take much less time.
>   Thanks,
>      Matt
>     Thanks,
>     Danyang
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180425/33601659/attachment.html>
