[petsc-users] DMSetLabelValue takes a lot of time for large domain
Matthew Knepley
knepley at gmail.com
Wed Apr 25 05:16:16 CDT 2018
On Tue, Apr 24, 2018 at 11:57 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi All,
> I use DMPlex in unstructured grid code and recently found DMSetLabelValue
> takes a lot of time for large problem, e.g., num. of cells > 1 million. In
> my code, I use
I read your code wrong. For large loop, you should not use the convenience
function. You should use
> DMPlexCreateFromCellList ()
DMGetLabel(dm, name, &label)
> Loop over all cells/nodes{
> DMSetLabelValue
Replace this by DMLabelSetValue(label, point, val)
> DMPlexDistribute
> The code works fine except DMSetLabelValue takes a lot of time for large
> problem. I use DMSetLabelValue to set material id for all the nodes or
> cells so that each subdomain has a copy of material id. Is there any other
> functions that can be used more efficient, e.g. set labels by array, not 1
> by 1?
That should take much less time.
Matt
> Thanks,
> Danyang
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180425/7d61b575/attachment.html>
