[petsc-users] DMSetLabelValue takes a lot of time for large domain
    Matthew Knepley
    knepley at gmail.com
    Wed Apr 25 11:47:40 CDT 2018
On Wed, Apr 25, 2018 at 12:40 PM, Danyang Su <danyang.su at gmail.com> wrote:
> Hi Matthew,
> In the worst case, every node/cell may have different label.
> Do not use Label for this. Its not an appropriate thing. If every cell is
different, just use the cell number.
Labels are for mapping a relatively small number of keys (like material
IDs) to sets of points (cells, vertices, etc.)
Its not a great data structure for a permutation.
However, I still do not believe these numbers. The old code does a string
comparison every time. I will setup a test.
   Matt
> Below is one of the worst scenario with 102299 nodes and 102299 different
> labels for test. I found the time cost increase during the loop. The first
> 9300 loop takes least time (<0.5) while the last 9300 loops takes much more
> time (>7.7), as shown below. If I use larger mesh with >1 million nodes, it
> runs very very slowly in this part. The PETSc is configured with
> optimization on.
> Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-mpich --download-scalapack --download-parmetis --download-metis
> --download-ptscotch --download-fblaslapack --download-hypre
> --download-superlu_dist --download-hdf5=yes --download-ctetgen
> --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native
> -mtune=native"
> istart iend progress CPU_Time time cost - old (sec) time cost - new (sec)
> 0 9299 0 1524670045.51166
> 9300 18599 0.100010753 1524670045.99605 0.4843890667 0.497246027
> 18600 27899 0.200010747 1524670047.32635 1.330302 1.3820912838
> 27900 37199 0.300010741 1524670049.3066 1.9802515507 2.2439446449
> 37200 46499 0.400010765 1524670052.1594 2.852804184 3.0739262104
> 46500 55799 0.500010729 1524670055.90961 3.7502081394 3.9270553589
> 55800 65099 0.600010753 1524670060.47654 4.5669286251 4.7571902275
> 65100 74399 0.700010777 1524670066.0941 5.6175630093 5.7428796291
> 74400 83699 0.800010741 1524670072.53886 6.44475317 6.5761549473
> 83700 92998 0.900010765 1524670079.99072 7.4518604279 7.4606924057
> 92999 102298 1 1524670087.71066 7.7199423313 8.2424075603
> old code
>         do ipoint = 0, istart-1
>           !c output time cost, use 1 processor to test
>           if (b_enable_output .and. rank == 0) then
>             if (mod(ipoint,iprogress) == 0 .or. ipoint == istart-1) then
>               !write(*,'(f3.1,1x)',advance="no") (ipoint+1.0)/istart
>               write(*,*) ipoint, (ipoint+1.0)/istart,"time",MPI_Wtime()
>             end if
>           end if
>           call DMSetLabelValue(dmda_flow%da,"cid_lg2g",ipoint,         &
>                                ipoint+1,ierr)
>           CHKERRQ(ierr)
>         end do
> new code
>         call DMCreateLabel(dmda_flow%da,'cid_lg2g',ierr)
>         CHKERRQ(ierr)
>         call DMGetLabel(dmda_flow%da,'cid_lg2g',label, ierr)
>         CHKERRQ(ierr)
>             end if
>           end if
>           call DMLabelSetValue(label,ipoint,ipoint+1,ierr)
>           CHKERRQ(ierr)
>         end do
> Thanks,
> Danyang
> On 2018-04-25 03:16 AM, Matthew Knepley wrote:
> On Tue, Apr 24, 2018 at 11:57 PM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi All,
>> I use DMPlex in unstructured grid code and recently found DMSetLabelValue
>> takes a lot of time for large problem, e.g., num. of cells > 1 million. In
>> my code, I use
> I read your code wrong. For large loop, you should not use the convenience
> function. You should use
>> DMPlexCreateFromCellList ()
> DMGetLabel(dm, name, &label)
>> Loop over all cells/nodes{
>> DMSetLabelValue
> Replace this by DMLabelSetValue(label, point, val)
>> DMPlexDistribute
>> The code works fine except DMSetLabelValue takes a lot of time for large
>> problem. I use DMSetLabelValue to set material id for all the nodes or
>> cells so that each subdomain has a copy of material id. Is there any other
>> functions that can be used more efficient, e.g. set labels by array, not 1
>> by 1?
> That should take much less time.
>   Thanks,
>      Matt
>> Thanks,
>> Danyang
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180425/a3828bfa/attachment-0001.html>
