[petsc-users] Error: likely due to memory corruption
Tue Apr 24 08:34:03 CDT 2018
On Tue, Apr 24, 2018 at 9:29 AM, Yongxiang Wu <yongxiang27 at gmail.com> wrote:
> Hello PETSC users:
> i am using slepc4py to compute a geenral eigenvalue problem.  I have
> compiled PETSC/SLEPC and petsc4py/slepc4py on a cray cluster (hazelhen).
> When I run my test case, I get the following error. Would anyone provide me
> the direction to solve it?
As Satish said, it looks like you are running on hardware that the binary
was not compiled for (maybe KNL?).
     Matt
> regards
> Yong
> Slepsc begins ...
> Parallel read in petsc binary matrix for each processor!!!
> load petsc binary finished
> Start solving ...
> [0]PETSC ERROR: [2]PETSC ERROR: ------------------------------
> [5]PETSC ERROR: ------------------------------
> [0]PETSC ERROR: [2]PETSC ERROR: [1]PETSC ERROR:
> Caught signal number 4 Illegal instruction: Likely due to memory corruption
> [5]PETSC ERROR: [0]PETSC ERROR: [2]PETSC ERROR:
> Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: [2]PETSC ERROR: [0]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [5]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: [2]PETSC ERROR: or try http://valgrind.org on GNU/linux
> and Apple Mac OS X to find memory corruption errors
> [5]PETSC ERROR: [3]PETSC ERROR: [4]PETSC ERROR:
> or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [3]PETSC ERROR: [1]PETSC ERROR: Caught signal number 4 Illegal
> or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [3]PETSC ERROR: [4]PETSC ERROR: [2]PETSC ERROR: Caught signal number 4
> configure using --with-debugging=yes, recompile, link, and run
> [2]PETSC ERROR: to get more information on the crash.
> [5]PETSC ERROR: [1]PETSC ERROR: Try option -start_in_debugger or
> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> corruption errors
> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [5]PETSC ERROR: [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [4]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and
> run
> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [5]PETSC ERROR: to get more information on the crash.
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [4]PETSC ERROR: to get more information on the crash.
> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [4]PETSC ERROR: [3]PETSC ERROR: configure using --with-debugging=yes,
> Rank 2 [Tue Apr 24 14:17:09 2018] [c4-3c2s4n2] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 2
> Rank 0 [Tue Apr 24 14:17:09 2018] [c4-3c2s4n2] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> Rank 5 [Tue Apr 24 14:17:09 2018] [c4-3c2s4n2] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 5
> Rank 1 [Tue Apr 24 14:17:09 2018] [c4-3c2s4n2] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 1
> Rank 3 [Tue Apr 24 14:17:09 2018] [c4-3c2s4n2] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 3
> Rank 4 [Tue Apr 24 14:17:09 2018] [c4-3c2s4n2] application called
> MPI_Abort(MPI_COMM_WORLD, 59) - process 4
> _pmiu_daemon(SIGCHLD): [NID 07826] [c4-3c2s4n2] [Tue Apr 24 14:17:09 2018]
> PE RANK 0 exit signal Aborted
> [NID 07826] 2018-04-24 14:17:09 Apid 298658: initiated application
> termination
> Application 298658 exit codes: 134
> Application 298658 resources: utime ~6s, stime ~2s, Rss ~488036, inblocks
> ~862, outblocks ~0
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180424/7768408d/attachment-0001.html>
