[petsc-users] DMSetLabelValue takes a lot of time for large domain
Danyang Su
danyang.su at gmail.com
Tue Apr 24 22:57:26 CDT 2018
Hi All,
I use DMPlex in unstructured grid code and recently found
DMSetLabelValue takes a lot of time for large problem, e.g., num. of
cells > 1 million. In my code, I use
DMPlexCreateFromCellList ()
Loop over all cells/nodes{
DMSetLabelValue
DMPlexDistribute
The code works fine except DMSetLabelValue takes a lot of time for large
problem. I use DMSetLabelValue to set material id for all the nodes or
cells so that each subdomain has a copy of material id. Is there any
other functions that can be used more efficient, e.g. set labels by
array, not 1 by 1?
Danyang
