[petsc-users] Problems with VecGetArray under sub-communicators
Dave May
dave.mayhem23 at gmail.com
Sun Apr 22 14:14:36 CDT 2018
On Sun, 22 Apr 2018 at 20:13, Zin Lin <zinlin.zinlin at gmail.com> wrote:
> Hi
> I am experiencing possible memory issues with VecGetArray when it is used
> under sub-communicators (when I split the PETSC_COMM_WORLD to multiple
> subcomms). The following is the minimal code. Basically, you can test that
> if you parallelize the vector to more than one processor under a subcomm,
> the array obtained from the VecGetArray call doesn't seem to be correct.
> Please test it with
> 1) mpirun -np 1 ./example -ncomms 1
> 2) mpirun -np 2 ./example -ncomms 2
> 3) mpirun -np 2 ./example -ncomms 1
> 4) mpirun -np 4 ./example -ncomms 2
> you will 1) and 2) work as expected while in 3) and 4) some entries of the
> array are assigned erroneous values.
First - your call to PetscPrintf contains a mistake. The second instance of
i is missing.
Second (more important), you cannot access the raw array obtained via
VecGetArray() using global indices. You must use local indices.
Change the access to _u[i-ns] and the code should work.
Also, debugging based on what printf() tells you can be misleading. It's
much better to use valgrind - see here
https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
Dave
> Any input will be appreciated.
> Thanks
> Zin
> Minimal Code
> PetscErrorCode main(int argc, char **argv)
> MPI_Init(NULL, NULL);
> PetscInitialize(&argc,&argv,NULL,NULL);
> int size;
> MPI_Comm_size(MPI_COMM_WORLD, &size);
> PetscPrintf(PETSC_COMM_WORLD,"\tThe total number of processors is
> %d\n",size);
> //check if the number of processors is divisible by the number of
> subcomms
> int ncomms, np_per_comm;
> PetscOptionsGetInt(NULL,"-ncomms",&ncomms,NULL);
> if(!(size%ncomms==0)) SETERRQ(PETSC_COMM_WORLD,1,"The number of
> processes must be a multiple of ncomms so that it is divisible by the
> number of subcomms.");
> np_per_comm=size/ncomms;
> PetscPrintf(PETSC_COMM_WORLD,"\tThe number of subcomms is %d.\n\tEach
> subcomm has %d processors.\n",ncomms,np_per_comm);
> //calculate the colour of each subcomm ( = rank of each processor /
> number of processors in each subcomm )
> //note once calculated, the colour is fixed throughout the entire run
> int rank;
> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
> MPI_Comm subcomm;
> int colour = rank/np_per_comm;
> MPI_Comm_split(MPI_COMM_WORLD, colour, rank, &subcomm);
> Vec u;
> PetscScalar *_u;
> int i,ns,ne;
> PetscScalar tmp;
> VecCreateMPI(subcomm,PETSC_DECIDE,10,&u);
> VecSet(u,1.0+PETSC_i*0);
> VecGetArray(u,&_u);
> VecGetOwnershipRange(u,&ns,&ne);
> for(i=ns;i<ne;i++){
> VecGetValues(u,1,&i,&tmp);
> PetscPrintf(PETSC_COMM_SELF,"colour %d, u[%d]_array = %g + i * (%g),
> u[%d]_vec = %g + i * %g \n",colour,i,creal(_u[i]),cimag(_u[i]),
Insert i here
creal(tmp),cimag(tmp));
> VecRestoreArray(u,&_u);
> PetscFinalize();
> return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180422/cf0e4c89/attachment.html>
