[petsc-users] Problems with VecGetArray under sub-communicators
Zin Lin zinlin.zinlin at gmail.com
Sun Apr 22 14:34:30 CDT 2018
Thanks a lot!
That clears things up.
I do have one more question though.
The behavior of DMDAVecGetArray is different then? From ex3.c (below), it
doesn't seem like the raw array needs the local indices?
>From ex3.c,
  DMDAVecGetArray
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDAVecGetArray.html#DMDAVecGetArray>(cda,global,&coors);
  DMDAGetCorners
<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDAGetCorners.html#DMDAGetCorners>(cda,&mstart,&nstart,&pstart,&m,&n,&p);
  for (i=mstart; i<mstart+m; i++) {
    for (j=nstart; j<nstart+n; j++) {
      for (k=pstart; k<pstart+p; k++) {
          coors[k][j][i].x = ...
On Sun, Apr 22, 2018 at 3:14 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On Sun, 22 Apr 2018 at 20:13, Zin Lin <zinlin.zinlin at gmail.com> wrote:
>> Hi
>> I am experiencing possible memory issues with VecGetArray when it is used
>> under sub-communicators (when I split the PETSC_COMM_WORLD to multiple
>> subcomms). The following is the minimal code. Basically, you can test that
>> if you parallelize the vector to more than one processor under a subcomm,
>> the array obtained from the VecGetArray call doesn't seem to be correct.
>> Please test it with
>> 1)  mpirun -np 1 ./example -ncomms 1
>> 2)  mpirun -np 2 ./example -ncomms 2
>> 3)  mpirun -np 2 ./example -ncomms 1
>> 4)  mpirun -np 4 ./example -ncomms 2
>> you will 1) and 2) work as expected while in 3) and 4) some entries of
>> the array are assigned erroneous values.
> First - your call to PetscPrintf contains a mistake. The second instance
> of i is missing.
> Second (more important), you cannot access the raw array obtained via
> VecGetArray() using global indices. You must use local indices.
> Change the access to _u[i-ns] and the code should work.
> Also, debugging based on what printf() tells you can be misleading. It's
> much better to use valgrind - see here
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> Thanks,
>   Dave
>> Any input will be appreciated.
>> Thanks
>> Zin
>> Minimal Code
>> PetscErrorCode main(int argc, char **argv)
>>   MPI_Init(NULL, NULL);
>>   PetscInitialize(&argc,&argv,NULL,NULL);
>>   int size;
>>   MPI_Comm_size(MPI_COMM_WORLD, &size);
>>   PetscPrintf(PETSC_COMM_WORLD,"\tThe total number of processors is
>> %d\n",size);
>>   //check if the number of processors is divisible by the number of
>> subcomms
>>   int ncomms, np_per_comm;
>>   PetscOptionsGetInt(NULL,"-ncomms",&ncomms,NULL);
>>   if(!(size%ncomms==0)) SETERRQ(PETSC_COMM_WORLD,1,"The number of
>> processes must be a multiple of ncomms so that it is divisible by the
>> number of subcomms.");
>>   np_per_comm=size/ncomms;
>>   PetscPrintf(PETSC_COMM_WORLD,"\tThe number of subcomms is %d.\n\tEach
>> subcomm has %d processors.\n",ncomms,np_per_comm);
>>   //calculate the colour of each subcomm ( = rank of each processor /
>> number of processors in each subcomm )
>>   //note once calculated, the colour is fixed throughout the entire run
>>   int rank;
>>   MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>>   MPI_Comm subcomm;
>>   int colour = rank/np_per_comm;
>>   MPI_Comm_split(MPI_COMM_WORLD, colour, rank, &subcomm);
>>   Vec u;
>>   PetscScalar *_u;
>>   int i,ns,ne;
>>   PetscScalar tmp;
>>   VecCreateMPI(subcomm,PETSC_DECIDE,10,&u);
>>   VecSet(u,1.0+PETSC_i*0);
>>   VecGetArray(u,&_u);
>>   VecGetOwnershipRange(u,&ns,&ne);
>>   for(i=ns;i<ne;i++){
>>     VecGetValues(u,1,&i,&tmp);
>>     PetscPrintf(PETSC_COMM_SELF,"colour %d, u[%d]_array = %g + i * (%g),
>> u[%d]_vec = %g + i * %g \n",colour,i,creal(_u[i]),cimag(_u[i]),
> Insert i here
> creal(tmp),cimag(tmp));
>>   VecRestoreArray(u,&_u);
>>   PetscFinalize();
>>   return 0;
Zin Lin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180422/f31d0c36/attachment-0001.html>
