[petsc-users] Problems with VecGetArray under sub-communicators
Zin Lin
zinlin.zinlin at gmail.com
Sun Apr 22 13:13:13 CDT 2018
Hi
I am experiencing possible memory issues with VecGetArray when it is used
under sub-communicators (when I split the PETSC_COMM_WORLD to multiple
subcomms). The following is the minimal code. Basically, you can test that
if you parallelize the vector to more than one processor under a subcomm,
the array obtained from the VecGetArray call doesn't seem to be correct.
Please test it with
1) mpirun -np 1 ./example -ncomms 1
2) mpirun -np 2 ./example -ncomms 2
3) mpirun -np 2 ./example -ncomms 1
4) mpirun -np 4 ./example -ncomms 2
you will 1) and 2) work as expected while in 3) and 4) some entries of the
array are assigned erroneous values.
Any input will be appreciated.
Thanks
Zin
Minimal Code
PetscErrorCode main(int argc, char **argv)
MPI_Init(NULL, NULL);
PetscInitialize(&argc,&argv,NULL,NULL);
int size;
MPI_Comm_size(MPI_COMM_WORLD, &size);
PetscPrintf(PETSC_COMM_WORLD,"\tThe total number of processors is
%d\n",size);
//check if the number of processors is divisible by the number of subcomms
int ncomms, np_per_comm;
PetscOptionsGetInt(NULL,"-ncomms",&ncomms,NULL);
if(!(size%ncomms==0)) SETERRQ(PETSC_COMM_WORLD,1,"The number of processes
must be a multiple of ncomms so that it is divisible by the number of
subcomms.");
np_per_comm=size/ncomms;
PetscPrintf(PETSC_COMM_WORLD,"\tThe number of subcomms is %d.\n\tEach
subcomm has %d processors.\n",ncomms,np_per_comm);
//calculate the colour of each subcomm ( = rank of each processor /
number of processors in each subcomm )
//note once calculated, the colour is fixed throughout the entire run
int rank;
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MPI_Comm subcomm;
int colour = rank/np_per_comm;
MPI_Comm_split(MPI_COMM_WORLD, colour, rank, &subcomm);
Vec u;
PetscScalar *_u;
int i,ns,ne;
PetscScalar tmp;
VecCreateMPI(subcomm,PETSC_DECIDE,10,&u);
VecSet(u,1.0+PETSC_i*0);
VecGetArray(u,&_u);
VecGetOwnershipRange(u,&ns,&ne);
for(i=ns;i<ne;i++){
VecGetValues(u,1,&i,&tmp);
PetscPrintf(PETSC_COMM_SELF,"colour %d, u[%d]_array = %g + i * (%g),
u[%d]_vec = %g + i * %g
\n",colour,i,creal(_u[i]),cimag(_u[i]),creal(tmp),cimag(tmp));
VecRestoreArray(u,&_u);
PetscFinalize();
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180422/3e6dcaff/attachment.html>
