[petsc-users] Reuse KSP
    Matthew Knepley
    knepley at gmail.com
    Tue Apr 17 07:38:40 CDT 2018
On Tue, Apr 17, 2018 at 8:33 AM, Young, Matthew, Adam <may at bu.edu> wrote:
> My code (C/C++) uses PETSc to solve a linear system at each iteration in a
> time-stepping scheme. The PETSc routines are separated out because the
> scheme that uses them is optional in the larger code.
> At each time step, the PETSc scheme calls a routine that includes:
>   Mat A;
>   Vec x,b;
>   KSP ksp;
>   [Set up A,x,b]
>   KSPCreate(PETSC_COMM_WORLD,&ksp);
>   [Build A and b from simulation data]
>   [Set nullspace of A with MatSetNullSpace]
>   KSPSetOperators(ksp,A,A);
>   KSPSetFromOptions(ksp);
>   KSPSolve(ksp,b,x);
>   [Write x into an instance of our array class, perform checks, etc.]
>   KSPDestroy(&ksp);
>   return(0);
> My question is: If I want to use superLU_DIST with the option
> -mat_superlu_dist_fact SamePattern (or SamePattern_SameRowPerm), should I
> move KSPCreate/Destroy outside of the time-step loop in the larger code?
1) Yes
2) How are you using LU when A has a nullspace?
3) You can also move out SetFromOptions().
  Matt
> Thanks.
> Matthew Young
> PhD Candidate
> Astronomy Department
> Boston University
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180417/7421dc09/attachment.html>
