[petsc-users] Reuse KSP
Young, Matthew, Adam
may at bu.edu
Tue Apr 17 07:33:21 CDT 2018
My code (C/C++) uses PETSc to solve a linear system at each iteration in a time-stepping scheme. The PETSc routines are separated out because the scheme that uses them is optional in the larger code.
At each time step, the PETSc scheme calls a routine that includes:
Mat A;
Vec x,b;
KSP ksp;
[Set up A,x,b]
KSPCreate(PETSC_COMM_WORLD,&ksp);
[Build A and b from simulation data]
[Set nullspace of A with MatSetNullSpace]
KSPSetOperators(ksp,A,A);
KSPSetFromOptions(ksp);
KSPSolve(ksp,b,x);
[Write x into an instance of our array class, perform checks, etc.]
KSPDestroy(&ksp);
return(0);
My question is: If I want to use superLU_DIST with the option -mat_superlu_dist_fact SamePattern (or SamePattern_SameRowPerm), should I move KSPCreate/Destroy outside of the time-step loop in the larger code?
Thanks.
Matthew Young
PhD Candidate
Astronomy Department
Boston University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180417/c4dc7401/attachment.html>
