[petsc-users] Reuse KSP
    Young, Matthew, Adam
    may at bu.edu
    Tue Apr 17 07:48:15 CDT 2018
Sent: Tuesday, April 17, 2018 8:38 AM
To: Young, Matthew, Adam
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Reuse KSP
On Tue, Apr 17, 2018 at 8:33 AM, Young, Matthew, Adam <may at bu.edu<mailto:may at bu.edu>> wrote:
My code (C/C++) uses PETSc to solve a linear system at each iteration in a time-stepping scheme. The PETSc routines are separated out because the scheme that uses them is optional in the larger code.
At each time step, the PETSc scheme calls a routine that includes:
  Mat A;
  Vec x,b;
  KSP ksp;
  [Set up A,x,b]
  KSPCreate(PETSC_COMM_WORLD,&ksp);
  [Build A and b from simulation data]
  [Set nullspace of A with MatSetNullSpace]
  KSPSetOperators(ksp,A,A);
  KSPSetFromOptions(ksp);
  KSPSolve(ksp,b,x);
  [Write x into an instance of our array class, perform checks, etc.]
  KSPDestroy(&ksp);
  return(0);
My question is: If I want to use superLU_DIST with the option -mat_superlu_dist_fact SamePattern (or SamePattern_SameRowPerm), should I move KSPCreate/Destroy outside of the time-step loop in the larger code?
1) Yes
2) How are you using LU when A has a nullspace?
My bad - that code is in there from when I was trying iterative solvers. Should I remove it if I use LU or will PETSc just ignore it?
3) You can also move out SetFromOptions().
Thanks for the advice. So, that means I'll build A and b from simulation data, SetOperators(), Solve(), and carry on?
  Matt
Thanks.
Matthew Young
PhD Candidate
Astronomy Department
Boston University
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180417/69ed5662/attachment-0001.html>
