[petsc-users] Optimal coloring using -snes_fd_color with DMDACreate
Buesing, Henrik
hbuesing at eonerc.rwth-aachen.de
Fri Apr 13 03:14:45 CDT 2018
Great! Thank you! I will have a look at the code and I will also check how much function evaluations are needed in my case.
Henrik
Dipl.-Math. Henrik Büsing
Institute for Applied Geophysics and Geothermal Energy
E.ON Energy Research Center
RWTH Aachen University
Mathieustr. 10 | Tel +49 (0)241 80 49907
52074 Aachen, Germany | Fax +49 (0)241 80 49889
http://www.eonerc.rwth-aachen.de/GGE
-----Ursprüngliche Nachricht-----
Von: Smith, Barry F. <bsmith at mcs.anl.gov>
Gesendet: Donnerstag, 12. April 2018 16:42
An: Buesing, Henrik <HBuesing at eonerc.rwth-aachen.de>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Betreff: Re: [petsc-users] Optimal coloring using -snes_fd_color with
DMDACreate
I'm not familiar with that paper so I am not sure if it produces
exactly the same colorings. It is based on the same principle. The
coloring is done in
/src/dm/impls/da/fdda.c DMCreateColoring_DA_3d_MPIAIJ() so you could
compare. Note if they have more efficient special cases in the paper
they could be added to the code without too much difficulty.
Barry
> On Apr 12, 2018, at 8:26 AM, Buesing, Henrik <hbuesing at eonerc.rwth-
aachen.de> wrote:
> Dear all,
> When I use –snes_fd_color with my da created by DMDACreate3d, will it
use an optimal coloring algorithm (see [1]) to estimate the Jacobian?
> Thank you!
> Henrik
> [1]
> Goldfarb/Toint: Optimal estimation of Jacobian and Hessian matrices
that arise in finite difference calculations
> https://doi.org/10.1090/S0025-5718-1984-0744925-5
