[petsc-users] Which matrix object type should I use?
Klaus Burkart k_burkart at yahoo.com
Thu Apr 12 13:54:05 CDT 2018
I am confused with matrix object types and which one to use in my case:
I want to solve a linear system using multiple processes. The steps I am struggling with is the import of the global matrix and global rhs vector into applicable PETSc objects.
The global matrix is currently stored in CSR format using 3 arrays. Array one contains all the row indices, array two all the column indices, array three all the values of the global matrix. In addition to that, there's a vector object containing the rhs vector.
I think for the vector object I should use VectorCreateMPI with m set to PETSC_DECIDE?
What's the matrix object I should use in my case which also takes care of the allocation local matrices to the processes at a later stage i.e. creates the local matrices in line with the rhs vector?
Klaus
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180412/fe5d079b/attachment.html>
