[petsc-users] Cuda libraries and DMDA
Manuel Valera
mvalera-w at sdsu.edu
Mon Apr 9 20:34:58 CDT 2018
It looks like it's working now :)
i needed to setup the DMMatrix and that made the trick,
On Mon, Apr 9, 2018 at 6:13 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> Oh ok, thanks Matt,
> I think the problem is that i am not using DMCreateMatrix at all but a
> regular MatCreate, i will follow ex44f and get back to you,
> I am calling DMSetFromOptions right after creating the DMDA, way before
> the matrix is created,
> On Mon, Apr 9, 2018 at 5:57 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Apr 9, 2018 at 7:55 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>>> On Mon, Apr 9, 2018 at 4:53 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Apr 9, 2018 at 7:52 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>>> Ok thanks, i'm learning more every day,
>>>>> I still get the same error, i am running with -dm_vec_type viennacl
>>>>> -dm_mat_type aijviennacl -pc_type saviennacl
>>>> 1) Are you calling DMSetFromOptions()?
>>> Yes, i get:
>> Let me be more precise. For the DMDA you are using, you must call
>> DMSetFromOptions() before you call
>> DMCreateMatrix (or before its called automatically), in order to get the
>> Mat type you want from the command line.
>> If you do not get the right type, you know this has not happened.
>> Matt
>>> [valera at node50 Src]$ grep DMSetFromOptions *.f90
>>> DMDAmetrics.f90:call DMSetFromOptions(daDerivs,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daGrid,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daSingle,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daConstants,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daSgs,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daLaplacian,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daMetrics,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daCenters,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daPressureCoeffs,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daDivSgs,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daDummy,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daVelocities,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daScalars,ierr)
>>> dmdaobjs.f90: call DMSetFromOptions(daDensity,ierr)
>>> fileIO.f90: call DMSetFromOptions(daWriteCenters,ierr)
>>> fileIO.f90: call DMSetFromOptions(daWriteUgrid,ierr)
>>> fileIO.f90: call DMSetFromOptions(daWriteVgrid,ierr)
>>> fileIO.f90: call DMSetFromOptions(daWriteWgrid,ierr)
>>> romsmodule.f90: call DMSetFromOptions(daSeqEastWest_u,ierrp)
>>> romsmodule.f90: call DMSetFromOptions(daSeqEastWest_v,ierrp)
>>> romsmodule.f90: call DMSetFromOptions(daSeqEastWest_w,ierrp)
>>> seamountbeamroms.f90: call DMSetFromOptions(daMinPlaneZ,i
>>> err)
>>>> 2) Does your DM have a prefix?
>>> What does this mean? the one used in the KSPSolve is daDummy
>>> Thanks,
>>>> Matt
>>>>> The error:
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>> [0]PETSC ERROR: Currently only handles ViennaCL matrices
>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>> ocumentation/faq.html for trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9-13-g05d412b GIT
>>>>> Date: 2018-04-09 08:39:52 -0500
>>>>> [0]PETSC ERROR: ./gcmBEAM on a cuda-debug named node50 by valera Mon
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>>>>> --download-mpich --with-blaslapack-dir=/usr/lib64 COPTFLAGS=-O2
>>>>> CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=1 --download-hypre
>>>>> --with-debugging=1 --with-cuda=1 --CUDAFLAGS=-arch=sm_60 --download-hypre
>>>>> --download-viennacl --download-cusp --download-cusp-commit=116b090
>>>>> [0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
>>>>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
>>>>> [0]PETSC ERROR: #2 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>>>> interface/precon.c
>>>>> [0]PETSC ERROR: #3 KSPSetUp() line 381 in
>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #4 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #5 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>>>> interface/precon.c
>>>>> Finished setting up matrix objects
>>>>> Exiting PrepareNetCDF
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #6 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #7 PCSetUp() line 923 in /home/valera/petsc/src/ksp/pc/
>>>>> interface/precon.c
>>>>> [0]PETSC ERROR: #8 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #9 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.7096996307373047E-002
>>>>> PETSC_Solve_SSG: 1.7321825027465820E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #10 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #11 PCSetUp() line 923 in
>>>>> /home/valera/petsc/src/ksp/pc/interface/precon.c
>>>>> [0]PETSC ERROR: #12 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #13 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2702941894531250E-002
>>>>> PETSC_Solve_SSG: 1.2929439544677734E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #14 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #15 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #16 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #17 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2219429016113281E-002
>>>>> PETSC_Solve_SSG: 1.2480735778808594E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #18 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #19 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #20 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #21 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2894392013549805E-002
>>>>> PETSC_Solve_SSG: 1.3124227523803711E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #22 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #23 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #24 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #25 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2183427810668945E-002
>>>>> PETSC_Solve_SSG: 1.2410402297973633E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #26 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #27 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #28 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #29 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2546300888061523E-002
>>>>> PETSC_Solve_SSG: 1.2778043746948242E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #30 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #31 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #32 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #33 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2255668640136719E-002
>>>>> PETSC_Solve_SSG: 1.2504816055297852E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #34 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #35 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #36 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #37 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.3138055801391602E-002
>>>>> PETSC_Solve_SSG: 1.3362646102905273E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #38 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #39 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #40 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #41 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2072801589965820E-002
>>>>> PETSC_Solve_SSG: 1.2319087982177734E-002
>>>>> Apr 9 16:50:21 2018
>>>>> [0]PETSC ERROR: #42 PCSetUp_SAVIENNACL() line 47 in
>>>>> [0]PETSC ERROR: #43 PCSetUp() line 923 in
>>>>> [0]PETSC ERROR: #44 KSPSetUp() line 381 in
>>>>> [0]PETSC ERROR: #45 KSPSolve() line 612 in
>>>>> PETSC_Solve_Sol: 1.2498617172241211E-002
>>>>> PETSC_Solve_SSG: 1.2726306915283203E-002
>>>>> TMain_Loop: 1.1020996570587158
>>>>> WARNING! There are options you set that were not used!
>>>>> WARNING! could be spelling mistake, etc!
>>>>> On Mon, Apr 9, 2018 at 4:45 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Apr 9, 2018 at 7:27 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>>>> wrote:
>>>>>>> On Mon, Apr 9, 2018 at 4:09 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Mon, Apr 9, 2018 at 6:12 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>>>>>> wrote:
>>>>>>>>> Hello guys,
>>>>>>>>> I've made advances in my CUDA acceleration project, as you
>>>>>>>>> remember i have a CFD model in need of better execution times.
>>>>>>>>> So far i have been able to solve the pressure system in the GPU
>>>>>>>>> and the rest in serial, using PETSc only for this pressure solve, the
>>>>>>>>> library i got to work was ViennaCL. First question, do i still have to
>>>>>>>>> switch installations to use either CUDA library? this was a suggestion
>>>>>>>>> before, so in order to use CUSP instead of ViennaCL, for example, i
>>>>>>>>> currently have to change installations, is this still the case?
>>>>>>>> I am not sure what that means exactly. However, you can build a
>>>>>>>> PETSc with CUDA and ViennaCL support. The type of Vec/Mat is selected at
>>>>>>>> runtime.
>>>>>>> Karl Rupp wrote in a previous email:
>>>>>>> * * Right now only one of {native CUDA, CUSP, ViennaCL} can be
>>>>>>> activated at configure time. This will be fixed later this month.*
>>>>>>> I was asking if this was already solved in 3.9,
>>>>>> Karl knows better than I do. I thought that was fixed, but maybe not
>>>>>> in this release.
>>>>>>>>> Now, i started working in a fully parallelized version of the
>>>>>>>>> model, which uses the DMs and DMDAs to distribute the arrays, if i try the
>>>>>>>>> same flags as before i get an error saying "Currently only handles ViennaCL
>>>>>>>>> matrices" when trying to solve for pressure, i get this is a feature still
>>>>>>>>> not implemented? what options do i have to solve pressure, or assign a DMDA
>>>>>>>>> array update to be done specifically in a GPU device?
>>>>>>>> If we can't see the error, we are just guessing. Please send the
>>>>>>>> entire error message.
>>>>>>> Got it, I will paste the error at the end of this email
>>>>>> It is asking for a ViennaCL matrix. You must tell the DM to create
>>>>>> one:
>>>>>>>> Note, we only do linear algebra on the GPU, so none of the
>>>>>>>> FormFunction/FormJacobian stuff for DMDA would be on the GPU.
>>>>>>> Yes, we only use it for linear algebra, e.g. solving a linear system
>>>>>>> and updating an array with a problematic algorithm.
>>>>>>>>> I was thinking of using the VecScatterCreateToZero for a regular
>>>>>>>>> vector,
>>>>>>>> Why do you want a serial vector?
>>>>>>> Because it looks live ViennaCL doesn't handle arrays created with
>>>>>>> DMDAVec, it was just an idea
>>>>>> No, it just needs the right type.
>>>>>>>> but then i would have to create a vector and copy the DMDAVec into
>>>>>>>>> it,
>>>>>>>> I do not understand what it means to copy the DM into the Vec.
>>>>>>> I meant copying a DMDAVec into a Vec object, the first is created
>>>>>>> with a DMDA object for it's mapping across processors,
>>>>>> There is no such thing as a DMDAVec. Everything is just a Vec.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> is this accomplished with DMDAVecGetArrayReadF90 and then just
>>>>>>>>> copy? do you think this will generate too much overhead?
>>>>>>>>> Thanks so much for your input,
>>>>>>>>> Manuel
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>> The error happens when trying to use KSPSolve() for a vector made
>>>>>>> with DMDAVec routines, the matrix is created without any DMDA routines
>>>>>>> Error:
>>>>>>> v3.8.4-2418-gd9c423b GIT Date: 2018-04-02 11:59:41 +0200
>>>>>>> [0]PETSC ERROR: ./gcmBEAM on a cuda named node50 by valera Mon Apr
>>>>>>> 9 16:24:26 2018
>>>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --download-mpich
>>>>>>> --download-fblaslapack COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2
>>>>>>> --with-shared-libraries=1 --download-hypre --with-debugging=no
>>>>>>> --with-cuda=1 --CUDAFLAGS=-arch=sm_60 --download-hypre --download-viennacl
>>>>>>> --download-cusp
>>>>>>> [0]PETSC ERROR: #2 PCSetUp() line 924 in
>>>>>>> 9 16:24:26 2018
>>>>>>> --download-cusp
>>>>>>> [0]PETSC ERROR: #5 PCSetUp() line 924 in
>>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation, probably memory access out of range
>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> -on_error_attach_debugger
>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>> ocumentation/faq.html#valgrind
>>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>>>> Mac OS X to find memory corruption errors
>>>>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>>>>> link, and run
>>>>>>> [0]PETSC ERROR: to get more information on the crash.
>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>> 9 16:24:26 2018
>>>>>>> --download-cusp
>>>>>>> [0]PETSC ERROR: #6 User provided function() line 0 in unknown file
>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180409/8863c104/attachment-0001.html>
