[petsc-users] Cuda libraries and DMDA
    Matthew Knepley
    knepley at gmail.com
    Mon Apr  9 20:40:20 CDT 2018
On Mon, Apr 9, 2018 at 9:34 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
> It looks like it's working now :)
> i needed to setup the DMMatrix and that made the trick,
Glad its working.
    Matt
> Thanks,
> On Mon, Apr 9, 2018 at 6:13 PM, Manuel Valera <mvalera-w at sdsu.edu> wrote:
>> Oh ok, thanks Matt,
>> I think the problem is that i am not using DMCreateMatrix at all but a
>> regular MatCreate, i will follow ex44f and get back to you,
>> I am calling DMSetFromOptions right after creating the DMDA, way before
>> the matrix is created,
>> On Mon, Apr 9, 2018 at 5:57 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Apr 9, 2018 at 7:55 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>> wrote:
>>>> On Mon, Apr 9, 2018 at 4:53 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Apr 9, 2018 at 7:52 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>>> wrote:
>>>>>> Ok thanks, i'm learning more every day,
>>>>>> I still get the same error, i am running with -dm_vec_type viennacl
>>>>>> -dm_mat_type aijviennacl -pc_type saviennacl
>>>>> 1) Are you calling DMSetFromOptions()?
>>>> Yes, i get:
>>> Let me be more precise. For the DMDA you are using, you must call
>>> DMSetFromOptions() before you call
>>> DMCreateMatrix (or before its called automatically), in order to get the
>>> Mat type you want from the command line.
>>> If you do not get the right type, you know this has not happened.
>>>    Matt
>>>> [valera at node50 Src]$ grep DMSetFromOptions *.f90
>>>> DMDAmetrics.f90:call DMSetFromOptions(daDerivs,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daGrid,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daSingle,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daConstants,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daSgs,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daLaplacian,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daMetrics,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daCenters,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daPressureCoeffs,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daDivSgs,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daDummy,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daVelocities,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daScalars,ierr)
>>>> dmdaobjs.f90:            call DMSetFromOptions(daDensity,ierr)
>>>> fileIO.f90:            call DMSetFromOptions(daWriteCenters,ierr)
>>>> fileIO.f90:            call DMSetFromOptions(daWriteUgrid,ierr)
>>>> fileIO.f90:            call DMSetFromOptions(daWriteVgrid,ierr)
>>>> fileIO.f90:            call DMSetFromOptions(daWriteWgrid,ierr)
>>>> romsmodule.f90:        call DMSetFromOptions(daSeqEastWest_u,ierrp)
>>>> romsmodule.f90:        call DMSetFromOptions(daSeqEastWest_v,ierrp)
>>>> romsmodule.f90:        call DMSetFromOptions(daSeqEastWest_w,ierrp)
>>>> seamountbeamroms.f90:                call DMSetFromOptions(daMinPlaneZ,i
>>>> err)
>>>>> 2) Does your DM have a prefix?
>>>> What does this mean? the one used in the KSPSolve is daDummy
>>>> Thanks,
>>>>>   Matt
>>>>>> The error:
>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>> [0]PETSC ERROR: No support for this operation for this object type
>>>>>> [0]PETSC ERROR: Currently only handles ViennaCL matrices
>>>>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/d
>>>>>> ocumentation/faq.html for trouble shooting.
>>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.9-13-g05d412b  GIT
>>>>>> Date: 2018-04-09 08:39:52 -0500
>>>>>> [0]PETSC ERROR: ./gcmBEAM on a cuda-debug named node50 by valera Mon
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda-debug
>>>>>> --download-mpich --with-blaslapack-dir=/usr/lib64 COPTFLAGS=-O2
>>>>>> CXXOPTFLAGS=-O2 FOPTFLAGS=-O2 --with-shared-libraries=1 --download-hypre
>>>>>> --with-debugging=1 --with-cuda=1 --CUDAFLAGS=-arch=sm_60 --download-hypre
>>>>>> --download-viennacl --download-cusp --download-cusp-commit=116b090
>>>>>> [0]PETSC ERROR: #1 PCSetUp_SAVIENNACL() line 47 in
>>>>>> /home/valera/petsc/src/ksp/pc/impls/saviennaclcuda/saviennacl.cu
>>>>>> [0]PETSC ERROR: #2 PCSetUp() line 923 in
>>>>>> /home/valera/petsc/src/ksp/pc/interface/precon.c
>>>>>> [0]PETSC ERROR: #3 KSPSetUp() line 381 in
>>>>>> /home/valera/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #4 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #5 PCSetUp() line 923 in
>>>>>>  Finished setting up matrix objects
>>>>>>  Exiting PrepareNetCDF
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #6 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #7 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #8 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #9 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.7096996307373047E-002
>>>>>>  PETSC_Solve_SSG:   1.7321825027465820E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #10 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #11 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #12 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #13 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2702941894531250E-002
>>>>>>  PETSC_Solve_SSG:   1.2929439544677734E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #14 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #15 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #16 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #17 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2219429016113281E-002
>>>>>>  PETSC_Solve_SSG:   1.2480735778808594E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #18 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #19 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #20 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #21 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2894392013549805E-002
>>>>>>  PETSC_Solve_SSG:   1.3124227523803711E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #22 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #23 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #24 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #25 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2183427810668945E-002
>>>>>>  PETSC_Solve_SSG:   1.2410402297973633E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #26 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #27 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #28 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #29 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2546300888061523E-002
>>>>>>  PETSC_Solve_SSG:   1.2778043746948242E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #30 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #31 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #32 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #33 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2255668640136719E-002
>>>>>>  PETSC_Solve_SSG:   1.2504816055297852E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #34 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #35 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #36 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #37 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.3138055801391602E-002
>>>>>>  PETSC_Solve_SSG:   1.3362646102905273E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #38 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #39 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #40 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #41 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2072801589965820E-002
>>>>>>  PETSC_Solve_SSG:   1.2319087982177734E-002
>>>>>> Apr  9 16:50:21 2018
>>>>>> [0]PETSC ERROR: #42 PCSetUp_SAVIENNACL() line 47 in
>>>>>> [0]PETSC ERROR: #43 PCSetUp() line 923 in
>>>>>> [0]PETSC ERROR: #44 KSPSetUp() line 381 in
>>>>>> [0]PETSC ERROR: #45 KSPSolve() line 612 in
>>>>>>  PETSC_Solve_Sol:   1.2498617172241211E-002
>>>>>>  PETSC_Solve_SSG:   1.2726306915283203E-002
>>>>>>  TMain_Loop:    1.1020996570587158
>>>>>> WARNING! There are options you set that were not used!
>>>>>> WARNING! could be spelling mistake, etc!
>>>>>> On Mon, Apr 9, 2018 at 4:45 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Mon, Apr 9, 2018 at 7:27 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>>>>> wrote:
>>>>>>>> On Mon, Apr 9, 2018 at 4:09 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Mon, Apr 9, 2018 at 6:12 PM, Manuel Valera <mvalera-w at sdsu.edu>
>>>>>>>>> wrote:
>>>>>>>>>> Hello guys,
>>>>>>>>>> I've made advances in my CUDA acceleration project, as you
>>>>>>>>>> remember i have a CFD model in need of better execution times.
>>>>>>>>>> So far i have been able to solve the pressure system in the GPU
>>>>>>>>>> and the rest in serial, using PETSc only for this pressure solve, the
>>>>>>>>>> library i got to work was ViennaCL. First question, do i still have to
>>>>>>>>>> switch installations to use either CUDA library? this was a suggestion
>>>>>>>>>> before, so in order to use CUSP instead of ViennaCL, for example, i
>>>>>>>>>> currently have to change installations, is this still the case?
>>>>>>>>> I am not sure what that means exactly. However, you can build a
>>>>>>>>> PETSc with CUDA and ViennaCL support. The type of Vec/Mat is selected at
>>>>>>>>> runtime.
>>>>>>>> Karl Rupp wrote in a previous email:
>>>>>>>> * * Right now only one of {native CUDA, CUSP, ViennaCL} can be
>>>>>>>> activated at configure time. This will be fixed later this month.*
>>>>>>>> I was asking if this was already solved in 3.9,
>>>>>>> Karl knows better than I do. I thought that was fixed, but maybe not
>>>>>>> in this release.
>>>>>>>>>> Now, i started working in a fully parallelized version of the
>>>>>>>>>> model, which uses the DMs and DMDAs to distribute the arrays, if i try the
>>>>>>>>>> same flags as before i get an error saying "Currently only handles ViennaCL
>>>>>>>>>> matrices" when trying to solve for pressure, i get this is a feature still
>>>>>>>>>> not implemented? what options do i have to solve pressure, or assign a DMDA
>>>>>>>>>> array update to be done specifically in a GPU device?
>>>>>>>>> If we can't see the error, we are just guessing. Please send the
>>>>>>>>> entire error message.
>>>>>>>> Got it, I will paste the error at the end of this email
>>>>>>> It is asking for a ViennaCL matrix. You must tell the DM to create
>>>>>>> one:
>>>>>>>>> Note, we only do linear algebra on the GPU, so none of the
>>>>>>>>> FormFunction/FormJacobian stuff for DMDA would be on the GPU.
>>>>>>>> Yes, we only use it for linear algebra, e.g. solving a linear
>>>>>>>> system and updating an array with a problematic algorithm.
>>>>>>>>>> I was thinking of using the VecScatterCreateToZero for a regular
>>>>>>>>>> vector,
>>>>>>>>> Why do you want a serial vector?
>>>>>>>> Because it looks live ViennaCL doesn't handle arrays created with
>>>>>>>> DMDAVec, it was just an idea
>>>>>>> No, it just needs the right type.
>>>>>>>>> but then i would have to create a vector and copy the DMDAVec into
>>>>>>>>>> it,
>>>>>>>>> I do not understand what it means to copy the DM into the Vec.
>>>>>>>> I meant copying a DMDAVec into a Vec object, the first is created
>>>>>>>> with a DMDA object for it's mapping across processors,
>>>>>>> There is no such thing as a DMDAVec. Everything is just a Vec.
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> is this accomplished with DMDAVecGetArrayReadF90 and then just
>>>>>>>>>> copy? do you think this will generate too much overhead?
>>>>>>>>>> Thanks so much for your input,
>>>>>>>>>> Manuel
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.caam.rice.edu/~mk51/>
>>>>>>>> The error happens when trying to use KSPSolve() for a vector made
>>>>>>>> with DMDAVec routines, the matrix is created without any DMDA routines
>>>>>>>> Error:
>>>>>>>> v3.8.4-2418-gd9c423b  GIT Date: 2018-04-02 11:59:41 +0200
>>>>>>>> [0]PETSC ERROR: ./gcmBEAM on a cuda named node50 by valera Mon Apr
>>>>>>>> 9 16:24:26 2018
>>>>>>>> [0]PETSC ERROR: Configure options PETSC_ARCH=cuda --download-mpich
>>>>>>>> --download-fblaslapack COPTFLAGS=-O2 CXXOPTFLAGS=-O2 FOPTFLAGS=-O2
>>>>>>>> --with-shared-libraries=1 --download-hypre --with-debugging=no
>>>>>>>> --with-cuda=1 --CUDAFLAGS=-arch=sm_60 --download-hypre --download-viennacl
>>>>>>>> --download-cusp
>>>>>>>> [0]PETSC ERROR: #2 PCSetUp() line 924 in
>>>>>>>> 9 16:24:26 2018
>>>>>>>> --download-cusp
>>>>>>>> [0]PETSC ERROR: #5 PCSetUp() line 924 in
>>>>>>>> [0]PETSC ERROR: ------------------------------
>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>> Violation, probably memory access out of range
>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>> -on_error_attach_debugger
>>>>>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/d
>>>>>>>> ocumentation/faq.html#valgrind
>>>>>>>> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>>>>>>> Mac OS X to find memory corruption errors
>>>>>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>>>>>> link, and run
>>>>>>>> [0]PETSC ERROR: to get more information on the crash.
>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>> 9 16:24:26 2018
>>>>>>>> --download-cusp
>>>>>>>> [0]PETSC ERROR: #6 User provided function() line 0 in  unknown file
>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=59
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180409/e0792dd8/attachment-0001.html>
