[petsc-users] Could not execute "['git', 'rev-parse', '--git-dir']"
Garvey, Cormac T cormac.garvey at inl.gov
Wed Apr 4 18:04:57 CDT 2018
I though it was fixed, yes I will look into it again.
Do you get an error just doing a git clone on falcon1 and falcon2?
On Wed, Apr 4, 2018 at 4:48 PM, Kong, Fande <fande.kong at inl.gov> wrote:
> module load git/2.16.2-GCCcore-5.4.0"  also works.
> Could you somehow make the default git work as well? Hence we do not need
> to have this extra "module load for git"
> Fande,
> On Wed, Apr 4, 2018 at 4:43 PM, Kong, Fande <fande.kong at inl.gov> wrote:
>> Thanks, Cormac,
>> *module load git/1.8.5.2-GCC-4.8.3 *
>> works for me.
>> Did not try "module load git/2.16.2-GCCcore-5.4.0" yet.
>> I will try, and get it back here.
>> Fande
>> On Wed, Apr 4, 2018 at 4:39 PM, Garvey, Cormac T <cormac.garvey at inl.gov>
>> wrote:
>>> We needed to rebuilt git on the INL falcon cluster because github server
>>> changed such that it no longer accepted TLSv1.
>>> The default git on the falcon cluster /usr/bin/git is just a wrapper
>>> script, so users would not need to load any modules to
>>> use git.
>>> When you load load git on falcon1 or falcon2 does it still fail?
>>> Thanks,
>>> Cormac.
>>> On Wed, Apr 4, 2018 at 4:28 PM, Kong, Fande <fande.kong at inl.gov> wrote:
>>>> Hi Cormac,
>>>> Do you know anything on "git"? How did you guys build git on the
>>>> falcon1?  The default git on Falcon1 does not work with petsc any more.
>>>> Fande,
>>>> On Wed, Apr 4, 2018 at 4:20 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>>> Ok - I don't think I have access to this OS.
>>>>> And I see its from 2009 [sure its enterprise os - with regular
>>>>> backport updates]
>>>>> But its wierd that you have such a new version of git at /usr/bin/git
>>>>> From what we know so far - the problem appears to be some bad
>>>>> interaction of python-2.6 with this old OS [i.e old glibc etc..] - and
>>>>> this new git version [binary built locally or on a different OS and
>>>>> installed locally ?].
>>>>> Satish
>>>>> On Wed, 4 Apr 2018, Kong, Fande wrote:
>>>>> >  moose]$ uname -a
>>>>> > Linux falcon1 3.0.101-108.13-default #1 SMP Wed Oct 11 12:30:40 UTC
>>>>> 2017
>>>>> > (294ccfe) x86_64 x86_64 x86_64 GNU/Linux
>>>>> > moose]$ lsb_release -a
>>>>> > LSB Version:
>>>>> > core-2.0-noarch:core-3.2-noarch:core-4.0-noarch:core-2.0-x86
>>>>> _64:core-3.2-x86_64:core-4.0-x86_64:desktop-4.0-amd64:deskto
>>>>> p-4.0-noarch:graphics-2.0-amd64:graphics-2.0-noarch:graphics
>>>>> -3.2-amd64:graphics-3.2-noarch:graphics-4.0-amd64:graphics-4.0-noarch
>>>>> > Distributor ID:    SUSE LINUX
>>>>> > Description:    SUSE Linux Enterprise Server 11 (x86_64)
>>>>> > Release:    11
>>>>> > Codename:    n/a
>>>>> > On Wed, Apr 4, 2018 at 4:08 PM, Satish Balay <balay at mcs.anl.gov>
>>>>> wrote:
>>>>> > > > > was your '2.16.2' version installed from source?
>>>>> > > > Checking for program /usr/bin/git...found
>>>>> > > >                 Defined make macro "GIT" to "git"
>>>>> > > > Executing: git --version
>>>>> > > > stdout: git version 2.16.2
>>>>> > > > I gues its the OS default package
>>>>> > > > Machine platform:
>>>>> > > > ('Linux', 'falcon1', '3.0.101-108.13-default', '#1 SMP Wed Oct 11
>>>>> > > 12:30:40 UTC 2017 (294ccfe)', 'x86_64', 'x86_64')
>>>>> > > > Python version:
>>>>> > > > 2.6.9 (unknown, Aug  5 2016, 11:15:31)
>>>>> > > > [GCC 4.3.4 [gcc-4_3-branch revision 152973]]
>>>>> > > > What OS/version is on this machine? I can try reproducing in a VM
>>>>> > > It is strange that the kernel is old [3.0 - perhaps LTS OS] ,
>>>>> python is
>>>>> > > old [2.6] - but git is new? [2.16?]
>>>>> > > https://urldefense.proofpoint.com/v2/url?u=https-3A__
>>>>> > > mirrors.edge.kernel.org_pub_software_scm_git_&d=DwIBAg&c=
>>>>> > > 54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=DUUt3SRGI0_
>>>>> > > JgtNaS3udV68GRkgV4ts7XKfj2opmiCY&m=WF6ZxIh9Z9Hh2kYY0w70aNrgfPicp6
>>>>> > > kgIh5BvezPiEY&s=KWMsO7XC0-pQuQ_mD03tNJWEpxSTATlZW_DmX0QofGw&e=
>>>>> > > git-2.16.2.tar.gz                                  16-Feb-2018
>>>>> 17:48
>>>>> > > 7M
>>>>> > > Satish
>>> Cormac Garvey
>>> HPC Software Consultant
>>> Scientific Computing
>>> Idaho National Laboratory
>>> Ph: 208-526-6294
Cormac Garvey
Ph: 208-526-6294
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180404/f3e57777/attachment.html>
