[petsc-users] Obtaining compiling and building information from a.out
TAY wee-beng
zonexo at gmail.com
Wed Apr 4 04:11:17 CDT 2018
I emailed as shown below a while ago but I have yet to get a response.
Can someone help?
Thank you very much.
Yours sincerely,
TAY Wee-Beng (Zheng Weiming) 郑伟明
Personal research webpage: http://tayweebeng.wixsite.com/website
Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
linkedin: www.linkedin.com/in/tay-weebeng
On 29/3/2018 1:48 PM, TAY wee-beng wrote:
> On 28/3/2018 5:45 PM, Matthew Knepley wrote:
>> On Tue, Mar 27, 2018 at 10:17 PM, TAY wee-beng <zonexo at gmail.com
>> <mailto:zonexo at gmail.com>> wrote:
>> Hi Dave,
>> I looked at the output using log_view and re-compile. However,
>> although I use the same options "-xHost -g -O3 -openmp" (some
>> filenames and dir names are now different but they are actually
>> the same), I still get different results timing. I have attach
>> both, fast and slow. So what else can I do to pinpoint the
>> differences?
>> The solver options must be different. In Fast, there is almost no
>> time in LUFactor, but in Slow its half the time.
>> Matt
> Hi Matt,
> Finally found that it was because I was using KSPRICHARDSON in the new
> code. KSPGMRES in the old code is much faster.
> I also tried cg, lsqr, fgmres. CG and GMRES seem similar in term of
> best performance. Are there any other recommendations to try? The
> Poisson eqn is symmetric.
> I also tried -pc_type mg -pc_mg_nlevels 2 instead of -poisson_pc_type
> gamg -poisson_pc_gamg_agg_nsmooths 1.
> It reduces the runtime from 2.25 to 1.46min.
> However, I found that my subroutine is very similar to my momentum
> subroutine, which is based on KSPSolve:
> 0. DMDACreate, DMDACreate3d etc
> 1. Assemble matrix
> 2. KSPSetOperators, KSPSetType etc
> 3. KSPSolve
> However, the 2D Poisson example in ex5f.F90 uses SNESSetDM, SNESSolve
> etc. So does it matter if I use SNESSolve or KSPSolve if I'm using
> -pc_type mg?
>> Yours sincerely,
>> Personal research webpage:http://tayweebeng.wixsite.com/website
>> <http://tayweebeng.wixsite.com/website>
>> Youtube research showcase:https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>> <https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA>
>> linkedin:www.linkedin.com/in/tay-weebeng
>> <http://www.linkedin.com/in/tay-weebeng>
>> On 27/3/2018 5:22 PM, Dave May wrote:
>>> On 27 March 2018 at 10:16, TAY wee-beng <zonexo at gmail.com
>>> Hi,
>>> I have been compiling and building different version of my
>>> CFD with the intel 2016, 2018 compilers, and also different
>>> compiling options.
>>> I tested a version of my a.out and it is much faster than
>>> the other a.out, using only 3 min instead of more than 10min
>>> to solve a certain case using GAMG.
>>> However, I can't recall how it was compiled. I only know
>>> that I used the intel 2016 compiler.
>>> So is there any way I can find out how the a.out was
>>> compiled? Like what options were used?
>>> Since you posted to the list I presume "a.out" links against
>>> petsc...
>>> If so, run your code with
>>> -log_view
>>> Upon calling PetscFinalize(), you will get all the options given
>>> to PETSc configure, plus the CFLAGS, link lines, etc.
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180404/2df0217b/attachment-0001.html>
