[petsc-users] Obtaining compiling and building information from a.out
Wed Apr 4 06:55:51 CDT 2018
On Thu, Mar 29, 2018 at 1:48 AM, TAY wee-beng <zonexo at gmail.com> wrote:
> On 28/3/2018 5:45 PM, Matthew Knepley wrote:
> On Tue, Mar 27, 2018 at 10:17 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> Hi Dave,
>> I looked at the output using log_view and re-compile. However, although I
>> use the same options "-xHost -g -O3 -openmp" (some filenames and dir names
>> are now different but they are actually the same), I still get different
>> results timing. I have attach both, fast and slow. So what else can I do to
>> pinpoint the differences?
> The solver options must be different. In Fast, there is almost no time in
> LUFactor, but in Slow its half the time.
>    Matt
> Hi Matt,
> Finally found that it was because I was using KSPRICHARDSON in the new
> code. KSPGMRES in the old code is much faster.
> I also tried cg, lsqr, fgmres. CG and GMRES seem similar in term of best
> performance. Are there any other recommendations to try? The Poisson eqn is
> symmetric.
Krylov solvers fundamentally do not matter for solving elliptic problems.
It comes down to your preconditioner.
> I also tried -pc_type mg -pc_mg_nlevels 2 instead of -poisson_pc_type gamg
> -poisson_pc_gamg_agg_nsmooths 1.
> It reduces the runtime from 2.25 to 1.46min.
Yes, GMG has faster setup time than AMG. The solve time should be similar.
> However, I found that my subroutine is very similar to my momentum
> subroutine, which is based on KSPSolve:
> 0. DMDACreate, DMDACreate3d etc
> 1. Assemble matrix
> 2. KSPSetOperators, KSPSetType etc
> 3. KSPSolve
> However, the 2D Poisson example in ex5f.F90 uses SNESSetDM, SNESSolve etc.
> So does it matter if I use SNESSolve or KSPSolve if I'm using -pc_type mg?
Not really.
     Matt
> Thank you very much.
>> Yours sincerely,
>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>> Personal research webpage: http://tayweebeng.wixsite.com/website
>> Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>> linkedin: www.linkedin.com/in/tay-weebeng
>> On 27/3/2018 5:22 PM, Dave May wrote:
>> On 27 March 2018 at 10:16, TAY wee-beng <zonexo at gmail.com> wrote:
>>> Hi,
>>> I have been compiling and building different version of my CFD with the
>>> intel 2016, 2018 compilers, and also different compiling options.
>>> I tested a version of my a.out and it is much faster than the other
>>> a.out, using only 3 min instead of more than 10min to solve a certain case
>>> using GAMG.
>>> However, I can't recall how it was compiled. I only know that I used the
>>> intel 2016 compiler.
>>> So is there any way I can find out how the a.out was compiled? Like what
>>> options were used?
>> Since you posted to the list I presume "a.out" links against petsc...
>> If so, run your code with
>>   -log_view
>> Upon calling PetscFinalize(), you will get all the options given to PETSc
>> configure, plus the CFLAGS, link lines, etc.
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180404/84b21808/attachment.html>
