[petsc-users] PDSLin 2.0.0 example memory corruption error
    Afrah Najib
    afrah.nacib at gmail.com
    Fri Sep 15 06:00:36 CDT 2017
I am trying to run the examples of PDSLin 2.0.0[
http://portal.nersc.gov/project/sparse/pdslin/]
but I got the following error:
:~/pdslin_2.0.0/examples$ mpiexec -n 8 ./dtest input matrices/U.dat
 input->num_doms      = 4
Preconditioner parameters:
 input->nproc_dcomp   = 4
 input->nproc_schur   = 4
 input->free_local    = PDSLin_NO
 input->dcomp_type    = SCOTCH
 input->diag_tau      = 0.000000e+00
 input->tau_sub       = 0.000000e+00
 input->drop_tau0     = 1.000000e-02
 input->drop_tau2     = 0.000000e+00
 input->drop_tau1     = 1.000000e-03
 input->drop_tau3     = 0.000000e+00
 input->ilu_lvl       = -1
 input->equil_dom    = 0 (no equil or row perm).
 input->perm_dom      = 0
 input->mat_type      = UNSYMMETRIC
 input->mat_pattern   = UNSYMMETRIC
 input->blk_size      = 1
 input->equil_schur   = 5
 input->relax_factor  = 3.000000e-01
 input->pperm_schur   = PDSLin_YES
 input->psymb_schur   = PDSLin_YES
 input->dom_solver    = SLU_DIST
Schur solution parameters:
 input->inner_outer   = PDSLin_NO
 input->outer_tol     = 1.000000e-12
 input->outer_max     = 50
 input->schur_itrs    = PDSLin_NO
 input->exact_schur   = PDSLin_NO
 input->direct_schur  = PDSLin_NO
 input->explicit_restart  = PDSLin_NO
 input->inner_max     = 500
 input->inner_restart = 60
 input->inner_tol     = 1.000000e-12
 input->inner_solver  = PDSLin_FGMRES
==== dtest(): reading in matrix from matrices/U.dat
 took 1.785858e-01 seconds to read matrix.
==== dtest: factorizing the matrix.
PARMETIS ERROR: Poor initial vertex distribution. Processor 2 has no
vertices assigned to it!
PARMETIS ERROR: Poor initial vertex distribution. Processor 3 has no
[0]PETSC ERROR:
[0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[0]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
to find memory corruption errors
[0]PETSC ERROR: likely location of problem given in stack below
[0]PETSC ERROR: ---------------------  Stack Frames
[0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[0]PETSC ERROR:       INSTEAD the line number of the start of the function
[0]PETSC ERROR:       is given.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Signal received
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[0]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
Fri Sep 15 13:53:42 2017
[0]PETSC ERROR: Configure options
PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
PETSC_ARCH=arch-linux2-c-debug
prefix=/home/afrah/PETSc-library2/petsc-3.7.6/source --with-cc=mpicc
--with-cxx=mpicxx --with-fc=mpif90 --download-blacs --download-scalapack=1
--download-mumps=1 --with-valgrind=1 --with-valgrind-dir="[/usr/local/bin]"
[0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
[1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[1]PETSC ERROR: likely location of problem given in stack below
[1]PETSC ERROR: ---------------------  Stack Frames
[1]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[1]PETSC ERROR:       INSTEAD the line number of the start of the function
[1]PETSC ERROR:       is given.
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Signal received
[1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[1]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[1]PETSC ERROR: Configure options
[1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
[2]PETSC ERROR:
[2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[2]PETSC ERROR: or see
[2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[2]PETSC ERROR: likely location of problem given in stack below
[2]PETSC ERROR: ---------------------  Stack Frames
[2]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[2]PETSC ERROR:       INSTEAD the line number of the start of the function
[2]PETSC ERROR:       is given.
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Signal received
[2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[2]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[2]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[2]PETSC ERROR: Configure options
[2]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2
[3]PETSC ERROR:
[3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[3]PETSC ERROR: or see
[3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[3]PETSC ERROR: likely location of problem given in stack below
[3]PETSC ERROR: ---------------------  Stack Frames
[3]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[3]PETSC ERROR:       INSTEAD the line number of the start of the function
[3]PETSC ERROR:       is given.
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Signal received
[3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[3]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[3]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[3]PETSC ERROR: Configure options
[3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
[4]PETSC ERROR:
[4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[4]PETSC ERROR: or see
[4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[4]PETSC ERROR: likely location of problem given in stack below
[4]PETSC ERROR: ---------------------  Stack Frames
[4]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[4]PETSC ERROR:       INSTEAD the line number of the start of the function
[4]PETSC ERROR:       is given.
[4]PETSC ERROR: --------------------- Error Message
[4]PETSC ERROR: Signal received
[4]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[4]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[4]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[4]PETSC ERROR: Configure options
[4]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 4
[5]PETSC ERROR:
[5]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[5]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[5]PETSC ERROR: or see
[5]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[5]PETSC ERROR: likely location of problem given in stack below
[5]PETSC ERROR: ---------------------  Stack Frames
[5]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[5]PETSC ERROR:       INSTEAD the line number of the start of the function
[5]PETSC ERROR:       is given.
[5]PETSC ERROR: --------------------- Error Message
[5]PETSC ERROR: Signal received
[5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[5]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[5]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[5]PETSC ERROR: Configure options
[5]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 5
[6]PETSC ERROR: [7]PETSC ERROR:
[7]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[7]PETSC ERROR: or see
[7]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[7]PETSC ERROR: likely location of problem given in stack below
[7]PETSC ERROR: ---------------------  Stack Frames
[7]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[7]PETSC ERROR:       INSTEAD the line number of the start of the function
[7]PETSC ERROR:       is given.
[7]PETSC ERROR: --------------------- Error Message
[7]PETSC ERROR: Signal received
[7]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[7]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[7]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[7]PETSC ERROR: Configure options
[7]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 7
[6]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
[6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[6]PETSC ERROR: or see
[6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
[6]PETSC ERROR: likely location of problem given in stack below
[6]PETSC ERROR: ---------------------  Stack Frames
[6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
[6]PETSC ERROR:       INSTEAD the line number of the start of the function
[6]PETSC ERROR:       is given.
[6]PETSC ERROR: --------------------- Error Message
[6]PETSC ERROR: Signal received
[6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[6]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
[6]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
[6]PETSC ERROR: Configure options
[6]PETSC ERROR: #1 User provided function() line 0 in  unknown file
application called MPI_Abort(MPI_COMM_WORLD, 59) - process 6
any idea
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170915/71018f99/attachment-0001.html>
