[petsc-users] PDSLin 2.0.0 example memory corruption error
    Matthew Knepley
    knepley at gmail.com
    Fri Sep 15 07:01:06 CDT 2017
On Fri, Sep 15, 2017 at 7:00 AM, Afrah Najib <afrah.nacib at gmail.com> wrote:
> Hi,
> I am trying to run the examples of PDSLin 2.0.0[http://portal.nersc.gov/
> project/sparse/pdslin/]
> but I got the following error:
This is not a PETSc error. PETSc is just catching the signal. I think you
have to contact
the PDSLin developers.
     Matt
> :~/pdslin_2.0.0/examples$ mpiexec -n 8 ./dtest input matrices/U.dat
>  input->num_doms      = 4
> Preconditioner parameters:
>  input->nproc_dcomp   = 4
>  input->nproc_schur   = 4
>  input->free_local    = PDSLin_NO
>  input->dcomp_type    = SCOTCH
>  input->diag_tau      = 0.000000e+00
>  input->tau_sub       = 0.000000e+00
>  input->drop_tau0     = 1.000000e-02
>  input->drop_tau2     = 0.000000e+00
>  input->drop_tau1     = 1.000000e-03
>  input->drop_tau3     = 0.000000e+00
>  input->ilu_lvl       = -1
>  input->equil_dom    = 0 (no equil or row perm).
>  input->perm_dom      = 0
>  input->mat_type      = UNSYMMETRIC
>  input->mat_pattern   = UNSYMMETRIC
>  input->blk_size      = 1
>  input->equil_schur   = 5
>  input->relax_factor  = 3.000000e-01
>  input->pperm_schur   = PDSLin_YES
>  input->psymb_schur   = PDSLin_YES
>  input->dom_solver    = SLU_DIST
> Schur solution parameters:
>  input->inner_outer   = PDSLin_NO
>  input->outer_tol     = 1.000000e-12
>  input->outer_max     = 50
>  input->schur_itrs    = PDSLin_NO
>  input->exact_schur   = PDSLin_NO
>  input->direct_schur  = PDSLin_NO
>  input->explicit_restart  = PDSLin_NO
>  input->inner_max     = 500
>  input->inner_restart = 60
>  input->inner_tol     = 1.000000e-12
>  input->inner_solver  = PDSLin_FGMRES
> ==== dtest(): reading in matrix from matrices/U.dat
>  took 1.785858e-01 seconds to read matrix.
> ==== dtest: factorizing the matrix.
> PARMETIS ERROR: Poor initial vertex distribution. Processor 2 has no
> vertices assigned to it!
> PARMETIS ERROR: Poor initial vertex distribution. Processor 3 has no
> [0]PETSC ERROR: ------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> X to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
> [0]PETSC ERROR:       is given.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [0]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> Fri Sep 15 13:53:42 2017
> [0]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> PETSC_ARCH=arch-linux2-c-debug prefix=/home/afrah/PETSc-library2/petsc-3.7.6/source
> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90 --download-blacs
> --download-scalapack=1 --download-mumps=1 --with-valgrind=1
> --with-valgrind-dir="[/usr/local/bin]"
> [0]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> [1]PETSC ERROR: ------------------------------
> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [1]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [1]PETSC ERROR: likely location of problem given in stack below
> [1]PETSC ERROR: ---------------------  Stack Frames
> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [1]PETSC ERROR:       INSTEAD the line number of the start of the function
> [1]PETSC ERROR:       is given.
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Signal received
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [1]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [1]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [1]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [1]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
> [2]PETSC ERROR: ------------------------------
> [2]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [2]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [2]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [2]PETSC ERROR: likely location of problem given in stack below
> [2]PETSC ERROR: ---------------------  Stack Frames
> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [2]PETSC ERROR:       INSTEAD the line number of the start of the function
> [2]PETSC ERROR:       is given.
> [2]PETSC ERROR: --------------------- Error Message
> [2]PETSC ERROR: Signal received
> [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [2]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [2]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [2]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [2]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 2
> [3]PETSC ERROR: ------------------------------
> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [3]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [3]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [3]PETSC ERROR: likely location of problem given in stack below
> [3]PETSC ERROR: ---------------------  Stack Frames
> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [3]PETSC ERROR:       INSTEAD the line number of the start of the function
> [3]PETSC ERROR:       is given.
> [3]PETSC ERROR: --------------------- Error Message
> [3]PETSC ERROR: Signal received
> [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [3]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [3]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [3]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [3]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 3
> [4]PETSC ERROR: ------------------------------
> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [4]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [4]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [4]PETSC ERROR: likely location of problem given in stack below
> [4]PETSC ERROR: ---------------------  Stack Frames
> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [4]PETSC ERROR:       INSTEAD the line number of the start of the function
> [4]PETSC ERROR:       is given.
> [4]PETSC ERROR: --------------------- Error Message
> [4]PETSC ERROR: Signal received
> [4]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [4]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [4]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [4]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [4]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 4
> [5]PETSC ERROR: ------------------------------
> [5]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [5]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [5]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [5]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [5]PETSC ERROR: likely location of problem given in stack below
> [5]PETSC ERROR: ---------------------  Stack Frames
> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [5]PETSC ERROR:       INSTEAD the line number of the start of the function
> [5]PETSC ERROR:       is given.
> [5]PETSC ERROR: --------------------- Error Message
> [5]PETSC ERROR: Signal received
> [5]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [5]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [5]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [5]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [5]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 5
> [6]PETSC ERROR: [7]PETSC ERROR: ------------------------------
> [7]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [7]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [7]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [7]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [7]PETSC ERROR: likely location of problem given in stack below
> [7]PETSC ERROR: ---------------------  Stack Frames
> [7]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [7]PETSC ERROR:       INSTEAD the line number of the start of the function
> [7]PETSC ERROR:       is given.
> [7]PETSC ERROR: --------------------- Error Message
> [7]PETSC ERROR: Signal received
> [7]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [7]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [7]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [7]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [7]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 7
> [6]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/
> [6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS
> [6]PETSC ERROR: likely location of problem given in stack below
> [6]PETSC ERROR: ---------------------  Stack Frames
> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> [6]PETSC ERROR:       INSTEAD the line number of the start of the function
> [6]PETSC ERROR:       is given.
> [6]PETSC ERROR: --------------------- Error Message
> [6]PETSC ERROR: Signal received
> [6]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> [6]PETSC ERROR: Petsc Release Version 3.7.6, Apr, 24, 2017
> [6]PETSC ERROR: ./dtest on a arch-linux2-c-debug named afrah-pc by afrah
> [6]PETSC ERROR: Configure options PETSC_DIR=/home/afrah/PETSc-library2/petsc-3.7.6
> [6]PETSC ERROR: #1 User provided function() line 0 in  unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 6
> any idea
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170915/56fbdfd7/attachment-0001.html>
