[petsc-users] Example for solving system of pde with snes
Matthew Knepley
knepley at gmail.com
Sun Sep 10 07:06:04 CDT 2017
On Sun, Sep 10, 2017 at 2:39 AM, Praveen C <cpraveen at gmail.com> wrote:
> Dear all
> I am solving 3 coupled first order PDE in 2-D with SNES. The stencil is
> (3+1+3) in both directions due to weno scheme. I want to use matrix-free
> gmres. For preconditioner, I will use first order scheme with stencil
> (1+1+1) in both directions. I am using DMDA.
> Two things that I am looking for are:
> How to setup the matrix ?
> Since I have 3 variables at each grid point, how to fill the jacobian
> matrix.
> Is there an existing example that comes close to this situation. My search
> was not fruitful.
No. You want 2 DAs, 1 for evaluating residuals with s = 3, and one for
making a Jacobian with s = 1. You give these
two DAs to
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/DMDASNESSetFunctionLocal.html
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/DMDASNESSetJacobianLocal.html
and I think it should work as you want. Its too bad we cannot handle this
case with SNESSetDM() since it only takes
a single DM and there is no way to specialize the Jacobian.
Matt
Thank you
> praveen
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170910/2167d541/attachment.html>
