[petsc-users] configuration error
Smith, Barry F. bsmith at mcs.anl.gov
Tue Oct 31 16:25:34 CDT 2017
  Manav,
    Thanks for reporting the problem
  Fande,
    Thanks for the pointer.
    Satish determined the correct long term fix and it is in the branch barry/fix-lto_library-option-maint and will be put in the maint branch and master branch if it passes the testing tonight.
   Barry
> On Oct 30, 2017, at 11:36 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> We had exactly the same issue when upgraded compilers.  I guess this is somehow related to gfortran.  A simple way to work around for us is to change if with_rpath: to  if False at line 54 of config/BuildSystem/config/libraries.py.
> Not sure if it works for you.
> Fande,
> On Mon, Oct 30, 2017 at 10:14 AM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
>   I am trying to install pets 3.8 on a new MacBook machine with OS 10.13. I have installed openmpi from macports and I am getting this error on configuration. Attached is also the configure.log file.
>   I am not sure how to proceed with this. Any advice will be greatly appreciated!
> Regards,
> Manav
>              Configuring PETSc to compile on your system
> ===============================================================================        ***** WARNING: Using default optimization C flags -g -O3        You might consider manually setting optimal optimization flags for your system with        COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        ***** WARNING: Using default C++ optimization flags -g -O3        You might consider manually setting optimal optimization flags for your system with        CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        ***** WARNING: Using default FORTRAN optimization flags -g -O        You might consider manually setting optimal optimization flags for your system with        FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        WARNING! Compiling PETSc with no debugging, this should        only be done for timing and production runs. All development should        be done when configured using --with-debugging=1        ===============================================================================        TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:171)        *******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> C libraries cannot directly be used from Fortran
