[petsc-users] configuration error
    Satish Balay
    balay at mcs.anl.gov
    Mon Oct 30 18:14:54 CDT 2017
--prefix=/Users/manav/Documents/codes/numerical_lib/petsc/petsc-3.8.0/../
You have a strange prefix. You are basically using:
The general convention is to use a different prefix for different versions of libraries [or different type of builds]
Can you redo a clean build [i.e rm -rf PETSC_ARCH]  into a clean prefix location?
Satish
On Mon, 30 Oct 2017, Manav Bhatia wrote:
> I am not getting errors with mumps (please see below).
> Interestingly, I just compiled this on another machine with clang-3.8 and gfortran-6.7 without problems.
> -Manav
> mumps_c.c:307:53: error: no member named 'nnz' in 'CMUMPS_STRUC_C'; did you mean 'nz'?
>         mumps_par->n=0; mumps_par->nz=0; mumps_par->nnz=0; mumps_par->nz_loc=0; mumps_par->nnz_loc=0; mumps_par->nelt=0;mumps_par->instance_number=0;mumps_par->deficiency=0;mumps_par->lwk_user=0;mumps_par->size_schur=0;mumps_par->lrhs=0; mumps_par->lredrhs=0; mumps_par->nrhs=0; mumps_par->nz_rhs=0; mumps_par->lsol_loc=0;
>                                                     nz
> /Users/manav/Documents/codes/numerical_lib/petsc/include/cmumps_c.h:56:20: note: 'nz' declared here
>     MUMPS_INT      nz;
> mumps_c.c:307:92: error: no member named 'nnz_loc' in 'CMUMPS_STRUC_C'; did you mean 'nz_loc'?
>        nz_loc
> /Users/manav/Documents/codes/numerical_lib/petsc/include/cmumps_c.h:62:20: note: 'nz_loc' declared here
>     MUMPS_INT      nz_loc;
> mumps_c.c:419:42: error: no member named 'nnz' in 'CMUMPS_STRUC_C'; did you mean 'nz'?
>           &(mumps_par->nz), &(mumps_par->nnz), irn, &irn_avail, jcn, &jcn_avail, a, &a_avail,
>                                          nz
>     MUMPS_INT      nz;
> mumps_c.c:420:46: error: no member named 'nnz_loc' in 'CMUMPS_STRUC_C'; did you mean 'nz_loc'?
>           &(mumps_par->nz_loc), &(mumps_par->nnz_loc), irn_loc, &irn_loc_avail, jcn_loc, &jcn_loc_avail,
>                                              nz_loc
>     MUMPS_INT      nz_loc;
> mumps_c.c:419:29: warning: incompatible pointer types passing 'int *' to parameter of type 'int64_t *' (aka 'long long *') [-Wincompatible-pointer-types]
> mumps_c.c:99:28: note: passing argument to parameter 'nnz' here
>            MUMPS_INT8     *nnz,
> mumps_c.c:420:33: warning: incompatible pointer types passing 'int *' to parameter of type 'int64_t *' (aka 'long long *') [-Wincompatible-pointer-types]
> mumps_c.c:107:28: note: passing argument to parameter 'nnz_loc' here
>            MUMPS_INT8     *nnz_loc,
> 2 warnings and 4 errors generated.
> > On Oct 30, 2017, at 11:36 AM, Kong, Fande <fande.kong at inl.gov> wrote:
> > We had exactly the same issue when upgraded compilers.  I guess this is somehow related to gfortran.  A simple way to work around for us is to change if with_rpath: to  if False at line 54 of config/BuildSystem/config/libraries.py.
> > Not sure if it works for you.
> > Fande,
> > On Mon, Oct 30, 2017 at 10:14 AM, Manav Bhatia <bhatiamanav at gmail.com <mailto:bhatiamanav at gmail.com>> wrote:
> > Hi,
> >   I am trying to install pets 3.8 on a new MacBook machine with OS 10.13. I have installed openmpi from macports and I am getting this error on configuration. Attached is also the configure.log file.
> >   I am not sure how to proceed with this. Any advice will be greatly appreciated!
> > Regards,
> > Manav
> >              Configuring PETSc to compile on your system
> > ===============================================================================        ***** WARNING: Using default optimization C flags -g -O3        You might consider manually setting optimal optimization flags for your system with        COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        ***** WARNING: Using default C++ optimization flags -g -O3        You might consider manually setting optimal optimization flags for your system with        CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        ***** WARNING: Using default FORTRAN optimization flags -g -O        You might consider manually setting optimal optimization flags for your system with        FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples        ===============================================================================        ===============================================================================        WARNING! Compiling PETSc with no debugging, this should        only be done for timing and production runs. All development should        be done when configured using --with-debugging=1        ===============================================================================        TESTING: checkCLibraries from config.compilers(config/BuildSystem/config/compilers.py:171)        *******************************************************************************
> >          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> > C libraries cannot directly be used from Fortran
