[petsc-users] Parallelizing a matrix-free code
Michael Werner michael.werner at dlr.de
Tue Oct 17 05:08:16 CDT 2017
Because usally this code is called just once. It runs one multiple
processes, but there it's still always processing the whole domain. I
can't run it on only one subdomain. As I understand it now, when I call
it from PETSc, this call is issued once per process, so I would end up
running several contesting instances of the computation on the whole domain.
But maybe that's only because I haven't completly understood how MPI
really works in such cases...
Kind regards,
Michael
Am 17.10.2017 um 11:50 schrieb Matthew Knepley:
> On Tue, Oct 17, 2017 at 5:46 AM, Michael Werner <michael.werner at dlr.de
> <mailto:michael.werner at dlr.de>> wrote:
>     I'm not sure what you mean with this question?
>     The external CFD code, if that was what you referred to, can be
>     run in parallel.
> Then why is it a problem that "in a parallel case, this call obviously
> gets called once per process"?
>    Matt
>     Am 17.10.2017 um 11:11 schrieb Matthew Knepley:
>>     On Tue, Oct 17, 2017 at 4:21 AM, Michael Werner
>>     <michael.werner at dlr.de <mailto:michael.werner at dlr.de>> wrote:
>>         That's something I'm still struggling with. In the serial
>>         case, I can simply extract the values from the original grid,
>>         and since the ordering of the Jacobian is the same there is
>>         no problem. In the parallel case this is still a more or less
>>         open question. That's why I thought about reordering the
>>         Jacobian. As long as the position of the individual IDs is
>>         the same for both, I don't have to care about their absolute
>>         position.
>>         I also wanted to thank you for your previous answer, it seems
>>         that the application ordering might be what I'm looking for.
>>         However, in the meantime I stumbled about another problem,
>>         that I have to solve first. My new problem is, that I call
>>         the external code within the shell matrix' multiply call. But
>>         in a parallel case, this call obviously gets called once per
>>         process. So right now I'm trying to circumvent this, so it
>>         might take a while before I'm able to come back to the
>>         original problem...
>>     I am not understanding. Is your original code parallel?
>>       Thanks,
>>          Matt
>>         Kind regards,
>>         Michael
>>         Am 16.10.2017 um 17:25 schrieb Praveen C:
>>>         I am interested to learn more about how this works. How are
>>>         the vectors created if the ids are not contiguous in a
>>>         partition ?
>>>         Thanks
>>>         praveen
>>>         On Mon, Oct 16, 2017 at 2:02 PM, Stefano Zampini
>>>         <stefano.zampini at gmail.com
>>>         <mailto:stefano.zampini at gmail.com>> wrote:
>>>             2017-10-16 10:26 GMT+03:00 Michael Werner
>>>             <michael.werner at dlr.de <mailto:michael.werner at dlr.de>>:
>>>                 Hello,
>>>                 I'm having trouble with parallelizing a matrix-free
>>>                 code with PETSc. In this code, I use an external CFD
>>>                 code to provide the matrix-vector product for an
>>>                 iterative solver in PETSc. To increase convergence
>>>                 rate, I'm using an explicitly stored Jacobian matrix
>>>                 to precondition the solver. This works fine for
>>>                 serial runs. However, when I try to use multiple
>>>                 processes, I face the problem that PETSc decomposes
>>>                 the preconditioner matrix, and probably also the
>>>                 shell matrix, in a different way than the external
>>>                 CFD code decomposes the grid.
>>>                 The Jacobian matrix is built in a way, that its rows
>>>                 and columns correspond to the global IDs of the
>>>                 individual points in my CFD mesh
>>>                 The CFD code decomposes the domain based on the
>>>                 proximity of points to each other, so that the
>>>                 resulting subgrids are coherent. However, since its
>>>                 an unstructured grid, those subgrids are not
>>>                 necessarily made up of points with successive global
>>>                 IDs. This is a problem, since PETSc seems to
>>>                 partition the matrix in  coherent slices.
>>>                 I'm not sure what the best approach to this problem
>>>                 might be. Is it maybe possible to exactly tell
>>>                 PETSc, which rows/columns it should assign to the
>>>                 individual processes?
>>>             If you are explicitly setting the values in your
>>>             Jacobians via MatSetValues(), you can create a
>>>             ISLocalToGlobalMapping
>>>             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html
>>>             <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html>
>>>             that maps the numbering you use for the Jacobians to
>>>             their counterpart in the CFD ordering, then call
>>>             MatSetLocalToGlobalMapping and then use
>>>             MatSetValuesLocal with the same arguments you are
>>>             calling MatSetValues now.
>>>             Otherwise, you can play with the application ordering
>>>             http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/index.html
>>>             <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/index.html>
>>>             Stefano
>>         ____________________________________________________
>>         Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
>>         Institut für Aerodynamik und Strömungstechnik |Bunsenstr. 10 | 37073 Göttingen
>>         <https://maps.google.com/?q=Bunsenstr.+10+%7C+37073+G%C3%B6ttingen&entry=gmail&source=g>
>>         Michael Werner
>>         Telefon 0551 709-2627 | Telefax 0551 709-2811 |Michael.Werner at dlr.de <mailto:Michael.Werner at dlr.de>
>>         DLR.de
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
>>     https://www.cse.buffalo.edu/~knepley/
>>     <http://www.caam.rice.edu/%7Emk51/>
>     Michael Werner
>     DLR.de
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 | 37073 Göttingen
Michael Werner
Telefon 0551 709-2627 | Telefax 0551 709-2811 | Michael.Werner at dlr.de
DLR.de
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171017/d6e9a489/attachment-0001.html>
