[petsc-users] Parallelizing a matrix-free code
Tue Oct 17 04:50:58 CDT 2017
On Tue, Oct 17, 2017 at 5:46 AM, Michael Werner <michael.werner at dlr.de>
wrote:
> I'm not sure what you mean with this question?
> The external CFD code, if that was what you referred to, can be run in
> parallel.
Then why is it a problem that "in a parallel case, this call obviously gets
called once per process"?
   Matt
> Am 17.10.2017 um 11:11 schrieb Matthew Knepley:
> On Tue, Oct 17, 2017 at 4:21 AM, Michael Werner <michael.werner at dlr.de>
> wrote:
>> That's something I'm still struggling with. In the serial case, I can
>> simply extract the values from the original grid, and since the ordering of
>> the Jacobian is the same there is no problem. In the parallel case this is
>> still a more or less open question. That's why I thought about reordering
>> the Jacobian. As long as the position of the individual IDs is the same for
>> both, I don't have to care about their absolute position.
>> I also wanted to thank you for your previous answer, it seems that the
>> application ordering might be what I'm looking for. However, in the
>> meantime I stumbled about another problem, that I have to solve first. My
>> new problem is, that I call the external code within the shell matrix'
>> multiply call. But in a parallel case, this call obviously gets called once
>> per process. So right now I'm trying to circumvent this, so it might take a
>> while before I'm able to come back to the original problem...
> I am not understanding. Is your original code parallel?
>   Thanks,
>      Matt
>> Kind regards,
>> Michael
>> Am 16.10.2017 um 17:25 schrieb Praveen C:
>> I am interested to learn more about how this works. How are the vectors
>> created if the ids are not contiguous in a partition ?
>> Thanks
>> praveen
>> On Mon, Oct 16, 2017 at 2:02 PM, Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> 2017-10-16 10:26 GMT+03:00 Michael Werner <michael.werner at dlr.de>:
>>>> Hello,
>>>> I'm having trouble with parallelizing a matrix-free code with PETSc. In
>>>> this code, I use an external CFD code to provide the matrix-vector product
>>>> for an iterative solver in PETSc. To increase convergence rate, I'm using
>>>> an explicitly stored Jacobian matrix to precondition the solver. This works
>>>> fine for serial runs. However, when I try to use multiple processes, I face
>>>> the problem that PETSc decomposes the preconditioner matrix, and probably
>>>> also the shell matrix, in a different way than the external CFD code
>>>> decomposes the grid.
>>>> The Jacobian matrix is built in a way, that its rows and columns
>>>> correspond to the global IDs of the individual points in my CFD mesh
>>>> The CFD code decomposes the domain based on the proximity of points to
>>>> each other, so that the resulting subgrids are coherent. However, since its
>>>> an unstructured grid, those subgrids are not necessarily made up of points
>>>> with successive global IDs. This is a problem, since PETSc seems to
>>>> partition the matrix in  coherent slices.
>>>> I'm not sure what the best approach to this problem might be. Is it
>>>> maybe possible to exactly tell PETSc, which rows/columns it should assign
>>>> to the individual processes?
>>> If you are explicitly setting the values in your Jacobians via
>>> MatSetValues(), you can create a ISLocalToGlobalMapping
>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>> IS/ISLocalToGlobalMappingCreate.html
>>> that maps the numbering you use for the Jacobians to their counterpart
>>> in the CFD ordering, then call MatSetLocalToGlobalMapping and then use
>>> MatSetValuesLocal with the same arguments you are calling MatSetValues now.
>>> Otherwise, you can play with the application ordering
>>> AO/index.html
>>> Stefano
>> ____________________________________________________
>> Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
>> Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 | 37073 Göttingen <https://maps.google.com/?q=Bunsenstr.+10+%7C+37073+G%C3%B6ttingen&entry=gmail&source=g>
>> Michael Werner
>> Telefon 0551 709-2627 | Telefax 0551 709-2811 | Michael.Werner at dlr.de
>> DLR.de
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
> Michael Werner
> DLR.de
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171017/a15a650f/attachment.html>
