[petsc-users] Parallelizing a matrix-free code
Tue Oct 17 05:31:51 CDT 2017
On Tue, Oct 17, 2017 at 6:08 AM, Michael Werner <michael.werner at dlr.de>
wrote:
> Because usally this code is called just once. It runs one multiple
> processes, but there it's still always processing the whole domain. I can't
> run it on only one subdomain. As I understand it now, when I call it from
> PETSc, this call is issued once per process, so I would end up running
> several contesting instances of the computation on the whole domain.
> But maybe that's only because I haven't completly understood how MPI
> really works in such cases...
No, it makes one call in which all processes participate. So you would call
your external CFD routine once from all processes, passing in the MPI
communicator.
   Matt
> Kind regards,
> Michael
> Am 17.10.2017 um 11:50 schrieb Matthew Knepley:
> On Tue, Oct 17, 2017 at 5:46 AM, Michael Werner <michael.werner at dlr.de>
> wrote:
>> I'm not sure what you mean with this question?
>> The external CFD code, if that was what you referred to, can be run in
>> parallel.
> Then why is it a problem that "in a parallel case, this call obviously
> gets called once per process"?
>    Matt
>> Am 17.10.2017 um 11:11 schrieb Matthew Knepley:
>> On Tue, Oct 17, 2017 at 4:21 AM, Michael Werner <michael.werner at dlr.de>
>> wrote:
>>> That's something I'm still struggling with. In the serial case, I can
>>> simply extract the values from the original grid, and since the ordering of
>>> the Jacobian is the same there is no problem. In the parallel case this is
>>> still a more or less open question. That's why I thought about reordering
>>> the Jacobian. As long as the position of the individual IDs is the same for
>>> both, I don't have to care about their absolute position.
>>> I also wanted to thank you for your previous answer, it seems that the
>>> application ordering might be what I'm looking for. However, in the
>>> meantime I stumbled about another problem, that I have to solve first. My
>>> new problem is, that I call the external code within the shell matrix'
>>> multiply call. But in a parallel case, this call obviously gets called once
>>> per process. So right now I'm trying to circumvent this, so it might take a
>>> while before I'm able to come back to the original problem...
>> I am not understanding. Is your original code parallel?
>>   Thanks,
>>      Matt
>>> Kind regards,
>>> Michael
>>> Am 16.10.2017 um 17:25 schrieb Praveen C:
>>> I am interested to learn more about how this works. How are the vectors
>>> created if the ids are not contiguous in a partition ?
>>> Thanks
>>> praveen
>>> On Mon, Oct 16, 2017 at 2:02 PM, Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>>> 2017-10-16 10:26 GMT+03:00 Michael Werner <michael.werner at dlr.de>:
>>>>> Hello,
>>>>> I'm having trouble with parallelizing a matrix-free code with PETSc.
>>>>> In this code, I use an external CFD code to provide the matrix-vector
>>>>> product for an iterative solver in PETSc. To increase convergence rate, I'm
>>>>> using an explicitly stored Jacobian matrix to precondition the solver. This
>>>>> works fine for serial runs. However, when I try to use multiple processes,
>>>>> I face the problem that PETSc decomposes the preconditioner matrix, and
>>>>> probably also the shell matrix, in a different way than the external CFD
>>>>> code decomposes the grid.
>>>>> The Jacobian matrix is built in a way, that its rows and columns
>>>>> correspond to the global IDs of the individual points in my CFD mesh
>>>>> The CFD code decomposes the domain based on the proximity of points to
>>>>> each other, so that the resulting subgrids are coherent. However, since its
>>>>> an unstructured grid, those subgrids are not necessarily made up of points
>>>>> with successive global IDs. This is a problem, since PETSc seems to
>>>>> partition the matrix in  coherent slices.
>>>>> I'm not sure what the best approach to this problem might be. Is it
>>>>> maybe possible to exactly tell PETSc, which rows/columns it should assign
>>>>> to the individual processes?
>>>> If you are explicitly setting the values in your Jacobians via
>>>> MatSetValues(), you can create a ISLocalToGlobalMapping
>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>> IS/ISLocalToGlobalMappingCreate.html
>>>> that maps the numbering you use for the Jacobians to their counterpart
>>>> in the CFD ordering, then call MatSetLocalToGlobalMapping and then use
>>>> MatSetValuesLocal with the same arguments you are calling MatSetValues now.
>>>> Otherwise, you can play with the application ordering
>>>> AO/index.html
>>>> Stefano
>>> ____________________________________________________
>>> Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
>>> Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 | 37073 Göttingen <https://maps.google.com/?q=Bunsenstr.+10+%7C+37073+G%C3%B6ttingen&entry=gmail&source=g>
>>> Michael Werner
>>> Telefon 0551 709-2627 | Telefax 0551 709-2811 | Michael.Werner at dlr.de
>>> DLR.de
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
>> Michael Werner
>> DLR.de
> experiments lead.
> -- Norbert Wiener
> Michael Werner
> DLR.de
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171017/427be04a/attachment.html>
