[petsc-users] Parallelizing a matrix-free code
Michael Werner michael.werner at dlr.de
Tue Oct 17 04:46:44 CDT 2017
I'm not sure what you mean with this question?
The external CFD code, if that was what you referred to, can be run in
parallel.
Am 17.10.2017 um 11:11 schrieb Matthew Knepley:
> On Tue, Oct 17, 2017 at 4:21 AM, Michael Werner <michael.werner at dlr.de
> <mailto:michael.werner at dlr.de>> wrote:
>     That's something I'm still struggling with. In the serial case, I
>     can simply extract the values from the original grid, and since
>     the ordering of the Jacobian is the same there is no problem. In
>     the parallel case this is still a more or less open question.
>     That's why I thought about reordering the Jacobian. As long as the
>     position of the individual IDs is the same for both, I don't have
>     to care about their absolute position.
>     I also wanted to thank you for your previous answer, it seems that
>     the application ordering might be what I'm looking for. However,
>     in the meantime I stumbled about another problem, that I have to
>     solve first. My new problem is, that I call the external code
>     within the shell matrix' multiply call. But in a parallel case,
>     this call obviously gets called once per process. So right now I'm
>     trying to circumvent this, so it might take a while before I'm
>     able to come back to the original problem...
> I am not understanding. Is your original code parallel?
>   Thanks,
>      Matt
>     Kind regards,
>     Michael
>     Am 16.10.2017 um 17:25 schrieb Praveen C:
>>     I am interested to learn more about how this works. How are the
>>     vectors created if the ids are not contiguous in a partition ?
>>     Thanks
>>     praveen
>>     On Mon, Oct 16, 2017 at 2:02 PM, Stefano Zampini
>>     <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
>>         2017-10-16 10:26 GMT+03:00 Michael Werner
>>         <michael.werner at dlr.de <mailto:michael.werner at dlr.de>>:
>>             Hello,
>>             I'm having trouble with parallelizing a matrix-free code
>>             with PETSc. In this code, I use an external CFD code to
>>             provide the matrix-vector product for an iterative solver
>>             in PETSc. To increase convergence rate, I'm using an
>>             explicitly stored Jacobian matrix to precondition the
>>             solver. This works fine for serial runs. However, when I
>>             try to use multiple processes, I face the problem that
>>             PETSc decomposes the preconditioner matrix, and probably
>>             also the shell matrix, in a different way than the
>>             external CFD code decomposes the grid.
>>             The Jacobian matrix is built in a way, that its rows and
>>             columns correspond to the global IDs of the individual
>>             points in my CFD mesh
>>             The CFD code decomposes the domain based on the proximity
>>             of points to each other, so that the resulting subgrids
>>             are coherent. However, since its an unstructured grid,
>>             those subgrids are not necessarily made up of points with
>>             successive global IDs. This is a problem, since PETSc
>>             seems to partition the matrix in  coherent slices.
>>             I'm not sure what the best approach to this problem might
>>             be. Is it maybe possible to exactly tell PETSc, which
>>             rows/columns it should assign to the individual processes?
>>         If you are explicitly setting the values in your Jacobians
>>         via MatSetValues(), you can create a ISLocalToGlobalMapping
>>         http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html
>>         <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/IS/ISLocalToGlobalMappingCreate.html>
>>         that maps the numbering you use for the Jacobians to their
>>         counterpart in the CFD ordering, then call
>>         MatSetLocalToGlobalMapping and then use MatSetValuesLocal
>>         with the same arguments you are calling MatSetValues now.
>>         Otherwise, you can play with the application ordering
>>         http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/index.html
>>         <http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/AO/index.html>
>>         Stefano
>     ____________________________________________________
>     Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
>     Institut für Aerodynamik und Strömungstechnik |Bunsenstr. 10 | 37073 Göttingen
>     <https://maps.google.com/?q=Bunsenstr.+10+%7C+37073+G%C3%B6ttingen&entry=gmail&source=g>
>     Michael Werner
>     Telefon 0551 709-2627 | Telefax 0551 709-2811 |Michael.Werner at dlr.de <mailto:Michael.Werner at dlr.de>
>     DLR.de
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 | 37073 Göttingen
Michael Werner
Telefon 0551 709-2627 | Telefax 0551 709-2811 | Michael.Werner at dlr.de
DLR.de
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171017/7c555d20/attachment-0001.html>
