[petsc-users] Good recommendation on meshing package?
Zou, Ling ling.zou at inl.gov
Mon Oct 16 09:40:55 CDT 2017
Matt, thanks for your input.
This is very helpful.
Ling
On Fri, Oct 13, 2017 at 8:13 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 29, 2017 at 11:06 AM, Zou, Ling <ling.zou at inl.gov> wrote:
>> Hi all,
>> I know this is a bit off topic on PETSc email list.
>> I would like to try some finite volume type of CFD algorithm with PETSc,
>> but I found it quite troublesome to manage mesh by myself.
>> I wonder if there is any good existing meshing package that works well
>> with PTESc.
> It possible you could use the DMPlex support in PETSc.
>> My expectation on such a package would be:
>> 1) I create the mesh with some tool.
> We support at least GMsh, ExodusII, PLY, Triangle, and TetGen.
>> 2) Read this mesh with the meshing package, so I have things like node
>> set, edge set, cell set, etc. to play with
>> 3) discretize my PDE with the mesh
>> 4) solve it
>> I also understand many people here use PETSc solve their CFD problem.
>> I would appreciate it if you could also point me to some good examples.
> There are a bunch of tests, like src/dm/impls/plex/examples/tests/ex1
> which reads in a mesh and views it, and also
> some examples of solving PDEs, all elliptic, such as SNES ex12, ex62, and
> ex77 and TS ex45, ex46, and ex47.
>   Thanks,
>      Matt
>> Best,
>> Ling
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.caam.rice.edu_-7Emk51_&d=DwMFaQ&c=54IZrppPQZKX9mLzcGdPfFD1hxrcB__aEkJFOKJFd00&r=kuHHom1yjd94zUrBWecnYg&m=gmI1ahF3wlxKEGudlMA6bQdzsd8kgF_uZlMp24sdByY&s=MNy3ow4W37g2Bu_H7IWtV4QOguUeJKbY6-xWOEAB28M&e=>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171016/e9ac3dc3/attachment.html>
