[petsc-users] Issue of mg_coarse_ksp not converge
Mark Adams
mfadams at lbl.gov
Mon Oct 2 10:49:20 CDT 2017
Whenbo, do you build your PETSc?
On Mon, Oct 2, 2017 at 11:45 AM, Mark Adams <mfadams at lbl.gov> wrote:
> This is normal:
> Linear st_gamg_est_ solve did not converge due to DIVERGED_ITS iterations
> 10
> It looks like ksp->errorifnotconverged got set somehow. If the default
> changed in KSP then (SAGG) GAMG would not ever work.
> I assume you don't have a .petscrc file with more (crazy) options in it
> On Mon, Oct 2, 2017 at 11:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
> wrote:
>> On Mon, Oct 2, 2017 at 11:30 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Oct 2, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> non-smoothed aggregation is converging very fast. smoothed fails in the
>>>> eigen estimator.
>>>> Run this again with -st_gamg_est_ksp_view and -st_gamg_est_ksp_monitor,
>>>> and see if you get more output (I'm not 100% sure about these args).
>>> I also want -st_gamg_est_ksp_converged_reason
>>> Thanks,
>>> Matt
>> $make NCORE=1 runkr_smooth
>> mpirun -n 1 ./step-41 \
>> -st_ksp_type gmres -st_ksp_view -st_ksp_monitor \
>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>> -mata AMAT.dat -matb BMAT.dat \
>> -st_gamg_est_ksp_view -st_gamg_est_ksp_monitor \
>> -st_gamg_est_ksp_converged_reason \
>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_smooth 2>&1
>> makefile:43: recipe for target 'runkr_smooth' failed
>> make: *** [runkr_smooth] Error 91
>> Thanks
>> Wenbo
>>>> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>> wrote:
>>>>> Matt,
>>>>> Test 1 nonsmooth
>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1
>>>>> runkr_nonsmooth
>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>>>>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_nonsmooth 2>&1
>>>>> Test 2 smooth
>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_smooth
>>>>> Thanks,
>>>>> Wenbo
>>>>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com
>>>>>> > wrote:
>>>>>>> Mark,
>>>>>>> Thanks for your reply.
>>>>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor and we
>>>>>>>> can start to debug it.
>>>>>>>> Test 1 with nonsmooth and preonly is OK
>>>>>>> runkr_nonsmooth
>>>>>>> -st_ksp_view -mata AMAT.dat -matb BMAT.dat \
>>>>>>> -st_mg_coarse_ksp_type preonly -st_mg_coarse_ksp_monitor \
>>>>>>> 2>&1
>>>>>>> Test 2 smooth and preonly is not OK
>>>>>>> runkr_smooth
>>>>>>> Test 3 nonsmooth and gmres is not OK
>>>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_gmres
>>>>>>> -st_mg_coarse_ksp_type gmres -st_mg_coarse_ksp_monitor
>>>>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>>> DO NOT DO THIS. Please send the output where you do NOTHING to the
>>>>>> coarse solver.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> -eps_nev 1 -eps_ncv 10 -eps_monitor -log_view > log_gmres 2>&1
>>>>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>>>>> make: *** [runkr_gmres] Error 91
>>>>>>> log-files is attached.
>>>>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>>>>> (diffusion). Where does the asymmetry come from?
>>>>>>> It is a two-group diffusion equations, where group denotes neutron
>>>>>>> enegry discretisation.
>>>>>>> Matrix B consists of neutron diffusion/leakage term, removal term
>>>>>>> and minus neutron scatter source term between different energies, when
>>>>>>> matrix A denotes neutron fission source.
>>>>>>> Diffusion term(Laplace operator) is elliptic and symmetric. Removal
>>>>>>> term is diagonal only. However scatter term is asymmetry since scatter term
>>>>>>> from high energy to low energy is far greater than the term from low to
>>>>>>> high.
>>>>>>> Wenbo
>>>>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <
>>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>>> Matt,
>>>>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>>>>> to test those options.
>>>>>>>>> Wenbo
>>>>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <
>>>>>>>>>>> Matt
>>>>>>>>>>> Because I am not clear about what will happen using 'preonly'
>>>>>>>>>>> for large scale problem.
>>>>>>>>>> The size of the problem has nothing to do with 'preonly'. All it
>>>>>>>>>> means is to apply a preconditioner without a Krylov solver.
>>>>>>>>>>> It seems to use a direct solver from below,
>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>>>>> KSP/KSPPREONLY.html
>>>>>>>>>> However, I still cannot understand why you would change the
>>>>>>>>>> default?
>>>>>>>>>> Matt
>>>>>>>>>>> Thanks!
>>>>>>>>>>> Wenbo
>>>>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>>>>>> Matt,
>>>>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>>>>> But I am not clear about the 'preonly' option. Which solver is
>>>>>>>>>>>>> used in preonly? I wonder if 'preonly' is suitable for large scale problem
>>>>>>>>>>>>> such as 400,000,000 unknowns.
>>>>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>>>>> I mean, why are you setting this at all. Just do not set the
>>>>>>>>>>>> coarse solver. The default should work fine.
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Matt
>>>>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve
>>>>>>>>>>>>>>> two-group neutron diffusion equations with finite difference method. The
>>>>>>>>>>>>>>> grid is 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where B
>>>>>>>>>>>>>>> is diagonally dominant matrix but not symmetry.
>>>>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>>>> ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>> ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only
>>>>>>>>>>>>>>> non-smooths and preonly is OK.
>>>>>>>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>> Test 1
>>>>>>>>>>>>>>> $ make NCORE=1 runkr_nonsmooth
>>>>>>>>>>>>>>> -st_ksp_type gmres \
>>>>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>>>>> Test 2
>>>>>>>>>>>>>>> log_smooth 2>&1
>>>>>>>>>>>>>>> Test 3
>>>>>>>>>>>>>>> log_gmres 2>&1
>>>>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and BMAT.dat.
>>>>>>>>>>>>>>> Is it correct? Or something wrong with my code or
>>>>>>>>>>>>>>> commad-line?
>>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/79cdc244/attachment-0001.html>
