[petsc-users] Issue of mg_coarse_ksp not converge
Mark Adams mfadams at lbl.gov
Mon Oct 2 10:45:45 CDT 2017
This is normal:
Linear st_gamg_est_ solve did not converge due to DIVERGED_ITS iterations 10
It looks like ksp->errorifnotconverged got set somehow. If the default
changed in KSP then (SAGG) GAMG would not ever work.
I assume you don't have a .petscrc file with more (crazy) options in it ...
On Mon, Oct 2, 2017 at 11:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
wrote:
> On Mon, Oct 2, 2017 at 11:30 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Oct 2, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> non-smoothed aggregation is converging very fast. smoothed fails in the
>>> eigen estimator.
>>> Run this again with -st_gamg_est_ksp_view and -st_gamg_est_ksp_monitor,
>>> and see if you get more output (I'm not 100% sure about these args).
>> I also want -st_gamg_est_ksp_converged_reason
>>   Thanks,
>>     Matt
> $make NCORE=1 runkr_smooth
> mpirun -n 1 ./step-41 \
>    -st_ksp_type gmres -st_ksp_view -st_ksp_monitor  \
>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
>    -mata AMAT.dat -matb BMAT.dat \
>    -st_gamg_est_ksp_view -st_gamg_est_ksp_monitor \
>    -st_gamg_est_ksp_converged_reason \
>    -eps_nev 1 -eps_ncv 10  -eps_monitor -log_view > log_smooth 2>&1
> makefile:43: recipe for target 'runkr_smooth' failed
> make: *** [runkr_smooth] Error 91
> Thanks
> Wenbo
>>> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>> wrote:
>>>> Matt,
>>>> Test 1 nonsmooth
>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1
>>>> runkr_nonsmooth
>>>>    -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
>>>>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_nonsmooth 2>&1
>>>> Test 2 smooth
>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_smooth
>>>> Thanks,
>>>> Wenbo
>>>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>>> wrote:
>>>>>> Mark,
>>>>>> Thanks for your reply.
>>>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor and we
>>>>>>> can start to debug it.
>>>>>>> Test 1 with nonsmooth and preonly is OK
>>>>>> runkr_nonsmooth
>>>>>>    -st_ksp_view  -mata AMAT.dat -matb BMAT.dat \
>>>>>>    -st_mg_coarse_ksp_type preonly   -st_mg_coarse_ksp_monitor  \
>>>>>> 2>&1
>>>>>> Test 2 smooth and preonly is not OK
>>>>>> Test 3 nonsmooth and gmres is not OK
>>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_gmres
>>>>>>    -st_mg_coarse_ksp_type gmres  -st_mg_coarse_ksp_monitor
>>>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>> DO NOT DO THIS. Please send the output where you do NOTHING to the
>>>>> coarse solver.
>>>>>   Thanks,
>>>>>      Matt
>>>>>>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_gmres 2>&1
>>>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>>>> make: *** [runkr_gmres] Error 91
>>>>>> log-files is attached.
>>>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>>>> (diffusion). Where does the asymmetry come from?
>>>>>> It is a two-group diffusion equations, where group denotes neutron
>>>>>> enegry discretisation.
>>>>>> Matrix B consists of neutron diffusion/leakage term, removal term and
>>>>>> minus neutron scatter source term between different energies, when matrix A
>>>>>> denotes neutron fission source.
>>>>>> Diffusion term(Laplace operator) is elliptic and symmetric. Removal
>>>>>> term is diagonal only. However scatter term is asymmetry since scatter term
>>>>>> from high energy to low energy is far greater than the term from low to
>>>>>> high.
>>>>>> Wenbo
>>>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com
>>>>>>> > wrote:
>>>>>>>> Matt,
>>>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>>>> to test those options.
>>>>>>>> Wenbo
>>>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <
>>>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>>>> Matt
>>>>>>>>>> Because I am not clear about what will happen using 'preonly' for
>>>>>>>>>> large scale problem.
>>>>>>>>> The size of the problem has nothing to do with 'preonly'. All it
>>>>>>>>> means is to apply a preconditioner without a Krylov solver.
>>>>>>>>>> It seems to use a direct solver from below,
>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>>>> KSP/KSPPREONLY.html
>>>>>>>>> However, I still cannot understand why you would change the
>>>>>>>>> default?
>>>>>>>>>   Matt
>>>>>>>>>> Thanks!
>>>>>>>>>> Wenbo
>>>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <
>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>>>>> Matt,
>>>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>>>> But I am not clear about the 'preonly' option. Which solver is
>>>>>>>>>>>> used in preonly? I wonder if 'preonly' is suitable for large scale problem
>>>>>>>>>>>> such as 400,000,000 unknowns.
>>>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>>>> I mean, why are you setting this at all. Just do not set the
>>>>>>>>>>> coarse solver. The default should work fine.
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>     Matt
>>>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>>>> Thanks.
>>>>>>>>>>>> Wenbo
>>>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve
>>>>>>>>>>>>>> two-group neutron diffusion equations with finite difference method. The
>>>>>>>>>>>>>> grid is 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where B is
>>>>>>>>>>>>>> diagonally dominant matrix but not symmetry.
>>>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>>>  ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>  ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only non-smooths
>>>>>>>>>>>>>> and preonly is OK.
>>>>>>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>> Test 1
>>>>>>>>>>>>>> $ make NCORE=1 runkr_nonsmooth
>>>>>>>>>>>>>>    -st_ksp_type gmres  \
>>>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>>>> Test 2
>>>>>>>>>>>>>> log_smooth 2>&1
>>>>>>>>>>>>>> Test 3
>>>>>>>>>>>>>> log_gmres 2>&1
>>>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and BMAT.dat.
>>>>>>>>>>>>>> Is it correct? Or something wrong with my code or commad-line?
>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/%7Emk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/0261710a/attachment-0001.html>
