[petsc-users] Issue of mg_coarse_ksp not converge
    Wenbo Zhao
    zhaowenbo.npic at gmail.com
    Mon Oct  2 10:56:13 CDT 2017
On Mon, Oct 2, 2017 at 11:49 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Whenbo, do you build your PETSc?
> Yes.
My configure option is listed below
./configure --with-mpi=1 --with-shared-libraries=1 \
            --with-64-bit-indices=1 --with-debugging=1
And I set PETSC_DIR, PETSC_ARCH and SLEPC_DIR in my ~/.bashrc.
The Makefile for my problem is listed below,
PETSC_ARCH = arch-linux2-c-debug
PETSC_DIR = /home/zhaowenbo/research/petsc/petsc_git
SLEPC_DIR = /home/zhaowenbo/research/slepc/slepc_git
#PETSC_DIR = /home/zhaowenbo/research/petsc/petsc-3.7.4
#SLEPC_DIR = /home/zhaowenbo/research/slepc/slepc-3.7.3
HYPRE_DIR = /usr/local/hypre
DEBUG_OPT  = -g
COMP_FLAGS = -fPIC  -Wall  \
  -I${SLEPC_DIR}/include -I${SLEPC_DIR}/${PETSC_ARCH}/include \
  -I${PETSC_DIR}/include -I${PETSC_DIR}/${PETSC_ARCH}/include \
  -Isrc
LINK_FLAGS = -fPIC -Wall  \
  -Wl,-rpath,${SLEPC_DIR}/${PETSC_ARCH}/lib
-L${SLEPC_DIR}/${PETSC_ARCH}/lib -lslepc \
  -Wl,-rpath,${PETSC_DIR}/${PETSC_ARCH}/lib
-L${PETSC_DIR}/${PETSC_ARCH}/lib  -lpetsc \
  -llapack -lblas -lhwloc -lm -lgfortran  -lquadmath
step-41: src/main.o src/readinp.o src/base.o src/sp3.o src/diffu.o
    mpicxx -o step-41 $^  ${LINK_FLAGS} ${DEBUG_OPT}
src/main.o: src/main.c
    mpicxx -o src/main.o -c  $^  ${COMP_FLAGS} ${DEBUG_OPT}
src/readinp.o: src/readinp.c
    mpicxx -o src/readinp.o -c $^  ${COMP_FLAGS} ${DEBUG_OPT}
src/sp3.o: src/sp3.c
    mpicxx -o src/sp3.o -c $^  ${COMP_FLAGS} ${DEBUG_OPT}
src/diffu.o: src/diffu.c
    mpicxx -o src/diffu.o -c $^  ${COMP_FLAGS} ${DEBUG_OPT}
src/base.o: src/base.c
    mpicxx -o src/base.o -c $^ ${COMP_FLAGS} ${DEBUG_OPT}
clean:
    rm step-41 src/main.o src/readinp.o src/sp3.o src/diffu.o src/base.o
runkr_smooth:
    mpirun -n ${NCORE} ./step-41 \
   -st_ksp_type gmres -st_ksp_view -st_ksp_monitor  \
   -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1 \
   -mata AMAT.dat -matb BMAT.dat \
   -st_gamg_est_ksp_view -st_gamg_est_ksp_monitor \
   -st_gamg_est_ksp_converged_reason \
   -eps_nev 1 -eps_ncv 10  -eps_monitor -log_view > log_smooth 2>&1
runkr_nonsmooth:
   -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 0 \
   -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_nonsmooth 2>&1
Wenbo
> On Mon, Oct 2, 2017 at 11:45 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> This is normal:
>> Linear st_gamg_est_ solve did not converge due to DIVERGED_ITS iterations
>> 10
>> It looks like ksp->errorifnotconverged got set somehow. If the default
>> changed in KSP then (SAGG) GAMG would not ever work.
>> I assume you don't have a .petscrc file with more (crazy) options in it
>> On Mon, Oct 2, 2017 at 11:39 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>> wrote:
>>> On Mon, Oct 2, 2017 at 11:30 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Mon, Oct 2, 2017 at 11:15 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> non-smoothed aggregation is converging very fast. smoothed fails in
>>>>> the eigen estimator.
>>>>> Run this again with -st_gamg_est_ksp_view and
>>>>> -st_gamg_est_ksp_monitor, and see if you get more output (I'm not 100% sure
>>>>> about these args).
>>>> I also want -st_gamg_est_ksp_converged_reason
>>>>   Thanks,
>>>>     Matt
>>> $make NCORE=1 runkr_smooth
>>> mpirun -n 1 ./step-41 \
>>> makefile:43: recipe for target 'runkr_smooth' failed
>>> make: *** [runkr_smooth] Error 91
>>> Thanks
>>> Wenbo
>>>>> On Mon, Oct 2, 2017 at 11:06 AM, Wenbo Zhao <zhaowenbo.npic at gmail.com>
>>>>> wrote:
>>>>>> Matt,
>>>>>> Test 1 nonsmooth
>>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1
>>>>>> runkr_nonsmooth
>>>>>> 2>&1
>>>>>> Test 2 smooth
>>>>>> zhaowenbo at ubuntu:~/test_slepc/SPARK/spark$ make NCORE=1 runkr_smooth
>>>>>> Thanks,
>>>>>> Wenbo
>>>>>> On Mon, Oct 2, 2017 at 10:48 PM, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Mon, Oct 2, 2017 at 10:43 AM, Wenbo Zhao <
>>>>>>> zhaowenbo.npic at gmail.com> wrote:
>>>>>>>> Mark,
>>>>>>>> Thanks for your reply.
>>>>>>>> On Mon, Oct 2, 2017 at 9:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> Please send the output with -st_ksp_view and -st_ksp_monitor and
>>>>>>>>> we can start to debug it.
>>>>>>>>> Test 1 with nonsmooth and preonly is OK
>>>>>>>> runkr_nonsmooth
>>>>>>>>    -st_ksp_view  -mata AMAT.dat -matb BMAT.dat \
>>>>>>>>    -st_mg_coarse_ksp_type preonly   -st_mg_coarse_ksp_monitor  \
>>>>>>>> 2>&1
>>>>>>>> Test 2 smooth and preonly is not OK
>>>>>>>> runkr_smooth
>>>>>>>> Test 3 nonsmooth and gmres is not OK
>>>>>>>> runkr_gmres
>>>>>>>>    -st_mg_coarse_ksp_type gmres  -st_mg_coarse_ksp_monitor
>>>>>>>> -st_mg_coarse_ksp_rtol 1.0e-6 \
>>>>>>> DO NOT DO THIS. Please send the output where you do NOTHING to the
>>>>>>> coarse solver.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>>    -eps_nev 1 -eps_ncv 10  -eps_monitor  -log_view > log_gmres 2>&1
>>>>>>>> makefile:59: recipe for target 'runkr_gmres' failed
>>>>>>>> make: *** [runkr_gmres] Error 91
>>>>>>>> log-files is attached.
>>>>>>>> You mentioned that B is not symmetric. I assume it is elliptic
>>>>>>>>> (diffusion). Where does the asymmetry come from?
>>>>>>>> It is a two-group diffusion equations, where group denotes neutron
>>>>>>>> enegry discretisation.
>>>>>>>> Matrix B consists of neutron diffusion/leakage term, removal term
>>>>>>>> and minus neutron scatter source term between different energies, when
>>>>>>>> matrix A denotes neutron fission source.
>>>>>>>> Diffusion term(Laplace operator) is elliptic and symmetric. Removal
>>>>>>>> term is diagonal only. However scatter term is asymmetry since scatter term
>>>>>>>> from high energy to low energy is far greater than the term from low to
>>>>>>>> high.
>>>>>>>> Wenbo
>>>>>>>>> On Mon, Oct 2, 2017 at 9:39 AM, Wenbo Zhao <
>>>>>>>>>> Matt,
>>>>>>>>>> For the defalt option doesnt work firstly( -st_ksp_type gmres
>>>>>>>>>> -st_pc_type gamg -st_pc_gamg_type agg -st_pc_gamg_agg_nsmooths 1), I tried
>>>>>>>>>> to test those options.
>>>>>>>>>> Wenbo
>>>>>>>>>> On Mon, Oct 2, 2017 at 9:08 PM, Matthew Knepley <
>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>> On Mon, Oct 2, 2017 at 8:30 AM, Wenbo Zhao <
>>>>>>>>>>>> Matt
>>>>>>>>>>>> Because I am not clear about what will happen using 'preonly'
>>>>>>>>>>>> for large scale problem.
>>>>>>>>>>> The size of the problem has nothing to do with 'preonly'. All it
>>>>>>>>>>> means is to apply a preconditioner without a Krylov solver.
>>>>>>>>>>>> It seems to use a direct solver from below,
>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/
>>>>>>>>>>>> KSP/KSPPREONLY.html
>>>>>>>>>>> However, I still cannot understand why you would change the
>>>>>>>>>>> default?
>>>>>>>>>>>   Matt
>>>>>>>>>>>> Thanks!
>>>>>>>>>>>> Wenbo
>>>>>>>>>>>> On Mon, Oct 2, 2017 at 5:09 PM, Matthew Knepley <
>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 9:53 PM, Wenbo Zhao <
>>>>>>>>>>>>>> Matt,
>>>>>>>>>>>>>> It DOES make no sense for this problem.
>>>>>>>>>>>>>> But I am not clear about the 'preonly' option. Which solver
>>>>>>>>>>>>>> is used in preonly? I wonder if 'preonly' is suitable for large scale
>>>>>>>>>>>>>> problem such as 400,000,000 unknowns.
>>>>>>>>>>>>>> So I tried 'gmres' option and found these error messages.
>>>>>>>>>>>>> I mean, why are you setting this at all. Just do not set the
>>>>>>>>>>>>> coarse solver. The default should work fine.
>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>> Could you give me some suggestions?
>>>>>>>>>>>>>> Thanks.
>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>> On Mon, Oct 2, 2017 at 12:34 AM, Matthew Knepley <
>>>>>>>>>>>>>>> On Sun, Oct 1, 2017 at 6:49 AM, Wenbo Zhao <
>>>>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>>>>> I met some questions when I use PETSC/SLEPC to solve
>>>>>>>>>>>>>>>> two-group neutron diffusion equations with finite difference method. The
>>>>>>>>>>>>>>>> grid is 3*3*3, when DOF on each points is 2. So the matrix size is 54*54.
>>>>>>>>>>>>>>>> It is generalized eigenvalue problem Ax=\lamda Bx, where B
>>>>>>>>>>>>>>>> is diagonally dominant matrix but not symmetry.
>>>>>>>>>>>>>>>> EPS is set as below,
>>>>>>>>>>>>>>>>  ierr = EPSSetProblemType(eps,EPS_GNHEP);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>>>  ierr = EPSSetWhichEigenpairs(eps,EPS_
>>>>>>>>>>>>>>>> LARGEST_REAL);CHKERRQ(ierr);¬
>>>>>>>>>>>>>>>> Krylovschur is used as eps sovler. GAMG is used as PC.
>>>>>>>>>>>>>>>> I tried agg_nsmooths and mg_coarse_ksp_type. Only
>>>>>>>>>>>>>>>> non-smooths and preonly is OK.
>>>>>>>>>>>>>>> Why are you setting the coarse solver. This makes no sense.
>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>> Test 1
>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_nonsmooth
>>>>>>>>>>>>>>>>    -st_ksp_type gmres  \
>>>>>>>>>>>>>>>> log_nonsmooth 2>&1
>>>>>>>>>>>>>>>> Test 2
>>>>>>>>>>>>>>>> log_smooth 2>&1
>>>>>>>>>>>>>>>> Test 3
>>>>>>>>>>>>>>>> $ make NCORE=1 runkr_gmres
>>>>>>>>>>>>>>>> log_gmres 2>&1
>>>>>>>>>>>>>>>> Log files were attched.
>>>>>>>>>>>>>>>> The matrix file were also attched as AMAT.dat and BMAT.dat.
>>>>>>>>>>>>>>>> Is it correct? Or something wrong with my code or
>>>>>>>>>>>>>>>> commad-line?
>>>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>>> Wenbo
>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>> their experiments lead.
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>>>>>> <http://www.caam.rice.edu/%7Emk51/>
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20171002/b445b6c0/attachment-0001.html>
