[petsc-users] petsc-3.5 quadruple precision mixed with double
Matthew Knepley
knepley at gmail.com
Wed Jun 28 21:02:35 CDT 2017
On Wed, Jun 28, 2017 at 9:00 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> thanks, @Matthew
> I was worried about this. is there a way to convert double to PetscScalar?
C cast.
> incompressible code are double type everywhere else except for PETSc.
> could this be the problem?
I doubt using high precision only in the solve will make much difference,
certainly not 10^{-14}.
Matt
> it was double type for the entire code including PETSc before this
> quadruple test.
> On Wed, Jun 28, 2017 at 9:27 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jun 28, 2017 at 8:22 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
>>> It's 3d incompressible RT simulation. My pressure between serial and
>>> parallel calculation is off by 10^(-14) in relative error.
>> This could just be reordering of the calculation.
>>> it eventually build up at later time. I want to rule out the
>>> possibilities that PETSc give me bad solution. pressure scale is 10^(-2).
>>> I use PetscScalar. thanks @Jed Brown for confirming that but I have
>>> Segmentation Violation when retrieving x. I allocated memory for the array
>>> x (PetscScalar type). if not for quadruple precision, there is no error.
>> It sounds like maybe you are passing a double where a PetscScalar is
>> expected, or vice versa. Run under valgrind.
>> Matt
>>> thanks @Satish Balay. I will update code petsc-3.7 later.
>> experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/
> hao
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170628/f02230a1/attachment.html>
