[petsc-users] -ksp_pc_side for -pc_fieldsplit_schur_fact_type upper
Hoang Giang Bui
hgbk2008 at gmail.com
Mon Jun 26 17:03:02 CDT 2017
Thanks Barry for the paper. I also noticed that the block lower
preconditioner also has the same minimal polynomial (the proof is similar),
hence left and right preconditioning shall apply the same.
Giang
On Fri, Jun 23, 2017 at 9:14 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Based on my reading of the attached paper, in particular the last line
> on page 1050 I don't think it matters.
> and P−1A and AP−1 have the minimal polynomial (λ − 1)2.
> since the application on either side matches the same polynomial.
> Barry
> > On Jun 23, 2017, at 11:48 AM, Hoang Giang Bui <hgbk2008 at gmail.com>
> wrote:
> > Hello
> > I just want to make sure that I understand the right thing, in the
> manual page of PCFieldSplitSetSchurFactType:
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/PC/
> PCFieldSplitSetSchurFactType.html
> > The "upper" option uses DU from the full factorization. If I understand
> correctly, the ksp must be used with right preconditioning, because A P^-1
> = (LDU) * (DU)^(-1) = L. If that was the case, should the manual put this
> information to be more clear?
> > Thanks
> > Giang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170627/1e1b88c2/attachment.html>
