[petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
Sun Jun 25 12:03:38 CDT 2017
On Tue, Apr 11, 2017 at 9:21 AM, Hassan Raiesi <
Hassan.Raiesi at aero.bombardier.com> wrote:
> Hello,
> I’m trying to use DMPlexCreateFromCellListParallel to create a DM from an
> already partitioned mesh,
> It requires an array of numVertices*spaceDim numbers, but how should one
> order the coordinates of the vertices?
Global order. Here is the idea. You must read the file in chunks so that
each proc can read its own chunk in parallel
without talking to anyone else.
> we only pass the global vertex numbers using ‘const int cells[]’ to define
> the cell-connectivity, so passing the vertex coordinates in local ordering
> wouldn’t make sense?
Yes.
> If it needs to be in global ordering, should I sort the global index of
> the node numbers owned by each rank (as they wont be continuous).
Nope.
    Matt
> Thank you
> Hassan Raiesi,
> Bombardier Aerospace
> www.bombardier.com
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170625/78d8f9e2/attachment.html>
