[petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
Hassan Raiesi
Hassan.Raiesi at aero.bombardier.com
Tue Jun 27 09:12:33 CDT 2017
Thanks for your reply,
Is there any example where each rank owns more than 1 element, i.e for the simple mesh here(attached png file), how should I pack and pass the coordinates of the vertices owned by rank0, rank1
Rank0:numcells = 2; num nodes=4, cells=[154 245] , nodes=[1 5 2 4]
nodes = 1245
vertex coords: in what node order ?
[coords_n1 coords_n2 coords_n4 coords_n5] or
[coords_n2 coords_n4 coords_n1 coords_n5] or …..?
rank1: numcells = 2; num nodes=2, cells=[532 635], nodes=[6 3]
vertexcoords [how to pack the nodes coords here?]
should it be [x6y6 x3y3] or [x3y3 x6y6]? In what order?
thanks
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Sunday, June 25, 2017 1:04 PM
To: Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] specifying vertex coordinates using DMPlexCreateFromCellListParallel
On Tue, Apr 11, 2017 at 9:21 AM, Hassan Raiesi <Hassan.Raiesi at aero.bombardier.com<mailto:Hassan.Raiesi at aero.bombardier.com>> wrote:
Hello,
I’m trying to use DMPlexCreateFromCellListParallel to create a DM from an already partitioned mesh,
It requires an array of numVertices*spaceDim numbers, but how should one order the coordinates of the vertices?
Global order. Here is the idea. You must read the file in chunks so that each proc can read its own chunk in parallel
without talking to anyone else.
we only pass the global vertex numbers using ‘const int cells[]’ to define the cell-connectivity, so passing the vertex coordinates in local ordering wouldn’t make sense?
Yes.
If it needs to be in global ordering, should I sort the global index of the node numbers owned by each rank (as they wont be continuous).
Nope.
Matt
Thank you
Hassan Raiesi,
Bombardier Aerospace
www.bombardier.com<http://www.bombardier.com>
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170627/66b1b543/attachment.html>
Type: image/png
Desc: dmplex_mesh.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170627/66b1b543/attachment.png>
