[petsc-users] PETSC Test
Mohamadreza Soltanian m.rezasoltanian at gmail.com
Wed Jun 14 23:19:08 CDT 2017
Hello Satish
Thank you for your reply. I am using macOS Sierra 10.12.5.
Thanks
On Thu, Jun 15, 2017 at 12:07 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> Likely its hanging in gethostbyname() call - which is caued
> by a mismatch in hostname.
> What OS are you using? If linux - can you do the following?
> sudo echo 127.0.0.1 `hostname` >> /etc/hosts
> And retry?
> Satish
> On Thu, 15 Jun 2017, Mohamadreza Soltanian wrote:
> > Hello All,
> > I am trying to install and test PETSC. When I get to the test part, it
> > seems everything get stuck in the following line. I was wondering if
> anyone
> > can help. Thank you
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> MPI
> > process
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170615/015adeed/attachment.html>
